Central Locking Switch for Passenger Side for RHD A3 8V PFL SB
zabster
West Yorkshire, UK
C?ID=421594
Hi
I am planning to install Locking Switch on front Passenger door.
I believe I need part 8v1962107, 8K0973754A wired up, and activation for Lock switch in Passenger door module through LongCoding.
Is that all I will need or there is something else I need to consider.
Appreciate your help.
Regards
If the car didn't come with it, that would be a Retrofit, not a Tweak. Moving.
You might want to post an Auto-Scan for context, so people can see how this car is equipped and configured.
zabster
West Yorkshire, UK
C?ID=421594
Sorry I will add AutoScan as soon as I get a chance. My car is RHD and has the switch on driver door but I want to add additional one on passenger door so yes retrofit.
zabster
West Yorkshire, UK
C?ID=421594
Please see AutoScan below. I have managed to complete the switch installation. It was easy enough. I purchased a used Right Hand side lock switch, the 4pin plug to go with it, and wired it up-to door module 32 pin connector.
Of the 4 pin connector,
>pin 1 to Ground
>pin 2 to pin 28 on 32pin connector,
>pin 3 to pin 4 on 32 pin connector
>pin 4 to pin 13 on 32 pin connector.
On VCDS I went into Module 52: Door Elect, Pass, Long Coding, Byte 2, and activated Bit 1 (lock_unlock_switch,active).
Saturday,14,August,2021,15:12:01:25845
VIN: WAUZZZ8V2DA073420   License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F 6C BB BC
VIN: WAUZZZ8V2DA073420   Mileage: 92663km-57578miles
Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 5514
   Revision: 83H22---
   Coding: 02190012032501082000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM20TDI01104L906021DS 002009
   ROD: EV_ECM20TDI01104L906021DS_002.rod
   VCID: 79AFE6F7A95F1D93C8D-802C
   Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
   Component: ESC           H75 0437
   Revision: 00000000    Serial number:
   Coding: 12F18AA220270A6F017B060201C3294851045080608094F20279003485
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
   ROD: EV_Brake1UDSContiMK100IPB_008.rod
   VCID: 7DA7F2E7BD7721B3E45-8028
   Part No SW: 8V0 820 043     HW: 8V0 820 043
   Component: AC Automat    H12 0031
   Revision: 20020000    Serial number: 00000000069846
   Coding: 03100104002000011000000000001100
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
   VCID: 6FBBD8AFE71B4323669-803A
   Humidity sensor: exterior:
   Serial number: 794881A6000000000001
   Part No SW: 5Q0 937 084 N    HW: 5Q0 937 084 N
   Component: BCM MQBAB M   H14 0106
   Serial number: 00011309201665
   Coding: 07000842C24102FD03844000B31407A8000F000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 010001
   ROD: EV_BCMBOSCH_010.rod
   VCID: 43D3441F9B139743D21-8016
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 130317  041 0580
   Serial number:         130326070845
   Coding: 0A47F7
   Serial number: 21188208
   Coding: 06006C
   Subsystem 3 - Part No SW: 8V0 941 531 Q    HW: 8V0 941 531 Q
   Serial number: 27 03 2013  00001219
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY1306419X6
   Serial number: 00000000000056480103
   Part No SW: 5Q0 919 294 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  002 0026
   Revision: --------    Serial number: 94231310200921
   Coding: 0010151041
   ASAM Dataset: EV_EPHVA18AU3700000 002016
   VCID: 3A2D39FBECD9D68B817-806E
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Component: AirbagVW20    011 0361
   Serial number: 003M2R015M2+
   Coding: 98CCC0000C0000005C5400CA00C800000065
   VCID: 4BC36C3FB3435F032A1-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 000 304 13
   Serial number: 357670000008A109CC0.
   Subsystem 2 - Part No SW: -----------    HW: 480 000 304 13
   Serial number: 35867000000B0209CC0W
   Subsystem 3 - Part No SW: -----------    HW: 480 401 903 13
   Serial number: 3516502BB0FAE8A3D3A1
   Subsystem 4 - Part No SW: -----------    HW: 480 401 903 13
   Serial number: 3526502AF0FAE895C2B5
   Subsystem 5 - Part No SW: -----------    HW: 480 401 602 13
   Serial number: 3556502C30F7B8E0C0F.
   Subsystem 6 - Part No SW: -----------    HW: 480 400 304 13
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502C50FEA215B0ES
   Subsystem 7 - Part No SW: -----------    HW: 480 400 304 13
   Component: PedP_Sensor_P  001 6149
   Serial number: 2296502C10FEA2108238
   Subsystem 8 - Part No SW: -----------    HW: 480 401 602 13
   Component: PedP_Sensor_C  001 6149
   Serial number: 2306502B90F7B8E5435O
   Part No SW: 8V0 953 521 B    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 15041308491651
   Coding: A408
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   VCID: 392F26F7E9DFDD9388D-806C
   Part No SW: 8V0 920 970 B    HW: 8V0 920 970 B
   Component: KOMBI         H24 0570
   Coding: 27AD0900238046000100FE00000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008026
   VCID: 3B233CFFE3E3EF839A1-806E
   Part No SW: 5Q0 907 530 H    HW: 5Q0 907 530 E
   Component: GW MQB Mid    124 1126
   Revision: --------    Serial number: 0000526761
   Coding: 030100F40B0876005B000248080B00000001000000000000000000000000
   ASAM Dataset: EV_GatewLear 008010
   ROD: EV_GatewLear_008.rod
   VCID: 36352DCBD8C132EB65F-8062
   Generator:
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 13 04 2013  C0237013
   Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
   Component: J367-BDM  H08 0192
   Serial number: 00000000004051211579
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 26031306070420
   Coding: 00168E205E01040000001002
   VCID: 3FDB48EFF7FBF3A3B69-806A
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 81
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D2732E7FDF7E1B3A45-8068
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 22031302090817
   Coding: 001686205E01040000001002
   VCID: 3E2535EBF0F1FAABBDF-806A
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 864 A    HW: 8V0 035 864
   Component: MU-S-N-ER     039 0370
   Serial number: A3F01104131319
   Coding: 01730301FF00000021110001000A00002F0003460100010006
   ASAM Dataset: EV_MUStd4CPASE 002018
   ROD: EV_MUStd4CPASE_VW37.rod
   Subsystem 1 - Part No SW: 8V0 919 866 A    HW: -----------
   Component:  ECE 2013  --- 0021
   Multimedia System 1:
   Subsystem 2 - Part No SW: 8V0 919 603 A    HW: 8V0 919 603 A
   Component: DU Std  H47 0013
   Serial number: AUZ8Z9DG600HJY
   Subsystem 3 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
   Component: ControlUnit_B  H33 0037
   Serial number: C1000028021300010159
   Part No SW: 5Q0 907 441     HW: 5Q0 907 441
   Component: MQB RVC Mid   H05 0120
   Coding: 027300010201000300
   ROD: EV_2CamSysRearPASE.rod
   Part No SW: 5Q0 959 595 A    HW: 5Q0 959 595
   Component: TSG HFS       010 0006
   Serial number: 30031302090110
   Coding: 000686204001040000001002
   VCID: 41DF4E17810F8553C0D-8014
   Component: TSG HBFS      010 0006
   Serial number: 30031306070113
End----------(Elapsed Time: 01:24, VBatt start/end: 13.2V/13.3V)-----------
