Hi guys,
I have here one Audi A6 4F with 2.7TDI engine.
This care have retrofit manual gearbox instead of automatic.
I need now to code ABS but vcds point me to support email.
Autoscan attached.
Thank you
Autoscan attached.
Thank you
Friday,16,July,2021,14:06:26:49159
VCDS Version: 21.3.0.0 (x64) HEX-NET CB: 0.4544.4
Dealer/Shop Name: Ursu
VIN: WAUZZZ4F67N040996 License Plate:
Mileage: 347380km-215851mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 03 05 07 08 09 0E 15 16 17 18 19 37 42 46 47 4F 52 53 55
56 61 62 67 72 76 77
VIN: WAUZZZ4F67N040996 Mileage: 347380km-215851miles
Address 01: Engine Labels: 059-907-401-BPP.clb
Part No SW: 4F1 910 401 R HW: 4F0 907 401 C
Component: 2.7L V6TDI G000CG 0030
Revision: --H03--- Serial number:
Coding: 0011382
Shop #: WSC 00011 888 06946
VCID: 2C14DDE68FCB30EB4F-8078
P1653 - 002 -
Fault Status: 01100010
Mileage: 347387 km
Date: 2006.03.25
Time: 09:34:38
Torque: 0.0 Nm
Duty Cycle: 1.0 %
Voltage: 11.93 V
Bin. Bits: 00101000
Torque: 70.2 Nm
Readiness: 0 0 1 X 1
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 AC HW: 4F0 614 517 T
Component: ESP8 front H01 0070
Coding: 0020872
Shop #: WSC 00046 000 00000
VCID: 658268C2ACA1C1A350-8030
Reset counter: 62
Mileage: 347363 km
Date: 2006.03.23
Time: 14:48:24
Hex Value: 0x0000
Hex Value: 0x4282
Hex Value: 0x0013
Hex Value: 0x44A8
Hex Value: 0x00FF
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601000500308
Coding: 0000003
Shop #: WSC 02323 785 00200
VCID: 638676DAA295BF93BE-8036
Subsystem 1 - Part No: 4F0 910 132 D
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
00263 - Transmission
Reset counter: 61
Mileage: 347363 km
Date: 2006.03.23
Time: 14:48:29
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 731 D HW: 4E0 035 729
Component: Interfacebox H43 2830
Revision: 00000000 Serial number: 350GS067708076
Coding: 0000303
Shop #: WSC 00000 000 08192
VCID: 230636DAE215FF93FE-8076
Component: Bedienteil MMIC6H02 0060
Subsystem 2 - Serial number: 00000000488041
Subsystem 3 - Serial number: 0101.08.060000000100011227ÿ
Subsystem 4 - Serial number: 011227ÿ
01964 - Control Module for Seat & Steering Column Memory (J136)
Reset counter: 61
Mileage: 347377 km
Date: 2006.03.25
Time: 08:03:18
01310 - Level Control System Control Module (J197)
Reset counter: 61
Mileage: 347377 km
Date: 2006.03.25
Time: 08:04:32
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 AC
Component: KLIMABETAETIGUNGH20 0170
Revision: 00000030 Serial number: 00000030149029
Coding: 0002070
Shop #: WSC 02325 785 00200
VCID: 5BF64E3A9AE58753F6-800E
01853 - Heated Seat; Left Front (Z45)
Reset counter: 61
Mileage: 347363 km
Date: 2006.03.23
Time: 14:48:29
Temperature: 35.0°C
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 61
Mileage: 347377 km
Date: 2006.03.25
Time: 08:04:04
Temperature: 44.0°C
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Coding: 0012121
Shop #: WSC 02335 785 00200
VCID: 312ACC92A8E95D037C-8064
Subsystem 1 - Part No: 4F1 910 113 B Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 05913389
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111
Component: CD-Changer H43 0470
Revision: 00000000 Serial number: AUZ5ZBD3000828
VCID: 1C740D26DF6BC06B3F-8048
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 42 AIRBAG AUDI8RH29 0280
Revision: 08H29000 Serial number: 0037LD0G3ZNZ
Coding: 0013362
VCID: 291A24F2803925C3B4-807C
Subsystem 1 - Serial number: 6332CSME122C450C%
Subsystem 2 - Serial number: 6342CSME123D5C3DE
Subsystem 3 - Serial number: 6352QSME12793519E
Subsystem 4 - Serial number: 6362QSME14264B0BH
Subsystem 5 - Serial number: 63734SME10463F07.
Subsystem 6 - Serial number: 63834SME127C157F9
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90025061960014
Coding: 0002141
VCID: 66806FCE51A7CABB59-8032
Component: Lenkradmodul H07 0090
Part No SW: 4F0 910 930 C HW: 4F0 920 932
Component: KOMBIINSTR. M73 H18 0110
Revision: 00300000 Serial number: 5HP722K76
Coding: 2048043
Shop #: WSC 50741 143 61874
Address 18: Aux. Heat Labels: None
Part No SW: 4F0 910 105 A HW: 4F0 265 081 L
Component: Heizgeraet H08 0060
Revision: B Serial number: 09011480
Coding: 0000111
VCID: 1B760E3ADA65C75336-804E
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 1300806721816E
Coding: ECEE73C61B7104
VCID: 271E22CA962D13B3A2-8072
Part No SW: 4E0 910 887 Q HW: 4E0 919 887 D
Component: MNS ECE H48 0850
Revision: 00000000 Serial number: 364G$067583963
Shop #: WSC 00493 128 21477
VCID: 3B36EEBA7AA5A753D6-806E
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00-00000
Coding: 0000618
Shop #: WSC 02327 785 00200
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01017095430000
Coding: 0401541
VCID: 2E10D7EEB9D742FB61-807A
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 62
Mileage: 320672 km
Date: 2019.05.18
Time: 15:30:40
Reset counter: 56
Mileage: 347244 km
Date: 2006.03.16
Time: 08:06:43
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 F HW: 4F0 035 223 F
Component: DSP-High C6 H09 0190
Revision: PROD_01 Serial number: 00000000010872
Coding: 0000028
VCID: 210A3CD2F809ED83EC-8074
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000268912
Coding: 0001013
VCID: 5EF0472E89F7927B91-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00-00000
Coding: 0000618
Part No SW: 4F0 910 801 B HW: 4F0 907 801 A
Component: EPB CB4C0060 H04 0060
Revision: --H04---
Coding: 0000531
Shop #: WSC 00000 785 00200
VCID: 1F0E3A2ACE7DDB73DA-804A
Fault Status: 11100100
Fault Frequency: 105
Reset counter: 60
Mileage: 347240 km
Date: 2006.03.15
Time: 12:05:04
Voltage: 11.70 V
Count: 243
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Coding: 0000003
VCID: 3D32E0A264B1A963E8-8068
Part No SW: 4E0 910 541 M HW: 4F0 035 541 H
Component: TUNER EU/US/RDW H42 0570
Revision: 00000000 Serial number: 394G.067670574
Coding: 0000001
VCID: 2A18DBFE853F2EDBBD-807E
Fault Frequency: 8
Reset counter: 101
Mileage: 347245 km
Date: 2006.06.17
Time: 00:20:51
Reset counter: 101
Mileage: 347245 km
Date: 2006.05.31
Time: 13:43:23
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000084258
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2607282031
Coding: 344630393135313035442056413032363037323832303331
Shop #: WSC 00000 384 00290
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0000042
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 R HW: 4E0 035 753 A
Component: SDS 3500 DE H45 0630
Revision: 00000000 Serial number: 00000607040168
Shop #: WSC 12336 024 394758
VCID: 3522F8825C81712320-8060
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0000042
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06220620104155
Coding: 0201006
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H13 0700
Revision: 00000000 Serial number: 00000007562766
Coding: 0010900
End----(Elapsed Time: 01:44, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
