Octavia MK2 rear wiper - to be sure question
Orchid70
Sweden
C?ID=354348
Hi
I can turn on both wiper motor and washer with VCDS - only.
Nothing happens with the lever. Not the wiper nor washer. No clicks under the steering wheel.
Lever works on wind sheald wiper and washer.
Is there any chanse it to be the Comfort control module or is it usually the lever itself?
I had to already change the motor and wiper arm, due to them beeing welded together by rust.
Fault code for Inclination sensor G384 and
Fault codes on Steering wheel, remains after erazing
See below
Thank you
Saturday,24,July,2021,15:31:36:18201
Dealer/Shop Name: Firma Johannes Bruun
Workshop Code: 000 02013 000000
VIN: TMBGA61Z4A2085698   License Plate: AZB599AFTER
Mileage: 200920km-124845mi   Repair Order:
Chassis Type: 1Z-SK35 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 69 72
VIN: TMBGA61Z4A2085698   Mileage: 200920km-124845miles
Address 01: Engine        Labels: 06A-906-033-BGU.lbl
   Part No: 06A 906 033 JE
   Component: CCSA S77 1.6 2VG    1908
   Revision: --H04---    Serial number:
   Coding: 0044071
   Shop #: WSC 73430 790 00000
   VCID: 6B83C5F6CF8181C34A1-803E
Readiness: 0110 1101
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 113B201C092A00FF881104ED90210040300000
   VCID: 78A9EABA82D73A5BB73-802C
   Part No SW: 3T0 907 044 AS    HW: 3T0 907 044 AS
   Component: Climatronic   H15 0401
   Revision: 00005001
   Coding: 0000000002
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 03538D56CB916983921-8056
   Part No SW: 1K0 937 087 D    HW: 1K0 937 087 D
   Component: BCM PQ35  H   103 0575
   Revision: 00103 AG
   Coding: 40180AB8F05BF1C040080080110081E4430100AE626D8D605C0540000000
   VCID: 323D1892242B100B497-8066
   Subsystem 1 - Part No: 1Z1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 16011  22  0601
   Coding: 00D7B7
   Component: RLS 070110 05  54  0402
   Coding: 0730ED
   Subsystem 3 - Part No: 1Z0 951 171 A
   Component: Innenraumuebe  009 5103
00323 - Vehicle Inclination Sensor (G384)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 164
                    Mileage: 200922 km
                    Date: 2015.12.15
                    Time: 22:54:44
                        Term 15 Off
                    Voltage: 12.00 V
                        Term 50 Off
                    Fault Status: 00101010
                    Reset counter: 204
                    Mileage: 200922 km
                    Date: 2015.12.15
                    Time: 20:52:21
                    Voltage: 11.70 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels:. 1Z0-919-475-V1.clb
   Part No SW: 1Z0 919 475 B    HW: 1Z0 919 475
   Component: PARKHILFE 4K  H06 0006
   Revision: --------    Serial number: 66641000904037
   Coding: 110001
   VCID: 40D9425A9A87B29BCF3-8014
   Component: Q6 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2J7CMP
   Coding: 0020790
   VCID: 3D273BAEE175DF73A45-8068
   Subsystem 1 - Serial number: 6332MSME4D12136CD
   Subsystem 2 - Serial number: 6342MSME4D154F20G
   Subsystem 3 - Serial number: 6351HSME1F756A60H
   Subsystem 4 - Serial number: 6361HSME20170F7FF
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           053 0111
   Coding: 0000034
   VCID: 03538D56C7116983921-8056
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
   Part No SW: 1Z0 920 843 F    HW: 1Z0 920 843 F
   Component: KOMBI         H05 0305
   Coding: 110F00
   Shop #: WSC 73430 031 00000
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
   VCID: 3B2335B6F3E1D1439A1-806E
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0233
   Revision:   H16       Serial number: 4520K101120841
   Coding: E9A07F46000202002302
   VCID: 698FBFFEC57D93D338D-803C
   Component: IMMO          H05 0305
   VCID: 6A8DC0F2CCFB98CB317-803E
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2113
   Coding: 0000246
   VCID: 76B5E48284C34C2BA5F-8022
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 67     3001
   Revision: 00H17000
   VCID: 313F179E2D2D2B1330D-8064
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Coding: 0000246
   VCID: 48C95A7ABEB78ADB073-801C
   Part No SW: 1Z0 035 161 G    HW: 1Z0 035 161 G
   Component: Radio-SWING   008 0034
   Revision: -----11S    Serial number: SKZ4Z2K1102040
   Coding: 0D0004000001
   Shop #: WSC 58819 001 1048576
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
   VCID: 323D1892282B100B497-8066
   Component: Anhaenger     H07 0070
   Revision: 3A001001    Serial number: 00000125155022
   Coding: 410D000100000000
   VCID: 3039129A2A27221B3F3-8064
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 33331D96D7311903421-8066
End----(Elapsed Time: 01:04, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
Do you have a wiring diagram?
I would focus on the ignition switch faults. It may need a new switch. I could see where that might prevent the wiper/washer controls from working.
Mari
C?ID=150535
Replace ingnition switch, clear faults and see what comes back and check if you wiper/washer works... You can check switches in measuring blocks...
Orchid70
Sweden
C?ID=354348
Is this the correct part (car manufactured january 2010)?
1k0905865a
Orchid70
Sweden
C?ID=354348
After changing the ignition switch, the fault codes on it are gone.
How ever, the rear wier doesnt work from the lever itself. Would we be looking on the lever next? Change it?
I couldnt see on the wiring diagram, that the wiper wires would go through the comfort control module.
Orchid70
Sweden
C?ID=354348
Came back and re-read what you guys have said.
And checked out the measuring blocks....
This is really strange.
There is still no fault codes - but I can see in the measuring blocks that the lever i operated.... but the rear wiper motor nor washer operates - only when I operate it with VCDS.
Orchid70
Sweden
C?ID=354348
The coding in 16 Steering wheel, is correct 00034:
Long coding in 09 Central Electric module looks like this:
Someone who has any ideas?
Orchid70
Sweden
C?ID=354348
And yeas - the boot is correctly shown closed.
Orchid70
Sweden
C?ID=354348
Anyone?
Im going nuts.... with this car as well................
H-E-L-P please =(
