7P Touareg Lock Doors With Engine Running
funbard
Canada
C?ID=234680
I have been looking around everywhere to change the coding through VCDS on my 7P Touareg to use the key FOB to lock the doors with the engine running. I want to do this so I can have my golden retriever stay nice and cool while we are running errands.
Has anyone done this and point me in the right direction? I have looked around on the different modules but haven't found anything.
Currently I use a spare plastic VW key that I bought off of ebay to manually lock the door but I do not like the looks of having the key cover off permanently on the door handle.
Any help would be appreciated!
Trowbridge, UK
We're going to need to see a VCDS Auto-Scan to be able to advise if/how it's possible.
funbard
Canada
C?ID=234680
Monday,26,July,2021,10:06:07:28517
VCDS Version: 21.3.0.0 (x64)
VIN: WVGEK9BP1CD010575   License Plate:
Mileage: 218464km-135747mi   Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 52 53 56 5F 62 65
          69 6D 72
VIN: WVGEK9BP1CD010575   Mileage: 218464km-135747miles
Address 01: Engine (J623-CATA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401 J    HW: 7P0 907 401 E
   Component: 3.0TDI EDC17  X17 0005
   Revision: 56X17---
   Coding: 292A4012233600050000
   ASAM Dataset: EV_ECM30TDI0117P0907401J 001005
   ROD: EV_ECM30TDI0117P0907401J_001.rod
   VCID: 366316458928183B29-8062
Readiness: 0 0 0 0 X
   Part No SW: 0C8 927 750 G    HW: 0C8 927 750 G
   Component: AL1000 AISIN  001 2084
   Coding: 001168
   Shop #: WSC 59323 001 104857
   ROD: EV_TCMAL991031_002.rod
   VCID: 306F205D6B4C360B73-8064
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 J    HW: 7P0 907 379 A
   Component: MK25A         H36 0433
   Revision: --------    Serial number: 409320010EC815
   Coding: 5B7613C349252553DAF9C89A92D7A440F700
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: 44877C8DCFF4BAABA7-8010
   Part No SW: 4H0 907 064 BK    HW: 4H0 907 064 BK
   Component: BCM2 2.0      H31 0333
   Coding: 0D860000000000000000
   VCID: 73E5EF51D2DA4D13CE-8026
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2311000274964011
03283 - Antenna for Access & Start Authorization; Left
                    Fault Status: 00101011
                    Reset counter: 235
                    Mileage: 217925 km
                    Date: 2021.07.10
                    Time: 18:32:11
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 BK    HW: 7P6 907 040 BK
   Component: Klima 2 Zonen H20 1305
   Coding: B686000A80
   VCID: 7EF3CE65E198107BB1-802A
0243 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Fault Frequency: 23
                    Reset counter: 230
                    Mileage: 214686 km
                    Date: 2021.05.09
                    Time: 06:31:38
   Part No SW: 4H0 907 063 BL    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0111
   Revision: 15012002    Serial number: 00000001452685
   Coding: 69000012873C5D010004000380005F5F431C660882000261800000000000
   Subsystem 1 - Part No SW: 7P0 955 119     HW: 7P0 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    120213  31  0020
   Serial number: 90243400120224185307
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
   Component: RLFS  H09 0011
   Serial number: 10345357
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 E    HW: 7P6 941 431 E
   Component: E1 - LDS  H04 0031
   Serial number: 00000000003103120034
   Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0020
   Serial number: 0000001805569R114D07
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA103663000000864888
   Coding: 010300
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 B    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0021
   Revision: --------    Serial number: 28261208903166
   Coding: 118501
   ASAM Dataset: EV_VW526ParkiAssis2 001011
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 428B7A95D5E0B49B95-8016
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
   Component: VW10Airbag025 H05 0025
   Revision: --------    Serial number: 003L0002JHZB
   Coding: 000000000000000000000000000000003235
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 41897599D0E6AF838C-8014
   Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
   Component: BF-Gewichtss.  003 0005
   Serial number: 5850000R1213105GP4
   Serial number: 3575LRB405P17UE22P5R
   Serial number: 3585LRB405717UE061J2
   Serial number: 3515RRB406115N42210%
   Serial number: 3525RRB406315N42B86O
   Serial number: 3555NRB405R18AICN9E
   Serial number: 3565NRB405T18AICJGG3
   Part No SW: 4H0 953 568 H    HW: 7P6 953 507 M
   Revision: --------    Serial number: 90815LD20002O
   Coding: 000C15
   VCID: 387F187D8B3CEE4B3B-806C
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
   Serial number: 0164440
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 882     HW: 7P6 920 882
   Component: Kombi         H14 0253
   Revision: 12240067    Serial number: 658230312592069
   Coding: 0B3F310023009008020004
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 7AFBC275FDB03C5B8D-802E
   Part No SW: 7P6 907 530 C    HW: 7P6 907 530 A
   Component: GW-CAN-L-MOST H08 5202
   Revision: --------    Serial number: 00000000458722
   Coding: 0001037500
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: 387F187D833CEE4B3B-806C
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000005650662136
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000026763055
   Coding: 00581B0000004001000001010101202020202121202020
   VCID: 34672C4D97540A2B17-8060
   Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
   Component: TSG FA        H07 0166
   Revision: --------    Serial number: 0000126113904
   Coding: 011D17205E00453005080000
   VCID: 44877C8DC7F4BAABA7-8010
02123 - Door Warning Light / Entry Light
                    Fault Status: 01101100
                    Fault Frequency: 52
                    Reset counter: 190
                    Mileage: 217100 km
                    Date: 2021.06.24
                    Time: 16:27:40
   Revision: 00002001    Serial number: 0174008494
   Coding: 0186163A28B9509580A00620210000000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
   Component: GTO BT  H19 0059
   Serial number: 0821212131
   Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
   Component: J245 PS30.055  H01 0008
   Serial number:     WOO15682231
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
   Component: J394 PS30.055  H01 0008
   Serial number:     WOO15701390
   Coding: 191100
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0166
   Revision: --------    Serial number: 0000126091176
   VCID: 3B750771BA0AC553D6-806E
                    Fault Frequency: 12
                    Reset counter: 198
                    Mileage: 218157 km
                    Date: 2021.07.18
                    Time: 07:48:52
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1232200740
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   Slave 3:
   Component: Radio U SIRIU H53 0133
   Revision: AB001007    Serial number: 156C10C7590956
   Coding: 020007020000000001
   VCID: 2447DC0D27B49AAB87-8070
   Part No SW: 7P6 035 664 D    HW: 7P6 035 664
   Component: H-BN-NA       H44 0706
   Revision: --------    Serial number: 445CZ0C7530548
   Coding: 010200050040E1ED41022F0E00000003F00001010000000000
   VCID: 39791D79B036F743C4-806C
   Subsystem 1 - Part No: 7P6 060 884 J
   Component: NAR 2017/2018  1602
   Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: DU8 SV Touch  H26 0045
   Serial number: VWZ8Z9L79003QT
   Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: CD-Database  1886
03175 - Invalid Data Set
                    Reset counter: 27
                    Mileage: 214481 km
                    Date: 2021.05.04
                    Time: 18:52:42
                    Voltage: 14.30 V
03623 - Invalid Security/Release Code
                    Reset counter: 27
                    Mileage: 214481 km
                    Date: 2021.05.04
                    Time: 18:52:43
                    Hex Value: 0x0004
                    Hex Value: 0x0009
                    Count: 7
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0167
   Revision: --------    Serial number: 0000126098630
   Coding: 011C17200000253005080000
   VCID: 3A7B0275B530FC5BCD-806E
                    Reset counter: 196
                    Mileage: 218271 km
                    Date: 2021.07.22
                    Time: 09:45:21
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 10000000070451
   ASAM Dataset: EV_RDKBERU25 003006
   ROD: EV_RDKBERU25_VW52.rod
   VCID: 3F8D7361A612D973FA-806A
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
   Component: Anhaenger     H09 0110
   Revision: 5A001001    Serial number: 00000173421217
   Coding: 020D000000000000
   Part No SW: 7P6 959 107 A    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0620
   Revision: 22010001    Serial number: 083200938
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202137
   ROD: EV_HeckkTouar.rod
   VCID: 3D710969AC1ECB63E8-8068
   Component: TSG HR        H09 0167
   Revision: --------    Serial number: 0000126095584
End-------------------------(Elapsed Time: 04:56)--------------------------
I've looked at the data for 05 and 46 and didn't find an obvious way to accomplish that.
That doesn't necessarily mean there isn't a way, somewhere, somehow...
NEtech
Denmark
C?ID=56995
You could test coding in [46]
Byte 5 Bit 2
funbard
Canada
C?ID=234680
Byte 5 Bit 2
Unfortunately I couldnt get anything to work for this locking function.
