My car is trying to kill me haha
wolfmaster74
Kent, UK
C?ID=198202
Ok so started a couple weeks ago, sometimes when pulling away turning right faster than normal the steering would cut out momentarily the red steering wheel would come up it would beep at me maybe once bit them instantly be ok again.
Today it kind of done the same thing although I was already driving down a sweeping right hand hill put some power in on the turn and boom the electric cut on it again although no red steering wheel this time but the radio also turned off
Obviously when this happens on a turn it is quite scary as it actually trys to straighten up momentarily
Any ideas where to start looking? I hate electrical issues will post scan when I can get the laptop on thanks in advance
iichel
Eindhoven, NB, NL
C?ID=284912
My '66 Karmann Ghia also did this and it was a bent top left wishbone.
wolfmaster74
Kent, UK
C?ID=198202
Been a long time coming sorry, had been busy latley! ok so update this is becoming more frequent now little bumps not turing and even sometimes coming to a stop also sometimes when accelerating, at first i thought it was just the loss of steering but i also notice my radio turns of and my dash, been having a few random electrical issues at the same time.
Latest scan after this issues and also i managed to do some logging in the link below what i notice is when i have this issue of loss of steering and beep beep is when the voltage drops to 10v it did this twice in the logs, im really not sure what is going on as the voltage is not consistant and neither is the problem.
oh and to top it off i now have no boost its like driving a non turbo i also tried to log the specified and actual boost pressures but the actual just stays low. any guidance for that hahaha.
as always appreciate the assistance and support.
Sunday,15,August,2021,17:09:00:22691
VCDS Version: 21.3.0.0 (x64)
VIN: WVWZZZ1KZ9W527843   License Plate: MJ09DPK
Mileage: 192690km-119732mi   Repair Order:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
VIN: WVWZZZ1KZ9W527843   Mileage: 192690km-119732miles
Address 01: Engine (CCZ)       Labels:. 06J-907-115-CCZ.clb
   Part No SW: 5K0 907 115     HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0050
   Revision: AAH03---    Serial number:
   Coding: 0403000C1C070160
   Shop #: WSC 74565 000 00000
   VCID: 67F350C7563577B362-8032
001674 - ECM Power Relay Load Circuit
               P068A - 000 - Opens Too Early - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 96.0°C
                    Temperature: 42.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 11.684 V
001089 - EVAP Emission Control Sys
               P0441 - 000 - Incorrect Flow - Intermittent
                    Mileage: 192315 km
                    Date: 2016.01.06
                    Time: 01:37:56
                    RPM: 942 /min
                    Load: 22.7 %
                    Temperature: 85.0°C
                    Temperature: 41.0°C
                    Voltage: 13.335 V
008342 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
               P2096 - 000 - Too Lean - Intermittent
                    Mileage: 192570 km
                    Date: 2016.01.06
                    Time: 21:50:03
                    RPM: 2610 /min
                    Load: 29.4 %
                    Speed: 105.0 km/h
                    Temperature: 96.0°C
                    Temperature: 27.0°C
                    Voltage: 13.843 V
000566 - Manifold Pressure / Boost Sensor (G31)
               P0236 - 000 - Implausible Signal
                    Mileage: 192651 km
                    Date: 2016.01.06
                    Time: 12:39:18
                    RPM: 769 /min
                    Load: 26.7 %
                    Temperature: 65.0°C
                    Temperature: 37.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.589 V
Readiness: 0000 0001
   Part No SW: 02E 300 051 R    HW: 02E 927 770 AM
   Component: GSG DSG AG6     511 1975
   Revision: 05351112    Serial number: 00001102251239
   Coding: 0000024
   Shop #: WSC 00191 264 15243
   VCID: 226501D3FD97529BF5-8076
   Part No SW: 1K0 907 379 AM    HW: 1K0 907 379 AM
   Component: ESP MK60EC1   H45 0106
   Revision: 00H45001
   Coding: 163B600D89240001681306E8911C0081B108
   VCID: 7DDF12AFE4A9CD63A8-8028
                    Reset counter: 171
                    Mileage: 192684 km
                    Date: 2016.01.06
                    Time: 13:10:27
                    Count: 32768
                    Count: 4608
                    Count: 128
                    Count: 46347
                    Count: 56031
                    Count: 59162
                    Fault Status: 00100001
                    Reset counter: 171
                    Mileage: 192287 km
                    Date: 2016.01.06
                    Time: 00:04:05
                    Count: 64
                    Count: 4608
                    Count: 129
                    Count: 37164
                    Count: 62940
                    Count: 52998
   Part No SW: 5K0 907 044 AK    HW: 5K0 907 044 AK
   Component: Climatronic   130 0305
   Coding: 0000000000
   ASAM Dataset: EV_Climatronic A01001
   VCID: 74C9378BDFE38C2BD7-8020
   Part No SW: 1K0 937 086     HW: 1K0 937 086
   Component: BCM PQ35  M   020 0358
   Revision: 00020000
   Coding: 48180ABA9825F1C0440A00801100008447710008437D8D60648020040000
   VCID: 6DFF22EFB4C95DE318-8038
   Component: Wischer 05030  21  0501
   Coding: 009795
   Component: RLS 200309 05  54  0402
   Coding: 0330AD
                    Reset counter: 167
                    Mileage: 192247 km
                    Date: 2016.01.06
                    Time: 20:22:08
                    Voltage: 11.40 V
                        Term 50 Off
01598 - Drive Battery Voltage
                    Fault Status: 00101011
                    Fault Frequency: 16
                    Reset counter: 210
                    Mileage: 192247 km
                    Date: 2016.01.06
                    Time: 22:05:07
                    Voltage: 13.55 V
                        Term 50 Off
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 208
                    Mileage: 192302 km
                    Date: 2016.01.06
                    Time: 00:39:37
                        Term 15 Off
                    Voltage: 12.55 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
   Part No SW: 5K0 919 475 C    HW: 5K0 919 475
   Component: PARKHILFE 8K  H07 0008
   Revision: --------    Serial number: 12940906301944
   Coding: 300103
   VCID: 364DCD83811FDE3B29-8062
   Part No SW: 5K0 959 655     HW: 5K0 959 655
   Component: AirbagVW10    033 0604
   Serial number: 003C2D09Z5RK
   Coding: 00003136
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 77D30087CE95E733F2-8022
   Component: S.Sens.Fahr.V  U01 ----
   Serial number: 0E442546ZZZZZZZZZZZZ
   Component: S.Sens.Beif.V  U01 ----
   Serial number: 18752346ZZZZZZZZZZZZ
   Serial number: 0C492313ZZZZZZZZZZZZ
   Serial number: 00281C25ZZZZZZZZZZZZ
   Part No SW: 1K0 953 549 CE    HW: 1K0 953 549 CE
   Component: J0527           055 0111
   Coding: 0001632
   VCID: 77D300870695E733F2-8022
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000131
   Part No SW: 5K6 920 970 B    HW: 5K6 920 970 B
   Component: KOMBI         H05 0206
   Coding: 470900
   VCID: 334BF4979A6DCB130E-8066
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533  Gateway   H07 0071
   Revision:   H07 01    Serial number: 130309F1000499
   Coding: EDA07F06000612000003
   Shop #: WSC 08060 210 01865
   VCID: 3753C0874615273332-8062
   Component: IMMO          H05 0206
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Component: SG EXT.PLAYER H13 0084
   Revision: A1001003    Serial number: 7667386067
   VCID: 266D1DC351BFAEBB99-8072
   Part No SW: 1K0 959 701 AF    HW: 1K0 959 701 AF
   Component: Tuer-SG         008 2034
   Coding: 0000692
   VCID: 72C531936DF7821BC5-8026
   Part No: 1K0 909 144 E
   Component: EPS_ZFLS Kl. 74     2501
   Revision: 00H15000
   VCID: 2C79EFEB8F5394EB4F-8078
   Part No SW: 1K0 959 702 AG    HW: 1K0 959 702 AG
   Coding: 0000948
   VCID: 74C9378B17E38C2BD7-8020
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 190     HW: 3C8 035 190
   Component: Radio RCD510  036 0130
   Revision: 00000001    Serial number: VWZ1Z3I4298761
   Coding: 0100044004
   VCID: 60E14BDB731B008BA3-8034
00856 - Radio Antenna
                    Fault Status: 00100111
                    Reset counter: 209
                    Mileage: 192247 km
                    Date: 2016.01.06
                    Time: 20:24:12
   Part No SW: 1K0 959 703 AL    HW: 1K0 959 703 AL
   Component: Tuer-SG         007 2009
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   VCID: 7AD519B33587FA5B8D-802E
   Part No SW: 1K0 959 704 AL    HW: 1K0 959 704 AL
   Coding: 0000144
   VCID: 7BDB1CB73ABDC35396-802E
Address 77: Telephone        Labels: RETROFIT77.lbl
   Part No SW: KTC 364 96P     HW: KTC 364 96P
   Component: SWP:3.11.8      H24 0185
   Shop #: WSC 21977 142 74100
   VCID: 3E5DD5A3692F167BF1-806A
End-------------------------(Elapsed Time: 02:08)--------------------------
wolfmaster74
Kent, UK
C?ID=198202
i feel like i must be getting a massive short circuit at times , battery is also good and holds good charge less than year old. on initial tests alt looks good as putting out resonable voltage.
wolfmaster74
Kent, UK
C?ID=198202
Ok so yeah i saw that article although im unsure as to which relay is Power Supply Relay (J271/J317) - i Checked the fuses in both cabin and engine bay, all check out ok none look like have seen heat or damage in anyway continuty across the fuses is good. Checked all the wiring at the engine bay fuse box all ooks good not seeing anything that look melted burnt or black cant see any obvious arcing any where.
Alternator wiring looks good up to the fuses.
Battery seems good , hold good charge never lazy to start
I have no errors on dash normally untill the monmentariy issue occures then will get usually the steering wheel and beep but also notice things like cluster go off and radio at same time.
Only thing that looked suspcct was the main fuse strip as one of the legs looked twisted compared tothe others - i have ordered a new one and will see if it makes any difference.
But yes also very possible a connection gets disconnected rather than shorting out but trying to figure out which connection i should be looking at.
Many Thanks
for the continued support
Bruce
Near Philadelphia, PA, USA
I would suspect an open, rather than a shorted, circuit.
I agree with Uwe, and Bruce , it seems you have a momentary "open" and loss of power to this circuit. With a WD you will be able to trace the harness or circuit back from the cluster ; it may go to that relay in post #6 (?) Check Youtube on how to test that relay.
You may need to have a look under the car (remove the plastic shields) or deep in the engine compartment : look for the Ground straps or wire(s) (large solid brown ; usually) you may have a very corroded connection ; especially around or near the battery. A WD , post #8 from Bruce) would tell you where these are located.
I think this is your most obvious clue:
wolfmaster74
Kent, UK
C?ID=198202
Thabkyou very much for the valuable troubleshooting steps, I will looks at getting the WD later today on a side note I change the main fuse strip today as noticed it was broken and on the power steering fuse especially and others seem lose to like wobbly teeth haha. I have replaced it now and will test car and see if issue re occurs, also want to open this old one up and see how bad inside is
wolfmaster74
Kent, UK
C?ID=198202
Ok so opened up the fuse and can see the steering one was holding on by a thread so that may explain why it was losing power but doesn't explain the rest at the same Time will have to wait and see will also clean up all the grounds I can find
wolfmaster74
Kent, UK
C?ID=198202
So far so good took it for a spirited drive, over bumps did some hard stops and hard acceleration both straight and in turn and not seen the issue yet so fingers crossed, will have to see on a longer drive next to see if it's a heat thing too possible problem only shows under heat
Also managed to down load all the WD from he Erwun link thankyoy for that will now need to take some lessons on reading them hahaha
wolfmaster74
Kent, UK
C?ID=198202
Ok no problem still there u can make it happen more often when turning right and then accelerating, again everything turned off and came back on instantly with the red steering wheel and beeps,
i cleared the codes and drove no faults and codes remain clear (except the alarm horn that is always present) and then straight after the problem i scan again please see below scan
am feeling very deflated but want to get to bottom of this ....
Monday,16,August,2021,18:42:00:22691
VIN: WVWZZZ1KZ9W527843   Mileage: 192780km-119787miles
                    Mileage: 192775 km
                    Date: 2016.01.07
                    Time: 03:53:41
                    RPM: 847 /min
                    Load: 18.0 %
                    Temperature: 97.0°C
                    Temperature: 58.0°C
                    Voltage: 13.589 V
   Coding: 0000024
   Revision: 00H45001
                    Reset counter: 172
                    Mileage: 192781 km
                    Date: 2016.01.07
                    Time: 06:42:11
                    Count: 32769
                    Count: 4608
                    Count: 129
                    Count: 31488
                    Count: 62163
                    Count: 54287
   Coding: 0000000000
   Revision: 00020000
   Coding: 009795
   Coding: 0330AD
                    Reset counter: 172
                    Mileage: 192775 km
                    Date: 2016.01.07
                    Time: 03:50:22
                    Voltage: 13.75 V
                        Term 50 Off
                    Reset counter: 212
                    Mileage: 192775 km
                    Date: 2016.01.07
                    Time: 06:10:02
                    Voltage: 11.50 V
                        Term 50 Off
                    Reset counter: 212
                    Mileage: 192781 km
                    Date: 2016.01.07
                    Time: 06:41:31
                    Voltage: 13.10 V
                        Term 50 Off
                    Reset counter: 212
                    Mileage: 192782 km
                    Date: 2016.01.07
                    Time: 06:43:38
                    Voltage: 12.05 V
                        Term 50 Off
   Coding: 300103
   Coding: 00003136
   Coding: 0001632
   Coding: 00000131
   Coding: 470900
   Coding: 0000692
   Revision: 00H15000
   Coding: 0000948
   Coding: 0100044004
   Coding: 0000144
   Coding: 0000144
End-------------------------(Elapsed Time: 02:10)--------------------------
Can you recreate the problem with the car engine running but not moving ; try turning the steering wheel while the car engine is running, but vehicle not moving, lock to lock L and R. Does the problem occur then ?
wolfmaster74
Kent, UK
C?ID=198202
unfortunately no i cannot recreate it on purpose or standstill its so random, have also found several other vws / audis threads with similar problem
heres another simalar posts with almost identical issue , problem is no one ever has a solution or says wether problem is resolved.
This is another simaler problem and it was an earth issue so will look at earth points next
I would definitely check the external earth points ; ie the ones exposed to the elements ; these (loose or corroded) connections can create all sorts of unpredictable problems.
Also, regarding your last link with the "solved" mentioned...... I do know that some Subaru and Honda owners routinely do this to prevent grounding problems: with heavy gauge wire they run a series of "fingers" / wires to a common ground point on the body (a new one if necessary). Intake manifold, engine block, to a solid body ground point with separate wires, then from that common ground point run a heavy wire to the alternator MOUNTING bolt (ie between the case of the alternator and a mounting bracket)........ and then run a wire from the common grounding point that you established to the negative side of the battery.
They "sware" by it. They feel that the injectors on the aluminum intake manifold are not adequately grounded since the engine is mounted in rubber etc.
It is easy enough to do ; safe ; and perhaps worth a try.
wolfmaster74
Kent, UK
C?ID=198202
Yeah I'm starting to think earth when I check between battery negative and engine on multimeter ohms setting 200 I get high readings of 100 - 150 between negative and body post seeing 55 on the meter negative to negative pole is reading 00.0 I chucked an a quick wire between negative and body post and the ohm went down to 00.2 so guessing the cable between negative and body is bad, is strange as when I remove the cable and test it I also get 00.0 even when wiggling it, will order a new negative cables and retest
Trowbridge, UK
Likely to be corrosion at either or both ends where the cable connects to the body and motor.
wolfmaster74
Kent, UK
C?ID=198202
I thought this cleaned it all up both ends battery post and body post even though it was nice and bright and looked corrosion free and still same issue have got some heavy duty lugs to pick up today and some nice 16mm cable from an old battery reloaction project so am going to add a couple of additonal earths
