Audi Q3 2017 Hold Hill Assist Indicator Lamp
kjrehsi
C?ID=287868
Hi Guys,
Just retrofitted a HHA switch and was able to get it working by coding the 03- ABS Brake module.
Byte 18 was coded from 34 (00110100) to 36 (00110110).
Everything works fine and Hill Assist works as it is meant to. However, I cannot find any information on how to get the GREEN indicator lamp (P) in the instrument panel?
VCDS doesn't have any labels for the module so I am blind in knowing which Byte would enable the indicator lamp?
In the measuring section I can see rest of HHA functions working apart from the 'Indicator' lamp showing OFF?
Any help would be appreciated please?
Here is a copy of the scan 03- ABS Brake module
Address 03: ABS Brakes (J104)       Labels: 5N0-614-109-V1.clb
   Part No SW: 5N0 614 109 CF    HW: 5N0 614 109 CJ
   Component: ESC-EBC460iV1 H12 0013
   Serial number: A01H7WA
   Coding: 21F124A1C920C36E2078840224C693C304365700508B4885
   Shop #: WSC 00049 770 00150
   ASAM Dataset: EV_Brake1ESCEPBTRW 006353
   ROD: EV_Brake1ESCEPBTRW_006.rod
   VCID: 71BFD7CA112A9C2370D-8024
kjrehsi
C?ID=287868
Can we get a complete Auto-Scan please?
Saturday,24,July,2021,21:30:53:14442
VIN: WAUZZZ8U9JR002123   License Plate:
Chassis Type: 8U-AU21 (8U0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 55 56 5F 62
          6C 6D 72
VIN: WAUZZZ8U9JR002123   Mileage: 53060km-32969miles
Address 01: Engine (J623-DFUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 FL    HW: 04L 907 309 AB
   Component: R4 2.0l TDI   H20 3201
   Revision: 8EH20---
   Coding: 02250012043701082000
   Shop #: WSC 00049 770 00116
   ASAM Dataset: EV_ECM20TDI01104L906016FL 004003
   ROD: EV_ECM20TDI011_AU21.rod
   VCID: 78A9EAEE7250CD6BB73-802C
   Part No SW: 0BH 300 013 D    HW: 0BH 927 711 G
   Component: DSG DQ500-7A  H11 5302
   Revision: 00H11V01
   VCID: 2517F39A95628083DC5-8070
   Part No SW: 8U0 820 043 H    HW: 8U0 820 043 H
   Component: E87  Klimavoll      0220
   Revision: 00H05000    Serial number: 8U0820043H
   VCID: 363524D63444FB1B65F-8062
   Part No SW: 8X0 907 063 AK    HW: 8X0 907 063 AF
   Component: BCM PQ35  M   113 0827
   Revision: AB113821
   Coding: 0E000A2CA817F1C0201849C0218401CC47F327AA216F812BE408878400C1
   Shop #: WSC 46606 001 104857
   VCID: 0557931A3522A083BC5-8050
   Subsystem 1 - Part No SW: 8U2 955 119     HW: 8U2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS316 170330  H38 0090
   Serial number:         170425124206
   Coding: 004FF7
   Serial number: 62807490
   Coding: 02006E
   Subsystem 3 - Part No: 8X0 951 177 A
   Component: Sensor, DWA 0  005 0002
Address 10: Park/Steer Assist (J446)       Labels:| 8X0-919-475.clb
   Part No SW: 8X0 919 475 AK    HW: 4H0 919 475 AG
   Component: PARKHILFE 8K  H01 0090
   Revision: 11001001    Serial number: 61031714201501
   Coding: A8C30F
   ASAM Dataset: EV_EPHVA18AU21X0000 003009
   ROD: EV_EPHVA18AU21X0000_003.rod
   VCID: 0F7BB13267DEEAD3069-805A
   Part No SW: 8U0 959 655 D    HW: 8U0 959 655 D
   Component: AirbagVW-AU10 H12 0910
   Serial number: 003S0R0HTGC3
   Coding: 30523232333030303030554A305238553053
   ASAM Dataset: EV_AirbaAU10SMEAU316 001010
   ROD: EV_AirbaAU10SMEAU316_001.rod
   VCID: 48C95A2E42307DEB073-801C
   Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3496KSME4F351543ZZZ-
   Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3506KSME54031543ZZZD
   Serial number: 3516KSME5F131543ZZZQ
   Serial number: 3526KSME28513D42ZZZS
   Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
   Serial number: 3555USME373C2242ZZZ.
   Part No SW: 8X0 953 521 AF    HW: 5K0 953 569 BD
   Revision: FF010018    Serial number: 20170512100280
   Coding: 1894204000
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 0059820E2A8085AB8F3-8054
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
   Serial number: 27 04 2017  C0044847
   Part No SW: 8U0 920 990 M    HW: 8U0 920 990 M
   Component: KOMBI_COLOUR  H04 0430
   Coding: 42CF01
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
   VCID: 47CB59124F2E72930E9-8012
   Part No SW: 8U0 907 468 AQ    HW: 8U0 907 468 G
   Component: GAT 4CAN 1L M H13 0090
   Revision: 1P170044    Serial number: 4441P17430000B
   Coding: FBCF1A5A000108610353
   VCID: 117FB74A716AFC2310D-8044
   Subsystem 1 - Part No SW: 1K0 915 181 L    HW: 1K0 915 181 L
   Component: J367-BDM  H07 0270
   Serial number: 44137G53095831428881
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663 D
   Serial number: 170315000000000007A0
   Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7540
   Serial number: HA1-00028.03.17
   Coding: 0001
   VCID: 52FD7846B46CC73B697-8006
   Component: IMMO          H04 0430
   Coding: 000002
   ROD: EV_Immo_UDS_VDD_AU10.rod
   Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
   Component: TSG FA        H11 0415
   Coding: 011806205C01000000
   VCID: 52FD7846B4ECC73B697-8006
   Part No: 5N0 909 144 R
   Component: EPS_ZFLS Kl. 297    3501
   Revision: 00H22000
   VCID: 40D9420E668045ABCF3-8014
   Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
   Component: TSG BF        H11 0415
   Coding: 011806205E01000000
   VCID: 51FF774AB1EABC2350D-8004
Address 55: Headlight Range (J745)       Labels:| 5M0-907-357-V3.clb
   Part No SW: 5M0 907 357 G    HW: 7P6 907 357 B
   Component: AFS-ECU       H01 0031
   Coding: 08AE00102B230200
   ASAM Dataset: EV_HeadlRegulLEDAFSPt 001001
   ROD: EV_HeadlRegulLEDAFSPt.rod
   VCID: 38292AEE32D00D6B773-806C
   Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H09 0003
   Coding: E02500
   Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H09 0003
   Coding: E02500
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 7050
   Coding: E02500
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 7050
   Coding: E02500
   Part No SW: 4G0 035 061 S    HW: 4G0 035 061
   Component: Radio U DAB   H60 0154
   Revision: AB001007    Serial number: 109DM0H5021025
   Coding: 010105020100000002
   VCID: 2D070BBACD12B8C3145-8078
   Part No SW: 8U1 035 670 F    HW: 8U1 035 670 E
   Component: H-BNT-EU      H43 1072
   Revision: --------    Serial number: 486D/0HB004145
   Coding: 0E010106000AE1EB05800F3600000001000000000000000000
   VCID: 392F2FEA095A146388D-806C
   Subsystem 1 - Part No: 8R0 060 884 EM
   Component: EUR 2017/2018  2503
   Subsystem 2 - Part No SW: 8U0 919 604 A    HW: 8U0 919 604 A
   Component: DU High AU316  H43 0018
   Serial number: AUZ8ZDHCR01MAY$
   Subsystem 3 - Part No: 8R0 060 961 G
   Component: CD-Database  9040
Address 62: Door, Rear Left (J388)       Labels:. 8X0-959-795.clb
   Part No SW: 8X0 959 795 C    HW: 8X0 959 795 C
   Component: TSG HL        H08 0415
   Coding: 010006200001000000
   VCID: 4FFB7132A7DEAAD3469-801A
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 8U0 907 441     HW: 8U0 907 441
   Component: SG Rueckfahrkamera  0031
   Revision: --H11---    Serial number: 525 PA8JC7H060
   Coding: 1020015
   Shop #: WSC 02391 785 00013
   VCID: 76B5E4D674C4BB1BA5F-8022
03006 - Back-up Camera System not calibrated
                    Reset counter: 96
   Part No SW: 8U0 959 107 A    HW: 8U0 959 107 A
   Component: HDSG-Modul    H02 0552
   Revision: 15001001    Serial number: 108700270
   Coding: 183307C002
   ASAM Dataset: EV_HDSGAU316 001001
   ROD: EV_HDSGAU316.rod
   VCID: 3D273BFA1DF22843A45-8068
Address 72: Door, Rear Right (J389)       Labels:. 8X0-959-795.clb
   Component: TSG HR        H08 0415
End----------(Elapsed Time: 01:39, VBatt start/end: 13.2V/13.1V)-----------
kjrehsi
C?ID=287868
Anybody?
I was thinking there might be something in the cluster's coding or adaptation for it, but if there is, I don't see it.
kjrehsi
C?ID=287868
Thanks Uwe, yeah it is tough one I guess? :confused:
NEtech
Denmark
C?ID=56995
If you want to test, you could try these:
21F124A1C920E36E2078840224C693C704365700508B4885
21F124A1E920C36E2078840224C697C304365700508B4885
21F124A1E920E36E2078840224C697C704365700508B4885
kjrehsi
C?ID=287868
Thanks NEtech I will give it a go :o
kjrehsi
C?ID=287868
This code worked :)
However I am presented with this error. It doesn't seem to go even with the original code.
Strangely I am not getting any error in the 'Auto Scan' area?
Saturday,21,August,2021,20:24:21:14442
VCDS Version: Release 21.3.0 (x64) Running on Windows 10 x64
                Address 03: ABS Brakes       Labels: 5N0-614-109-V1.clb
Control Module Part Number: 5N0 614 109 CF    HW: 5N0 614 109 CJ
  Component and/or Version: ESC-EBC460iV1 H12 0013
           Software Coding: 21F124A1E920C36E2078840224C697C304365700508B4885
            Work Shop Code: WSC 00049 770 00150
              ASAM Dataset: EV_Brake1ESCEPBTRW 006353 (AU21)
0898 - Vacuum sensor
          C10A3 01 [009] - Electrical Failure
          [VAC_SENS_1_SIGNAL_LOST_INFO]
                    Reset counter: 130
                    Mileage: 55240 km
                    Date: 2021.08.21
                    Time: 20:18:48
                    Additional_Codes: 00 00 00 0B FE 7F 00 08 0A
                    DTC: 00 03 82
                    Additional2: 01 04 01 05 05 00 38 00 38 00
kjrehsi
C?ID=287868
@NEtech do I need to recalibrate something? After changing the code am getting the above Vacuum sensor error even if I go back to the original code.
I haven't driven the car much but I am expecting the ABS lights to come on dash from reading one of the forums.
Please advice
NEtech
Denmark
C?ID=56995
Not that I know about.
DTC Intermittent? delete it.
kjrehsi
C?ID=287868
It comes back after clearing the code, however no errors on Dashboard as yet
kjrehsi
C?ID=287868
@NEtech green 'P' now not visible. It stopped work :(
Tiptop
C?ID=127746
Kjrehsi
Have you tried setting byte 18 back to 34?
Have you any back up scans saved to check against incase anything else has altered?
Tiptop
C?ID=127746
Kjrehsi
When you altered the ABS coding did you alter both bytes (4 and 14) that were different to your original or did you try one at a time?
kjrehsi
C?ID=287868
Kjrehsi
Kjrehsi
@Tiptop
I tried all 3 long coding's suggested by NEtech.
I have the previous version of long coding saved so will revert back and try the individual bytes.
Tiptop
C?ID=127746
Please post back on how you get on
kjrehsi
C?ID=287868
Ok I had to change Byte 6 to E3 AND Byte 15 to C7 at the same time otherwise you will get 'Request out of range' error.
I can see the green 'P' again now. Tested it on a short drive and can still see the green 'P' lit up on dash when Hold assist is activated
However I am still seeing this error
                    Reset counter: 130
                    Mileage: 55240 km
                    Date: 2021.08.21
                    Time: 20:18:48
                    DTC: 00 03 82
kjrehsi
C?ID=287868
Guys should I be worried about the error for Vacuum sensor? I am not sure if the change of coding has caused this?
Never saw this error before the code change.
dnoermann
C?ID=358118
I guess that this is a Error in your ABS Coding.
You have a Diesel
And i guess that the Vacuum Sensor Error in ABS is related to the Vacuum Sensor needed in Gasoline Engines.
So ABS Thinks that you have a Gasoline ...
