Audi A1 GB backup battery
chb
C?ID=361330
The official audi service plan (from erWin) for the inspection after (the first) 2 years demands to read out the state of the (sos?) backup battery. How can I do this with VCDS?
Where is this battery located in the car? In the Gateway module (and if yes, where is the gateway located)? Can this battery be easily changed?
Thanks, Chris
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Check your Auto-Scan for the BDM (Battery Data Module), you should find that either as a Slave/Subsystem of #19 or #61. Then access either of the modules and check the battery data, the description in VCDS should be self explaining. If you happen to have further questions, please make sure to include an Auto-Scan in your reply.
chb
C?ID=361330
Thanks for your quick answer. However, I believe you describe testing the main battery used for starting the engine. I already know the procedure in module #19 for testing this one.
I am talking about a second (small) battery (BACKUP battery = "Notstrombatterie" in German), e.g. used for sending an emergency call if the main battery should be broken after an accident or similar. I think it might be attached to the gateway module (as desribed above). I found no entry for that in the advaced measuring values.
OT: Why is the Function measuring block 08 grayed out for module 19?
Here (not the latest but anonymized) autoscan. I think this should be sufficient:
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 10 x64
VCDS Version: AIB 20.4.2.1  HEX-NET CB: 0.4513.4
Datenstand: 20200919 DS317.0
www.vcds.de
Fahrzeug-Ident.-Nr.: WAUZXXXXXXXXXXX   KFZ-Kennzeichen: xxxxxxx
Kilometerstand: xxxxxkm   Reparaturauftrag:
Fahrzeugtyp: GB-AU27 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 42 44 52 5F 75 A5
Fahrzeug-Ident.-Nr.: XXXXXXXXXXXXXXXX   Kilometerstand: xxxxxxkm
01-Motorelektronik -- Status: i.O. 0000
02-Getriebe -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: i.O. 0000
10-Einparkhilfe 2 -- Status: i.O. 0000
13-Distanzregelung -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
42-Türelektr. Fahrer -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
52-Türelektr. Beifahr. -- Status: i.O. 0000
5F-Informationselek. I -- Status: i.O. 0000
75-Telematik -- Status: i.O. 0000
A5-Front-/Vorfeldkamera -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-DADA)       Labeldatei:. DRV\04E-907-309-V1.clb
   Teilenummer SW: 05E 906 018 AB    HW: 05E 907 309
   Bauteil: R4 1.5l TFS   H22 9763
   Revision: 81H22000
   Codierung: 0225003223041D0800000000000000000000000000000000
   Betriebsnr.: WSC 33396 001 1048576
   ASAM Datensatz: EV_ECM15TFS01105E906018AB 003005
   ROD: EV_ECM15TFS01105E906018AB_AU27.rod
   VCID: E5823838E45F7BAE01-80B0
Kein(e) Fehlercode(s) gefunden.
Adresse 02: Getriebe (J743)       Labeldatei: DRV\0CW-927-769.clb
   Teilenummer SW: 0CW 300 043 D    HW: 0AM 927 769 E
   Bauteil: GSG DQ200G2_M H05 1605
   Revision: 00005008    Seriennummer: CUxxxxxxxxxxxxxx
   Codierung: 0014
   Betriebsnr.: WSC 00049 770 00163
   ASAM Datensatz: EV_TCMDQ200021 001001
   ROD: EV_TCMDQ200021_VW27.rod
   VCID: B83CA14C036D36466A-80EC
Adresse 03: Bremsenelektronik (J104)       Labeldatei: Umleit. fehlgeschl.!
   Teilenummer SW: 2Q0 614 517 AG    HW: 2Q0 614 517 N
   Bauteil: ESC_base_vFGS H23 0242
   Seriennummer: 085xxxxxxxxxxxxxxx
   Codierung: 42094D4F354742AFB200AC1A37E123A649125126336A24582454285445ECC46592488A64CC56241A242A142AA24DD2423DB24B42BC
   ASAM Datensatz: EV_Brake1BOSCHESPMQBA0 004036
   ROD: EV_Brake1BOSCHESPMQBA0_004.rod
   VCID: F3A656605A8B951E9F-80A6
Adresse 08: Klima-/Heizungsel. (E87)       Labeldatei:* Keine
   Teilenummer SW: 83A 820 047 A    HW: 83A 820 047 A
   Bauteil: AC Manuell el H04 0020
   Revision: 20026000    Seriennummer: 000000xxxxxxxxxxxxxxx
   Codierung: 230000040000000010000000000000000000000000000000
   ASAM Datensatz: EV_AirCondiFrontManAU326 001003
   ROD: EV_AirCondiFrontManAU326.rod
   VCID: A2086324B5F14C96A4-80F6
Adresse 09: Zentralelektrik (J519)       Labeldatei:. DRV\5Q0-937-08X-V2.clb
   Teilenummer SW: 5Q0 937 084 DC    HW: 5Q0 937 084 CF
   Bauteil: BCM MQBAB M+  H38 0273
   Seriennummer: 010xxxxxxxxxxxxx
   Codierung: 000000000000000000000000000000000000000000000000000000000000
   ASAM Datensatz: EV_BCMMQB 019001
   ROD: EV_BCMBOSCH_019.rod
   VCID: FCB47D5C77D5DA66CE-80A8
   Sensor für Regen- und Lichterkennung:
   Subsystem 1 - Teilenummer SW: 81A 955 559 A    HW: 81A 955 559
   Bauteil: G397_RLS  H06 0002
   Seriennummer: 20xxxxxxxxxxxxxxxxxx
   Codierung: 80004D
   Lichtschalter:
   Subsystem 2 - Teilenummer SW: 4K1 941 501 D    HW: 4K1 941 501 D
   Bauteil: E1 - LTM  H05 0053
   Seriennummer: 1xxxxxxxxxxxxxx
   Lenkstockschalter:
   Subsystem 3 - Teilenummer SW: 82A 953 521 DR    HW: 5Q1 953 549
   Bauteil: J527 SMLS MQB  004 0070
   Seriennummer: 000000xxxxxxxxxxxxxxxx
Adresse 10: Einparkhilfe 2 (J446)       Labeldatei:| DRV\5Q0-919-294.clb
   Teilenummer SW: 5QA 919 294 C    HW: 5QA 919 294
   Bauteil: PDC 8 KanalH07 0050
   Seriennummer: 00xxxxxxxxxxxxx
   Codierung: 0471051011
   ASAM Datensatz: EV_EPHVA18AU3700000 009039
   ROD: EV_EPHVA18AU3700000_009_VW27.rod
   VCID: CCD4ED9C67F5AAE63E-8098
Adresse 13: Distanzregelung (J428)       Labeldatei:| 2Q0-907-572.clb
   Teilenummer SW: 2Q0 907 572 Q    HW: 5Q3 907 572
   Bauteil: ACCCONTIMQB   H03 0342
   Codierung: 3200000208F78728747C61450050A700000000000000000000
   ASAM Datensatz: EV_ACCMRRCONTIVW376 003015
   ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
   VCID: C2C8C3A455B16C96C4-8096
Adresse 15: Airbag (J234)       Labeldatei:* Keine
   Teilenummer SW: 2Q0 959 655 AM    HW: 2Q0 959 655 AM
   Bauteil: VW22Airbag    010 0351
   Revision: --------
   Codierung: 88CCC0C0000000005C5400DF000840A80065
   Betriebsnr.: WSC 00049 770 00119
   ASAM Datensatz: EV_AirbaVW22BPAVW27X 001020
   ROD: EV_AirbaVW22BPAVW27X_VW37.rod
   VCID: 885C118C330D86C6DA-80DC
   Crashsensor für Seitenairbag Fahrerseite:
   Subsystem 1 - Teilenummer SW: -----------    HW: 442 062 005 19
   Bauteil: SideSensor_Df  1E2 0887
   Seriennummer: 3xxxxxxxxxxxxxxxxxx
   Codierung: 2D2D2D
   Crashsensor für Seitenairbag Beifahrerseite:
   Subsystem 2 - Teilenummer SW: -----------    HW: 442 062 005 19
   Bauteil: SideSensor_Pf  1E2 0887
   Codierung: 2D2D2D
   Crashsensor für Seitenairbag hinten Fahrerseite:
   Subsystem 3 - Teilenummer SW: -----------    HW: 442 0B1 105 19
   Bauteil: SideSensor_Dr  1C7 0148
   Seriennummer: 35xxxxxxxxxxxx
   Codierung: 2D2D2D
   Crashsensor für Seitenairbag hinten Beifahrerseite:
   Subsystem 4 - Teilenummer SW: -----------    HW: 442 0B1 205 19
   Bauteil: SideSensor_Pr  1C7 0148
   Codierung: 2D2D2D
   Crashsensor für Frontairbag Fahrerseite:
   Subsystem 5 - Teilenummer SW: -----------    HW: 442 133 003 19
   Bauteil: FrontSensor_D  290 118A
   Seriennummer: 3xxxxxxxxxxxxxxxxxxx
   Codierung: 2D2D2D
Adresse 17: Schalttafeleinsatz (J285)       Labeldatei:* Keine-SRI3
   Teilenummer SW: 82A 920 700     HW: 82A 920 700
   Bauteil: KOMBI         H13 1712
   Codierung: 00840008618000080080A0001000000000000000
   ASAM Datensatz: EV_DashBoardVDDMQBA0 001027
   ROD: EV_DashBoardVDDMQBA0_AU27.rod
   VCID: DDF210D8CC0F336ED9-8088
Adresse 19: Diagnoseinterface (J533)       Labeldatei:| DRV\3Q0-907-530-V1.clb
   Teilenummer SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
   Bauteil: GW MQB High   521 5366
   Seriennummer: 05xxxxxxxxxxxxxxx
   Codierung: 030100F42F0857005B000248180B00000000000000000000000000000000
   ASAM Datensatz: EV_GatewNF 013025
   ROD: EV_GatewNF_AU27.rod
   VCID: EE90471431A9B8F670-80BA
   Generator:
   Bauteil: 0-00-02-00-04
   Steuergerät für Multifunktionslenkrad:
   Subsystem 2 - Teilenummer SW: 83A 951 523     HW: 83A 951 523
   Bauteil: J453 MFL  H05 0004
   Seriennummer: 20xxxxxxxxxxxx xxxxx
   Steuergerät für Batterieüberwachung:
   Subsystem 3 - Teilenummer SW: 2Q0 915 181     HW: 2Q0 915 181
   Bauteil: J367-BDMBOSCH  H02 2011
Adresse 42: Türelektr. Fahrer (J386)       Labeldatei:| 5QX-959-X93-42.clb
   Teilenummer SW: 5Q4 959 393 F    HW: 5Q4 959 393 F
   Bauteil: TSG FS        006 0246
   Seriennummer: xxxxxxxxxxxxxx
   Codierung: 00100320E100020000001000
   ASAM Datensatz: EV_DCU2DriveSideMAXHCONT 001005
   VCID: C6C0DFB4799950B6E8-8092
   Türsteuergerät Fahrerseite hinten:
   Subsystem 1 - Teilenummer SW: 5Q0 959 407     HW: 5Q0 959 163
   Bauteil: FOND_FHSG_DRV  007 0010
   Codierung: 310000
Adresse 44: Lenkhilfe (J792)       Labeldatei:* Keine
   Teilenummer SW: 2Q1 909 144 M    HW: 2Q1 909 144 F
   Bauteil: TRW_G4L_MQBA0 611 6041
   Seriennummer: 1xxxxxxxxxxxxxxx
   Codierung: 010000000100000001010201010001010000010101
   ASAM Datensatz: EV_SteerAssisTRWG4LMQBA0 011016
   ROD: EV_SteerAssisTRWG4LMQBA0.rod
   VCID: BC34BD5C37551A668E-80E8
Adresse 52: Türelektr. Beifahr. (J387)       Labeldatei:| 5QX-959-X92-52.clb
   Teilenummer SW: 5Q4 959 392 F    HW: 5Q4 959 392 F
   Bauteil: TSG BFS       006 0246
   Seriennummer: 0xxxxxxxxxxxxx
   Codierung: 00100120E100020000001000
   ASAM Datensatz: EV_DCU2PasseSideMAXHCONT 001005
   VCID: C5C2D8B8449F5BAEE1-8090
   Türsteuergerät Beifahrerseite hinten:
   Subsystem 1 - Teilenummer SW: 5Q0 959 408     HW: 5Q0 959 164
   Bauteil: FOND_FHSG_PSG  007 0010
   Seriennummer: 0xxxxxxxxxxxxxxxxxx
   Codierung: 290000
Adresse 5F: Informationselek. I (J794)       Labeldatei:* Keine
   Teilenummer SW: 83A 035 842     HW: 83A 035 842
   Bauteil: MU-S-D-ER     742 0051
   Seriennummer:
   Codierung: 01720000BE00000041111101C00800002F0007E40170000002
   Betriebsnr.: WSC 23582 187 00000
   ASAM Datensatz: EV_MUStdGen2pDELP 001001
   ROD: EV_MUStdGen2pDELP.rod
   VCID: E2882324F5710C96E4-80B6
   Anzeigeeinheit 1 für Multimediasystem:
   Subsystem 1 - Teilenummer SW: 82A 919 604 A    HW: 82A 919 604 A
   Bauteil: DU AU270 Std  H42 0133
   Seriennummer: Mxxxxxxxxxxxxxxxx
   Lautstärkeregler 1:
   Subsystem 2 - Teilenummer SW: 82A 919 616     HW: 82A 919 616
   Bauteil: LSR-D5/C8  H33 0108
   Seriennummer: 00ccxxxxxxxxxxxxxxxxx
Adresse 75: Telematik (J949)       Labeldatei:| 5QE-035-285.clb
   Teilenummer SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Bauteil: OCULowMQBLGE  H19 0833
   Revision: --------
   Codierung: 01720601EA370A0F05109C0000354003804651
   ASAM Datensatz: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW27.rod
   VCID: BD32B0582C4F136EB9-80E8
Adresse A5: Front-/Vorfeldkamera (R242)       Labeldatei:| DRV\3Q0-980-65X-A5.clb
   Teilenummer SW: 3Q0 980 654 M    HW: 3Q0 980 654 A
   Bauteil: MQB_B_MFK     H09 0451
   Seriennummer: 2xxxxxxxxxxxxxx
   Codierung: 0402070000000401002200448146480084000E00000000
   ASAM Datensatz: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: C1CACCA850B7778EDD-8094
Ende--(Dauer: 01:08, Batt.-Spannung Start/Ende: 11.9V/11.9V. VIgn 11.9V)---
Because that module uses the UDS protocol.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Thanks for clarifying. You can help us answering your questions by being more precise with your initial inquiry, an Auto-Scan is in almost all cases mandatory.
Your should find the eCall Battery Status in your telematics control module, check...
IDE11307-ENG160003 = eCall Batteriestatus - Batterieladezustand
IDE11307-ENG160002 = eCall Batteriestatus - Batterieladestatus
IDE04293-ENG159758 = Betriebszustand für Notrufmodul - Restlaufzeit
IDE04293-ENG99298 = Betriebszustand für Notrufmodul
In addition, please send an unedited (non-anonymized) Auto-Scan to us via email (support@ross-tech.com). This will allow us to take care of the missing label files and possibly not yet documented coding options for your specific model/equipment.
chb
C?ID=361330
That was it! Thanks Sebastian and Uwe for your help!
@Sebastan: I did send you a complete Autoscan as desired to support@ross-tech.com . Hope that helps.
Chris
