Problems after adjusting gateway and removing component protection audi a3 8v sportback
Rexhunt
C?ID=389364
After buying a 2013 a3 8v sportback 5 doors I installed the following: (the audi was very bare with factory entry radio)
MF steering wheel, mmi mib std nav, cruise control, led rear lights, rain light sensor, pdc front and rear, gateway high, middle button bar. I got the mf steer and cruise control working already.
Because the gateway and mmi have component protection, I waited with that first. The radio unfortunately did not work due to the CP. I put the old data from the gateway low into the gateway high. then got cruise control working with vcds and the multifunction steering wheel. Then the car kit and bluetooth worked (despite component protection).
However, after the CP was removed from both the gateway and MMI, all of this stopped working, except for the radio. Now I am unable to activate it again.
First (14-05-2021) the auto scan from when I bought the car, the 2nd (04-07-2021) auto scan is after the gateway has been changed by the gateway high and the 3rd (28-07-2021) scan is after removing CP. Who can help me?
Vrijdag,14,Mei,2021,16:56:48:33886
VCDS -- Windows Gebaseerde VAG/VAS Emulator Loopt op Windows 10 x64
VCDS Versie: HZH 19.6.2.1  HEX-NET CB: 0.4513.4
Data versie: 20191019 DS308.0
www.Randstadcarsolutions.nl
VIN: WAUZZZ8V2EA054416   Kenteken: J-061-VV
Kilometrage: 143078km   Reparatie Order:
Gateway Installatie Lijst:  5Q0 907 530 K
01-Motor -- Status: OK 0000
03-ABS Systeem -- Status: Defect 0010
08-Airco/Verwarming -- Status: Defect 0010
09-Centr.Electr. -- Status: Defect 0010
16-Stuurwiel -- Status: OK 0000
17-Instrumenten -- Status: OK 0000
19-CAN-bus Interface -- Status: OK 0000
42-Portierelektr.,LV -- Status: OK 0000
44-Stuurhulp -- Status: OK 0000
52-Portierelectr.,RV -- Status: OK 0000
5F-Informatie Electr. -- Status: OK 0000
Vrijdag,14,Mei,2021,17:02:13:33886
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WAUZZZ8V2EA054416   Kilometrage: 143078km
Adres 01: Motor (J623-CXSA)       Labels:. 04E-907-309-V1.clb
   Onderdeel No SW: 04E 906 016 DE    HW: 04E 907 309 A
   Component: 1.4l R4 TSI   H08 5672
   Revisie: WAH08---
   Codering: 02190012230401082000
   Werkplaats#: WSC 06314 790 00021
   ASAM Dataset: EV_ECM14TFS01104E906016DE 002002
   ROD: EV_ECM14TFS01104E906016DE_AU37.rod
   VCID: E89C1A9913F7050F8E-80BC
Geen Fout Code Gevonden.
Gereedheid: 0000 0000
Adres 03: ABS Systeem (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Onderdeel No SW: 5Q0 907 379 AA    HW: 5Q0 907 379 G
   Revisie: 00000000    Serienummer: 622830000010E1
   Codering: 12F16AA224252A70017B060141C9294856245480608294F2002100788508
   VCID: FBB655D57261BE9773-80AE
1 Fout Gevonden:
32833 - Knop voor elektromechanische parkeerrem
          C100C 01 [008] - Electrische fout
          Intermitterend - Bevestigd - Getest sinds Geheugen Wissen
             Bevries Frame:
                    Fout Status: 00000001
                    Fout Prioriteit: 2
                    Fout Frekwentie: 1
                    Reset teller: 28
                    Kilometrage: 0 km
                    Datum: 2013.08.30
                    Tijd: 00:00:26
Adres 08: Airco/Verwarming (E87)       Labels:| 8V0-820-047.clb
   Onderdeel No SW: 8V0 820 047 C    HW: 8V0 820 047 C
   Component: AC Manuell el H11 0031
   Revisie: 20019000    Serienummer: 00000000025561
   Codering: 03000004000000001000000000000100
   ASAM Dataset: EV_AirCondiFrontManAU37X 008016
   ROD: EV_AirCondiFrontManAU37X.rod
   VCID: B62084E109C3A3FFCC-80E2
1 Fout Gevonden:
262914 - Koelmediumdruk
          B10AB F0 [009] - Onderste grenswaarde onderschreden
             Bevries Frame:
                    Fout Prioriteit: 2
                    Fout Frekwentie: 34
                    Reset teller: 61
                    Kilometrage: 142562 km
                    Datum: 2021.03.24
                    Tijd: 03:06:17
                    Buitentemperatuur: 13.5 °C
                    Motortoerental: 0.00 /min
                    Compressorstroom: werk. waarde: 0.000 A
                    Temperatuur na verdamper: 22.0 °C
                    Koelmediumdruk: 1.0 bar
                    Systeemlooptijd-Motorlooptijd: 0 s
                    Systeemlooptijd-Contact 15 aan: 253 s
Adres 09: Centr.Electr. (J519)       Labels:| 5Q0-937-08X-MV1.clb
   Onderdeel No SW: 5Q0 937 084 T    HW: 5Q0 937 084 T
   Component: BCM MQBAB M+  H14 0112
   Serienummer: 00011321800822
   Codering: 04000846C241005D43A44004001407A80000000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: C9DAFF1D683DDC07B1-809C
   Regelapparaat voor wissermotor:
   Subsysteem 1 - Onderdeel No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 130720  041 0580
   Serienummer:         130805134255
   Codering: 0A47F7
   Lichtschakelaar:
   Subsysteem 2 - Onderdeel No SW: 8V0 941 531 N    HW: 8V0 941 531 N
   Serienummer: 17 06 2013  00000380
3 Fouten Gevonden:
197644 - Aansturing van tankklepontgrendeling
          B1263 01 [009] - Electrische fout
             Bevries Frame:
                    Fout Prioriteit: 4
                    Fout Frekwentie: 3
                    Reset teller: 56
                    Kilometrage: 142565 km
                    Datum: 2021.03.24
                    Tijd: 03:40:21
204546 - Sleutel 2
          B147A 18 [008] - Stroom te laag
             Bevries Frame:
                    Fout Prioriteit: 4
                    Fout Frekwentie: 1
                    Reset teller: 98
                    Kilometrage: 142960 km
                    Datum: 2021.04.29
                    Tijd: 01:16:13
787211 - Ruitensproeierpomp
          B1261 13 [008] - Open Circuit
             Bevries Frame:
                    Fout Prioriteit: 3
                    Fout Frekwentie: 1
                    Reset teller: 67
                    Kilometrage: 142832 km
                    Datum: 2021.04.19
                    Tijd: 15:55:29
Adres 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Onderdeel No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Component: AirbagVW20    011 0361
   Serienummer: 003M2R02UTD%
   Codering: 98CCC0000C0000005C540000004800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: CBD6C5156241CE1783-809E
   Ongevalsensor voor zij-airbag: bestuurderszijde:
   Subsysteem 1 - Onderdeel No SW: -----------    HW: 480 001 008 13
   Serienummer: 357670000003F0898D0+
   Codering: 2D2D2D
   Ongevalsensor voor zij-airbag: bijrijderszijde:
   Subsysteem 2 - Onderdeel No SW: -----------    HW: 480 001 008 13
   Serienummer: 358670000007D0898D01
   Codering: 2D2D2D
   Ongevalsensor voor zij-airbag achterin: bestuurderszijde:
   Subsysteem 3 - Onderdeel No SW: -----------    HW: 480 400 908 13
   Serienummer: 3516502B910EDE43209G
   Codering: 2D2D2D
   Ongevalsensor voor zij-airbag achterin: bijrijderszijde:
   Subsysteem 4 - Onderdeel No SW: -----------    HW: 480 401 908 13
   Serienummer: 3526502A510EDE43037B
   Codering: 2D2D2D
   Ongevalsensor voorairbag: bestuurderszijde:
   Subsysteem 5 - Onderdeel No SW: -----------    HW: 480 401 107 13
   Serienummer: 35565029D106FA44F16O
   Codering: 2D2D2D
   Ongevalsensor voetgangersbesch. bestuurderszijde:
   Subsysteem 6 - Onderdeel No SW: -----------    HW: 480 401 307 13
   Component: PedP_Sensor_D  001 6149
   Serienummer: 22865029F107DB5121AE
   Codering: 2D2D2D
   Ongevalsensor voetgangersbesch. bijrijderszijde:
   Subsysteem 7 - Onderdeel No SW: -----------    HW: 480 400 308 13
   Component: PedP_Sensor_P  001 6149
   Serienummer: 2296502A11088B0302B
   Codering: 2D2D2D
   Ongevalsensor voetgangersbesch. midden:
   Subsysteem 8 - Onderdeel No SW: -----------    HW: 480 400 108 13
   Component: PedP_Sensor_C  001 6149
   Serienummer: 2306502B91074481515V
   Codering: 2D2D2D
Adres 16: Stuurwiel (J527)       Labels:| 5Q0-953-549.clb
   Onderdeel No SW: 8V0 953 521 A    HW: 5Q0 953 549 A
   Revisie: --------    Serienummer: 06081308491156
   Codering: 8618
   VCID: B83C8AD903D7558FDE-80EC
Adres 17: Instrumenten (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Onderdeel No SW: 8V0 920 870 G    HW: 8V0 920 870 G
   Component: KOMBI         H03 2211
   Codering: 078409002380000800000800000000
   VCID: BFCEE1C526F962B71F-80EA
Adres 19: CAN-bus Interface (J533)       Labels:| 5Q0-907-530-V1.clb
   Onderdeel No SW: 5Q0 907 530 K    HW: 5Q0 907 530 D
   Component: GW MQB Low    123 1144
   Revisie: --------    Serienummer: 0000793739
   Codering: 030000042B0864005B000248080B00000001000000000000000000000000
   ROD: EV_GatewLear_009.rod
   VCID: B93A8FDD38DD4C8721-80EC
   Dynamo:
   Regelapparaat voor accubewaking:
   Subsysteem 2 - Onderdeel No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
   Component: J367-BDM  H08 0192
   Serienummer: 00000000004051868592
Adres 42: Portierelektr.,LV (J386)       Labels:| 5QX-959-X93-42.clb
   Onderdeel No SW: 5Q0 959 393 A    HW: 5Q0 959 393
   Component: TSG FS        012 0006
   Serienummer: 02081304080256
   Codering: 00100E204000040000001002
   VCID: BD329BCD2CF570A70D-80E8
   Portierregelapparaat achter: bestuurderszijde:
   Subsysteem 1 - Onderdeel No SW: 5Q0 959 811     HW: 5Q0 959 811   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  005 0004
   Serienummer: 00000000000000411924
   Codering: 110000
Adres 44: Stuurhulp (J500)       Labels:| 5Q0-909-144.clb
   Onderdeel No SW: 5Q0 909 144 L    HW: 5Q0 909 144 M
   Component: EPS_MQB_ZFLS  127 1021
   Codering: 81
   ROD: EV_SteerAssisMQB_008.rod
Adres 52: Portierelectr.,RV (J387)       Labels:| 5QX-959-X92-52.clb
   Onderdeel No SW: 5Q0 959 392 A    HW: 5Q0 959 392
   Component: TSG BFS       012 0006
   Serienummer: 18071303110763
   Codering: 001006204000040000001002
   VCID: BC3496C937EF79AF3A-80E8
   Portierregelapparaat achter: bijrijderszijde:
   Subsysteem 1 - Onderdeel No SW: 5Q0 959 812     HW: 5Q0 959 812   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  005 0004
   Serienummer: 00000000000000397768
   Codering: 090000
Adres 5F: Informatie Electr. (J794)       Labels:* Geen
   Onderdeel No SW: 8V0 035 870 A    HW: 8V0 035 870
   Component: MU-E--ER      170 0107
   Revisie: --------    Serienummer: 000085596001000
   Codering: 017303003C00000010110001000A0000000001040100010000
   ASAM Dataset: EV_MUEnt4CCONT 004052
   ROD: EV_MUEnt4CCONT.rod
   Weergave- en bedieningseenheid 1 informatie-elektronica:
   Subsysteem 1 - Onderdeel No SW: 8V0 035 630     HW: 8V0 035 630
   Component: ABT  160 0016
   Serienummer: VD1BDY18071300210009
Einde-------(Verstreken Tijd: 01:01, VBatt start/eind: 12.2V/12.2V)--------
Zondag,04,Juli,2021,15:35:12:33886
Kilometrage: 143930km   Reparatie Order: 04-07-2021 15:34 uur
Chassis Type: 8V-AU37 (3Q0)
VIN: WAUZZZ8V2EA054416   Kilometrage: 143930km
01-Motor -- Status: Defect 0010
15-Airbags -- Status: Defect 0010
16-Stuurwiel -- Status: Defect 0010
17-Instrumenten -- Status: Defect 0010
19-CAN-bus Interface -- Status: Defect 0010
5F-Informatie Electr. -- Status: Defect 0010
   Revisie: WAH08---
   Codering: 02190012232401082000
4 Fouten Gevonden:
17165 - Databus ontvangen storingswaarde
          U1123 00 [032] - -
          Intermitterend - Niet Bevestigd - Getest sinds Geheugen Wissen
             Bevries Frame:
                    Fout Prioriteit: 6
                    Fout Frekwentie: 1
                    Kilometrage: 143930 km
                    Datum: 2021.07.03
                    Tijd: 20:25:08
                    Genorm. bel.waarde: 0.0 %
                    Rijsnelheid: 0 km/h
                    Koelvloeistoftemperatuur: 92 °C
                    Aanzuigluchttemperatuur: 39 °C
                    Buitenluchtdruk: 1010 mbar
                    Spanning contact 30: 12.274 V
                    Verleerteller na OBD: 40
                    massastroom via gasklep: 0.0 kg/h
                    Gemiddelde inspuittijd: 0.000 ms
                    Bedrijfsfunctie motor: Nullast
                    Bedrijfsfunctie motor-Test_Program_Channel 87: 5
17158 - Databus ontvangen storingswaarde
          U1123 00 [032] - -
             Bevries Frame:
                    Fout Prioriteit: 6
                    Fout Frekwentie: 1
                    Datum: 2021.07.04
                    Tijd: 12:05:57
                    Motortoerental: 1215.50 /min
                    Genorm. bel.waarde: 30.2 %
                    Rijsnelheid: 0 km/h
                    Koelvloeistoftemperatuur: 20 °C
                    Aanzuigluchttemperatuur: 21 °C
                    Buitenluchtdruk: 1000 mbar
                    Spanning contact 30: 11.826 V
                    massastroom via gasklep: 49.1 kg/h
                    Gemiddelde inspuittijd: 1.782 ms
17149 - Codering/uitvoeringen van regelapparaten
          P1647 00 [032] - in aandrijflijn controleren
          [Checking coding/versions ofcontrol modules in drivetrain]
             Bevries Frame:
                    Fout Prioriteit: 2
                    Fout Frekwentie: 7
                    Datum: 2021.07.03
                    Tijd: 20:25:09
                    Rijsnelheid: 0 km/h
17921 - Databus onaannemelijke informatie
          U1122 00 [039] - -
             Bevries Frame:
                    Fout Prioriteit: 2
                    Fout Frekwentie: 11
                    Datum: 2021.07.03
                    Tijd: 20:25:08
                    Rijsnelheid: 0 km/h
Gereedheid: 1110 0001
2 Fouten Gevonden:
8314 - Codering/uitvoeringen van regelapparaten
          P1647 00 [009] - in aandrijflijn controleren
          [FCAN: Coding of ESP and TSK does not fit together]
             Bevries Frame:
                    Fout Prioriteit: 6
                    Fout Frekwentie: 12
                    Reset teller: 186
                    Datum: 2021.07.03
                    Tijd: 21:12:38
16401 - Waarschuwing bandenspanning
          C102D 00 [137] - -
          MIL AAN - Bevestigd - Getest sinds Geheugen Wissen
             Bevries Frame:
                    Fout Prioriteit: 6
                    Fout Frekwentie: 1
                    Reset teller: 169
                    Datum: 2021.07.03
                    Tijd: 20:25:14
1 Fout Gevonden:
             Bevries Frame:
                    Fout Prioriteit: 2
                    Fout Frekwentie: 1
                    Reset teller: 169
                    Datum: 2021.07.03
                    Tijd: 20:25:20
                    Buitentemperatuur: 21.5 °C
                    Temperatuur na verdamper: 30.3 °C
   Codering: 0A47F7
   Lichtschakelaar:
   Subsysteem 2 - Onderdeel No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serienummer: 11 03 2017  00001340
4 Fouten Gevonden:
             Bevries Frame:
                    Fout Prioriteit: 4
                    Fout Frekwentie: 1
                    Reset teller: 169
                    Datum: 2021.07.03
                    Tijd: 21:18:15
929796 - Lichtschakelaar
          U110B 00 [008] - Geen communicatie
          [Lichtschalter-E1->Kein Signal/Kommunikation]
             Bevries Frame:
                    Fout Prioriteit: 2
                    Fout Frekwentie: 2
                    Reset teller: 209
                    Datum: 2021.07.03
                    Tijd: 21:16:19
930056 - Lichtschakelaar
          B126A 29 [008] - Signaal onaannemelijk
             Bevries Frame:
                    Fout Prioriteit: 3
                    Fout Frekwentie: 1
                    Reset teller: 209
                    Datum: 2021.07.03
                    Tijd: 21:17:16
15360768 - Componentenbescherming actief
          U1101 00 [009] - -
             Bevries Frame:
                    Fout Prioriteit: 4
                    Fout Frekwentie: 1
                    Reset teller: 186
                    Datum: 2021.07.04
                    Tijd: 13:37:24
   Codering: 2D2D2D
   Codering: 2D2D2D
   Codering: 2D2D2D
   Codering: 2D2D2D
   Codering: 2D2D2D
   Codering: 2D2D2D
   Codering: 2D2D2D
   Codering: 2D2D2D
6 Fouten Gevonden:
9437211 - Ontsteker voor bestuurdersairbag
          B1000 1B [136] - Weerstand te hoog
          MIL AAN - Intermitterend - Bevestigd - Getest sinds Geheugen Wissen
             Bevries Frame:
                    Fout Prioriteit: 2
                    Fout Frekwentie: 1
                    Datum: 2021.07.03
                    Tijd: 20:49:24
9445376 - Sleutelschak. voor buiten werking stellen airbag; bijrijdersz.
          B1020 00 [136] - -
             Bevries Frame:
                    Fout Prioriteit: 2
                    Fout Frekwentie: 1
                    Datum: 2021.07.03
                    Tijd: 20:39:27
9446656 - Redundant signaalweg b. werking stellen airbag; bijr.zijde
          B1025 00 [136] - -
             Bevries Frame:
                    Fout Prioriteit: 2
                    Fout Frekwentie: 1
                    Datum: 2021.07.03
                    Tijd: 20:39:27
          U1101 00 [137] - -
          [ATP Inconsistency]
             Bevries Frame:
                    Fout Prioriteit: 2
                    Fout Frekwentie: 3
                    Datum: 2021.07.04
                    Tijd: 13:37:25
9442816 - Controlelampje airbag buiten werking; bijrijderszijde
          B1016 00 [137] - -
             Bevries Frame:
                    Fout Prioriteit: 2
                    Fout Frekwentie: 1
                    Datum: 2021.07.03
                    Tijd: 20:39:28
10487296 - Regelapparaat past niet bij de wagen
          B2006 00 [137] - -
          [ECU does not fit to vehicle configuration]
             Bevries Frame:
                    Fout Prioriteit: 1
                    Fout Frekwentie: 1
                    Datum: 2021.07.03
                    Tijd: 20:39:27
   Codering: A618
1 Fout Gevonden:
227387 - Ruitenwisserschakelaar met interval
          B1149 13 [009] - Open Circuit
             Bevries Frame:
                    Fout Prioriteit: 3
                    Fout Frekwentie: 1
                    Reset teller: 186
                    Datum: 2021.07.04
                    Tijd: 13:54:14
                    Inschakeltijd: 266494 min
                    Voedingsspanning contact 30: 12.1 V
                    Rijsnelheid: 0 km/h
                    Spanning op schakelaar: 4.98 V
                    Status contact 15: actief
                    Systeemstatus: 30
                    FF U Wischer AD value: 230
                    FF U Wish Wash AD value: 229
                    FF U Intervall Poti AD value: 201
                    FF U MFA AD value: 254
   Codering: 07A409002380000800000800000000
2 Fouten Gevonden:
16777018 - Beperkte werking wegens communicatiestoring
          U1110 00 [008] - -
          [BAP_Audio_0x31 keine Kommunikation]
             Bevries Frame:
                    Fout Prioriteit: 6
                    Fout Frekwentie: 1
                    Reset teller: 209
                    Datum: 2021.07.04
                    Tijd: 12:06:15
15360512 - Componentenbescherming actief
          U1101 00 [009] - -
             Bevries Frame:
                    Fout Prioriteit: 4
                    Fout Frekwentie: 1
                    Reset teller: 186
                    Datum: 2021.07.04
                    Tijd: 13:37:24
Adres 19: CAN-bus Interface (J533)       Labels:| 3Q0-907-530-V1.clb
   Onderdeel No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   515 5344
   Serienummer: 23011710520311
   Codering: 030100342B086400FB00024C080B00000001000000000000000000000000
   Werkplaats#: WSC 01730 666 28888
   ROD: EV_GatewNF.rod
   Dynamo:
   Component: 1-01-03-01-04
   Regelapparaat voor multifunctiestuurwiel:
   Subsysteem 2 - Onderdeel No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serienummer: 03 06 2013  C0272822
   Subsysteem 3 - Onderdeel No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
2 Fouten Gevonden:
          U1101 00 [009] - -
             Bevries Frame:
                    Fout Prioriteit: 4
                    Fout Frekwentie: 2
                    Reset teller: 186
                    Datum: 2021.07.04
                    Tijd: 14:25:19
                    Voedingsspanning contact 30: 11.9 V
                    Contact 15: aan
          U1101 00 [009] - -
             Bevries Frame:
                    Fout Prioriteit: 4
                    Fout Frekwentie: 2
                    Reset teller: 186
                    Datum: 2021.07.04
                    Tijd: 14:25:19
                    Contact 15: aan
   Codering: 110000
   Codering: 81
   Codering: 090000
Adres 5F: Informatie Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Onderdeel No SW: 8V0 035 864 C    HW: 8V0 035 864
   Component: MU-S-N-ER     039 0461
   Serienummer: A3F02401130206
   Codering: 01730301FF00000021110001000A00002F0004440100010006
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: BB3695D532E17E9733-80EE
   Sticker met gegevens:
   Subsysteem 1 - Onderdeel No SW: 8V0 060 866 G    HW: -----------
   Component:  ECE 2018  --- 0072
   Serienummer: --------------------
   Beeldscherm 1 voor multimedia:
   Subsysteem 2 - Onderdeel No SW: 8V0 919 603 A    HW: 8V0 919 603 A
   Component: DU Std  H47 0014
   Serienummer: AUZ8Z9CG200EMB
   Bedieningseenheid voor multimedia:
   Subsysteem 3 - Onderdeel No SW: 8V0 919 614 B    HW: 8V0 919 614 B
   Component: ControlUnit_B  H33 0037
   Serienummer: C1000027111200010065
11 Fouten Gevonden:
          U1101 00 [009] - -
          [Anti-theft protection - component protection active (0xEA6300)]
             Bevries Frame:
                    Fout Prioriteit: 3
                    Fout Frekwentie: 1
                    Reset teller: 169
                    Datum: 2021.07.03
                    Tijd: 20:33:45
                    Spanning contact 30: 12.2 V
2571 - Navigatiesysteem
          B126C F2 [009] - Navigatiedatabase niet vrijgegeven
             Bevries Frame:
                    Fout Prioriteit: 6
                    Fout Frekwentie: 1
                    Reset teller: 169
                    Datum: 2021.07.03
                    Tijd: 20:47:26
0512 - Lagetonenluidspreker rechts achter
          B1067 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 1: Unterbrechung]
             Bevries Frame:
                    Fout Prioriteit: 6
                    Fout Frekwentie: 1
                    Reset teller: 169
                    Datum: 2021.07.03
                    Tijd: 20:33:48
0513 - Hogetonenluidspreker rechts achter
          B1068 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 1: Unterbrechung]
             Bevries Frame:
                    Fout Prioriteit: 6
                    Fout Frekwentie: 1
                    Reset teller: 169
                    Datum: 2021.07.03
                    Tijd: 20:33:48
0527 - Lagetonenluidspreker links achter
          B1065 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 4: Unterbrechung]
             Bevries Frame:
                    Fout Prioriteit: 6
                    Fout Frekwentie: 1
                    Reset teller: 169
                    Datum: 2021.07.03
                    Tijd: 20:33:48
0528 - Hogetonenluidspreker links achter
          B1066 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 4: Unterbrechung]
             Bevries Frame:
                    Fout Prioriteit: 6
                    Fout Frekwentie: 1
                    Reset teller: 169
                    Datum: 2021.07.03
                    Tijd: 20:33:48
0005 - Antenneversterker 1 voor radio
          B126D 13 [008] - Open Circuit
             Bevries Frame:
                    Fout Prioriteit: 6
                    Fout Frekwentie: 1
                    Reset teller: 209
                    Datum: 2000.00.00
                    Tijd: 00:00:00
                    Spanning contact 30: 12.5 V
                    Status antenne 1 voor radio-Antennestroom: 0 mA
                    Status antenne 1 voor radio-Verbinding tussen radio en antenneversterker: Onderbreking
                    Status antenne 1 voor radio-Verbinding tussen antenneversterker en antenne: Niet beschikbaar
                    Status antenne 1 voor radio-Ontvangstniveau antenne 1: 255 dBµV
0006 - Antenneversterker 2 voor radio
          B126E 13 [008] - Open Circuit
             Bevries Frame:
                    Fout Prioriteit: 6
                    Fout Frekwentie: 1
                    Reset teller: 209
                    Datum: 2000.00.00
                    Tijd: 00:00:00
                    Status antenne 2 voor radio-Antennestroom: 0 mA
                    Status antenne 2 voor radio-Verbinding tussen radio en antenneversterker: Onderbreking
                    Status antenne 2 voor radio-Verbinding tussen antenneversterker en antenne: Niet beschikbaar
                    Status antenne 2 voor radio-Ontvangstniveau antenne 2: 255 dBµV
2565 - Gps-antenne
          B1054 13 [008] - Kortsluiting met massa
          [GPS aerial - open circuit]
             Bevries Frame:
                    Fout Prioriteit: 4
                    Fout Frekwentie: 2
                    Reset teller: 226
                    Datum: 2000.00.00
                    Tijd: 00:00:00
1024 - Interface v. externe multimedia-apparaten (MEDIA-IN)
          B1288 13 [009] - Open Circuit
             Bevries Frame:
                    Fout Prioriteit: 6
                    Fout Frekwentie: 1
                    Reset teller: 169
                    Datum: 2021.07.03
                    Tijd: 20:33:45
7178 - Functiebeperking wegens ontbrekende informatie
          U1111 00 [009] - -
          [Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
             Bevries Frame:
                    Fout Prioriteit: 6
                    Fout Frekwentie: 1
                    Reset teller: 169
                    Datum: 2021.07.04
                    Tijd: 12:53:47
                    Spanning contact 30: 11.9 V
                    BAP-BAP_Function_ID: 02
Einde-(Verstreken Tijd: 01:04, VBatt start/eind: 11.9V/11.9V. VIgn 11.9V)--
Woensdag,28,Juli,2021,20:04:45:33886
Kilometrage: 144059km   Reparatie Order: 28-07-2021
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: WAUZZZ8V2EA054416   Kilometrage: 144059km
10-Parkeerhulp -- Status: Kan niet bereikt worden 0100
   Revisie: WAH08---
2 Fouten Gevonden:
          U1123 00 [047] - -
             Bevries Frame:
                    Fout Prioriteit: 6
                    Fout Frekwentie: 6
                    Kilometrage: 144038 km
                    Datum: 2021.07.26
                    Tijd: 23:08:12
                    Motortoerental: 1129.50 /min
                    Genorm. bel.waarde: 43.5 %
                    Rijsnelheid: 0 km/h
                    Koelvloeistoftemperatuur: 19 °C
                    Aanzuigluchttemperatuur: 19 °C
                    Spanning contact 30: 11.685 V
                    massastroom via gasklep: 38.9 kg/h
                    Gemiddelde inspuittijd: 2.334 ms
          P1647 00 [044] - in aandrijflijn controleren
             Bevries Frame:
                    Fout Prioriteit: 2
                    Fout Frekwentie: 7
                    Datum: 2021.07.26
                    Tijd: 23:08:12
                    Rijsnelheid: 0 km/h
                    Koelvloeistoftemperatuur: 24 °C
                    Aanzuigluchttemperatuur: 25 °C
                    Spanning contact 30: 12.015 V
Gereedheid: 0000 0001
2 Fouten Gevonden:
             Bevries Frame:
                    Fout Prioriteit: 6
                    Fout Frekwentie: 16
                    Reset teller: 203
                    Datum: 2021.07.26
                    Tijd: 23:08:10
          C102D 00 [137] - -
             Bevries Frame:
                    Fout Prioriteit: 6
                    Fout Frekwentie: 1
                    Reset teller: 200
                    Datum: 2021.07.26
                    Tijd: 23:08:10
1 Fout Gevonden:
             Bevries Frame:
                    Fout Prioriteit: 2
                    Fout Frekwentie: 2
                    Reset teller: 202
                    Datum: 2021.07.26
                    Tijd: 23:08:09
                    Buitentemperatuur: 21 °C
                    Temperatuur na verdamper: 27.2 °C
   Codering: 0A47F7
   Lichtschakelaar:
3 Fouten Gevonden:
             Bevries Frame:
                    Fout Prioriteit: 4
                    Fout Frekwentie: 1
                    Reset teller: 200
                    Datum: 2021.07.26
                    Tijd: 23:39:06
197904 - Centrale vergrendeling
          B140A 4B [008] - Oververhitting
             Bevries Frame:
                    Fout Prioriteit: 6
                    Fout Frekwentie: 2
                    Reset teller: 243
                    Kilometrage: 144054 km
                    Datum: 2021.07.27
                    Tijd: 18:47:18
             Bevries Frame:
                    Fout Prioriteit: 3
                    Fout Frekwentie: 1
                    Reset teller: 241
                    Datum: 2021.07.26
                    Tijd: 23:42:17
Adres 10: Parkeerhulp
   Codering: 2D2D2D
   Codering: 2D2D2D
   Codering: 2D2D2D
   Codering: 2D2D2D
   Codering: 2D2D2D
   Codering: 2D2D2D
   Codering: 2D2D2D
   Codering: 2D2D2D
4 Fouten Gevonden:
          B1020 00 [137] - -
             Bevries Frame:
                    Fout Prioriteit: 2
                    Fout Frekwentie: 1
                    Datum: 2021.07.26
                    Tijd: 23:08:10
          B1025 00 [137] - -
             Bevries Frame:
                    Fout Prioriteit: 2
                    Fout Frekwentie: 1
                    Datum: 2021.07.26
                    Tijd: 23:08:10
          B1016 00 [137] - -
             Bevries Frame:
                    Fout Prioriteit: 2
                    Fout Frekwentie: 1
                    Datum: 2021.07.26
                    Tijd: 23:08:11
          B2006 00 [137] - -
             Bevries Frame:
                    Fout Prioriteit: 1
                    Fout Frekwentie: 1
                    Datum: 2021.07.26
                    Tijd: 23:08:10
   Codering: A618
1 Fout Gevonden:
             Bevries Frame:
                    Fout Prioriteit: 3
                    Fout Frekwentie: 1
                    Reset teller: 200
                    Datum: 2021.07.26
                    Tijd: 23:08:09
                    Inschakeltijd: 267672 min
                    Voedingsspanning contact 30: 12.3 V
                    Rijsnelheid: 0 km/h
                    Systeemstatus: 30
   Codering: 07AD0900228000080D00EE00000000
1 Fout Gevonden:
13636608 - Regelapparaat verkeerd gecodeerd
          U1014 00 [009] - -
             Bevries Frame:
                    Fout Prioriteit: 2
                    Fout Frekwentie: 8
                    Reset teller: 203
                    Datum: 2021.07.26
                    Tijd: 23:27:59
   ROD: EV_GatewNF.rod
   Dynamo:
1 Fout Gevonden:
131594 - Regelapparaat voor inparkeersysteem
          U104E 00 [009] - Geen communicatie
          [Timeout Knoten 0x0A / 76 - Steuergerät für Parklenkassistent]
             Bevries Frame:
                    Fout Prioriteit: 2
                    Fout Frekwentie: 1
                    Reset teller: 203
                    Kilometrage: 144059 km
                    Datum: 2021.07.27
                    Tijd: 22:51:19
                    Contact 15: aan
   Codering: 110000
   Codering: 81
   Codering: 090000
   Codering: 01730301FF00000031110001000A00001F0004C40100010006
6 Fouten Gevonden:
1543 - Regelapparaat verkeerd gecodeerd
          U1014 00 [009] - -
             Bevries Frame:
                    Fout Prioriteit: 4
                    Fout Frekwentie: 1
                    Reset teller: 200
                    Datum: 2021.07.26
                    Tijd: 23:36:54
                    Spanning contact 30: 11.8 V
                    Byte_Coding_Condition-byte_10_condition: FOUT
                    Byte_Coding_Condition-byte_11_condition: FOUT
                    Byte_Coding_Condition-byte_12_condition: FOUT
                    Byte_Coding_Condition-byte_13_condition: FOUT
                    Byte_Coding_Condition-byte_14_condition: FOUT
                    Byte_Coding_Condition-byte_15_condition: FOUT
                    Byte_Coding_Condition-byte_16_condition: FOUT
                    Byte_Coding_Condition-byte_17_condition: FOUT
                    Byte_Coding_Condition-byte_18_condition: FOUT
                    Byte_Coding_Condition-byte_19_condition: FOUT
                    Byte_Coding_Condition-byte_20_condition: FOUT
                    Byte_Coding_Condition-byte_21_condition: FOUT
                    Byte_Coding_Condition-byte_22_condition: FOUT
                    Byte_Coding_Condition-byte_23_condition: FOUT
                    Byte_Coding_Condition-byte_24_condition: FOUT
                    Byte_Coding_Condition-byte_25_condition: FOUT
                    Byte_Coding_Condition-byte_26_condition: FOUT
                    Byte_Coding_Condition-byte_27_condition: FOUT
                    Byte_Coding_Condition-byte_8_condition: FOUT
             Bevries Frame:
                    Fout Prioriteit: 6
                    Fout Frekwentie: 1
                    Reset teller: 200
                    Datum: 2021.07.26
                    Tijd: 23:08:13
             Bevries Frame:
                    Fout Prioriteit: 6
                    Fout Frekwentie: 1
                    Reset teller: 200
                    Datum: 2021.07.26
                    Tijd: 23:08:13
             Bevries Frame:
                    Fout Prioriteit: 6
                    Fout Frekwentie: 1
                    Reset teller: 200
                    Datum: 2021.07.26
                    Tijd: 23:08:13
             Bevries Frame:
                    Fout Prioriteit: 6
                    Fout Frekwentie: 1
                    Reset teller: 200
                    Datum: 2021.07.26
                    Tijd: 23:08:13
             Bevries Frame:
                    Fout Prioriteit: 6
                    Fout Frekwentie: 1
                    Reset teller: 200
                    Datum: 2021.07.26
                    Tijd: 23:08:09
Einde-------(Verstreken Tijd: 01:42, VBatt start/eind: 12.4V/12.3V)--------
Since very few people here can read Dutch, please grab the current English version of VCDS from the following page and use it for posting data here in the future:
Your car does not appear to have 10-Parkeerhulp. I suggest removing it from your Gateway Installation List.
@Rexhunt: This reply in no way addresses your questions- but I consider it necessary to mark your use of a forum handle from a local Aussie celebrity!!
I'm surprised that someone from the Netherlands is even aware of Rex Hunt. For others reading this- Rex Hunt is ex Aust Football League player who became an announcer on local AM radio. And to explain the picture on first post, Rex also had a penchant for fishing and he was a TV celebrity on this topic (his trade-mark was his habit of kissing every fish that he caught before releasing it!)
PS: I'm keen on fly fishing but I never kiss a fish before releasing it - because it may have been a fish that was previously caught-and-released by Rex!!! :D
@Rexhunt : ok- as for the serious stuff and pending a better understanding of your auto-scan details from the English version of VCDS - ALL of the changes that you made before CP removal are recorded on the laptop that you use to run VCDS as explained by @Jef HERE.
Why not compare these past changes with the current settings on the altered modules (after CP removal)?
Rexhunt
C?ID=389364
Hahahaha, i always watched Rex on Discovery Channel, wonderfull to see him fish in the most beautifull waters!, i am from 1978 :-)
Rexhunt
C?ID=389364
ENGLISH version :-) using google translate.
As i am a newby using vcds i love any help. Main question is why only radio works after i let someone remove CP
THIS IS WHERE THE CAR CAME WITH FACTORY
Friday,14,May,2021,16:56:48:33886
VCDS -- Windows Based VAG/VAS Emulator Runs on Windows 10 x64
VCDS Version: HZH 19.6.2.1 HEX-NET CB: 0.4513.4
Data version: 20191019 DS308.0
VIN: WAUZZZ8V2EA054416 License Plate: J-061-VV
Mileage: 143078km Repair Order:
Gateway Installation List: 5Q0 907 530 K
03-ABS System -- Status: Fault 0010
08-Airco/Heating -- Status: Defect 0010
09-Centr.Electr. -- Status: Fault 0010
16-Steering Wheel -- Status: OK 0000
19-CAN bus Interface -- Status: OK 0000
42-Door Electric, LV -- Status: OK 0000
52-Door Electric,RV -- Status: OK 0000
Friday,14,May,2021,17:02:13:33886
VIN: WAUZZZ8V2EA054416 Mileage: 143078km
Address 01: Engine (J623-CXSA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 016 DE HW: 04E 907 309 A
Revision: WAH08---
Coding: 02190012230401082000
Workshop#: WSC 06314 790 00021
No Error Code Found.
Address 03: ABS System (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Revision: 00000000 Serial Number: 622830000010E1
Coding: 12F16AA224252A70017B060141C9294856245480608294F2002100788508
1 Error Found:
32833 - Electromechanical parking brake button
C100C 01 [008] - Electrical fault
Intermittent - Confirmed - Tested since Memory Clear
Error Status: 00000001
Error Priority: 2
Error Frequency: 1
Reset counter: 28
Date: 2013.08.30
Time: 00:00:26
Address 08: Airco/Heating (E87) Labels:| 8V0-820-047.clb
Part No SW: 8V0 820 047 C HW: 8V0 820 047 C
Revision: 20019000 Serial Number: 000000000025561
Coding: 03000004000000001000000000000100
1 Error Found:
262914 - Coolant pressure
B10AB F0 [009] - Lower limit value undershot
Error Priority: 2
Error Frequency: 34
Reset counter: 61
Mileage: 142562 km
Date: 2021.03.24
Time: 03:06:17
Outside temperature: 13.5 °C
Motor speed: 0.00 /min
Compressor current: work. value: 0.000 A
Temperature after evaporator: 22.0 °C
Cooling medium pressure: 1.0 bar
System run time - Motor run time: 0 s
System run time - Contact 15 on: 253 s
Address 09: Centr.Electr. (J519) Tags:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 T HW: 5Q0 937 084 T
Serial Number: 00011321800822
Coding: 04000846C241005D43A44004001407A80000000000000000000000000000
Workshop#: WSC 06
Wiper motor control unit:
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
Serial Number: 130805134255
Coding: 0A47F7
Subsystem 2 - Part No SW: 8V0 941 531 N HW: 8V0 941 531 N
Serial number: 17 06 2013 00000380
3 Errors Found:
197644 - Tank valve release control
B1263 01 [009] - Electrical fault
Error Priority: 4
Error Frequency: 3
Reset counter: 56
Mileage: 142565 km
Date: 2021.03.24
Time: 03:40:21
204546 - Key 2
B147A 18 [008] - Current too low
Error Priority: 4
Error Frequency: 1
Reset counter: 98
Mileage: 142960 km
Date: 2021.04.29
Time: 01:16:13
787211 - Windshield Washer Pump
Error Priority: 3
Error Frequency: 1
Reset counter: 67
Mileage: 142832 km
Date: 2021.04.19
Time: 15:55:29
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: Airbag VW20 011 0361
Serial Number: 003M2R02UTD%
Coding: 98CCC0000C0000005C540000004800000065
Accident sensor for side airbag: driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 001 008 13
Serial number: 357670000003F0898D0+
Accident sensor for side airbag: passenger side:
Subsystem 2 - Part No SW: ----------- HW: 480 001 008 13
Serial Number: 358670000007D0898D01
Accident sensor for rear side airbag: driver side:
Subsystem 3 - Part No SW: ----------- HW: 480 400 908 13
Serial Number: 3516502B910EDE43209G
Accident sensor for rear side airbag: passenger side:
Subsystem 4 - Part No SW: ----------- HW: 480 401 908 13
Serial Number: 3526502A510EDE43037B
Front airbag accident sensor: driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 401 107 13
Serial Number: 35565029D106FA44F16O
Accident sensor pedestrian protection driver side:
Subsystem 6 - Part No SW: ----------- HW: 480 401 307 13
Serial Number: 22865029F107DB5121AE
Accident sensor pedestrian protection passenger side:
Subsystem 7 - Part No SW: ----------- HW: 480 400 308 13
Serial Number: 2296502A11088B0302B
Accident sensor pedestrian protection middle:
Subsystem 8 - Part No SW: ----------- HW: 480 400 108 13
Serial Number: 2306502B91074481515V
Address 16: Steering Wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 8V0 953 521 A HW: 5Q0 953 549 A
Component: Lenks. Module 007 0070
Revision: -------- Serial Number: 06081308491156
Coding: 8618
Part No SW: 8V0 920 870 G HW: 8V0 920 870 G
Part: KOMBI H03 2211
Coding: 078409002380000800000800000000
ASAM dataset: EV_DashBoardVDDMQBAB 008031
Address 19: CAN Bus Interface (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 K HW: 5Q0 907 530 D
Component: GW MQB Layer 123 1144
Revision: -------- Serial Number: 0000793739
Coding: 030000042B0864005B000248080B0000000100000000000000000000000000000
ASAM dataset: EV_GatewLear 009013
Dynamo:
Control unit for battery monitoring:
Subsystem 2 - Component No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Part: J367-BDM H08 0192
Serial Number: 0000004051868592
Address 42: Portielektr.,LV (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 393 A HW: 5Q0 959 393
Part: TSG FS 012 0006
Serial Number: 02081304080256
Coding: 00100E2040000040000001002
ASAM dataset: EV_DCUDriveSideEWMINKLO 006003
Rear door control unit: driver side:
Subsystem 1 - Component No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Part: FOND_FHSG_DRV 005 0004
Serial Number: 00000000000000411924
Coding: 110000
Address 44: Steering Assistance (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 M
Part: EPS_MQB_ZFLS 127 1021
Coding: 81
ASAM dataset: EV_SteerAssisMQB 008022
Address 52: Door elec.,RV (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 392 A HW: 5Q0 959 392
Serial Number: 18071303110763
Coding: 001006204000040000001002
ASAM dataset: EV_DCUPasseSideEWMINKLO 006003
Rear door control unit: passenger side:
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Part: FOND_FHSG_PSG 005 0004
Serial Number: 00000000000000397768
Coding: 090000
Part No SW: 8V0 035 870 A HW: 8V0 035 870
Revision: -------- Serial Number: 000085596001000
Coding: 017303003C00000010110001000A00000000001040100010000
ASAM dataset: EV_MUEnt4CCONT 004052
Display and operating unit 1 information electronics:
Subsystem 1 - Component No SW: 8V0 035 630 HW: 8V0 035 630
Part: ABT 160 0016
Serial Number: VD1BDY18071300210009
End--strokes-----(Elapsed Time: 01:01, VBatt start/end: 12.2V/12.2V)--------
NEXT AFTER CP REMOVAL
Wednesday,28,July,2021,20:04:45:33886
Mileage: 144059km Repair Order: 28-07-2021
VIN: WAUZZZ8V2EA054416 Mileage: 144059km
01-Engine -- Status: Fault 0010
10-Parking assistance -- Status: Cannot be reached 0100
16-Steering Wheel -- Status: Defect 0010
17-Instruments -- Status: Fault 0010
19-CAN bus Interface -- Status: Fault 0010
5F-Information Electr. -- Status: Fault 0010
Revision: WAH08---
Coding: 02190012232401082000
2 Errors Found:
17158 - Data bus received fault value
U1123 00 [047] - -
Error Priority: 6
Error Frequency: 6
Mileage: 144038 km
Date: 2021.07.26
Time: 23:08:12
Engine speed: 1129.50 /min
normal. call value: 43.5%
Driving speed: 0 km/h
Coolant temperature: 19 °C
Suction air temperature: 19 °C
Outside air pressure: 1000 mbar
Voltage contact 30: 11,685 V
Narrator after OBD: 40
mass flow through gas valve: 38.9 kg/h
Average injection time: 2,334 ms
Engine operating function: Zero load
Operating function motor-Test_Program_Channel 87: 5
17149 - Coding/Types of Control Units
P1647 00 [044] - check in powertrain
[Checking coding/versions of control modules in drivetrain]
Error Priority: 2
Error Frequency: 7
Mileage: 144038 km
Date: 2021.07.26
Time: 23:08:12
normal. call value: 0.0 %
Coolant temperature: 24 °C
Suction air temperature: 25 °C
Voltage contact 30: 12,015 V
mass flow through gas valve: 0.0 kg/h
Average injection time: 0.000 ms
Readiness: 0000 0001
2 Errors Found:
8314 - Coding/Types of Control Units
P1647 00 [009] - check in powertrain
Error Priority: 6
Error Frequency: 16
Reset counter: 203
Date: 2021.07.26
Time: 23:08:10
16401 - Tire Pressure Warning
C102D 00 [137] - -
MIL ON - Confirmed - Tested since Clear Memory
Error Priority: 6
Error Frequency: 1
Reset counter: 200
Date: 2021.07.26
Time: 23:08:10
1 Error Found:
Error Priority: 2
Error Frequency: 2
Reset counter: 202
Mileage: 144038 km
Date: 2021.07.26
Time: 23:08:09
Outside temperature: 21 °C
Temperature after evaporator: 27.2 °C
Coding: 0A47F7
Subsystem 2 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Serial number: 11 03 2017 00001340
3 Errors Found:
Error Priority: 4
Error Frequency: 1
Reset counter: 200
Mileage: 144038 km
Date: 2021.07.26
Time: 23:39:06
197904 - Central locking
B140A 4B [008] - Overheating
Error Priority: 6
Error Frequency: 2
Reset counter: 243
Mileage: 144054 km
Date: 2021.07.27
Time: 18:47:18
930056 - Light Switch
B126A 29 [008] - Signal implausible
Error Priority: 3
Error Frequency: 1
Reset counter: 241
Mileage: 144038 km
Date: 2021.07.26
Time: 23:42:17
Address 10: Parking assistance
Can't be reached
Part: SideSensor_Dr 001 6149
Part: SideSensor_Pr 001 6149
Part: PedP_Sensor_C 001 6149
4 Errors Found:
9445376 - Key switch. for airbag deactivation; co-driverz.
B1020 00 [137] - -
Error status: 00000001
Error Priority: 2
Error Frequency: 1
Mileage: 144038 km
Date: 2021.07.26
Time: 23:08:10
9446656 - Redundant signal path b. deploy airbag; side
B1025 00 [137] - -
Error Priority: 2
Error Frequency: 1
Mileage: 144038 km
Date: 2021.07.26
Time: 23:08:10
9442816 - Airbag inoperative indicator light; passenger side
B1016 00 [137] - -
Error Priority: 2
Error Frequency: 1
Mileage: 144038 km
Date: 2021.07.26
Time: 23:08:11
10487296 - Control unit past not with the car
B2006 00 [137] - -
[ECU does not fit in vehicle configuration]
Error Priority: 1
Error Frequency: 1
Mileage: 144038 km
Date: 2021.07.26
Time: 23:08:10
Coding: A618
ASAM dataset: EV_SMLSKLOMQB 009001
1 Error Found:
227387 - Intermittent wiper switch
Error Priority: 3
Error Frequency: 1
Reset counter: 200
Mileage: 144038 km
Date: 2021.07.26
Time: 23:08:09
Switch-on time: 267672 min
Supply voltage contact 30: 12.3 V
Voltage at switch: 4.98 V
Status contact 15: active
System status: 30
Coding: 07AD0900228000080D00EE00000000
1 Error Found:
13636608 - Control unit coded incorrectly
U1014 00 [009] - -
Error Priority: 2
Error Frequency: 8
Reset counter: 203
Mileage: 144038 km
Date: 2021.07.26
Time: 23:27:59
Address 19: CAN Bus Interface (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 Q HW: 3Q0 907 530 C
Serial Number: 23011710520311
Coding: 030100342B086400FB00024C080B0000000100000000000000000000000000000
Workshop#: WSC 01730 666 28888
ROD: EV_GatewNF.rod
Dynamo:
Component: 01-01-03-01-04
Control unit for multifunction steering wheel:
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Serial number: 03 06 2013 C0272822
Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Serial Number: 00000000004051868592
1 Error Found:
131594 - Parking System Control Unit
U104E 00 [009] - No communication
Error Priority: 2
Error Frequency: 1
Reset counter: 203
Mileage: 144059 km
Date: 2021.07.27
Time: 22:51:19
Contact 15: on
Address 42: Door Electric, LV (J386) Labels:| 5QX-959-X93-42.clb
Coding: 00100E204000040000001002
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Coding: 110000
Coding: 81
Coding: 090000
Address 5F: Information Electr. (J794) Tags:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 864 C HW: 8V0 035 864
Serial Number: A3F02401130206
Coding: 01730301FF00000031110001000A00001F0004C40100010006
Decal with data:
Subsystem 1 - Part No SW: 8V0 060 866 G HW: -----------
Serial Number: --------------------
Display 1 for multimedia:
Subsystem 2 - Part No SW: 8V0 919 603 A HW: 8V0 919 603 A
Serial Number: AUZ8Z9CG200EMB
Multimedia control unit:
Subsystem 3 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Serial Number: C1000027111200010065
6 Errors Found:
1543 - Control Unit Coded Wrong
U1014 00 [009] - -
Error Priority: 4
Error Frequency: 1
Reset counter: 200
Mileage: 144038 km
Date: 2021.07.26
Time: 23:36:54
Voltage contact 30: 11.8 V
Byte_Coding_Condition-byte_8_condition: ERROR
0512 - Bass speaker right rear
Error Priority: 6
Error Frequency: 1
Reset counter: 200
Mileage: 144038 km
Date: 2021.07.26
Time: 23:08:13
Voltage contact 30: 11.9 V
0513 - Treble speaker rear right
Error Priority: 6
Error Frequency: 1
Reset counter: 200
Mileage: 144038 km
Date: 2021.07.26
Time: 23:08:13
0527 - Bass speaker rear left
Error Priority: 6
Error Frequency: 1
Reset counter: 200
Mileage: 144038 km
Date: 2021.07.26
Time: 23:08:13
0528 - Treble speaker rear left
Error Priority: 6
Error Frequency: 1
Reset counter: 200
Mileage: 144038 km
Date: 2021.07.26
Time: 23:08:13
1024 - Interface for external multimedia devices (MEDIA-IN)
Error Priority: 6
Error Frequency: 1
Reset counter: 200
Mileage: 144038 km
Date: 2021.07.26
Time: 23:08:09
End------(Elapsed Time: 01:42, VBatt start/end: 12.4V/12.3V)--------
@Rexhunt: To add to @Uwe request - more information about the "main problem" might help in our understanding. For example, more words about:
  1. How was CP removal done - did you use a registered dealer (with FAZIT connection back to VAG's central database), or was it done remotely via a hack?.
  2. Were the factory SWAP equipment licenses (called FEC - Feature Enabling Codes) in the original modules re-established as part of the CP removal process?
  3. There are a myriad of DTCs in your auto-scans. To help add some structure to answering your statement "Main question is why only radio works after i let someone remove CP" -please describe what specifically didn't "work" as direct result of CP removal (separate from what did not "work" prior to CP removal- and continues to not work)?
Rexhunt
C?ID=389364
Hi Don,
1. CP was removed with a dealer connection i am told
2. No he only removed CP
3. What didnt work as result op removing CP is: Bleutooth, Cruise control, Audi Drive Select, Start Stop, ABS fault.
PDC i just installed (probably some wiring not correct as VCDS cannot reach it???
Airbag faults which return after erasing???
And TPMS occured after installing the new gateway and i do not have that option in my a3
Yibbida Yibbida
Trowbridge, UK
By only removing CP and not restoring the FEC any optional features will no longer work e.g. Audi Drive Select, etc.
The car needs to go back to the dealer who removed CP and tell them to to the other half of the job which is restoring the FEC codes.
Rexhunt
C?ID=389364
Can i restore the FEC myself? Ofcourse i will ask the dude (tuning guy) who removed the CP but if i can do it myself i have a 2nd option.
Rexhunt
C?ID=389364
@Uwe the Guy who removed cp said that hè thought the gateway and mib1 where new. Thats why hè did not re installed the FEC’s …. Is that normaal? I think if i see Your comments you always need to re install fec?!?
AINils
Germany (AIB)
C?ID=56975
FEc can only be restored to VIN which was equipped for. So your FIN hasn`t Navigation FEC, and it can't be restored.... You`ll need patched Unit.... But that isn`t part of this Forum. But didn`t understand why you retrofit MIB1 STd Crap..... These Units are Windows CE based, slow and waste of money
Rexhunt
C?ID=389364
@AINils can you please help/ guide me with ...patched unit...
i also liked mib2 better but it is expensive for me. If i can get my gear sorted it would be good.
AINils
Germany (AIB)
C?ID=56975
As I wrote these Panasonic Units are crap, only few people over the world can patch these Windows CE units. Best way is MIB1 High or MIB2/MIB2Scale
Rexhunt
C?ID=389364
ok trying to understand how everything works and what i can do myself.
are fec codes written in gateway or mmi?
i can buythe following unit:
81a035192a Delphi MIB HS
8v0857273p Alpine screen (is this the mmi high big screen?)
if i buy this i need cp removal again i think,and can i do anything myself?
AINils
Germany (AIB)
C?ID=56975
MMI related FEC are stored in MMI. MKE, CCS and Driving Profiles are stored in Gateway, but they are not important for Navigation. Unit Part Nr is the right one for MIB Scale, for Display iam not sure whicht Part Nr is right one.
CP can be removed by dealer (if unit is not illegal ownership change) or by patch.
