Skoda Octavia III - Errormessages 5F - High beam assist not working
Scheijgrond
C?ID=132153
I recently updated my Amundsen. After this I experienced some reoccuring errormessages witch I can't seem to get out as some missing funcionality.
- My High beam assist is not working anymore. The icon doesn't appear on the dashboard. Switch ofcourse on auto. The lever operates the highbeam as old-school. The menu-options on the Columbus are still there and are activated.
- In the servicemenu of the amundsen I can find my VIN, but I'm missing the information about time & KM's to next service.
I checked the 5F long coding several times, recoded it with the same code or minor changes. The error appears arround bit 10 witch contains information about the DAB-receiver. Changing the values doesn't change the errorcodes. (I cleared the codes after every change, but they keep coming instantly back). I tried adapting ' channel IDE02502-Confirmation of installation change'. This channel has as value 02 9A and by XOR-calculation I found I could confirm this with CB 48, but this doesn't effect the errors. Maybe a wrong XOR calculation?
Please help....
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F 69 A5
VIN: TMBJP7NE2H0026XXX   Mileage: 104918km-65193miles
Address 01: Engine (J623-CHZD)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 026 AB    HW: 04C 907 309 AE
   Component: R3 1.0l TFS   H25 2993
   Revision: W1H25---
   Coding: 01250032236419080000
   Shop #: WSC 73430 031 12345
   ASAM Dataset: EV_ECM10TFS01104C906026AB 002005
   ROD: EV_ECM10TFS_VW37.rod
   VCID: 61C3A5BD702D5383AC-8034
Readiness: 1110 0001
   Part No SW: 0CW 300 049 M    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 0901
   Revision: 00005006    Serial number: CU501606076886
   Shop #: WSC 73430 031 00063
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 47975B25FEC90DB342-8012
   Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
   Component: ESC           H62 0736
   Revision: 00000000    Serial number: 61646000000245
   Coding: 1C076A9124221972407A060141CA243856249802608224721621F070C02203
   ROD: EV_Brake1UDSContiMK100IPB_035.rod
   VCID: 7BFFF7D5F281995396-802E
   Part No SW: 5E0 907 044 AC    HW: 5E0 907 044 AC
   Component: Climatronic   H04 1601
   Revision: 00001K07
   Coding: 02010004000110011005004000101002
   ASAM Dataset: EV_ACClimaBHBVW37X 006142
   ROD: EV_ACClimaBHBVW37X_006_SK37.rod
   VCID: 66C9B6A1990334BB59-8032
   Air quality sensor:
   Part No SW: 5Q0 937 086 AJ    HW: 5Q0 937 086 AJ
   Revision: --------    Serial number: 86581306160060
   Coding: 0C02184642C702FB47E04000000407080008000000000000000000000000
   Shop #: WSC 02534 211 12345
   ROD: EV_BCMBOSCH_015.rod
   VCID: 02018A31956BE89BD5-8056
   Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 160522  041 0570
   Serial number:         160531095019
   Coding: 065DDD
   Component: RLHS  042 0105
   Serial number: S3Y16M06D15H17M41S49
   Coding: 00885D
   Humidity sensor: interior:
   Revision: --------    Serial number: 39331616003576
   Coding: 0071151151
   Shop #: WSC 02534 211 00000
   VCID: 438F4F35CAF121939E-8016
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 07051603213095
   Coding: 000C1C00FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   VCID: 3A7132D1BD3B605BCD-806E
   Part No SW: 3Q0 959 655 AS    HW: 3Q0 959 655 AS
   Component: Airbag VW20   013 0200
   Revision: --------    Serial number: 003SQPATYCZU
   Coding: 98CCC000000000005C5400CC000800000065
   Shop #: WSC 73430 790 00000
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 0F27B305D63995F34A-805A
   Subsystem 1 - Part No SW: -----------    HW: 454 002 905 16
   Serial number: 3576U0000002A7545B1A
   Subsystem 2 - Part No SW: -----------    HW: 454 000 406 16
   Serial number: 3586U000000782CC8B1R
   Subsystem 3 - Part No SW: -----------    HW: 454 802 705 16
   Serial number: 3516RD0E8850A000000E
   Subsystem 4 - Part No SW: -----------    HW: 454 802 705 16
   Serial number: 3526R921C820A0000001
   Subsystem 5 - Part No SW: -----------    HW: 454 802 305 16
   Serial number: 3556VD890F60A000000P
   Part No SW: 5Q0 953 507 HB    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 15061604221103
   Coding: 6410
   VCID: 7DFBF9CDEC959763A8-8028
   Part No SW: 5E0 920 750 C    HW: 5E0 920 750 C
   Component: KOMBI         305 8311
   Coding: 07A50A086584000C01886A031000000000000000
   VCID: 244DECA92FBF06AB87-8070
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1265
   Revision: --------    Serial number: 0004955620
   Coding: 030100047F085700EB0002581C0F00010001050000000000000000000000
   Shop #: WSC 73430 790 12345
   ROD: EV_GatewLear_013.rod
   VCID: 7CFDF4C9F78F9E6B9F-8028
   Generator:
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000D0630080616
   Serial number: 75410803001605301851
   Component: TSG FS        010 0031
   Serial number: 0000203984339
   Coding: 00130120D000040000001101
   Serial number: 00000000000010387345
   Coding: 010200
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 1107
   Shop #: WSC 49534 001 1048576
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 458B512DC4C51FA3B0-8010
   Component: TSG BFS       010 0031
   Serial number: 0000204156121
   Coding: 00130120D400040000001101
   VCID: 46895621F9C314BBB9-8012
   Serial number: 00000000000010357203
   Coding: 190200
   Part No SW: 5Q0 035 874 B    HW: 5Q0 035 874 B
   Component: MU-S-ND-ER    H30 0367
   Serial number: SKZAZ2S5096738
   Coding: 03730201FF00000011111201008802002F01009401200100FE
   Shop #: WSC 00066 000 00000
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 336F1FF59A5191130E-8066
   Subsystem 1 - Part No SW: 5E0 919 605 J    HW: 5E0 919 605 J
   Component: ABT_Std-2_Nav  H43 1031
   Serial number: SKZ8Z9SLH00WNC
   Subsystem 2 - Part No SW: 5L0 051 236 BR    HW: -----------
   Component: ECE AS 20/21  --- 1410
          U1014 00 [009] - -
                    Reset counter: 71
                    Mileage: 104918 km
                    Date: 2021.07.28
                    Time: 21:21:27
                    Voltage terminal 30: 11.7 V
7191 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 71
                    Mileage: 104918 km
                    Date: 2021.07.28
                    Time: 21:21:30
                    BAP-BAP_Function_ID: 02
7225 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 71
                    Mileage: 104918 km
                    Date: 2021.07.28
                    Time: 21:21:30
7228 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 71
                    Mileage: 104918 km
                    Date: 2021.07.28
                    Time: 21:21:30
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anhaenger     H21 0203
   Revision: 8A001003    Serial number: 0354028438
   Coding: 0100000202000000
   VCID: 3B7F37D5B2015953D6-806E
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H07 0060
   Serial number: 10000572056
   Coding: 0101010001030306000000000100000101
   ROD: EV_MFKBoschAU370.rod
   VCID: 3C7D34C9B70F5E6BDF-8068
End-------------------------(Elapsed Time: 04:19)--------------------------
downtime
Finland
C?ID=280813
Your 5F module still has incorrect coding as you can see from the error.
Do you have the coding from Amundsen?
Then you need to record the adaptations from your Amundsen unit and by hand change the Columbus adaptations to match.
Is your new unit a hacked unit? If it isn’t, you will never get navigation to work as Amundsen and Columbus have different FeCs for navigation.
Scheijgrond
C?ID=132153
Sorry, I'm not quite clear. I didn't replace the unit, but the software inside was updated. It is an original unit, not beeing hacked.
I asume I've got the Columbus... It's an amundsen.
Trowbridge, UK
In your first post you mention both Columbus and Amundsen - which is confusing?
The part number in the Auto-Scan is 5Q0 035 874 B - which is an Amundsen with DAB.
You say you 'updated' the 5F - please explain EXACTLY what you did.
The 5F is complaining of incorrect coding, after a SW update that will not happen (I've updated the SW twice in my Amundsen and all that happens is the confirmation of installion change DTC) so something else has changed. Do you have a previous Auto-Scan (BTW VCDS auto-saves scans).
Scheijgrond
C?ID=132153
Sorry about that, fixed it to Amundsen. My mistake.
I really don't know why this happened. I tried fixing this with the confirmation of installation after the SW-update, but that doesn't seem to fix it. THis is an older scan from when I just got the car.
Wednesday,09,August,2017,15:43:23:25849
VCDS Version: 17.8.0.1 (x64)
VIN: TMBJP7NE2H0026317   License Plate: PN275D
Mileage: 12887km-8007mi   Repair Order:
VIN: TMBJP7NE2H0026xxx   Mileage: 12887km-8007miles
   Revision: W1H25---
   Shop #: WSC 73430 031 00000
   ROD: EV_ECM10TFS01104C906026AB_002.rod
   VCID: 61C3A5BD702D534EE5-8034
   CAN Converter 01:
   VCID: 47975B25FEC90D7E0B-8012
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   ROD: EV_Brake1UDSContiMK100IPB_035_SK37.rod
   VCID: 7BFFF7D5F281999EDF-802E
   Revision: 00001K07
   Coding: 02010004000110011005000000101002
   VCID: 66C9B6A19903347610-8032
   Air quality sensor:
   Coding: 0C02184642C702FB47E04000001407080000000000000000000000000000
   ROD: EV_BCMBOSCH_015_VW37.rod
   VCID: 02018A31956BE8569C-8056
   Coding: 065DDD
   Coding: 00885D
   Coding: 0071151151
   ROD: EV_EPHVA18AU3700000_VW26.rod
   VCID: 438F4F35CAF1215ED7-8016
   VCID: 3A7132D1BD3B609684-806E
   VCID: 0F27B305D639953E03-805A
   Coding: 6410
   ROD: EV_SMLSKLOMQB_020_SK37.rod
   VCID: 7DFBF9CDEC9597AEE1-8028
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb
   ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
   VCID: 244DECA92FBF0666CE-8070
   ROD: EV_GatewLear_013_VW37.rod
   VCID: 7CFDF4C9F78F9EA6D6-8028
   Coding: 00110120D000040000001100
   Coding: 010200
   Component: EPS_MQB_ZFLS  129 1072
   Coding: 1107
   ROD: EV_SteerAssisMQB_013_VW37.rod
   VCID: 458B512DC4C51F6EF9-8010
   VCID: 46895621F9C31476F0-8012
   Coding: 190200
   Component: MU-S-ND-ER    H30 0353
   Coding: 03730201FF00000011111201008800002F0201D401200100CE
   Shop #: WSC 73430 790 00063
   ROD: EV_MUStd4CTSAT_SK26.rod
   VCID: 336F1FF59A5191DE47-8066
   Subsystem 2 - Part No SW: 5L0 051 236 T    HW: -----------
   Component: ECE1 2017/18  --- 0820
   VCID: 3B7F37D5B201599E9F-806E
   VCID: 3C7D34C9B70F5EA696-8068
1123600 - predictive route data
          B1630 02 [008] - Signal Failure
                    Fault Frequency: 8
                    Reset counter: 233
                    Mileage: 12496 km
                    Date: 2017.08.05
                    Time: 13:52:04
                    Control Module temperature: 66 °C
                    Outside air temperature: 21.5 °C
                    Vehicle speed: 6.40 km/h
                    Voltage terminal 15: 13.3 V
                    System run time: 416.1 s
1123601 - predictive route data
                    Reset counter: 232
                    Mileage: 12494 km
                    Date: 2017.08.05
                    Time: 13:48:07
                    Control Module temperature: 61 °C
                    Vehicle speed: 26.88 km/h
                    Voltage terminal 15: 13.1 V
                    System run time: 179.1 s
End-------------------------(Elapsed Time: 04:23)--------------------------
Scheijgrond
C?ID=132153
Changed it to USB with Iphone functionality and resetted. Didn't make any difference.
09 popped up with a databus error. Maybe because battery shortly dropped below 12v.
Thursday,29,July,2021,11:26:28:25849
VCDS Version: 21.3.0.0 (x64)
Mileage: 104922km-65195mi   Repair Order:
VIN: TMBJP7NE2H0026xxx   Mileage: 104922km-65195miles
   Revision: W1H25---
Readiness: 1010 0001
   Revision: 00001K07
   Air quality sensor:
   Shop #: WSC 00066 123 12345
   Coding: 065DDD
   Coding: 00885D
560917 - Databus
                    Reset counter: 73
                    Mileage: 104922 km
                    Date: 2021.07.29
                    Time: 11:20:36
   Coding: 0071151151
   Coding: 6410
   Coding: 07A50A086584000C0D887E031000000000000000
   Generator:
   Coding: 010200
   Coding: 1107
   Coding: 190200
   Coding: 03730201FF00000011111201008802002F0100D401200100FE
   Subsystem 2 - Part No SW: V03 959 809 BP    HW: -----------
   Component: ECE DL1 2021  --- 1510
          U1014 00 [009] - -
                    Reset counter: 73
                    Mileage: 104922 km
                    Date: 2021.07.29
                    Time: 11:21:12
                    Voltage terminal 30: 14.2 V
          U1111 00 [009] - -
                    Reset counter: 73
                    Mileage: 104922 km
                    Date: 2021.07.29
                    Time: 11:21:15
          U1111 00 [009] - -
                    Reset counter: 73
                    Mileage: 104922 km
                    Date: 2021.07.29
                    Time: 11:21:15
          U1111 00 [009] - -
                    Reset counter: 73
                    Mileage: 104922 km
                    Date: 2021.07.29
                    Time: 11:21:15
End-------------------------(Elapsed Time: 04:26)--------------------------
Trowbridge, UK
Low voltage can cause all sorts of strange errors, I suggest you get the battery on a charger and once the battery is well charged clear all fault codes and do a new scan.
@Scheijgrond: hmmm....... with absolutely no offense intended and given the nature of the responses provided thus far - it might be prudent to re-set the discussion and go-back to the beginning - and address the basics, maybe?
From my understanding of the history, the event that initiated this problem was an update of the hex5F module. To paraphrase @PetrolDave earlier request - please tell us more about this process (which I assume ONLY happened to the one module). In your response, maybe include some words about the following:
  • what precisely do you mean by "update" (software only, hardware, or both)?
  • why was the module updated- what were you attempting to do?
  • How was the update done - by whom and what device was used?
  • What were the "before" details of the hex5F module (maybe look at an early autoscan in the C:\Ross-Tech\VCDS\Scans folder on the laptop that use to run VCDS) ?
  • Before the update - did you have the foresight to create an adaptation channel map of the hex5F module in its original state?
