Transporter t6 bcm problem
smirnoffrules
C?ID=269658
hi lads/ladys ,
l have a customer with a t6
VOLKSWAGEN TRANSPORTER T28 TDI P/V TRENDLINE BMT
VIN: WV1ZZZ7HZGH129480 Bhp: 101
Reg Date: 28/06/2016 Engine Code: CAAB
he bought van with with faulty bcm he thought and ask me to program in new one . he has bought one with all the same numbers, l copied coding from old one to new one but the display on cluster show wrong door open ? n/s/f open when o/s/f is open his old one show the doors correctly.
in long coding help there is nothing about door or different country setting like cluster does , in cluster its set to uk , the right setting .
any ideas what lm missing . this is full read from old bcm , the oil fault is switch on sump , lm not the first to see this car , many have been there before me , but lm he fiest to fit bsm unit l think
Saturday,24,July,2021,09:28:44:42713
VIN: WV1ZZZ7HZGH129480   License Plate: T5STEVE
Mileage: 164380km-102140mi   Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 09 10 15 17 19 25 5F 61 0B
VIN: WV1ZZZ7HZGH129480   Mileage: 164380km-102140miles
Address 01: Engine (J623-CAAB)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GE    HW: 03L 907 309 L
   Component: R4 2,0L EDC   X38 6292
   Revision: 22X38---    Serial number: 00000000000000
   Coding: 01114010232401080000
   Shop #: WSC 26214 051 00000
   ASAM Dataset: EV_ECM20TDI01103L906019GE 003004
   ROD: EV_ECM20TDI01103L906019GD_003.rod
   VCID: 74B02AD72E31423B9BB-8020
7144 - Please Check DTC Memory in CAN Gateway (J533)
          U1008 00 [044] - -
          [Diagnostic interface for data busRead out DTC]
                    Fault Frequency: 60
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 02:36:13
                    Engine RPM: 862.50 /min
                    Normed load value: 45.9 %
                    Coolant temperature: 37 °C
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 13.860 V
                    ACC specified acceleration: 0.000 m/s²
                    ACC control module: received status-Bits 0-7: 4
                    Active brake system error status-Bits 0-7: 0
                    Status of ACC/CCS acceleration interface-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
                    Engine status: COENG_RUNNING
5273 - Output for Starter Relay
          P0616 00 [032] - Short to Ground
                    Mileage: 163798 km
                    Date: 2021.06.18
                    Time: 18:15:25
                    Engine RPM: 861.50 /min
                    Coolant temperature: 30 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 13.980 V
                    Starter control: terminal 50 feedback-Bits 0-7: 0
                    Starter control: relay 1-Bits 0-7: 0
                    Starter control: release conditions-Bits 0-7: 2
                    Starter control: release conditions-Bits 0-7: 12
                    Starter control: shut-off conditions 1-Bits 0-7: 0
                    Starter control: shut-off conditions 1-Bits 0-7: 1
                    Number of manual engine starts-Bits 0-7: 0
                    Number of manual engine starts-Bits 0-7: 22
                    Number of automatic engine starts-Bits 0-7: 0
                    Number of automatic engine starts-Bits 0-7: 163
5459 - Control Circuit for Starter Relay 2
          P3048 00 [032] - Short to Ground
                    Mileage: 163794 km
                    Date: 2021.06.18
                    Time: 18:06:20
4482 - Function Restriction due to Implausible Message(s)
          U1112 00 [040] - -
                    Fault Frequency: 9
                    Mileage: 164373 km
                    Date: 2021.07.23
                    Time: 12:21:06
                    Engine RPM: 0.00 /min
                    Coolant temperature: 23 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 11.740 V
                    Cruise Control System (CCS): switch position-Bits 0-7: 0
                    Cruise Control System (CCS): status-Bits 0-7: 12
                    Cruise control switch-off: irreversible-Bits 0-7: 255
                    Cruise control switch-off: reversible-Bits 0-7: 255
                    Cruise Control System: specified speed: 0.00 km/h
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
   Component: ESC           H05 0132
   Revision: 00000000    Serial number: 40896000001605
   Coding: 517E4098256484878A79027EA48221E6390000
   Shop #: WSC 02739 790 50316
   VCID: 3FDAB5FB57F7D163B69-806A
8224 - Databus
          [ACAN: Airbag coding missmatch]
                    Reset counter: 21
                    Mileage: 164373 km
                    Date: 2021.07.23
                    Time: 12:21:06
   Serial number: 16031613470490
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA408FF107D186BFDF-802A
332644 - Databus
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:27
                    Voltage terminal 15: 12.20 V
                    Voltage terminal 30: 5.00 V
                    Terminal 15 status: not coded/not installed
                    Entprellzeit: 5000 ms
332660 - Databus
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:27
117060 - Databus
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:27
                    Voltage terminal 30: 12.25 V
                    Terminal 15 status: On
   Part No SW: 7E0 937 090     HW: 7E0 937 090
   Component: BCM PQ25 Max4 H80 0736
   Revision: B9080001    Serial number: 0771 092160977
   Coding: E0A4303A0A2120B1002009742C2B8C508FA0708F60444D60320400220800
   Shop #: WSC 02737 022 1072630
   VCID: 68884EA76279B6DB273-803C
   Subsystem 1 - Part No SW: 7E0 959 801 K    HW: 7E0 959 801 K  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 8654
   Serial number: KU0KU030031660905567
   Coding: 1400B0
   Subsystem 2 - Part No SW: 7E0 959 802 K    HW: 7E0 959 802 K  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 8654
   Serial number: KU0KU030031660902086
   Coding: 0400A0
01365 - Lock/Unlock Switch; Interior
                    Fault Status: 01101000
                    Fault Frequency: 213
                    Reset counter: 236
03301 - Response Closing Status of Drivers Door
                    Fault Frequency: 14
                    Reset counter: 20
                    Mileage: 163769 km
                    Date: 2021.06.15
                    Time: 04:07:37
03303 - Response Closing Status of Rear Left Door
                    Fault Frequency: 8
                    Reset counter: 253
                    Mileage: 163794 km
                    Date: 2021.06.18
                    Time: 18:07:54
                    Fault Status: 00101011
                    Reset counter: 20
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 236
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:51
                    Reset counter: 236
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:51
   Part No SW: 7E0 919 475 R    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0210
   Revision: --------    Serial number: 32961605400354
   Coding: 10800A
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_VW75XParkAssis4K 001012
   ROD: EV_VW75XParkAssis4K_001.rod
   VCID: 41DEB3032103A793C0D-8014
1079316 - Center Rear Right Parking Aid Sensor
          B1078 14 [009] - Open or Short to Ground
                    Reset counter: 171
                    Mileage: 163570 km
                    Date: 2021.05.26
                    Time: 18:21:59
   Part No SW: 7E0 959 655 G    HW: 7E0 959 655 G
   Component: VW10Airbag01N H08 0018
   Revision: --------    Serial number: 003V3000D3V+
   Coding: 00000000000000000000000000000000314E
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750_VN75.rod
   VCID: 3A2CC4EF4CD5F44B817-806E
   Part No SW: 7E0 920 970 L    HW: 7E0 920 970 L
   Component: KOMBI         H05 1008
   Coding: 470B010100
   VCID: 3332E9CB6BBF0503421-8066
9453841 - Oil Level Thermal Sensor
          B1041 33 [009] - Signal low time > maximum
                    Reset counter: 176
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:03:24
13639427 - Please Check Fault Codes in Engine Control Module
          U101F 00 [009] - -
          [Steuergerät für Motor: bitte Fehlerspeicher auslesen Öltemperatur]
                    Reset counter: 236
                    Mileage: 164382 km
                    Date: 2021.07.24
                    Time: 09:25:30
12605440 - Databus
          U1201 00 [008] - No Communications
                    Reset counter: 21
                    Mileage: 164373 km
                    Date: 2021.07.23
                    Time: 12:19:31
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H80 0736
   Revision: B9080001
   Coding: 042305
   Component: IMMO          H05 1008
   VCID: 6A8C34AF7CF584CB317-803E
13762816 - Databus
                    Reset counter: 21
                    Mileage: 164373 km
                    Date: 2021.07.23
                    Time: 12:19:31
   Part No SW: 1K8 035 150 E    HW: 1K8 035 150 E
   Component: MU-E-D-ER     857 6495
   Serial number: 16031600010047
   Coding: 065700003C00000041111101008000001F0000860000010001
   ASAM Dataset: EV_MUEnt4CGen2LGE 001025
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 270A0D9BAF6779A3EE9-8072
10 Faults Found:
6705 - Databus
          [Terminal_status: no communication]
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:27
                    Voltage terminal 30: 12.2 V
                    Network diagnosis-Status: Not available
6725 - Databus
          [LIMP HOME: data bus: no communication]
                    Reset counter: 21
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:27
6700 - Databus
          [Dimming: no communication]
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:27
6702 - Databus
          [ESP: no communication]
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:27
6704 - Databus
          [Gateway: no communication]
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:27
6706 - Databus
          [Instrument cluster: no communication]
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:27
6708 - Databus
          [Engine: no communication]
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:27
6713 - Databus
          [System information: no communication]
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:27
6714 - Databus
          [VIN: no communication]
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:27
6922 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Park assist OPS (0x0A) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 176
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0736
   Coding: 030B1A73
   Shop #: WSC 02739 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 G    HW: 7E0 915 181 G
   Component: J367-BDM  H08 0223
   Serial number: 53082847481261771005
02252 - Generator
                    Reset counter: 170
                    Mileage: 163564 km
                    Date: 2021.05.26
                    Time: 13:23:59
02256 - Quiescent Current
                    Fault Status: 00100001
                    Fault Frequency: 41
                    Reset counter: 15
                    Date: 2021.05.27
                    Time: 02:01:57
End----(Elapsed Time: 01:07, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
Address 09,7E0 937 090 ,recoded (Long Coding),from,24982BBB0C610000000000302E4B0C800F00400F60040850200000000000,to,E0A4303A0A2120B1002009742C2B8C508FA0708F60444D60320400220800,(18752/008/00032),
Address 09: DTCs cleared
VWT6
Finland
C?ID=295527
Did you copy also the coding for the 19-Gateway - as it's in the same box with the BCM (as well as 61-Battery Management)
I'd expect it to be similar as in T5.1 - here -->
PS. In the T6 BCM there is also a good bunch of adaptation channels which possibly need to be transferred too.
smirnoffrules
C?ID=269658
ok perfect thanks , that sounds like where lm going wrong
smirnoffrules
C?ID=269658
that sorted the door opening but have a problem after programming remotes , they both work but lock signals to central locking and hazards flash but doest lock doors , its like it thinks a door is open , the coding is the same in all units
, exactly the same options inputted , with old bcm remote locks fine ?
iichel
Eindhoven, NB, NL
C?ID=284912
Scan with the new BCM please
smirnoffrules
C?ID=269658
l did scan , l think this is after l put all the same codes in the 3 units
Sunday,25,July,2021,10:14:20:42713
Scan: 01 03 04 09 10 15 17 19 25 56 5F 77 0B
VIN: WV1ZZZ7HZGH129480   Mileage: 164390km-102147miles
03-ABS Brakes -- Status: Not registered 0011
04-Steering Angle -- Status: Not registered 0001
10-Park/Steer Assist -- Status: Not registered 0011
15-Airbags -- Status: Not registered 0001
56-Radio -- Status: Not registered 0001
5F-Information Electr. -- Status: Not registered 0011
77-Telephone -- Status: Not registered 0001
8224 - Databus
                    Reset counter: 0
                    Mileage: 164373 km
                    Date: 2021.07.23
                    Time: 12:21:06
   Coding: 01
332644 - Databus
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:27
332660 - Databus
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:27
117060 - Databus
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:27
   Revision: B9080001    Serial number: 0771 342170086
   Shop #: WSC 18752 008 00032
   Coding: 1400B0
   Coding: 0400A0
                    Reset counter: 0
                    Mileage: 164391 km
                    Date: 2021.07.25
                    Time: 10:11:17
   Coding: 10800A
                    Reset counter: 171
                    Mileage: 163570 km
                    Date: 2021.05.26
                    Time: 18:21:59
   Coding: 460B010100
                    Reset counter: 0
                    Mileage: 164382 km
                    Date: 2021.07.24
                    Time: 09:56:02
          U101F 00 [009] - -
                    Reset counter: 0
                    Mileage: 164391 km
                    Date: 2021.07.25
                    Time: 10:12:22
12605440 - Databus
                    Reset counter: 21
                    Mileage: 164382 km
                    Date: 2021.07.24
                    Time: 10:24:08
   Revision: B9080001
   Coding: 042305
                    Date: 2021.07.23
                    Time: 12:20:56
13762560 - Databus
          U1200 00 [008] - Defective
                    Reset counter: 21
                    Mileage: 164382 km
                    Date: 2021.07.24
                    Time: 09:36:53
13762816 - Databus
                    Reset counter: 21
                    Mileage: 164373 km
                    Date: 2021.07.23
                    Time: 12:19:31
Address 56: Radio
10 Faults Found:
6705 - Databus
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:27
6725 - Databus
                    Reset counter: 21
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:27
6700 - Databus
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:27
6702 - Databus
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:27
6704 - Databus
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:27
6706 - Databus
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:27
6708 - Databus
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:27
6713 - Databus
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:27
6714 - Databus
                    Mileage: 163649 km
                    Date: 2021.06.01
                    Time: 00:17:27
          U1111 00 [009] - -
                    Reset counter: 176
Address 77: Telephone
End----------(Elapsed Time: 01:05, VBatt start/end: 12.6V/12.2V)-----------
VWT6
Finland
C?ID=295527
You transferred also the adaptations?
Perhaps could just doublecheck the following.
09- Measurement Blocks
Do Measurement Blocks(-Field) 005-1, 005-2, 005-3, 005-4 report all doors are closed?​
The hatches in 006-1, 006-2, 006-3 - all closed, status of door unlock/switch in block 006-4 - Not oper.?​
Door statuses in 007-1, 007-2, 007-3, 007-4 - Unlocked, Locked?​
Remote commands in 015-1 - do you get Lock/Unlock when buttons on remote are pressed?​
iichel
Eindhoven, NB, NL
C?ID=284912
Was it a brand new BCM? because your installation list looks a bit... wrong and you probably left factory mode (channel 99 in bcm adaptations) on
smirnoffrules
C?ID=269658
he got it from ebay , he was told it was new , l change coding and took pictures of every page on old and the same on new , where is this 99 channel ?
smirnoffrules
C?ID=269658
l copied them all over , in activations l can make door lock , the display shows all door open when open and all doors closed then closed
smirnoffrules
C?ID=269658
l will have to go back out to him , the other problem his is daytime running light are not on ,
this is only option now , but lm sure his old bcm which drl they work and theres an option to turn on
this is off utube but lm sure l seen option like this before
iichel
Eindhoven, NB, NL
C?ID=284912
Okay let's not do anything silly like having a look at the golf mk6 BCM on youtube. Or look at a T4 forum for a T6.
Step 1: fix your gateway installation list (tick all that is installed, this is a mess)
Step 2: put in the old bcm and make a list of all the adaptation channels
Step 3: put back the new BCM and put in the values of the adaptations of the new BCM
Step 4: make an autoscan with the new bcm and the corrections above, clear all DTCs and make another scan
Step 5: check the closing status of the bonnet as well
Step 5: post the most recent scan here. it shouldn't have barely any to no intermittent errors anymore and the gateway installation list at the top of your scan should not mention 'not registered' anymore.
smirnoffrules
C?ID=269658
ok , l will get car to my garage , he lives 40 miles away and car isnt tax or moted , l did take pictures of every page from old bcm and put all the same adaptations in new one one tho ? but as l say l think many have been there before me ,
These are all the pages from the original bcm , l have copied all these into replacement and same with battery and can network module https://easyupload.io/bu7ekx sorry picture at on the side
