Audi TT (8S) - 2019 Audi TT
Rikki-Tikki-Tavi
Southern Maryland, USA
C?ID=451140
Second post... I originally posted this in the "get to know me" section but I reposted it here to get some feedback on the engine fault codes; in particular:
Address 01: Engine (J623-DHHA)       Labels: None
   Part No SW: 8S0 906 259 H    HW: 06K 907 425 J
   Revision: --H13---
   Coding: 0A2500124426010F3000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208S0906259H 001004
   ROD: EV_ECM20TFS0208S0906259H.rod
   VCID: 42DD43E084049FBBD97-8016
15080 - Cold Start Idle Air Control System
          P050A 00 [096] - Malfunction
                    Mileage: 20059 km
                    Date: 2021.07.13
                    Time: 20:19:05
                    Engine RPM: 866.00 /min
                    Normed load value: 39.2 %
                    Coolant temperature: 72 �C
                    Intake air temperature: 52 �C
                    Voltage terminal 30: 12.382 V
                    Engine: operating status: IS
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 13 s
                    MAP_MES_SAE: 93 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.963 V
                    FAC_TPS_1_SAE: 22.656250 %
                    FUP_H_SAE: 19510.0 kPa
26279 - Manifold / Barometric Pressure Sensor (G71) / (F96)
          P0106 00 [040] - Implausible Signal
                    Mileage: 21406 km
                    Date: 2021.07.23
                    Time: 15:47:38
                    Engine RPM: 2224.25 /min
                    Vehicle speed: 128 km/h
                    Coolant temperature: 90 �C
                    Intake air temperature: 37 �C
                    Voltage terminal 30: 14.804 V
                    Unlearning counter according OBD: 33
                    PV: 0.00 %
                    Throttle valve angle: 4.916 �
                    MAP_MES_SAE: 29 kPa
                    TAA: 28.469 �C
                    Engine oil temperature: 104.0 �C
                    Engine: operating status: PUC
                    Time since engine start: 1945.0 s
Original post is here
2019 Audi TT with RaceChip GTS Black (no haters please...) and a yummy carbon fiber gigantic APR intake (again, no haters please); otherwise stock.
Buying the Ross-Tech VCDS was on my list, and after popping a CEL on a recent road trip I decided to pull the trigger on the SW.
Full Auto Scan prior to clearing any codes is linked here. The below fault is what kicked on the CEL. The CEL shut itself off overnight and did not return. As the RacecChip is tied directly into the MAP sensor, I suspect it was the culprit. The CEL did come on very close after receiving a low fuel warning; maybe unrelated but happened very close. I cleared all codes after this run and will monitor. I also shut off the auto start-stop function, yeah!
"26279 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 00 [040] - Implausible Signal"
APR Gigantic open intake with carbon fiber tube, RaceChip (pink connector) is mounted directly behind the intake, new oil breather filter (white) to left of RaceChip
Bruce
Near Philadelphia, PA, USA
Does this fault come back on? Or was this a one time event?
If one time, clear the code and keep an eye on it. It may have been a hiccup or sun spot activity.. you know, gremlins in the magic smoke inside all those magic chips we can't get.
"Access Denied"
That would be my first thought too. If it were mine and I was trying to trouble-shoot these codes, I would start removing the aftermarket parts one at a time, and clearing the fault codes each time, to see if any of them are the source of the problem.
Please post a full and unedited Autoscan "here" (ie on the forum).
Rikki-Tikki-Tavi
C?ID=451140
Right... So far a one-time thing. I will continue to monitor; very happy to have VCDS and all the smart folks here
Sorry about that; I tried to link it but it seems that didn't work. Full auto scan below:
Thursday,29,July,2021,08:22:35:46314
Dealer/Shop Name: Greenwood Motorsports
VIN: TRUAEAFV6K1011585   License Plate: TT
Mileage: 22235km-13816mi   Repair Order:
Chassis Type: FV-AU37 (8S0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 3C 42 44 47 52 55 5F 6C
          A9
VIN: TRUAEAFV6K1011585   Mileage: 22235km-13816miles
   Revision: --H13---
                    Mileage: 20059 km
                    Date: 2021.07.13
                    Time: 20:19:05
                    Coolant temperature: 72 °C
                    Intake air temperature: 52 °C
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 13 s
                    MAP_MES_SAE: 93 kPa
                    Mileage: 21406 km
                    Date: 2021.07.23
                    Time: 15:47:38
                    Coolant temperature: 90 °C
                    Intake air temperature: 37 °C
                    PV: 0.00 %
                    Throttle valve angle: 4.916 °
                    MAP_MES_SAE: 29 kPa
                    TAA: 28.469 °C
                    Engine oil temperature: 104.0 °C
   Part No SW: 0GC 300 013 N    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2404
   Revision: 00H06V07
   ROD: EV_TCMDQ381061_VW37.rod
   VCID: 2F3B1A54279602D3269-807A
   No subsystems:
   Part No SW: 8S0 907 379 N    HW: 8S0 907 379 F
   Component: ESC           H42 0550
   Revision: 00000000    Serial number: 61429000000949
   Coding: 22AAE08D0A9A15AA4196006C8296930633440750A8820041C960CC
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 060017
   ROD: EV_Brake1UDSContiMK100IPB_060.rod
   VCID: 4CC16DD8B64059CB23B-8018
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0518087043
   Coding: 030C0C1720
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3E253710F0FCFB5BBDF-806A
   Part No SW: 8S0 820 043     HW: 8S0 820 043
   Component: AC Automat    H05 0040
   Revision: 20010000    Serial number: 19140000009000
   Coding: 400040100011041100
   ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
   ROD: EV_AirCondiVAPrehAU33x.rod
   VCID: 6C81CD58D600B9CB43B-8038
   Humidity sensor: exterior:
   Rear A/C Control Head 1:
   Subsystem 2 - Part No SW: 8S0 820 373 A    HW: 8S0 820 373 A
   Component: E774 BuA_1  H07 0020
   Serial number: 00000000000000057255
   Rear A/C Control Head 2:
   Subsystem 3 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
   Component: E775 BuA_2  H07 0020
   Rear A/C Control Head 3:
   Subsystem 4 - Part No SW: 8S0 820 359     HW: 8S0 820 359
   Component: E776 BuA_3  H07 0020
   Rear A/C Control Head 4:
   Subsystem 5 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
   Component: E777 BuA_4  H07 0020
   Rear A/C Control Head 5:
   Subsystem 6 - Part No SW: 8S0 820 373 B    HW: 8S0 820 373 B
   Component: E778 BuA_5  H07 0020
   Part No SW: 5Q0 937 085 BT    HW: 5Q0 937 085 BG
   Component: BCM MQBAB HNA H38 0273
   Serial number: 01001915600088
   ROD: EV_BCMBOSCH_019.rod
   VCID: 0C41ADD8F6C019CBE3B-8058
   Subsystem 1 - Part No SW: 8S1 955 119 B    HW: 8K1 955 119 B  Labels: 5QX-955-119-V1.CLB
   Component: 43x LL 190506  038 0371
   Serial number: 00000001905020302676
   Coding: 1BC7F7
   Serial number: 21940089X81A955547A0
   Coding: 00005D
   Serial number: 27 03 2019  20000477
   Subsystem 4 - Part No SW: 4N0 907 410 B    HW: 4M0 907 410 A
   Component: USHL5  H10 0100
   Serial number: 0000009600368Z00W902
   Coding: 150000
   Garage door opener control head:
   Subsystem 5 - Part No SW: 8S0 959 719     HW: 8S0 959 719
   Component: GTO BF  H05 0010
   Serial number: 20190417090113 00175
   Subsystem 6 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000031180115
204546 - Remote key 2
          B147A 18 [008] - Current Too Low
                    Reset counter: 192
                    Mileage: 16118 km
                    Date: 2021.04.06
                    Time: 14:08:25
   Part No SW: 5Q0 919 294 M    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0545
   Revision: --------    Serial number: 39331915601626
   Coding: 0070150051
   ASAM Dataset: EV_EPHVA18AU3700000 003027
   ROD: EV_EPHVA18AU3700000_003.rod
   VCID: 45D758FC952AA883FC5-8010
   Part No SW: 5Q0 959 655 R    HW: 5Q0 959 655 R
   Serial number: 003M9R00AZ9T
   Coding: BFCCF0C000800000A000001FC24800000065
   VCID: 4FFB7AD4475662D3469-801A
   Subsystem 1 - Part No SW: 4M0 959 339     HW: 4M0 959 339
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH00000000000BNHRLG
   Coding: 303334
   Subsystem 2 - Part No SW: -----------    HW: 480 001 506 19
   Serial number: 35700000000DDC80FC35
   Subsystem 3 - Part No SW: -----------    HW: 480 001 506 19
   Serial number: 358000000006EC80FC30
   Subsystem 4 - Part No SW: -----------    HW: 480 010 705 18
   Component: SideSensor_Dr  005 0108
   Serial number: 351001A0D80985929E2D
   Subsystem 5 - Part No SW: -----------    HW: 480 401 905 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001C8F029AA561AG
   Subsystem 6 - Part No SW: -----------    HW: 480 401 905 19
   Component: FrontSensor_P  005 6149
   Serial number: 3560001C8F029AA5724D
   Part No SW: 8S0 907 129 AJ    HW: 8S0 907 129 AJ
   Component: Lenks. Modul  H07 0150
   Revision: --------    Serial number: 91335SEK01291
   Coding: 2058
   ASAM Dataset: EV_SMLSKLOMQB 050001
   ROD: EV_SMLSKLOMQB_050.rod
   VCID: 025D83E0C4845FBB997-8056
   Part No SW: 8S0 920 890 D    HW: 8S0 920 890 D
   Component: FBenUSA       H45 0359
   Coding: 08E70041298ACF050220E8C09800800000000000
   ASAM Dataset: EV_DashBoardBOSCHAU33X 001032
   ROD: EV_DashBoardBOSCHAU33X.rod
   VCID: 3B233E04E3EEEE739A1-806E
   Part No SW: 8S0 907 468 J    HW: 8S0 907 468 E
   Component: GW MQB TT3    023 0366
   Serial number: 26051910801585
   Coding: 030100042F025B004B000068380B00000000000000000000000000000001
   ASAM Dataset: EV_GatewContiAU33X 013025
   ROD: EV_GatewContiAU33X_013.rod
   VCID: 47CB52F4AF26BA930E9-8012
   Generator:
   Component: 1-01-0d-01-04
   Subsystem 2 - Part No SW: 8S0 951 523 C    HW: 8S0 951 523 C
   Component: J453 MFL  H07 0002
   Serial number: 20190530063045 00333
   Subsystem 3 - Part No SW: 8W0 915 181     HW: 8W0 915 181
   Serial number: 3141941405
   Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
   Component: Haldex4Motion H55 7756
   Serial number: HA1-00017.05.19
   Coding: 0101
   Part No SW: 8S0 907 566     HW: 4H0 907 566 F
   Component: SWA Master    H08 0060
   Serial number: 0516185789
   Coding: 030311
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 7CA1FD18A660294BD3B-8028
   Subsystem 1 - Part No SW: 8S0 907 568     HW: 4H0 907 568 F
   Component: SWA Slave  H08 0060
   Serial number: 0518363945
   Coding: 030311
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS002 0287
   Serial number: YE007SFA11955
   Coding: 001F53225000000100000402
   VCID: 44D145F89E10918BEBB-8010
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Coding: 811F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C213D18E6E0E94B93B-8068
   Part No SW: 8S0 035 466 A    HW: 8S0 035 466
   Component: MIB2_amp_P_TT H10 0440
   Revision: 00000001    Serial number: AUZ8ZAK5C00H6HX
   Coding: 0133040000AA2A2AAA0000010000
   ASAM Dataset: EV_AMPMst16C1Gen2ALPI 001012
   ROD: EV_AMPMst16C1Gen2ALPI_AU37.rod
   VCID: 34311538CEB0210B5BB-8060
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS002 0287
   Serial number: YE007SFB04376
   Coding: 001F53225C00000100000402
   VCID: 43D346E49B1E96B3D21-8016
   Part No SW: 4H4 907 357 G    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0115
   Coding: 03EA001123200400
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005012
   VCID: 36352F30D8CC331B65F-8062
   Coding: E01800
   Coding: E01800
   Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 S002
   Coding: E01800
   Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 S002
   Coding: E01800
   Part No SW: 8S0 035 046 B    HW: 8S0 035 025 G
   Component: MU-H-LNS-US   055 1462
   Serial number: A707F0KS005370
   Coding: 013304020000000011220002041A00332F0000E0007000047E
   Subsystem 1 - Part No SW: V03 959 802 DK    HW: -----------
   Component: NAR 2018/2019  --- 0066
   Subsystem 2 - Part No SW: 8S0 919 614 M    HW: 8S0 919 614 M
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK118051900010142
   Compact disc data bank:
   Component: Gracenote2  --- 3013
   Coding: 0233040102002001000040
   VCID: 392F240CE9D2DC6388D-806C
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 8S0 907 159 E    HW: 81A 907 159 A
   Component: SAS-GEN 2.5   H08 0001
   Serial number: 190508201222
   VCID: 3FDB4A14F7F6F253B69-806A
End----------(Elapsed Time: 01:30, VBatt start/end: 12.2V/12.1V)-----------
VCDS Release 21.3.0:  SRI Reset-SRI2.CLB
Control Module Part Number: 8S0 920 890 D       Labels:  *Redir Fail!-SRI2
Component:FBenUSA       H45 0359, Coding:08E70041298ACF050220E8C09800800000000000
Channel        Description                                                     Current val.                                                    New val.
IDE00342-ESI: Resetting ESI        ESI: Service Reminder Status                                    no warning                                                      ---
IDE00510-ESI: distance driven from inspection                                                           ESI: Distance since Inspection                                  5800 km                                                         ---
IDE00511-ESI: time from inspection        ESI: Time since Inspection                                      112 d                                                           ---
IDE00515-ESI: oil quality        ESI: Oil Quality                                                poor oil quality                                                ---
IDE00517-ESI: soot entry        ESI: Soot Quantity                                              0 km                                                            ---
IDE00518-ESI: thermal load        ESI: Thermal Load                                               9100 km                                                         ---
IDE01153-SIA: maximum value of distance to service                                                      SIA: Maximum Distance to Service                                16100 km                                                        ---
IDE01154-SIA: maximum value of time to service                                                          SIA: Maximum Time to Service                                    365 d                                                           ---
IDE03349-FIX:Max. distance driven until next mileage-related inspection                                 FIX: Maximum Distance to Inspection                             32187 km                                                        ---
IDE03350-FIX: Maximum time until next time-dependent inspection                                         FIX: Maximum Time to Inspection                                 730 d                                                           ---
IDE03351-FIX: Distance covered since last mileage-dependent inspection                                  FIX: Distance since Inspection                                  22200 km                                                        ---
IDE03352-FIX: Time since last time-dependent inspection                                                 FIX: Time since Inspection                                      651 d                                                           ---
Rikki-Tikki-Tavi
C?ID=451140
"Access Denied"
Thank you for your help with my questions and the help getting me settled here. I think I fixed the link (Auto Scan Here)
Besides trying what Uwe advised in post #3,
Have you touched base with APR regarding these faults ? They may have some insights regarding these mods. If they can not help, then I would follow post #3 advice .
My prediction: APR will point the finger at the Racechip thing. Racechip will point the finger at the APR bits. That's always a problem when mixing and matching engine performance mods.
Ah, yes. Thank you Uwe, I missed that ; his photos of APR products have such a impact that I completely missed that detail. Also, APR has a tune and does alot of R and D with Audi TT's . So, not sure why RTT mixed them. :thanks:
Rikki-Tikki-Tavi
C?ID=451140
For now, I have "reviewed" the fault codes, cleared the codes, and will continue to monitor.
I'm right here, you could just ask me. :)
The reason I installed a RaceChip (versus a tune) is primarily because I can install/control/remove the box on my own. I prefer to do my own maintenance (and mods) if possible; it's why I bought the Ross-Tech SW. Thanks again for your feedback.
