2008/9 VW Passat not starting need help please
forestautoelectrics
C?ID=126364 (NRRT)
Hi i am new here and i need some help please I am working on a 2008/9 VW Passat and when I try and start it starts up for around 1 second then cuts straight out again a mechanic has changed the steering column lock and says it needs programming but I don't how to do it can any one help me also please take a look at the autoscan bellow and let me know if there is any other reason it may not be starting up as there other codes for immobiliser and ABS module i think has lost its coding. thanks ! also i am in the UK.
Here is the autoscan from the log file i copied and paste it
Monday,26,July,2021,15:49:50:49140
VCDS Version: 21.3.0.0 (x64)
VIN: WVWZZZ3CZ9P024894   License Plate: PE58OCX
Mileage: 254730km-158281mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ9P024894   Mileage: 254730km-158281miles
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 BL    HW: 03L 907 309
   Component: R4 2,0L EDC 0000SG  3570
   Revision: 13H01---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 00246 210 71401
   VCID: 70EA44C1631CE70B33-8024
000406 - Engine Oil Temp. Sensor (G8)
               P0196 - 000 - Implausible Signal
                    Mileage: 254739 km
                    Time: 18:05:50
                    Content: 0.0 mm
                    Content: 22.0 mm
                    Temperature: 25.2°C
                    Temperature: 29.7°C
                    Temperature: 37.8°C
001299 - Incorrect Immobilizer Key
               P0513 - 000 -
                    Mileage: 254739 km
                    Time: 18:06:29
                    RPM: 2047 /min
                    Voltage: 11.48 V
                    Absolute Pres.: 989.4 mbar
                    Absolute Pres.: 948.6 mbar
                    Temperature: 27.0°C
                    Temperature: 50.4°C
Address 03: ABS Brakes        Labels:. 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 P    HW: 3C0 614 109 P
   Component: J104    C4 440 V2   0011
   Revision: --025---    Serial number: 00000785897163
   Coding: 0001298
   Shop #: WSC 00028 028 00001
   VCID: 2B5093AD8ABAC4D346-807E
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 CR    HW: 3C0 907 044 CR
   Component: ClimatronicPQ46 132 0811
   Revision: 00132023    Serial number: 00000000000000
   VCID: 73E04BCD120ADC13CE-8026
   Revision: 00H54000    Serial number: 00000005858544
   Coding: E1800F0700041A00470A00000F00000000085D435C000120000000000000
   VCID: 33608BCD528A9C130E-8066
   Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 260608 022  0601
   Coding: 00046997
   Shop #: WSC 00028
   Component: RLS     110808 046  0204
   Coding: 00208933
   Shop #: WSC 00028
   Component: J234__006 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DPETA59V
   Coding: 0012342
   VCID: 3B70A3ED7ADA5453D6-806E
   Subsystem 1 - Serial number: 6333FTS607491728
   Subsystem 2 - Serial number: 6343FTS666811598
   Subsystem 3 - Serial number: 6353ETS6C615UVNH
   Subsystem 4 - Serial number: 6363ETS62S05UVNP
   Part No SW: 3C0 953 549 AB    HW: 3C0 953 549 AB
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C5953507AM
   Coding: 0000003
   VCID: 6CD250B14F3403EB0F-8038
   Part No SW: 3C0 920 960 N    HW: 3C0 920 960 N
   Component: KOMBIINSTRUMENT VD1 1216
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0007405
   Shop #: WSC 12345 067 57207
   VCID: 2E569AB9B9A8B1FB61-807A
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 66
                    Mileage: 254739 km
                    Time: 18:15:48
Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 H    HW: 3C0 907 951
   Component: J533__Gateway   H13 0142
   Revision:   H13       Serial number: 2600P087140094
   Coding: F9807F060002021003
   VCID: 264662999158F9BB99-8072
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   Revision: 00042000    Serial number: 00000000000000
   Shop #: WSC 130942 250 2031289
   VCID: 397CB9E570E66643C4-806C
02823 - Requirements for Locking the Steering Column Lock not met
                    Fault Status: 00110000
                    Reset counter: 106
                    Mileage: 254739 km
                    Time: 11:55:25
02827 - Wake-Up request via ESP
                    Fault Status: 00111000
                    Reset counter: 106
                    Mileage: 254739 km
                    Time: 11:55:26
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1518
   Revision: 72009005    Serial number: 00000512388703
   Coding: 0000693
   VCID: 6FE847BD7E22F8F32A-803A
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 195    2301
   Revision: 00H15000
   VCID: 2A5E96A98540DDDBBD-807E
                    Fault Status: 11100101
                    Mileage: 254739 km
                    Time: 18:15:06
                    Battery Volts: 11.6 V
                        DD
                    Temperature: 25.0°C
                    Count: 3
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Component:    KSG PQ46 ELV 042 0472
   Coding: 01910A0001860E763004941570085FCE107CA1
   Component: LIN BACKUP HORN H08 9001
   Component: Neigungssensor  004 0611
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1518
   Revision: 72009005    Serial number: 00000073888621
   Coding: 0000692
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   009       Serial number: 00000000099551
   Coding: 0010000
   VCID: 285A6CA19B4CEFCBAB-807C
            000 - - - MIL ON
                    Fault Status: 11110000
                    Reset counter: 66
                    Mileage: 254739 km
                    Voltage: 11.60 V
                    Count: 43
                    Hex Value: 0x1241
                    Hex Value: 0x0001
                    Hex Value: 0x1010
02845 - Function Display in Instrument Cluster (!)
            007 - Short to Ground - MIL ON
                    Fault Status: 11100111
                    Fault Frequency: 14
                    Reset counter: 66
                    Mileage: 254739 km
                    Voltage: 11.30 V
                    Count: 78
                    Hex Value: 0x1241
                    Hex Value: 0x0001
                    Hex Value: 0x1010
03190 - Incorrect Vehicle Type
            000 - - - MIL ON
                    Fault Status: 11100000
                    Reset counter: 66
                    Mileage: 254739 km
                    Voltage: 11.30 V
                    Count: 98
                    Hex Value: 0x1251
                    Hex Value: 0x0001
                    Hex Value: 0x1010
            000 - - - MIL ON
                    Reset counter: 66
                    Mileage: 254739 km
                    Voltage: 11.60 V
                    Count: 100
                    Hex Value: 0x1241
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Fault Status: 11110101
                    Reset counter: 66
                    Mileage: 254739 km
                    Voltage: 11.60 V
                    Count: 101
                    Hex Value: 0x1241
                    Hex Value: 0x0001
                    Hex Value: 0x1010
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  036 0130
   Revision: 00000001    Serial number: VWZ1Z3H3335430
   Coding: 0500040004
   VCID: 65C425956CDE32A350-8030
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0308
   Revision: 41004101    Serial number: 00000000548523
   Coding: 0000144
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0308
   Revision: 41004101    Serial number: 00000000535723
   Coding: 0000144
   VCID: 71EC41C56816EE033C-8024
End-------------------------(Elapsed Time: 01:46)--------------------------
   Coding: 0000072
                    Mileage: 254739 km
                    Time: 18:05:50
                    Content: 0.0 mm
                    Content: 22.0 mm
                    Temperature: 25.2°C
                    Temperature: 29.7°C
                    Temperature: 37.8°C
               P0513 - 000 -
                    Mileage: 254739 km
                    Time: 18:06:29
                    RPM: 2047 /min
                    Voltage: 11.48 V
                    Temperature: 27.0°C
                    Temperature: 50.4°C
   Coding: 0001298
   Coding: 00046997
   Shop #: WSC 00028
   Coding: 00208933
   Shop #: WSC 00028
   Coding: 0012342
   Coding: 0000003
   Coding: 0007405
                    Reset counter: 66
                    Mileage: 254739 km
                    Time: 18:15:48
                    Reset counter: 106
                    Mileage: 254739 km
                    Time: 11:55:25
                    Reset counter: 106
                    Mileage: 254739 km
                    Time: 11:55:26
   Coding: 0000693
   Revision: 00H15000
                    Mileage: 254739 km
                    Time: 18:15:06
                        DD
                    Temperature: 25.0°C
                    Count: 3
                        SteerAng n.Init
   Coding: 0000692
   Coding: 0010000
            000 - - - MIL ON
                    Reset counter: 66
                    Mileage: 254739 km
                    Voltage: 11.60 V
                    Count: 43
                    Hex Value: 0x1241
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Fault Frequency: 14
                    Reset counter: 66
                    Mileage: 254739 km
                    Voltage: 11.30 V
                    Count: 78
                    Hex Value: 0x1241
                    Hex Value: 0x0001
                    Hex Value: 0x1010
            000 - - - MIL ON
                    Reset counter: 66
                    Mileage: 254739 km
                    Voltage: 11.30 V
                    Count: 98
                    Hex Value: 0x1251
                    Hex Value: 0x0001
                    Hex Value: 0x1010
            000 - - - MIL ON
                    Reset counter: 66
                    Mileage: 254739 km
                    Voltage: 11.60 V
                    Count: 100
                    Hex Value: 0x1241
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Reset counter: 66
                    Mileage: 254739 km
                    Voltage: 11.60 V
                    Count: 101
                    Hex Value: 0x1241
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Coding: 0500040004
   Coding: 0000144
   Coding: 0000144
Answer will be after Ross-Tech team verified is it legit VCDS scan.
His VCDS is legit, but older, and never registered with us.
forestautoelectrics
C?ID=126364 (NRRT)
Hi I got the VCDS software from the Ross tech website and also got a genuine Ross tech cable it is an older used cable but still genuine I am waiting on verification but I am working on the Passat today so thought I would put a post up in the new user forum to see if I Could get any help also how can I register the vcds with you I am new to this software
Please see:
siLc
Tallinn, Estonia
C?ID=330192
The new electronic steering lock will definetly have to be matched to the immo. Then the engine will run for more than one second.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
X2 above post , means steering column has Electronic steering lock which has Immobilizer and preventing car from start.
You can program it with VCDS only if you have SKC(Pin) from car but SKC VCDS can not retrieve , you must have different Immobilizer tool.
