Friday,30,July,2021,09:37:06:55582
VCDS Version: 21.3.0.0 (x64) HEX-NET CB: 0.4544.4
VIN: 11111111111111111 License Plate:
Chassis Type: 11-AU72 (4T0)
Scan: 01 02 03 05 06 08 09 11 31 14 15 16 17 19 1B 22 26 36 3B 42
44 46 47 52 53 55 56 5F 65 6B 6C A6 C2 D0
VIN: 11111111111111111 Mileage: 5900km-3666miles
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
26-Auto Roof -- Status: Malfunction 0010
6B-Aerodynamics -- Status: OK 0000
6C-Back-up Cam. -- Status: Cannot be reached 0100
A6-Microphone -- Status: OK 0000
C2-Auto Trans 2 -- Status: OK 0000
D0-Frt Axle Lift -- Status: OK 0000
Address 01: Engine
Address 02: Auto Trans (J217) Labels:. 0BH-927-711.clb
Part No SW: 4T0 927 155 L HW: 0BH 927 711 F
Component: LB HP SB NAR H10 4107
Revision: 00H10V01
ASAM Dataset: EV_TCMDL800041 001015
ROD: EV_TCMDL800041_AU72.rod
VCID: 41CAA700D050D4838C-8014
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4S0 907 379 E HW: 4S0 907 379 E
Component: ESP PREMIUM H09 0400
Coding: 258AC151A451838A4B00
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004050
ROD: EV_ESPPremiAU57X_AU72.rod
VCID: 3FCEA1F8A6A4A273FA-806A
0793 - Control Difference
C1069 F0 [008] - Upper Limit Exceeded
Reset counter: 246
Mileage: 5893 km
Date: 2012.01.02
Time: 18:16:56
VzRef: 7A
Bit Info 1: 11
Bit Info 2: 40
Bit Info 3: 36
Bit Info 4: 1F
F-Path: 01
F-Type: 0F
Uz: B5
29212 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[ComScl PDU_Aero_01 - Timeout error]
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.05
Time: 03:47:03
VzRef: 00
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 00
Bit Info 4: 1F
F-Path: 00
F-Type: BD
Uz: B1
29198 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[Scl_Allrad_04_LB_ALR_ESP_akt]
Reset counter: 246
Mileage: 5893 km
Date: 2012.01.02
Time: 18:16:57
VzRef: 8C
Bit Info 1: 00
Bit Info 2: 62
Bit Info 3: 36
Bit Info 4: 1F
F-Path: 02
F-Type: 45
Uz: B4
Part No SW: 4H0 907 064 JD HW: 4H0 907 064 JD
Component: BCM2 2.0 H44 0582
Coding: 09803006000000000000
VCID: 74A43ED4D762312BD7-8020
Serial number: 3218000021243007
Part No SW: 4S0 959 760 HW: 4S0 959 760
Component: MEM-BFS 001 0020
Revision: AA001003 Serial number: 00000203336342
Coding: 0000100000042000000001210101000000000000000000
Shop #: WSC 28977 003 1048576
VCID: 7BB615E8FA3C7E5396-802E
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4T0 820 043 L HW: 4T0 820 043 L
Component: KLIMA 1 ZONE H03 0140
Revision: A1002000 Serial number: 01020320180013
Coding: 4A03208000
VCID: 3522C3D09C98682320-8060
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 HK HW: 4H0 907 063 EK
Component: BCM1 2.0 H21 0725
Revision: 2502102S Serial number: 00001929723901
Coding: 00E9009040208F303D01C8C300202800001C46C8220602C10000081C0440100000400034010000
VCID: 78BC0AE4CB0A554BFB-802C
Subsystem 1 - Part No SW: 4T1 955 113 HW: 955 113
Component: WWS72x 180220 043 0015
Serial number: ????????????
Coding: 0000F7
Component: G397_RLFS H06 0004
Serial number: 63249304
Coding: 02005D
Subsystem 3 - Part No SW: 4T1 941 531 E HW: 4T1 941 531 E
Component: LCU H02 0012
Subsystem 4 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H02 0007
Serial number: D622581900PAG0MUFU03
02070 - Rear Parking Aid Sensors
Fault Status: 01101011
Reset counter: 206
Mileage: 5886 km
Date: 2012.01.05
Time: 02:49:28
Address 11: Engine II
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 4S0 907 376 E HW: 4S0 907 376 C
Component: DAEMPFUNGS-SG H06 0065
Serial number: 150318008
ASAM Dataset: EV_AudiMagneRide 003007
ROD: EV_AudiMagneRide_003.rod
VCID: 3C34D6F4B7B2B96BDF-8068
Part No SW: 4G0 959 655 B HW: 4G0 959 655 B
Component: Airbag10.43 H66 0098
Revision: -------- Serial number: 003G0004VN0Y
Coding: 303338443033303030364A55304C34543053
VCID: 3424FED49FE2712B17-8060
Serial number: 6940000Y180001PWZG0%
Serial number: 3575HRB400G5DNAKF1DN
Serial number: 3585HRB400G5DNAK90PT
Serial number: 3515JRB405H5CFN410PA
Serial number: 3525JRB405J5CFN47PFY
Serial number: 3554VRB405D5A8NUI9GC
Serial number: 3564VRB405D5A8NUDGNM
Part No SW: 4T0 953 513 B HW: 4T0 953 513 B
Component: Lenks.Modul H02 0090
Revision: C0072465 Serial number: 90815RAN0002W
Coding: 000004
VCID: 3424FED497E2712B17-8060
Subsystem 1 - Part No SW: 18G 959 542 A HW: 18G 959 542 A
Component: E221__MFL-TAS H05 0012
Serial number: 0015749 TAT 20170718
Address 17: Instruments (J285) Labels:. 4T0-920-xxx-17.clb
Part No SW: 4T0 920 900 K HW: 4T0 920 900 K
Component: KOMBIINSTR. 018 1887
Revision: AA001001 Serial number: 05800054018MOC
Coding: 01F91A94FFBFD3F00200A4
VCID: 373EC9D886949A3332-8062
Reset counter: 206
Mileage: 5886 km
Date: 2012.01.05
Time: 01:38:32
Fault Status: 00111110
Fault Frequency: 12
Reset counter: 206
Mileage: 5886 km
Date: 2012.01.05
Time: 02:49:27
04195 - Telemetry Control Module
Reset counter: 206
Mileage: 5889 km
Date: 2012.01.05
Time: 03:08:05
04224 - Telemetry Control Module; Optical Databus
Fault Status: 00101110
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.05
Time: 03:39:50
03830 - Control Module for Aerodynamics
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.05
Time: 03:47:06
Part No SW: 4T0 907 468 B HW: 4S0 907 468
Component: J533--Gateway H15 0074
Revision: -------- Serial number: 00000002921208
Coding: 0009071600
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_GatewPkoUDS 002000
ROD: EV_GatewPkoUDS_002_LB72.rod
Subsystem 1 - Part No SW: 4S0 915 181 HW: 4S0 915 181
Component: J367-BDM H08 0270
Serial number: 55054K34572871868348
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 C HW: 8K0 959 663 C
Serial number: 18067001185021200410
5186 - Second (Slave) Engine Control Module
U0115 00 [008] - No Communication
Fault Frequency: 43
Reset counter: 246
Mileage: 5886 km
Date: 2012.01.05
Time: 02:15:26
Voltage terminal 30: 12.4 V
Voltage terminal 15: 0.0 V
Control Module temperature: 47 °C
Engine running: On
IN ZAS_Te_X: OFF
Terminal 15 status: OFF
Datenfeld: 0
5807 - Rear View Camera System Control Module
U104C 00 [009] - No communication
Reset counter: 206
Mileage: 5886 km
Date: 2012.01.05
Time: 01:38:30
Voltage terminal 30: 13.9 V
Voltage terminal 15: 13.9 V
Control Module temperature: 41 °C
System status: Terminal 15 on
Engine running: On
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [008] - -
Fault Frequency: 50
Reset counter: 246
Mileage: 5886 km
Date: 2012.01.05
Time: 01:39:34
Engine running: On
IN ZAS_Te_X: OFF
Datenfeld: 0
5511 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.05
Time: 03:47:04
Voltage terminal 30: 13.5 V
Voltage terminal 15: 13.5 V
Control Module temperature: 52 °C
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
Part No SW: 8K0 907 144 N HW: 8K0 907 144 N
Component: DYNAMIKLENK. H06 0740
Revision: 52001005 Serial number: --------------
Coding: 050000
VCID: 3A38D0ECB586875BCD-806E
Address 22: AWD (J492) Labels: None
Part No SW: 4S0 907 160 HW: 4S0 907 160
Component: 4 Wheel Drive H07 0207
Revision: 00001002 Serial number: 007GD5U
ASAM Dataset: EV_AllWheelContrBORGLB724 006012
ROD: EV_AllWheelContrBORGLB724.rod
VCID: 6E902CBCB14E1BFB21-803A
0115 - Databus
[DTC_FCAN_ESP_Systemstatus]
Reset counter: 246
Mileage: 5893 km
Date: 2012.01.02
Time: 18:16:57
Vehicle speed: 135.95 km/h
Steering angle: 4.80 °
Outside temperature: 34.40 °C
Accelerator pedal travel: 100.00 %
Torque specifications: front axle: 323.25 Nm
Torque: front axle: 323 Nm
Coolant pump: not active
ESP status: active
Hydraulic pressure sensor 1: 16.24 bar
Hydraulic temperature sensor: 42 °C
Cooling fin temperature: 46 °C
Haldex clutch pump: current: 5.00 A
Haldex clutch pump: voltage: 5.00 V
Voltage terminal 30: 13.90 V
0194 - Databus
[DTC_FCAN_Monitoring_Querb]
Reset counter: 246
Mileage: 5893 km
Date: 2012.01.02
Time: 18:16:57
Vehicle speed: 136.35 km/h
Steering angle: 4.50 °
Torque specifications: front axle: 539.00 Nm
Torque: front axle: 539 Nm
ESP status: active
Hydraulic pressure sensor 1: 17.24 bar
Haldex clutch pump: current: 9.00 A
Haldex clutch pump: voltage: 6.75 V
Voltage terminal 30: 13.80 V
0196 - Databus
[DTC_FCAN_Monitoring_Gierrate]
Reset counter: 246
Mileage: 5893 km
Date: 2012.01.02
Time: 18:16:57
ESP status: active
Hydraulic pressure sensor 1: 17.90 bar
0197 - Databus
[DTC_FCAN_Monitoring_Lenkwinkel]
Reset counter: 246
Mileage: 5893 km
Date: 2012.01.02
Time: 18:16:57
ESP status: active
Address 26: Auto Roof () Labels:* None
Part No SW: 4T7 959 255 HW: 4T7 959 255
Component: VSG LB625H01 0012
ASAM Dataset: EV_ElectRoofContrWIMLB625 001007
ROD: EV_ElectRoofContrWIMLB625.rod
VCID: 0248680C95D60F9BD5-8056
0043 - Switch for Folding Top Compartment Cover; Right; Closed
B123C 29 [009] - Signal Implausible
Reset counter: 206
Mileage: 5889 km
Date: 2012.01.01
Time: 16:59:37
0044 - Switch for Folding Top Compartment Cover; Left; Closed
B123B 29 [009] - Signal Implausible
Reset counter: 206
Mileage: 5889 km
Date: 2012.01.01
Time: 16:59:37
Component: MEM-FS 001 0020
Revision: AA001003 Serial number: 00000203336251
Coding: 0000100000040000000001210101000000000000000000
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H04 0056
Revision: -------- Serial number: EJ1BPA7E038FLJ
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 373EC9D88E949A3332-8062
Part No SW: 4T0 959 793 J HW: 4T0 959 793 H
Component: TSG FA H08 0802
Revision: -------- Serial number: 0000311317163
Coding: 010C43525008620100080502
VCID: 4CD48634EF1209EB6F-8018
Part No SW: 4S0 909 144 J HW: 4S0 909 144 B
Component: EPS H13 0906
Revision: 00000000 Serial number: L00272447
Coding: 0905
ASAM Dataset: EV_EPSZFAU72X 003010
ROD: EV_EPSZFAU72X_003.rod
Revision: 00002001 Serial number: 0471325227
Coding: 011E029A18F200A1A0B0C300008500470000000000000000000000000000
Subsystem 1 - Part No: 8J0 951 177
Component: DWA-Sensor H03 0030
01503 - Bulb for 3rd Brake Light (M25)
Fault Status: 00101100
Reset counter: 246
Mileage: 5886 km
Date: 2012.01.05
Time: 01:38:44
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.05
Time: 03:46:32
02911 - Bulb for Side Marker Light; Rear Left (M37)
Fault Status: 11101100
Reset counter: 206
Mileage: 5902 km
Date: 2012.01.03
Time: 01:14:57
02912 - Bulb for Side Marker Light; Rear Right (M38)
Reset counter: 206
Mileage: 5902 km
Date: 2012.01.03
Time: 01:14:57
Reset counter: 206
Mileage: 5902 km
Date: 2012.01.03
Time: 01:14:57
Part No SW: 4T7 035 466 HW: 4T7 035 466
Component: DSP Prem H05 0010
Revision: 00005001 Serial number: 94881066715605
VCID: 77BE09D8C6145A33F2-8022
Part No SW: 4T0 959 792 J HW: 4T0 959 792 H
Component: TSG BF H08 0802
Revision: -------- Serial number: 0000307544649
Coding: 010C43525008620100080500
VCID: 4BD68528EA1C0ED366-801E
Part No SW: 4S0 907 801 HW: 8K0 907 801 J
Component: EPB-4 H04 0001
Revision: -------- Serial number: 20000000005105
ROD: EV_ParkiBrake_AU72.rod
VCID: 70AC32C4AB7A0D0B33-8024
Address 55: Headlight Range (J431) Labels:| 4H4-907-357-V1.clb
Part No SW: 4T0 907 357 A HW: 4H4 907 357 A
Component: ....AFS13.... H01 0003
Serial number: 180312-0004-002
Coding: 72846F6118020200
ASAM Dataset: EV_AFSLEDHELLALB72X 006131
ROD: EV_AFSLEDHELLALB72X.rod
VCID: 383CCAE4838A954B3B-806C
Subsystem 1 - Part No SW: 7PP 941 329 S HW: 7PP 941 329 S
H01 7020
Coding: 1D0000
Subsystem 2 - Part No SW: 7PP 941 329 S HW: 7PP 941 329 S
H01 7020
Coding: 1D0000
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156C40J2563579
Coding: 020007010000000001
VCID: 24040E942702E1AB87-8070
Part No SW: 4T0 035 664 C HW: 4T0 035 664 C
Component: H-BN-NA H41 1090
Revision: -------- Serial number: 325BT0JB003440
Coding: 030200030001A16D0100820600000001FD0000020000000000
VCID: 3326FDC892EC76130E-8066
Subsystem 1 - Part No: 4T0 919 859 S
Component: NAR 2016 0900
Subsystem 3 - Part No SW: 4T0 919 609 R HW: 4T0 919 609 R
Component: E380 BDT LB2 H01 0011
Serial number: 00000000010982
Component: CD-Database 6890
00658 - Control Head
Fault Frequency: 18
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.05
Time: 03:08:05
Voltage: 12.40 V
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.01
Time: 23:27:26
Voltage: 12.00 V
Bin. Bits: 001
Address 65: Tire Pressure (-----) Labels: 3Y0-907-273.clb
Part No SW: 4H0 907 273 D HW: 4H0 907 273 B
Component: RDKBERU25 H10 0900
Serial number: 10000000049287
ROD: EV_RDKBERU25_AU57.rod
VCID: 2C14E6B447D229EB4F-8078
8400898 - TPMS Warning; Front Left Tire
C1054 00 [009] - Pressure too Low
Reset counter: 206
Mileage: 5886 km
Date: 2012.01.05
Time: 01:39:08
8400901 - TPMS Warning; Front Right Tire
C1056 00 [009] - Pressure too Low
Reset counter: 206
Mileage: 5886 km
Date: 2012.01.05
Time: 01:39:08
Address 6B: Aerodynamics (J920) Labels: None
Part No SW: 4T0 907 777 HW: 4T0 907 777
Component: DRS H01 0022
Serial number: 1701170001554
Coding: 010500
VCID: 7DB21BF0E4287063A8-8028
Address 6C: Back-up Cam.
Address A6: Microphone (J886) Labels:. 420-907-394.clb
Part No SW: 420 907 394 B HW: 420 907 394
Component: BELTMICBOX H10 0840
Coding: 0101030202
ASAM Dataset: EV_BeltMicPARAGAU335 003011
ROD: EV_BeltMicPARAGAU335.rod
VCID: 187C2A64E34AB54B1B-804C
Address C2: Auto Trans 2 (J217) Labels: None
Part No SW: 4T0 927 109 A HW: 4S0 927 109
Component: DL800 ZSG H12 0002
Revision: --H12--- Serial number: 0000000047
ASAM Dataset: EV_TCMDL800421 001024
ROD: EV_TCMDL800.rod
VCID: 3522C3D09498682320-8060
Address D0: Frt Axle Lift (J988) Labels: None
Part No SW: 4S0 959 257 A HW: 4S0 959 257
Component: Lift-VA006 1991
Revision: 00000000 Serial number: 180500121
Coding: 000707
ASAM Dataset: EV_LiftVA003 001010
ROD: EV_LiftVA003.rod
VCID: 3D32DBF0ACA8B063E8-8068
End----(Elapsed Time: 02:17, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
Address 01: Engine
Revision: 00H10V01
Reset counter: 246
Mileage: 5893 km
Date: 2012.01.02
Time: 18:16:56
VzRef: 7A
Bit Info 1: 11
Bit Info 2: 40
Bit Info 3: 36
Bit Info 4: 1F
F-Path: 01
F-Type: 0F
Uz: B5
U1111 00 [008] - -
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.05
Time: 03:47:03
VzRef: 00
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 00
Bit Info 4: 1F
F-Path: 00
F-Type: BD
Uz: B1
U1113 00 [008] - -
Reset counter: 246
Mileage: 5893 km
Date: 2012.01.02
Time: 18:16:57
VzRef: 8C
Bit Info 1: 00
Bit Info 2: 62
Bit Info 3: 36
Bit Info 4: 1F
F-Path: 02
F-Type: 45
Uz: B4
Coding: 4A03208000
Coding: 0000F7
Coding: 02005D
Reset counter: 206
Mileage: 5886 km
Date: 2012.01.05
Time: 02:49:28
Coding: 000004
Reset counter: 206
Mileage: 5886 km
Date: 2012.01.05
Time: 01:38:32
Fault Frequency: 12
Reset counter: 206
Mileage: 5886 km
Date: 2012.01.05
Time: 02:49:27
Reset counter: 206
Mileage: 5889 km
Date: 2012.01.05
Time: 03:08:05
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.05
Time: 03:39:50
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.05
Time: 03:47:06
Coding: 0009071600
Voltage stabilizer:
Fault Frequency: 43
Reset counter: 246
Mileage: 5886 km
Date: 2012.01.05
Time: 02:15:26
Engine running: On
IN ZAS_Te_X: OFF
Datenfeld: 0
Reset counter: 206
Mileage: 5886 km
Date: 2012.01.05
Time: 01:38:30
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
U0100 00 [008] - -
Fault Frequency: 50
Reset counter: 246
Mileage: 5886 km
Date: 2012.01.05
Time: 01:39:34
Engine running: On
IN ZAS_Te_X: OFF
Datenfeld: 0
- 00 [008]
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.05
Time: 03:47:04
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
Coding: 050000
0115 - Databus
Reset counter: 246
Mileage: 5893 km
Date: 2012.01.02
Time: 18:16:57
ESP status: active
0194 - Databus
Reset counter: 246
Mileage: 5893 km
Date: 2012.01.02
Time: 18:16:57
ESP status: active
0196 - Databus
Reset counter: 246
Mileage: 5893 km
Date: 2012.01.02
Time: 18:16:57
ESP status: active
0197 - Databus
Reset counter: 246
Mileage: 5893 km
Date: 2012.01.02
Time: 18:16:57
ESP status: active
Reset counter: 206
Mileage: 5889 km
Date: 2012.01.01
Time: 16:59:37
Reset counter: 206
Mileage: 5889 km
Date: 2012.01.01
Time: 16:59:37
ROD: EV_SARA2.rod
Coding: 0905
Reset counter: 246
Mileage: 5886 km
Date: 2012.01.05
Time: 01:38:44
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.05
Time: 03:46:32
Reset counter: 206
Mileage: 5902 km
Date: 2012.01.03
Time: 01:14:57
Reset counter: 206
Mileage: 5902 km
Date: 2012.01.03
Time: 01:14:57
Reset counter: 206
Mileage: 5902 km
Date: 2012.01.03
Time: 01:14:57
H01 7020
Coding: 1D0000
H01 7020
Coding: 1D0000
Fault Frequency: 18
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.05
Time: 03:08:05
Voltage: 12.40 V
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.01
Time: 23:27:26
Voltage: 12.00 V
Bin. Bits: 001
Reset counter: 206
Mileage: 5886 km
Date: 2012.01.05
Time: 01:39:08
Reset counter: 206
Mileage: 5886 km
Date: 2012.01.05
Time: 01:39:08
Coding: 010500
Coding: 0101030202
Coding: 000707
