A Little Help Please
whosrusty
Florida, USA
C?ID=447743
Hi everyone. I'm new to VW so any help is appreciated. Here's the scan. Thanks in advance.
Thursday,22,July,2021,20:00:24:34628
VIN: 3VWTH69M73M127714   License Plate:
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
          75 76
VIN: 3VWTH69M73M127714   Mileage: 264380km-164278miles
Address 01: Engine        Labels: 022-906-032-BDF.lbl
   Part No: 022 906 032 CR
   Component: MOTRONIC ME7.1.1G   0005
   Coding: 00033
   Shop #: WSC 00066
   VCID: 5DE790FB4429FAA3C45-5160
   3VWTH69M73M127714     VWZ7Z0B6206963
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 09A-927-750.lbl
   Part No: 09A 927 750 AH
   Component: AG5 Getriebe 09A   0218
   VCID: 71BFDC4BA8B16EC370D-5066
00300 - Transmission Fluid Temp. Sensor (G93)
01166 - Engine Torque Signal
            16-10 - Signal Outside Specifications - Intermittent
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 M
   Coding: 0019970
   Shop #: WSC 00066 000 00000
   VCID: 3431155F92231BEB5BB-5160
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 2.0.0
   Coding: 01000
   Shop #: WSC 00066
   VCID: 211FEC0B38D19E43A0D-51A8
00603 - Footwell/defroster Flap Positioning Motor (V85)
            37-10 - Faulty - Intermittent
00281 - Vehicle Speed Sensor (G68)
            37-00 - Faulty
01272 - Positioning Motor for Central Flap (V70)
   Part No: 1C0 909 605 F
   Component: 04 AIRBAG VW61 0202 0001
   Coding: 12340
   Shop #: WSC 00066
   VCID: 270BF21356F56073EE9-513C
   Part No: 1J0 907 487 A
   Component: Lenkradelektronik   0005
   Coding: 00118
   Shop #: WSC 00066
   VCID: 2F3B1A337E053833269-5160
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
00926 - Terminal 30
   Part No: 1J0 920 926 F
   Component: KOMBI+WEGFAHRSP VDO V64
   Coding: 07234
   VCID: 2D07003B74094A23145-513C
01304 - Radio
            49-00 - No Communications
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70B9D94FA3BB67CB7F3-513C
01304 - Radio
Address 36: Seat Mem. Drvr        Labels: 3B1-959-760.lbl
   Part No: 3B1 959 760 E
   Component: Sitzverstellung     0301
   VCID: 2F3B1A337B053833269-513C
01008 - Note; Emergency OFF Switch is Active!
   Part No: 1C0 959 799 C
   Component: 1H Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 00066
   VCID: 372B22538655F0F37E9-4B1E
   Component: 1H Tõrsteuer.FS KLO 0009
   Component: 1H Tõrsteuer.BF KLO 0009
   Component: 1H Tõrsteuer.HL KLO 0009
   Component: 1H Tõrsteuer.HR KLO 0009
11 Faults Found:
            54-10 - Incorrectly Equipped - Intermittent
01359 - Internal Central Locking Switch; Passenger Side (E198)
            27-00 - Implausible Signal
End----------(Elapsed Time: 05:10, VBatt start/end: 12.2V/12.3V)-----------
iichel
Eindhoven, NB, NL
C?ID=284912
So uh what's the problem?
whosrusty
Florida, USA
C?ID=447743
No communication through the can gateway is what I'm suspecting but there isn't an individual module for it however it gives a part # for it. Is it part of the instrument panel? Thanks for the fast response!
iichel
Eindhoven, NB, NL
C?ID=284912
All of the issues are flagged as intermittent. Is there something not working?
whosrusty
Florida, USA
C?ID=447743
My daughter was driving the car and the instrument panel lit up like a Christmas tree and she heard a pop and the car didn't die but just would not go. The popping noise was the vacuum boost pump fuse. Replaced the vacuum and that fixed the fuse issue. I rebuilt the transmission and found 2 clutch packs burnt up. It is possible i don't have fluid passages lined up right in there but i want to look other places before i go in there again. I did not change the transmission harness while i was in there and that bit me in the @ss. Looks like I'll have to go back in it after all. So I'm trying to figure out why i have no communication to my ecu to my tcu to my instrument and my can bus gateway. The radio was gone when we got the car and the car still ran ginge for 3 months. I double checked all coding and they all look good. I do not have the codes in the vw manual for the ccm though so couldn't compare them.
Trowbridge, UK
There are lots of intermittent fault codes, to (hopefully) improve the signal-to-noise ratio it would help if you clear the fault codes in all modules then post a new Auto-Scan which will show only the current (real) fault codes.
whosrusty
Florida, USA
C?ID=447743
I did clear all the codes. Crank it up and do another reading this is what i get everytime. Can someone please just tell me what instrument the gateway is located in. It shows a part number but no module
The (aspiring) CAN Gateway in that car is a virtual module in the instrument cluster.
whosrusty
Florida, USA
C?ID=447743
Thank you so much! Explains why the instrument panel lit up like a Christmas tree and now i have no communication. Im working on the car now doing some other tests for other problems. I'll post more later with new scan codes. Thanks again.
whosrusty
Florida, USA
C?ID=447743
Here is a scan after I cleared the codes and NOT starting it! Big difference. I think you guys helped me find my problem. Thanks for all the help.
Monday,26,July,2021,12:36:21:34628
Mileage: 264380km-164278mi   Repair Order:
          75 76
   VCID: 71BFDC4BA8B16EC370D-508A
   Coding: 0019970
   Coding: 01000
   Shop #: WSC 00066
   Coding: 12340
   Shop #: WSC 00066
   Coding: 00118
   Shop #: WSC 00066
   Coding: 07234
01304 - Radio
   Coding: 00006
   Shop #: WSC 00066
01304 - Radio
   Coding: 00258
   Shop #: WSC 00066
End----------(Elapsed Time: 04:48, VBatt start/end: 12.4V/12.3V)-----------
whosrusty
Florida, USA
C?ID=447743
UPDATE... disconnect instrument panel and run diagnostics and no fault codes come up. Thanks for the help everyone! Much much appreciated!
