MK7 Euro Tail lights....
DJM
C?ID=54909
Looking for help on sorting the adaption of adding Euro LED tail lights with harnesses installed.
I have tried several times and still get the same result.
the right Inner light has Fog on and no other lights.
Friday,23,July,2021,13:27:02:33028
VCDS Version: 21.3.0.0 (x64)  HEX-NET2 CB: 0.4544.4
Dealer/Shop Name: Double J Motorwerks
VIN: 3VW447AU7HM065269   License Plate:
Mileage: 45273km-28131mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 32 42 44 47 52 55 5F 75 A9
VIN: 3VW447AU7HM065269   Mileage: 45273km-28131miles
Address 01: Engine (J623-CXCB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 L    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091D00124424002F1000
   Shop #: WSC 00066 790 00218
   ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
   ROD: EV_ECM20TFS0205G0906259L.rod
   VCID: 3720413BCFC594F37E9-8062
   Part No SW: 0D9 300 020 N    HW: 02E 927 770 AS
   Component: DQ250-6V MQB  H54 5004
   Revision: 06454104    Serial number: TFK01703142362
   ROD: EV_TCMDQ250021.rod
   VCID: 20128A677A4BF34BAF3-8074
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AQ    HW: 5Q0 614 517 AF
   Component: ESC           H62 0400
   Revision: 00000000    Serial number: 51167000000159
   Coding: 01FA6BA1542609718079020640CC6880D62A90014002163600435051C009430000000012121212B835351919323200
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
   ROD: EV_Brake1UDSContiMK100ESP_036.rod
   VCID: 0052EAE7DA8B134B8F3-8054
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0437321022
   Coding: 032C0C
   VCID: 3B285D0BF3EDB0939A1-806E
   Part No SW: 5GM 907 426 E    HW: 5GM 907 426 E
   Component: AC Manuell    H03 1801
   Revision: 00001K04
   Coding: 00020004200100000000000010000002
   Shop #: WSC 12345 123 61029
   VCID: 4AC608CFAC37191B117-801E
          B10CD 00 [008] - -
                    Reset counter: 247
                    Mileage: 45273 km
                    Date: 2021.07.22
                    Time: 14:26:18
                    Voltage terminal 30: 11.2 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up lamp: On
   Part No SW: 5Q0 937 087 AN    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 032 0223
   Revision: --------    Serial number: C864050417011Q
   Shop #: WSC 00066 790 00200
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017.rod
   VCID: 0740F1FBFFA52473CE9-8052
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    170305  043 0551
   Serial number: 97022066170321233416
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  042 0105
   Serial number: S7Y17M03D27H07M15S12
   Coding: 00A8DD
   Sunroof control module:
   Subsystem 3 - Part No SW: 5GD 959 591 A    HW: 5GD 959 591 A
   Component: J245 PS60.006  H07 0170
   Serial number: 03690806871312161925
   Coding: 181803
   Serial number: 003GCR07UWFD
   VCID: 47C031FBBF25E4730E9-8012
   Serial number: IBH00000000000729QVZ
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 000 704 17
   Serial number: 3570000000050B388029
   Subsystem 3 - Part No SW: -----------    HW: 480 000 704 17
   Serial number: 35800000000C722C622I
   Subsystem 4 - Part No SW: -----------    HW: 480 400 704 17
   Serial number: 3510001AD257C44392A5
   Subsystem 5 - Part No SW: -----------    HW: 480 400 704 17
   Serial number: 3520001C3257C423C13Y
   Subsystem 6 - Part No SW: -----------    HW: 480 402 603 17
   Serial number: 3550002B924F3845B236
   Subsystem 7 - Part No SW: -----------    HW: 480 402 603 17
   Serial number: 3560002B924F38429388
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 16041704220757
   Coding: 0410
   Part No SW: 5G1 920 856 B    HW: 5G1 920 856 B
   Component: KOMBI         344 8311
   Coding: 0BAD091AA9804F0502086A001000000000000000
   VCID: 2D0C63533D992E23145-8078
          U1110 00 [008] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Reset counter: 234
                    Mileage: 44769 km
                    Date: 2021.06.18
                    Time: 14:31:40
   Component: GW MQB High   518 5286
   Serial number: 23051700840570
   Coding: 0101000870085900FB00002B1C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07026
   ROD: EV_GatewNF_VW37.rod
   VCID: 2F30795B37955C33269-807A
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29170000085820027035
   Coding: 31FFFF
   Revision: 00000000    Serial number: 17000094341004
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 343A7637DEB37FEB5BB-8060
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00016.01.17
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   Serial number: 020517060508OH
   Coding: 003E13200400020000000000
   VCID: 43D825EB8B1DC853D21-8016
   Serial number: 00000000000006346815
   Coding: 011000
   Part No SW: 3QM 909 144     HW: 3QM 909 144
   Coding: 8102
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 0C4ACED7E6C3472BE3B-8058
11776 - Supply voltage
          [Warnung vor dauerhaft zu geringer Versorgungsspannung Anzeige von Unterspannung]
                    Reset counter: 199
                    Mileage: 45273 km
                    Date: 2021.07.22
                    Time: 15:35:34
                    Motor status: 00
                    Supply voltage: 10.50 V
                    Temperature: 42.0 °C
                    KFC: 2E
                    KFA: 00 00
                    Freeze frame conditions: 21
                    uioUdNotFilt_xdu16: 10.77 V
                    uAdSensI_SwitchedKl30_xdu16: 10.77 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
   Revision: 00000001    Serial number: VWZ8Z1HBA03CH52
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 6D8CA353FD19EE23545-8038
12 Faults Found:
0512 - Rear Right Treble Speaker
          B1068 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 1: Unterbrechung (AC-Diagnose)]
                    Fault Frequency: 9
                    Reset counter: 206
                    Mileage: 44693 km
                    Date: 2021.06.10
                    Time: 13:19:57
                    Voltage terminal 30: 12.7 V
0517 - Rear Left Treble Speaker
          B1066 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 2: Unterbrechung (AC-Diagnose)]
                    Fault Frequency: 9
                    Reset counter: 206
                    Mileage: 44693 km
                    Date: 2021.06.10
                    Time: 13:19:57
0522 - Double Bass Speaker 2; Front Right
          B1348 13 [009] - Open Circuit
                    Fault Frequency: 9
                    Reset counter: 206
                    Mileage: 44693 km
                    Date: 2021.06.10
                    Time: 13:19:57
0527 - Double Bass Speaker 1; Front Right
          B1346 13 [009] - Open Circuit
                    Fault Frequency: 9
                    Reset counter: 206
                    Mileage: 44693 km
                    Date: 2021.06.10
                    Time: 13:19:57
0532 - Rear Right Bass Speaker
          B1067 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 5: Unterbrechung (DC-Diagnose)]
                    Fault Frequency: 9
                    Reset counter: 206
                    Mileage: 44693 km
                    Date: 2021.06.10
                    Time: 13:19:57
0537 - Rear Left Bass Speaker
          B1065 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 6: Unterbrechung (DC-Diagnose)]
                    Fault Frequency: 9
                    Reset counter: 206
                    Mileage: 44693 km
                    Date: 2021.06.10
                    Time: 13:19:57
0560 - Front Right Treble Speaker
          B1064 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 7: Unterbrechung (AC-Diagnose)]
                    Fault Frequency: 9
                    Reset counter: 206
                    Mileage: 44693 km
                    Date: 2021.06.10
                    Time: 13:19:57
0565 - Loudspeaker 1 in Double-Subwoofer
          B130C 13 [009] - Open Circuit
                    Fault Frequency: 9
                    Reset counter: 206
                    Mileage: 44693 km
                    Date: 2021.06.10
                    Time: 13:19:57
0570 - Loudspeaker 2 in Double-Subwoofer
          B130D 13 [009] - Open Circuit
                    Fault Frequency: 9
                    Reset counter: 206
                    Mileage: 44693 km
                    Date: 2021.06.10
                    Time: 13:19:57
0575 - Double Bass Speaker 1; Front Left
          B1345 13 [009] - Open Circuit
                    Fault Frequency: 9
                    Reset counter: 206
                    Mileage: 44693 km
                    Date: 2021.06.10
                    Time: 13:19:57
0580 - Double Bass Speaker 2; Front Left
          B1347 13 [009] - Open Circuit
                    Fault Frequency: 9
                    Reset counter: 206
                    Mileage: 44693 km
                    Date: 2021.06.10
                    Time: 13:19:57
0585 - Front Left Treble Speaker
          B1061 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 12: Unterbrechung (AC-Diagnose)]
                    Fault Frequency: 9
                    Reset counter: 206
                    Mileage: 44693 km
                    Date: 2021.06.10
                    Time: 13:19:57
   Serial number: 2404170605000F
   Coding: 003E13200000020000000000
   VCID: 42D620EF9407C15BD97-8016
   Serial number: 00000000000006365517
   Coding: 091000
589845 - Window Regulator; Front Passenger side
          B1320 F5 [008] - Supply Voltage too Low
                    Reset counter: 247
   Coding: 021A01010B000400
   VCID: 40D22AE79A0BD34BCF3-8014
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
   Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
   Component: MU-S-S-US     710 0753
   Coding: 027300000000000051220002001808009F0203F40120010002
   ROD: EV_MUStd4CDELP_VW26.rod
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H53 1031
   Serial number: VWZ8Z9TJW02FPJ
          B11CF 53 [009] - Deactivated
                    Reset counter: 168
                    Mileage: 44726 km
                    Date: 2021.06.12
                    Time: 13:11:25
                    Voltage terminal 30: 12.3 V
                    SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
                    SDARS_tuner_status_2-Audio Signal: available.
                    SDARS_tuner_status_2-Antenna current: 143 mA
                    SDARS_tuner_status_2-Reception quality: optimum_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
6720 - Rear View Camera
          B1102 31 [008] - No Signal
                    Reset counter: 239
                    Mileage: 45171 km
                    Date: 2021.07.16
                    Time: 10:57:22
                    Voltage terminal 30: 13.9 V
   ROD: EV_OCULowMQB.rod
   Component: SAS-GEN 2     H06 0014
   Serial number: 170221200857
   VCID: 6B88AD4BC30DE0134A1-803E
End----------(Elapsed Time: 01:29, VBatt start/end: 12.4V/12.2V)-----------
@DJM: Hi
Pending a better response from someone who is more experienced with this retrofit on NAR cars - a seminal problem in answering your question is that the project is not OEM (by definition). Of course the OEM solution would be to install new wires in the car loom (back to the BCM) to control the extra LED lights in the EURO tails and to re-code the BCM to OEM settings.
As I'm sure you already know- the role of cross-wiring harness is to "create" unused wires by joining together lamps with the same function on both sides of the car (like the Brake-light and Parking Light). There are a couple of different ways to do this non-OEM task and the solution is specific to harness manufacturer - and it's specific to the original specs of the tails as factory fitted.
So:
  1. did you receive any coding instructions from the harness manufacturer that you can share?
  2. what coding changes did you make?
  3. what are the details of the harness?
  4. what type of tails were factory fitted to the car (incandescent, I assume)?
  5. Are the new EURO tails OEM?
  6. Have you made a BCM Admap that you can share?
  7. What exactly do you mean by "the right Inner light has Fog on and no other lights"?
PS: maybe this thread should be moved to "Retrofit"?
DJM
C?ID=54909
@DJM: Hi
So:
So glad that someone chimed in.
1. The coding instructions are from DAP.
2. The coding changes that DAP recommends.
3. These are UroTuning harnesses. (probably copies of DAP)
4 The car came with Incandescent tails.
5. The new tails are European OEM Cherry Red LED's w/FOGS
6. I havent made a "Admap"?
7. With them installed and the DAP coding applied, The Right Inner lamp assembly, the fog light is always on. ( with running lights and headlights, and brake lights)
I have VCDS and OBD11. OBD11 didnt have some of the DAP coding/adaptation channels so i used VCDS.
I will be honest. I dont work with computers all that much. Please be patient with me and I will try to keep up.
Thanks everybody!
@DJM: OK, you might need to share a copy of the DAP instruction (PM, or post here) and please provide a web link to the actual harness as well as the new tails.
I'm confused about the fog light being on the right-side on a NAR model car - shouldn't Yankee cars have this on the left side? Or do your new tails have fogs on both sides?
Clearly given that I live in the very deep south, my knowledge of NAR models ain't that flash, but my understanding of the DAP harness application to Yankee cars for the fog light function is that it requires mods to Leuchte26NSL. Is this the same in your instructions- for the fog light?
ONLY IF THE ANSWER IS "YES"- I pulled the following note from an ECS harness instruction-set on my MQB database about vehicles from your country.
There was a split in the middle of MY2015 which​
changed the channel for the rear side marker​
lights from Leutchte26NSL to Leutchte27NSL.​
The note then says:
If your vehicle falls after that split you will need​
to perform these Adaptations on Leutchte27NSL.​
I'm not sure of the build date of your car from your auto-scan, but 45,273km suggests that it's relatively new. Maybe this is the problem?
If so, try restoring the old settings like this:
  • Leuchte26NSL LA72-Lichtfunktion A 26 > Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
and change this:
  • Leuchte27NSL RC6-Lichtfunktion A 26 > Nebelschlusslicht wenn kein Anhaeenger gesteckt
