2007 Q7 Air Suspension Problems
Foz
Chesterfield, UK
C?ID=443761
Ok sure no problem , here goes.
I have an Audi Q7, 2007, 3.0 Litre (4L model i think) Uk, owned for 5 years with no issues but recently a few things have started to go wrong with it.
Firstly it just wouldnt start at all one day, electrics all worked fine, dashboard lit up, just wouldnt crank over at all - anyhow that turned our to be the starter motor. Had a new one fitted and everything was back to normal.
Then a few weeks ago, both rear tyres started wearing on the inside, so sent them in to get aligned. But the mechanic couldnt align them as all the bolts on the rear control arms had seized. So i spent another £400 getting the rear control arms and bolts replaced.
So then it went back into the garage to have the rear wheels aligned, and they could adjust them no problem, all is ok at this point.
Then driving back from the garage after the alignment was done, about 10 mins or so, i got an ESP/ABS Fault come up on the dashboard, and the orange light (the one with the slippery tyres?) came on. i pulled over on the way home from the garage, and tried setting a different suspension level. I chose lift and it went up ok, but now it seems to be stuck in that position but only on the front and not the rear?. I have to drive it home in the highest position (on the front) and thats where its stayed for the last few days, still stuck in the highest position on the front, and what would be comfort level on the back.
Im not sure if the wheel alignment had anything to do with it, as its been showing some signs of air suspension problems for a couple of months now. For example, the front end would be low in a morning when i came out to it, or the level of the car would move slightly whilst im stood in traffic, but nothing other than that. So maybe there has been signs of a problem for a while, and its just coincidence this happened at the same time as the wheel alignment?
As the front suspension has been stuck at the highest level for two days, i guess there isnt a leak on the system either? But i dont know a great deal about these cars really.
So thats the problem i have right now, the air suspension seems to be stuck at the highest level, on the front only, and comfort level at the rear.
Now i know little about the codes that i can see, but could it point to a level sensor maybe?
Which is why i bought a HEX-V2 to help me diagnose the problem. I really like the Q7 so want to keep it if i can so though this device would come in handy for the future, also the wife has a Seat so can use it on that too.
Thanks for your help trying to find out what the problem is! I appreciate it.
Please find attached my autoscan logs, the first one i ran the first time i plugged the V2 into the car. Then i cleared the logs, and ran it again, which is the second attachment below:
This is the very first autoscan - before i cleared the codes:
Tuesday,20,July,2021,10:38:39:46323
VIN: WAUZZZ4L68D014380   License Plate: XX03F0Z 200721
Mileage: 164030km-101923mi   Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 18 19 1E 34 36 37 3C 42
          46 47 4F 52 55 56 61 62 67 6D 6F 72 76 77
VIN: WAUZZZ4L68D014380   Mileage: 164030km-101923miles
Address 01: Engine        Labels: 059-907-401-ASB.clb
   Part No SW: 4L0 910 401 T    HW: 4L0 907 401
   Component: 3.0L V6TDI  G000AG  0020
   Revision: --H04---    Serial number:
   Coding: 0011775
   Shop #: WSC 31414 790 00001
   VCID: 333316EDC73E27A3421-8066
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No SW: 09D 927 750 FS    HW: 09D 927 750 FS
   Component: AL 750 6A           1000
   Revision: 00H64000    Serial number:
   Coding: 0000504
   VCID: 04518531D210501BABB-8050
   Part No SW: 4L0 910 517 B    HW: 4L0 614 517 D
   Component: ESP ALLRAD MK25E1   0010
   Revision: 00H30001
   Coding: 0103569
   VCID: 290FF48515F26D73F8D-807C
                    Reset counter: 2
                    Mileage: 162684 km
                    Date: 2007.06.03
                    Time: 14:47:23
                    Count: 2113
                    Count: 128
                    Count: 31744
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Reset counter: 212
                    Mileage: 163734 km
                    Date: 2021.07.14
                    Time: 13:59:41
                    Count: 17152
                    Count: 8193
                    Count: 288
                    Count: 49664
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0230
   Revision: 09010701    Serial number: 10601500826699
   Coding: 0000151
   VCID: 6393A6AD375EF723F21-8036
   Subsystem 1 - Part No: 4F0 910 131 G
   Component: FBSAUDIC6 EZS   H45 0080
   Component: FBSAUDIC6 KSG   H27 0080
   Subsystem 3 - Part No: 4F0 910 220 K
   Component: FBSAUDIC6 IDG   H01 0060
00191 - Passenger's Door Handle Touch Sensor (G416)
                    Fault Status: 00110111
                    Fault Frequency: 12
                    Reset counter: 241
                    Mileage: 161206 km
                    Date: 2007.03.17
                    Time: 15:13:00
                    Fault Status: 00111000
                    Fault Status: 01111011
                    Reset counter: 113
                    Mileage: 161338 km
                    Date: 2007.04.09
                    Time: 12:54:11
00193 - Rear Right Door Handle Touch Sensor (G418)
                    Fault Frequency: 14
                    Reset counter: 254
                    Mileage: 162224 km
                    Date: 2007.04.26
                    Time: 17:02:34
                    Reset counter: 215
                    Mileage: 162246 km
                    Date: 2007.04.29
                    Time: 10:20:41
                    Reset counter: 248
                    Mileage: 163662 km
                    Date: 2021.07.10
                    Time: 12:00:17
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4F0 910 760     HW: 4L0 959 760
   Component: Sitzmemory BFS  H01 0100
   Revision: 00000000    Serial number: 00000000896401
   Coding: 0078944
   VCID: 619FACA52D42E533E0D-8034
Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
   Part No SW: 4L1 910 732 G    HW: 4E0 035 729
   Component: Interfacebox    H43 5570
   Revision: 00000000    Serial number: 386G/077547275
   Coding: 0002002
   VCID: 2E0507992C1C0A4B2DF-807A
   Subsystem 1 - Part No: 4L0 910 609
   Component: E0380 BedienteilH01 0060
   Subsystem 2 - Serial number: 00000000815231
   Subsystem 3 - Serial number: 0119.07.070000000100010352ÿ
   Subsystem 4 - Serial number: 010352ÿ
   Part No SW: 4L0 910 043     HW: 4L0 820 043 F
   Component: KLIMABETAETIGUNGH05 0060
   Revision: 00---012    Serial number: 00000030053824
   Coding: 0001046
                    Reset counter: 1
                    Mileage: 162684 km
                    Date: 2007.06.03
                    Time: 14:47:25
                    Voltage: 12.00 V
   Part No SW: 4F0 910 279 J    HW: 4F0 907 279 A
   Component: ILM Fahrer      H18 0250
   Coding: 0113121
   VCID: 303919E136281CBB3F3-8064
   Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H10 0100
   Coding: 00064792
   Shop #: WSC 31414
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0090
   Coding: 00150059
   Shop #: WSC 31414
   Part No SW: 4L0 910 110 B    HW: 4L0 035 110
   Component: MP3-Changer     H45 0390
   Revision: 00045004    Serial number: AUZ5ZBG1207357
   VCID: 1E65D7595CBC9ACB9DF-804A
   Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
   Component: 71 AIRBAG AUDI8RH42 0230
   Revision: 03H42000    Serial number: 00399D03AVTL
   Coding: 0014129
   Subsystem 1 - Serial number: 6332QSME32190B37B
   Subsystem 2 - Serial number: 6342QSME33281A07A
   Subsystem 3 - Serial number: 6352QSME33282E2FQ
   Subsystem 4 - Serial number: 6362QSME33511C6DM
   Subsystem 5 - Serial number: 63734SME2B7C0E0BF
   Subsystem 6 - Serial number: 63834SME2E28324B5
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0410
   Revision: 00H02000    Serial number: 90054071870223
   Coding: 0112142
   VCID: 270BF2BD03E65B03EE9-8072
   Component: E0221           H02 0030
Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4L0 920 981 B
   Component: KOMBIINSTR. M73 H21 0220
   Revision: 00600000    Serial number: 6EL391J77
   Coding: 3681458
   Shop #: WSC 62083 067 57207
   VCID: 2313E6AD77DEB723B21-8076
Address 18: Aux. Heat        Labels: 4L0-910-105.lbl
   Part No SW: 4L0 910 105     HW: 4L0 815 071 D
   Component: Heizgeraet      H08 0080
   Revision: 0000000C    Serial number: 00000009014264
   Coding: 0000001
   VCID: 6099A9A12648EC3BEF3-8034
01412 - Glow-Plug with Flame Monitoring (Q8)
02251 - Heater Unit Locked
Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
   Part No SW: 4L0 910 468 A    HW: 4L0 907 468 C
   Component: J533__Gateway   H06 0060
   Revision: 00H06000    Serial number: 1000D076128157
   Coding: F5DBBF7F74720200
   Shop #: WSC 00652 210 91784
   VCID: 2D070095211A7153145-8078
Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 B
   Component: SG ext.Player H09 0850
   Revision: 00000000
   VCID: 2B030E8D130E7F630A1-807E
Address 34: Level Control        Labels: 4L0-910-553.lbl
   Part No SW: 4L0 910 553 C    HW: 4L0 907 553
   Component: LUFTFDR.-CDC    H03 7660
   Revision: --H03001    Serial number: 15.1528-0096.2
   Coding: 0015510
   Shop #: WSC 64466 001 1048576
   VCID: 2A0D0B8910F4666BF17-807E
7 Faults Found:
00776 - Level Control System Sensor; Left Front (G78)
                    Reset counter: 3
                    Mileage: 162780 km
                    Date: 2007.06.04
                    Time: 10:34:22
                    Error Code: 24
01772 - Signal from Level Control Pressure Sensor (G291)
                    Fault Frequency: 189
                    Reset counter: 3
                    Mileage: 160555 km
                    Date: 2007.03.08
                    Time: 08:39:44
                    Error Code: 78
            013 - Check DTC Memory
                    Fault Status: 11101101
                    Reset counter: 219
                    Mileage: 164035 km
                    Date: 2021.07.20
                    Time: 10:25:28
                    Error Code: 98
01780 - Sensor for Vehicle Leveling
                    Fault Status: 00100011
                    Reset counter: 3
                    Mileage: 164031 km
                    Date: 2021.07.18
                    Time: 16:22:19
                    Error Code: 31
01583 - Leak in System Detected
                    Fault Frequency: 92
                    Reset counter: 2
                    Mileage: 161285 km
                    Date: 2007.03.25
                    Time: 10:54:14
                    Error Code: 70
02250 - Function Deactivation; Valve Duty Cycle
                    Fault Status: 00100001
                    Reset counter: 3
                    Mileage: 164034 km
                    Date: 2021.07.18
                    Time: 16:27:47
                    Error Code: 46
01577 - Turn-Off due to Over-Temp
                    Reset counter: 3
                    Mileage: 164035 km
                    Date: 2021.07.19
                    Time: 07:37:33
                    Error Code: 68
   Component: Sitzmemory FS   H01 0100
   Coding: 0074858
01447 - Sensor for Driver Seat; Height Adjust (G231)
                    Fault Status: 01100101
                    Reset counter: 219
                    Mileage: 160548 km
                    Date: 2007.03.07
                    Time: 06:50:14
   Part No SW: 4E0 910 887 T    HW: 4E0 919 887 M
   Component: MNS ECE         H50 1030
   Revision: 00000000    Serial number: 399G 077582720
   Shop #: WSC 00652 210 91743
   VCID: 3E2537D9FC7CFACBBDF-806A
   Part No SW: 4L0 910 566 B    HW: 4L0 907 566 A
   Component: J0769_SWA_MasterH07 0070
   Revision: 00H07000    Serial number: 6PZ 009 014-00
   Coding: 0001101
   Subsystem 1 - Part No: 4L0 910 568 B
   Component: J0770_SWA_Slave_H06 0070
   Subsystem 2 - Serial number: 6PZ 009 014-20
   Subsystem 3 - Serial number: 3F20.06.0700H0600000010217ÿ
   Subsystem 4 - Serial number: 010217ÿ
02857 - Supply Voltage for Lane Change Assistance Control Module 2
                    Reset counter: 248
                    Mileage: 163652 km
                    Date: 2021.07.05
                    Time: 12:41:48
                    Reset counter: 248
                    Mileage: 163652 km
                    Date: 2021.07.05
                    Time: 12:41:50
Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
   Component: TSG FA          H12 0150
   Revision: 00000000    Serial number: Y‡”
   Coding: 0019163
   VCID: 2F3B1A9D2B160343269-807A
   Part No SW: 4L0 910 289 F    HW: 4L0 907 289 C
   Component: Komfortgeraet   H07 0040
   Revision: 0040 ---    Serial number: 01054074380000
   Coding: 7610619
   Subsystem 2 - Part No: 4F0 910 177
   Component: Innenraumueberw.H01 0020
Address 47: Sound System        Labels: 4L0-910-223-BO.lbl
   Part No SW: 4L0 910 223 G    HW: 4L0 035 223 D
   Component: DSP-High AU716  H03 0150
   Revision: PROD_01     Serial number: 00000000035274
   Coding: 0000023
   VCID: 2809F1810EF8547BE73-807C
02247 - Subwoofer (R148/R157)
                    Fault Status: 00111011
                    Reset counter: 4
                    Mileage: 160551 km
                    Date: 2007.03.07
                    Time: 06:53:08
   Part No SW: 4F0 910 280     HW: 4F0 907 280 E
   Component: ILM Beifahrer   H12 0100
   Revision:             Serial number: 00000000026594
   Coding: 0011101
   VCID: 5EE597591C3CDACBDDF-800A
Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
   Component: TSG BF          H12 0150
   Revision: 00-00000
   Coding: 0019163
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Coding: 0000022
   Component: AFS-Modul links H06 0002
   Component: AFS-Modul rechtsH06 0002
   Part No SW: 4E0 910 541 T    HW: 4E0 035 541 S
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 388G 077636632
   Coding: 0000001
   VCID: 313F1CE53D2215B330D-8064
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4L0 910 181 A    HW: 4L0 915 181
   Component: J0644 BEM       H12 0690
   Revision: --------    Serial number: 00000000013994
   VCID: 2517F8B579EA4913DC5-8070
   Subsystem 1 - Part No: 4F0 915 105 D
   Component: von VA0  VAO3EAA0EQ
   Coding: 344630393135313035442056413056414F33454141304551
   Shop #: WSC 64240 001 1048576
                    Fault Frequency: 38
                    Mileage: 161206 km
                    Date: 2007.03.17
                    Time: 17:30:51
Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
   Component: TSG HL          H21 0150
   Coding: 0018442
   Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
   Component: SDS 3502 UK     H46 0630
   Revision: 00000000    Serial number: 00000707050039
   Shop #: WSC 12336 024 394758
   VCID: 36352FF9D44C328B65F-8062
   Part No SW: 4L0 910 945     HW: 4L0 827 851 C
   Component: ValeoHeckdeckel H24 0280
   Revision: --H24001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C81CD91DA80B85B43B-8038
   Subsystem 3 - Serial number: RD20.07.07--H24001001B0137ÿ
   Subsystem 4 - Serial number: 1B0137ÿ
   Component: ILM HINTEN 2    H05 0060
   Revision: AAH05061    Serial number: 002930182-----
   Coding: 0003587
   VCID: 2615FFB904EC420BD5F-8072
   Subsystem 1 - Part No: 4L0 910 591
   Component: J_245_EE16_SKB09H10 0200
   Subsystem 2 - Part No: 4L0 910 591
   Component: J_394_EE16_SKB09H10 0200
   Subsystem 3 - Part No: 4L0 910 591
   Component: J_392_EE16_SKB09H10 0200
Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
   Component: TSG HR          H21 0150
   Coding: 0018442
   Part No SW: 4F0 910 283 H    HW: 4F0 919 283 H
   Component: Parkhilfe 8-Kan H12 0080
   Revision: 00H12000    Serial number: 06330719006734
   Coding: 0201146
   Part No SW: 4E0 910 336 M    HW: 4E0 862 335
   Component: Handyvorb2      H16 1130
   Revision: 00000000    Serial number: 00000007625741
   Coding: 0010900
   Shop #: WSC 00251 210 91224
   VCID: 2C010D911A00785B03B-8078
End----(Elapsed Time: 02:35, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
This is the second autoscan AFTER clearing the codes:[/B]
Tuesday,20,July,2021,20:03:08:46323
   Coding: 0011775
   Coding: 0000504
   Revision: 00H30001
   Coding: 0103569
                    Reset counter: 219
                    Mileage: 164035 km
                    Date: 2021.07.20
                    Time: 12:00:28
                    Count: 321
                    Count: 288
                    Count: 42752
                    Fault Status: 01100010
                    Reset counter: 219
                    Mileage: 164035 km
                    Date: 2021.07.20
                    Time: 12:20:11
                    Count: 128
                    Count: 2305
                    Count: 128
                    Count: 32768
   Coding: 0000151
   Coding: 0078944
   Coding: 0002002
   Coding: 0001046
   Coding: 0113121
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Coding: 0014129
   Coding: 0112142
   Coding: 3681458
   Coding: 0000001
   Revision: 00000000
   Coding: 0015510
                    Reset counter: 219
                    Mileage: 164035 km
                    Date: 2021.07.20
                    Time: 12:20:08
                    Error Code: 98
                    Fault Status: 11100001
                    Reset counter: 219
                    Mileage: 164035 km
                    Date: 2021.07.20
                    Time: 12:22:45
                    Error Code: 68
   Coding: 0074858
                    Reset counter: 219
                    Mileage: 164032 km
                    Date: 2021.07.20
                    Time: 12:00:27
   Coding: 0001101
   Coding: 0019163
   Coding: 7610619
   Coding: 0000023
                    Reset counter: 4
                    Mileage: 164035 km
                    Date: 2021.07.20
                    Time: 12:03:41
   Coding: 0011101
   Revision: 00-00000
   Coding: 0019163
   Coding: 0000022
   Coding: 0000001
   Coding: 0018442
   Coding: 0003587
   Coding: 0018442
   Coding: 0201146
   Coding: 0010900
End----------(Elapsed Time: 02:29, VBatt start/end: 13.8V/13.9V)-----------
No problem, just submitted :)
Verified.
Looks like there might be an issue with your steering angle sensor.
You should also check the air suspension for leaks.
Welcome to toe joys of owning a 14 year old, top-of-the-line Audi. ;)
Foz
Chesterfield, UK
C?ID=443761
Ah that may make sense as the steering wheel was slightly off centre, when it went in for wheel alignment and when i was driving it home from the garage, i noticed it was much more off centre.
So if the steering wheel is quite a way off centre, would that cause the air suspension to have this issue of sitting on the highest setting?
I doubt it. My sense is these are two separate problems.
Was the suspension already misbehaving when you got the vehicle aligned? Because having the suspension at proper "normal" height while doing an alignment is critical to getting it right.
Foz
Chesterfield, UK
C?ID=443761
Not really. But lets say i was sitting in traffic i would notice just sometimes the front suspension would lower ever so slightly, say a few mm then go back to where it was. Other than that, the air suspension has always behaved as it should.
Ive only ever had it set to Comfort level, and rarely touched it and when i did it worked fine.
Although during Covid when i wasnt using the car so much i did notice the front suspension would be quite low after sitting on the drive for a week or so without moving, but would go straight back to its comfort level when i started the car, but this happened only on the front suspension not the rear.
I thought maybe theres a small leak somewhere, but now the front suspension has been stuck in the highest level for over 3 days and its not moved, so i guess there cant be a leak?
My concern is that i have a family camping trip in 2 weeks so im really trying to get it sorted for then, but at the moment im not sure what the actual issue is.
My plan though today is to take it back to the wheel alignment place and ask them to reverse the front settings as i have a print out of what they were before they touched them and see if that works.
So when the wheels are being aligned, what 'height' should they be set to?
Thanks again for your help.
Normal. And the suspension should be properly calibrated before doing the alignment.
If it's stuck at a higher height at one corner, then chances are there valve that's supposed to open when lowering that corner is stuck closed.
PS: Split from this thread
Foz
Chesterfield, UK
C?ID=443761
Ok another update.
Took the car back to the same place that did the wheel alignment and asked them to reverse whatever alignment they did to the front wheels as this is when the problems started. I had the original readout of the wheel alignment before they made any changes to it.
Once they did that, i took the car for a quick run, then headed back to the garage - and hey presto, both the ESP/ABS Fault and Orange Fault light had disappeared from the car.
So the problem that remained is that the BOTH front tyres seem to be stuck in the highest position. So i drove the car around some more with the suspension set at Automatic - and it seemed to go down slightly lower, but still sat quite high. Once the car is stationary, it doesnt seem to matter which level of suspension is chosen, the front height changes but only ever so slightly, yet the rears seem to behave a bit more as expected.
Im still not sure what the issue is now, i may look to use the HEX and get the codes again and see if that brings anything up.
Its like the suspension levels are all out of whack? Is there a way to 'factory reset' the suspension levels at all? Maybe that will work unless someone else has any other areas i need to be looking at?
Foz.
"Factory reset" No, not really,
But I'm starting to wonder if that shop tried to calibrate the suspension and muffed it up?
Maybe clear faults in that module and try calibrating it yourself?
That said, the "Turn-Off due to Over-Temp" DTC bothers me. That typically happens as a result of a leak, which makes the compressor work too hard in an attempt to compensate.
Foz
Chesterfield, UK
C?ID=443761
Ok made some more progress and i think ive found the source of the problem, but my suspension is still unable to alter and its stuck in 'automatic' mode.
So anyhow i found out the location of the sensors and had a look under the front wheels, and hey presto on the passenger side the sensor was just 'dangling' and flopping around out of its usual position. Im wondering if the garage had knocked this out during aligning the wheels maybe - otherwise its a huge co-incidence.
I tried to push the sensor back into its hole, but it wouldn't stay there, is there a clip o something that holds it in place as i cant see how its supposed to stay in place. So i ended up using a tie wrap to hold it for now.
Once i did that and turned the engine on, the cars front end immediately came down and sat 'level' - thank god!
So i got in the car and tried to alter the suspension, but it was stuck in automatic mode, i couldn't choose any other setting on it.
At least i could take it back to get the wheels aligned now as they couldn't finish it due to the car being stuck in LIFT at the front.
So ive just got back now from the garage, wheels all aligned and the car is flat - but i still have this issues where i cant choose any other suspension level setting, its just set to automatic and all the other settings are 'grayed out'.
So i used the HEX to do another autoscan just now, then i cleared the codes, took the car for a run and did another scan - both files are below:
Can anyone interpret what the possile cause may be, also noting th "Turn-Off due to Over-Temp" DTC message from Uwe above? Also another thing that has happened is that my air con has started to blow luke warm air, but only through the passenger side climate control, the drivers side is much more cold - but i cant see any fault codes for that.
So three possible problems remain that i need to sort out:
1 - My suspension is stuck on automatic mode.
2 - What is causing the error "Turn-Off due to Over-Temp" DTC and how can i address that
3 - What could possible be causing the air con to blow luke warm, just on the passenger side on my climate control?
Thanks again for all the help, appreciate it.
Heres my autoscan before i cleared the DTC erros - after i got the wheel aligned and the level sensor tie wrapped back in place:
Monday,26,July,2021,12:49:32:46323
Mileage: 164130km-101985mi   Repair Order:
VIN: WAUZZZ4L68D014380   Mileage: 164130km-101985miles
   Coding: 0011775
   Coding: 0000504
   Revision: 00H30001
   Coding: 0103569
                    Reset counter: 5
                    Mileage: 164103 km
                    Date: 2021.07.25
                    Time: 19:41:53
                    Count: 2241
                    Count: 128
                    Count: 31744
   Coding: 0000151
00192 - Rear Left Door Handle Touch Sensor (G417)
                    Fault Status: 01110111
                    Reset counter: 220
                    Mileage: 164085 km
                    Date: 2021.07.22
                    Time: 13:06:29
                    Reset counter: 4
                    Mileage: 164085 km
                    Date: 2021.07.22
                    Time: 13:06:29
00190 - Driver's Door Handle Touch Sensor (G415)
                    Reset counter: 220
                    Mileage: 164085 km
                    Date: 2021.07.22
                    Time: 13:06:29
                    Reset counter: 220
                    Mileage: 164085 km
                    Date: 2021.07.22
                    Time: 13:06:29
   Coding: 0078944
   Coding: 0002002
   Coding: 0001046
                    Reset counter: 5
                    Mileage: 164103 km
                    Date: 2021.07.25
                    Time: 19:41:55
                    Voltage: 9.10 V
   Coding: 0113121
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Coding: 0014129
   Coding: 0112142
   Coding: 3681458
   Coding: 0000001
   Revision: 00000000
   Coding: 0015510
01437 - Control Position not Learned
                    Fault Status: 11100101
                    Reset counter: 220
                    Mileage: 164085 km
                    Date: 2021.07.22
                    Time: 13:07:39
                    Error Code: 6
                    Reset counter: 5
                    Mileage: 164086 km
                    Date: 2021.07.22
                    Time: 13:13:48
                    Error Code: 78
                    Reset counter: 4
                    Mileage: 164086 km
                    Date: 2021.07.22
                    Time: 13:14:22
                    Error Code: 31
                    Reset counter: 4
                    Mileage: 164091 km
                    Date: 2021.07.22
                    Time: 13:21:07
                    Error Code: 24
   Coding: 0074858
                    Reset counter: 221
                    Mileage: 164084 km
                    Date: 2021.07.22
                    Time: 13:00:37
   Coding: 0001101
   Coding: 0019163
   Coding: 7610619
   Coding: 0000023
                    Fault Frequency: 16
                    Reset counter: 6
                    Mileage: 164103 km
                    Date: 2021.07.22
                    Time: 13:36:19
   Coding: 0011101
   Revision: 00-00000
   Coding: 0019163
   Coding: 0000022
   Coding: 0000001
   Coding: 0018442
   Coding: 0003587
   Coding: 0018442
   Coding: 0201146
   Coding: 0010900
End----(Elapsed Time: 02:27, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
Gateway Installation List:  4L0 910 468 A
i then cleared the log, tool the car for a 20 min drive, and then ran an autoscan again below:
Monday,26,July,2021,13:18:52:46323
Mileage: 164150km-101998mi   Repair Order:
VIN: WAUZZZ4L68D014380   Mileage: 164150km-101998miles
   Coding: 0011775
   Coding: 0000504
   Revision: 00H30001
   Coding: 0103569
   Coding: 0000151
   Coding: 0078944
   Coding: 0002002
   Coding: 0001046
   Coding: 0113121
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Coding: 0014129
   Coding: 0112142
   Coding: 3681458
   Coding: 0000001
   Revision: 00000000
   Coding: 0015510
                    Reset counter: 221
                    Mileage: 164137 km
                    Date: 2021.07.26
                    Time: 12:51:50
                    Error Code: 6
                    Reset counter: 5
                    Mileage: 164139 km
                    Date: 2021.07.26
                    Time: 12:57:58
                    Error Code: 78
   Coding: 0074858
                    Reset counter: 221
                    Mileage: 164136 km
                    Date: 2021.07.26
                    Time: 12:51:50
   Coding: 0001101
   Coding: 0019163
   Coding: 7610619
   Coding: 0000023
                    Reset counter: 6
                    Mileage: 164150 km
                    Date: 2021.07.26
                    Time: 13:12:27
   Coding: 0011101
   Revision: 00-00000
   Coding: 0019163
   Coding: 0000022
   Coding: 0000001
   Coding: 0018442
   Coding: 0003587
   Coding: 0018442
   Coding: 0201146
   Coding: 0010900
End----------(Elapsed Time: 02:26, VBatt start/end: 12.4V/12.3V)-----------
Foz
Chesterfield, UK
C?ID=443761
Ok so i then followed the suspension calibration procedure as Uwe suggested and the suspension now seems to be working fine, i can choose any level i want and it behaves normally, hurrah!
So two issues left to sort:
Working after doing a suspension calibration process: 1 - My suspension is stuck on automatic mode.
3 - What could possible be causing the air con to blow luke warm, just on the passenger side on my climate control? - just checking fuses etc now...
Most likely either a leak, causing the compressor to run too much, too long, or a worn-out compressor.
I'm not familiar enough with the physical layout of that HVAC system to say much. Normally a problem like that would be caused by a problem with one or more of the flaps that control temperature and airflow, but if those aren't moving as they should, I'd expect to see a fault code, and there don't seem to be any. :confused:
