2021 VW T6.1 Multivan
lordbowl
Sydney, Australia
C?ID=445269
Hello everyone, I'm new to forum and also new to VCDS. I have a registered HEX-V2. I'm hoping to discover some useful tweaks for my new VW Multivan.
My first scan is below and I note there are a few malfunctions/faults. Should I be worried about these? If not, I'll happily post this scan to the Reference Scans forum.
I look forward to learning from you all and maybe passing some knowledge on to others in future.
Wednesday,28,July,2021,17:55:47:55694
VIN: WV2ZZZ7HZMH106325   License Plate:
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 02 03 08 09 10 13 14 15 17 19 36 3C 44 55 5F 65 69 6D A5
          BB BC BE BF D6 D7
VIN: WV2ZZZ7HZMH106325   Mileage: 434km-269miles
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
Address 01: Engine (J623-CXEC)       Labels: None
   Part No SW: 04L 906 057 L    HW: 04L 907 445 N
   Component: R4 2.0l BTD   H01 0411
   Revision: 23401001
   Coding: 002540144374050800000000000000000000000000000000
   Shop #: WSC 11665 004 1048576
   ASAM Dataset: EV_ECM20BTD03004L906057L 004003
   ROD: EV_ECM20BTD030_VN46.rod
   VCID: 372B228C7FC01C537E9-8062
Readiness: N/A
   Part No SW: 0BT 300 046 R    HW: 0GC 927 711 H
   Component: GSG DQ500     H06 3102
   Revision: 00H06V11
   ROD: EV_TCMDQ500021_VN46.rod
   VCID: 45D75844352C7EC3FC5-8010
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 7LA 614 517 B    HW: 7LA 614 517
   Component: ESC_high      H01 0800
   Serial number: 08512259210328
   Coding: 10552452C847E68B085724A6136B676639272478
   Shop #: WSC 00012 790 00028
   ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 003012
   ROD: EV_Brake1ESP90iBOSCHVN46X_003.rod
   VCID: 3E2537A850FA2D1BBDF-806A
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 7LA 907 040 E    HW: 7LA 907 040 E
   Component: Climatronic   H01 0602
   Coding: 0031100008100300010009005040010500000000000B1101C08000000000
   Shop #: WSC 00012 790 00176
   ASAM Dataset: EV_AirCondiBHTCVN54XT6PA 001002
   ROD: EV_AirCondiBHTCVN54XT6PA.rod
   VCID: 3D2730A45DFC3603A45-8068
   Rear A/C control head:
   Subsystem 1 - Part No SW: 7LA 907 049 F    HW: 7LA 907 049 F
   Component: E857  H02 0301
   Serial number: 00005062171111210222
   Part No SW: 2Q0 937 090 C    HW: 2Q0 937 090 C
   Component: BCM A0 Std+   H11 0943
   Serial number: 00102110002950
   ASAM Dataset: EV_BCMA0 206001
   ROD: EV_BCMA0_206.rod
   VCID: 323D139894A2F97B497-8066
   Subsystem 1 - Part No SW: 5Q0 955 559 C    HW: 5Q0 955 559 C  Labels: 5Q0-955-547.CLB
   Component: RLS  054 0206
   Serial number: S2Y21M04D07H10M27S23
   Coding: 0018DD
   Driver door control module:
   Subsystem 2 - Part No SW: 7L1 959 405 B    HW: 7L1 959 163 B
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000049125900
   Coding: 1F0007
   Front passenger door control module:
   Subsystem 3 - Part No SW: 7L1 959 406 B    HW: 7L1 959 164 B
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000049142865
   Coding: 050007
   Subsystem 4 - Part No SW: 2N0 951 173     HW: 2N0 951 173
   Component: Sensor, DWA  015 0316
   Serial number: 000000000ZY2033525UM
   Serial number: 00000000000049391512
591363 - Motor for External Mirror Folding; Driver Side
          B1745 07 [008] - Mechanical Failure
                    Reset counter: 43
                    Mileage: 68 km
                    Date: 2021.07.20
                    Time: 17:47:24
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: On
                    Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
                    Zusaetzliche Umgebungsdaten-Low beam: Not operated
                    Zusaetzliche Umgebungsdaten-OFF: Not operated
                    Zusaetzliche Umgebungsdaten-Outside temperature: -50.0 °C
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: operated
                    Zusaetzliche Umgebungsdaten-Position lamps: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light left: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light right: Not operated
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
                    Zusaetzliche Umgebungsdaten-last wakeup: keine Stoerschutzursache
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 13.1 V
595971 - Motor for External Mirror Folding; Passenger Side
          B1755 07 [008] - Mechanical Failure
                    Reset counter: 43
                    Mileage: 68 km
                    Date: 2021.07.20
                    Time: 17:47:23
                    Zusaetzliche Umgebungsdaten-voltage measurement: 13.2 V
   Part No SW: 5QA 919 298 K    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H08 0073
   Serial number: 000150057621090
   Coding: 8379167951
   ASAM Dataset: EV_EPHVA2CAU3700000 009055
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 58E98130D29EF32B973-800C
12583936 - Data Bus for Suspension
          U10AC 00 [008] - No Communications
          [Daten-Bus Fahrwerk - kein Signal/keine Kommunikation]
                    Reset counter: 48
13688835 - Databus
          [Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
                    Reset counter: 42
                    Mileage: 20 km
                    Date: 2021.07.18
                    Time: 10:31:12
12650512 - Databus
                    Fault Frequency: 58
                    Reset counter: 15
                    Mileage: 20 km
                    Date: 2021.07.18
                    Time: 10:30:35
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Coding: 3204678B49FF8748949C815580508700000000000000000004
   ROD: EV_ACCMRRCONTIVW376_003_VN54.rod
   VCID: 43D3465C3B1840F3D21-8016
   Part No SW: 5Q0 907 376 C    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0130
   Serial number: 08032141350110
   ROD: EV_DRCONTITEMIC_VW27.rod
   VCID: 392F24B449D40A2388D-806C
   Part No SW: 2Q0 959 655 AE    HW: 2Q0 959 655 AE
   Component: VW22Airbag    016 0506
   Revision: --------
   Coding: 88CFC0000000000080000000008C00000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 005989506A8E9BEB8F3-8054
   Subsystem 1 - Part No SW: -----------    HW: 442 062 502 21
   Serial number: 3577Y519D011BEE53228
   Subsystem 2 - Part No SW: -----------    HW: 442 062 502 21
   Serial number: 3587Y519D00B16D04292
   Subsystem 3 - Part No SW: -----------    HW: 442 0D0 810 20
   Component: SideSensor_Dr  30F 1108
   Serial number: 351CF11AD338361383DQ
   Subsystem 4 - Part No SW: -----------    HW: 442 0D0 810 20
   Component: SideSensor_Pr  30F 1108
   Serial number: 352CF11AD3383612976O
Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI3
   Part No SW: 7LA 920 320 A    HW: 7LA 920 320 A
   Component: KOMBI         502 5175
   Coding: 24A400887C8800080188620F1001000080001E02
   ASAM Dataset: EV_DashBoardVDDMQBA0 001044
   ROD: EV_DashBoardVDDMQBA0_VW27.rod
   VCID: 3537288465CCEE436C5-8060
10485841 - Monitored Display Output
          B159A F0 [008] - Replacement Function Activated
                    Reset counter: 43
                    Mileage: 68 km
                    Date: 2021.07.20
                    Time: 16:16:10
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_Audio_0x31 keine Kommunikation]
                    Fault Frequency: 9
                    Reset counter: 54
                    Mileage: 21 km
                    Date: 2021.07.19
                    Time: 15:16:12
          U1110 00 [008] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Reset counter: 54
                    Mileage: 207 km
                    Date: 2021.07.22
                    Time: 18:48:03
16777022 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_NAV SD_0x32 keine Kommunikation]
                    Reset counter: 54
                    Mileage: 207 km
                    Date: 2021.07.22
                    Time: 18:48:03
16777056 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_SDS_0x46 keine Kommunikation]
                    Fault Frequency: 9
                    Reset counter: 54
                    Mileage: 21 km
                    Date: 2021.07.19
                    Time: 15:16:12
16711685 - Databus
                    Reset counter: 54
                    Mileage: 136 km
                    Date: 2021.07.21
                    Time: 15:42:45
   Part No SW: 3Q0 907 530 AG    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5423
   Serial number: 31032110521347
   Coding: 030100344F05730499100258900F00010001070000000000000000000000
   ROD: EV_GatewNF_VW27.rod
   VCID: 74B1D5802E36B74B9BB-8020
   Generator:
   Component: 5-00-15-00-04
   Subsystem 2 - Part No SW: 3G0 959 442 N    HW: 3G0 959 442 N
   Component: E221__MFL-PR6  H07 0110
   Serial number: PR6-0440066027214068
   Coding: 2C0D00
   Subsystem 3 - Part No SW: 7E0 915 181 L    HW: 7E0 915 181 L
   Serial number: 77197200002103180142
197149 - Generator
          U1052 00 [008] - No Communication
          [Generator (LIN#1) Timeout]
                    Reset counter: 48
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          [Ruhestrom oberer Grenzwert überschritten]
                    Fault Frequency: 8
                    Reset counter: 55
                    Mileage: 21 km
                    Date: 2021.07.18
                    Time: 19:29:27
                    Terminal 30 power supply: 12.2 V
                    Terminal 15: OFF
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 F    HW: 5Q0 959 760 F
   Component: Sitzmemory    H10 0026
   Serial number: Y0007UAC35042
   Coding: 0014000000000500008480818080000000008181000000F400
   Shop #: WSC 00012 790 00101
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: 40D949502A0E5BEBCF3-8014
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0150
   Serial number: 14520007850643
   Coding: 92954640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15.rod
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H06 0150
   Serial number: 14520007796106
2240530 - Databus
          [databus error value received - Parkhilfe_01 - PH_Tongeber_H_verfuegbar]
                    Reset counter: 27
                    Mileage: 20 km
                    Date: 2021.07.18
                    Time: 10:31:12
Address 44: Steering Assist (J500)       Labels:| 2N0-909-143.clb
   Part No SW: 7LA 909 144 G    HW: 7LA 909 144 D
   Component: EPS_MQB_ZFLS  751 7160
   Coding: 9306
   ASAM Dataset: EV_SteerAssisMNB 002015
   ROD: EV_SteerAssisMNB.rod
   VCID: 46D55F48082A75DBF5F-8012
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Coding: 0C86020009200003
   ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
   VCID: 41DF4C54210452E3C0D-8014
   Part No SW: 3G5 035 876 C    HW: 3G5 035 876 A
   Component: MU-O-N-R2     H56 0782
   Serial number: WG8LGM100321000
   Coding: 64600008000020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001002
   ROD: EV_MUOIMQB_VN46.rod
   VCID: 2F3B1AEC8790D493269-807A
   Subsystem 1 - Part No SW: 5G6 919 606 B    HW: 5G6 919 606 B
   Component: ABT_High-2     H61 9216
   Serial number: VWZ6ZJY0970631
   Subsystem 2 - Part No SW: V03 959 809 KJ    HW: -----------
   Component: MRM 2021       --- 4032
6720 - Rear View Camera
          B1102 31 [008] - No Signal
                    Reset counter: 27
                    Mileage: 21 km
                    Date: 2021.07.18
                    Time: 11:25:45
                    Voltage terminal 30: 12.1 V
   Part No SW: 5Q0 907 273 D    HW: 5Q0 907 273
   Component: RDKBERU30     H06 0010
   Serial number: 40000000529596
   ROD: EV_RDKBERU30_VW41.rod
   VCID: 36352F8878CAE55B65F-8062
Address 69: Trailer (J345)       Labels:| 5H0-907-383.clb
   Part No SW: 5H0 907 383     HW: 5H0 907 383
   Component: Anhaenger     H09 0040
   Serial number: 000000000005741
   Coding: 0100000202001300
   ASAM Dataset: EV_TrailFunctGener3Hella 001009
   ROD: EV_TrailFunctGener3Hella_VW37.rod
   VCID: 6B83CEFC730868B34A1-803E
Address 6D: Trunk Elect. (J605)       Labels:* None
   Part No SW: 7LA 959 107 A    HW: 4M0 959 107 C
   Component: HDSG-Modul    H14 0673
   Revision: --------    Serial number: A2-C769-9790-3
   Coding: 4180
   ASAM Dataset: EV_DeckLidCONTIVN46T 001017
   ROD: EV_DeckLidCONTIVN46T.rod
   VCID: 44D145403E1647CBEBB-8010
   Part No SW: 2Q0 980 653 B    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H13 1202
   Serial number: E57829512210960
   Coding: 00010C08117AC020509F00000030002006018000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   VCID: 343115806EB6F74B5BB-8060
1124116 - Internal Fault
          B200F F0 [008] - Unknown Error Elaboration
          [SPI_communication_to_EyeQ_timout]
                    Reset counter: 32
                    Mileage: 148 km
                    Date: 2021.07.21
                    Time: 18:07:30
Address BB: Door Rear Drv (J1093)       Labels: None
   Part No SW: 7LA 035 593 A    HW: 7LA 035 593 A
   Component: SLD_Rx-Unit_d H07 0031
   Serial number: 1900B7B5
   Coding: 00
   ASAM Dataset: EV_ReceiRearDriveSideHuf 002002
   ROD: EV_ReceiRearDriveSideHuf.rod
Address BC: Door Rear Pass (J1094)       Labels: None
   Component: SLD_Rx-Unit_p H07 0031
   Serial number: 1900B644
   Coding: 00
   ASAM Dataset: EV_ReceiRearPasseSideHuf 002002
Address BE: Slid. Door Rear Left (J926)       Labels:* None
   Part No SW: 7LA 959 244 D    HW: 7LA 959 244 D
   Component: Slidingdoor_d H09 0037
   Serial number: 18009089
   Coding: 12
   ASAM Dataset: EV_SlideDoorDriveHufT6PA 001010
   ROD: EV_SlideDoorDriveHufT6PA_VN46.rod
   VCID: 49CF547419349AA318D-801C
Address BF: Slid. Door Rear Right (J927)       Labels:* None
   Component: Slidingdoor_p H09 0037
   Serial number: 1800917B
   Coding: 12
   ASAM Dataset: EV_SlideDoorPasseHufT6PA 001010
   ROD: EV_SlideDoorPasseHufT6PA_VN46.rod
12313 - Motor for Sliding Door Opening
          B115A 19 [040] - Current Too High
                    Reset counter: 19
                    Mileage: 166 km
                    Date: 2021.07.21
                    Time: 18:17:24
   Part No SW: 992 941 571 AE    HW: 992 941 571 A
   Component: LED1L         H08 9202
   ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
   VCID: 6597B8C495EC5EC31C5-8030
   Component: LED1R         H08 9202
End----(Elapsed Time: 01:48, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
Mari
C?ID=150535
If this was the first scan of the car, just clear faultcodes, do a little drive and see which of them come back... those need further investigation...
Looks like yet another case of a dealer not doing a proper PDI...
But yes, by all means, clear the faults. Most of them occurred when the vehicle has ~20 km on it, presumably before it was delivered.
lordbowl
Sydney, Australia
C?ID=445269
Thank you Mari & Uwe. I have cleared the faults and most remain cleared upon a new scan.
Unfortunately, it seems my new Multivan has SFD so I'm unable to perform any of the tweaks I was hoping to achieve (eg. auto-folding mirrors, mirror dip on reverse, etc.). I suppose I just need to wait until VW allow that functionality.
Trowbridge, UK
Have you tried opening the bonnet (hood)? Some recent vehicles have a diagnostic interlock that prevents some changes being made unless the bonnet (hood) is open.
lordbowl
Sydney, Australia
C?ID=445269
Thanks PetrolDave,
I had noticed in other parts of the forum that opening the bonnet is a good idea and I had tried that with no success.
I tried a basic adaptation (mirror fold on key fob lock), but an error message "Vehicle speed too fast" was the result (I was stationary with the engine idling).
I tried another basic adaptation (needle sweep), but that time the error was "Vehicle revs too high" (or something similar - I was getting a bit frustrated by this point. And again, I was stationary with the engine idling. Tried again with the engine off but ignition on).
Is there anywhere in a VCDS scan that shows if a vehicle actually has Vehicle Diagnostic Protection SFD?
Trowbridge, UK
Those don't sound like SFD type errors to me, but I think we need to wait for an expert to come along @Uwe
I am rather skeptical that this van that it has SFD. SFD is generally something that is being introduced in new chassis types, and a T6.1 isn't that.
However, you could try Beta 21.7 which will show an [SFD] button in modules that have it and should show the presence of SFD in the an Auto-Scan in most modules that have it.
Are you sure this van is equipped with the hardware and software that allows for such functionality from the mirrors?
Was the engine running while you were trying to do that? If so, I would try it with the ignition on, but the engine not running. But keep in mind that much like mirror folding and dipping, not all instrument clusters support needle sweep.
lordbowl
Sydney, Australia
C?ID=445269
Thank you Ewe,
I tried the 21.7.2 Beta and was able to complete the mirror fold on key fob lock adaptation.
It seems you were correct about SFD not being in a T6.1.
I will try some more adaptations when I have some more time to explore.
