Audi A5 2008 HVAC and Light level issues
RedLion
Hello hive mind,
i'm new to this VCDS malarky, IE my caddy is pretty basic, buuuuut i bought a 2008 A5 yesterday, and its got a couple of issues. I did some scanning and then some googling, and im still none the wiser.
In the paperwork with the vehicle its got a receipt for a rear suspension levelling thing being fit a short while ago, so im hoping thats a simple calibration needed.
The HVAC system is a little more concerning i think. can anyone shed any light on what might be the issue?
Thanks, Red.
Monday,26,July,2021,11:53:35:20641
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 21.3.0.0 (x64)  HEX-V2 CB: 0.4543.4
VIN: WAUZZZ8T28A042057   License Plate: WF08WWO
Mileage: 160400km-99667mi   Repair Order:
Chassis Type: 8T-AU48 (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 77
VIN: WAUZZZ8T28A042057   Mileage: 160400km-99667miles
Address 01: Engine (------CABD)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8T0 907 115 A    HW: 8K1 907 115
   Component: 1.8l R4/4V TF H07 0004
   Revision: A5H07---
   Coding: 0114000318070018
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM18TFS8T0907115A A01004
   ROD: EV_ECM18TFS8K1907115B.rod
   VCID: 3430E2D20EBE65BB5BB-8061
Readiness: 0010 0000
   Part No SW: 8K0 907 379 P    HW: 8K0 907 379 P
   Component: ESP8 front    H04 0180
   Coding: 030500
   VCID: 46D4A81A68A2E72BF5F-8013
   Part No SW: 8K0 907 289 C    HW: 8K0 907 289 C
   Component: BCM2.01       H38 0253
   Revision: 00003002
   Coding: 031000
   VCID: 392ED3E6295C98D388D-806D
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Serial number: 0508000013337004
   Component: ELVAUDIB8  H35 0039
   Serial number: 0208000013217009
   Part No SW: 8T2 820 043 M    HW: 8T2 820 043 M
   Component: KLIMA 3 ZONEN H05 0120
   Revision: D0000000    Serial number: 0105.04.080558
   Coding: 64060000
   VCID: 3C20CAF2266EADFB93B-8069
00713 - Centre Left Vent Positioning Motor (V110)
                    Fault Status: 01101000
                    Fault Frequency: 181
                    Reset counter: 214
                    Mileage: 158424 km
                    Date: 2021.03.28
                    Time: 12:53:42
                    Voltage: 11.60 V
                    Temperature: 20.0∞C
                    Temperature: 17.0∞C
                    Count: 10000
                    Fault Frequency: 138
                    Reset counter: 214
                    Mileage: 158531 km
                    Date: 2021.05.03
                    Time: 12:29:27
                    Voltage: 11.30 V
                    Temperature: 17.0∞C
                    Temperature: 15.0∞C
                    Count: 10000
                    Fault Frequency: 217
                    Reset counter: 214
                    Mileage: 158424 km
                    Date: 2021.03.28
                    Time: 12:54:51
                    Voltage: 11.40 V
                    Temperature: 16.0∞C
                    Temperature: 17.0∞C
                    Count: 11914
                    Count: 11914
01187 - Rear Temperature Flap Positioning Motor (V137)
                    Fault Frequency: 165
                    Reset counter: 214
                    Mileage: 158530 km
                    Date: 2008.02.09
                    Time: 01:46:42
                    Voltage: 12.60 V
                    Temperature: 29.0∞C
                    Temperature: 16.0∞C
                    Count: 10000
01844 - Control Module for Fresh Air Blower (J126)
                    Fault Frequency: 133
                    Reset counter: 214
                    Mileage: 158602 km
                    Date: 2008.02.08
                    Time: 00:00:46
                    Temperature: 12.0∞C
00716 - Air recirculation Flap Positioning Motor (V113)
                    Fault Frequency: 166
                    Reset counter: 214
                    Mileage: 158530 km
                    Date: 2008.02.09
                    Time: 01:46:42
                    Voltage: 12.60 V
                    Temperature: 29.0∞C
                    Temperature: 16.0∞C
                    Count: 10000
   Part No SW: 8K0 907 063 C    HW: 8K0 907 063 C
   Component: BCM1 1.0      H21 0253
   Revision: 04021001    Serial number: 00000000023619
   Coding: 26005091401CAF010E09000000005D5D4F1D038800010141000000
   Shop #: WSC 06325 123 12345
   VCID: 2F3AEDBEE7184663269-807B
   Subsystem 1 - Part No SW: 8T2 955 119 C    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 290308  H11 0040
   Serial number: SWFBIE 0000168
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10097800
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
   Serial number: 00000000001104080855
00471 - Control Module for Elect. Regulated Dampers (J250)
                    Reset counter: 214
                    Mileage: 160379 km
                    Date: 2021.07.25
                    Time: 16:31:00
   Part No SW: 8K0 919 475 B    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0010
   Revision: 11001001    Serial number: 75330809508486
   VCID: 3828D6E2125681DB773-806D
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0038JD14BTUW
   Coding: 30323433363030303030554A305238543053
   VCID: 3C20CAF226EEADFB93B-8069
   Serial number: 6334MSME26560421%
   Serial number: 6344MSME3B734F3AU
   Serial number: 6352QSME5B64235FS
   Serial number: 6362QSME5E4B3765X
   Serial number: 63732SME5B6C1F5DO
   Serial number: 63832SME591908391
   Component: Lenks.Modul   H12 0013
   Revision: --------    Serial number: 90304HDD000EL
   Coding: 000012
   VCID: 3D26C7F63D74A4F3A45-8069
   Part No SW: 8T0 920 981 A    HW: 8T0 920 981 A
   Component: KOMBIINSTR.   H28 0221
   Revision: 00000000    Serial number: 71V19X048
   Coding: 2F0D000002002600010000
   VCID: 3A2CCCEA2C5A93CB817-806F
   Part No SW: 8T0 907 468 H    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0091
   Revision: GB102039    Serial number: 3900G08312839A
   Coding: 000303
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H03 0150
   Serial number: 18010F7B270308
   Part No SW: 8K0 959 793     HW: 8K0 959 793
   Component: TSG FA        H09 0149
   Revision:             Serial number: $I
   Coding: 011C022240012201
   VCID: 7DA607F67DF464F3E45-8029
   Revision: 00003002    Serial number: 0109955331
   Coding: 011F0682003904C0003000
02616 - Fuel Tank Cap; Unlock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 97
                    Mileage: 157486 km
                    Date: 2021.03.03
                    Time: 15:36:11
02615 - Fuel Tank Cap; Lock
                    Reset counter: 196
                    Mileage: 157489 km
                    Date: 2021.03.04
                    Time: 08:32:55
                    Fault Status: 11101100
                    Fault Frequency: 9
                    Reset counter: 214
                    Mileage: 157490 km
                    Date: 2021.03.05
                    Time: 13:53:29
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 J    HW: 8T0 035 223
   Component: DSP STD       H07 0210
   Revision: S1700000
   Coding: 0203010102
   VCID: 3536DFD605447CB36C5-8061
01304 - Radio
                    Reset counter: 195
                    Mileage: 158530 km
                    Date: 2008.02.08
                    Time: 00:00:35
                    Voltage: 13.70 V
                    Temperature: 22.0∞C
                    Bin. Bits: 00000001
00417 - Left Front DSP Mid-Bass Speaker (R101)
                    Fault Frequency: 9
                    Reset counter: 214
                    Mileage: 159936 km
                    Date: 2021.06.27
                    Time: 13:19:50
                    Voltage: 12.70 V
                    Temperature: 18.0∞C
                    Bin. Bits: 00000000
   Part No SW: 8K0 959 792     HW: 8K0 959 792
   Component: TSG BF        H09 0149
   Revision:             Serial number: h)ô
   Coding: 011C02224C012201
   VCID: 7CA00AF266EE6DFBD3B-8029
                    Reset counter: 214
                    Mileage: 160400 km
                    Date: 2021.07.25
                    Time: 18:52:23
   Part No SW: 8K0 907 801 D    HW: 8K0 907 801 D
   Component: EPB Audi B8   H04 0050
   Revision: 00000003    Serial number: 00000000106758
   VCID: 3038EEC2FA26599B3F3-8065
   Part No: 8K0 907 357 B
   Coding: 0000001
   Shop #: WSC 06324 000 00000
   VCID: 3430E2D2023E65BB5BB-8061
01537 - Vehicle Level Sensor; Supply Voltage
            007 - Short to Ground - MIL ON
                    Fault Status: 11100111
                    Reset counter: 97
                    Mileage: 157486 km
                    Date: 2021.03.03
                    Time: 11:23:33
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8T2 035 186 B    HW: 8T2 035 186 B
   Component: Concert3      H11 0150
   Revision: 00000012    Serial number: AUZ5Z6H1043296
   Coding: 0002008201048D00875B070000
   VCID: 372AD5DE1F488EA37E9-8063
   Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
   Component: Display
00849 - S-contact at Ignition/Starter Switch (D)
                    Mileage: 158531 km
                    Date: 2021.05.03
                    Time: 13:39:51
01704 - Terminal 58 (Dimming)
                    Mileage: 158531 km
                    Date: 2021.05.03
                    Time: 13:39:51
   Part No SW: 8T0 862 335 B    HW: 8T0 862 335 B
   Component: FSE_255x BT     H26 0350
   Revision: 00000000    Serial number: 00000005043430
   Coding: 0010320
   VCID: 392ED3E6255C98D388D-806D
End----------(Elapsed Time: 01:23, VBatt start/end: 12.0V/12.0V)-----------
Address 46: DTCs cleared
Address 47: DTCs cleared
Address 52: DTCs cleared
Address 55: DTCs cleared
Address 56: DTCs cleared
Address 09: DTCs cleared
Address 08: DTCs cleared
09: Cent. Elect. (J519) is coded for "Magnetic Ride Suspension Installed", but I see no such control module in this car, nor is any other module complaining about its absence. If it were mine, I'd tell the J519 module that the car doesn't have it. See Byte 8 of the coding in J519.
For all those HVAC faults: Any chance you've got a blown or missing fuse?
RedLion
I really dont think so, i metered all of the fuses today, both sides of the dash, in didn't check exact fuse positions, but i did shine a torch in and note that there were no empty slots that had a buzz bar. albeit i didn't meter all of the fuses in the rear. any thoughts on where to start? im not entirely sure the fuse diagrams are correct, also, the rear one was absent.
I have no confidence in the fuse diagrams that come with these cars. If it were my car, I'd get wiring diagram and see how those things the HVAC module is complaining about are wired and exactly where they get power from.
RedLion
So, I have signed up to Erwin, as this seems to be the place for circuit diagrams, however, it seems what i need is in german. Can anyone point me in the right direction?
Also, re the light levelling fault, i tried calibrating and that didnt work at all. If anyone has any suggestions on where to start it would be very welcome. fanx
