Tiguan Malfunction
robertdaleweir
Canada
C?ID=51846
I have just acquired a Tiguan which I had been previously leasing. I ran a Scan on it and it shows the following output:
Friday,23,July,2021,11:52:31:56923
VCDS Version: 21.3.0.0 (x64)
VIN: WVGLV7AX9HK009343   License Plate: MH214D
Mileage: 28150km-17491mi   Repair Order: 2
                Address 01: Engine       Labels: 06J-906-026-CCT.clb
Control Module Part Number: 06J 906 027 KB    HW: 06J 907 309 A
  Component and/or Version: MED17.5.2 TFSI 2 07 3231
           Software Coding: 0423010A190F0160
            Work Shop Code: WSC 01383 790 00058
                      VCID: 75EA59401C1F6D23E0-8020
001109 - EVAP System
               P0455 - 000 - Large Leak Detected - MIL ON
                    Fault Status: 11100000
                    Mileage: 28066 km
                    Date: 2021.07.18
                    Time: 11:58:59
                    RPM: 747 /min
                    Load: 38.4 %
                    Speed: 2.0 km/h
                    Temperature: 60.0°C
                    Temperature: 27.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.843 V
I have other transport and I need to get this figured out so I can get it repaired. Any help would be appreciated ...
Robert
TFSI
Maryland, USA
C?ID=66650
Robert
Hi Robert-
Ok whats the exact primary concern you have on this car?
robertdaleweir
Canada
C?ID=51846
I have a 'yellow icon' on the dash which when I look it up in the User's Manual it says to do not drive fast but get to a VW Dealer as soon as possible. I do not want to harm the engine and therefore would like to know what is wrong so I can order the parts and get it fixed. I have driven this vehicle since it was new so I know that it has not been abused but parts do go. It has been running rough for a bit now. I am a noob at understanding the output of my Scan. Just need to have some confidence on where to go from here. Hope that helps and thanks ...
Robert
TFSI
Maryland, USA
C?ID=66650
Probably that yellow light is check engine light based on your scan results. Ensure that gas cap is tight enough or if the rubber seal is worn you may need to replace the gas cap as i can see large leak from your dig report and then clear the fault, and if that's my car i will drive it for at least 20-30 miles and rescan system to check if fault is disappeared or not.
robertdaleweir
Canada
C?ID=51846
Hi TFSI
I will do exactly as you suggest. I will post back once I have carried out what you are suggesting. And thanks ...
Robert
robertdaleweir
Canada
C?ID=51846
Hi TFSI
I did as you suggested and after a short while the Check Engine Light went out. It never came back on and I drove a good 30 miles. I had the battery removed around the time of the fault as I was installing a wiring harness for a Trailer Hitch. I haven't really driven it much since then but no Check Engine Light ever came on when I did. I guess that the "in-car computer' still showed the Checck Engine Light on at first but must be able to clear its own DTCs, as it went out eventually? I ran another scan when I returned home and it generated a clean report part of which I setout below. Everything appears fine now as shown below.
VIN: WVGLV7AX9HK009343 Mileage: 28190km-17516miles
I had checked the gas cap previously but I reseated it before the latest drive, just in case. I want to thank you for your help and my education on the use of my scanner.
Robert
