Inside lights stay on and dash shows a door open.
TDIBob
Florida, USA
C?ID=429237
i have a 2006 jetta tdi. i checked the VCDS and it showed some of the door locks with fault codes. i replaced them all and cleared the codes. i also replaced the driveers door wiring harness as it had damage and was repaired in the past. The trunk and hood have its own light on the dash and it is not lit. Yet it still shows doors open on the dash and keeps the interior lights on which i had to remove the bulbs to be able to drive it at night...Any ideas ? all 4 door controllers show no codes....
TDIBob
Florida, USA
C?ID=429237
Tuesday,27,July,2021,20:00:35:17287
VIN: 3VWRT71K76M682028   License Plate:
Mileage: 262560km-163147mi   Repair Order:
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWRT71K76M682028   Mileage: 262560km-163147miles
04-Steering Angle -- Status: Not registered 0001
44-Steering Assist -- Status: Not registered 0011
7D-Aux. Heat -- Status: Not registered 0011
Address 01: Engine        Labels: 038-906-016-BEW.lbl
   Part No SW: 03G 906 016 AB    HW: 028 101 223 8
   Component: R4 1,9L EDC G000SG  7550
   Revision: --H01---    Serial number: VWZ7Z0E2640520
   Coding: 0050071
   Shop #: WSC 18243 002 1048576
   VCID: 6393A42147518063F21-8036
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Revision: 00T12001
   Coding: 0021122
   Shop #: WSC 00066 000 00000
   VCID: 40D94BADF687FB7BCF3-8014
   Part No: 1K0 820 047 DK
   Component: Climatic PQ35   090 0505
   VCID: 70B9DB6D86A72BFB7F3-8024
01296 - Sensor for Vent Temperature; Center (G191)
            007 - Short to Ground
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Revision: 00H37000    Serial number: 00000000152509
   Coding: 14010E234004180000140000001400000008730B5C
   Shop #: WSC 07342 444 00098
   VCID: 2A0D090560FB112BF17-807E
   Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0402
   Coding: 00065493
   Shop #: WSC 07342
   Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
   Component: 1S AIRBAG VW8R  024 6300
   Revision: 03024000    Serial number: 0037KD03TXK%
   Coding: 0012627
   VCID: 2E0505155C137D0B2DF-807A
   Subsystem 1 - Part No: 1K0 959 339 E
   Component: BF-Gewichtsens. 006 0005
   Subsystem 2 - Serial number: 6332MSME0B2F3A07J
   Subsystem 3 - Serial number: 6342MSME0B06112F8
   Subsystem 4 - Serial number: 6351HSME081649094
   Subsystem 5 - Serial number: 6361HSME08060D634
   Subsystem 6 - Serial number: 63727SME07356413W
   Subsystem 7 - Serial number: 63827SME076B4A47A
   Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
   Component: J0527           034 0070
   Coding: 0000021
   VCID: 78A9E34DEED773BBB73-802C
   Part No: 1K0 920 952 L
   Component: KOMBIINSTRUMENT 3HL 4312
   Coding: 0023203
   Shop #: WSC 18243 067 57207
   VCID: 33331461B73150E3421-8066
   Part No SW: 7N0 907 530 AK    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1642
   Revision:   H57       Serial number: 011020F1000166
   Coding: 350000
   VCID: 79AFE649D9DD6AB3C8D-802C
                    Reset counter: 71
                    Mileage: 262567 km
                    Time: 05:17:06
                    Mileage: 262567 km
                    Time: 05:17:05
   Component: IMMO            3HL 4312
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2377
   Coding: 0001269
   VCID: 36352D75A44345CB65F-8062
   Part No: 1K1 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 323D1165482B59EB497-8066
   Part No: 1K0 959 433 AF
   Coding: 137803281B09050F880F048051A0
   VCID: 74B1D77DF2BF17DB9BB-8020
   Part No: 1K0 959 702 K
   Coding: 0001269
   VCID: 372B2071A349BCC37E9-8062
Address 56: Radio
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2434
   Coding: 0000144
   VCID: 313F1E694D2D62F330D-8064
   Part No: 1K0 959 704 D
   Coding: 0000144
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   VCID: 2D07021951150613145-8078
End----------(Elapsed Time: 01:04, VBatt start/end: 12.3V/12.3V)-----------
siLc
Tallinn, Estonia
C?ID=330192
Check measurement blocks of module 46 to see which door lock’s contact switch is reporting open.
iichel
Eindhoven, NB, NL
C?ID=284912
I agree. Have a look at which door is reported to be open
TDIBob
Florida, USA
C?ID=429237
Perfect ! Thank you so much. I did not know where to look . Drivers door was shown open as i had it closed.
Bob
