2008 Audi B6/B7 8H Cabriolet Airbag and Steering Angle issues
Goodness66
Virgina, USA
C?ID=338071
Good evening all...I have an 08 cab with an airbag issue along with steering angle fault. I think these are related but am not sure so I am coming to the experts for suggestions and advice. In Feb I had a dead immobilizer in the instrument cluster that @Jetta 97 helped me fix. PRIOR to that issue the airbag light was illuminated but I needed to fix one issue at a time. The wife took the car to the dealer for a scan/diagnosis due to all the work they had done to replace the airbags cause of the Takata issue. They said the clock spring was probably bad...I just replaced it today and still have the same issues. Now...I know I replaced it correctly but I am not sure if there is any coding/adaptation/calibration needed. Additionally, I still have the 01826 fault (sensor for steering angle G85 supply voltage) as well as the 2 drivers side airbag igniter faults. I am hoping someone can throw out a few suggestions for what to try to troubleshoot. Thanks.
Thursday,29,July,2021,17:06:00:20814
VIN: WAUDF48H18K008865   License Plate:
Mileage: 142730km-88688mi   Repair Order:
Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
          63 65 67 73 75 76 77
VIN: WAUDF48H18K008865   Mileage: 142730km-88688miles
   Part No SW: 8E1 910 115 G    HW: 8E0 907 115 D
   Revision: 5EH15---    Serial number:
   Coding: 011C010A190F0120
   VCID: 26150A1054E219DBD5F-8072
005495 - Right Engine Mount Solenoid Valve (N145)
               P1577 - 004 - Open Circuit
                    Mileage: 142726 km
                    RPM: 212 /min
                    Load: 67.0 %
                    Temperature: 46.0°C
                    Temperature: 40.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 10.795 V
012555 - Low Pressure Fuel regulation
               P310B - 002 - Fuel Pressure Outside Specification - Intermittent
                    Mileage: 142726 km
                    RPM: 1014 /min
                    Load: 25.1 %
                    Temperature: 46.0°C
                    Temperature: 38.0°C
                    Voltage: 12.954 V
Readiness: 0000 0101
   Part No SW: 8E1 910 156 K    HW: 09L 927 156 B
   Component: AG6 09L 2,0TFSI USA 0080
   Revision: --H01---    Serial number:        4389515
   Coding: 0000002
   VCID: 2F3BEF347B185893269-807A
   Part No SW: 8E0 910 517 J    HW: 8E0 614 517 BH
   Component: ESP8 quattro    H06 0140
   Coding: 0004528
   Shop #: WSC 00672 785 00200
   VCID: 2E05F2307C12519B2DF-807A
                    Reset counter: 38
                    Hex Value: 0x0000
                    Hex Value: 0x4222
                    Hex Value: 0x0024
                    Hex Value: 0x0190
                    Hex Value: 0x0001
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   3233
   Coding: 00100
   Shop #: WSC 00672
   VCID: 6D87353CB484EA83545-50F4
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  USA 0907
   Coding: 21023
   VCID: 3D27C57CA464BA03A45-4AA4
   Part No SW: 8E0 035 593 N    HW:
   Component: SDAR SIRIUS
   Revision:             Serial number: AUZ4Z7G0200359
   VCID: 3431E058921E7B4B5BB-5160
Address 15: Airbags        Labels: 8H0-959-655-94.lbl
   Part No SW: 8H0 959 655 H    HW: 8H0 959 655 H
   Component:    Airbag 9.42  H01 1830
   Revision: 92H01183    Serial number: 003D000034BY
   Coding: 0132105
   VCID: 3FDBBF74AB78A813B69-806A
   Subsystem 1 - Part No: 8H0 910 339 B
   Component: BF-Gewichtsens. H02 0020
   Subsystem 2 - Serial number: 01KFP
   Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332BRB402F94E24Vÿ†63
   Subsystem 5 - Serial number: 94E24Vÿ†6342BRB402F94DC71ÿ†63
   Subsystem 6 - Serial number: 94DC71ÿ†63729RB402AA04D4Qÿ†63
   Subsystem 7 - Serial number: A04D4Qÿ†63829RB402AA0437Kÿ
   Subsystem 8 - Serial number: A0437Kÿ
            002 - Lower Limit Exceeded - MIL ON
                    Fault Status: 11100010
01587 - Igniter 2 for Airbag; Drivers Side (N250)
                    Fault Status: 11100001
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0801
   Coding: 03041
   Shop #: WSC 00672
   VCID: 41DFB98CD89CDEE3C0D-4AA4
   Part No SW: 8H0 920 982 B    HW: 8H0 920 982 B
   Component: KOMBI+WFS 4     H10 0200
   Revision: 0200        Serial number: 00000000000000
   Coding: 0007261
   Shop #: WSC 08701 444 54496
   VCID: 3039EC486636476B3F3-50F4
   Coding: 0007261
Address 26: Auto Roof        Labels: 8H0-959-255.lbl
   Part No: 8H0 959 255 B
   Component:  VSG  B6 CABRIO     7195
   VCID: 3537DD5C995462436C5-50F4
   Part No: 8H0 959 433 L
   Component: Komfortgerát T7B    5442
   Coding: 11820
   Shop #: WSC 00672
   Subsystem 1 - Part No: 8H1959801D
   Component: Tõrsteuer.FS BRM 0205
   Subsystem 2 - Part No: 8H1959802D
   Component: Tõrsteuer.BF BRM 0205
   Subsystem 3 - Part No: 8H0959801A
   Component: Tõrsteuer.HL BRM 0002
   Subsystem 4 - Part No: 8H0959802A
   Component: Tõrsteuer.HR BRM 0002
   Part No SW: 4L0 910 357     HW: 4L0 907 357
   Component: AFS 1           H01 0030
   Coding: 0000019
   VCID: 698F412C857CF6A338D-803C
   Subsystem 1 - Part No: 8E0 941 329 A
   Component: AFS-Modul links H05 0030
   Subsystem 2 - Part No: 8E0 941 329 A
   Component: AFS-Modul rechtsH05 0030
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8H0 035 192 H    HW: 8H0 035 192 H
   Component: RNS-E US        H74 0250
   Revision:      04S    Serial number: AUZBZ7G2502147
   Coding: 0419637
   VCID: 2C01F8384A2E238B03B-5160
Address 63: Entry Assist,D        Labels: None
   Part No: 8H0 959 760 A
   Component: EasyEntry F   H13   0010
   Coding: 00005
   Shop #: WSC 00065
   VCID: 3537DD5C9C6462436C5-4B3C
Address 65: Tire Pressure        Labels: 8E0-907-273.lbl
   Part No SW: 8E0 907 273 A    HW: 8E0 907 273 A
   Component: Reifendruck 3   H04 0130
   Coding: 0062121
   VCID: 2A0DFE2040DA3DBBF17-5160
   Part No SW: 8P0 862 335 R    HW: 8P0 862 335 R
   Component: FSE_255x BT     H26 0350
   Revision: 00000000    Serial number: 00000005057355
   Coding: 0011807
   VCID: 45D7AD9CC9B4F2C3FC5-50D0
End----(Elapsed Time: 04:51, VBatt start/end: 11.9V/11.8V. VIgn 0.0V)------
Do you have a scan from before you replaced the clock spring?
Goodness66
Virgina, USA
C?ID=338071
Thanks for the reply...I do have a prior scan. Will take me a bit to get it loaded though...technical issues LOL. What will we be looking for in old vs. new scan?
Goodness66
Virgina, USA
C?ID=338071
Here is the prior scan. This scan is during the issue I had with the bad immobilizer which, as you can see, has been resolved. But the airbag issue was there prior to this. When the car was at the dealer for the scan/diagnosis, they said they removed the drivers airbag unit and checked the wiring and igniters and did not find any issues which is why they said it was most likely the clock spring. Thanks again for your help.
BTW...I think I cleared the Steering Angle issue but I need to scan again.
End----(Elapsed Time: 05:32, VBatt start/end: 11.5V/11.5V. VIgn 11.4V)-----
Wednesday,24,February,2021,10:41:45:20814
VCDS Version: 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
   VCID: 26150A1054E219DB29E-8072
                    Fault Frequency: 54
                    Mileage: 133115 km
                    RPM: 216 /min
                    Load: 77.6 %
                    Temperature: 10.0°C
                    Temperature: 12.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 10.922 V
               U0155 - 008 -
                    Fault Status: 01101000
                    Mileage: 137151 km
                    Temperature: 2.0°C
                    Temperature: 5.0°C
                    Voltage: 10.795 V
049412 - No Communication with Cruise Control Module
               U0104 - 008 -
                    Mileage: 137151 km
                    Temperature: 2.0°C
                    Temperature: 5.0°C
                    Voltage: 10.795 V
049508 - No Communications with HVAC Control Module (J301)
               U0164 - 008 -
                    Mileage: 137151 km
                    Temperature: 2.0°C
                    Temperature: 5.0°C
                    Voltage: 10.160 V
001299 - Incorrect Immobilizer Key
               P0513 - 008 -
                    RPM: 1376 /min
                    Load: 26.3 %
                    Temperature: 12.0°C
                    Temperature: 10.0°C
                    Voltage: 12.192 V
   Coding: 0000002
   VCID: 2F3BEF347B185893DA8-807A
049682 - Steering Column Control Module
               U0212 - 000 - No Communications
                    (no units): 30.0
                    (no units): 10.0
                    Temperature: 4.0°C
                    T.B. Angle: 0.0°
               U0155 - 000 -
   Coding: 0004528
   VCID: 2E05F2307C12519BD1E-807A
                    Hex Value: 0x0000
                    Hex Value: 0x4202
                    Hex Value: 0x0013
                    Hex Value: 0x298C
                    Hex Value: 0x0001
                    Hex Value: 0x0000
                    Hex Value: 0x4202
                    Hex Value: 0x0024
                    Hex Value: 0x0198
                    Hex Value: 0x0001
   Coding: 00100
   Shop #: WSC 00672
   VCID: 6D87353CB484EA83A84-50F4
            49-00 - No Communications
            27-00 - Implausible Signal
   Coding: 21023
   VCID: 3D27C57CA464BA03584-4AA4
            79-00 - Please Check Fault Codes
01312 - Powertrain Data Bus
   Coding: 0132105
   VCID: 3FDBBF74AB78A8134A8-806A
            001 - Upper Limit Exceeded - Intermittent - MIL ON
                    Fault Status: 10100001
                    Fault Frequency: 17
                    Fault Status: 11100100
                    Fault Frequency: 30
   Coding: 03041
   Shop #: WSC 00672
   VCID: 41DFB98CD89CDEE33CC-4AA4
01304 - Radio
   VCID: 3537DD5C99546243904-50F4
   Coding: 11820
   Shop #: WSC 00672
01369 - Alarm triggered by Hood Switch
            35-00 - -
   Coding: 0000019
   VCID: 698F412C857CF6A3C4C-803C
   Coding: 00005
   Shop #: WSC 00065
   VCID: 3537DD5C9C646243904-4B3C
   Coding: 0062121
   VCID: 2A0DFE2040DA3DBB0D6-5160
                    Fault Frequency: 56
                    (no units): 0.0
                    Voltage: 11.40 V
                    (no units): 30.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Raw, Index/Key Err.: 253 000 000
End----(Elapsed Time: 05:50, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
When you clear codes , do you do in Auto scan like clear all codes or direct in Module?
I ask this because most of the time Air Bag module will need go direct in module and clear code there .
For ABS , did you try to adopt G85?
Here is the instructions:
Goodness66
Virgina, USA
C?ID=338071
I was able to adapt/calibrate the G85 successfully and the fault has cleared for now...went and drove it for a while just to make sure. I also cleared the airbag codes several times directly from the module but with no luck...they keep coming back. The one thing I did notice from the scans is that after I put the new clock spring in, I also got the 00588 code in addition to the 01587 code I had originally. Everything else on the steering wheel works. I wonder if the dealer didn't test the airbag harness (they said they did) in the steering wheel and that is my issue. Thoughts anyone?
