2007 A4 8E BWT Basic settings and readiness problem
Shzeps
C?ID=11561
Hi Group,
11/06 2007 A4 8E BWT
I am trying to run the readiness script (automatic end of line test BS 200) and not able to start it.
Then I tried to perform a basic setting like 034 which requires the brake and accelerator to be held to automatically run. When pressing both pedals the engine does not raise the RPM and initiate the test.
Maybe this control unit is not capable of the automatic settings and software needs to be changed to manually controlling RPM for each setting?
Thanks for any help or info, Shep
Here is the autoscan and I will submit the control unit log as well.
Wednesday,28,July,2021,12:58:30:57829
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4543.4
VIN: WAUKF78E77A128687   License Plate:
Mileage: 275110km-170945mi   Repair Order:
          67 69 75 76 77
VIN: WAUKF78E77A128687   Mileage: 275110km-170945miles
   Part No HW: 8E0 907 115 D
   Revision: 5EH14---    Serial number:
   VCID: D5E2DB3D3CE0332340-8080
008577 - Performance Malfunction in Cooling System
               P2181 - 008 -  - MIL ON
                    Fault Status: 11101000
                    Fault Frequency: 24
                    Mileage: 254688 km
                    RPM: 2940 /min
                    Load: 63.9 %
                    Speed: 63.0 km/h
                    Temperature: 69.0°C
                    Temperature: 16.0°C
                    Absolute Pres.: 1030.0 mbar
                    Voltage: 13.970 V
               P0299 - 002 - Control Range Not Reached - Intermittent - MIL ON
                    Fault Status: 10100010
                    Mileage: 264996 km
                    RPM: 2638 /min
                    Load: 66.6 %
                    Speed: 98.0 km/h
                    Temperature: 83.0°C
                    Temperature: 38.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.716 V
   Part No SW: 8E0 910 517 J    HW: 8E0 614 517 BH
   Component: ESP8 quattro    H06 0140
   Coding: 0004526
   Shop #: WSC 06335 000 00000
   VCID: AE1054D139F620FBE1-80FA
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   2833
   Coding: 00000
   VCID: ED9293DDA5709BE398-50D0
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  USA 0907
   Coding: 11023
   Shop #: WSC 65536
   VCID: BD32639DB590CB6368-4AA4
   Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
   Component:    Airbag 9.41  H12 3840
   Revision: 91H12384    Serial number: 0036N0G0HDE6
   Coding: 0032607
   VCID: BC346E99FF8AC26B5F-80E8
   Subsystem 1 - Part No: 8E0 910 339 B
   Component: BF-Gewichtsens. 002 0070
   Subsystem 2 - Serial number: 3C9H5
   Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332DRB404250BAFUÿ†63
   Subsystem 5 - Serial number: 50BAFUÿ†6342DRB404140CB3Jÿ†63
   Subsystem 6 - Serial number: 40CB3Jÿ†6352ARB401BB7B89/ÿ†63
   Subsystem 7 - Serial number: B7B89/ÿ†6362ARB401BB7F02Uÿ†63
   Subsystem 8 - Serial number: B7F02Uÿ†63729RB401CB47F2Zÿ†63
   Subsystem 9 - Serial number: B47F2Zÿ†63829RB401CB478D/ÿ
   Subsystem 10 - Serial number: B478D/ÿ
01211 - Belt Tensioner Igniter; Rear Driver Side (N196)
                    Fault Status: 00100001
                    Reset counter: 39
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0701
   Coding: 04042
   Shop #: WSC 06335
   VCID: C1CA1F6DC968AF830C-4AA4
   Part No SW: 8E0 920 951 N    HW: 8E0 920 951 N
   Component: KOMBI+WFS 4     H14 0200
   Revision: 0200        Serial number: 00000000000000
   Coding: 0023268
   Shop #: WSC 26149 444 92471
   VCID: B5227BBDDDA01323A0-5118
   Coding: 0023268
   Part No: 8E0 959 433 CG
   Component: Komfortgerát T7B    4135
   Coding: 12076
   Shop #: WSC 06335
   VCID: F8BCB289DA322E4B7B-4AA4
   Subsystem 1 - Part No: 8E1959801G
   Component: Tõrsteuer.FS BRM 0706
   Subsystem 2 - Part No: 8E1959802G
   Component: Tõrsteuer.BF BRM 0706
   Component: Tõrsteuer.HL BRM 0606
   Subsystem 4 - Part No: 8E0959802E
   Component: Tõrsteuer.HR BRM 0606
00962 - Alarm via. Tilt Sensor
            35-00 - -
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Coding: 0000019
   VCID: A91AA7CD001847C334-80FC
   Subsystem 1 - Part No: 8E0 941 329 A
   Component: AFS-Modul links H03 0020
   Subsystem 2 - Part No: 8E0 941 329 A
   Component: AFS-Modul rechtsH03 0020
   Part No SW: 8E0 035 195 AC    HW: 8E0 035 195 AC
   Component: R Symphony2+    H03 0070
   Revision: 00H03000    Serial number: AUZ1Z4F3846595
   Coding: 0610122
   VCID: E89CE2C9D992BECBEB-5160
                    Time Indication: 15
   Part No SW: 8P0 862 335 J    HW: 8P0 862 335 J
   Component: FSE_255x BT     H26 0290
   Revision: 00000000    Serial number: 00000005013274
   Coding: 0001677
   VCID: BD32639DE590CB6368-50F4
End----------(Elapsed Time: 05:32, VBatt start/end: 14.3V/14.3V)-----------
Basic Settings Group 200 should work on this ECU, but something is unhappy with it; it's not providing full ID data in that scan. It should look more like this:
Address 01: Engine        Labels: 06F-907-115-AXX.clb
     Part No SW: 8E0 910 115 P    HW: 8E0 907 115 D
     Coding: 010C010A180F0120
     Shop #: WSC 26110 444 85836
Shzeps
C?ID=11561
Interesting, maybe a poor connection at the OBD connector?
I'm not seeing similar problems with any other module, so I'm doubting that...
