Monday,19,July,2021,22:23:59:17548
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
VIN: WVWZZZ3CZJE212080 License Plate: OCN550
Mileage: 102926km-63955mi Repair Order:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 22 2B 3C 42 44 47
4B 52 5F 69 6C 6D A5 BB BC CF D6 D7
VIN: WVWZZZ3CZJE212080 Mileage: 102926km-63955miles
Address 01: Engine (J623-CUAA) Labels: None
Part No SW: 03N 906 026 A HW: 03N 907 309
Component: R4 2.0l BTD H24 5164
Revision: A1H24---
Coding: 0125003A047605083000
Shop #: WSC 05311 115 00107
ASAM Dataset: EV_ECM20BTD01103N906026A 004006
ROD: EV_ECM20BTD01103N906026A.rod
VCID: 290E0351197D6A8304C-807C
17159 - Databus
Part No SW: 0DL 300 012 S HW: 0BH 927 711 F
Component: GSG DQ500 H10 5303
Revision: 00H10V01
VCID: 392ED311E9DDDA0374C-806C
Part No SW: 5Q0 614 517 DA HW: 5Q0 614 517 AH
Component: ESC H62 0753
Revision: 00000000 Serial number: 61068000000765
Coding: 0FEC6B8F54210B6E4777070860C369F0D62AD0E2E0069675386250F8CAA9420B00000012121212B835351919323200
Shop #: WSC 00015 115 08193
ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
VCID: 73B221398B3160537E0-8026
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0907
Revision: 00037000 Serial number: 0477843640
Coding: 1F20000723
Shop #: WSC 05311 115 00306
ROD: EV_KessyHellaMQBAB.rod
VCID: 3E24C00DF0F3FD3B41E-806A
Part No SW: 5G0 907 044 DQ HW: 5G0 907 044 DQ
Component: Climatronic H04 2001
Revision: 00001K10
Coding: 12020104204111011115100C0010192A
VCID: 79AE1311A95D1A0334C-802C
Air quality sensor:
Humidity sensor: exterior:
328452 - Motor for Rear Temperature Flap
B108E 71 [008] - Actuator stuck
Fault Frequency: 9
Reset counter: 146
Mileage: 102013 km
Date: 2021.03.03
Time: 12:08:20
Voltage terminal 30: 14.3 V
Outside temperature: 9.0 °C
Inside temperature: 28.3 °C
Rear temperature flap: actual value: 0.0 %
Rear temperature flap: actual value: 42
Rear temperature flap: specified value: 19
Part No SW: 5Q0 937 086 BM HW: 5Q0 937 086 BH
Component: BCM PQ37BOSCH 034 0245
Revision: -------- Serial number: 865816041800G0
ROD: EV_BCMBOSCH_018.rod
VCID: 065468EDE8A365FB49E-8052
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 180228 042 0607
Serial number: 180328124500
Component: RLHS 050 0107
Serial number: SAY18M04D24H10M44S28
Coding: 00A8DD
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 14 03 2018 10000986
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY180643CCK
Subsystem 5 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0006
Serial number: 00000000000000098030
Humidity sensor: interior:
204290 - Remote key 1
B1479 18 [008] - Current Too Low
Reset counter: 148
Mileage: 93366 km
Date: 2020.11.17
Time: 08:26:53
204546 - Remote key 2
B147A 18 [008] - Current Too Low
Reset counter: 148
Mileage: 93367 km
Date: 2020.11.25
Time: 18:01:32
B1263 01 [008] - Electrical Failure
Fault Frequency: 12
Reset counter: 140
Mileage: 96330 km
Date: 2020.12.26
Time: 12:57:38
Part No SW: 5QA 919 298 F HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0453
Serial number: 000308417618097
Coding: 0271167951
Shop #: WSC 05311 115 00065
ASAM Dataset: EV_EPHVA2CAU3700000 009037
ROD: EV_EPHVA2CAU3700000.rod
VCID: 53F281B96B7100539E0-8006
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 C HW: 3Q0 907 572 C
Component: ACC BOSCH MQB H04 0195
Coding: 320467DB5DFFC728949C8045
ASAM Dataset: EV_ACCBOSCHVW48X 001009
ROD: EV_ACCBOSCHVW48X.rod
VCID: 3536DF21C5C53E63904-8060
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 14031841350042
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 3828D615D2D7C30B8B2-806C
Part No SW: 3Q0 959 655 BK HW: 3Q0 959 655 BK
Component: Airbag VW21 006 0703
Revision: -------- Serial number: 003W6P7UQM7T
Coding: 88CCC000008000005C5400CF000800000065
Shop #: WSC 05311 000 08193
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 084866D5E2B7738B3B2-805C
Left seat belt tensioner:
Serial number: 3G0857705 0100S01035
Coding: 80000D
Right seat belt tensioner:
Serial number: 3G0857706 0100S00869
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 454 000 604 18
Serial number: 35700000000B914C5F2V
Subsystem 4 - Part No SW: ----------- HW: 454 000 504 18
Serial number: 3580000000005C990F2P
Subsystem 5 - Part No SW: ----------- HW: 454 800 504 18
Serial number: 3510024712414000000Y
Subsystem 6 - Part No SW: ----------- HW: 454 800 504 18
Serial number: 3520037712414000000$
Subsystem 7 - Part No SW: ----------- HW: 454 800 904 18
Serial number: 35500DA2F4B14000000U
Part No SW: 5Q0 953 521 FG HW: 5Q0 953 569 B
Component: Lenks.Modul 100 0225
Revision: FF034034 Serial number: 20180428501396
Coding: 0C10
ASAM Dataset: EV_SMLSVALEOMQBLRH 001009
ROD: EV_SMLSVALEOMQBLRH.rod
VCID: 7CA00A05A66F2F2B2FA-8028
291104 - Temperature Sensor for Heated Steering Wheel
B1455 01 [008] - Electrical Failure
Reset counter: 148
Mileage: 93366 km
Date: 2020.11.17
Time: 08:26:44
Ubat 30 Voltage: 12.70 V
Internal error state: 0
LIN_Temp: 254
Isense: 0
Max.Leistung: 110
PWM: 0
Offset: 0
Slope: 133
kp: 13
OUT: 50
Temperatur Statisch: 30
p_t_soll_0: 39.00 °C
p_t_soll_1: 43.00 °C
p_t_soll_2: 47.00 °C
Part No SW: 3G0 920 791 C HW: 3G0 920 791 C
Component: KOMBI 407 3196
Coding: 07A40818FF8C000801886B2B1001000080000000
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 J HW: 5Q0 963 272 J
Component: STH-MQB 008 0080
Coding: 9309
VCID: 3D26C701FDF5E623584-8068
Auxiliary heating remote control:
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0402
Serial number: 00000000000000451493
0036 - Fuel Level too Low
P1250 00 [008] - -
Reset counter: 125
Mileage: 101586 km
Date: 2021.02.26
Time: 07:16:20
Parking heater: operating condition: active: control pause
8F
Coolant temperature of parking heater: 84 °C
Coolant temperature: 84 °C
Engine running status: detected
Fuel level: 9 l
Heating performance: 0 W
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 518 5323
Serial number: 08041810803657
Coding: 030300345F017300FB00025E9C0F00010001070000000000000000000000
ROD: EV_GatewNF_VW37.rod
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0040
Serial number: 39180000649600028161
Coding: 2FFFFF
Subsystem 3 - Part No SW: 3Q0 915 181 B HW: 3Q0 915 181 B
Serial number: 8339977004
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 111 1004
Serial number: 0704201800010273
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Serial number: HA1-00027.03.18
Coding: 0301
VCID: 4CC09AC5B64F5FABDFA-8018
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 18000129079006
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 3332E139CBB12053BE0-8066
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 E HW: 3Q0 907 566
Component: MRR1Rear H20 0510
Revision: --------
Coding: 14C002
VCID: 3A2CCC1DECDBD11B7D6-806E
267010 - Databus
[FAULT_SLAVE]
Reset counter: 6
Mileage: 97367 km
Date: 2021.01.11
Time: 16:43:07
Control Module temperature: 8 °C
Voltage terminal 30: Measuring value not available
Vehicle speed: 47.74 km/h
Terminal 15 status: Measuring value not available
Voltage terminal 15: 14.30 V
Component: TSG FS 020 0041
Serial number: 110418EDA1701A
Coding: 003F1A208000028000001000
VCID: 43D2B1F99B1190D32E0-8016
Part No SW: 3Q0 909 144 L HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5081
Coding: 93170000
Shop #: WSC 00015 115 00306
ROD: EV_SteerAssisMQB_015.rod
VCID: 3B22C919E3E1E813660-806E
Address 47: Sound System (J525) Labels:| 3Q0-035-466.clb
Part No SW: 3Q0 035 465 HW: 3Q0 035 465
Component: MIB2_amp_P_VW H60 0440
Revision: 00000001 Serial number: VWZ8Z1JJD01HPG.
Coding: 1284020001AA0A2AAA0000000000
ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001016
ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
VCID: 6B823959D301B893B60-803E
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 14041810523481
Coding: 000000060100035207004F01020000000000000000000000000000000000
VCID: 72BC243DF42B695B756-8026
Subsystem 1 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _
Component: Leimo links H02 0003
Coding: E02400
Subsystem 2 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _
Component: Leimo rechts H02 0003
Coding: E02400
Component: TSG BFS 020 0041
Serial number: 310318ECV12787
Coding: 003F10208000028000001000
VCID: 42DCB4FD840B99DB256-8016
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 5NA 035 043 B HW: 5NA 035 043
Component: MU-H-N-EU H54 1161
Serial number: A848E0JS047169
Coding: 02840201000000005111000200080A001F0100E4012004009F
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H52 9130
Serial number: VWZ6ZJV1335288
Subsystem 2 - Part No SW: V03 959 800 QR HW: -----------
Component: ECE 2017/2018 --- 0161
Compact disc data bank:
Component: Gracenote2 --- 1016
0005 - Antenna Amplifier 1 for Radio
B126D 13 [009] - Open Circuit
Reset counter: 189
Mileage: 93360 km
Date: 2020.11.17
Time: 08:11:23
Voltage terminal 30: 14.2 V
Status of antenna 1 for radio-Antenna current: 0 mA
Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
Status of antenna 1 for radio-Reception level antenna 1: 255 dBµV
Part No SW: 5Q0 907 383 N HW: 5Q0 907 383 N
Component: Anhaenger H27 0264
Revision: 8A001003 Serial number: 0477201123
Coding: 0100000202000000
Component: RVC Compact H12 0231
Coding: 0184020163002017000040
Part No SW: 5Q0 959 107 L HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0261
Revision: -------- Serial number: 31892926400000
Coding: 0288
VCID: 41DEBBF1810D82C33CC-8014
Part No SW: 3Q0 980 653 F HW: 3Q0 980 653
Component: MQB_B_MFK H13 0171
Serial number: 13041811P12357
Coding: 00040802000004010022234FC150A900980094300040
1275 - Unknown Error Code
B182E F0 [008] - Unknown Error Elaboration
Reset counter: 47
Mileage: 98954 km
Date: 2021.01.29
Time: 16:39:19
Control Module temperature: 23 °C
Outside temperature: -4.5 °C
Vehicle speed: 22.30 km/h
System run time: 403.0 s
Voltage terminal 15: 14.2 V
mid: 01 63
Status of camera: operational
Engine_Running_Info: 1
Software_Info_4: 1
Software_Info_3: 7
Software_Info_2: 1
Software_Info_1: 0
Component: TSG HFS 020 0041
Serial number: 090418ED745131
Coding: 000E10200100028000001000
VCID: 45D6AFE19525AEE3004-8010
Component: TSG HBFS 020 0041
Serial number: 090418ED745134
Address CF: Lane Chge Asst 2 (J770) Labels:. 3Q0-907-566.clb
Part No SW: 3Q0 907 590 E HW: 3Q0 907 590
Revision: --------
Coding: 14C002
VCID: 372AD529DFC9CC73828-8062
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
VCID: 167438ADB803D57BB9E-8042
Component: LED1R H09 0003
End----(Elapsed Time: 02:33, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
