Driver Install Trouble
ejg3855
Western NY, USA
C?ID=146905
So I ditched the ARM device and got a new x86 device. I've never had so much trouble in my life with VCDS. I've had my HEX-CAN cable for years and many different laptops.
So here I am trying to install VCDS, software installs fine. Driver for the cable wont.
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
{Bad Image}
%hs is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support. Error status 0x
Sebastian
Magdeburg, Germany
HN0-nnnnnn
What device are you installing on (make, model etc.)? What is the exact version of Windows you are installing this on?
ejg3855
Western NY, USA
C?ID=146905
Windows 10 Home, Microsoft Surface.
I had a surface pro 3 (no problems) this is a surface go2 Intel X86 based, can run standard windows programs. I checked the FAQ.
Edition    Windows 10 Home
Version    20H2
Installed on    ‎7/‎23/‎2021
OS build    19042.1110
Serial number    004428310551
Experience    Windows Feature Experience Pack 120.2212.3530.0
Strange. I have a Surface Go 2, no issues installing drivers on it.
ejg3855
Western NY, USA
C?ID=146905
I did a clean install and still was presented the same issue, I booted into mode without driver signing required and had the same issue.
which driver should I be using? I can try forcing it.
Check this:
Settings -> Update & Security -> Windows Security -> Device Security -> Core Isolation. Is "Memory integrity" turned on? If so, turn it off.
That "feature" uses virtualization and will likely prevent the driver from loading. It is generally off by default on most systems, but I wouldn't put it past Microsoft to have it on...
ejg3855
Western NY, USA
C?ID=146905
I was just getting down this road, as the drivers would load in safe mode with no issue and as soon as I booted into regular mode it gave erros.
Your solution was correct, thanks for the assistance.
