2011 Jetta Sportwagen ABS Coding Help (MK60EC1)
engineofgod
Columbus, OH, USA
C?ID=450537
My abs module recently lost its coding due to, I think an instrument cluster repair, but mostly out of my ignorance about VW's. I am now just starting to learn about them. So from reading the wiki, i have to post a thread on how to get the coding calculated.
Thursday,22,July,2021,18:29:29:19351
Dealer/Shop Name: Jacob
VIN: 3VWPL7AJXBM649145   License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 72 77
VIN: 3VWPL7AJXBM649145   Mileage: 206300km-128188miles
04-Steering Angle -- Status: Sporadic communication error 1000
   Part No SW: 03L 906 019 DB    HW: 03L 906 019 DA
   Component: R4 2,0L EDC G000AG  9971
   Revision: 12H13---    Serial number:
   Coding: 0050078
   Shop #: WSC 00066 000 00000
   VCID: 6E85C76C3C93BC0B6DF-803A
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 003 - Implausible Signal - MIL ON
                    Fault Status: 11100011
                    Mileage: 205578 km
                    Date: 2015.12.07
                    Time: 00:15:60
                    Voltage: 12.08 V
                    Lambda: 6.3 %
                    Lambda: 11.8 %
                    Bin. Bits: 00000000
                    Voltage: 0.304 V
               U0155 - 003 -  - Intermittent
                    Fault Status: 00100011
                    Mileage: 205578 km
                    Temperature: 27.0°C
                    Voltage: 12.08 V
                    Bin. Bits: 00000000
                    Torque: 219.0 Nm
                    Temperature: 47.7°C
008200 - Intake Manifold Flap; Bank 1
               P2008 - 000 - Electrical Malfunction - Intermittent - MIL ON
                    Fault Status: 10100000
                    Fault Frequency: 255
                    Mileage: 205578 km
                    Date: 2015.12.08
                    Time: 17:26:08
                    RPM: 2116 /min
                    Speed: 29.0 km/h
                    Load: 43.5 %
                    Load: 75.3 %
                    Lambda: 99.4 %
                    Mass Air / Rev.: 510.0 mg/str
                    Temperature: 23.4°C
001025 - EGR System
               P0401 - 001 - Insufficient Flow - Intermittent - MIL ON
                    Fault Status: 10100001
                    Fault Frequency: 8
                    Mileage: 205860 km
                    Date: 2015.12.09
                    Time: 15:23:49
                    RPM: 1817 /min
                    Speed: 91.0 km/h
                    Voltage: 13.76 V
                    Load: 95.7 %
                    Load: 100.0 %
                    Mass Air / Rev.: 375.0 mg/str
                    Mass Air / Rev.: 405.0 mg/str
Readiness: 1 3 0 0 0
   Part No SW: 02E 300 052 G    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2267
   Revision: 05151112    Serial number: 00001009151239
   VCID: 1869C1B46E9712BB573-804C
18036 - Powertrain Data Bus
            P1628 - 000 - Missing Message from Steering Angle Sensor - Intermittent
                    Mileage: 206304 km
                    Date: 2015.12.13
                    Time: 18:16:56
   Part No SW: 1K0 907 379 BC    HW: 1K0 907 379 BC
   Component: ESP MK60EC1   H30 0106
   Revision: 00H30001
   VCID: 74B1D5045EBF96DB9BB-8020
01486 - System Function Test Activated
                    Reset counter: 36
                    Mileage: 206304 km
                    Date: 2015.12.13
                    Time: 18:14:08
                    Count: 16387
                    Count: 12
                    Count: 4096
                    Count: 320
                    Count: 43264
                    Count: 5888
                    Reset counter: 36
                    Mileage: 206304 km
                    Date: 2015.12.13
                    Time: 18:08:17
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 195
                    Count: 43776
                    Fault Status: 01100101
                    Reset counter: 36
                    Mileage: 206304 km
                    Date: 2015.12.13
                    Time: 18:08:17
                    Count: 2
                    Count: 12
                    Count: 4096
                    Count: 279
                    Count: 43776
                    Reset counter: 36
                    Mileage: 206304 km
                    Date: 2015.12.13
                    Time: 18:08:17
                    Count: 7
                    Count: 12
                    Count: 4096
                    Count: 295
                    Count: 43776
                    Reset counter: 36
                    Mileage: 206304 km
                    Date: 2015.12.13
                    Time: 18:08:17
                    Count: 2
                    Count: 12
                    Count: 4096
                    Count: 270
                    Count: 43776
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Revision: 00009001
   Coding: 0000001002
   Shop #: WSC 00066 000 00148
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 75B7E80055458FD3AC5-8020
   Part No SW: 5K0 937 084 E    HW: 5K0 937 084 E
   Component: BCM PQ35 B    011 0035
   Revision: BG011001
   Coding: 2D380E1A902F3EC4008800816000004401000086535D8560648020000040
   VCID: 343115041E3FD6DB5BB-8060
   Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 17111  21  0512
   Coding: 009795
                    Reset counter: 76
                    Mileage: 206304 km
                    Date: 2015.12.13
                    Time: 18:16:56
                    Voltage: 12.10 V
   Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
   Component: AirbagVW10G   021 0706
   Serial number: 003C4R014EP4
   Coding: 00003044
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 392F243039DD2BB388D-806C
   Subsystem 1 - Part No SW: 1KM 959 339     HW: 1KM 959 339
   Component: BF-Gewichtss.  007 0001
   Serial number: ---0000R--0005GZEG00
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3572MSME241A6257ZZZU
   Subsystem 3 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3582MSME193A6257ZZZ.
   Serial number: 3511HSME47336324ZZZD
   Serial number: 3521HSME7D286324ZZZR
   Serial number: 35527SME5A0B4B23ZZZM
   Serial number: 35627SME5C094C23ZZZO
   Component: Lenks.Modul   007 0080
   Revision: --------    Serial number:  90422JJ5000W5
   Coding: 188A140000
   Shop #: WSC 00066 000 00158
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 76B5EF0C484384CBA5F-8022
   Component: E221__MFL-TAS  H07 0013
   Serial number: 0084550
   Coding: 820000
   Part No SW: 5K0 920 971 C    HW: 5K0 920 971 C
   Component: KOMBI         H23 0206
   Revision: X0023007    Serial number:
   Coding: 270F01
   ASAM Dataset: EV_KombiUDSMM9RM10 A04203
   ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
   VCID: 2F3B1A68F799F503269-807A
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 5603
   Revision:   H27       Serial number: 14111001211156
   Coding: ED807F0600160200002002
   VCID: 6D87C06031954713545-8038
                    Fault Status: 00110100
                    Reset counter: 76
                    Mileage: 206304 km
                    Date: 2015.12.13
                    Time: 18:16:56
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1225223RACYW06
   Coding: 0000002
   VCID: 7EA5F72C6CF3CC8BFDF-802A
   Part No SW: 5K0 953 234     HW: 5K0 920 971 C
   Component: IMMO          H23 0206
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01200
   VCID: 6A8DCB7C0CFB502B317-803E
   Part No SW: 3C0 959 701 B    HW: 3C0 959 793
   Component: TUER-SG FT    002 0307
   Revision: 13101005    Serial number: 0001503959
   Coding: 0004B5
   Shop #: WSC 01383 790 50316
   ROD: EV_DCU42BroseDriveSide.rod
   VCID: 270BF248DF69AD43EE9-8072
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  006 1401
   Serial number: 00000005193123
   Coding: 000490
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 313F1C10ED2DE3F330D-8064
                    Fault Status: 11100101
                    Mileage: 206304 km
                    Date: 2015.12.13
                    Time: 18:08:16
                    Battery Volts: 12.2 V
                        DD
                    Temperature: 50.0°C
                    Count: 3
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
   Part No SW: 3C0 959 702 B    HW: 3C0 959 792
   Component: TUER-SG BT    002 0307
   Revision: 15101005    Serial number: 0001481788
   Coding: 0004B4
   ROD: EV_DCU52BrosePasseSide.rod
   VCID: 2809F174D277A23BE73-807C
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  006 1401
   Serial number: 00000005191940
   Coding: 000490
   Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
   Component: Radio Prem-8  H13 0043
   Revision: -----26S    Serial number: VWZ4Z7K3126905
   Coding: 0500040004
   VCID: 619FAC50F14D1373E0D-8034
                    Reset counter: 36
                    Mileage: 206304 km
                    Date: 2015.12.13
                    Time: 18:08:58
   Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668526161
   Coding: 0A00000000010100
   ASAM Dataset: UHVNA A01007
   ROD: EV_UHVNA_A01_VW25.rod
   VCID: 323D131CE4ABD8EB497-8066
End----------(Elapsed Time: 01:19, VBatt start/end: 12.2V/12.2V)-----------
Thanks for the scan and history. As long as 3VWPL7AJXBM649145 is both the correct VIN, and the VIN shown in addresses 01, 17 and 25 as per the notes here, the factory condition 03-ABS coding should have been:
114B600C49260003880C06E8921E0042B70000
Copy and Paste that directly into the New Coding and enter non zero WSC/Importer/Equipment numbers before clicking Do It. After the coding is accepted, complete the first 4 Basic Setting operations on this page before exiting the module:
The Replacement section at the bottom of that page should be helpful and we have a video here:
engineofgod
Columbus, OH, USA
C?ID=450537
Thank you very much!! Is there a way to calculate the long codes myself or does it require special software/skills?
MK60EC1 codings are something of a black art...
