[Audi A4 B7] HVAC issues
AudiB720TS
Sweden
C?ID=375558
I decided to take full day out of my vacation and close some DTC's. I've fixed my license plate light as well as parking sensor problem that's been with me for a year or more.
I then started at my HVAC fault code:
   Part No: 8E0 820 043 BK
   Component:   A4 Klimaautomat   2833
   Coding: 00000
   VCID: 6B83C7F20A965C43969-5118
00716 - Air recirculation Flap Positioning Motor (V113)
            41-10 - Blocked or No Voltage - Intermittent
To do this I removed the glovebox and ran the 'Output tests' on HVAC while observing the flap motors and listening / feeling the HVAC functions.
Everything seemed okay (each test caused something to happen) except for the V113 test. The flap circled in the below image never opened and so I concluded that flap would be run by the V113 flap motor (also circled).
I then went on to order a 8E1820511L (L revision) flap motor costing me near 200$ shipped. Well turned out I paid for expressing a revision D which is the old version already on my car :banghead:
Don't know why I still bother with eBay but that's a different topic. Anyways, I installed this unit and still nothing happens on output tests. That flap isn't moving.
I then did the code reading from with the HVAC context menu and now I am getting additional codes:
7 Faults Found:
00710 - Defroster Flap Positioning Motor (V107)
01272 - Positioning Motor for Central Flap (V70)
01810 - Actuating Motor for Temperature Flap; Right (V159)
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
            09-00 - Adaptation Limit Surpassed
I don't know if these codes are caused by the series of Output tests or by installing the new flap motor.
Running a full scan (below) after clearing DTC's they all come back.
Not sure what to do next. Are there adaptations or coding to be done (how?).
Many thanks in advance
Full scan:
Friday,23,July,2021,14:56:05:15041
VIN: WUAZZZ8E47A801426   License Plate:
Mileage: 141500km-87924mi   Repair Order:
          67 69 75 76 77
VIN: WUAZZZ8E47A801426   Mileage: 141500km-87924miles
   Part No SW: 8E0 910 115 N    HW: 8E0 907 115 D
   Component: 2.0l R4/4V TFSI     0070
   Revision: 5EH13---    Serial number:
   Coding: 010C0003180F0120
   Shop #: WSC 40970 222 87061
   VCID: 2C0104EECA089B7B03B-8078
008583 - Bank 1; System too Lean at Idle
               P2187 - 004 -  - Intermittent
                    Mileage: 141279 km
                    RPM: 742 /min
                    Load: 4.7 %
                    Temperature: 79.0°C
                    Temperature: 48.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.335 V
   Part No SW: 8E0 910 517 J    HW: 8E0 614 517 BH
   Component: ESP8 quattro    H06 0140
   Coding: 0004526
   Shop #: WSC 06335 000 00000
   VCID: 2E050EE6FC14E96B2DF-807A
   Coding: 00000
   VCID: 6B83C7F20A965C434A1-5118
7 Faults Found:
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  ECE 0907
   Coding: 11141
   Shop #: WSC 65536
   VCID: 3D2739AA246202F3A45-4AA4
02397 - Parking Light Rear Right (M2)
            30-00 - Open or Short to Plus
02737 - Bulb for Tail/Fog Light; Right
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H12 3730
   Revision: 91H12373    Serial number: 0036M0G2T14/
   Coding: 0031612
   VCID: 3B2337B23F660CC39A1-806E
   Subsystem 1 - Serial number: 6332DRB403ABC8AF9
   Subsystem 2 - Serial number: 6342DRB40392CC24S
   Subsystem 3 - Serial number: 6352ARB401773B15H
   Subsystem 4 - Serial number: 6362ARB40179CF55.
   Subsystem 5 - Serial number: 63729RB4017DDE12Y
   Subsystem 6 - Serial number: 63829RB4017DDE6B6
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
                    Fault Status: 11101010
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0701
   Coding: 04042
   VCID: 41DF455A589A6613C0D-4AA4
01304 - Radio
            49-00 - No Communications
   Part No SW: 8E0 920 901 J    HW: 8E0 920 901 J
   Component: KOMBI+WFS 4     H14 0200
   Revision: 0200        Serial number: 00000000000000
   Coding: 0007101
   Shop #: WSC 80093 222 69422
   VCID: 2C0104EECA189B7B03B-50F4
01304 - Radio
   Coding: 0007101
01304 - Radio
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8E0 951 177
   Component: Innenraumueberw.   0804
   Coding: 00001
   Shop #: WSC 40970
   VCID: 6B83C7F20A965C434A1-5066
Address 46: Central Conv.        Labels:. 8E0-959-433-MIN.clb
   Part No: 8E0 959 433 CJ
   Component: Komfortgerát TBF    4035
   Coding: 07018
   Shop #: WSC 06335
   VCID: 7BA3F7B27AF6CCC3DA1-4AA4
   Subsystem 1 - Part No: 8E1959801H
   Component: Tõrsteuer.FS BRM 0606
   Subsystem 2 - Part No: 8E1959802H
   Component: Tõrsteuer.BF BRM 0606
01370 - Alarm triggered by Interior Monitoring
            35-00 - -
00962 - Alarm via. Tilt Sensor
            35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
            35-00 - -
   Part No: 8P0 907 357 F
   Coding: 0000005
   VCID: 3D2739AA217202F3A45-8068
   Part No SW: 8P0 862 335 H    HW: 8P0 862 335 H
   Component: FSE_255x BT     H25 0290
   Revision: 00000000    Serial number: 00000005007651
   Coding: 0001692
   VCID: 3B2337B23F760CC39A1-50D0
01304 - Radio
                    Reset counter: 176
                    Time Indication: 15
End----------(Elapsed Time: 05:12, VBatt start/end: 12.5V/12.4V)-----------
AudiB720TS
Sweden
C?ID=375558
Some more info:
Also, when running Basic Settings, everything goes to 0 except 8,9,10. AFAIK the test does finish (there's no user feedback):
