Huracan Sypder Soft Top Reset
SHARDUL
C?ID=248471
Does anyone know how to reset to the convertible top on a Huracan sypder.
I am in the soft top menu but the reset button is not functional on the screen.
Thank you
SHARDUL
C?ID=248471
Friday,30,July,2021,09:37:06:55582
VCDS Version: 21.3.0.0 (x64) HEX-NET CB: 0.4544.4
VIN: 11111111111111111 License Plate:
Chassis Type: 11-AU72 (4T0)
Scan: 01 02 03 05 06 08 09 11 31 14 15 16 17 19 1B 22 26 36 3B 42
44 46 47 52 53 55 56 5F 65 6B 6C A6 C2 D0
VIN: 11111111111111111 Mileage: 5900km-3666miles
26-Auto Roof -- Status: Malfunction 0010
6B-Aerodynamics -- Status: OK 0000
6C-Back-up Cam. -- Status: Cannot be reached 0100
A6-Microphone -- Status: OK 0000
C2-Auto Trans 2 -- Status: OK 0000
D0-Frt Axle Lift -- Status: OK 0000
Address 01: Engine
Address 02: Auto Trans (J217) Labels:. 0BH-927-711.clb
Part No SW: 4T0 927 155 L HW: 0BH 927 711 F
Component: LB HP SB NAR H10 4107
Revision: 00H10V01
ASAM Dataset: EV_TCMDL800041 001015
ROD: EV_TCMDL800041_AU72.rod
VCID: 41CAA700D050D4838C-8014
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4S0 907 379 E HW: 4S0 907 379 E
Component: ESP PREMIUM H09 0400
Coding: 258AC151A451838A4B00
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004050
ROD: EV_ESPPremiAU57X_AU72.rod
VCID: 3FCEA1F8A6A4A273FA-806A
0793 - Control Difference
C1069 F0 [008] - Upper Limit Exceeded
Reset counter: 246
Mileage: 5893 km
Date: 2012.01.02
Time: 18:16:56
VzRef: 7A
Bit Info 1: 11
Bit Info 2: 40
Bit Info 3: 36
Bit Info 4: 1F
F-Path: 01
F-Type: 0F
Uz: B5
29212 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[ComScl PDU_Aero_01 - Timeout error]
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.05
Time: 03:47:03
VzRef: 00
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 00
Bit Info 4: 1F
F-Path: 00
F-Type: BD
Uz: B1
29198 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[Scl_Allrad_04_LB_ALR_ESP_akt]
Reset counter: 246
Mileage: 5893 km
Date: 2012.01.02
Time: 18:16:57
VzRef: 8C
Bit Info 1: 00
Bit Info 2: 62
Bit Info 3: 36
Bit Info 4: 1F
F-Path: 02
F-Type: 45
Uz: B4
Part No SW: 4H0 907 064 JD HW: 4H0 907 064 JD
Component: BCM2 2.0 H44 0582
Coding: 09803006000000000000
VCID: 74A43ED4D762312BD7-8020
Serial number: 3218000021243007
Part No SW: 4S0 959 760 HW: 4S0 959 760
Component: MEM-BFS 001 0020
Revision: AA001003 Serial number: 00000203336342
Coding: 0000100000042000000001210101000000000000000000
Shop #: WSC 28977 003 1048576
VCID: 7BB615E8FA3C7E5396-802E
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4T0 820 043 L HW: 4T0 820 043 L
Component: KLIMA 1 ZONE H03 0140
Revision: A1002000 Serial number: 01020320180013
Coding: 4A03208000
VCID: 3522C3D09C98682320-8060
Part No SW: 4H0 907 063 HK HW: 4H0 907 063 EK
Component: BCM1 2.0 H21 0725
Revision: 2502102S Serial number: 00001929723901
Coding: 00E9009040208F303D01C8C300202800001C46C8220602C10000081C0440100000400034010000
VCID: 78BC0AE4CB0A554BFB-802C
Subsystem 1 - Part No SW: 4T1 955 113 HW: 955 113
Component: WWS72x 180220 043 0015
Serial number: ????????????
Coding: 0000F7
Component: G397_RLFS H06 0004
Serial number: 63249304
Coding: 02005D
Subsystem 3 - Part No SW: 4T1 941 531 E HW: 4T1 941 531 E
Component: LCU H02 0012
Subsystem 4 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H02 0007
Serial number: D622581900PAG0MUFU03
02070 - Rear Parking Aid Sensors
Reset counter: 206
Mileage: 5886 km
Date: 2012.01.05
Time: 02:49:28
Address 11: Engine II
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 4S0 907 376 E HW: 4S0 907 376 C
Component: DAEMPFUNGS-SG H06 0065
Serial number: 150318008
ASAM Dataset: EV_AudiMagneRide 003007
ROD: EV_AudiMagneRide_003.rod
VCID: 3C34D6F4B7B2B96BDF-8068
Part No SW: 4G0 959 655 B HW: 4G0 959 655 B
Component: Airbag10.43 H66 0098
Revision: -------- Serial number: 003G0004VN0Y
Coding: 303338443033303030364A55304C34543053
VCID: 3424FED49FE2712B17-8060
Serial number: 6940000Y180001PWZG0%
Serial number: 3575HRB400G5DNAKF1DN
Serial number: 3585HRB400G5DNAK90PT
Serial number: 3515JRB405H5CFN410PA
Serial number: 3525JRB405J5CFN47PFY
Serial number: 3554VRB405D5A8NUI9GC
Serial number: 3564VRB405D5A8NUDGNM
Part No SW: 4T0 953 513 B HW: 4T0 953 513 B
Component: Lenks.Modul H02 0090
Revision: C0072465 Serial number: 90815RAN0002W
Coding: 000004
VCID: 3424FED497E2712B17-8060
Subsystem 1 - Part No SW: 18G 959 542 A HW: 18G 959 542 A
Component: E221__MFL-TAS H05 0012
Serial number: 0015749 TAT 20170718
Address 17: Instruments (J285) Labels:. 4T0-920-xxx-17.clb
Part No SW: 4T0 920 900 K HW: 4T0 920 900 K
Component: KOMBIINSTR. 018 1887
Revision: AA001001 Serial number: 05800054018MOC
Coding: 01F91A94FFBFD3F00200A4
VCID: 373EC9D886949A3332-8062
Reset counter: 206
Mileage: 5886 km
Date: 2012.01.05
Time: 01:38:32
Fault Status: 00111110
Fault Frequency: 12
Reset counter: 206
Mileage: 5886 km
Date: 2012.01.05
Time: 02:49:27
04195 - Telemetry Control Module
Reset counter: 206
Mileage: 5889 km
Date: 2012.01.05
Time: 03:08:05
04224 - Telemetry Control Module; Optical Databus
Fault Status: 00101110
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.05
Time: 03:39:50
03830 - Control Module for Aerodynamics
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.05
Time: 03:47:06
Part No SW: 4T0 907 468 B HW: 4S0 907 468
Component: J533--Gateway H15 0074
Revision: -------- Serial number: 00000002921208
Coding: 0009071600
Shop #: WSC 02391 785 00200
ROD: EV_GatewPkoUDS_002_LB72.rod
Subsystem 1 - Part No SW: 4S0 915 181 HW: 4S0 915 181
Component: J367-BDM H08 0270
Serial number: 55054K34572871868348
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 C HW: 8K0 959 663 C
Serial number: 18067001185021200410
5186 - Second (Slave) Engine Control Module
U0115 00 [008] - No Communication
Fault Frequency: 43
Reset counter: 246
Mileage: 5886 km
Date: 2012.01.05
Time: 02:15:26
Voltage terminal 30: 12.4 V
Voltage terminal 15: 0.0 V
Control Module temperature: 47 °C
System status: Awake_Timer_active
Engine running: On
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: OFF
Datenfeld: 0
5807 - Rear View Camera System Control Module
U104C 00 [009] - No communication
Reset counter: 206
Mileage: 5886 km
Date: 2012.01.05
Time: 01:38:30
Voltage terminal 30: 13.9 V
Voltage terminal 15: 13.9 V
Control Module temperature: 41 °C
System status: Terminal 15 on
Engine running: On
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [008] - -
Fault Frequency: 50
Reset counter: 246
Mileage: 5886 km
Date: 2012.01.05
Time: 01:39:34
Engine running: On
IN ZAS_Te_X: OFF
Datenfeld: 0
5511 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.05
Time: 03:47:04
Voltage terminal 30: 13.5 V
Voltage terminal 15: 13.5 V
Control Module temperature: 52 °C
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 N HW: 8K0 907 144 N
Component: DYNAMIKLENK. H06 0740
Revision: 52001005 Serial number: --------------
Coding: 050000
VCID: 3A38D0ECB586875BCD-806E
Address 22: AWD (J492) Labels: None
Part No SW: 4S0 907 160 HW: 4S0 907 160
Component: 4 Wheel Drive H07 0207
Revision: 00001002 Serial number: 007GD5U
ASAM Dataset: EV_AllWheelContrBORGLB724 006012
ROD: EV_AllWheelContrBORGLB724.rod
VCID: 6E902CBCB14E1BFB21-803A
0115 - Databus
[DTC_FCAN_ESP_Systemstatus]
Reset counter: 246
Mileage: 5893 km
Date: 2012.01.02
Time: 18:16:57
Vehicle speed: 135.95 km/h
Steering angle: 4.80 °
Outside temperature: 34.40 °C
Accelerator pedal travel: 100.00 %
Torque specifications: front axle: 323.25 Nm
Torque: front axle: 323 Nm
Coolant pump: not active
ESP status: active
Hydraulic pressure sensor 1: 16.24 bar
Hydraulic temperature sensor: 42 °C
Cooling fin temperature: 46 °C
Haldex clutch pump: current: 5.00 A
Haldex clutch pump: voltage: 5.00 V
Voltage terminal 30: 13.90 V
0194 - Databus
[DTC_FCAN_Monitoring_Querb]
Reset counter: 246
Mileage: 5893 km
Date: 2012.01.02
Time: 18:16:57
Vehicle speed: 136.35 km/h
Steering angle: 4.50 °
Torque specifications: front axle: 539.00 Nm
Torque: front axle: 539 Nm
ESP status: active
Hydraulic pressure sensor 1: 17.24 bar
Haldex clutch pump: current: 9.00 A
Haldex clutch pump: voltage: 6.75 V
Voltage terminal 30: 13.80 V
0196 - Databus
[DTC_FCAN_Monitoring_Gierrate]
Reset counter: 246
Mileage: 5893 km
Date: 2012.01.02
Time: 18:16:57
ESP status: active
Hydraulic pressure sensor 1: 17.90 bar
0197 - Databus
[DTC_FCAN_Monitoring_Lenkwinkel]
Reset counter: 246
Mileage: 5893 km
Date: 2012.01.02
Time: 18:16:57
ESP status: active
Address 26: Auto Roof () Labels:* None
Part No SW: 4T7 959 255 HW: 4T7 959 255
Component: VSG LB625H01 0012
ASAM Dataset: EV_ElectRoofContrWIMLB625 001007
ROD: EV_ElectRoofContrWIMLB625.rod
VCID: 0248680C95D60F9BD5-8056
0043 - Switch for Folding Top Compartment Cover; Right; Closed
B123C 29 [009] - Signal Implausible
Reset counter: 206
Mileage: 5889 km
Date: 2012.01.01
Time: 16:59:37
0044 - Switch for Folding Top Compartment Cover; Left; Closed
B123B 29 [009] - Signal Implausible
Reset counter: 206
Mileage: 5889 km
Date: 2012.01.01
Time: 16:59:37
Component: MEM-FS 001 0020
Revision: AA001003 Serial number: 00000203336251
Coding: 0000100000040000000001210101000000000000000000
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H04 0056
Revision: -------- Serial number: EJ1BPA7E038FLJ
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 373EC9D88E949A3332-8062
Part No SW: 4T0 959 793 J HW: 4T0 959 793 H
Component: TSG FA H08 0802
Revision: -------- Serial number: 0000311317163
Coding: 010C43525008620100080502
VCID: 4CD48634EF1209EB6F-8018
Part No SW: 4S0 909 144 J HW: 4S0 909 144 B
Component: EPS H13 0906
Revision: 00000000 Serial number: L00272447
Coding: 0905
ASAM Dataset: EV_EPSZFAU72X 003010
ROD: EV_EPSZFAU72X_003.rod
Revision: 00002001 Serial number: 0471325227
Coding: 011E029A18F200A1A0B0C300008500470000000000000000000000000000
Subsystem 1 - Part No: 8J0 951 177
Component: DWA-Sensor H03 0030
01503 - Bulb for 3rd Brake Light (M25)
Fault Status: 00101100
Reset counter: 246
Mileage: 5886 km
Date: 2012.01.05
Time: 01:38:44
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.05
Time: 03:46:32
02911 - Bulb for Side Marker Light; Rear Left (M37)
Fault Status: 11101100
Reset counter: 206
Mileage: 5902 km
Date: 2012.01.03
Time: 01:14:57
02912 - Bulb for Side Marker Light; Rear Right (M38)
Reset counter: 206
Mileage: 5902 km
Date: 2012.01.03
Time: 01:14:57
Reset counter: 206
Mileage: 5902 km
Date: 2012.01.03
Time: 01:14:57
Part No SW: 4T7 035 466 HW: 4T7 035 466
Component: DSP Prem H05 0010
Revision: 00005001 Serial number: 94881066715605
VCID: 77BE09D8C6145A33F2-8022
Part No SW: 4T0 959 792 J HW: 4T0 959 792 H
Component: TSG BF H08 0802
Revision: -------- Serial number: 0000307544649
Coding: 010C43525008620100080500
VCID: 4BD68528EA1C0ED366-801E
Part No SW: 4S0 907 801 HW: 8K0 907 801 J
Component: EPB-4 H04 0001
Revision: -------- Serial number: 20000000005105
ROD: EV_ParkiBrake_AU72.rod
VCID: 70AC32C4AB7A0D0B33-8024
Address 55: Headlight Range (J431) Labels:| 4H4-907-357-V1.clb
Part No SW: 4T0 907 357 A HW: 4H4 907 357 A
Component: ....AFS13.... H01 0003
Serial number: 180312-0004-002
Coding: 72846F6118020200
ASAM Dataset: EV_AFSLEDHELLALB72X 006131
ROD: EV_AFSLEDHELLALB72X.rod
VCID: 383CCAE4838A954B3B-806C
Subsystem 1 - Part No SW: 7PP 941 329 S HW: 7PP 941 329 S
H01 7020
Coding: 1D0000
Subsystem 2 - Part No SW: 7PP 941 329 S HW: 7PP 941 329 S
H01 7020
Coding: 1D0000
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156C40J2563579
Coding: 020007010000000001
VCID: 24040E942702E1AB87-8070
Part No SW: 4T0 035 664 C HW: 4T0 035 664 C
Component: H-BN-NA H41 1090
Revision: -------- Serial number: 325BT0JB003440
Coding: 030200030001A16D0100820600000001FD0000020000000000
VCID: 3326FDC892EC76130E-8066
Subsystem 1 - Part No: 4T0 919 859 S
Component: NAR 2016 0900
Subsystem 3 - Part No SW: 4T0 919 609 R HW: 4T0 919 609 R
Component: E380 BDT LB2 H01 0011
Serial number: 00000000010982
Component: CD-Database 6890
00658 - Control Head
Fault Frequency: 18
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.05
Time: 03:08:05
Voltage: 12.40 V
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.01
Time: 23:27:26
Voltage: 12.00 V
Bin. Bits: 001
Address 65: Tire Pressure (-----) Labels: 3Y0-907-273.clb
Part No SW: 4H0 907 273 D HW: 4H0 907 273 B
Component: RDKBERU25 H10 0900
Serial number: 10000000049287
ASAM Dataset: EV_RDKBERU25 003014
ROD: EV_RDKBERU25_AU57.rod
VCID: 2C14E6B447D229EB4F-8078
8400898 - TPMS Warning; Front Left Tire
C1054 00 [009] - Pressure too Low
Reset counter: 206
Mileage: 5886 km
Date: 2012.01.05
Time: 01:39:08
8400901 - TPMS Warning; Front Right Tire
C1056 00 [009] - Pressure too Low
Reset counter: 206
Mileage: 5886 km
Date: 2012.01.05
Time: 01:39:08
Address 6B: Aerodynamics (J920) Labels: None
Part No SW: 4T0 907 777 HW: 4T0 907 777
Component: DRS H01 0022
Serial number: 1701170001554
Coding: 010500
VCID: 7DB21BF0E4287063A8-8028
Address 6C: Back-up Cam.
Address A6: Microphone (J886) Labels:. 420-907-394.clb
Part No SW: 420 907 394 B HW: 420 907 394
Component: BELTMICBOX H10 0840
Coding: 0101030202
ASAM Dataset: EV_BeltMicPARAGAU335 003011
ROD: EV_BeltMicPARAGAU335.rod
VCID: 187C2A64E34AB54B1B-804C
Address C2: Auto Trans 2 (J217) Labels: None
Part No SW: 4T0 927 109 A HW: 4S0 927 109
Component: DL800 ZSG H12 0002
Revision: --H12--- Serial number: 0000000047
ASAM Dataset: EV_TCMDL800421 001024
ROD: EV_TCMDL800.rod
VCID: 3522C3D09498682320-8060
Address D0: Frt Axle Lift (J988) Labels: None
Part No SW: 4S0 959 257 A HW: 4S0 959 257
Component: Lift-VA006 1991
Revision: 00000000 Serial number: 180500121
Coding: 000707
ASAM Dataset: EV_LiftVA003 001010
ROD: EV_LiftVA003.rod
VCID: 3D32DBF0ACA8B063E8-8068
End----(Elapsed Time: 02:17, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
Address 01: Engine
Revision: 00H10V01
Reset counter: 246
Mileage: 5893 km
Date: 2012.01.02
Time: 18:16:56
VzRef: 7A
Bit Info 1: 11
Bit Info 2: 40
Bit Info 3: 36
Bit Info 4: 1F
F-Path: 01
F-Type: 0F
Uz: B5
U1111 00 [008] - -
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.05
Time: 03:47:03
VzRef: 00
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 00
Bit Info 4: 1F
F-Path: 00
F-Type: BD
Uz: B1
U1113 00 [008] - -
Reset counter: 246
Mileage: 5893 km
Date: 2012.01.02
Time: 18:16:57
VzRef: 8C
Bit Info 1: 00
Bit Info 2: 62
Bit Info 3: 36
Bit Info 4: 1F
F-Path: 02
F-Type: 45
Uz: B4
Coding: 4A03208000
Coding: 0000F7
Coding: 02005D
Reset counter: 206
Mileage: 5886 km
Date: 2012.01.05
Time: 02:49:28
Coding: 000004
Reset counter: 206
Mileage: 5886 km
Date: 2012.01.05
Time: 01:38:32
Fault Frequency: 12
Reset counter: 206
Mileage: 5886 km
Date: 2012.01.05
Time: 02:49:27
Reset counter: 206
Mileage: 5889 km
Date: 2012.01.05
Time: 03:08:05
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.05
Time: 03:39:50
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.05
Time: 03:47:06
Coding: 0009071600
Voltage stabilizer:
Fault Frequency: 43
Reset counter: 246
Mileage: 5886 km
Date: 2012.01.05
Time: 02:15:26
Engine running: On
IN ZAS_Te_X: OFF
Datenfeld: 0
Reset counter: 206
Mileage: 5886 km
Date: 2012.01.05
Time: 01:38:30
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
U0100 00 [008] - -
Fault Frequency: 50
Reset counter: 246
Mileage: 5886 km
Date: 2012.01.05
Time: 01:39:34
Engine running: On
IN ZAS_Te_X: OFF
Datenfeld: 0
- 00 [008]
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.05
Time: 03:47:04
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
Coding: 050000
0115 - Databus
Reset counter: 246
Mileage: 5893 km
Date: 2012.01.02
Time: 18:16:57
ESP status: active
0194 - Databus
Reset counter: 246
Mileage: 5893 km
Date: 2012.01.02
Time: 18:16:57
ESP status: active
0196 - Databus
Reset counter: 246
Mileage: 5893 km
Date: 2012.01.02
Time: 18:16:57
ESP status: active
0197 - Databus
Reset counter: 246
Mileage: 5893 km
Date: 2012.01.02
Time: 18:16:57
ESP status: active
Reset counter: 206
Mileage: 5889 km
Date: 2012.01.01
Time: 16:59:37
Reset counter: 206
Mileage: 5889 km
Date: 2012.01.01
Time: 16:59:37
ROD: EV_SARA2.rod
Coding: 0905
Reset counter: 246
Mileage: 5886 km
Date: 2012.01.05
Time: 01:38:44
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.05
Time: 03:46:32
Reset counter: 206
Mileage: 5902 km
Date: 2012.01.03
Time: 01:14:57
Reset counter: 206
Mileage: 5902 km
Date: 2012.01.03
Time: 01:14:57
Reset counter: 206
Mileage: 5902 km
Date: 2012.01.03
Time: 01:14:57
H01 7020
Coding: 1D0000
H01 7020
Coding: 1D0000
Fault Frequency: 18
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.05
Time: 03:08:05
Voltage: 12.40 V
Reset counter: 246
Mileage: 5889 km
Date: 2012.01.01
Time: 23:27:26
Voltage: 12.00 V
Bin. Bits: 001
Reset counter: 206
Mileage: 5886 km
Date: 2012.01.05
Time: 01:39:08
Reset counter: 206
Mileage: 5886 km
Date: 2012.01.05
Time: 01:39:08
Coding: 010500
Coding: 0101030202
Coding: 000707
SHARDUL
C?ID=248471
Anyone?
You have "Implausible Signal" DTCs from two of the switches for the top. I don't think any kind of "Reset" is going to fix that.
SHARDUL
C?ID=248471
OK thank you
Why do you want to do this? What is the problem with the top?
If it is "stuck" up or down, get someone to help you and hold the up or down button and also have a helper pull up or down on the top and see if it will free itself up; one or both (?) of the motors my have a flat spot on the armature and you need to get it off of that spot. It maybe worth a try.
