2007 Jetta - Steering Assist and ABS problems
29MarkyV
Washington DC, USA
C?ID=122329
Hi all, I've searched other threads regarding this issue, but nothing seems to cover this exact problem (solutions have worked for the others which haven't for me). 2007 Jetta, MKV, 2.5l Automatic
I upgraded my head unit with an RCD330 and replaced the basic steering wheel to a MK6 with radio controls
Radio, works fine. Steering wheel buttons, horn and lights work fine.
I'm getting yellow steering wheel and ABS warning lights and steering seems like it has no power steering.
I replaced the CANBUS Gateway from 1K0 907 530 K to AD (for battery drain issue)
I replaced the Steering Wheel Control Module from 1K0 953 549 AP to CH (for steering wheel controls)
In VCDS under [44 Steering Assist], I used [Measure Blocks] but it doesn't register any steering wheel angle even though the steering wheel was being turned.
I've tried the method to turn wheel max left and hold 10 seconds, turn wheel max right and hold 10 seconds, drive 10 metres then repeat. That didn't work.
In VCDS I went to [44 Steering Assist], [Basic Setting] and block [060], but I cannot reset anything, it shows ERROR, not available (Imgur image won't load for some reason). Maybe this'll work?
I'm not sure what to do next, any suggestions will be appreciated. Code from this evening is shown below.
Wednesday,21,July,2021,18:53:29:11046
VCDS Version: 21.3.0.0
VIN: 3VWEF71K67M185799   License Plate: 29MARKYV
Mileage: 213560km-132700mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWEF71K67M185799   Mileage: 213560km-132700miles
04-Steering Angle -- Status: Sporadic communication error 1000
44-Steering Assist -- Status: Malfunction 1010
Address 01: Engine        Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 S    HW: 07K 906 032 Q
   Component: 2.5l R5/4V      G   9652
   Revision: --H01---    Serial number: VWZ7Z0G9075947
   Coding: 0000003
   Shop #: WSC 00066 000 00000
   VCID: 3957FD4B7072B443C4-806C
005699 - Please check DTC Memory of Electric Load Controller
               P1643 - 001 -
                    Fault Status: 01100001
                    Fault Frequency: 43
                    Temperature: 38.0°C
                    Temperature: 31.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 11.811 V
049446 - No Communications with Steering Angle Sender (G85)
               U0126 - 008 -  - Intermittent
                    Temperature: 62.0°C
                    Temperature: 48.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 12.446 V
Readiness: 0000 1000
   Part No SW: 09G 927 750 FL    HW: 09G 927 750 FL
   Component: AQ 250 6F           0920
   Revision: 00H69000    Serial number:
   Coding: 0000072
   VCID: 002150AF5328258BC3-8054
   Revision: 00H11001
   Coding: 0021122
   VCID: 73CB0F63129E0E13CE-8026
   Part No SW: 1K0 820 047 GG    HW: 1K0 820 047 GG
   Component: Climatic PQ35   141 0909
   Revision: 00141027    Serial number: 00000000000000
   VCID: 6FC303137EB62AF32A-803A
   Part No SW: 3C0 937 049 AD    HW: 3C0 937 049 AD
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000000628390
   Coding: 04058E0700041500070A00000F000000000959035C0000
   VCID: 6BFB17034AAED6D306-803E
   Component: Wischer 240507 020  0501
   Coding: 00038805
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M01VZ4R
   Coding: 0013889
   VCID: 6CF9141F4FA0D1EB0F-8038
   Subsystem 1 - Part No: 1K0 959 339 F
   Component: BF-Gewichtsens. 007 0005
   Subsystem 2 - Serial number: 6332MSME17383E5EQ
   Subsystem 3 - Serial number: 6342MSME1928642CG
   Subsystem 4 - Serial number: 6351HSME0D3A1943A
   Subsystem 5 - Serial number: 6361HSME0D215A7AG
   Subsystem 6 - Serial number: 63727SME0C750924%
   Subsystem 7 - Serial number: 63827SME0C746200Z
02513 - Belt Force Sensor for Seat Occupied Recognition (G453)
   Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
   Coding: 0001533
   Shop #: WSC 131071 102 209715
   VCID: 7AD5224735F47F5B8D-802E
   Subsystem 1 - Part No: 5K0 959 542 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H31 0037
   Coding: 00000130
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective
00895 - Cruise Control Switch (E45)
            014 - Defective
   Part No SW: 1K0 920 953 P    HW: 1K0 920 953 P
   Component: KOMBIINSTRUMENT 3HL 1610
   Revision: V0003000    Serial number: VWZ7Z0G9075947
   Coding: 0023407
   Shop #: WSC 00066 067 57207
   VCID: 3851F84F4B78AD4B3B-806C
00771 - Fuel Level Sensor (G)
                    Fault Status: 00101010
                    Reset counter: 183
                    Mileage: 213303 km
                    Time: 05:23:43
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0112
   Revision:   H07 01    Serial number: 200110F1001435
   Coding: ED807F07000202001002
   Shop #: WSC 00066 123 12345
   VCID: 69F76D0B4052C4C374-803C
                    Fault Status: 00110100
                    Reset counter: 192
                    Mileage: 285068 km
                    Date: 2046.14.04
                    Time: 05:10:16
                    Reset counter: 176
                    Mileage: 285068 km
                    Date: 2046.14.04
                    Time: 05:10:16
                    Reset counter: 176
                    Mileage: 212910 km
                    Time: 17:11:34
                    Fault Status: 01110100
                    Reset counter: 134
                    Mileage: 284738 km
                    Date: 2045.14.26
                    Time: 01:32:41
                    Mileage: 212910 km
                    Time: 17:11:33
   Component: IMMO            3HL 1610
   Component: J386  TUER-SG FT    1133
   Revision: 32008001    Serial number: 00000543678501
   Coding: 0001205
   VCID: 3B5BE7437A4E8653D6-806E
                    Fault Status: 00101100
                    Reset counter: 191
                    Mileage: 212911 km
00109 - Left Mirror Turn Signal Lamp (L131)
                    Fault Frequency: 21
                    Reset counter: 192
                    Mileage: 213511 km
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.070 H07 1806
   Shop #: WSC 02069 000 90108
   VCID: 3449CC7F5710492B17-8060
02546 - Steering Limit Stop
                    Mileage: 213550 km
                    Temperature: 27.0°C
                    Voltage: 14.40 V
                    Voltage: 14.20 V
   Component:    KSG PQ35 RDK 052 0218
   Coding: 13900F880186083F2904058FB0888F0488DCA0
   VCID: 04295CBF473039ABE7-8050
   Component: J387  TUER-SG BT    1133
   Revision: 32008001    Serial number: 00000020078507
   Coding: 0001204
   VCID: 3C59E45F7F40816BDF-8068
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: Radio         541 5614
   Revision: --------    Serial number: VWZZZ4H6262575
   Coding: 16000400040005
   Shop #: WSC 00078 790 00185
   VCID: 46AD86B7F18CCBBBB9-8012
00849 - S-contact at Ignition/Starter Switch (D)
                    Reset counter: 176
00856 - Radio Antenna
                    Fault Status: 00111011
                    Reset counter: 112
                    Reset counter: 136
                    Mileage: 212911 km
                    Time: 17:51:41
                    Reset counter: 137
                    Mileage: 212915 km
                    Time: 19:31:21
   Component: J388   TUER-SG HL   1120
   Revision: 12006001    Serial number: 00000001443194
   Coding: 0001168
   VCID: 3E5DEE57695C937BF1-806A
                    Fault Status: 00111000
                    Reset counter: 197
                    Mileage: 213296 km
                    Fault Status: 00111100
                    Reset counter: 197
                    Mileage: 213296 km
   Component:    RDK              0440
   Coding: 0100101
   Component: J389   TUER-SG HR   1120
   Revision: 12006001    Serial number: 00000001476912
   Coding: 0001168
   VCID: 3FA393536E569A73FA-806A
End-------------------------(Elapsed Time: 01:56)--------------------------
Clear faults in 03-ABS brakes.
Then try this:
Note: That's done in 03-ABS, not 44-Steering Assist.
Of course it's also possible that there is a some physical problem with the steering angle sensor...
29MarkyV
Washington DC, USA
C?ID=122329
Then try this:
I COULD KISS YOU UWE!!
After running the [Sensor For Angle Steering] and [Steering Limit Stop] tests in the link, the ABS warning went off immediately.
Steering wheel warning was still lit though. I drove about 1km then went to a parking lot, stopped and turned the wheel all the way right for 10 seconds, then all the way left for 10 seconds. When I returned to center, the light went off and I got power steering back.
THANK YOU SO MUCH!! I've been fighting with this every night for a week.
I hope my feedback helps someone else too.
