Error 22: condition not met/wrong sequence or something like that
coconutaudi
Kuala Lumpur, Malaysia
C?ID=345326
I have this problem with my Headlight range control module (j431) for years now. The malfunction light for this control module will always be on no matter what. I did asked the forum about the issue but did not solved it. I replaced my headlights a few months ago since the internal wirings were damaged due to corrosion caused by water ingress. Even after I’ve replaced the headlights the control module problem is still there. Recently when doing a scan I’ve notice that one of the DTC in the headlight range module (address 55) is that the module is not coded. I tried to program the module with the code from my previous saved scan but was unable to do so. The prompt that came up was Error 22: condition not met/wrong sequence or something like that. What does that mean? How do I get to recode the control module. At the moment, the driver side of the headlight could not perform the usual AFS left right and up down movement of the headlight projector when turning on the ignition. That is the only problem with the headlight now. Hope these information will help. Thank you.
Wednesday,14,July,2021,18:31:29:34670
VIN: WAUZZZ4G9BN031310   License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 42 44 46 52 53 55
          56 5F 62 6C 72 85 8F 90
VIN: WAUZZZ4G9BN031310   Mileage: 192572km-119658miles
Address 01: Engine (J623-CGWB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 907 551     HW: 4H0 907 551
   Component: 3.0l V6 TFSI  H05 0007
   Revision: --H05---
   Coding: 0A250034052701020000
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM30TFS0214G0907551 002010
   ROD: EV_ECM30TFS0214G0907551_002.rod
   VCID: 6695B5FFE8EFBBDB15F-8032
6429 - Oxygen (Lambda) Sensor B1 S2
          P0136 00 [096] - Malfunction in Circuit
                    Mileage: 192399 km
                    Date: 2021.07.02
                    Time: 18:24:15
                    Engine RPM: 1962.00 /min
                    Vehicle speed: 116 km/h
                    Coolant temperature: 95 °C
                    Intake air temperature: 47 °C
                    Voltage terminal 30: 13.304 V
                    Engine speed: actual: 1952 /min
                    MAF_ENVD: 103.49411 mg/stroke
                    Coolant temperature (unfiltered): 95.25 °C
                    Engine: operating status: PUC
                    Engine load: 0.000000 %
                    STATE_LS_ENVD[1]: 4
6368 - Bank 2: CMP Sens 2 (G163) / Engine Speed Sensor (G28)
          P0018 00 [032] - Incorrect Correlation
                    Mileage: 192314 km
                    Date: 2021.06.29
                    Time: 10:28:36
                    Engine RPM: 678.00 /min
                    Normed load value: 13.3 %
                    Coolant temperature: 87 °C
                    Intake air temperature: 39 °C
Voltage terminal 30: 13.710 V
Unlearning counter according OBD: 37
Engine speed: actual: 672 /min
MAF_ENVD: 108.94117 mg/stroke
Calculated oil temperature: 7B
Engine: operating status: IS
ENVD_CAM_IN_2: 0
Battery voltage: 13.914063 V
PartNoSW:4G0927156M HW:0B5927156F Component: 0B5 30TFSIRdW H10 0024
Revision: --H10--- Serial number: 0000000785 Coding: 000001
   Shop #: WSC 04940 001 00001
   ASAM Dataset: EV_TCMDL501 A02196
   ROD: EV_TCMDL501.rod
   VCID: 363525BFF8CF0B5B65F-8062
   Part No SW: 4G0 907 379     HW: 4G0 907 379
   Component: ESP PREMIUM   H08 0190
   Coding: 44A687002265E100DB00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 003013
   ROD: EV_ESPPremiAU57X_003.rod
   VCID: 6E85CDDFC01F739B6DF-803A
0631 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 65
                    Mileage: 192506 km
                    Date: 2021.07.08
                    Time: 14:29:56
                    VzRef: 45
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 26
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 32
Uz: B4
   Part No SW: 4H0 907 064 AP    HW: 4H0 907 064 AP
   Component: BCM2 2.0      H24 0217
   Coding: 05B82F00000000000000
   VCID: 77ABE8BBBFC53253BE9-8022
   Subsystem 2 - Part No SW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2311000097450009
HW: 4H0 905 852 B
PartNoSW:4G0820043K HW:4G0820043K Component: KLIMA 4 ZONEN H11 0056
Serial number: 06051100040574
Coding: 6621007824
   ASAM Dataset: EV_AirCondiComfoUDS 002029
   VCID: 270BF8FB2F6562D3EE9-8072
0378 - Coolant Circulation Pump
          B10D0 04 [008] - Internal System Fault
                    Reset counter: 65
                    Mileage: 192282 km
                    Date: 2021.06.23
                    Time: 18:12:22
                    Voltage terminal 30: 13.76 V
                    Outside temperature: 34.0 °C
                    Inside temperature: 27.81 °C
0379 - Supply Voltage Terminal 30 for Coolant Pump
          B11D5 01 [009] - Electrical Failure
                    Fault Frequency: 16
                    Reset counter: 25
                    Mileage: 192271 km
                    Date: 2021.06.23
                    Time: 15:48:21
                    Voltage terminal 30: 13.85 V
                    Outside temperature: 49.5 °C
                    Inside temperature: 38.45 °C
PartNoSW:4H0907063N HW:4H0907063F
Component: BCM1 2.0 H12 0092
Revision: 20012002 Serial number: 00000001044197
Coding: 0200201050B49FE0C181008380001908CF9DC3082F080101000008402100 Shop #: WSC 02391 785 00200
   VCID: 33331CABEB3D1E73421-8066
   Subsystem 1 - Part No SW: 4G2 955 119
1KX-955-119.CLB
   Component: WWS57X 110404  H35 0051
   Serial number:         110407090850
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8K0 955 559
8K0-955-559.CLB
   Component: RLS  H04 0003
   Serial number: 11418017
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 22 04 2011  00000235
   Subsystem 4 - Part No SW: 4H0 907 658
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 5228C6A5000000000001
HW: 4G8 955 119 A  Labels:
HW: 8K0 955 559
 HW: 4G0 941 531 E
HW: 4H0 907 658
Labels:
                    Fault Status: 00101100
                    Reset counter: 65
                    Mileage: 192571 km
                    Date: 2021.07.08
                    Time: 18:09:00
                    Reset counter: 65
                    Mileage: 192571 km
                    Date: 2021.07.08
                    Time: 18:09:00
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 22
                    Mileage: 192314 km
                    Date: 2021.06.29
                    Time: 10:22:00
PartNoSW:4H0919475J HW:4H0919475C Component: PARKHILFE ACC H07 0032
Revision: 11001001 Serial number: 55901107004778 Coding: 300306
   Shop #: WSC 00097 210 98728
   ASAM Dataset: EV_EPHVA18AU57X0000 001002
   ROD: EV_EPHVA18AU57X0000_001.rod
   VCID: 392F2E83C9D1E42388D-806C
PartNoSW:4H0959655C HW:4H0959655C Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG002BRPH Coding: 30323436313330303631554A305234473053 Shop #: WSC 02391 785 00200
   Serial number: 3575HRB404T0HM766GDR
   Serial number: 3585HRB405H0H0LUC8R2
   Serial number: 3515JRB405D0H4DU9P4N
   Serial number: 3525JRB405F0G944N0G$
   Serial number: 3554VRB40630GR36HOS5
   Serial number: 3564VRB405D0GR36IHD.
PartNoSW:4G0953568A HW:4G0953568A Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20110505000939 Coding: 000034
   VCID: 303913A71A2B256B3F3-8064
   Subsystem 1 - Part No SW: 4G0 951 528 A
   Component: E221 - MFL  H07 0009
HW: 4G0 951 528 A
PartNoSW:4G8920981A HW:4G8920981A Component: TBenGb H34 0312
Revision: 19100074 Serial number: 658020411593026 Coding: 33A709000B012600010000
   ASAM Dataset: EV_RBD4K 004033
   ROD: EV_RBD4K_AU57.rod
   VCID: 313F16A311A12C6330D-8064
PartNoSW:4G0907468C HW:4G0907468A Component: J533--Gateway H08 0204
Revision: -------- Serial number: 00000000141378 Coding: 00CD073000
   ROD: EV_GatewUDS_AU57.rod
   VCID: 303913A71AAB256B3F3-8064
   Subsystem 1 - Part No SW: 8X0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650387009
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663
   Serial number: 11130001538021200181
HW: 8X0 915 181
HW: 8K0 959 663
PartNoSW:4G0919158C HW:4G0919158C Component: KLIMA FOND H07 0056
Serial number: 06051100040012
Coding: 02
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
   VCID: 2F3B10DB07953A93269-807A
0026 - Motor for Rear Left Upper Body Vent
          B10D3 21 [008] - Signal Amplitude Too Low
                    Reset counter: 62
                    Mileage: 192314 km
                    Date: 2021.06.29
                    Time: 10:03:34
                    Voltage terminal 30: 12.18 V
                    Outside temperature: 27.5 °C
                    Left Rear Upper Body Vent Motor-Act.val.: 9849
                    Left Rear Upper Body Vent Motor-Target value: 9849
                    Left Rear Upper Body Vent Motor-Stop open: 11400
                    Left Rear Upper Body Vent Motor-Stop closed: 10000
   Component: MEM-FS        H03 0153
   Revision: AA000000    Serial number: 00000006129999
   Coding: 00781B0000006001000001010101102030303232203232
PartNoSW:4G0907637B HW:4G0907637B Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA4200UA850 Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 2D070AD30D994883145-8078
PartNoSW:4G8959793C HW:4G8959793A Component: TSG FA H04 0210
Revision: -------- Serial number: -------------- Coding: 011F16205E01628002080002
   Shop #: WSC 02312 785 00200
   VCID: 40D94367AA8BB5EBCF3-8014
PartNoSW:4G0909144L HW:4G0909144G Component: RCEPS H33 0010
Revision: 00001000 Serial number: 0010073316
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D19AF14A7177B497-8066
   Revision: 00002001    Serial number: 0149428872
   Coding: 011B0E2200B9048183300804080100000000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 19
                    Mileage: 192271 km
                    Date: 2021.06.23
                    Time: 15:48:34
PartNoSW:4G8959792C HW:4G8959792A Component: TSG BF H04 0210
   VCID: 3FDB409BD775CA13B69-806A
PartNoSW:4H0907801E HW:4H0907801A Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000070722 ASAM Dataset: EV_ParkiBrake 001022
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2A0D01CF3C775FBBF17-807E
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
PartNoSW:4H4907357A HW:4H4907357A Component: ....AFS13.... H01 0012
Serial number: 110502-0004-033
Coding: 0000020000020000
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
266752 - Control module not coded
          U1013 00 [137] - -
          [Steuergeraet nicht codiert]
                    Reset counter: 22
                    Mileage: 192314 km
                    Date: 2021.06.29
                    Time: 10:21:35
530180 - Local Data Bus
          U10BA 00 [137] - No Communication
                    Fault Frequency: 30
                    Reset counter: 25
                    Mileage: 192314 km
                    Date: 2021.06.29
                    Time: 10:21:36
   Part No SW: 4G0 035 056 A    HW: 4G0 035 056
   Component: Radio U STD   H52 0050
   Revision: AB001007    Serial number: 051EY0B7516476
   Coding: 010003020100000001
   VCID: 1F1BE01B77B5AA13969-804A
   Part No SW: 4G0 035 670 B    HW: 4G0 035 670
   Component: H-BNT-EU      H46 0239
   Revision: --------    Serial number: 428EX0B7514227
   Coding: 050101000003E1EF45108B3E000000030000010000000000
   VCID: 221DE9EF44C787FBB97-8076
   Subsystem 1 - Part No: 8R0 060 884 N
   Component: EUR 2011  1205
   Subsystem 2 - Part No SW: 4G0 919 605 A
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDB1300QPJ1
   Subsystem 3 - Part No SW: 4G2 919 612 L
   Component: E380 BDT C7  H08 0120
   Serial number: 90349KDT0007U
   Subsystem 4 - Part No: 8R0 060 961 A
   Component: CD-Database  2712
HW: 4G0 919 605 A
HW: 4G2 919 612 L
PartNoSW:4G8959795C HW:4G8959795A Component: TSG HL H03 0210
Revision: -------- Serial number: -------------- Coding: 010F14204001628002080002
   VCID: 42DD496FA487A7FBD97-8016
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0050
   Revision: --H04---    Serial number: 525 PA8J14F0S1
   Coding: 1020004
   VCID: 2517F2F359E970C3DC5-8070
PartNoSW:4G8959795C HW:4G8959795A Component: TSG HR H03 0210
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H24 0034
   Coding: 64040000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 6597B2F315E9B0C31C5-8030
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Coding: 00060000031F030000030800424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 6FBBD0DBC7157A93669-803A
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 70B9D3A7DA2B656B7F3-8024
End----------(Elapsed Time: 02:14, VBatt start/end: 13.3V/13.3V)-----------
It's likely due to this this fault:
The module can't communicate with something on a local bus and thus, "Conditions not correct".
coconutaudi
C?ID=345326
I didn’t think about that as the vcds can communicate with the module. Thank you Uwe, something for me to start on.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
With the output stages properly communicating, your output should look similar to this...
Address 55: Xenon Range (J431)
   Part No SW: 4H4 907 357 A    HW: 4H4 907 357 A
H02 0008
H02 0008
...which means, your J431 isn't communicating with the output stages which are located at the headlights themselves.
coconutaudi
C?ID=345326
Thank you Sebastian, I guess I have to get the wiring diagram to determine which are the can bus wires which go from the module to both headlights.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Yes, a wiring diagram would help. :) I am not certain that this would be CAN, it is likely to be a single wire LIN databus.
coconutaudi
C?ID=345326
Every input is valuable Sebastian, thanks again. Now to get my hands on the diagram which can show me the data wire.
coconutaudi
C?ID=345326
This is the J431 wiring diagram that I have:
There are 2 Can Bus Wires at pin 2 and 3 which go to J533 and finally to J519. I cannot see any LIN bus wire though. Wires in Pins 16, 17, 18 and 19 go to the left headlight range control motor while wires in pins 15, 20, 21, 22 go to the right headlight range control motor. I don’t know what pins 5 and 9 are all about.
Those are pins (presumably grounds) that connect to the shielding around the other four wires that go to the headlights.
