2021 Audi A6 Sedan
mafi69
Turkey
C?ID=417507
AutoScan: WAUZZZF29MN105510
Monday,19,July,2021,16:22:37:35862
VCDS Version: 21.3.0.0 (x64)  HEX-NET2 CB: 0.4543.4
Data version: 20210318 DS325.0
VIN: WAUZZZF29MN105510   License Plate:
Chassis Type: F2-AU58 (4KE)
Scan: 01 02 03 09 15 16 17 19 22 36 42 44 46 52 5F 65 6C 6D 75 80
          81 A5 AC BB BC CA D6 D7 DE
VIN: WAUZZZF29MN105510   Mileage: 312km-193miles
80-Batt. reg. aux. accum. -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DTPA)       Labels: None
   Part No SW: 05L 906 027 AB    HW: 05L 907 309
   Component: R4 2.0l TDI   H22 1112
   Revision: E1H22---
   Coding: 0A6540322326050C34082000000400000000000000000000
   Shop #: WSC 02664 785 00200
   ASAM Dataset: EV_ECM20TDI01105L906027AB 007005
   ROD: EV_ECM20TDI01105L906027AA_007.rod
   VCID: 6C8AAFE09673360B43B-8038
   Part No SW: 4K0 927 153 AP    HW: 0HK 927 156 B
   Component: 0CJ 20TDI RdW H01 0001
   Revision: --H01---    Serial number: 0000000870
   ASAM Dataset: EV_TCMDL382021 002038
   ROD: EV_TCMDL382021_AU58.rod
   VCID: 7BA89CBCE31DA1B3DA1-802E
   MTF pump:
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 M
   Component: V553 MTFP  003 0582
   Serial number: 75290041210139002486
   Part No SW: 4K0 907 379 T    HW: 4K0 907 379 A
   Component: ESP9 Plus     H06 0857
   Coding: 0CAA49972CA20A9B11A34892227D9292F5B9C0309234508812444949AF9D03
   ROD: EV_ESP9BOSCHCMP_004_AU65.rod
   VCID: 46DE3D48E85F2C5BF5F-8012
   Part No SW: 4N0 907 063 JG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0712
   Coding: 07000943C13900CD074C57881C2F0C68130B33110006009701010A0039321C810A45093242560508000003030041081A0802000044010100000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 017002
   ROD: EV_BCM1BOSCHAU651_017.rod
   VCID: 7CAA9FA0E613A68BD3B-8028
   Subsystem 1 - Part No SW: 4K1 955 119     HW: 4K1 955 119
   Component: J400FRWISCH  063 0740
   Serial number: 00000002104260403791
   Coding: 7DC727
   Component: G397_RLFSS  H06 0004
   Serial number: 41722958X81A955555B0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4K1 941 501 A    HW: 4K1 941 501 A
   Component: E1 - LTM  H09 0086
   Serial number: 16S28.05.2100690583
   Subsystem 4 - Part No SW: 8W0 857 511 F    HW: 8W0 857 511
   Serial number: GX1CE111032124110257
   Interior Light Module:
   Subsystem 5 - Part No SW: 4K0 947 135 AF    HW: 4K0 947 135 AF
   Component: Dachmodul  H42 0416
   Serial number: A00458906
   Coding: 010104
   Subsystem 6 - Part No SW: 80A 907 705 A    HW: 80A 907 705
   Component: J866-EVLS-SG  H09 0210
   Serial number: WA149387000104452268
   Coding: 0A0700
67736 - Databus
          [Camera sensor blocked]
                    Reset counter: 52
                    Mileage: 274 km
                    Date: 2021.07.19
                    Time: 07:31:12
                    average_Voltage_terminals: 12.10 V
                    Outside air temperature sensor-Outside air temperature on CAN: 22.00 °C
                    interior_temperature: 24.50 °C
                    Vehicle speed: 27.20 km/h
66308 - Reading Lamp; Rear Left
          B14EE 01 [008] - Electrical Failure
                    Reset counter: 50
                    Mileage: 243 km
                    Date: 2021.07.18
                    Time: 15:01:03
                    average_Voltage_terminals: 12.00 V
                    Outside air temperature sensor-Outside air temperature on CAN: 27.00 °C
                    interior_temperature: 32.50 °C
                    Vehicle speed: 0.00 km/h
   Part No SW: 4N0 959 655 S    HW: 4N0 959 655 S
   Component: AirbagVW31    H01 2844
   Serial number: 0031EM00TUZ5
   Coding: AACCF0C000C00000985400FFF00D400000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001042
   ROD: EV_AirbaVW31SMEAU65x.rod
   VCID: 4CCA0F60F633D60B23B-8018
   Subsystem 1 - Part No SW: -----------    HW: 480 000 206 21
   Serial number: 3570000000053AC8F55Z
   Subsystem 2 - Part No SW: -----------    HW: 480 000 106 21
   Serial number: 35800000000E3075965M
   Subsystem 3 - Part No SW: -----------    HW: 480 030 806 21
   Serial number: 351002C1C14899603A77
   Subsystem 4 - Part No SW: -----------    HW: 480 030 806 21
   Serial number: 352002C1C14A18B09C8F
   Subsystem 5 - Part No SW: -----------    HW: 480 032 505 21
   Serial number: 355002C1C1441230EDFB
   Subsystem 6 - Part No SW: -----------    HW: 480 032 205 21
   Serial number: 356002C1CCB58690DB6-
   Part No SW: 4N0 907 129 KP    HW: 4N0 907 129 KP
   Component: Lenks.Modul   H03 0009
   ROD: EV_SMLSKLOAU736_AU58.rod
   VCID: 0944F674B9C18323D8D-805C
   Part No SW: 4K0 920 790 E    HW: 4K0 920 790 E
   Component: FBenRDW------ H26 0056
   Coding: 0C8443C2EA8000081600E3409000000008002000
   ASAM Dataset: EV_DashBoardAU65X 002025
   ROD: EV_DashBoardAU65X_002_AU58.rod
   VCID: 2F3078EC67E58D13269-807A
   Part No SW: 4KE 907 468 C    HW: 4K1 907 468 B
   Component: Gateway       H07 0602
   Serial number: F0264346284721
   Coding: 02010001002006405A86000200590032C8380000100000000900000002000000
   ASAM Dataset: EV_Gatew31xAU65x 003220
   ROD: EV_Gatew31xAU65x_AU58.rod
   VCID: 49C43674F941C32318D-801C
   Subsystem 1 - Part No SW: 4K0 951 523 H    HW: 4K0 951 523 H
   Component: E221__MFL  H50 0053
   Subsystem 2 - Part No SW: 4K0 915 181     HW: 4K0 915 181
   Serial number: 74186313002105181069
Address 22: AWD (J492)       Labels:* None
   Part No SW: 4K0 927 755 D    HW: 0CJ 927 749 A
   Component: C8_DL3_N_SD1H02 0021
   Serial number: 2106415375
   Coding: 010C0000
   ASAM Dataset: EV_AWDCQUOD31 001052
   ROD: EV_AWDCQUOD31.rod
   VCID: 363E4D8898BFBCDB65F-8062
   Part No SW: 4M6 959 760     HW: 4M4 959 760
   Component: MEM-FS        009 0064
   Serial number: 00000442280703
   Coding: 01581A400000B4010003010101010000000000000000000000000000004000
   Part No SW: 4M1 959 793 J    HW: 4M1 959 793 D
   Component: TSG FS003 0430
   Serial number: YE007UF404045
   Coding: 001DCB0052000200A009B000
   ROD: EV_DCU2DriveSideMAXHCONT_VW38.rod
   Coding: 94002101010000
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 3236719874D7A0FB497-8066
   Part No SW: 4N0 907 064 EG    HW: 4N0 907 064 G
   Component: BCM2 MLBevo H16 0224
   Coding: 01340000002000E0630980006C00090403034000804302502F0400000504823F001F0600000035
   ASAM Dataset: EV_BCM2CONTIAU651 011009
   ROD: EV_BCM2CONTIAU651_011.rod
   VCID: 78A283B0D22B8AABB73-802C
   ID - sensor:
   Subsystem 2 - Part No SW: 3G0 962 243 D    HW: 3G0 962 243 D
   Component: GEB.F.Heckoef  H17 0908
   Serial number: 38708217
131076 - Antenna for Access/Start Authorization; Right
          B1475 12 [008] - Short to Plus
                    Reset counter: 50
                    Mileage: 241 km
                    Date: 2021.07.18
                    Time: 12:53:02
                    Supply voltages-Terminal 30 power supply: 12.381 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.485 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.360 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 10 04 00
                    antenna_freeze_frame: 00110011 00000010 00000000 01000000
653572 - Bulb for Center Brake Light
          B12C6 15 [008] - Open or Short to Plus
                    Reset counter: 50
                    Mileage: 240 km
                    Date: 2021.07.18
                    Time: 12:10:49
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.457 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.346 V
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 02 0A 94 02 78
                    light_freeze_frame: 00000000 01000001 01100110 01111100
   Part No SW: 4M1 959 792 J    HW: 4M1 959 792 D
   Component: TSG BFS003 0430
   Serial number: YE007UDN08013
   Coding: 001DCB005E000200A009B000
   ROD: EV_DCU2PasseSideMAXHCONT_VW38.rod
   VCID: 45DC3A44D5592743FC5-8010
   Part No SW: 4M2 035 086 A    HW: 4M2 035 086
   Component: MU-TP-N-RW    042 3385
   Serial number: GRO-63327.04.21
   Coding: 15810010804000000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: EV_MUTI_AU27.rod
   VCID: 2A0669F85C07E83BF17-807E
   Multimedia System 1:
   Subsystem 1 - Part No SW: 4K1 919 605 K    HW: 4K1 919 605 F
   Component: DU AU58x Top   H71 0193
   Serial number: BHB00126052103200313
   Subsystem 2 - Part No: V03 959 807 CS
   Component: MIB3_RW_Q319   0373
   Compact disc data bank:
   Component: Gracenote2     4007
   Multimedia System 5:
   Subsystem 4 - Part No SW: 4K1 919 603 K    HW: 4K1 919 603 F
   Component: DU AU58x Bot   H71 0193
   Serial number: BHB00128052103130652
   Volume Control 1:
   Subsystem 5 - Part No SW: 4K1 919 616 B    HW: 4K1 919 616 A
   Component: LSR-D5/C8      H33 0110
   Serial number: 00007521000074097002
   Media socket:
   Subsystem 6 - Part No: 4N1 035 736
005 0005
Address 65: Tire Pressure (J502)       Labels: None
   Part No SW: 4M0 907 273 B    HW: 4M0 907 273 B
   Component: RDKHUFAU736   H06 0010
   Serial number: 30000000097065
   ROD: EV_RDKHUFAU736_AU58.rod
8400898 - Tires 01: Tire  Pressure Warning
          C111B 00 [008] - Pressure too Low
                    Reset counter: 45
                    Mileage: 15 km
                    Date: 2021.07.16
                    Time: 16:46:49
                    Expanded ambient data 6-Vehicle speed: 0.00 km/h
                    Expanded ambient data 6-Outside temperature: 35.50 °C
                    Expanded ambient data 2-Left front tire pressure sensor: nominal pressure: 2.80 bar
                    Expanded ambient data 2-Left front tire pressure sensor: actual pressure: 2.30 bar
                    Expanded ambient data 2-Left front tire pressure sensor: temperature: 36 °C
                    Expanded ambient data 2-Left front tire pressure sensor: identification: 575837454
8400901 - Tires 02: Tire  Pressure Warning
          C111D 00 [008] - Pressure too Low
                    Reset counter: 45
                    Expanded ambient data 6-Outside temperature: Initialization
                    Expanded ambient data 3-Right front tire pressure sensor: nominal pressure: 2.73 bar
                    Expanded ambient data 3-Right front tire pressure sensor: actual pressure: Not available
                    Expanded ambient data 3-Right front tire pressure sensor: temperature: Not available
                    Expanded ambient data 3-Right front tire pressure sensor: identification: 575837149
8400904 - Tires 03: Tire  Pressure Warning
          C111F 00 [008] - Pressure too Low
                    Reset counter: 45
                    Expanded ambient data 4-Left rear tire pressure sensor: nominal pressure: 2.80 bar
                    Expanded ambient data 4-Left rear tire pressure sensor: actual pressure: Not available
                    Expanded ambient data 4-Left rear tire pressure sensor: temperature: Not available
                    Expanded ambient data 4-Left rear tire pressure sensor: identification: 575837465
8400907 - Tires 04: Tire  Pressure Warning
          C1121 00 [008] - Pressure too Low
                    Reset counter: 45
                    Expanded ambient data 5-Right rear tire pressure sensor: no: 2.78 bar
                    Expanded ambient data 5-Right rear tire pressure sensor: actual pressure: Not available
                    Expanded ambient data 5-Right rear tire pressure sensor: temperature: Not available
                    Expanded ambient data 5-Right rear tire pressure sensor: identification: 575837219
   Component: RVC Compact   H18 0250
   Coding: 0285010102002001C20040
   ROD: EV_CamSysRVRVCPANAMLBEv_005_VW53.rod
   VCID: 3338749C8BCDA9F3421-8066
Address 6D: Trunk Elect. (J605)       Labels:* None
   Part No SW: 8W5 959 107 D    HW: 8W5 959 107
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: A2-C744-8791-3
   Coding: 1130
   VCID: 47C0304CEF5535530E9-8012
   Part No SW: 4K2 035 282 A    HW: 4K2 035 282 B
   Component: CB_H_RdW      041 0236
   Serial number: A981E0MS029044
   Coding: 0100E008C04000F6E0
   ASAM Dataset: EV_ConBoxHighAU49X 001004
   ROD: EV_ConBoxHighAU49X.rod
   VCID: 261E9DC8481FCC5BD5F-8072
Address 80: Batt. reg. aux. accum. (A1)       Labels: None
   Part No SW: 4K0 915 101     HW: 4K0 915 101
   Component: MQ-BMS        H20 0127
   Serial number: 21000210802004
   ASAM Dataset: EV_BMS12VLiIonSDIAU49X 001001
   ROD: EV_BMS12VLiIonSDIAU49X.rod
   VCID: 6092CBD06ABB626BEF3-8034
   Part No SW: 4K1 713 041 M    HW: 4K1 713 041 H
   Component: GSM-LL H15 0056
   Serial number: 21.151 41242
   ASAM Dataset: EV_GSMKAMAU581 001005
   ROD: EV_GSMKAMAU581.rod
   VCID: 2D0C62E46DE9FF03145-8078
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4K4 907 107 G    HW: 4K4 907 107
   Component: zFAS Var A    H08 0366
   Coding: 0401820000000000000006000040042C18995200000000800000000000000000001900000000000000000000000000000000000000000000000080000000000000007818008000900000000000000000008040000080
   ASAM Dataset: EV_ZFASAU516 003008
   ROD: EV_ZFASAU516_003.rod
221284 - Front Camera for Driver Assist Systems
          C12B3 FD [008] - View Temporarily Restricted
          [temp view limitations]
                    Reset counter: 52
                    Mileage: 262 km
                    Date: 2021.07.19
                    Time: 00:03:27
                    EyeQ temperatures-CPU: -40 °C
                    EyeQ temperatures-VPM: 33 °C
                    Vehicle speed: 1.39 km/h
                    Front camera: blinding detection-Status: not active
                    Front camera: blinding detection-Blinding detected by light assistance assessment module: No
                    Front camera: blinding detection-Blinding detected by road sign recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by pedestrian recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by lane recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by object recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by distance regulation assessment module: Yes
                    Front camera: blinding detection-Blinding detected by road profile estimation assessment module: No
                    Front camera: blinding detection-Blinding detected by free space recognition assessment module: No
                    Front camera: blinding detection-Request for window defogger for front sensor system due to blinding: Yes
                    Front camera: blinding detection-Glare detected: No
                    Front camera: blinding detection-free view detected once: Yes
Address AC: Reductant Control (J880)       Labels: None
   Part No SW: 80A 907 355 G    HW: 80A 907 355 D
   Component: SCR-Stg-G4H08 0005
   ASAM Dataset: EV_RDCMHelbaAU426 003011
   ROD: EV_RDCMHelbaAU426_003.rod
   Part No SW: 4M1 959 795 J    HW: 4M1 959 795 D
   Component: TSG HFS005 0430
   Serial number: YE007UFB26386
   Coding: 000DC90000000200A008B000
   ROD: EV_DCU2RearDriveMAXHKLO_VW53.rod
   VCID: 48C23370E24B3A2B073-801C
   Component: TSG HBFS005 0430
   Serial number: YE007UFB24126
   ROD: EV_DCU2RearPasseMAXHKLO_VW38.rod
   Coding: 468040058101
   ROD: EV_SunRoofCONTIAU736_009_AU58.rod
   VCID: 75BC8A84C539F7C3AC5-8020
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 4K0 941 572 DC    HW: 4K0 941 572 D
   Component: LMS_MLBevo    H06 0032
   ROD: EV_LMSLeftHELLAAU58X.rod
   VCID: 72B6B198B457E0FB897-8026
Address D7: Light Ctrl Right 2 (A27)       Labels: None
Address DE: Charger 1 for mobile dev (J1146)       Labels:* None
   Part No SW: 4K0 035 502 B    HW: 4K0 035 502 B
   Component: WLC Front     H14 0061
   Coding: 400000
   VCID: 20128BD02A3B226BAF3-8074
End----------(Elapsed Time: 01:45, VBatt start/end: 12.3V/12.3V)-----------
adpmap-01-05L-906-027-AB_WAUZZZF29MN105510-20210719-1933.CSV
;SW:05L-906-027-AB   HW:05L-907-309 ---  Engine
;Component:R4 2.0l TDI   H22 1112, Coding:0A6540322326050C34082000000400000000000000000000
;EV_ECM20TDI01105L906027AB,007005,EV_ECM20TDI01105L906027AA_007.rod
;Monday,19,July,2021,19:33:22:35862
;VCDS Version: Release 21.3.0  Data version: 20210318 DS325.0
;VCID: 6C8AAFE09673360B43B-8038
IDE00263-Injector 1 correction value,8ZH45F4 ,7
IDE00264-Injector 2 correction value,8F8656H ,7
IDE00265-Injector 3 correction value,ARIABX7 ,7
IDE00266-Injector 4 correction value,871AGXG ,7
IDE01096-Particulate Filter Statistics,0 ,1
IDE01711-Blocking of particle filter regeneration,not active ,1
IDE01945-Engine run-in oil pressure,not active ,1
IDE02637-Adaptation for metering quantity measurement,04 ,1
IDE04158-Activation of start/stop function,active ,1
IDE07903-Adaptation of ash mass,0.12 g,2
IDE10309-Adaptation of oxidation catalytic converter ageing,18048 s,2
IDE12048-MAS13895-Adaptation of correction angle position detection bank 1 outlet-Error angle sensor,-129.69 °,4
IDE12048-MAS13896-Adaptation of correction angle position detection bank 1 outlet-Error angle sensor wheel,0.00 °,4
IDE12080-MAS13895-Adaptation of correction angle of crankshaft position detection-Error angle sensor,10.94 °,4
IDE12080-MAS13896-Adaptation of correction angle of crankshaft position detection-Error angle sensor wheel,0.00 °,4
IDE12846-Selection of the start system,Automatic status selection ,1
IDE15783-Adaptation for aging coated particulate filter,0.0000 s,4
Elapsed Time: 00:05
adpmap-02-4K0-927-153-AP_WAUZZZF29MN105510-20210719-1933.CSV
;SW:4K0-927-153-AP   HW:0HK-927-156-B ---  Auto Trans
;Component:0CJ 20TDI RdW H01 0001, Coding:000001
;EV_TCMDL382021,002038,EV_TCMDL382021_AU58.rod
;Monday,19,July,2021,19:33:32:35862
;VCID: 7BA89CBCE31DA1B3DA1-802E
IDE02861-Mechatronic identification,0CK325026AF0CK325031ARM4C08K1175210528 ,38
IDE02862-Production data transmission,006ULFC021216K210528 ,20
IDE04111-Individual gear display,Default ,1
IDE05306-Write/reset automatic start counter,0 ,2
IDE06425-Dynamometer mode: functional-,not activated ,1
IDE06425-ENG98891-Dynamometer mode: functional-Reserved,0 ,1
IDE09374-Draining oil pressure reservoir,OFF ,1
ENG106098-ENG99811-Activation points_GS13-Einsatzpunkte_GS_neg,633.0 mA,4
ENG106098-ENG101455-Activation points_GS13-Einsatzpunkte_GS_pos,824.0 mA,4
ENG106099-ENG99811-Activation points_GS2R-Einsatzpunkte_GS_neg,639.0 mA,4
ENG106099-ENG101455-Activation points_GS2R-Einsatzpunkte_GS_pos,828.0 mA,4
ENG106100-ENG99811-Activation points_GS46-Einsatzpunkte_GS_neg,643.0 mA,4
ENG106100-ENG101455-Activation points_GS46-Einsatzpunkte_GS_pos,835.0 mA,4
ENG169905-Ak0a_EepromData_PK0_Ist_PKP1,6.500 bar,2
ENG169906-Ak0a_EepromData_PK0_Soll_PKP1,6.500 bar,2
ENG169908-Ak0k_EepromData_PK0_Ist_PKP0,2.200 bar,2
ENG169909-Ak0k_EepromData_PK0_Soll_PKP0,3.900 bar,2
ENG179009-Ak0o_EepromData_PK0_Ist_PKP2,0.000 bar,2
ENG179010-Ak0o_EepromData_PK0_Soll_PKP2,16.000 bar,2
ENG129676-ENG98345-ATF_motor_speed_requirement-Activation,keine Vorgabe ,3
ENG129676-ENG129929-ATF_motor_speed_requirement-Motor Speed Requirement,0 /min,3
ENG129673-ENG98353-ATFMotor_Winkelsensor_Adaption-Adaption,not active ,2
ENG129673-ENG98502-ATFMotor_Winkelsensor_Adaption-Data,0 ,2
ENG179011-ENG98345-ATFP2_speed_requirement-Activation,keine Vorgabe ,3
ENG179011-ENG129929-ATFP2_speed_requirement-Motor Speed Requirement,740 /min,3
ENG129677-Dither_amplitude_management,not active ,1
ENG105999-E003_Akk_PKupAkt_PKp0[K1],2.784 bar,2
ENG106000-E004_Akk_PKupAkt_PKp0[K2],3.132 bar,2
ENG99685-E010_Akk_kl[K1].PKp0,2.778 bar,2
ENG103532-E011_Akk_kl[K2].PKp0,3.151 bar,2
ENG125931-ECU_W,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,188
ENG139903-ENG99811-Einsatzpunkte_GS57-Einsatzpunkte_GS_neg,640.0 mA,4
ENG139903-ENG101455-Einsatzpunkte_GS57-Einsatzpunkte_GS_pos,826.0 mA,4
ENG129674-ENG129930-Externe_Wertevorgabe_aktivieren-Externe Wertevorgabe aktivieren,not active ,2
ENG129674-ENG129931-Externe_Wertevorgabe_aktivieren-Vorgabe TATF,Einlesen interner Tatf aktiv ,2
ENG106748-ENG104158-Gangvorgabe_Eingangswelle-Eingangswelle,Welle 1 ,2
ENG106748-ENG98913-Gangvorgabe_Eingangswelle-Sollgang,keine Vorgabe ,2
ENG129675-ENG98569-Getriebe_adaption-Function,0 ,6
ENG129675-ENG129932-Getriebe_adaption-Kalibrierungsart,0 ,6
ENG129675-ENG98840-Getriebe_adaption-Parameter 3,0.0 ,6
ENG106779-ENG100014-Getriebe_spezifische_Uebersetzungen-Daten_Erkennungs_Version,Version 1 ,17
ENG106779-ENG129933-Getriebe_spezifische_Uebersetzungen-Übersetzung Gang 1,14.057 ,17
ENG106779-ENG129934-Getriebe_spezifische_Uebersetzungen-Übersetzung Gang 2,9.660 ,17
ENG106779-ENG129935-Getriebe_spezifische_Uebersetzungen-Übersetzung Gang 3,6.691 ,17
ENG106779-ENG129936-Getriebe_spezifische_Uebersetzungen-Übersetzung Gang 4,4.662 ,17
ENG106779-ENG129937-Getriebe_spezifische_Uebersetzungen-Übersetzung Gang 5,3.255 ,17
ENG106779-ENG129938-Getriebe_spezifische_Uebersetzungen-Übersetzung Gang 6,2.240 ,17
ENG106779-ENG129939-Getriebe_spezifische_Uebersetzungen-Übersetzung Gang 7,1.701 ,17
ENG106779-ENG129940-Getriebe_spezifische_Uebersetzungen-Übersetzung Gang R,12.128 ,17
ENG245654-K0alAda_POfs_P1,0.000 bar,2
ENG179925-K0alAda_POfs_P2,0.000 bar,2
ENG179926-K0alAda_TOfs_P1,0 ms,1
ENG179927-K0alAda_TOfs_P2,0 ms,1
ENG107510-M028_Akk_FlagPKp0_allg.Freigabe,OFF ,1
ENG248471-SvcHyb_MK0Soll_Man_ko,-500.00 Nm,2
ENG248472-SvcHyb_SwK0ZielVorgabe_ko,SVC_K0_ZIEL_AUTO ,1
ENG109348-TCM_VMS,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 ,16
ENG153985-ENG154944-VKU_Ablage_Mittelposition-ATF_Motordrehzahl,3000 /min,9
ENG153985-ENG154945-VKU_Ablage_Mittelposition-ATF_Temperatur,60 °C,9
ENG153985-ENG155134-VKU_Ablage_Mittelposition-Herkunft,UDS-Vorgabe ,9
ENG153985-ENG155352-VKU_Ablage_Mittelposition-Mittelposition_fallend,743 mA,9
ENG153985-ENG155353-VKU_Ablage_Mittelposition-Mittelposition_steigend,772 mA,9
ENG153985-ENG155997-VKU_Ablage_Mittelposition-VSL_Position,Charging ,9
ENG109987-Vorgabe_Reset,No Reset ,1
ENG109988-ENG98569-Vorgabe_Solldruck-Function,VKP1 ,4
ENG109988-ENG103310-Vorgabe_Solldruck-Solldruck,0.000 bar,4
ENG109988-ENG130056-Vorgabe_Solldruck-Vorgabeart,keine Vorgabe ,4
ENG109989-ENG98914-Vorgabe_Ventilstrom-Target value,0.0 mA,4
ENG109989-ENG102564-Vorgabe_Ventilstrom-Ventil,VKP1 ,4
ENG109989-ENG100360-Vorgabe_Ventilstrom-Vorgabetyp,keine Vorgabe ,4
ENG110352-Z067_Vwh_TWh_AbbruchZeit,10000 ms,2
Elapsed Time: 00:13
adpmap-03-4K0-907-379-T_WAUZZZF29MN105510-20210719-1933.CSV
;SW:4K0-907-379-T   HW:4K0-907-379-A ---  ABS Brakes
;Component:ESP9 Plus     H06 0857, Coding:0CAA49972CA20A9B11A34892227D9292F5B9C0309234508812444949AF9D03
;EV_ESP9BOSCHCMP,004011,EV_ESP9BOSCHCMP_004_AU65.rod
;Monday,19,July,2021,19:33:50:35862
;VCID: 46DE3D48E85F2C5BF5F-8012
IDE00001-IDE01211-Production mode-Static current measuring mode,Deactivating ,3
IDE00001-IDE09543-Production mode-Vehicle holding function,Deactivating ,3
IDE00001-MAS16682-Production mode-Production mode after-run monitoring,Deactivating ,3
IDE00820-ENG135838-Activating and deactivating all development messages-EWB_DEV_EPB_01,not activated ,3
IDE00820-ENG167488-Activating and deactivating all development messages-EWB_DEV_ESP_00,not activated ,3
IDE00820-ENG135837-Activating and deactivating all development messages-EWB_DEV_ESP_01,not activated ,3
IDE00820-ENG168450-Activating and deactivating all development messages-EWB_DEV_ESP_03,not activated ,3
IDE00820-ENG135839-Activating and deactivating all development messages-EWB_DEV_RKA_01,not activated ,3
IDE00820-ENG135834-Activating and deactivating all development messages-EWB_S100,not activated ,3
IDE00820-ENG135835-Activating and deactivating all development messages-EWB_S101,not activated ,3
IDE00820-ENG135836-Activating and deactivating all development messages-EWB_S102,not activated ,3
IDE00820-ENG102355-Activating and deactivating all development messages-Internal System Error Number,00 00 ,3
IDE02630-MAS09081-ESP coasting operation-Axis for vehicle speed measurement,Front axle activated ,1
IDE02630-MAS09082-ESP coasting operation-Roller operation ESP: status,not active ,1
IDE02631-Brake disc wiper,normal ,1
IDE08134-Automatic parking brake,activated ,1
IDE08214-Starting assistant: switching behavior,On ,1
IDE08220-Vehicle production mode-,Deactivating ,4
IDE09537-Driver warn. during hill descent,active ,1
IDE09539-Tripping threshold for start-up assist.,normal ,1
IDE09540-ENG101644-Install. position of wheel speed sens.-Wheel FL,regularly ,1
IDE09540-ENG102524-Install. position of wheel speed sens.-Wheel FR,regularly ,1
IDE09540-ENG99883-Install. position of wheel speed sens.-Wheel RL,regularly ,1
IDE09540-ENG99053-Install. position of wheel speed sens.-wheel rr,regularly ,1
IDE09541-Brake direction holding function,OFF ,1
IDE10866-Hold management in production mode,Deactivating ,1
IDE10867-MAS11564-Hold management in transport mode-Local activation,Deactivating ,1
IDE10867-MAS13351-Hold management in transport mode-Automatically take over transport mode,Activating ,1
IDE11038-Automatic closing if error in button for parking brake,not activated ,1
IDE11628-Analysis data: status,activated ,1
IDE12614-Wheel loose detection: position indicator,Default ,1
IDE12615-Wheel loose detection warming sensitivity,0 ,1
ENG135668-auto_hold_seatbelt_evaluation,Activating ,1
ENG135671-ENG135644-Dimmung_EPB_TaLa-Pos1_KL_58xd,1 ,6
ENG135671-ENG135645-Dimmung_EPB_TaLa-Pos2_KL_58xd,1 ,6
ENG135671-ENG135646-Dimmung_EPB_TaLa-Pos3_KL_58xd,10 ,6
ENG135671-ENG135647-Dimmung_EPB_TaLa-Pos4_KL_58xd,25 ,6
ENG135671-ENG135648-Dimmung_EPB_TaLa-Pos5_KL_58xd,60 ,6
ENG135671-ENG135649-Dimmung_EPB_TaLa-Pos6_KL_58xd,100 ,6
ENG135665-Driving_Steering_Recommendation,active ,1
ENG135670-DSDL_EOLCheck,not active ,1
ENG106318-ESP_ASR,ESC_Vollsystem ,1
ENG135666-Fading_Assistant_FBS_HFC_HPS,active ,1
ENG135672-Glaettung_PWM_Dimmung,not active ,1
ENG135673-Nominal_Voltage_dimming,13.00 V,1
ENG135669-Powertrain_Protection,not active ,1
ENG167431-Reset_ESC_Maximal_System_Runtime,valid value stored ,1
ENG153944-RLE_Simulation_Mode,00 00 ,2
ENG100419-text_warning,active ,1
ENG100453-VIN_monitoring,active ,1
Elapsed Time: 00:13
adpmap-09-4N0-907-063-JG_WAUZZZF29MN105510-20210719-1934.CSV
;SW:4N0-907-063-JG   HW:4N0-907-063-AG ---  Cent. Elect.
;Component:BCM1 MLBevo   H10 0712, Coding:07000B43C13900CD074C77881C2F0C68130B33110006009701030A0039321C810A45093242560508000003030041081A0802000044010100000000000000000000
;EV_BCM1BOSCHAU651,017002,EV_BCM1BOSCHAU651_017.rod
;Monday,19,July,2021,19:34:08:35862
;VCID: 7CAA9FA0E613A68BD3B-8028
IDE00001-MAS10842-Production mode-Deactivate exterior lighting,not active ,3
IDE00001-MAS10843-Production mode-Deactivate interior lighting,not active ,3
IDE00001-MAS10844-Production mode-Deactivate rear windshield wiper,not active ,3
IDE00001-MAS10847-Production mode-Deactivate windshield wipers,not active ,3
IDE00001-MAS10848-Production mode-Deactivate left-/right hand driving switch-over,not active ,3
IDE00001-MAS10849-Production mode-Switch parking assist to mute,not active ,3
IDE00001-MAS10850-Production mode-Deactivate massage function,not active ,3
IDE00001-MAS10871-Production mode-Deactivate AC compressor,not active ,3
IDE00001-MAS13264-Production mode-Activate headlamp cleaning system directly,not active ,3
IDE00001-MAS15400-Production mode-Continuation of basic settings without tester,not active ,3
IDE00001-MAS15622-Production mode-Cleaning of rearview camera: changed actuation time,not active ,3
IDE00001-MAS16746-Production mode-Deactivate air recirculation door,not active ,3
IDE01169-Audio lowering request,On ,1
IDE01476-Store air recirculation setting with terminal 15 OFF,According to country version ,1
IDE01482-After-run of parking heater or parking ventilation,activated ,1
IDE01485-Shut-off temperature for solar sunroof,-35 °C,1
IDE01493-Sensitivity of air quality sensor,Medium ,1
IDE01495-After-run time of auxiliary heater with air conditioner off,120 s,1
IDE01500-Reduction of window condensation with high humidity,Matching coding ,1
IDE01501-Air leak to footwell,automatic ,1
IDE01503-Running time of basic setting for compressor break-in,60 s,1
IDE01506-Tolerance range for flap end stops,0 ,1
IDE01536-Post heating of auxiliary heating,10 min,1
IDE01550-Service position,153.00 ,2
IDE01996-SFT00009-Installation list: specified installations-Electronic central electric,installed ,1
IDE01996-SFT00041-Installation list: specified installations-Left light control,not installed ,1
IDE01996-SFT00057-Installation list: specified installations-Right light control,not installed ,1
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2,installed ,1
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2,installed ,1
IDE01996-SFT00216-Installation list: specified installations-Projection module in left matrix headlamp,not installed ,1
IDE01996-SFT00217-Installation list: specified installations-Projection module in right matrix headlamp,not installed ,1
IDE01996-SFT33232-Installation list: specified installations-Central control for digital matrix light,not installed ,1
IDE03641-Presentation run dynamic AFS light,not active ,1
IDE03782-Switch-off speed for parking assist,10 ,1
IDE05274-Acoustic warning for rear lid assistant,not active ,1
IDE05318-Retrofitted components installed,Default ,1
IDE05569-Compressor control in efficiency mode,Comfort mode ,1
IDE06547-Air distribution for production routines,Air distribution upper body vents and footwell ,1
IDE06593-Air recirculation for production routines,Recirculating air ,1
IDE06769-Blower regulator for production routines,7 ,1
IDE07356-Position during interval mode,38.49 ,2
IDE08209-Speed of motors,Default ,1
IDE08373-Offset of fresh air blower speed,Default ,1
IDE10118-Fan speed reduction for telephony,Not available ,1
IDE10119-Blower reduction during voice control,available. ,1
IDE10296-upper turn position,174.00 ,2
IDE10297-lower turn position,38.49 ,2
IDE10298-Alternating park position 1,30.00 ,2
IDE10299-Alternating park position 2,35.00 ,2
IDE10307-Presentation mode of multicolor ambient and contour lighting,not active ,1
IDE10321-MAS01364-Seat heater: micro adjust.-Stage 1,0 °C,3
IDE10321-MAS01365-Seat heater: micro adjust.-Stage 2,0 °C,3
IDE10321-MAS01366-Seat heater: micro adjust.-Stage 3,0 °C,3
IDE10322-MAS01364-Seat ventilation: micro adjust.-Stage 1,0 %,3
IDE10322-MAS01365-Seat ventilation: micro adjust.-Stage 2,0 %,3
IDE10322-MAS01366-Seat ventilation: micro adjust.-Stage 3,0 %,3
IDE10331-MAS02201-Roof electronics control module: temperature-related dim.-Temperature,65 °C,2
IDE10331-MAS10404-Roof electronics control module: temperature-related dim.-max. brightness,10 %,2
IDE10362-MAS10458-Electrically adjustable steering column: adjustment speed-axial,47 1/s,2
IDE10362-MAS10462-Electrically adjustable steering column: adjustment speed-vertical,47 1/s,2
IDE10363-Electrically adjust. steering column: entry assist.,56 1/s,1
IDE10364-Electrically adjust. steering column: soft stop,3 ,1
IDE10661-Deactivation of start-stop function (climate control),not active ,1
IDE10729-Runtime measurement,on task level ,1
IDE10914-Seat occupancy-depending A/C,Matching coding ,1
IDE11217-Show parking space,not activated ,1
IDE11549-Automatic query of the identification data on LIN-Bus,activated: no backup ,1
IDE11613-MAS01364-Rear seat ventilation: micro adjustment-Stage 1,0 %,3
IDE11613-MAS01365-Rear seat ventilation: micro adjustment-Stage 2,0 %,3
IDE11613-MAS01366-Rear seat ventilation: micro adjustment-Stage 3,0 %,3
IDE11794-MAS13241-Fragrance diffuser system control module-Aroma 1,6 ,2
IDE11794-MAS13242-Fragrance diffuser system control module-Aroma 2,7 ,2
IDE11954-Automatic activation of parking distance control,active ,1
IDE12224-MAS14154-Rear parking aid warning buzzer with open convertible top-Volume at Level 1,4 ,2
IDE12224-MAS14155-Rear parking aid warning buzzer with open convertible top-Increment between the volume levels,20 ,2
IDE12225-MAS14154-Front parking aid warning buzzer with open convertible top-Volume at Level 1,4 ,2
IDE12225-MAS14155-Front parking aid warning buzzer with open convertible top-Increment between the volume levels,20 ,2
IDE12291-A/C control and display heads: dimming,Dimming: no dimming when approaching ,1
IDE13059-Cleaning of rearview camera: actuation time in production mode,2500 ms,2
IDE13064-Wiper motor control module: dataset,41 01 06 04 00 B9 00 B9 00 64 00 96 05 32 00 0A 00 E6 05 32 00 55 00 55 28 3C 14 04 78 1E 23 00 28 2B 2E 32 37 3A 3C 00 B9 01 FE 05 6E 00 1E 50 00 23 96 00 2D C8 00 3C FA 00 00 00 14 B8 AE 42 4C 78 96 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 EB 05 B0 ,90
IDE13354-Wiper motor control module: dataset 2,41 02 04 04 B4 64 0A 0A 05 05 0A 04 0A 00 03 0A 32 32 32 14 14 14 14 14 14 14 14 14 14 1E 5A 05 01 02 01 05 05 01 02 01 03 04 03 04 04 0C 6E 04 04 0C 01 04 04 00 00 00 00 00 00 00 00 00 00 00 00 00 9F 01 68 BD ,70
IDE13355-Wiper motor control module: dataset 3,30 00 01 6C 00 00 0F A0 FF FF F6 3C FF FF E0 C0 FF FF B9 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 34 00 44 00 ,50
IDE13356-Wiper motor control module: dataset 4,5A 10 00 00 00 00 00 00 00 00 00 00 00 00 00 34 4B 31 39 35 35 31 31 39 20 20 34 4B 31 39 35 35 31 31 39 20 20 30 36 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8C CB 0B 69 ,70
MAS01426-Rear parking aid buzzer: volume,Stage 4 ,1
MAS01427-Speaker frequency for rear park assist,Stage 6 ,1
MAS01428-Front parking aid buzzer: volume,Stage 1 ,1
MAS01429-Speaker frequency for front park assist,Stage 4 ,1
MAS12843-Maneuvering brake function,activated ,1
MAS15621-Restart information,activated ,1
ENG264023-ENG264129-evls_pso_data_1-Axialposition,77 ,2
ENG264023-ENG264281-evls_pso_data_1-Vertikalposition,100 ,2
ENG264024-ENG264129-evls_pso_data_2-Axialposition,77 ,2
ENG264024-ENG264281-evls_pso_data_2-Vertikalposition,48 ,2
ENG264034-ENG264129-evls_pso_data_3-Axialposition,77 ,2
ENG264034-ENG264281-evls_pso_data_3-Vertikalposition,48 ,2
ENG264031-ENG264129-evls_pso_data_4-Axialposition,100 ,2
ENG264031-ENG264281-evls_pso_data_4-Vertikalposition,100 ,2
ENG264020-ENG264129-evls_pso_data_5-Axialposition,100 ,2
ENG264020-ENG264281-evls_pso_data_5-Vertikalposition,100 ,2
ENG264019-ENG264129-evls_pso_data_6-Axialposition,100 ,2
ENG264019-ENG264281-evls_pso_data_6-Vertikalposition,100 ,2
ENG264026-ENG264129-evls_pso_data_7-Axialposition,100 ,2
ENG264026-ENG264281-evls_pso_data_7-Vertikalposition,100 ,2
ENG133836-Fehlermaske 2,00 00 00 00 ,4
ENG117283-Frontwaschfunktion,20 ,2
ENG133832-sLWR_counter_left,0 ,4
ENG133833-sLWR_counter_right,0 ,4
Elapsed Time: 01:50
adpmap-15-4N0-959-655-S_WAUZZZF29MN105510-20210719-1936.CSV
;SW:4N0-959-655-S   HW:4N0-959-655-S ---  Airbags
;Component:AirbagVW31    H01 2844, Coding:AACCF0C000C00000985400FFF00D400000C5
;EV_AirbaVW31SMEAU65x,001042,EV_AirbaVW31SMEAU65x.rod
;Monday,19,July,2021,19:36:04:35862
;VCID: 4CCA0F60F633D60B23B-8018
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not active ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not active ,1
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not active ,1
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not active ,1
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not active ,1
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not active ,1
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not active ,1
IDE02332-Deactivate production mode,Deactivating ,3
IDE05178-Conclude start of operation,completed ,1
IDE06314-Calibration data: pre-crash,02 40 3B FF FE 80 00 7F 00 00 00 00 C0 00 14 D0 10 98 ,18
IDE06527-IDE06311-Adaptation pre-crash-Left seat belt tensioner,not defined ,4
IDE06527-IDE06312-Adaptation pre-crash-Right seat belt tensioner,not defined ,4
IDE06527-IDE07271-Adaptation pre-crash-Belt tensioner second row right,not defined ,4
IDE06527-IDE07274-Adaptation pre-crash-Belt tensioner second row left,not defined ,4
IDE06527-IDE12159-Adaptation pre-crash-Belt feed control module for 2nd row left,not defined ,4
IDE06527-IDE12160-Adaptation pre-crash-Belt feed control module for 2nd row right,not defined ,4
IDE09601-IDE03311-Adaptation PreCrash functions-Emergency braking display,not defined ,16
IDE09601-IDE03633-Adaptation PreCrash functions-Close sunroof,not defined ,16
IDE09601-IDE03634-Adaptation PreCrash functions-Close windows,not defined ,16
IDE09601-IDE09602-Adaptation PreCrash functions-Locale hazard warning,not defined ,16
IDE09601-IDE09603-Adaptation PreCrash functions-RECAS,not defined ,16
IDE09601-IDE09604-Adaptation PreCrash functions-Seat adjustment - backrest,not defined ,16
IDE09601-IDE09605-Adaptation PreCrash functions-Seat adjust. - side bolster,not defined ,16
IDE09601-IDE09606-Adaptation PreCrash functions-Seat adjustment - headrests,not defined ,16
IDE09601-IDE09607-Adaptation PreCrash functions-PreCrash Front,not defined ,16
IDE09601-IDE09608-Adaptation PreCrash functions-Seat belt slack reduction: left,not defined ,16
IDE09601-IDE09609-Adaptation PreCrash functions-Seat belt slack reduction: right,not defined ,16
IDE09601-IDE09610-Adaptation PreCrash functions-Seat belt slack reduction: 2nd row left,not defined ,16
IDE09601-IDE09611-Adaptation PreCrash functions-Seat belt slack reduction: 2nd row right,not defined ,16
IDE09601-IDE09612-Adaptation PreCrash functions-Seat belt slack reduction: 2nd row ctr.,not defined ,16
IDE09601-IDE09613-Adaptation PreCrash functions-Seat belt slack reduction: 3rd row left,not defined ,16
IDE09601-IDE09614-Adaptation PreCrash functions-Seat belt slack reduction: 3rd row right,not defined ,16
IDE09601-IDE09615-Adaptation PreCrash functions-Seat belt slack reduction: 3rd row ctr.,not defined ,16
IDE09601-IDE09616-Adaptation PreCrash functions-Reversible belt tensioning left,not defined ,16
IDE09601-IDE09617-Adaptation PreCrash functions-Reversible belt tensioning right,not defined ,16
IDE09601-IDE09618-Adaptation PreCrash functions-Reversible belt tensioning: act. code of seat belt tightenert,not defined ,16
IDE09601-IDE09619-Adaptation PreCrash functions-Reversible belt tensioning: 2nd row right,not defined ,16
IDE09601-IDE09620-Adaptation PreCrash functions-Reversible belt tensioning: 2nd row ctr.,not defined ,16
IDE09601-IDE09621-Adaptation PreCrash functions-Reversible belt tensioning: 3rd row left,not defined ,16
IDE09601-IDE09622-Adaptation PreCrash functions-Reversible belt tensioning: 3rd row right,not defined ,16
IDE09601-IDE09623-Adaptation PreCrash functions-Reversible belt tensioning: 3rd row ctr.,not defined ,16
IDE09601-MAS00478-Adaptation PreCrash functions-Reserved,2 ,16
IDE09601-MAS03834-Adaptation PreCrash functions-Emergency signal flashing,not defined ,16
IDE09601-MAS09950-Adaptation PreCrash functions-LED bar activation,not defined ,16
IDE09601-MAS15067-Adaptation PreCrash functions-Belt parking 1st row,not defined ,16
IDE09601-MAS15068-Adaptation PreCrash functions-Belt parking 2nd row,not defined ,16
IDE09601-MAS15069-Adaptation PreCrash functions-Measurement recording,activated ,16
IDE09601-MAS15070-Adaptation PreCrash functions-BAP resistance PreSense system,not resistant ,16
IDE09601-MAS15071-Adaptation PreCrash functions-BAP resistance PreSense warning,not resistant ,16
IDE09601-MAS15072-Adaptation PreCrash functions-BAP resistance: distance warning,not defined ,16
IDE09601-MAS15073-Adaptation PreCrash functions-BAP resistance: turning assistance,not defined ,16
IDE09601-MAS15074-Adaptation PreCrash functions-BAP resistance proactive passenger cover,not resistant ,16
IDE12055-IDE12056-Adaptation airbag 2-Igniter for interaction airbag 2nd row: driver side,not defined ,8
IDE12055-IDE12057-Adaptation airbag 2-Igniter for interaction airbag 2nd row: driver side,not defined ,8
IDE12055-IDE12258-Adaptation airbag 2-Assistance-System-Monitor,activated ,8
IDE12055-IDE14239-Adaptation airbag 2-Igniter for high-voltage battery 2 open circuit,not defined ,8
IDE12055-IDE14240-Adaptation airbag 2-Driver side seat occupancy detection,not defined ,8
IDE12055-MAS00478-Adaptation airbag 2-Reserved,2 ,8
IDE12733-Calibration data: pre-crash 2,03 40 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,30
IDE12735-MAS00478-Adaptation PreCrash functions 2-Reserved,2 ,32
IDE12735-MAS10765-Adaptation PreCrash functions 2-Automatic emergency braking due to vehicle,not defined ,32
IDE12735-MAS11351-Adaptation PreCrash functions 2-Automatic emergency braking due to pedestrian,not defined ,32
IDE12735-MAS15075-Adaptation PreCrash functions 2-Warning - pedestrians,not defined ,32
IDE12735-MAS15076-Adaptation PreCrash functions 2-Warning - cyclist,not defined ,32
IDE12735-MAS15077-Adaptation PreCrash functions 2-Warning - vehicles,not defined ,32
IDE12735-MAS15078-Adaptation PreCrash functions 2-Warning - various objects,not defined ,32
IDE12735-MAS15079-Adaptation PreCrash functions 2-HBA threshold adaptation - pedestrians,not defined ,32
IDE12735-MAS15080-Adaptation PreCrash functions 2-HBA threshold adaptation - cyclists,not defined ,32
IDE12735-MAS15081-Adaptation PreCrash functions 2-HBA threshold adaptation - vehicles,not defined ,32
IDE12735-MAS15082-Adaptation PreCrash functions 2-HBA threshold adaptation - various objects,not defined ,32
IDE12735-MAS15083-Adaptation PreCrash functions 2-Brake pressure build-up - pedestrians,not defined ,32
IDE12735-MAS15084-Adaptation PreCrash functions 2-Brake pressure buildup - cyclists,not defined ,32
IDE12735-MAS15085-Adaptation PreCrash functions 2-Brake pressure buildup - vehicles,not defined ,32
IDE12735-MAS15086-Adaptation PreCrash functions 2-Brake pressure buildup - various objects,not defined ,32
IDE12735-MAS15087-Adaptation PreCrash functions 2-Brake jolt - pedestrians,not defined ,32
IDE12735-MAS15088-Adaptation PreCrash functions 2-Brake jolt - cyclists,not defined ,32
IDE12735-MAS15089-Adaptation PreCrash functions 2-Brake jolt - vehicles,not defined ,32
IDE12735-MAS15090-Adaptation PreCrash functions 2-Brake jolt - other objects,not defined ,32
IDE12735-MAS15091-Adaptation PreCrash functions 2-Partial braking - pedestrians,not defined ,32
IDE12735-MAS15092-Adaptation PreCrash functions 2-Partial braking - cyclists,not defined ,32
IDE12735-MAS15093-Adaptation PreCrash functions 2-Partial braking - vehicles,not defined ,32
IDE12735-MAS15094-Adaptation PreCrash functions 2-Partial braking - various objects,not defined ,32
IDE12735-MAS15095-Adaptation PreCrash functions 2-Automatic emergency braking - cyclists,not defined ,32
IDE12735-MAS15096-Adaptation PreCrash functions 2-Automatic emergency braking: various objects,not defined ,32
IDE12735-MAS15097-Adaptation PreCrash functions 2-Automatic braking cycle - pedestrians,not defined ,32
IDE12735-MAS15098-Adaptation PreCrash functions 2-Automatic target braking - cyclists,not defined ,32
IDE12735-MAS15099-Adaptation PreCrash functions 2-Automatic braking cycle - vehicles,not defined ,32
IDE12735-MAS15100-Adaptation PreCrash functions 2-Automatic target braking - various objects,not defined ,32
IDE12735-MAS15101-Adaptation PreCrash functions 2-Driver initiated braking cycle - pedestrians,not defined ,32
IDE12735-MAS15102-Adaptation PreCrash functions 2-Driver initiated braking cycle - cyclists,not defined ,32
IDE12735-MAS15103-Adaptation PreCrash functions 2-Driver initiated braking cycle - vehicles,not defined ,32
IDE12735-MAS15104-Adaptation PreCrash functions 2-Driver initiated target braking - various objects,not defined ,32
IDE12735-MAS15105-Adaptation PreCrash functions 2-Oncoming vehicle braking when turning,not defined ,32
IDE12735-MAS15106-Adaptation PreCrash functions 2-Distance warning,not defined ,32
IDE12735-MAS15107-Adaptation PreCrash functions 2-Drivetrain actuation,not defined ,32
MAS00975-IDE00947-Airbag adaptations-Driver side rear curtain airbag igniter,not defined ,8
MAS00975-IDE00948-Airbag adaptations-Frt.passenger side rear curtain airbag igniter,not defined ,8
MAS00975-IDE02852-Airbag adaptations-Battery Interrupt Igniter High-Voltage Battery,not defined ,8
MAS00975-IDE07190-Airbag adaptations-Igniter for battery open circuit 2nd battery,activated ,8
MAS00975-IDE07192-Airbag adaptations-Thorax airbag igniter,not defined ,8
MAS00975-IDE08436-Airbag adaptations-Driver side seat belt tensioner igniter 3,not defined ,8
MAS00975-IDE08437-Airbag adaptations-Front passenger side third row seat belt tensioner igniter,not defined ,8
MAS00975-IDE12208-Airbag adaptations-Igniter for deactivation of A/C system 1,not defined ,8
MAS00975-IDE12209-Airbag adaptations-Igniter for deactivation of A/C system 2,not defined ,8
MAS00975-MAS00003-Airbag adaptations-Front passenger airbag igniter,activated ,8
MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,not defined ,8
MAS00975-MAS00020-Airbag adaptations-Passenger side rear seat belt tensioner igniter,activated ,8
MAS00975-MAS00021-Airbag adaptations-Center rear seat belt tensioner igniter,not defined ,8
MAS00975-MAS00022-Airbag adaptations-Battery Interrupt Igniter,activated ,8
MAS00975-MAS00023-Airbag adaptations-Driver side active head restraint igniter,not defined ,8
MAS00975-MAS00024-Airbag adaptations-Igniter for active head restraint on frt. passenger side,not defined ,8
MAS00975-MAS00079-Airbag adaptations-Key switch,Airbag deactivation key switch installed ,8
MAS00975-MAS00231-Airbag adaptations-Seat occupied recognition passenger side,activated ,8
Elapsed Time: 00:09
adpmap-16-4N0-907-129-KP_WAUZZZF29MN105510-20210719-1936.CSV
;SW:4N0-907-129-KP   HW:4N0-907-129-KP ---  Steering wheel
;Component:Lenks.Modul   H03 0009, Coding:
;EV_SMLSKLOAU736,007012,EV_SMLSKLOAU736_AU58.rod
;Monday,19,July,2021,19:36:17:35862
;VCID: 0944F674B9C18323D8D-805C
IDE00820-IDE80001-Activating and deactivating all development messages-Analysis 1,OFF ,1
IDE00820-IDE80002-Activating and deactivating all development messages-Analysis 2,OFF ,1
IDE00820-IDE80003-Activating and deactivating all development messages-Analysis 3,OFF ,1
IDE00820-IDE80004-Activating and deactivating all development messages-Analysis 4,OFF ,1
IDE00820-IDE80005-Activating and deactivating all development messages-Analysis 5,OFF ,1
IDE12365-Switching off the MFL buttons during dynamic driving,On ,1
Elapsed Time: 00:01
adpmap-17-4K0-920-790-E_WAUZZZF29MN105510-20210719-1931.CSV
;SW:4K0-920-790-E   HW:4K0-920-790-E ---  Instruments
;Component:FBenRDW------ H26 0056, Coding:0C8D43C2EA8000081600E3409000000008002000
;EV_DashBoardAU65X,002025,EV_DashBoardAU65X_002_AU58.rod
;Monday,19,July,2021,19:31:33:35862
;VCID: 2F3078EC67E58D13269-807A
IDE00301-Mileage,312 km,3
IDE00343-Language variant,Turkish ,1
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas,No automatic reset ,3
IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection,No automatic reset ,3
IDE00819-Day counter,27 d,2
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,0.00 l,5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-0.60 l,5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,-12.80 l,5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.70 l,5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.70 l,5
IDE03346-IDE00301-Units adjusted-Mileage,Kilometers ,3
IDE03346-MAS02201-Units adjusted-Temperature,°C ,3
IDE03346-MAS03032-Units adjusted-Volume,Liters ,3
IDE07159-MAS01155-Control module switch-off: counter-Control module,0 ,2
IDE07159-MAS05583-Control module switch-off: counter-Data bus,0 ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 min,2
IDE07221-Cylinder shut-off,Readout ,1
IDE10208-Display correct. of consump. and operating range: elec.,100 %,1
IDE11086-Service notification,0 d,1
IDE11472-IDE03360-Configuration of displayable contents-Upshift display in center panel,No display ,4
IDE11472-MAS05424-Configuration of displayable contents-Natural gas quality,No display ,4
IDE11472-MAS15298-Configuration of displayable contents-Night vision system automatic triggering,not active ,4
IDE11472-MAS18773-Configuration of displayable contents-Acceleration measurement,No display ,4
IDE11472-MAS18774-Configuration of displayable contents-Drag indicator,No display ,4
IDE11472-MAS19085-Configuration of displayable contents-Tailgate position,Variant 1 ,4
IDE11472-MAS19086-Configuration of displayable contents-Charge symbol color,Standard ,4
IDE12050-Acoustic: drive position R,active ,1
IDE12211-China variant,No ,1
IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation,not active ,1
IDE12226-MAS05203-Display of longitudinal regulation coordinator-CCS,not active ,1
IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter,not active ,1
IDE12467-Tubes illustration,Variant 0 ,1
IDE12792-Personalization of user account 1,00 08 00 40 B4 00 00 30 00 00 00 00 00 03 00 00 01 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,70
IDE12794-Personalization of user account 2,00 08 00 00 00 00 00 00 00 00 00 00 00 01 10 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,70
IDE12796-Personalization of user account 3,00 08 00 00 00 00 00 00 00 00 00 00 00 01 10 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,70
IDE12798-Personalization of user account 4,00 08 00 00 00 00 00 00 00 00 00 00 00 01 10 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,70
IDE12800-Personalization of user account 5,00 08 00 00 00 00 00 00 00 00 00 00 00 01 10 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,70
IDE12802-Personalization of user account 6,00 08 00 00 00 00 00 00 00 00 00 00 00 01 10 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,70
IDE12804-IDE00301-Personalization of user account 7-Mileage,Kilometers ,70
IDE12804-MAS01230-Personalization of user account 7-Date,dd_mm_yy ,70
IDE12804-MAS01456-Personalization of user account 7-Speed,Kilometers per hour ,70
IDE12804-MAS02201-Personalization of user account 7-Temperature,°C ,70
IDE12804-MAS02957-Personalization of user account 7-Time,24h ,70
IDE12804-MAS03032-Personalization of user account 7-Volume,Liters ,70
IDE12804-MAS03034-Personalization of user account 7-Pressure,bar ,70
IDE12804-MAS05637-Personalization of user account 7-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12804-MAS05638-Personalization of user account 7-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12804-MAS05875-Personalization of user account 7-Average consumption: electric drive,kWh per 100 km ,70
IDE12804-Personalization of user account 7-,not active ,70
IDE12804-ENG154881-Personalization of user account 7-Active_design,0 ,70
IDE12804-ENG154882-Personalization of user account 7-Active_view,0 ,70
IDE12804-ENG155000-Personalization of user account 7-DC_aktiverSpeicherplatz,0 ,70
IDE12804-ENG155001-Personalization of user account 7-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12804-ENG155002-Personalization of user account 7-DC_linkeTubeninformation,00 ,70
IDE12804-ENG155003-Personalization of user account 7-DC_rechteTubeninformation,00 ,70
IDE12804-ENG155004-Personalization of user account 7-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12804-ENG155005-Personalization of user account 7-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12804-ENG155006-Personalization of user account 7-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12804-ENG155007-Personalization of user account 7-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12804-ENG155008-Personalization of user account 7-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12804-ENG155009-Personalization of user account 7-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12804-ENG155051-Personalization of user account 7-Display_Average_Consumption,not active ,70
IDE12804-ENG155052-Personalization of user account 7-Display_Average_Speed,not active ,70
IDE12804-ENG155053-Personalization of user account 7-Display_ComfortPowerConsumption,not active ,70
IDE12804-ENG155054-Personalization of user account 7-Display_ConsumerList,not active ,70
IDE12804-ENG155055-Personalization of user account 7-Display_CoolantTemperature,not active ,70
IDE12804-ENG155056-Personalization of user account 7-Display_CurrentConsumption,not active ,70
IDE12804-ENG155057-Personalization of user account 7-Display_DigitalSpeedometer,not active ,70
IDE12804-ENG155058-Personalization of user account 7-Display_Distance,not active ,70
IDE12804-ENG155059-Personalization of user account 7-Display_DrivingTime,not active ,70
IDE12804-ENG155060-Personalization of user account 7-Display_DualSpeedometer,not active ,70
IDE12804-ENG155061-Personalization of user account 7-Display_Laptimer,not active ,70
IDE12804-ENG155062-Personalization of user account 7-Display_LiveTips,not active ,70
IDE12804-ENG155063-Personalization of user account 7-Display_Nachtankmenge,not active ,70
IDE12804-ENG155064-Personalization of user account 7-Display_OilTemperature,not active ,70
IDE12804-ENG155065-Personalization of user account 7-Display_Range,not active ,70
IDE12804-ENG155066-Personalization of user account 7-Display_ResetTime,not active ,70
IDE12804-ENG155067-Personalization of user account 7-Display_SpeedWarning,not active ,70
IDE12804-ENG155068-Personalization of user account 7-Display_VZA,not active ,70
IDE12804-ENG155069-Personalization of user account 7-Display_ZeroEmission_Distance,not active ,70
IDE12804-ENG155070-Personalization of user account 7-Display_ZeroEmission_Time,not active ,70
IDE12804-ENG155246-Personalization of user account 7-LastMode_HMI_global_active_layout,0 ,70
IDE12804-ENG155247-Personalization of user account 7-LastMode_HMI_HistoryState_Fahrzeugreiter,1 ,70
IDE12804-ENG155248-Personalization of user account 7-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12804-ENG155249-Personalization of user account 7-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12804-ENG155250-Personalization of user account 7-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12804-ENG155251-Personalization of user account 7-LastMode_HMI_HistoryState_main,0 ,70
IDE12804-ENG155252-Personalization of user account 7-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12804-ENG155253-Personalization of user account 7-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12804-ENG155254-Personalization of user account 7-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12804-ENG155255-Personalization of user account 7-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,13 ,70
IDE12804-ENG155256-Personalization of user account 7-LastMode_HMI_HistoryState_sport,1 ,70
IDE12804-ENG155257-Personalization of user account 7-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12804-ENG155258-Personalization of user account 7-LastMode_HMI_MFA_store,0 ,70
IDE12804-ENG155259-Personalization of user account 7-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12804-ENG155260-Personalization of user account 7-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12804-ENG155261-Personalization of user account 7-LastMode_v_Kunde_aktiv,not active ,70
IDE12804-ENG155262-Personalization of user account 7-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12804-ENG155263-Personalization of user account 7-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12804-ENG155906-Personalization of user account 7-Speed 2,0 ,70
IDE12804-ENG155907-Personalization of user account 7-Speed_warning_unit_mph_/_kmh,Kilometers per hour ,70
IDE12960-Resetting oil service,no warning ,1
IDE12961-Oil quality,poor oil quality ,1
IDE12962-Oil: soot entry,500 km,2
IDE12963-Oil: thermal loading,200 km,2
IDE12964-Oil: driven distance since last oil service,200 km,3
IDE12965-Oil: time since last oil service,3 d,2
IDE12966-Oil: min distance until next oil service (flexible interval),15000 km,2
IDE12967-Oil: max. distance until next oil service (flexible interval),15000 km,2
IDE12968-Oil: min time until next oil service (flexible interval),365 d,2
IDE12969-Oil: max time until next oil service (flexible interval),730 d,2
IDE12970-Oil: distance until next oil service (fixed interval),15000 km,2
IDE12971-Oil: time until next oil service (fixed interval),365 d,2
IDE12978-Inspection: distance until next inspection,15000 km,3
IDE12979-Inspection: time until next inspection,365 d,2
IDE12980-Inspection: distance driven since the last inspection,200 km,3
IDE12981-Inspection: time since the last inspection,3 d,2
IDE12982-Inspection: distance reset value,30000 km,2
IDE12983-Inspection: time reset value,365 d,2
IDE13031-MAS03935-Long-term store-Drive time,752 min,44
IDE13031-MAS15517-Long-term store-Travel distance,312871 m,44
IDE13031-MAS15549-Long-term store-Average speed distance,312868 m,44
IDE13031-MAS15550-Long-term store-Time since average speed,745 min,44
IDE13031-MAS15551-Long-term store-Distance average consumption of VKM,312868 m,44
IDE13031-MAS15552-Long-term store-Consumption average consumption of VKM,27793 ml,44
IDE13031-MAS15553-Long-term store-Distance average consumption of gasoline,0 m,44
IDE13031-MAS15554-Long-term store-Consumption average consumption of gasoline,0 g,44
IDE13031-MAS15555-Long-term store-Distance average consumption of electricity,0 m,44
IDE13031-MAS15556-Long-term store-Consumption average consumption by individual electrics,0.00 kWh,44
IDE13031-MAS15557-Long-term store-Consumption average consumption by BMS electrics,0.00 kWh,44
IDE13275-IDE00301-Personalization default value-Mileage,Kilometers ,70
IDE13275-MAS01230-Personalization default value-Date,dd_mm_yy ,70
IDE13275-MAS01456-Personalization default value-Speed,Kilometers per hour ,70
IDE13275-MAS02201-Personalization default value-Temperature,°C ,70
IDE13275-MAS02957-Personalization default value-Time,24h ,70
IDE13275-MAS03032-Personalization default value-Volume,Liters ,70
IDE13275-MAS03034-Personalization default value-Pressure,bar ,70
IDE13275-MAS05637-Personalization default value-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE13275-MAS05638-Personalization default value-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE13275-MAS05875-Personalization default value-Average consumption: electric drive,kWh per 100 km ,70
IDE13275-Personalization default value-,not active ,70
IDE13275-ENG154881-Personalization default value-Active_design,0 ,70
IDE13275-ENG154882-Personalization default value-Active_view,0 ,70
IDE13275-ENG155000-Personalization default value-DC_aktiverSpeicherplatz,0 ,70
IDE13275-ENG155001-Personalization default value-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE13275-ENG155002-Personalization default value-DC_linkeTubeninformation,00 ,70
IDE13275-ENG155003-Personalization default value-DC_rechteTubeninformation,00 ,70
IDE13275-ENG155004-Personalization default value-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE13275-ENG155005-Personalization default value-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE13275-ENG155006-Personalization default value-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE13275-ENG155007-Personalization default value-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE13275-ENG155008-Personalization default value-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE13275-ENG155009-Personalization default value-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE13275-ENG155051-Personalization default value-Display_Average_Consumption,not active ,70
IDE13275-ENG155052-Personalization default value-Display_Average_Speed,not active ,70
IDE13275-ENG155053-Personalization default value-Display_ComfortPowerConsumption,not active ,70
IDE13275-ENG155054-Personalization default value-Display_ConsumerList,not active ,70
IDE13275-ENG155055-Personalization default value-Display_CoolantTemperature,not active ,70
IDE13275-ENG155056-Personalization default value-Display_CurrentConsumption,not active ,70
IDE13275-ENG155057-Personalization default value-Display_DigitalSpeedometer,not active ,70
IDE13275-ENG155058-Personalization default value-Display_Distance,not active ,70
IDE13275-ENG155059-Personalization default value-Display_DrivingTime,not active ,70
IDE13275-ENG155060-Personalization default value-Display_DualSpeedometer,not active ,70
IDE13275-ENG155061-Personalization default value-Display_Laptimer,not active ,70
IDE13275-ENG155062-Personalization default value-Display_LiveTips,not active ,70
IDE13275-ENG155063-Personalization default value-Display_Nachtankmenge,not active ,70
IDE13275-ENG155064-Personalization default value-Display_OilTemperature,not active ,70
IDE13275-ENG155065-Personalization default value-Display_Range,not active ,70
IDE13275-ENG155066-Personalization default value-Display_ResetTime,not active ,70
IDE13275-ENG155067-Personalization default value-Display_SpeedWarning,not active ,70
IDE13275-ENG155068-Personalization default value-Display_VZA,not active ,70
IDE13275-ENG155069-Personalization default value-Display_ZeroEmission_Distance,not active ,70
IDE13275-ENG155070-Personalization default value-Display_ZeroEmission_Time,not active ,70
IDE13275-ENG155246-Personalization default value-LastMode_HMI_global_active_layout,0 ,70
IDE13275-ENG155247-Personalization default value-LastMode_HMI_HistoryState_Fahrzeugreiter,1 ,70
IDE13275-ENG155248-Personalization default value-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE13275-ENG155249-Personalization default value-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE13275-ENG155250-Personalization default value-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE13275-ENG155251-Personalization default value-LastMode_HMI_HistoryState_main,0 ,70
IDE13275-ENG155252-Personalization default value-LastMode_HMI_HistoryState_mfa,0 ,70
IDE13275-ENG155253-Personalization default value-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE13275-ENG155254-Personalization default value-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE13275-ENG155255-Personalization default value-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,13 ,70
IDE13275-ENG155256-Personalization default value-LastMode_HMI_HistoryState_sport,1 ,70
IDE13275-ENG155257-Personalization default value-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE13275-ENG155258-Personalization default value-LastMode_HMI_MFA_store,0 ,70
IDE13275-ENG155259-Personalization default value-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE13275-ENG155260-Personalization default value-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE13275-ENG155261-Personalization default value-LastMode_v_Kunde_aktiv,not active ,70
IDE13275-ENG155262-Personalization default value-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE13275-ENG155263-Personalization default value-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE13275-ENG155906-Personalization default value-Speed 2,0 ,70
IDE13275-ENG155907-Personalization default value-Speed_warning_unit_mph_/_kmh,Kilometers per hour ,70
IDE13607-MAS16706-Lock display contents-List time out,0 s,9
IDE14123-MAS01129-Design variant activation-Variant 1,active ,2
IDE14123-MAS01130-Design variant activation-Variant 2,not active ,2
IDE14123-MAS01131-Design variant activation-Variant 3,active ,2
IDE14123-MAS01339-Design variant activation-Variant 9,not active ,2
IDE14123-MAS03101-Design variant activation-Variant 4,active ,2
IDE14123-MAS03102-Design variant activation-Variant 5,not active ,2
IDE14123-MAS03103-Design variant activation-Variant 6,not active ,2
IDE14123-MAS03104-Design variant activation-Variant 7,not active ,2
IDE14123-MAS03105-Design variant activation-Variant 8,not active ,2
IDE14123-MAS05866-Design variant activation-lock,Yes ,2
IDE14123-MAS06157-Design variant activation-Variant 10,not active ,2
IDE14123-MAS06158-Design variant activation-Variant 11,not active ,2
IDE14123-MAS06159-Design variant activation-Variant 12,not active ,2
IDE14123-MAS06160-Design variant activation-Variant 13,not active ,2
IDE14123-MAS06161-Design variant activation-Variant 14,not active ,2
IDE14123-MAS06162-Design variant activation-Variant 15,not active ,2
IDE14184-Active participant personalization,No ,1
IDE14188-Range indicator configuration,422 km,8
IDE14220-Vehicle speed warning for India-,0 s,1
MAS00194-ENG261675-----bm_100kmh,80.00 km/h,7
MAS00194-ENG261674-----bm_1-4Meile,200000 mm,7
MAS00194-ENG261673-----bm_1-8Meile,100000 mm,7
MAS00194-ENG261678-----bm_200kmh,170.00 km/h,7
MAS00194-ENG261677-----bm_standzeit,3 s,7
MAS01758-IDE00500-Date / time-Hour,19 H,6
MAS01758-IDE00501-Date / time-Minute,31 min,6
MAS01758-IDE00502-Date / time-Year,2021 yr,6
MAS01758-IDE00503-Date / time-Month,7 Months,6
MAS01758-IDE00504-Date / time-Day,19 d,6
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,31
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,31
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,31
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,31
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,31
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,31
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,31
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,31
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,31
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,31
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,31
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,31
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,31
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,31
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,31
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,31
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,31
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,31
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,31
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,31
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,31
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,31
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,31
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,31
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,31
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,31
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,31
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,31
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,31
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,31
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,31
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,31
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,31
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,31
ENG119877-ENG126397-Configuration of Development CAN-Messages-Block 40,OFF ,31
ENG119877-ENG167465-Configuration of Development CAN-Messages-Block 41,OFF ,31
ENG119877-ENG167466-Configuration of Development CAN-Messages-Block 42,OFF ,31
ENG119877-ENG167467-Configuration of Development CAN-Messages-Block 43,OFF ,31
ENG119877-ENG167468-Configuration of Development CAN-Messages-Block 44,OFF ,31
ENG119877-ENG167469-Configuration of Development CAN-Messages-Block 45,OFF ,31
ENG119877-ENG167470-Configuration of Development CAN-Messages-Block 46,OFF ,31
ENG119877-ENG167471-Configuration of Development CAN-Messages-Block 47,OFF ,31
ENG119877-ENG167472-Configuration of Development CAN-Messages-Block 48,OFF ,31
ENG119877-ENG167473-Configuration of Development CAN-Messages-Block 49,OFF ,31
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,31
ENG119877-ENG167474-Configuration of Development CAN-Messages-Block 50,OFF ,31
ENG119877-ENG167475-Configuration of Development CAN-Messages-Block 51,OFF ,31
ENG119877-ENG167476-Configuration of Development CAN-Messages-Block 52,OFF ,31
ENG119877-ENG167477-Configuration of Development CAN-Messages-Block 53,OFF ,31
ENG119877-ENG167478-Configuration of Development CAN-Messages-Block 54,OFF ,31
ENG119877-ENG167479-Configuration of Development CAN-Messages-Block 55,OFF ,31
ENG119877-ENG167480-Configuration of Development CAN-Messages-Block 56,OFF ,31
ENG119877-ENG167481-Configuration of Development CAN-Messages-Block 57,OFF ,31
ENG119877-ENG167482-Configuration of Development CAN-Messages-Block 58,OFF ,31
ENG119877-ENG167483-Configuration of Development CAN-Messages-Block 59,OFF ,31
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,31
ENG119877-ENG167484-Configuration of Development CAN-Messages-Block 60,OFF ,31
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,31
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,31
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,31
ENG119880-ENG101574-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X1,00 ,12
ENG119880-ENG99557-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X2,00 ,12
ENG119880-ENG102140-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X3,00 ,12
ENG119880-ENG102936-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X4,00 ,12
ENG119880-ENG103548-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X5,00 ,12
ENG119880-ENG113992-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X6,00 ,12
ENG119880-ENG99777-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y1,00 ,12
ENG119880-ENG100480-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y2,00 ,12
ENG119880-ENG100773-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y3,00 ,12
ENG119880-ENG100631-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y4,00 ,12
ENG119880-ENG102174-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y5,00 ,12
ENG119880-ENG113993-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y6,00 ,12
ENG119879-ENG99557-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2,00 ,12
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,00 ,12
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,00 ,12
ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5,00 ,12
ENG119879-ENG113992-dimming_characteristic_curve_adjustment_bargraph_main_colour-X6,00 ,12
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,00 ,12
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,00 ,12
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,00 ,12
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,00 ,12
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,00 ,12
ENG119879-ENG113993-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y6,00 ,12
ENG119881-ENG101574-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X1,00 ,12
ENG119881-ENG99557-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X2,00 ,12
ENG119881-ENG102140-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X3,00 ,12
ENG119881-ENG102936-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X4,00 ,12
ENG119881-ENG103548-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X5,00 ,12
ENG119881-ENG113992-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X6,00 ,12
ENG119881-ENG99777-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y1,00 ,12
ENG119881-ENG100480-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y2,00 ,12
ENG119881-ENG100773-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y3,00 ,12
ENG119881-ENG100631-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y4,00 ,12
ENG119881-ENG102174-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y5,00 ,12
ENG119881-ENG113993-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y6,00 ,12
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,0A ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,32 ,12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,64 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,96 ,12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,02 ,12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,02 ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,0E ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,1E ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,32 ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,64 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,0E ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,1E ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,32 ,12
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1,00 ,12
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,0A ,12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,32 ,12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,64 ,12
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,96 ,12
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,FD ,12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,02 ,12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,02 ,12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,0E ,12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,1E ,12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,32 ,12
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6,64 ,12
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1,00 ,12
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A ,12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32 ,12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64 ,12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,96 ,12
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD ,12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,02 ,12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,02 ,12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,0E ,12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,1E ,12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,32 ,12
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64 ,12
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1,00 02 ,20
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,32 0E ,20
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,96 32 ,20
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 00 ,20
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5,00 00 ,20
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1,0A 02 ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,64 1E ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,FD 64 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 00 ,20
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5,00 00 ,20
ENG153810-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X1,00 ,18
ENG153810-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X2,0A ,18
ENG153810-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X3,32 ,18
ENG153810-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X4,64 ,18
ENG153810-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X5,DC ,18
ENG153810-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X6,FD ,18
ENG153810-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y1,2.00 ,18
ENG153810-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y2,2.00 ,18
ENG153810-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y3,6.00 ,18
ENG153810-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y4,10.00 ,18
ENG153810-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y5,80.00 ,18
ENG153810-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y6,100.00 ,18
ENG153811-ENG154946-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X1,0.20 s,24
ENG153811-ENG154947-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X2,0.40 s,24
ENG153811-ENG154948-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X3,0.60 s,24
ENG153811-ENG154949-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X4,0.80 s,24
ENG153811-ENG154950-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X5,1.00 s,24
ENG153811-ENG154951-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X6,1.20 s,24
ENG153811-ENG154952-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y1,80.00 %,24
ENG153811-ENG154953-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y2,60.00 %,24
ENG153811-ENG154954-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y3,40.00 %,24
ENG153811-ENG154955-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y4,25.00 %,24
ENG153811-ENG154956-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y5,12.00 %,24
ENG153811-ENG154957-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y6,0.00 %,24
ENG153811-ENG155080-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X1,0.20 s,24
ENG153811-ENG155081-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X2,0.40 s,24
ENG153811-ENG155082-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X3,0.60 s,24
ENG153811-ENG155083-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X4,0.80 s,24
ENG153811-ENG155084-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X5,1.00 s,24
ENG153811-ENG155085-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X6,1.20 s,24
ENG153811-ENG155086-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y1,40.00 %,24
ENG153811-ENG155087-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y2,60.00 %,24
ENG153811-ENG155088-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y3,75.00 %,24
ENG153811-ENG155089-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y4,85.00 %,24
ENG153811-ENG155090-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y5,95.00 %,24
ENG153811-ENG155091-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y6,100.00 %,24
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xs_bus ,1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,lds ,1
ENG102605-ENG261672-outside_temperature-at_ITM_Kuehlmittel,No ,16
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.00 km,16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.00 °C,16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.00 ,16
ENG135292-phev_stat_intervall-,5.00 ,7
ENG135292-phev_stat_intervall-,100 m,7
ENG135292-phev_stat_intervall-,0 min,7
ENG135292-phev_stat_intervall-,5.00 km,7
ENG135292-phev_stat_intervall-,kein ,7
ENG135292-phev_stat_intervall-,1.00 s,7
ENG135292-phev_stat_intervall-,00000000 00010000  ,7
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF,300 ms,17
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.25 ,17
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.50 ,17
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.00 ,17
ENG153987-volume_offset,100 %,1
Elapsed Time: 01:05
adpmap-19-4KE-907-468-C_WAUZZZF29MN105510-20210719-1932.CSV
;SW:4KE-907-468-C   HW:4K1-907-468-B ---  CAN Gateway
;Component:Gateway       H07 0602, Coding:02010001002006405A86000200590032C8380000100000000900000002000000
;EV_Gatew31xAU65x,003220,EV_Gatew31xAU65x_AU58.rod
;Monday,19,July,2021,19:32:44:35862
;VCDS Version: Release 21.3.0  Data version: 20210318 DS325.0
;VCID: 49C43674F941C32318D-801C
IDE00001-IDE00332-Production mode-Buttons for multi-function steering wheel,Deactivating ,3
IDE00001-IDE10279-Production mode-Onboard data collector,Deactivating ,3
IDE00001-MAS01490-Production mode-Energy management,Deactivating ,3
IDE00001-MAS11109-Production mode-Wireless network connection,Deactivating ,3
IDE00002-Transport mode,not activated ,1
IDE00820-MAS03504-Activating and deactivating all development messages-XCP,not active ,1
IDE01996-IDE14867-Installation list: specified installations-Subgateway as firewall control module,Not coded ,32
IDE01996-IDE15844-Installation list: specified installations-Fuel cell drive control module,Not coded ,32
IDE01996-MAS00796-Installation list: specified installations-Engine Control Module,coded ,32
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1,coded ,32
IDE01996-SFT00002-Installation list: specified installations-Transmission Electronics,coded ,32
IDE01996-SFT00003-Installation list: specified installations-Brake electronics,Not coded ,32
IDE01996-SFT00003-Installation list: specified installations-Brake electronics,coded ,32
IDE01996-SFT00006-Installation list: specified installations-Seat adjustment: passenger's side,Not coded ,32
IDE01996-SFT00007-Installation list: specified installations-Display/control head,Not coded ,32
IDE01996-SFT00008-Installation list: specified installations-Climate Control Module,Not coded ,32
IDE01996-SFT00009-Installation list: specified installations-Electronic central electric,coded ,32
IDE01996-SFT00012-Installation list: specified installations-Rear Axle Steering 2,Not coded ,32
IDE01996-SFT00017-Installation list: specified installations-Engine electronics 2,Not coded ,32
IDE01996-SFT00019-Installation list: specified installations-Distance Regulation,Not coded ,32
IDE01996-SFT00021-Installation list: specified installations-Airbag,Not coded ,32
IDE01996-SFT00022-Installation list: specified installations-Steering column electronics systems,coded ,32
IDE01996-SFT00023-Installation list: specified installations-Instrument cluster,coded ,32
IDE01996-SFT00024-Installation list: specified installations-Auxiliary/parking heating,Not coded ,32
IDE01996-SFT00025-Installation list: specified installations-Data Bus OBD Interface,coded ,32
IDE01996-SFT00027-Installation list: specified installations-Active Steering,Not coded ,32
IDE01996-SFT00032-Installation list: specified installations-High beam assistant,Not coded ,32
IDE01996-SFT00033-Installation list: specified installations-Battery management 2,Not coded ,32
IDE01996-SFT00034-Installation list: specified installations-All-wheel drive electronics,coded ,32
IDE01996-SFT00038-Installation list: specified installations-Convertible top operation,Not coded ,32
IDE01996-SFT00039-Installation list: specified installations-Display/operating unit rear,Not coded ,32
IDE01996-SFT00040-Installation list: specified installations-Rear A/C control head,Not coded ,32
IDE01996-SFT00042-Installation list: specified installations-Control module for wireless charging,Not coded ,32
IDE01996-SFT00043-Installation list: specified installations-Steering column lock,Not coded ,32
IDE01996-SFT00050-Installation list: specified installations-Differential lock electronics,Not coded ,32
IDE01996-SFT00054-Installation list: specified installations-Seat adjustment: driver side,coded ,32
IDE01996-SFT00060-Installation list: specified installations-Lane change assistance,Not coded ,32
IDE01996-SFT00066-Installation list: specified installations-Driver's door electronics,coded ,32
IDE01996-SFT00067-Installation list: specified installations-Brake Electronics 2,Not coded ,32
IDE01996-SFT00068-Installation list: specified installations-Power steering,coded ,32
IDE01996-SFT00070-Installation list: specified installations-Comfort system central control module,coded ,32
IDE01996-SFT00070-Installation list: specified installations-Comfort system central control module,Not coded ,32
IDE01996-SFT00072-Installation list: specified installations-Seat adjustment: rear driver's side,Not coded ,32
IDE01996-SFT00080-Installation list: specified installations-Seat adjustment 3. seat row,Not coded ,32
IDE01996-SFT00081-Installation list: specified installations-Electric drive,Not coded ,32
IDE01996-SFT00082-Installation list: specified installations-Passenger's door electronics,coded ,32
IDE01996-SFT00090-Installation list: specified installations-Automated longitudinal control,Not coded ,32
IDE01996-SFT00091-Installation list: specified installations-Seat adjustment: rear passenger side,Not coded ,32
IDE01996-SFT00095-Installation list: specified installations-Information electronics 1,coded ,32
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring System (TPMS),coded ,32
IDE01996-SFT00107-Installation list: specified installations-Aerodynamic control module,Not coded ,32
IDE01996-SFT00108-Installation list: specified installations-Rear view camera system,coded ,32
IDE01996-SFT00109-Installation list: specified installations-Rear lid electronics,coded ,32
IDE01996-SFT00113-Installation list: specified installations-Battery Charger,Not coded ,32
IDE01996-SFT00116-Installation list: specified installations-Chassis Control,Not coded ,32
IDE01996-SFT00117-Installation list: specified installations-Emergency call module and communication unit,coded ,32
IDE01996-SFT00118-Installation list: specified installations-Parking aid,Not coded ,32
IDE01996-SFT00128-Installation list: specified installations-Battery control additional memory 1,coded ,32
IDE01996-SFT00129-Installation list: specified installations-Selector lever,coded ,32
IDE01996-SFT00130-Installation list: specified installations-Head-Up-Display,Not coded ,32
IDE01996-SFT00132-Installation list: specified installations-Night vision system,Not coded ,32
IDE01996-SFT00139-Installation list: specified installations-Distance regulation 2,Not coded ,32
IDE01996-SFT00140-Installation list: specified installations-Hybrid Battery Management,Not coded ,32
IDE01996-SFT00165-Installation list: specified installations-Front sensor for drivers assistant systems,Not coded ,32
IDE01996-SFT00165-Installation list: specified installations-Front sensor for drivers assistant systems,coded ,32
IDE01996-SFT00166-Installation list: specified installations-Microphone control module,Not coded ,32
IDE01996-SFT00169-Installation list: specified installations-Structure-borne sound actuator,Not coded ,32
IDE01996-SFT00172-Installation list: specified installations-Reducing Agent Metering System,coded ,32
IDE01996-SFT00186-Installation list: specified installations-Subframe mount,Not coded ,32
IDE01996-SFT00195-Installation list: specified installations-Electric drive 3,Not coded ,32
IDE01996-SFT00196-Installation list: specified installations-Voltage converter,Not coded ,32
IDE01996-SFT00203-Installation list: specified installations-Rear Axle Steering,Not coded ,32
IDE01996-SFT00205-Installation list: specified installations-Laser for adaptive cruise control,Not coded ,32
IDE01996-SFT00206-Installation list: specified installations-Electric drive 2,Not coded ,32
IDE01996-SFT00207-Installation list: specified installations-Lane Change Assistant 2,Not coded ,32
IDE01996-SFT00208-Installation list: specified installations-Front Axle Lift System,Not coded ,32
IDE01996-SFT00219-Installation list: specified installations-Front Corner Radar 1,Not coded ,32
IDE01996-SFT00220-Installation list: specified installations-Front Corner Radar 2,Not coded ,32
IDE01996-SFT00221-Installation list: specified installations-Sunroof control module 2,Not coded ,32
IDE01996-SFT33028-Installation list: specified installations-High voltage converter,Not coded ,32
IDE01996-SFT33031-Installation list: specified installations-Antenna module,Not coded ,32
IDE01996-SFT33032-Installation list: specified installations-Control unit for hood ornament,Not coded ,32
IDE01996-SFT33041-Installation list: specified installations-Right exterior rear view mirror,Not coded ,32
IDE01996-SFT33042-Installation list: specified installations-Left exterior rear view mirror,Not coded ,32
IDE01996-SFT33043-Installation list: specified installations-HV battery charging unit 2,Not coded ,32
IDE01996-SFT33044-Installation list: specified installations-High voltage converter 2,Not coded ,32
IDE01996-SFT33045-Installation list: specified installations-Remote Multifunction Module,Not coded ,32
IDE01996-SFT33232-Installation list: specified installations-Central control for digital matrix light,Not coded ,32
IDE01996-SFT271904-Installation list: specified installations-Sunroof control module,coded ,32
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,68 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,Fleece ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,VAO ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,610604411O ,15
IDE03903-Production process data 1,00 00 00 00 00 00 ,6
IDE04159-Deactivation of start/stop function,regular operation ,1
IDE06748-Break recommendation,activated ,1
IDE07139-Normal bus behavior during diagnosis,active ,1
IDE09797-IDE10294-Adaptation of range calculation-Initialization of LPG range consumption,10.20 l/100km,48
IDE09797-MAS09198-Adaptation of range calculation-Init. value of average speed electrical trip,40.10 km/h,48
IDE09797-MAS09199-Adaptation of range calculation-Init. value absolute forecast deviation air-condition. interior,100 W,48
IDE09797-MAS09200-Adaptation of range calculation-Init. value average performance A/C components,10 W,48
IDE09797-MAS09201-Adaptation of range calculation-Init. value average perf. low voltage basic consumer,990 W,48
IDE09797-MAS09202-Adaptation of range calculation-Init. value RWDS load profile,24 A,48
IDE09797-MAS09203-Adaptation of range calculation-Init. value of elec. average consumption on street class 0,23.10 kWh/100 km,48
IDE09797-MAS09204-Adaptation of range calculation-Init. value of elec. average consumption on street class 1,23.10 kWh/100 km,48
IDE09797-MAS09205-Adaptation of range calculation-Init. value of elec. average consumption on street class 2,23.10 kWh/100 km,48
IDE09797-MAS09206-Adaptation of range calculation-Init. value of elec. average consumption on street class 3,23.10 kWh/100 km,48
IDE09797-MAS09207-Adaptation of range calculation-Init. value of elec. average consumption on street class 4,23.10 kWh/100 km,48
IDE09797-MAS09208-Adaptation of range calculation-Init. value of elec. average consumption on street class 5,23.10 kWh/100 km,48
IDE09797-MAS09209-Adaptation of range calculation-Init. value average consumption BMS electric (forecast horizon),24.10 kWh/100 km,48
IDE09797-MAS09210-Adaptation of range calculation-Init. value cons. eng. range cons.,10.30 l/100km,48
IDE09797-MAS09211-Adaptation of range calculation-Init. value average range consumption: electric traction,23.30 kWh/100 km,48
IDE09797-MAS09212-Adaptation of range calculation-Init. value of elec. average consumption on street class 6,23.10 kWh/100 km,48
IDE09797-MAS10126-Adaptation of range calculation-Initialization of CNG range consumption,6.10 kg/100 km,48
IDE09797-MAS10294-Adaptation of range calculation-Initial value of average fuel consumption on street class 0,10.20 l/100km,48
IDE09797-MAS10295-Adaptation of range calculation-Initial value of average fuel consumption on street class 1,10.20 l/100km,48
IDE09797-MAS10296-Adaptation of range calculation-Initial value of average fuel consumption on street class 2,10.20 l/100km,48
IDE09797-MAS10297-Adaptation of range calculation-Initial value of average fuel consumption on street class 3,10.20 l/100km,48
IDE09797-MAS10298-Adaptation of range calculation-Initial value of average fuel consumption on street class 4,10.20 l/100km,48
IDE09797-MAS10299-Adaptation of range calculation-Initial value of average fuel consumption on street class 5,10.20 l/100km,48
IDE09797-MAS10300-Adaptation of range calculation-Initial value of average fuel consumption on street class 6,10.20 l/100km,48
IDE10351-MAS05767-Message mirroring-port,00 00 ,21
IDE10351-MAS09111-Message mirroring-IP address,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,21
IDE10351-MAS10445-Message mirroring-Data bus CAN 1,not active ,21
IDE10351-MAS10446-Message mirroring-Data bus CAN 2,not active ,21
IDE10351-MAS10447-Message mirroring-Data bus CAN 3,not active ,21
IDE10351-MAS10448-Message mirroring-Data bus CAN 4,not active ,21
IDE10351-MAS10449-Message mirroring-Data bus CAN 5,not active ,21
IDE10351-MAS10450-Message mirroring-Data bus CAN 6,not active ,21
IDE10351-MAS10451-Message mirroring-Data bus Flexray A,not active ,21
IDE10351-MAS10452-Message mirroring-Data bus LIN 1,not active ,21
IDE10351-MAS10453-Message mirroring-Data bus LIN 2,not active ,21
IDE10351-MAS10454-Message mirroring-Data bus LIN 3,not active ,21
IDE10351-MAS10460-Message mirroring-Target bus,not active ,21
IDE10351-MAS11107-Message mirroring-Data bus CAN 7,not active ,21
IDE10351-MAS13143-Message mirroring-FlexRay B data bus,not active ,21
IDE10351-MAS17841-Message mirroring-Data bus CAN 8,not active ,21
IDE10400-High-voltage system: locking,regular operation ,1
IDE11209-MAS12388-Vehicle condition report: settings-Send report after terminal 15 off wait time,1E ,5
IDE11209-MAS12389-Vehicle condition report: settings-After terminal 15 off: also wait for bus inactivity,OFF ,5
IDE11209-MAS12390-Vehicle condition report: settings-Send report after terminal 15 on wait time,1E ,5
IDE11209-MAS12391-Vehicle condition report: settings-Send report after bus inactivity wait time,05 ,5
IDE11209-MAS12392-Vehicle condition report: settings-Send report upon reaching BEM shutdown level,OFF ,5
IDE11688-IDE08958-Autonomous operation request-H-V system: start request,regular operation ,3
IDE11688-MAS08040-Autonomous operation request-Automatic recharging of starter battery,regular operation ,3
IDE11688-MAS13088-Autonomous operation request-Preconditioning of the interior,regular operation ,3
IDE11689-48V-System: locking,regular operation ,1
IDE14111-MAS02165-Routing groups-Group 1,activated ,2
IDE14111-MAS02166-Routing groups-Group 2,not activated ,2
IDE14111-MAS05859-Routing groups-Group 3,not activated ,2
IDE14111-MAS05860-Routing groups-Group 4,not activated ,2
IDE14111-MAS05861-Routing groups-Group 5,not activated ,2
IDE14111-MAS05862-Routing groups-Group 6,not activated ,2
IDE14111-MAS05863-Routing groups-Group 7,not activated ,2
IDE14111-MAS05864-Routing groups-Group 8,not activated ,2
IDE14111-MAS17847-Routing groups-Group 9,not activated ,2
IDE14111-MAS17848-Routing groups-Group 10,not activated ,2
IDE14111-MAS17849-Routing groups-Group 11,not activated ,2
IDE14111-MAS17850-Routing groups-Group 12,not activated ,2
IDE14111-MAS17851-Routing groups-Group 13,not activated ,2
IDE14111-MAS17852-Routing groups-Group 14,not activated ,2
IDE14111-MAS17853-Routing groups-Group 15,not activated ,2
IDE14154-MAS17900-Route-based range calculation adjustment-Classified consumption,12.10 kWh/100 km,40
IDE14154-MAS17901-Route-based range calculation adjustment-Classified consumption 2,12.10 kWh/100 km,40
IDE14154-MAS17902-Route-based range calculation adjustment-Classified consumption 3,12.10 kWh/100 km,40
IDE14154-MAS17903-Route-based range calculation adjustment-Classified consumption 4,12.10 kWh/100 km,40
IDE14154-MAS17904-Route-based range calculation adjustment-Classified consumption 5,12.10 kWh/100 km,40
IDE14154-MAS17905-Route-based range calculation adjustment-Classified consumption 6,12.10 kWh/100 km,40
IDE14154-MAS17906-Route-based range calculation adjustment-Classified consumption 7,12.10 kWh/100 km,40
IDE14154-MAS17907-Route-based range calculation adjustment-Classified consumption 8,12.10 kWh/100 km,40
IDE14154-MAS17908-Route-based range calculation adjustment-Classified consumption 9,12.10 kWh/100 km,40
IDE14154-MAS17909-Route-based range calculation adjustment-Classified consumption 10,12.10 kWh/100 km,40
IDE14154-MAS17910-Route-based range calculation adjustment-Calculated consumption,12.10 kWh/100 km,40
IDE14154-MAS17911-Route-based range calculation adjustment-Calculated consumption 2,12.10 kWh/100 km,40
IDE14154-MAS17912-Route-based range calculation adjustment-Calculated consumption 3,12.10 kWh/100 km,40
IDE14154-MAS17913-Route-based range calculation adjustment-Calculated consumption 4,12.10 kWh/100 km,40
IDE14154-MAS17914-Route-based range calculation adjustment-Calculated consumption 5,12.10 kWh/100 km,40
IDE14154-MAS17915-Route-based range calculation adjustment-Calculated consumption 6,12.10 kWh/100 km,40
IDE14154-MAS17916-Route-based range calculation adjustment-Calculated consumption 7,12.10 kWh/100 km,40
IDE14154-MAS17917-Route-based range calculation adjustment-Calculated consumption 8,12.10 kWh/100 km,40
IDE14154-MAS17918-Route-based range calculation adjustment-Calculated consumption 9,12.10 kWh/100 km,40
IDE14154-MAS17919-Route-based range calculation adjustment-Calculated consumption 10,12.10 kWh/100 km,40
IDE14168-Energy management additional components,00 00 00 00 00 00 00 00 ,8
IDE14222-Test number length: authentic time,16 B,1
IDE14223-Authentic time maximum deviation,5 min,1
IDE14670-MAS04389-Central data collector: settings-Number of repeat attempts,3 ,32
IDE14670-MAS18717-Central data collector: settings-Waiting time for diagnostic queries,15 s,32
IDE14670-MAS18718-Central data collector: settings-Event memory query interval,60 s,32
IDE14670-MAS18719-Central data collector: settings-Reset seating cycle,90 s,32
IDE14995-MAS19716-Private sphere mode: workshop settings-Services,Maximum private sphere in shape 1 ,6
IDE14995-MAS19722-Private sphere mode: workshop settings-Data collector,not activated ,6
IDE14995-MAS19797-Private sphere mode: workshop settings-Basic setting not recognized Guest: services,Settings from the previous drive cycle are adopted ,6
IDE14995-MAS19798-Private sphere mode: workshop settings-Basic setting not recognized Guest: campaigns with interest weighting,Settings from the previous drive cycle are adopted ,6
IDE14995-MAS19799-Private sphere mode: workshop settings-Basic setting not recognized Guest: campaigns with consent,Settings from the previous drive cycle are adopted ,6
IDE15042-MAS19716-Privacy mode: customer settings-Services,Tracking Data group selected ,6
IDE15042-MAS19722-Privacy mode: customer settings-Data collector,activated ,6
IDE15326-IDE06096-BAP display control module coding-Interior lights,not installed ,32
IDE15326-IDE15327-BAP display control module coding-Exterior lighting,installed ,32
IDE15326-IDE15334-BAP display control module coding-Wiper convenience,installed ,32
IDE15326-IDE15373-BAP display control module coding-Exterior rearview mirror setting,not installed ,32
IDE15326-IDE15374-BAP display control module coding-Driver seat setting,installed ,32
IDE15326-IDE15375-BAP display control module coding-Adjustment of units,not installed ,32
IDE15326-IDE15376-BAP display control module coding-Pneumatic driver seat,not installed ,32
IDE15326-IDE15377-BAP display control module coding-Connection manager setting,not installed ,32
IDE15326-IDE15378-BAP display control module coding-Setting display,not installed ,32
IDE15326-IDE15379-BAP display control module coding-Virtual exterior rearview mirror,not installed ,32
IDE15326-IDE15380-BAP display control module coding-Door: driver setting,not installed ,32
IDE15326-IDE15381-BAP display control module coding-Door: front passenger setting,not installed ,32
IDE15326-MAS03420-BAP display control module coding-Head-Up-Display,not installed ,32
ENG137256-Adaption_high_voltage_zero_potential,regular operation ,1
ENG153814-download_eem,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,256
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,active ,13
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,120 ,13
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms,13
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms,13
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,3000 ms,13
ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms,13
ENG118777-ENG136172-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Number_of_Keys,1 ,13
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms,13
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,500 ms,13
ENG118777-ENG136168-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation_1,800 ms,13
ENG118777-ENG136169-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation_2,1000 ms,13
ENG118777-ENG136170-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation_3,0 ms,13
ENG118777-ENG136171-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation_4,0 ms,13
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,6000 ms,13
ENG135872-EM_inside_fan_reduction,regular operation ,1
ENG118775-energy_management_deactiv_stage,regular operation ,1
ENG137255-HVK_Warning,regular operation ,1
ENG244867-Routing_matrix_generation,02 ,2
ENG118451-ENG118685-Switch_on_ban_independent_car_heater-Set_point_target_time,80 min,2
ENG118451-ENG118684-Switch_on_ban_independent_car_heater-Switch_on_ban_activation,regular operation ,2
ENG118774-ENG98345-WakeUpMonitor_Activation-Activation,activated ,2
ENG118774-ENG136195-WakeUpMonitor_Activation-Activation_Bus_Activity,activated ,2
ENG118774-ENG136134-WakeUpMonitor_Activation-Activation_Cluster_Sleep,activated ,2
ENG118774-ENG136135-WakeUpMonitor_Activation-Activation_Cluster_Start,activated ,2
ENG118774-ENG136197-WakeUpMonitor_Activation-Activation_CWUP,activated ,2
ENG118774-ENG136130-WakeUpMonitor_Activation-Activation_Keeping_Awake,activated ,2
ENG118774-ENG136196-WakeUpMonitor_Activation-Activation_Knock_Out,activated ,2
ENG118774-ENG136131-WakeUpMonitor_Activation-Activation_Logical_Wakeup,activated ,2
ENG118774-ENG136198-WakeUpMonitor_Activation-Activation_NFU,activated ,2
ENG118774-ENG136132-WakeUpMonitor_Activation-Activation_Physical_Wakeup,activated ,2
ENG118774-ENG136199-WakeUpMonitor_Activation-Activation_SBU,activated ,2
ENG118773-ENG136190-WakeUpMonitor_Configuration-Max_Num_Cluster_Sleep,20 counts,13
ENG118773-ENG136191-WakeUpMonitor_Configuration-Max_Num_Cluster_Start,20 counts,13
ENG118773-ENG136192-WakeUpMonitor_Configuration-Max_Num_CWUP,30 counts,13
ENG118773-ENG136189-WakeUpMonitor_Configuration-Max_Num_Knock_Out,3 counts,13
ENG118773-ENG136187-WakeUpMonitor_Configuration-Max_Num_Logical_Wakeup,40 counts,13
ENG118773-ENG136193-WakeUpMonitor_Configuration-Max_Num_NF,20 min,13
ENG118773-ENG136188-WakeUpMonitor_Configuration-Max_Num_Physical_Wakeup,10 counts,13
ENG118773-ENG136194-WakeUpMonitor_Configuration-Max_Num_Sb,20 min,13
ENG118773-ENG136186-WakeUpMonitor_Configuration-Max_Time_Keeping_Awake,20 min,13
ENG118773-ENG109064-WakeUpMonitor_Configuration-Start_Delay,0 s,13
ENG118773-ENG136185-WakeUpMonitor_Configuration-Wake_Delay,20 min,13
Elapsed Time: 00:26
adpmap-22-4K0-927-755-D_WAUZZZF29MN105510-20210719-1936.CSV
;SW:4K0-927-755-D   HW:0CJ-927-749-A ---  AWD
;Component:C8_DL3_N_SD1H02 0021, Coding:010C0000
;EV_AWDCQUOD31,001052,EV_AWDCQUOD31.rod
;Monday,19,July,2021,19:36:22:35862
;VCID: 363E4D8898BFBCDB65F-8062
IDE00820-ENG154874-Activating and deactivating all development messages-Activation_of_message_dev_allrad_00,not activated ,1
IDE00820-ENG154875-Activating and deactivating all development messages-Activation_of_message_dev_allrad_02,not activated ,1
IDE00820-ENG154876-Activating and deactivating all development messages-Activation_of_message_dev_x_03,not activated ,1
IDE00820-ENG154877-Activating and deactivating all development messages-Activation_of_message_dev_x_06,not activated ,1
IDE00820-ENG154878-Activating and deactivating all development messages-Activation_of_obd,not activated ,1
IDE00820-ENG154879-Activating and deactivating all development messages-Activation_of_xcp,not activated ,1
IDE03199-ENG101043-Dynamic calibration-Checksum,00 00 00 39 ,128
IDE03199-ENG154997-Dynamic calibration-Data Recovery (1),00 00 00 F6 B4 09 4B 00 00 01 38 00 16 00 00 00 00 01 39 00 00 00 01 00 00 00 36 00 00 00 02 00 00 00 02 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 ,128
IDE03199-ENG154998-Dynamic calibration-Data Recovery (2),36 00 00 00 02 00 00 00 02 00 00 00 01 00 00 05 13 00 00 00 F2 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
IDE03199-ENG154999-Dynamic calibration-Data Recovery (3),00 00 00 00 00 F8 07 ,128
IDE03199-ENG99892-Dynamic calibration-VIN,WAUZZZF29MN105510 ,128
IDE03339-ENG167401-Friction classes (customer service)-Class Gearbox,2379 ,3
IDE03339-ENG154974-Friction classes (customer service)-Class Version,7 ,3
IDE06425-Dynamometer mode: functional-,not activated ,1
IDE06425-ENG98891-Dynamometer mode: functional-Reserved,0 ,1
IDE12421-ENG154921-Counter for center differential lock-ARG Set Full_Lock_Histogram_1,0 ,28
IDE12421-ENG154922-Counter for center differential lock-ARG Set Full_Lock_Histogram_10,0 ,28
IDE12421-ENG154923-Counter for center differential lock-ARG Set Full_Lock_Histogram_11,0 ,28
IDE12421-ENG154924-Counter for center differential lock-ARG Set Full_Lock_Histogram_12,0 ,28
IDE12421-ENG154925-Counter for center differential lock-ARG Set Full_Lock_Histogram_13,0 ,28
IDE12421-ENG154926-Counter for center differential lock-ARG Set Full_Lock_Histogram_14,0 ,28
IDE12421-ENG154927-Counter for center differential lock-ARG Set Full_Lock_Histogram_2,0 ,28
IDE12421-ENG154928-Counter for center differential lock-ARG Set Full_Lock_Histogram_3,0 ,28
IDE12421-ENG154929-Counter for center differential lock-ARG Set Full_Lock_Histogram_4,0 ,28
IDE12421-ENG154930-Counter for center differential lock-ARG Set Full_Lock_Histogram_5,0 ,28
IDE12421-ENG154931-Counter for center differential lock-ARG Set Full_Lock_Histogram_6,0 ,28
IDE12421-ENG154932-Counter for center differential lock-ARG Set Full_Lock_Histogram_7,0 ,28
IDE12421-ENG154933-Counter for center differential lock-ARG Set Full_Lock_Histogram_8,0 ,28
IDE12421-ENG154934-Counter for center differential lock-ARG Set Full_Lock_Histogram_9,0 ,28
IDE12446-MAS06099-All Wheel Drive acoustics-Acoustic measure: anti droning,2000 ,4
IDE12446-MAS06100-All Wheel Drive acoustics-Acoustic measure: anti impact wrench,1300 ,4
IDE12446-MAS07124-All Wheel Drive acoustics-Lower speed threshold,51 km/h ,4
IDE12446-MAS14475-All Wheel Drive acoustics-Lowest gear,5 ,4
MAS09595-ENG155365-Production mode-not used Bit 0,not active ,3
MAS09595-ENG155366-Production mode-not used Bit 10,not active ,3
MAS09595-ENG155367-Production mode-not used Bit 11,not active ,3
MAS09595-ENG155368-Production mode-not used Bit 13,not active ,3
MAS09595-ENG155369-Production mode-not used Bit 14,not active ,3
MAS09595-ENG155370-Production mode-not used Bit 15,not active ,3
MAS09595-ENG155371-Production mode-not used Bit 16,not active ,3
MAS09595-ENG155372-Production mode-not used Bit 17,not active ,3
MAS09595-ENG155373-Production mode-not used Bit 18,not active ,3
MAS09595-ENG155374-Production mode-not used Bit 19,not active ,3
MAS09595-ENG155375-Production mode-not used Bit 20,not active ,3
MAS09595-ENG155376-Production mode-not used Bit 21,not active ,3
MAS09595-ENG155377-Production mode-not used Bit 22,not active ,3
MAS09595-ENG155378-Production mode-not used Bit 23,not active ,3
MAS09595-ENG155379-Production mode-not used Bit 3,not active ,3
MAS09595-ENG155380-Production mode-not used Bit 4,not active ,3
MAS09595-ENG155381-Production mode-not used Bit 5,not active ,3
MAS09595-ENG155382-Production mode-not used Bit 6,not active ,3
MAS09595-ENG155383-Production mode-not used Bit 7,not active ,3
MAS09595-ENG155384-Production mode-not used Bit 8,not active ,3
MAS09595-ENG155385-Production mode-not used Bit 9,not active ,3
MAS09595-ENG155568-Production mode-Permanent 2WD,not active ,3
MAS09595-ENG155924-Production mode-Suppress Shutdown Calibration,not active ,3
MAS09595-ENG155990-Production mode-UDS additional physical services,not active ,3
ENG153960-Steuern Deactivate FullLock,Not Used ,1
Elapsed Time: 00:05
adpmap-36-4M6-959-760_WAUZZZF29MN105510-20210719-1936.CSV
;SW:4M6-959-760   HW:4M4-959-760 ---  Seat Mem. Drvr
;Component:MEM-FS        009 0064, Coding:01581A400000B4010003010101010000000000000000000000000000004000
;EV_SCMDriveSideCONTIAU736,006013,EV_SCMDriveSideCONTIAU736_VW38.rod
;Monday,19,July,2021,19:36:33:35862
;VCID: 7BA89CBCE31DA1B3DA1-802E
IDE00001-MAS10850-Production mode-Deactivate massage function,not active ,3
IDE00001-MAS18842-Production mode-Assembly mode,not active ,3
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not active ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not active ,1
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not active ,1
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not active ,1
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not active ,1
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not active ,1
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not active ,1
IDE02854-Reset standardization,all ,3
IDE03066-Reset counter for compressor for multicontour seat,Activating ,1
IDE06869-installation position,Memory seat driver side ,1
ENG123066-vehicle_velocity_monitoring,active ,1
Elapsed Time: 00:17
adpmap-42-4M1-959-793-J_WAUZZZF29MN105510-20210719-1936.CSV
;SW:4M1-959-793-J   HW:4M1-959-793-D ---  Door Elect, Driver
;Component:TSG FS003 0430, Coding:001DCB0052000200A009B000
;EV_DCU2DriveSideMAXHKLO,001018,EV_DCU2DriveSideMAXHCONT_VW38.rod
;Monday,19,July,2021,19:36:53:35862
;VCID: 46DE3D48E85F2C5BF5F-8012
IDE09067-Side window shade: service mode,Deactivating ,1
Elapsed Time: 00:03
adpmap-44-4N0-909-144-E_WAUZZZF29MN105510-20210719-1937.CSV
;SW:4N0-909-144-E   HW:4N0-909-144-C ---  Steering Assist
;Component:EPS_MLBEVO2BS H22 0505, Coding:94002101010000
;EV_EPSVWBSAU426,010017,EV_EPSVWBSAU426_010.rod
;Monday,19,July,2021,19:37:00:35862
;VCID: 3236719874D7A0FB497-8066
IDE00820-ENG135538-Activating and deactivating all development messages-DEV_EPS_01,not activated ,1
IDE00820-ENG135535-Activating and deactivating all development messages-DEV_EPS_S100,not activated ,1
IDE00820-ENG135536-Activating and deactivating all development messages-DEV_EPS_S101,not activated ,1
IDE00820-ENG135537-Activating and deactivating all development messages-DEV_EPS_S102,not activated ,1
IDE00820-ENG111917-Activating and deactivating all development messages-Dev_Messages_Test_1,not activated ,1
IDE00820-ENG135539-Activating and deactivating all development messages-DEV_X_03,not activated ,1
IDE00820-ENG99057-Activating and deactivating all development messages-XCP,not activated ,1
IDE04555-MAS05425-Activation of pwr steering asst without engine running-100%,not activated ,5
IDE04555-MAS05427-Activation of pwr steering asst without engine running-80%,not activated ,5
IDE04555-MAS11217-Activation of pwr steering asst without engine running-20%,not activated ,5
IDE04555-MAS11219-Activation of pwr steering asst without engine running-40%,not activated ,5
IDE04555-MAS11221-Activation of pwr steering asst without engine running-60%,not activated ,5
ENG110582-Activation_update_programming_without_rest_bus_simulation,not activated ,1
ENG153795-deactivation_characteristic_curves_flash_via_data_set,not activated ,1
ENG153796-Deactivation_of_Assistenz_System_Monitor_message,not activated ,1
ENG110746-V_limit_kL30_disconnect,18.00 km/h,2
Elapsed Time: 00:02
adpmap-46-4N0-907-064-EG_WAUZZZF29MN105510-20210719-1937.CSV
;SW:4N0-907-064-EG   HW:4N0-907-064-G ---  Central Conv.
;Component:BCM2 MLBevo H16 0224, Coding:01340000402000E0630980006C00090403034000804302502F0400000504823F001F0600003F31
;EV_BCM2CONTIAU651,011009,EV_BCM2CONTIAU651_011.rod
;Monday,19,July,2021,19:37:26:35862
;VCID: 78A283B0D22B8AABB73-802C
IDE00001-MAS10843-Production mode-Deactivate interior lighting,not active ,3
IDE00001-MAS10851-Production mode-Deactivate engine start,not active ,3
IDE00001-MAS10853-Production mode-Deactivate sensor-controlled rear lid opening,not active ,3
IDE00001-MAS10854-Production mode-Deactivate central locking: function lock,not active ,3
IDE00001-MAS10855-Production mode-Deactivate ignition switch-off when vehicle has been left,not active ,3
IDE00001-MAS12009-Production mode-Deactivate lighting,not active ,3
IDE00001-MAS12010-Production mode-Deactivate automatic unlocking,not active ,3
IDE00001-MAS17290-Production mode-Suppress further signal sources for Terminal 15 on,not active ,3
IDE00001-MAS21865-Production mode-Hood and rear lid release,not active ,3
IDE00001-MAS22198-Production mode-Inside button for front/read lid inactive,not active ,3
IDE00820-Activating and deactivating all development messages,00 ,1
IDE01464-MAS01167-Rear window defogger-Actuation time,600 s,2
IDE01464-MAS01186-Rear window defogger-Shut-off temperature,35.0 °C,2
IDE04923-MAS08465-Turn signal control-Freeway flashing: flashing cycles,3 ,4
IDE04923-MAS08466-Turn signal control-Confirmation flashing unlocking central locking:flashing cycles,2 ,4
IDE04923-MAS08467-Turn signal control-Confirmation flashing locking central locking: flashing cycles,1 ,4
IDE04923-MAS10114-Turn signal control-Turn signal with relocking,On ,4
IDE04923-MAS10115-Turn signal control-Anti-theft blinkers by inter. door handle activ.,On ,4
IDE04923-MAS13291-Turn signal control-Motorway flashing cancel by counter tap,On ,4
IDE07279-Anti-theft warning system: monitoring diagnostics connection,On ,1
IDE07392-Terminal 15,Default ,1
IDE08221-MAS02444-Personalization settings key 1-Central locking system,global opening ,3
IDE08221-MAS06456-Personalization settings key 1-Auto lock,On ,3
IDE08221-MAS06457-Personalization settings key 1-Auto unlock,On ,3
IDE08221-MAS06696-Personalization settings key 1-Comfort opening sunroof,OFF ,3
IDE08221-MAS06697-Personalization settings key 1-Acoustic confirmation signal,On ,3
IDE08221-MAS06698-Personalization settings key 1-Highway blinking,On ,3
IDE08221-MAS06740-Personalization settings key 1-Release button in rear lid handle locked,On ,3
IDE08221-MAS06756-Personalization settings key 1-Rear shade automatic,OFF ,3
IDE08221-MAS06880-Personalization settings key 1-Mirror fold-in (Audi),OFF ,3
IDE08221-MAS10221-Personalization settings key 1-Rear lid release via rear lid open sensors,On ,3
IDE08221-MAS10228-Personalization settings key 1-Comfort opening window: driver side,OFF ,3
IDE08221-MAS10229-Personalization settings key 1-Comfort opening window: frt. pass. side,OFF ,3
IDE08221-MAS10230-Personalization settings key 1-Comfort opening rear window: driver side,OFF ,3
IDE08221-MAS10231-Personalization settings key 1-Comfort opening rear window: frt. pass. side,OFF ,3
IDE08222-MAS02444-Personalization settings key 2-Central locking system,global opening ,3
IDE08222-MAS06456-Personalization settings key 2-Auto lock,On ,3
IDE08222-MAS06457-Personalization settings key 2-Auto unlock,On ,3
IDE08222-MAS06696-Personalization settings key 2-Comfort opening sunroof,OFF ,3
IDE08222-MAS06697-Personalization settings key 2-Acoustic confirmation signal,On ,3
IDE08222-MAS06698-Personalization settings key 2-Highway blinking,On ,3
IDE08222-MAS06740-Personalization settings key 2-Release button in rear lid handle locked,On ,3
IDE08222-MAS06756-Personalization settings key 2-Rear shade automatic,OFF ,3
IDE08222-MAS06880-Personalization settings key 2-Mirror fold-in (Audi),OFF ,3
IDE08222-MAS10221-Personalization settings key 2-Rear lid release via rear lid open sensors,On ,3
IDE08222-MAS10228-Personalization settings key 2-Comfort opening window: driver side,OFF ,3
IDE08222-MAS10229-Personalization settings key 2-Comfort opening window: frt. pass. side,OFF ,3
IDE08222-MAS10230-Personalization settings key 2-Comfort opening rear window: driver side,OFF ,3
IDE08222-MAS10231-Personalization settings key 2-Comfort opening rear window: frt. pass. side,OFF ,3
IDE08223-MAS02444-Personalization settings key 3-Central locking system,global opening ,3
IDE08223-MAS06456-Personalization settings key 3-Auto lock,On ,3
IDE08223-MAS06457-Personalization settings key 3-Auto unlock,On ,3
IDE08223-MAS06696-Personalization settings key 3-Comfort opening sunroof,OFF ,3
IDE08223-MAS06697-Personalization settings key 3-Acoustic confirmation signal,On ,3
IDE08223-MAS06698-Personalization settings key 3-Highway blinking,On ,3
IDE08223-MAS06740-Personalization settings key 3-Release button in rear lid handle locked,On ,3
IDE08223-MAS06756-Personalization settings key 3-Rear shade automatic,OFF ,3
IDE08223-MAS06880-Personalization settings key 3-Mirror fold-in (Audi),OFF ,3
IDE08223-MAS10221-Personalization settings key 3-Rear lid release via rear lid open sensors,On ,3
IDE08223-MAS10228-Personalization settings key 3-Comfort opening window: driver side,OFF ,3
IDE08223-MAS10229-Personalization settings key 3-Comfort opening window: frt. pass. side,OFF ,3
IDE08223-MAS10230-Personalization settings key 3-Comfort opening rear window: driver side,OFF ,3
IDE08223-MAS10231-Personalization settings key 3-Comfort opening rear window: frt. pass. side,OFF ,3
IDE08224-MAS02444-Personalization settings key 4-Central locking system,global opening ,3
IDE08224-MAS06456-Personalization settings key 4-Auto lock,On ,3
IDE08224-MAS06457-Personalization settings key 4-Auto unlock,On ,3
IDE08224-MAS06696-Personalization settings key 4-Comfort opening sunroof,OFF ,3
IDE08224-MAS06697-Personalization settings key 4-Acoustic confirmation signal,On ,3
IDE08224-MAS06698-Personalization settings key 4-Highway blinking,On ,3
IDE08224-MAS06740-Personalization settings key 4-Release button in rear lid handle locked,On ,3
IDE08224-MAS06756-Personalization settings key 4-Rear shade automatic,OFF ,3
IDE08224-MAS06880-Personalization settings key 4-Mirror fold-in (Audi),OFF ,3
IDE08224-MAS10221-Personalization settings key 4-Rear lid release via rear lid open sensors,On ,3
IDE08224-MAS10228-Personalization settings key 4-Comfort opening window: driver side,OFF ,3
IDE08224-MAS10229-Personalization settings key 4-Comfort opening window: frt. pass. side,OFF ,3
IDE08224-MAS10230-Personalization settings key 4-Comfort opening rear window: driver side,OFF ,3
IDE08224-MAS10231-Personalization settings key 4-Comfort opening rear window: frt. pass. side,OFF ,3
IDE08225-MAS02444-Personalization settings vehicle-Central locking system,global opening ,3
IDE08225-MAS06456-Personalization settings vehicle-Auto lock,On ,3
IDE08225-MAS06457-Personalization settings vehicle-Auto unlock,On ,3
IDE08225-MAS06696-Personalization settings vehicle-Comfort opening sunroof,OFF ,3
IDE08225-MAS06697-Personalization settings vehicle-Acoustic confirmation signal,On ,3
IDE08225-MAS06698-Personalization settings vehicle-Highway blinking,On ,3
IDE08225-MAS06740-Personalization settings vehicle-Release button in rear lid handle locked,On ,3
IDE08225-MAS06756-Personalization settings vehicle-Rear shade automatic,OFF ,3
IDE08225-MAS06880-Personalization settings vehicle-Mirror fold-in (Audi),OFF ,3
IDE08225-MAS10221-Personalization settings vehicle-Rear lid release via rear lid open sensors,On ,3
IDE08225-MAS10228-Personalization settings vehicle-Comfort opening window: driver side,OFF ,3
IDE08225-MAS10229-Personalization settings vehicle-Comfort opening window: frt. pass. side,OFF ,3
IDE08225-MAS10230-Personalization settings vehicle-Comfort opening rear window: driver side,OFF ,3
IDE08225-MAS10231-Personalization settings vehicle-Comfort opening rear window: frt. pass. side,OFF ,3
IDE08225-MAS16238-Personalization settings vehicle-Keyless access authorization,On ,3
IDE08225-MAS20619-Personalization settings vehicle-Keyless access authorization: automatic opening,not active ,3
IDE08226-Use of personalization settings,Key ,1
IDE08398-Delay time alarm triggering,0 s,1
IDE08399-Delay time crash unlocking,5.0 s,1
IDE08400-Actuation time to open rear lid with remote control,800 ms,1
IDE09735-CU tailgate opener: sensor 1: threshold value 1,55 ,1
IDE09736-CU tailgate opener: sensor 1: threshold value 2,18 ,1
IDE09737-CU tailgate opener: sensor 1: threshold value 3,18 ,1
IDE09738-CU tailgate opener: sensor 1: threshold value 4,18 ,1
IDE09739-CU tailgate opener: sensor 1: threshold value 5,18 ,1
IDE09740-CU tailgate opener: sensor 2: threshold value 1,02 ,1
IDE09741-CU tailgate opener: sensor 2: threshold value 2,1F ,1
IDE09742-CU tailgate opener: sensor 2: threshold value 3,02 ,1
IDE09743-CU tailgate opener: sensor 2: threshold value 4,1F ,1
IDE09744-CU tailgate opener: sensor 2: threshold value 5,46 ,1
IDE09745-CU tailgate opener: sensor 1: timer value 1,AA ,1
IDE09746-CU tailgate opener: sensor 1: timer value 2,00 ,1
IDE09747-CU tailgate opener: sensor 1: timer value 3,00 ,1
IDE09748-CU tailgate opener: sensor 1: timer value 4,C1 ,1
IDE09749-CU tailgate opener: sensor 1: timer value 5,00 ,1
IDE09750-CU tailgate opener: sensor 2: timer value 1,0B ,1
IDE09751-CU tailgate opener: sensor 2: timer value 2,A5 ,1
IDE09752-CU tailgate opener: sensor 2: timer value 3,93 ,1
IDE09753-CU tailgate opener: sensor 2: timer value 4,CC ,1
IDE09754-CU tailgate opener: sensor 2: timer value 5,22 ,1
IDE09755-CU tailgate opener: sensor 1: burst length,10 ,1
IDE09756-CU tailgate opener: sensor 1: active screening,10 ,1
IDE09757-CU tailgate opener: sensor 2: burst length,02 ,1
IDE09758-CU tailgate opener: sensor 2: active screening,1F ,1
IDE09759-CU for tailgate opener: reset all counters,E0 ,1
IDE09760-CU for tailgate opener: check sum,AA ,1
IDE09829-CU tailgate opener: foot gestic recognition: timer value 1,02 ,1
IDE09830-CU tailgate opener: foot gestic recognition: timer value 2,1F ,1
IDE09831-CU for tailgate opener: play protection increments,06 ,1
IDE09832-CU for tailgate opener: play protection decrements,19 ,1
IDE09833-CU for tailgate opener: play protection threshold active,FF ,1
IDE09834-CU for tailgate opener: play protection threshold inactive,05 ,1
IDE09835-CU for tailgate opener: play protection decrement interval,3C ,1
IDE09836-CU tailgate opener: sensor 1: control parameter,10 ,1
IDE09837-CU tailgate opener: sensor 2: control parameter,10 ,1
IDE09838-CU tailgate opener: foot gestic recognition: evaluation,00 ,1
IDE09839-CU for tailgate opener: parameter set version,00 00 ,2
IDE10086-IDE02262-Personal settings of key 1: Part 2-synchronous mirror adjustment,OFF ,1
IDE10086-IDE03946-Personal settings of key 1: Part 2-Mirror dimming,OFF ,1
IDE10086-MAS05213-Personal settings of key 1: Part 2-Mirror heater,OFF ,1
IDE10086-MAS06870-Personal settings of key 1: Part 2-Mirror lowering in reverse,OFF ,1
IDE10086-MAS06881-Personal settings of key 1: Part 2-Mirror fold-in (VW),OFF ,1
IDE10087-IDE02262-Personal settings of key 2: Part 2-synchronous mirror adjustment,OFF ,1
IDE10087-IDE03946-Personal settings of key 2: Part 2-Mirror dimming,OFF ,1
IDE10087-MAS05213-Personal settings of key 2: Part 2-Mirror heater,OFF ,1
IDE10087-MAS06870-Personal settings of key 2: Part 2-Mirror lowering in reverse,OFF ,1
IDE10087-MAS06881-Personal settings of key 2: Part 2-Mirror fold-in (VW),OFF ,1
IDE10088-IDE02262-Personal settings of key 3: Part 2-synchronous mirror adjustment,OFF ,1
IDE10088-IDE03946-Personal settings of key 3: Part 2-Mirror dimming,OFF ,1
IDE10088-MAS05213-Personal settings of key 3: Part 2-Mirror heater,OFF ,1
IDE10088-MAS06870-Personal settings of key 3: Part 2-Mirror lowering in reverse,OFF ,1
IDE10088-MAS06881-Personal settings of key 3: Part 2-Mirror fold-in (VW),OFF ,1
IDE10089-IDE02262-Personal settings of key 4: Part 2-synchronous mirror adjustment,OFF ,1
IDE10089-IDE03946-Personal settings of key 4: Part 2-Mirror dimming,OFF ,1
IDE10089-MAS05213-Personal settings of key 4: Part 2-Mirror heater,OFF ,1
IDE10089-MAS06870-Personal settings of key 4: Part 2-Mirror lowering in reverse,OFF ,1
IDE10089-MAS06881-Personal settings of key 4: Part 2-Mirror fold-in (VW),OFF ,1
IDE10090-IDE02262-Personal settings of vehicle: Part 2-synchronous mirror adjustment,OFF ,1
IDE10090-IDE03946-Personal settings of vehicle: Part 2-Mirror dimming,OFF ,1
IDE10090-MAS05213-Personal settings of vehicle: Part 2-Mirror heater,OFF ,1
IDE10090-MAS06870-Personal settings of vehicle: Part 2-Mirror lowering in reverse,OFF ,1
IDE10090-MAS06881-Personal settings of vehicle: Part 2-Mirror fold-in (VW),OFF ,1
IDE10283-Key identification: transponder ID,FF FF FF FF ,4
IDE10318-Sunshade activation,can be activated ,1
IDE10347-Trip distance challenge,00 00 00 00 00 00 00 00 ,8
IDE10836-Enable code for vehicle positioning system,18477 ,2
IDE10858-Number of simultaneously adapting key,0 ,1
IDE10913-MAS10979-Setting the key data-Start page,46 00 ,3
IDE10913-MAS10980-Setting the key data-No. of pages,04 ,3
IDE10913-MAS11635-Setting the key data-Data security,encrypted ,3
IDE11476-Ignition lock: variant,Audi ,1
IDE11487-Trunk emergency release,OFF ,1
IDE11798-Speed-dependent activation of the back window heater,activated ,1
IDE11935-MAS13456-Personalization-Automatic key assignment,activated ,1
IDE11935-MAS13457-Personalization-Status of personalization,activated ,1
IDE12303-MAS14243-Separation monitoring radio key to rear lid-Minimum opening angle of the rear lid for activation,3 %,6
IDE12303-MAS14244-Separation monitoring radio key to rear lid-Minimum opening angle of the rear lid to reverse,0 %,6
IDE12303-MAS14245-Separation monitoring radio key to rear lid-Lock vehicle after closing,Unknown (4),6
IDE12303-MAS14246-Separation monitoring radio key to rear lid-Monitoring time for rear lid restart,8 %,6
IDE12303-MAS14247-Separation monitoring radio key to rear lid-Monitoring time for rear lid closing,0 %,6
IDE12465-Rear lid opener control module: response in trailer mode,not activated ,2
IDE12481-MAS06700-Horn and flasher via smartphone app-Speed threshold,0 km/h,5
IDE12481-MAS14561-Horn and flasher via smartphone app-Division factor of horn frequency,0 ,5
IDE12481-MAS14562-Horn and flasher via smartphone app-Maximum execution duration,45 s,5
IDE12548-MAS14750-NFC communication: settings-Command category for single-sided NFC authentication,00 ,27
IDE12548-MAS14751-NFC communication: settings-Command for one-sided NFC authentication,10 ,27
IDE12548-MAS14752-NFC communication: settings-Parameter 1 for one-sided NFC authentication,00 ,27
IDE12548-MAS14753-NFC communication: settings-Parameter 2 for one-sided NFC authentication,00 ,27
IDE12548-MAS14754-NFC communication: settings-Command category for two-sided NFC authentication,00 ,27
IDE12548-MAS14755-NFC communication: settings-Command for two-sided NFC authentication,10 ,27
IDE12548-MAS14756-NFC communication: settings-Parameter 1 for two-sided NFC authentication,10 ,27
IDE12548-MAS14757-NFC communication: settings-Parameter 2 for two-sided NFC authentication,00 01 02 ,27
IDE12548-MAS14758-NFC communication: settings-Time point for NFC advance authentication,Last door closed ,27
IDE12548-MAS14761-NFC communication: settings-Block NFC device in the interior,not activated ,27
IDE12548-MAS14762-NFC communication: settings-NFC event search,activated ,27
IDE12548-MAS15378-NFC communication: settings-Command category to trigger an event,00 ,27
IDE12548-MAS15379-NFC communication: settings-Command to trigger an event,10 ,27
IDE12548-MAS15380-NFC communication: settings-Parameter 1 to trigger an event,20 ,27
IDE12548-MAS15381-NFC communication: settings-Parameter 2 to trigger an event,00 ,27
IDE12548-MAS15382-NFC communication: settings-Command category for vehicle data,00 ,27
IDE12548-MAS15383-NFC communication: settings-Command for vehicle data,10 ,27
IDE12548-MAS15384-NFC communication: settings-Parameter 1 for vehicle data,90 ,27
IDE12548-MAS15385-NFC communication: settings-Parameter 2 for vehicle data,01 ,27
IDE12548-MAS15386-NFC communication: settings-Command category for event data,00 ,27
IDE12548-MAS15387-NFC communication: settings-Command for event data,10 ,27
IDE12548-MAS15388-NFC communication: settings-Parameter 1 for event data,90 ,27
IDE12548-MAS15389-NFC communication: settings-Parameter 2 for event data,00 ,27
IDE12548-MAS16723-NFC communication: settings-Expected length of triggering event,00 ,27
IDE12548-MAS16724-NFC communication: settings-Expected length of vehicle data,00 ,27
IDE12548-MAS16725-NFC communication: settings-Expected length of event data,00 ,27
IDE12548-MAS18680-NFC communication: settings-Mobile device charger: duration of charge interruption,2540 ms,27
IDE12792-MAS02444-Personalization of user account 1-Central locking system,global opening ,3
IDE12792-MAS06456-Personalization of user account 1-Auto lock,On ,3
IDE12792-MAS06457-Personalization of user account 1-Auto unlock,On ,3
IDE12792-MAS06696-Personalization of user account 1-Comfort opening sunroof,On ,3
IDE12792-MAS06697-Personalization of user account 1-Acoustic confirmation signal,On ,3
IDE12792-MAS06698-Personalization of user account 1-Highway blinking,On ,3
IDE12792-MAS06740-Personalization of user account 1-Release button in rear lid handle locked,On ,3
IDE12792-MAS06756-Personalization of user account 1-Rear shade automatic,OFF ,3
IDE12792-MAS06880-Personalization of user account 1-Mirror fold-in (Audi),On ,3
IDE12792-MAS10221-Personalization of user account 1-Rear lid release via rear lid open sensors,On ,3
IDE12792-MAS10228-Personalization of user account 1-Comfort opening window: driver side,On ,3
IDE12792-MAS10229-Personalization of user account 1-Comfort opening window: frt. pass. side,On ,3
IDE12792-MAS10230-Personalization of user account 1-Comfort opening rear window: driver side,On ,3
IDE12792-MAS10231-Personalization of user account 1-Comfort opening rear window: frt. pass. side,On ,3
IDE12792-MAS20789-Personalization of user account 1-Signature for tail light,0 ,3
IDE12793-IDE02262-Personalization of user account 1: part 2-synchronous mirror adjustment,OFF ,1
IDE12793-IDE03946-Personalization of user account 1: part 2-Mirror dimming,OFF ,1
IDE12793-MAS05213-Personalization of user account 1: part 2-Mirror heater,OFF ,1
IDE12793-MAS06870-Personalization of user account 1: part 2-Mirror lowering in reverse,OFF ,1
IDE12793-MAS06881-Personalization of user account 1: part 2-Mirror fold-in (VW),OFF ,1
IDE12794-MAS02444-Personalization of user account 2-Central locking system,Individual door opening ,3
IDE12794-MAS06456-Personalization of user account 2-Auto lock,On ,3
IDE12794-MAS06457-Personalization of user account 2-Auto unlock,On ,3
IDE12794-MAS06696-Personalization of user account 2-Comfort opening sunroof,On ,3
IDE12794-MAS06697-Personalization of user account 2-Acoustic confirmation signal,On ,3
IDE12794-MAS06698-Personalization of user account 2-Highway blinking,On ,3
IDE12794-MAS06740-Personalization of user account 2-Release button in rear lid handle locked,On ,3
IDE12794-MAS06756-Personalization of user account 2-Rear shade automatic,OFF ,3
IDE12794-MAS06880-Personalization of user account 2-Mirror fold-in (Audi),On ,3
IDE12794-MAS10221-Personalization of user account 2-Rear lid release via rear lid open sensors,On ,3
IDE12794-MAS10228-Personalization of user account 2-Comfort opening window: driver side,On ,3
IDE12794-MAS10229-Personalization of user account 2-Comfort opening window: frt. pass. side,On ,3
IDE12794-MAS10230-Personalization of user account 2-Comfort opening rear window: driver side,On ,3
IDE12794-MAS10231-Personalization of user account 2-Comfort opening rear window: frt. pass. side,On ,3
IDE12794-MAS20789-Personalization of user account 2-Signature for tail light,0 ,3
IDE12795-IDE02262-Personalization of user account 2: part 2-synchronous mirror adjustment,OFF ,1
IDE12795-IDE03946-Personalization of user account 2: part 2-Mirror dimming,OFF ,1
IDE12795-MAS05213-Personalization of user account 2: part 2-Mirror heater,OFF ,1
IDE12795-MAS06870-Personalization of user account 2: part 2-Mirror lowering in reverse,OFF ,1
IDE12795-MAS06881-Personalization of user account 2: part 2-Mirror fold-in (VW),OFF ,1
IDE12796-MAS02444-Personalization of user account 3-Central locking system,global opening ,3
IDE12796-MAS06456-Personalization of user account 3-Auto lock,On ,3
IDE12796-MAS06457-Personalization of user account 3-Auto unlock,On ,3
IDE12796-MAS06696-Personalization of user account 3-Comfort opening sunroof,OFF ,3
IDE12796-MAS06697-Personalization of user account 3-Acoustic confirmation signal,On ,3
IDE12796-MAS06698-Personalization of user account 3-Highway blinking,On ,3
IDE12796-MAS06740-Personalization of user account 3-Release button in rear lid handle locked,On ,3
IDE12796-MAS06756-Personalization of user account 3-Rear shade automatic,OFF ,3
IDE12796-MAS06880-Personalization of user account 3-Mirror fold-in (Audi),OFF ,3
IDE12796-MAS10221-Personalization of user account 3-Rear lid release via rear lid open sensors,On ,3
IDE12796-MAS10228-Personalization of user account 3-Comfort opening window: driver side,OFF ,3
IDE12796-MAS10229-Personalization of user account 3-Comfort opening window: frt. pass. side,OFF ,3
IDE12796-MAS10230-Personalization of user account 3-Comfort opening rear window: driver side,OFF ,3
IDE12796-MAS10231-Personalization of user account 3-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12796-MAS20789-Personalization of user account 3-Signature for tail light,0 ,3
IDE12797-IDE02262-Personalization of user account 3: part 2-synchronous mirror adjustment,OFF ,1
IDE12797-IDE03946-Personalization of user account 3: part 2-Mirror dimming,OFF ,1
IDE12797-MAS05213-Personalization of user account 3: part 2-Mirror heater,OFF ,1
IDE12797-MAS06870-Personalization of user account 3: part 2-Mirror lowering in reverse,OFF ,1
IDE12797-MAS06881-Personalization of user account 3: part 2-Mirror fold-in (VW),OFF ,1
IDE12798-MAS02444-Personalization of user account 4-Central locking system,global opening ,3
IDE12798-MAS06456-Personalization of user account 4-Auto lock,On ,3
IDE12798-MAS06457-Personalization of user account 4-Auto unlock,On ,3
IDE12798-MAS06696-Personalization of user account 4-Comfort opening sunroof,OFF ,3
IDE12798-MAS06697-Personalization of user account 4-Acoustic confirmation signal,On ,3
IDE12798-MAS06698-Personalization of user account 4-Highway blinking,On ,3
IDE12798-MAS06740-Personalization of user account 4-Release button in rear lid handle locked,On ,3
IDE12798-MAS06756-Personalization of user account 4-Rear shade automatic,OFF ,3
IDE12798-MAS06880-Personalization of user account 4-Mirror fold-in (Audi),OFF ,3
IDE12798-MAS10221-Personalization of user account 4-Rear lid release via rear lid open sensors,On ,3
IDE12798-MAS10228-Personalization of user account 4-Comfort opening window: driver side,OFF ,3
IDE12798-MAS10229-Personalization of user account 4-Comfort opening window: frt. pass. side,OFF ,3
IDE12798-MAS10230-Personalization of user account 4-Comfort opening rear window: driver side,OFF ,3
IDE12798-MAS10231-Personalization of user account 4-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12798-MAS20789-Personalization of user account 4-Signature for tail light,0 ,3
IDE12799-IDE02262-Personalization of user account 4: part 2-synchronous mirror adjustment,OFF ,1
IDE12799-IDE03946-Personalization of user account 4: part 2-Mirror dimming,OFF ,1
IDE12799-MAS05213-Personalization of user account 4: part 2-Mirror heater,OFF ,1
IDE12799-MAS06870-Personalization of user account 4: part 2-Mirror lowering in reverse,OFF ,1
IDE12799-MAS06881-Personalization of user account 4: part 2-Mirror fold-in (VW),OFF ,1
IDE12800-MAS02444-Personalization of user account 5-Central locking system,global opening ,3
IDE12800-MAS06456-Personalization of user account 5-Auto lock,On ,3
IDE12800-MAS06457-Personalization of user account 5-Auto unlock,On ,3
IDE12800-MAS06696-Personalization of user account 5-Comfort opening sunroof,OFF ,3
IDE12800-MAS06697-Personalization of user account 5-Acoustic confirmation signal,On ,3
IDE12800-MAS06698-Personalization of user account 5-Highway blinking,On ,3
IDE12800-MAS06740-Personalization of user account 5-Release button in rear lid handle locked,On ,3
IDE12800-MAS06756-Personalization of user account 5-Rear shade automatic,OFF ,3
IDE12800-MAS06880-Personalization of user account 5-Mirror fold-in (Audi),OFF ,3
IDE12800-MAS10221-Personalization of user account 5-Rear lid release via rear lid open sensors,On ,3
IDE12800-MAS10228-Personalization of user account 5-Comfort opening window: driver side,OFF ,3
IDE12800-MAS10229-Personalization of user account 5-Comfort opening window: frt. pass. side,OFF ,3
IDE12800-MAS10230-Personalization of user account 5-Comfort opening rear window: driver side,OFF ,3
IDE12800-MAS10231-Personalization of user account 5-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12800-MAS20789-Personalization of user account 5-Signature for tail light,0 ,3
IDE12801-IDE02262-Personalization of user account 5: part 2-synchronous mirror adjustment,OFF ,1
IDE12801-IDE03946-Personalization of user account 5: part 2-Mirror dimming,OFF ,1
IDE12801-MAS05213-Personalization of user account 5: part 2-Mirror heater,OFF ,1
IDE12801-MAS06870-Personalization of user account 5: part 2-Mirror lowering in reverse,OFF ,1
IDE12801-MAS06881-Personalization of user account 5: part 2-Mirror fold-in (VW),OFF ,1
IDE12802-MAS02444-Personalization of user account 6-Central locking system,global opening ,3
IDE12802-MAS06456-Personalization of user account 6-Auto lock,On ,3
IDE12802-MAS06457-Personalization of user account 6-Auto unlock,On ,3
IDE12802-MAS06696-Personalization of user account 6-Comfort opening sunroof,OFF ,3
IDE12802-MAS06697-Personalization of user account 6-Acoustic confirmation signal,On ,3
IDE12802-MAS06698-Personalization of user account 6-Highway blinking,On ,3
IDE12802-MAS06740-Personalization of user account 6-Release button in rear lid handle locked,On ,3
IDE12802-MAS06756-Personalization of user account 6-Rear shade automatic,OFF ,3
IDE12802-MAS06880-Personalization of user account 6-Mirror fold-in (Audi),OFF ,3
IDE12802-MAS10221-Personalization of user account 6-Rear lid release via rear lid open sensors,On ,3
IDE12802-MAS10228-Personalization of user account 6-Comfort opening window: driver side,OFF ,3
IDE12802-MAS10229-Personalization of user account 6-Comfort opening window: frt. pass. side,OFF ,3
IDE12802-MAS10230-Personalization of user account 6-Comfort opening rear window: driver side,OFF ,3
IDE12802-MAS10231-Personalization of user account 6-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12802-MAS20789-Personalization of user account 6-Signature for tail light,0 ,3
IDE12803-IDE02262-Personalization of user account 6: part 2-synchronous mirror adjustment,OFF ,1
IDE12803-IDE03946-Personalization of user account 6: part 2-Mirror dimming,OFF ,1
IDE12803-MAS05213-Personalization of user account 6: part 2-Mirror heater,OFF ,1
IDE12803-MAS06870-Personalization of user account 6: part 2-Mirror lowering in reverse,OFF ,1
IDE12803-MAS06881-Personalization of user account 6: part 2-Mirror fold-in (VW),OFF ,1
IDE12804-MAS02444-Personalization of user account 7-Central locking system,global opening ,3
IDE12804-MAS06456-Personalization of user account 7-Auto lock,On ,3
IDE12804-MAS06457-Personalization of user account 7-Auto unlock,On ,3
IDE12804-MAS06696-Personalization of user account 7-Comfort opening sunroof,OFF ,3
IDE12804-MAS06697-Personalization of user account 7-Acoustic confirmation signal,On ,3
IDE12804-MAS06698-Personalization of user account 7-Highway blinking,On ,3
IDE12804-MAS06740-Personalization of user account 7-Release button in rear lid handle locked,On ,3
IDE12804-MAS06756-Personalization of user account 7-Rear shade automatic,OFF ,3
IDE12804-MAS06880-Personalization of user account 7-Mirror fold-in (Audi),OFF ,3
IDE12804-MAS10221-Personalization of user account 7-Rear lid release via rear lid open sensors,On ,3
IDE12804-MAS10228-Personalization of user account 7-Comfort opening window: driver side,OFF ,3
IDE12804-MAS10229-Personalization of user account 7-Comfort opening window: frt. pass. side,OFF ,3
IDE12804-MAS10230-Personalization of user account 7-Comfort opening rear window: driver side,OFF ,3
IDE12804-MAS10231-Personalization of user account 7-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12804-MAS20789-Personalization of user account 7-Signature for tail light,0 ,3
IDE12805-IDE02262-Personalization of user account 7: part 2-synchronous mirror adjustment,OFF ,1
IDE12805-IDE03946-Personalization of user account 7: part 2-Mirror dimming,OFF ,1
IDE12805-MAS05213-Personalization of user account 7: part 2-Mirror heater,OFF ,1
IDE12805-MAS06870-Personalization of user account 7: part 2-Mirror lowering in reverse,OFF ,1
IDE12805-MAS06881-Personalization of user account 7: part 2-Mirror fold-in (VW),OFF ,1
IDE12808-Personalization of user account 1: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12809-Personalization of user account 2: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12810-Personalization of user account 3: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12811-Personalization of user account 4: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12812-Personalization of user account 5: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12813-Personalization of user account 6: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12814-Personalization of user account 7: name,47 61 73 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12815-MAS15187-User accounts for the NFC devices-User account of NFC device 1,0 ,8
IDE12815-MAS15188-User accounts for the NFC devices-User account of NFC device 2,0 ,8
IDE12815-MAS15189-User accounts for the NFC devices-User account of NFC device 3,0 ,8
IDE12815-MAS15190-User accounts for the NFC devices-User account of NFC device 4,0 ,8
IDE12815-MAS15191-User accounts for the NFC devices-User account of NFC device 5,0 ,8
IDE12815-MAS15192-User accounts for the NFC devices-User account of NFC device 6,0 ,8
IDE12815-MAS15193-User accounts for the NFC devices-User account of NFC device 7,0 ,8
IDE12815-MAS15194-User accounts for the NFC devices-User account of NFC device 8,0 ,8
IDE12815-MAS15195-User accounts for the NFC devices-User account of NFC device 9,0 ,8
IDE12815-MAS15196-User accounts for the NFC devices-User account of NFC device 10,0 ,8
IDE12815-MAS15197-User accounts for the NFC devices-User account of NFC device 11,0 ,8
IDE12815-MAS15198-User accounts for the NFC devices-User account of NFC device 12,0 ,8
IDE12815-MAS15199-User accounts for the NFC devices-User account of NFC device 13,0 ,8
IDE12815-MAS15200-User accounts for the NFC devices-User account of NFC device 14,0 ,8
IDE12815-MAS15201-User accounts for the NFC devices-User account of NFC device 15,0 ,8
IDE12815-MAS15202-User accounts for the NFC devices-User account of NFC device 16,0 ,8
IDE12938-MAS15390-NFC communication 2: settings-Command category for SELECT,00 ,22
IDE12938-MAS15391-NFC communication 2: settings-Command for SELECT,A4 ,22
IDE12938-MAS15392-NFC communication 2: settings-Parameter 1 for SELECT,04 ,22
IDE12938-MAS15393-NFC communication 2: settings-Parameter 2 for SELECT,00 ,22
IDE12938-MAS15394-NFC communication 2: settings-Utility data length for SELECT,0F ,22
IDE12938-MAS15395-NFC communication 2: settings-Application ID for SELECT,A0 00 00 07 02 00 00 00 00 00 00 01 00 00 01 00 ,22
IDE12938-MAS15396-NFC communication 2: settings-Expected length for SELECT,10 ,22
IDE13253-MAS16009-Convertible top convenience operation-Convenience closure with radio key,On ,2
IDE13253-MAS16010-Convertible top convenience operation-Convenience opening with lock cylinder,On ,2
IDE13253-MAS16011-Convertible top convenience operation-Convenience closing with exterior door handle touch sensor,On ,2
IDE13253-MAS16012-Convertible top convenience operation-Convenience opening with radio key,On ,2
IDE13253-MAS16013-Convertible top convenience operation-Convenient opening with lock cylinder,On ,2
IDE13254-MAS16014-Convenience opening: control points-Convenience opening of the window regulator with radio key,On ,2
IDE13254-MAS16015-Convenience opening: control points-Convenience opening of the window regulator with lock cylinder,On ,2
IDE13254-MAS16016-Convenience opening: control points-Convenience opening of the window regulator with window regulator button,On ,2
IDE13254-MAS16017-Convenience opening: control points-Convenience opening of the roof shade with the radio key,On ,2
IDE13254-MAS16018-Convenience opening: control points-Convenience opening of the roof shade with lock cylinder,On ,2
IDE13254-MAS16019-Convenience opening: control points-Convenience opening of the roof shade with window regulator button,On ,2
IDE13254-MAS16020-Convenience opening: control points-Comfort opening only for driver door,OFF ,2
IDE13254-MAS16029-Convenience opening: control points-Convenience opening of the sunroof with radio key,On ,2
IDE13254-MAS16030-Convenience opening: control points-Convenience opening of the sunroof with lock cylinder,On ,2
IDE13254-MAS16031-Convenience opening: control points-Convenience opening of the sun roof with window regulator button,On ,2
IDE13254-MAS16032-Convenience opening: control points-Convenience opening of rear sun roof with radio key,On ,2
IDE13254-MAS16033-Convenience opening: control points-Convenience opening of rear sun roof with lock cylinder,On ,2
IDE13254-MAS16034-Convenience opening: control points-Comfort opening of the rear sunroof with window regulator button,On ,2
IDE13255-MAS16021-Convenience closing: control points-Convenience closure of the window regulator with radio key,On ,2
IDE13255-MAS16022-Convenience closing: control points-Convenience closure of the window regulator with lock cylinder,On ,2
IDE13255-MAS16023-Convenience closing: control points-Convenience closure of the window regulator with window regulator button,On ,2
IDE13255-MAS16024-Convenience closing: control points-Convenience closure of window regulator with outside door handle sensor,On ,2
IDE13255-MAS16025-Convenience closing: control points-Convenience closing of the roof shade with the radio key,On ,2
IDE13255-MAS16026-Convenience closing: control points-Convenience closure of the roof shade with lock cylinder,On ,2
IDE13255-MAS16027-Convenience closing: control points-Convenience closure of the roof shade with window regulator button,On ,2
IDE13255-MAS16028-Convenience closing: control points-Convenience closure of roof shade with outside door handle,On ,2
IDE13255-MAS16035-Convenience closing: control points-Convenience closure of sun roof with radio key,On ,2
IDE13255-MAS16036-Convenience closing: control points-Convenience closing of the sunroof with lock cylinder,On ,2
IDE13255-MAS16037-Convenience closing: control points-Convenience closure of the sun roof with window regulator button,On ,2
IDE13255-MAS16038-Convenience closing: control points-Convenience closure of sunroof with outside door handle sensor,On ,2
IDE13255-MAS16039-Convenience closing: control points-Convenience closure of rear sun roof with radio key,On ,2
IDE13255-MAS16040-Convenience closing: control points-Convenience closure of rear sun roof with lock cylinder,On ,2
IDE13255-MAS16041-Convenience closing: control points-Convenience closure of the rear sun roof with window regulator button,On ,2
IDE13255-MAS16042-Convenience closing: control points-Convenience closure of rear sunroof with outside door handle sensor,On ,2
IDE14072-MAS17381-Central locking system actuation counter: configuration-Interface 1: counter 1,0 ,12
IDE14072-MAS17382-Central locking system actuation counter: configuration-Interface 2: counter 1,0 ,12
IDE14072-MAS17383-Central locking system actuation counter: configuration-Interface 3: counter 1,0 ,12
IDE14072-MAS17384-Central locking system actuation counter: configuration-Interface 1: counter 2,0 ,12
IDE14072-MAS17385-Central locking system actuation counter: configuration-Interface 2: counter 2,0 ,12
IDE14072-MAS17386-Central locking system actuation counter: configuration-Interface 3: counter 2,0 ,12
IDE14072-MAS17387-Central locking system actuation counter: configuration-Interface 1: counter 3,0 ,12
IDE14072-MAS17388-Central locking system actuation counter: configuration-Interface 2: counter 3,0 ,12
IDE14072-MAS17389-Central locking system actuation counter: configuration-Interface 3: counter 3,0 ,12
IDE14072-MAS17390-Central locking system actuation counter: configuration-Interface 1: counter 4,0 ,12
IDE14072-MAS17391-Central locking system actuation counter: configuration-Interface 2: counter 4,0 ,12
IDE14072-MAS17392-Central locking system actuation counter: configuration-Interface 3: counter 4,0 ,12
IDE14661-MAS18674-NFC communication 3: settings-Trigger event waiting time,0 ms,8
IDE14661-MAS18675-NFC communication 3: settings-Waiting time for sending event data,0 ms,8
IDE14661-MAS18676-NFC communication 3: settings-Waiting time for sending vehicle health data,300 ms,8
IDE14661-MAS18677-NFC communication 3: settings-Trigger NFC event,activated ,8
IDE14661-MAS18678-NFC communication 3: settings-Send NFC event data,activated ,8
IDE14661-MAS18679-NFC communication 3: settings-Send NFC vehicle health data,activated ,8
MAS13921-IDE00047-Control module rear lid opening: dataset-Parameter set version,0 ,37
MAS13921-IDE80001-Control module rear lid opening: dataset-Analysis 1,1 ,37
MAS13921-IDE80002-Control module rear lid opening: dataset-Analysis 2,1 ,37
MAS13921-IDE80003-Control module rear lid opening: dataset-Analysis 3,1 ,37
MAS13921-IDE80004-Control module rear lid opening: dataset-Analysis 4,1 ,37
MAS13921-IDE80005-Control module rear lid opening: dataset-Analysis 5,24 ,37
MAS13921-IDE80006-Control module rear lid opening: dataset-Analysis 6,24 ,37
MAS13921-IDE80007-Control module rear lid opening: dataset-Analysis 7,24 ,37
MAS13921-IDE80008-Control module rear lid opening: dataset-Analysis 8,24 ,37
MAS13921-IDE80009-Control module rear lid opening: dataset-Analysis 9,2 ,37
MAS13921-IDE80010-Control module rear lid opening: dataset-Analysis 10,31 ,37
MAS13921-IDE80011-Control module rear lid opening: dataset-Analysis 11,2 ,37
MAS13921-IDE80012-Control module rear lid opening: dataset-Analysis 12,31 ,37
MAS13921-IDE80013-Control module rear lid opening: dataset-Analysis 13,70 ,37
MAS13921-IDE80014-Control module rear lid opening: dataset-Analysis 14,10 ,37
MAS13921-IDE80015-Control module rear lid opening: dataset-Analysis 15,10 ,37
MAS13921-IDE80016-Control module rear lid opening: dataset-Analysis 16,0 ,37
MAS13921-IDE80017-Control module rear lid opening: dataset-Analysis 17,0 ,37
MAS13921-IDE80018-Control module rear lid opening: dataset-Analysis 18,0 ,37
MAS13921-IDE80019-Control module rear lid opening: dataset-Analysis 19,0 ,37
MAS13921-IDE80020-Control module rear lid opening: dataset-Analysis 20,active ,37
MAS13921-IDE80021-Control module rear lid opening: dataset-Analysis 21,not active ,37
MAS13921-IDE80022-Control module rear lid opening: dataset-Analysis 22,not active ,37
MAS13921-IDE80023-Control module rear lid opening: dataset-Analysis 23,Bottom ,37
MAS13921-IDE80024-Control module rear lid opening: dataset-Analysis 24,static ,37
MAS13921-IDE80025-Control module rear lid opening: dataset-Analysis 25,3 ,37
MAS13921-IDE80026-Control module rear lid opening: dataset-Analysis 26,not active ,37
MAS13921-IDE80027-Control module rear lid opening: dataset-Analysis 27,Dynamic ,37
MAS13921-IDE80028-Control module rear lid opening: dataset-Analysis 28,5 ,37
MAS13921-IDE80029-Control module rear lid opening: dataset-Analysis 29,6 ,37
MAS13921-IDE80030-Control module rear lid opening: dataset-Analysis 30,active ,37
MAS13921-IDE80031-Control module rear lid opening: dataset-Analysis 31,19 ,37
MAS13921-IDE80032-Control module rear lid opening: dataset-Analysis 32,2 ,37
MAS13921-IDE80033-Control module rear lid opening: dataset-Analysis 33,12 ,37
MAS13921-IDE80034-Control module rear lid opening: dataset-Analysis 34,4 ,37
MAS13921-IDE80035-Control module rear lid opening: dataset-Analysis 35,Do not reset ,37
MAS13921-IDE80036-Control module rear lid opening: dataset-Analysis 36,16 ,37
MAS13921-IDE80037-Control module rear lid opening: dataset-Analysis 37,16 ,37
MAS13921-IDE80038-Control module rear lid opening: dataset-Analysis 38,16 ,37
MAS13921-IDE80039-Control module rear lid opening: dataset-Analysis 39,16 ,37
MAS13921-IDE80040-Control module rear lid opening: dataset-Analysis 40,2 ,37
MAS13921-IDE80041-Control module rear lid opening: dataset-Analysis 41,31 ,37
MAS13921-IDE80042-Control module rear lid opening: dataset-Analysis 42,2 ,37
MAS13921-IDE80043-Control module rear lid opening: dataset-Analysis 43,31 ,37
MAS13921-IDE80044-Control module rear lid opening: dataset-Analysis 44,224 ,37
MAS13921-IDE80045-Control module rear lid opening: dataset-Analysis 45,10 ,37
MAS13921-IDE80046-Control module rear lid opening: dataset-Analysis 46,10 ,37
MAS13921-IDE80047-Control module rear lid opening: dataset-Analysis 47,0 ,37
MAS13921-IDE80048-Control module rear lid opening: dataset-Analysis 48,0 ,37
MAS13921-IDE80049-Control module rear lid opening: dataset-Analysis 49,0 ,37
MAS13921-IDE80050-Control module rear lid opening: dataset-Analysis 50,0 ,37
MAS13921-IDE80051-Control module rear lid opening: dataset-Analysis 51,6 ,37
MAS13921-IDE80052-Control module rear lid opening: dataset-Analysis 52,25 ,37
MAS13921-IDE80053-Control module rear lid opening: dataset-Analysis 53,255 ,37
MAS13921-IDE80054-Control module rear lid opening: dataset-Analysis 54,5 ,37
MAS13921-IDE80055-Control module rear lid opening: dataset-Analysis 55,60 ,37
MAS13921-IDE80056-Control module rear lid opening: dataset-Analysis 56,34 ,37
MAS13921-MAS01078-Control module rear lid opening: dataset-Vehicle model,0 ,37
MAS13921-MAS14087-Control module rear lid opening: dataset-time delay activation,not active ,37
MAS19655-MAS19656-Open rear lid by pushing remote control twice-Actuation time 1 for double-actuation,5100 ms,4
MAS19655-MAS19657-Open rear lid by pushing remote control twice-Actuation time 2 for double-actuation,5100 ms,4
MAS19655-MAS19658-Open rear lid by pushing remote control twice-Time window for double-actuation,1.40 s,4
ENG146368-ENG146489-central_locking_system-autolock_rear,On ,2
ENG146368-ENG146488-central_locking_system-beep_at_opening,OFF ,2
ENG146368-ENG146490-central_locking_system-global_unlocking_via_kessy_double_puls,OFF ,2
ENG146368-ENG146491-central_locking_system-unlocking_rear_via_vip_at_s_contact_active,OFF ,2
ENG153792-Conti_debug_switch,FF FF ,2
ENG146414-ffb_kessy_active_for_piloted_parking,Kessy_and_ffb_at_kl15_on_and_piloted_parking_event_active ,1
ENG146373-headlamp_range_adjustment,OFF ,1
ENG146406-ENG146575-Heated_front_window_lin_relais-Off_delay,0.50 s,14
ENG146406-ENG146574-Heated_front_window_lin_relais-On_delay,0.50 s,14
ENG146406-ENG146571-Heated_front_window_lin_relais-Threshold_driver_side_off,150 W,14
ENG146406-ENG146570-Heated_front_window_lin_relais-Threshold_driver_side_on,300 W,14
ENG146406-ENG146573-Heated_front_window_lin_relais-Threshold_passenger_side_off,350 W,14
ENG146406-ENG146572-Heated_front_window_lin_relais-Threshold_passenger_side_on,500 W,14
ENG146406-ENG146576-Heated_front_window_lin_relais-Two_Relais_installed,1 ,14
ENG146400-ENG146554-Heated_rear_window_with_extension-Default_activation_time,10 min,16
ENG146400-ENG155020-Heated_rear_window_with_extension-Delay_time_deactivate_heated_rear_window,1.00 ,16
ENG146400-ENG146546-Heated_rear_window_with_extension-Interval_1,5 min,16
ENG146400-ENG146547-Heated_rear_window_with_extension-Interval_2,7 min,16
ENG146400-ENG146548-Heated_rear_window_with_extension-Interval_3,15 min,16
ENG146400-ENG146549-Heated_rear_window_with_extension-Interval_4,20 min,16
ENG146400-ENG146550-Heated_rear_window_with_extension-Renewal_interval_1,0 min,16
ENG146400-ENG146551-Heated_rear_window_with_extension-Renewal_interval_2,3 min,16
ENG146400-ENG146552-Heated_rear_window_with_extension-Renewal_interval_3,5 min,16
ENG146400-ENG146553-Heated_rear_window_with_extension-Renewal_interval_4,0 min,16
ENG146400-ENG146555-Heated_rear_window_with_extension-Speed_theshold,50 ,16
ENG146400-ENG145114-Heated_rear_window_with_extension-Temperature_1,132 ,16
ENG146400-ENG145115-Heated_rear_window_with_extension-Temperature_2,124 ,16
ENG146400-ENG146545-Heated_rear_window_with_extension-Temperature_3,116 ,16
ENG146372-ENG146515-horn_settings-number_of_acoustic_acknowlagement_signals_zv_close,2 ,2
ENG146372-ENG146514-horn_settings-number_of_acoustic_acknowlagement_signals_zv_open,1 ,2
ENG153896-ENG146539-Mobile_Key-idle_time_state_S1,60 ,4
ENG153896-ENG155141-Mobile_Key-idle_time_state_S2,20 ,4
ENG153896-ENG155142-Mobile_Key-idle_time_vtan_state_S1,60 ,4
ENG153896-ENG155143-Mobile_Key-idle_time_vtan_state_S2,20 ,4
ENG146397-ENG146535-mq_ewi_activation-ewi_mode,On ,4
ENG146397-ENG146534-mq_ewi_activation-ewi_trace,On ,4
ENG146397-ENG146536-mq_ewi_activation-ewi_trace_messages,FF FF FF ,4
ENG247341-Personalisation_2_0_ew,150 ms,5
ENG146405-ENG146480-Personalisation_ew-Delay_Time,0.60 s,8
ENG146405-ENG146558-Personalisation_ew-FSG_Setup2_Bit1,0 ,8
ENG146405-ENG146559-Personalisation_ew-FSG_Setup2_Bit2,0 ,8
ENG146405-ENG146560-Personalisation_ew-FSG_Setup2_Bit3,1 ,8
ENG146405-ENG146561-Personalisation_ew-FSG_Setup2_Bit4,0 ,8
ENG146405-ENG146562-Personalisation_ew-FSG_Setup2_Bit5,0 ,8
ENG146405-ENG146563-Personalisation_ew-FSG_Setup2_Bit6,1 ,8
ENG146405-ENG146564-Personalisation_ew-FSG_Setup2_Bit7,1 ,8
ENG146405-ENG146569-Personalisation_ew-Minimum_display_duration,1 ,8
ENG146405-ENG146566-Personalisation_ew-Number_of_accounts,7 ,8
ENG146405-ENG146577-Personalisation_ew-Prioritization_device,1 ,8
ENG146405-ENG146567-Personalisation_ew-Time_slot_driver_door_opening,0.30 s,8
ENG146405-ENG146565-Personalisation_ew-Time_slot_key_identification,5 ,8
ENG146405-ENG146568-Personalisation_ew-Timeout_drive_active,60 ,8
ENG146375-ENG146520-pwm_levels_hl_1-pwm_high_1,100 ,3
ENG146375-ENG146521-pwm_levels_hl_1-pwm_high_2,0 ,3
ENG146375-ENG146519-pwm_levels_hl_1-pwm_low,0 ,3
ENG146384-ENG146520-pwm_levels_hl_10-pwm_high_1,100 ,3
ENG146384-ENG146521-pwm_levels_hl_10-pwm_high_2,0 ,3
ENG146384-ENG146519-pwm_levels_hl_10-pwm_low,0 ,3
ENG146385-ENG146520-pwm_levels_hl_11-pwm_high_1,0 ,3
ENG146385-ENG146521-pwm_levels_hl_11-pwm_high_2,0 ,3
ENG146385-ENG146519-pwm_levels_hl_11-pwm_low,100 ,3
ENG146386-ENG146520-pwm_levels_hl_12-pwm_high_1,100 ,3
ENG146386-ENG146521-pwm_levels_hl_12-pwm_high_2,0 ,3
ENG146386-ENG146519-pwm_levels_hl_12-pwm_low,0 ,3
ENG146387-ENG146520-pwm_levels_hl_13-pwm_high_1,100 ,3
ENG146387-ENG146521-pwm_levels_hl_13-pwm_high_2,100 ,3
ENG146387-ENG146519-pwm_levels_hl_13-pwm_low,100 ,3
ENG146388-ENG146520-pwm_levels_hl_14-pwm_high_1,100 ,3
ENG146388-ENG146521-pwm_levels_hl_14-pwm_high_2,0 ,3
ENG146388-ENG146519-pwm_levels_hl_14-pwm_low,0 ,3
ENG146389-ENG146520-pwm_levels_hl_15-pwm_high_1,0 ,3
ENG146389-ENG146521-pwm_levels_hl_15-pwm_high_2,0 ,3
ENG146389-ENG146519-pwm_levels_hl_15-pwm_low,100 ,3
ENG146390-ENG146520-pwm_levels_hl_16-pwm_high_1,0 ,3
ENG146390-ENG146521-pwm_levels_hl_16-pwm_high_2,100 ,3
ENG146390-ENG146519-pwm_levels_hl_16-pwm_low,0 ,3
ENG146391-ENG146520-pwm_levels_hl_17-pwm_high_1,100 ,3
ENG146391-ENG146521-pwm_levels_hl_17-pwm_high_2,100 ,3
ENG146391-ENG146519-pwm_levels_hl_17-pwm_low,0 ,3
ENG146392-ENG146520-pwm_levels_hl_18-pwm_high_1,100 ,3
ENG146392-ENG146521-pwm_levels_hl_18-pwm_high_2,0 ,3
ENG146392-ENG146519-pwm_levels_hl_18-pwm_low,0 ,3
ENG146393-ENG146520-pwm_levels_hl_19-pwm_high_1,100 ,3
ENG146393-ENG146521-pwm_levels_hl_19-pwm_high_2,0 ,3
ENG146393-ENG146519-pwm_levels_hl_19-pwm_low,0 ,3
ENG146376-ENG146520-pwm_levels_hl_2-pwm_high_1,100 ,3
ENG146376-ENG146521-pwm_levels_hl_2-pwm_high_2,0 ,3
ENG146376-ENG146519-pwm_levels_hl_2-pwm_low,0 ,3
ENG146394-ENG146520-pwm_levels_hl_20-pwm_high_1,0 ,3
ENG146394-ENG146521-pwm_levels_hl_20-pwm_high_2,0 ,3
ENG146394-ENG146519-pwm_levels_hl_20-pwm_low,0 ,3
ENG146395-ENG146520-pwm_levels_hl_21-pwm_high_1,0 ,3
ENG146395-ENG146521-pwm_levels_hl_21-pwm_high_2,0 ,3
ENG146395-ENG146519-pwm_levels_hl_21-pwm_low,0 ,3
ENG146377-ENG146520-pwm_levels_hl_3-pwm_high_1,100 ,3
ENG146377-ENG146521-pwm_levels_hl_3-pwm_high_2,0 ,3
ENG146377-ENG146519-pwm_levels_hl_3-pwm_low,0 ,3
ENG146378-ENG146520-pwm_levels_hl_4-pwm_high_1,100 ,3
ENG146378-ENG146521-pwm_levels_hl_4-pwm_high_2,0 ,3
ENG146378-ENG146519-pwm_levels_hl_4-pwm_low,0 ,3
ENG146379-ENG146520-pwm_levels_hl_5-pwm_high_1,0 ,3
ENG146379-ENG146521-pwm_levels_hl_5-pwm_high_2,0 ,3
ENG146379-ENG146519-pwm_levels_hl_5-pwm_low,100 ,3
ENG146380-ENG146520-pwm_levels_hl_6-pwm_high_1,0 ,3
ENG146380-ENG146521-pwm_levels_hl_6-pwm_high_2,0 ,3
ENG146380-ENG146519-pwm_levels_hl_6-pwm_low,100 ,3
ENG146381-ENG146520-pwm_levels_hl_7-pwm_high_1,100 ,3
ENG146381-ENG146521-pwm_levels_hl_7-pwm_high_2,100 ,3
ENG146381-ENG146519-pwm_levels_hl_7-pwm_low,100 ,3
ENG146382-ENG146520-pwm_levels_hl_8-pwm_high_1,0 ,3
ENG146382-ENG146521-pwm_levels_hl_8-pwm_high_2,100 ,3
ENG146382-ENG146519-pwm_levels_hl_8-pwm_low,0 ,3
ENG146383-ENG146520-pwm_levels_hl_9-pwm_high_1,100 ,3
ENG146383-ENG146521-pwm_levels_hl_9-pwm_high_2,0 ,3
ENG146383-ENG146519-pwm_levels_hl_9-pwm_low,0 ,3
ENG146399-ENG146543-remote_functions-idle_time_bap_remote_beep,500 ,8
ENG146399-ENG146544-remote_functions-idle_time_state_S0,1 ,8
ENG146399-ENG146539-remote_functions-idle_time_state_S1,60 ,8
ENG146399-ENG146540-remote_functions-idle_time_state_S3,2000 ,8
ENG146399-ENG146537-remote_functions-Rear_lid_handle_release_button_activation_time,30 ,8
ENG146399-ENG146538-remote_functions-Rear_lid_handle_release_button_active,active ,8
ENG146399-ENG146541-remote_functions-remote_beep_activation_time_high,100 ,8
ENG146399-ENG146542-remote_functions-remote_beep_activation_time_low,900 ,8
ENG146403-ENG114991-RF_adjustment-channel_1,00 ,3
ENG146403-ENG114992-RF_adjustment-channel_2,00 ,3
ENG146403-ENG114993-RF_adjustment-channel_3,00 ,3
ENG146402-ENG114991-RF_calibration-channel_1,01 0A EB ,9
ENG146402-ENG114992-RF_calibration-channel_2,01 1D 8B ,9
ENG146402-ENG114993-RF_calibration-channel_3,01 30 2C ,9
ENG129054-ENG144985-SERVICE_KEY-debounce_kilometer,15 km,9
ENG129054-ENG144693-SERVICE_KEY-Distance,20 km,9
ENG129054-ENG144983-SERVICE_KEY-hazard_warning_switch_delay_time,10 s,9
ENG129054-ENG144980-SERVICE_KEY-retry_request_obdc,3 ,9
ENG129054-ENG144979-SERVICE_KEY-timeout_request_obdc,30 s,9
ENG129054-ENG146532-SERVICE_KEY-write_cycles_per_key_and_day,20 ,9
ENG129054-ENG144984-SERVICE_KEY-write_data_delay_time,40 s,9
ENG129054-ENG144982-SERVICE_KEY-write_delay_speed,20 km/h,9
ENG129054-ENG144981-SERVICE_KEY-write_delay_time,20 s,9
ENG146371-ENG146510-sounder_settings-beeptime,10_ms ,2
ENG146371-ENG146511-sounder_settings-beeptime_closing_central_locking,single_beep ,2
ENG146371-ENG146513-sounder_settings-beeptime_opening_central_locking,double_beep ,2
ENG146371-ENG247388-sounder_settings-beeptime_reunlock,60_ms ,2
ENG146371-ENG146512-sounder_settings-sounder_sound,frequency_modulated ,2
ENG146364-ENG146516-Terminal_Control-deactivation_time_kl15,30 min,3
ENG146364-ENG146517-Terminal_Control-delay_time_leave_concept,200 ms,3
ENG146398-wiping_indicator,00010111  ,1
ENG146401-Write_key_content,17 00 01 0A 28 14 0F 14 FF 05 00 0A 32 0A 0B A5 93 CC 10 10 10 10 02 1F 02 1F E0 AA 00 00 06 19 FF 05 3C 00 22 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 30 30 07 72 0A 41 43 34 31 07 72 0B 30 30 30 30 07 72 0C 30 30 30 30 07 72 0D 30 30 30 30 07 ,98
Elapsed Time: 00:51
adpmap-52-4M1-959-792-J_WAUZZZF29MN105510-20210719-1938.CSV
;SW:4M1-959-792-J   HW:4M1-959-792-D ---  Door Elect, Pass.
;Component:TSG BFS003 0430, Coding:001DCB005E000200A009B000
;EV_DCU2PasseSideMAXHKLO,001018,EV_DCU2PasseSideMAXHCONT_VW38.rod
;Monday,19,July,2021,19:38:21:35862
;VCDS Version: Release 21.3.0  Data version: 20210318 DS325.0
;VCID: 45DC3A44D5592743FC5-8010
Elapsed Time: 00:02
adpmap-5F-4M2-035-086-A_WAUZZZF29MN105510-20210719-1938.CSV
;SW:4M2-035-086-A   HW:4M2-035-086 ---  Information Electr.
;Component:MU-TP-N-RW    042 3385, Coding:15810010804000000000000000000000000000000000000000
;EV_MUTI,001010,EV_MUTI_AU27.rod
;Monday,19,July,2021,19:38:27:35862
;VCID: 2A0669F85C07E83BF17-807E
IDE00001-ENG248499-Production mode-air_condition_operation,not activated ,3
IDE00001-ENG154175-Production mode-Bluetooth,not activated ,3
IDE00001-ENG248636-Production mode-display_1_move,not activated ,3
IDE00001-ENG248637-Production mode-display_1_on_off,not activated ,3
IDE00001-ENG248638-Production mode-display_2_move,not activated ,3
IDE00001-ENG248639-Production mode-display_2_on_off,not activated ,3
IDE00001-ENG251560-Production mode-display_3_on_off,not activated ,3
IDE00001-ENG282031-Production mode-Display_4_on_off,not activated ,3
IDE00001-ENG252053-Production mode-early_audio,not activated ,3
IDE00001-ENG248670-Production mode-extendible_tweeters,not activated ,3
IDE00001-ENG175909-Production mode-FPK,not activated ,3
IDE00001-ENG248687-Production mode-fpk_display,not activated ,3
IDE00001-ENG248690-Production mode-frequency_modification,not activated ,3
IDE00001-ENG146079-Production mode-Operation,not activated ,3
IDE00001-ENG248771-Production mode-p_mode_id_13,not activated ,3
IDE00001-ENG248772-Production mode-p_mode_id_14,not activated ,3
IDE00001-ENG248485-Production mode-Parameter_21,not activated ,3
IDE00001-ENG248486-Production mode-Parameter_22,not activated ,3
IDE00001-ENG248487-Production mode-Parameter_23,not activated ,3
IDE00001-ENG248791-Production mode-paramter_24,not activated ,3
IDE00001-ENG248796-Production mode-radio_link_esim,not activated ,3
IDE00001-ENG248480-Production mode-SDS,not activated ,3
IDE00001-ENG168106-Production mode-volume_control,not activated ,3
IDE00001-ENG248489-Production mode-Wifi,not activated ,3
IDE00346-Summertime-automatic,automatic ,1
IDE00768-Country identification: country of sale,TR ,2
IDE00820-MAS03180-Activating and deactivating all development messages-Local data bus,OFF ,1
IDE00820-MAS05583-Activating and deactivating all development messages-Data bus,OFF ,1
IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control module,Yes ,3
IDE01996-MAS00839-Installation list: specified installations-TV Tuner,No ,3
IDE01996-MAS00844-Installation list: specified installations-Radio,No ,3
IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module,No ,3
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1,Yes ,3
IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2,No ,3
IDE01996-MAS04300-Installation list: specified installations-DVD changer,No ,3
IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control module,No ,3
IDE01996-SFT00078-Installation list: specified installations-Display/operating unit rear right,No ,3
IDE01996-SFT00094-Installation list: specified installations-Display/operating unit rear left,No ,3
IDE01996-SFT00200-Installation list: specified installations-Auxiliary display/control head 2,No ,3
IDE01996-SFT00222-Installation list: specified installations-charging device 1 for mobile end device,Yes ,3
IDE01996-SFT00223-Installation list: specified installations-charging device 2 for mobile end device,No ,3
IDE01996-SFT00224-Installation list: specified installations-Auxiliary display/control head 1,No ,3
IDE01996-SFT271943-Installation list: specified installations-Multimedia system control head,No ,3
IDE01996-ENG262683-Installation list: specified installations-Reserved_Bit_0,No ,3
IDE01996-ENG171864-Installation list: specified installations-reserved_Bit_1,No ,3
IDE01996-ENG262679-Installation list: specified installations-reserved_Bit_2,No ,3
IDE01996-ENG262684-Installation list: specified installations-Reserved_Bit_3,No ,3
IDE01996-ENG262685-Installation list: specified installations-Reserved_Bit_4,No ,3
IDE01996-ENG262686-Installation list: specified installations-Reserved_Bit_5,No ,3
IDE01996-ENG262687-Installation list: specified installations-Reserved_Bit_6,No ,3
IDE01996-ENG262688-Installation list: specified installations-Reserved_Bit_7,No ,3
IDE02125-MAS08233-Voice operation for telephone-other,not installed ,1
IDE02125-MAS18502-Voice operation for telephone-Apple device,not installed ,1
IDE02476-MAS03001-Electrical test of speakers-Mode,automatic ,126
IDE02476-ENG248529-Electrical test of speakers-channel_1_lower_threshold,1 ,126
IDE02476-ENG248531-Electrical test of speakers-channel_1_upper_threshold,8 ,126
IDE02476-ENG248533-Electrical test of speakers-channel_10_lower_threshold,18 ,126
IDE02476-ENG248535-Electrical test of speakers-channel_10_upper_threshold,22 ,126
IDE02476-ENG248537-Electrical test of speakers-channel_11_lower_threshold,18 ,126
IDE02476-ENG248539-Electrical test of speakers-channel_11_upper_threshold,22 ,126
IDE02476-ENG248541-Electrical test of speakers-channel_12_lower_threshold,18 ,126
IDE02476-ENG248543-Electrical test of speakers-channel_12_upper_threshold,22 ,126
IDE02476-ENG248545-Electrical test of speakers-channel_13_lower_threshold,18 ,126
IDE02476-ENG248547-Electrical test of speakers-channel_13_upper_threshold,22 ,126
IDE02476-ENG248549-Electrical test of speakers-channel_14_lower_threshold,18 ,126
IDE02476-ENG248551-Electrical test of speakers-channel_14_upper_threshold,22 ,126
IDE02476-ENG248553-Electrical test of speakers-channel_15_lower_threshold,18 ,126
IDE02476-ENG248555-Electrical test of speakers-channel_15_upper_threshold,22 ,126
IDE02476-ENG248557-Electrical test of speakers-channel_16_lower_threshold,18 ,126
IDE02476-ENG248559-Electrical test of speakers-channel_16_upper_threshold,22 ,126
IDE02476-ENG248561-Electrical test of speakers-channel_17_lower_threshold,18 ,126
IDE02476-ENG248563-Electrical test of speakers-channel_17_upper_threshold,22 ,126
IDE02476-ENG248565-Electrical test of speakers-channel_18_lower_threshold,18 ,126
IDE02476-ENG248567-Electrical test of speakers-channel_18_upper_threshold,22 ,126
IDE02476-ENG248569-Electrical test of speakers-channel_19_lower_threshold,18 ,126
IDE02476-ENG248570-Electrical test of speakers-channel_19_upper_threshold,22 ,126
IDE02476-ENG248573-Electrical test of speakers-channel_2_lower_threshold,1 ,126
IDE02476-ENG248575-Electrical test of speakers-channel_2_upper_threshold,10 ,126
IDE02476-ENG248577-Electrical test of speakers-channel_20_lower_threshold,18 ,126
IDE02476-ENG248579-Electrical test of speakers-channel_20_upper_threshold,22 ,126
IDE02476-ENG248581-Electrical test of speakers-channel_21_lower_threshold,18 ,126
IDE02476-ENG248583-Electrical test of speakers-channel_21_upper_threshold,22 ,126
IDE02476-ENG248585-Electrical test of speakers-channel_22_lower_threshold,18 ,126
IDE02476-ENG248587-Electrical test of speakers-channel_22_upper_threshold,22 ,126
IDE02476-ENG248589-Electrical test of speakers-channel_23_lower_threshold,18 ,126
IDE02476-ENG248591-Electrical test of speakers-channel_23_upper_threshold,22 ,126
IDE02476-ENG248593-Electrical test of speakers-channel_24_lower_threshold,18 ,126
IDE02476-ENG248595-Electrical test of speakers-channel_24_upper_threshold,22 ,126
IDE02476-ENG260193-Electrical test of speakers-channel_25_lower_threshold,18 ,126
IDE02476-ENG259500-Electrical test of speakers-channel_25_upper_threshold,22 ,126
IDE02476-ENG248599-Electrical test of speakers-channel_3_lower_threshold,1 ,126
IDE02476-ENG248601-Electrical test of speakers-channel_3_upper_threshold,10 ,126
IDE02476-ENG248603-Electrical test of speakers-channel_4_lower_threshold,1 ,126
IDE02476-ENG248605-Electrical test of speakers-channel_4_upper_threshold,8 ,126
IDE02476-ENG248607-Electrical test of speakers-channel_5_lower_threshold,18 ,126
IDE02476-ENG248609-Electrical test of speakers-channel_5_upper_threshold,22 ,126
IDE02476-ENG248611-Electrical test of speakers-channel_6_lower_threshold,18 ,126
IDE02476-ENG248613-Electrical test of speakers-channel_6_upper_threshold,22 ,126
IDE02476-ENG248615-Electrical test of speakers-channel_7_lower_threshold,18 ,126
IDE02476-ENG248617-Electrical test of speakers-channel_7_upper_threshold,22 ,126
IDE02476-ENG248619-Electrical test of speakers-channel_8_lower_threshold,18 ,126
IDE02476-ENG248621-Electrical test of speakers-channel_8_upper_threshold,22 ,126
IDE02476-ENG248623-Electrical test of speakers-channel_9_lower_threshold,18 ,126
IDE02476-ENG248625-Electrical test of speakers-channel_9_upper_threshold,22 ,126
IDE02476-ENG117360-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,126
IDE02476-ENG117361-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,27 ,126
IDE02476-ENG117378-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,126
IDE02476-ENG117379-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,27 ,126
IDE02476-ENG117380-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,126
IDE02476-ENG117381-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,27 ,126
IDE02476-ENG117382-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,126
IDE02476-ENG117383-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,27 ,126
IDE02476-ENG117384-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,126
IDE02476-ENG117385-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,27 ,126
IDE02476-ENG117386-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,126
IDE02476-ENG117387-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,27 ,126
IDE02476-ENG117388-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,126
IDE02476-ENG117389-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,27 ,126
IDE02476-ENG117390-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,126
IDE02476-ENG117391-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,27 ,126
IDE02476-ENG126164-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_17_Test_Frequency,19000 Hz,126
IDE02476-ENG126165-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_17_Test_Volume,27 ,126
IDE02476-ENG126166-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_18_Test_Frequency,19000 Hz,126
IDE02476-ENG126167-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_18_Test_Volume,27 ,126
IDE02476-ENG126168-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_19_Test_Frequency,19000 Hz,126
IDE02476-ENG126169-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_19_Test_Volume,27 ,126
IDE02476-ENG117362-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,126
IDE02476-ENG117363-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,27 ,126
IDE02476-ENG126170-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_20_Test_Frequency,19000 Hz,126
IDE02476-ENG126171-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_20_Test_Volume,27 ,126
IDE02476-ENG126172-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_21_Test_Frequency,19000 Hz,126
IDE02476-ENG126173-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_21_Test_Volume,27 ,126
IDE02476-ENG126174-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_22_Test_Frequency,19000 Hz,126
IDE02476-ENG126175-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_22_Test_Volume,27 ,126
IDE02476-ENG126176-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_23_Test_Frequency,19000 Hz,126
IDE02476-ENG126177-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_23_Test_Volume,27 ,126
IDE02476-ENG126178-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_24_Test_Frequency,19000 Hz,126
IDE02476-ENG126179-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_24_Test_Volume,27 ,126
IDE02476-ENG260707-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_25_Test_Frequency,19000 Hz,126
IDE02476-ENG259929-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_25_Test_Volume,27 ,126
IDE02476-ENG117364-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,126
IDE02476-ENG117365-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,27 ,126
IDE02476-ENG117366-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,126
IDE02476-ENG117367-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,27 ,126
IDE02476-ENG117368-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,126
IDE02476-ENG117369-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,27 ,126
IDE02476-ENG117370-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,126
IDE02476-ENG117371-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,27 ,126
IDE02476-ENG117372-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,126
IDE02476-ENG117373-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,27 ,126
IDE02476-ENG117374-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,126
IDE02476-ENG117375-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,27 ,126
IDE02476-ENG117376-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,126
IDE02476-ENG117377-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,27 ,126
IDE02502-Confirmation of installation change,F2 91 ,2
IDE04298-MAS01779-Vehicle dimensions-Length,0 mm,6
IDE04298-MAS01780-Vehicle dimensions-Width,0 mm,6
IDE04298-MAS02230-Vehicle dimensions-Height,0 mm,6
IDE04300-ENG252089-Vehicle menu operation-menu_ambient_illumination_2,not activated ,256
IDE04300-ENG252074-Vehicle menu operation-menu_ambient_illumination_2_after_disclaimer,not activated ,256
IDE04300-ENG252062-Vehicle menu operation-menu_ambient_illumination_2_clamp_15_off,not activated ,256
IDE04300-ENG252061-Vehicle menu operation-menu_ambient_illumination_2_over_threshold_high,not activated ,256
IDE04300-ENG252091-Vehicle menu operation-menu_ambient_illumination_2_stillstand,not activated ,256
IDE04300-ENG125811-Vehicle menu operation-menu_auxiliary_climatization,not activated ,256
IDE04300-ENG125814-Vehicle menu operation-menu_auxiliary_climatization_after_disclaimer,not activated ,256
IDE04300-ENG126995-Vehicle menu operation-menu_auxiliary_climatization_clamp_15_off,not activated ,256
IDE04300-ENG125812-Vehicle menu operation-menu_auxiliary_climatization_over_threshold_high,not activated ,256
IDE04300-ENG125813-Vehicle menu operation-menu_auxiliary_climatization_standstill,not activated ,256
IDE04300-ENG152538-Vehicle menu operation-menu_auxiliary_ventilation,not activated ,256
IDE04300-ENG152539-Vehicle menu operation-menu_auxiliary_ventilation_after_disclaimer,not activated ,256
IDE04300-ENG152540-Vehicle menu operation-menu_auxiliary_ventilation_clamp_15_off,not activated ,256
IDE04300-ENG152541-Vehicle menu operation-menu_auxiliary_ventilation_over_threshold_high,not activated ,256
IDE04300-ENG152542-Vehicle menu operation-menu_auxiliary_ventilation_standstill,not activated ,256
IDE04300-ENG248728-Vehicle menu operation-menu_Car2X,not activated ,256
IDE04300-ENG248729-Vehicle menu operation-menu_Car2X_after_disclaimer,not activated ,256
IDE04300-ENG248730-Vehicle menu operation-menu_Car2X_clamp_15_off,not activated ,256
IDE04300-ENG248731-Vehicle menu operation-menu_Car2X_over_threshold_high,not activated ,256
IDE04300-ENG248732-Vehicle menu operation-menu_Car2X_stillstand,not activated ,256
IDE04300-ENG249906-Vehicle menu operation-menu_chassis_control,not activated ,256
IDE04300-ENG249907-Vehicle menu operation-menu_chassis_control_after_disclaimer,not activated ,256
IDE04300-ENG249908-Vehicle menu operation-menu_chassis_control_clamp_15_off,not activated ,256
IDE04300-ENG249909-Vehicle menu operation-menu_chassis_control_over_threshold_high,not activated ,256
IDE04300-ENG282005-Vehicle menu operation-menu_chassis_control_standstill,not activated ,256
IDE04300-ENG152495-Vehicle menu operation-menu_connection_manager,not activated ,256
IDE04300-ENG152499-Vehicle menu operation-menu_connection_manager_after_disclaimer,not activated ,256
IDE04300-ENG152496-Vehicle menu operation-menu_connection_manager_clamp_15_off,not activated ,256
IDE04300-ENG152497-Vehicle menu operation-menu_connection_manager_over_threshold_high,not activated ,256
IDE04300-ENG152498-Vehicle menu operation-menu_connection_manager_standstill,not activated ,256
IDE04300-ENG152543-Vehicle menu operation-menu_crossroad_assistent,not activated ,256
IDE04300-ENG152544-Vehicle menu operation-menu_crossroad_assistent_after_disclaimer,not activated ,256
IDE04300-ENG152545-Vehicle menu operation-menu_crossroad_assistent_clamp_15_off,not activated ,256
IDE04300-ENG152546-Vehicle menu operation-menu_crossroad_assistent_over_threshold_high,not activated ,256
IDE04300-ENG152547-Vehicle menu operation-menu_crossroad_assistent_standstill,not activated ,256
IDE04300-ENG152548-Vehicle menu operation-menu_daf_profile,not activated ,256
IDE04300-ENG152549-Vehicle menu operation-menu_daf_profile_after_disclaimer,not activated ,256
IDE04300-ENG152550-Vehicle menu operation-menu_daf_profile_clamp_15_off,not activated ,256
IDE04300-ENG152551-Vehicle menu operation-menu_daf_profile_over_threshold_high,not activated ,256
IDE04300-ENG152552-Vehicle menu operation-menu_daf_profile_stillstand,not activated ,256
IDE04300-ENG251562-Vehicle menu operation-menu_DCC_monitor,not activated ,256
IDE04300-ENG251561-Vehicle menu operation-menu_DCC_monitor_after_disclaimer,not activated ,256
IDE04300-ENG251559-Vehicle menu operation-menu_DCC_monitor_clamp_15_off,not activated ,256
IDE04300-ENG251557-Vehicle menu operation-menu_DCC_monitor_over_threshold_high,not activated ,256
IDE04300-ENG251558-Vehicle menu operation-menu_DCC_monitor_stillstand,not activated ,256
IDE04300-ENG117486-Vehicle menu operation-menu_display_ACC,not activated ,256
IDE04300-ENG117490-Vehicle menu operation-menu_display_ACC_after_disclaimer,not activated ,256
IDE04300-ENG117487-Vehicle menu operation-menu_display_ACC_operation_clamp_15_off,not activated ,256
IDE04300-ENG117488-Vehicle menu operation-menu_display_ACC_over_threshold_high,not activated ,256
IDE04300-ENG117489-Vehicle menu operation-menu_display_ACC_standstill,not activated ,256
IDE04300-ENG117646-Vehicle menu operation-menu_display_adaptive_key,activated ,256
IDE04300-ENG117650-Vehicle menu operation-menu_display_adaptive_key_after_disclaimer,not activated ,256
IDE04300-ENG117647-Vehicle menu operation-menu_display_adaptive_key_clamp_15_off,not activated ,256
IDE04300-ENG117648-Vehicle menu operation-menu_display_adaptive_key_over_threshold_high,activated ,256
IDE04300-ENG117649-Vehicle menu operation-menu_display_adaptive_key_standstill,not activated ,256
IDE04300-ENG126152-Vehicle menu operation-menu_display_Adblue,not activated ,256
IDE04300-ENG126155-Vehicle menu operation-menu_display_Adblue_after_disclaimer,not activated ,256
IDE04300-ENG127002-Vehicle menu operation-menu_display_Adblue_clamp_15_off,not activated ,256
IDE04300-ENG126153-Vehicle menu operation-menu_display_Adblue_over_threshold_high,not activated ,256
IDE04300-ENG126154-Vehicle menu operation-menu_display_Adblue_standstill,not activated ,256
IDE04300-ENG117591-Vehicle menu operation-menu_display_air_damper,not activated ,256
IDE04300-ENG117595-Vehicle menu operation-menu_display_air_damper_after_disclaimer,not activated ,256
IDE04300-ENG117592-Vehicle menu operation-menu_display_air_damper_clamp_15_off,not activated ,256
IDE04300-ENG117593-Vehicle menu operation-menu_display_air_damper_over_threshold_high,not activated ,256
IDE04300-ENG117594-Vehicle menu operation-menu_display_air_damper_standstill,not activated ,256
IDE04300-ENG117491-Vehicle menu operation-menu_display_ambient_illumination,activated ,256
IDE04300-ENG117495-Vehicle menu operation-menu_display_ambient_illumination_after_disclaimer,not activated ,256
IDE04300-ENG117492-Vehicle menu operation-menu_display_ambient_illumination_clamp_15_off,not activated ,256
IDE04300-ENG117493-Vehicle menu operation-menu_display_ambient_illumination_over_threshold_high,activated ,256
IDE04300-ENG117494-Vehicle menu operation-menu_display_ambient_illumination_standstill,not activated ,256
IDE04300-ENG122296-Vehicle menu operation-menu_display_angle_of_slope,not activated ,256
IDE04300-ENG122300-Vehicle menu operation-menu_display_angle_of_slope_after_disclaimer,not activated ,256
IDE04300-ENG122297-Vehicle menu operation-menu_display_angle_of_slope_clamp_15_off,not activated ,256
IDE04300-ENG122298-Vehicle menu operation-menu_display_angle_of_slope_over_threshold_high,not activated ,256
IDE04300-ENG122299-Vehicle menu operation-menu_display_angle_of_slope_standstill,not activated ,256
IDE04300-ENG117641-Vehicle menu operation-menu_display_attention_identification,not activated ,256
IDE04300-ENG117645-Vehicle menu operation-menu_display_attention_identification_after_disclaimer,not activated ,256
IDE04300-ENG117642-Vehicle menu operation-menu_display_attention_identification_clamp_15_off,not activated ,256
IDE04300-ENG117643-Vehicle menu operation-menu_display_attention_identification_over_threshold_high,not activated ,256
IDE04300-ENG117644-Vehicle menu operation-menu_display_attention_identification_standstill,not activated ,256
IDE04300-ENG117531-Vehicle menu operation-menu_display_auxiliary_heating,not activated ,256
IDE04300-ENG117535-Vehicle menu operation-menu_display_auxiliary_heating_after_disclaimer,not activated ,256
IDE04300-ENG117532-Vehicle menu operation-menu_display_auxiliary_heating_clamp_15_off,not activated ,256
IDE04300-ENG117533-Vehicle menu operation-menu_display_auxiliary_heating_over_threshold_high,not activated ,256
IDE04300-ENG117534-Vehicle menu operation-menu_display_auxiliary_heating_standstill,not activated ,256
IDE04300-ENG117501-Vehicle menu operation-menu_display_awv,not activated ,256
IDE04300-ENG117505-Vehicle menu operation-menu_display_awv_after_disclaimer,not activated ,256
IDE04300-ENG117502-Vehicle menu operation-menu_display_awv_clamp_15_off,not activated ,256
IDE04300-ENG117503-Vehicle menu operation-menu_display_awv_over_threshold_high,not activated ,256
IDE04300-ENG117504-Vehicle menu operation-menu_display_awv_standstill,not activated ,256
IDE04300-ENG122301-Vehicle menu operation-menu_display_battery_management,not activated ,256
IDE04300-ENG122305-Vehicle menu operation-menu_display_battery_management_after_disclaimer,not activated ,256
IDE04300-ENG122302-Vehicle menu operation-menu_display_battery_management_clamp_15_off,not activated ,256
IDE04300-ENG122303-Vehicle menu operation-menu_display_battery_management_over_threshold_high,not activated ,256
IDE04300-ENG122304-Vehicle menu operation-menu_display_battery_management_standstill,not activated ,256
IDE04300-ENG117666-Vehicle menu operation-menu_display_BCmE,not activated ,256
IDE04300-ENG117670-Vehicle menu operation-menu_display_BCmE_after_disclaimer,not activated ,256
IDE04300-ENG117667-Vehicle menu operation-menu_display_BCmE_clamp_15_off,not activated ,256
IDE04300-ENG117668-Vehicle menu operation-menu_display_BCmE_over_threshold_high,not activated ,256
IDE04300-ENG117669-Vehicle menu operation-menu_display_BCmE_standstill,not activated ,256
IDE04300-ENG117536-Vehicle menu operation-menu_display_board_computer,activated ,256
IDE04300-ENG117540-Vehicle menu operation-menu_display_board_computer_after_disclaimer,not activated ,256
IDE04300-ENG117537-Vehicle menu operation-menu_display_board_computer_clamp_15_off,not activated ,256
IDE04300-ENG117538-Vehicle menu operation-menu_display_board_computer_over_threshold_high,activated ,256
IDE04300-ENG117539-Vehicle menu operation-menu_display_board_computer_standstill,not activated ,256
IDE04300-ENG117671-Vehicle menu operation-menu_display_Brake_Function,not activated ,256
IDE04300-ENG117675-Vehicle menu operation-menu_display_Brake_Function_after_disclaimer,not activated ,256
IDE04300-ENG117672-Vehicle menu operation-menu_display_Brake_Function_clamp_15_off,not activated ,256
IDE04300-ENG117673-Vehicle menu operation-menu_display_Brake_Function_over_threshold_high,not activated ,256
IDE04300-ENG117674-Vehicle menu operation-menu_display_Brake_Function_standstill,not activated ,256
IDE04300-ENG117651-Vehicle menu operation-menu_display_car_mirror,not activated ,256
IDE04300-ENG117655-Vehicle menu operation-menu_display_car_mirror_after_disclaimer,not activated ,256
IDE04300-ENG117652-Vehicle menu operation-menu_display_car_mirror_clamp_15_off,not activated ,256
IDE04300-ENG117653-Vehicle menu operation-menu_display_car_mirror_over_threshold_high,not activated ,256
IDE04300-ENG117654-Vehicle menu operation-menu_display_car_mirror_standstill,not activated ,256
IDE04300-ENG117561-Vehicle menu operation-menu_display_central_locking,activated ,256
IDE04300-ENG117565-Vehicle menu operation-menu_display_central_locking_after_disclaimer,not activated ,256
IDE04300-ENG117562-Vehicle menu operation-menu_display_central_locking_clamp_15_off,activated ,256
IDE04300-ENG117563-Vehicle menu operation-menu_display_central_locking_over_threshold_high,activated ,256
IDE04300-ENG117564-Vehicle menu operation-menu_display_central_locking_standstill,not activated ,256
IDE04300-ENG117601-Vehicle menu operation-menu_display_central_unit_master,activated ,256
IDE04300-ENG117605-Vehicle menu operation-menu_display_central_unit_master_after_disclaimer,not activated ,256
IDE04300-ENG117602-Vehicle menu operation-menu_display_central_unit_master_clamp_15_off,not activated ,256
IDE04300-ENG117603-Vehicle menu operation-menu_display_central_unit_master_over_threshold_high,activated ,256
IDE04300-ENG117604-Vehicle menu operation-menu_display_central_unit_master_standstill,not activated ,256
IDE04300-ENG117571-Vehicle menu operation-menu_display_charisma,activated ,256
IDE04300-ENG117575-Vehicle menu operation-menu_display_charisma_after_disclaimer,not activated ,256
IDE04300-ENG117572-Vehicle menu operation-menu_display_charisma_clamp_15_off,not activated ,256
IDE04300-ENG117573-Vehicle menu operation-menu_display_charisma_over_threshold_high,activated ,256
IDE04300-ENG117574-Vehicle menu operation-menu_display_charisma_standstill,not activated ,256
IDE04300-ENG117526-Vehicle menu operation-menu_display_clima_configuration,activated ,256
IDE04300-ENG117530-Vehicle menu operation-menu_display_clima_configuration_after_disclaimer,not activated ,256
IDE04300-ENG117527-Vehicle menu operation-menu_display_clima_configuration_clamp_15_off,activated ,256
IDE04300-ENG117528-Vehicle menu operation-menu_display_clima_configuration_over_threshold_high,activated ,256
IDE04300-ENG117529-Vehicle menu operation-menu_display_clima_configuration_standstill,not activated ,256
IDE04300-ENG117586-Vehicle menu operation-menu_display_clock,activated ,256
IDE04300-ENG117590-Vehicle menu operation-menu_display_clock_after_disclaimer,not activated ,256
IDE04300-ENG117587-Vehicle menu operation-menu_display_clock_clamp_15_off,not activated ,256
IDE04300-ENG117588-Vehicle menu operation-menu_display_clock_over_threshold_high,activated ,256
IDE04300-ENG117589-Vehicle menu operation-menu_display_clock_standstill,not activated ,256
IDE04300-ENG117566-Vehicle menu operation-menu_display_compass,not activated ,256
IDE04300-ENG117570-Vehicle menu operation-menu_display_compass_after_disclaimer,not activated ,256
IDE04300-ENG117567-Vehicle menu operation-menu_display_compass_clamp_15_off,not activated ,256
IDE04300-ENG117568-Vehicle menu operation-menu_display_compass_over_threshold_high,not activated ,256
IDE04300-ENG117569-Vehicle menu operation-menu_display_compass_standstill,not activated ,256
IDE04300-ENG125823-Vehicle menu operation-menu_display_Curve_Assist,not activated ,256
IDE04300-ENG125826-Vehicle menu operation-menu_display_Curve_Assist_after_disclaimer,not activated ,256
IDE04300-ENG126998-Vehicle menu operation-menu_display_Curve_Assist_clamp_15_off,not activated ,256
IDE04300-ENG125824-Vehicle menu operation-menu_display_Curve_Assist_over_threshold_high,not activated ,256
IDE04300-ENG125825-Vehicle menu operation-menu_display_Curve_Assist_standstill,not activated ,256
IDE04300-ENG142087-Vehicle menu operation-menu_display_Display_Configuration,activated ,256
IDE04300-ENG142091-Vehicle menu operation-menu_display_Display_Configuration_after_disclaimer,not activated ,256
IDE04300-ENG142088-Vehicle menu operation-menu_display_Display_Configuration_clamp_15_off,not activated ,256
IDE04300-ENG142089-Vehicle menu operation-menu_display_Display_Configuration_over_threshold_high,activated ,256
IDE04300-ENG142090-Vehicle menu operation-menu_display_Display_Configuration_standstill,not activated ,256
IDE04300-ENG117656-Vehicle menu operation-menu_display_driving_school,not activated ,256
IDE04300-ENG117660-Vehicle menu operation-menu_display_driving_school_after_disclaimer,not activated ,256
IDE04300-ENG117657-Vehicle menu operation-menu_display_driving_school_clamp_15_off,not activated ,256
IDE04300-ENG117658-Vehicle menu operation-menu_display_driving_school_over_threshold_high,not activated ,256
IDE04300-ENG117659-Vehicle menu operation-menu_display_driving_school_standstill,not activated ,256
IDE04300-ENG125034-Vehicle menu operation-menu_display_Ecall,not activated ,256
IDE04300-ENG125038-Vehicle menu operation-menu_display_Ecall_after_disclaimer,not activated ,256
IDE04300-ENG126999-Vehicle menu operation-menu_display_eCall_clamp_15_off,not activated ,256
IDE04300-ENG125036-Vehicle menu operation-menu_display_Ecall_over_threshold_high,not activated ,256
IDE04300-ENG125037-Vehicle menu operation-menu_display_Ecall_standstill,not activated ,256
IDE04300-ENG126160-Vehicle menu operation-menu_display_Efficiency_Assist,activated ,256
IDE04300-ENG126163-Vehicle menu operation-menu_display_Efficiency_Assist_after_disclaimer,not activated ,256
IDE04300-ENG127004-Vehicle menu operation-menu_display_Efficiency_Assist_clamp_15_off,not activated ,256
IDE04300-ENG126161-Vehicle menu operation-menu_display_Efficiency_Assist_over_threshold_high,activated ,256
IDE04300-ENG126162-Vehicle menu operation-menu_display_Efficiency_Assist_standstill,not activated ,256
IDE04300-ENG126144-Vehicle menu operation-menu_display_ENI,not activated ,256
IDE04300-ENG126147-Vehicle menu operation-menu_display_ENI_after_disclaimer,not activated ,256
IDE04300-ENG127000-Vehicle menu operation-menu_display_ENI_clamp_15_off,not activated ,256
IDE04300-ENG126145-Vehicle menu operation-menu_display_ENI_over_threshold_high,not activated ,256
IDE04300-ENG126146-Vehicle menu operation-menu_display_ENI_standstill,not activated ,256
IDE04300-ENG117516-Vehicle menu operation-menu_display_exterior_illumination,activated ,256
IDE04300-ENG117520-Vehicle menu operation-menu_display_exterior_illumination_after_disclaimer,not activated ,256
IDE04300-ENG117517-Vehicle menu operation-menu_display_exterior_illumination_clamp_15_off,not activated ,256
IDE04300-ENG117518-Vehicle menu operation-menu_display_exterior_illumination_over_threshold_high,activated ,256
IDE04300-ENG117519-Vehicle menu operation-menu_display_exterior_illumination_standstill,not activated ,256
IDE04300-ENG117596-Vehicle menu operation-menu_display_headup_display,not activated ,256
IDE04300-ENG117600-Vehicle menu operation-menu_display_headup_display_after_disclaimer,not activated ,256
IDE04300-ENG117597-Vehicle menu operation-menu_display_headup_display_clamp_15_off,not activated ,256
IDE04300-ENG117598-Vehicle menu operation-menu_display_headup_display_over_threshold_high,not activated ,256
IDE04300-ENG117599-Vehicle menu operation-menu_display_headup_display_standstill,not activated ,256
IDE04300-ENG117606-Vehicle menu operation-menu_display_hybrid,not activated ,256
IDE04300-ENG117610-Vehicle menu operation-menu_display_hybrid_after_disclaimer,not activated ,256
IDE04300-ENG117607-Vehicle menu operation-menu_display_hybrid_clamp_15_off,not activated ,256
IDE04300-ENG117608-Vehicle menu operation-menu_display_hybrid_over_threshold_high,not activated ,256
IDE04300-ENG117609-Vehicle menu operation-menu_display_hybrid_standstill,not activated ,256
IDE04300-ENG125805-Vehicle menu operation-menu_display_lane_assistant,not activated ,256
IDE04300-ENG125809-Vehicle menu operation-menu_display_lane_assistant_after_disclaimer,not activated ,256
IDE04300-ENG125806-Vehicle menu operation-menu_display_lane_assistant_clamp_15_off,not activated ,256
IDE04300-ENG125807-Vehicle menu operation-menu_display_lane_assistant_over_threshold_high,not activated ,256
IDE04300-ENG125808-Vehicle menu operation-menu_display_lane_assistant_standstill,not activated ,256
IDE04300-ENG117506-Vehicle menu operation-menu_display_Lane_Departure_Warning,activated ,256
IDE04300-ENG117510-Vehicle menu operation-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,256
IDE04300-ENG117507-Vehicle menu operation-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,256
IDE04300-ENG117508-Vehicle menu operation-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,256
IDE04300-ENG117509-Vehicle menu operation-menu_display_Lane_Departure_Warning_standstill,not activated ,256
IDE04300-ENG117631-Vehicle menu operation-menu_display_MFL_jocker,activated ,256
IDE04300-ENG117635-Vehicle menu operation-menu_display_MFL_jocker_after_disclaimer,not activated ,256
IDE04300-ENG117632-Vehicle menu operation-menu_display_MFL_jocker_clamp_15_off,not activated ,256
IDE04300-ENG117633-Vehicle menu operation-menu_display_MFL_jocker_over_threshold_high,activated ,256
IDE04300-ENG117634-Vehicle menu operation-menu_display_MFL_jocker_standstill,not activated ,256
IDE04300-ENG117616-Vehicle menu operation-menu_display_night_vision,not activated ,256
IDE04300-ENG117620-Vehicle menu operation-menu_display_night_vision_after_disclaimer,not activated ,256
IDE04300-ENG117617-Vehicle menu operation-menu_display_night_vision_clamp_15_off,not activated ,256
IDE04300-ENG117618-Vehicle menu operation-menu_display_night_vision_over_threshold_high,not activated ,256
IDE04300-ENG117619-Vehicle menu operation-menu_display_night_vision_standstill,not activated ,256
IDE04300-ENG117576-Vehicle menu operation-menu_display_oil_level,activated ,256
IDE04300-ENG117580-Vehicle menu operation-menu_display_oil_level_after_disclaimer,not activated ,256
IDE04300-ENG117577-Vehicle menu operation-menu_display_oil_level_clamp_15_off,not activated ,256
IDE04300-ENG117578-Vehicle menu operation-menu_display_oil_level_over_threshold_high,activated ,256
IDE04300-ENG117579-Vehicle menu operation-menu_display_oil_level_standstill,not activated ,256
IDE04300-ENG117496-Vehicle menu operation-menu_display_pdc,activated ,256
IDE04300-ENG117500-Vehicle menu operation-menu_display_pdc_after_disclaimer,not activated ,256
IDE04300-ENG117497-Vehicle menu operation-menu_display_pdc_clamp_15_off,not activated ,256
IDE04300-ENG117498-Vehicle menu operation-menu_display_pdc_over_threshold_high,activated ,256
IDE04300-ENG117499-Vehicle menu operation-menu_display_pdc_standstill,not activated ,256
IDE04300-ENG125815-Vehicle menu operation-menu_display_Pedestrian_Assist,not activated ,256
IDE04300-ENG125818-Vehicle menu operation-menu_display_Pedestrian_Assist_after_disclaimer,not activated ,256
IDE04300-ENG126996-Vehicle menu operation-menu_display_Pedestrian_Assist_clamp_15_off,not activated ,256
IDE04300-ENG125816-Vehicle menu operation-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,256
IDE04300-ENG125817-Vehicle menu operation-menu_display_Pedestrian_Assist_standstill,not activated ,256
IDE04300-ENG117541-Vehicle menu operation-menu_display_rdk,activated ,256
IDE04300-ENG117545-Vehicle menu operation-menu_display_rdk_after_disclaimer,not activated ,256
IDE04300-ENG117542-Vehicle menu operation-menu_display_rdk_clamp_15_off,not activated ,256
IDE04300-ENG117543-Vehicle menu operation-menu_display_rdk_over_threshold_high,activated ,256
IDE04300-ENG117544-Vehicle menu operation-menu_display_rdk_standstill,not activated ,256
IDE04300-ENG122306-Vehicle menu operation-menu_display_RearSeatEntertainment,not activated ,256
IDE04300-ENG122310-Vehicle menu operation-menu_display_RearSeatEntertainment_after_disclaimer,not activated ,256
IDE04300-ENG122307-Vehicle menu operation-menu_display_RearSeatEntertainment_clamp_15_off,not activated ,256
IDE04300-ENG122308-Vehicle menu operation-menu_display_RearSeatEntertainment_over_threshold_high,not activated ,256
IDE04300-ENG122309-Vehicle menu operation-menu_display_RearSeatEntertainment_standstill,not activated ,256
IDE04300-ENG117626-Vehicle menu operation-menu_display_reversible_belt_pre_load,activated ,256
IDE04300-ENG117630-Vehicle menu operation-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,256
IDE04300-ENG117627-Vehicle menu operation-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,256
IDE04300-ENG117628-Vehicle menu operation-menu_display_reversible_belt_pre_load_over_threshold_high,activated ,256
IDE04300-ENG117629-Vehicle menu operation-menu_display_reversible_belt_pre_load_standstill,not activated ,256
IDE04300-ENG117636-Vehicle menu operation-menu_display_road_sign_identification,not activated ,256
IDE04300-ENG117640-Vehicle menu operation-menu_display_road_sign_identification_after_disclaimer,not activated ,256
IDE04300-ENG117637-Vehicle menu operation-menu_display_road_sign_identification_clamp_15_off,not activated ,256
IDE04300-ENG117638-Vehicle menu operation-menu_display_road_sign_identification_over_threshold_high,not activated ,256
IDE04300-ENG117639-Vehicle menu operation-menu_display_road_sign_identification_standstill,not activated ,256
IDE04300-ENG117556-Vehicle menu operation-menu_display_seat_configuration,activated ,256
IDE04300-ENG117560-Vehicle menu operation-menu_display_seat_configuration_after_disclaimer,not activated ,256
IDE04300-ENG117557-Vehicle menu operation-menu_display_seat_configuration_clamp_15_off,activated ,256
IDE04300-ENG117558-Vehicle menu operation-menu_display_seat_configuration_over_threshold_high,activated ,256
IDE04300-ENG117559-Vehicle menu operation-menu_display_seat_configuration_standstill,not activated ,256
IDE04300-ENG125819-Vehicle menu operation-menu_display_Seat_Pneumatic,not activated ,256
IDE04300-ENG125822-Vehicle menu operation-menu_display_Seat_Pneumatic_after_disclaimer,not activated ,256
IDE04300-ENG126997-Vehicle menu operation-menu_display_Seat_Pneumatic_clamp_15_off,not activated ,256
IDE04300-ENG125820-Vehicle menu operation-menu_display_Seat_Pneumatic_over_threshold_high,not activated ,256
IDE04300-ENG125821-Vehicle menu operation-menu_display_Seat_Pneumatic_standstill,not activated ,256
IDE04300-ENG117551-Vehicle menu operation-menu_display_sia,activated ,256
IDE04300-ENG117555-Vehicle menu operation-menu_display_sia_after_disclaimer,not activated ,256
IDE04300-ENG117552-Vehicle menu operation-menu_display_sia_clamp_15_off,not activated ,256
IDE04300-ENG117553-Vehicle menu operation-menu_display_sia_over_threshold_high,activated ,256
IDE04300-ENG117554-Vehicle menu operation-menu_display_sia_standstill,not activated ,256
IDE04300-ENG117621-Vehicle menu operation-menu_display_side_view,not activated ,256
IDE04300-ENG117625-Vehicle menu operation-menu_display_side_view_after_disclaimer,not activated ,256
IDE04300-ENG117622-Vehicle menu operation-menu_display_side_view_clamp_15_off,not activated ,256
IDE04300-ENG117623-Vehicle menu operation-menu_display_side_view_over_threshold_high,not activated ,256
IDE04300-ENG117624-Vehicle menu operation-menu_display_side_view_standstill,not activated ,256
IDE04300-ENG122311-Vehicle menu operation-menu_display_special_functions,not activated ,256
IDE04300-ENG122314-Vehicle menu operation-menu_display_special_functions_after_disclaimer,not activated ,256
IDE04300-ENG125810-Vehicle menu operation-menu_display_special_functions_clamp_15_off,not activated ,256
IDE04300-ENG122312-Vehicle menu operation-menu_display_special_functions_over_threshold_high,not activated ,256
IDE04300-ENG122313-Vehicle menu operation-menu_display_special_functions_standstill,not activated ,256
IDE04300-ENG142082-Vehicle menu operation-menu_display_Spoiler,not activated ,256
IDE04300-ENG142086-Vehicle menu operation-menu_display_Spoiler_after_disclaimer,not activated ,256
IDE04300-ENG142083-Vehicle menu operation-menu_display_Spoiler_clamp_15_off,not activated ,256
IDE04300-ENG142084-Vehicle menu operation-menu_display_Spoiler_over_threshold_high,not activated ,256
IDE04300-ENG142085-Vehicle menu operation-menu_display_Spoiler_standstill,not activated ,256
IDE04300-ENG126148-Vehicle menu operation-menu_display_SportHMI,not activated ,256
IDE04300-ENG126151-Vehicle menu operation-menu_display_SportHMI_after_disclaimer,not activated ,256
IDE04300-ENG127001-Vehicle menu operation-menu_display_SportHMI_clamp_15_off,not activated ,256
IDE04300-ENG126149-Vehicle menu operation-menu_display_SportHMI_over_threshold_high,not activated ,256
IDE04300-ENG126150-Vehicle menu operation-menu_display_SportHMI_standstill,not activated ,256
IDE04300-ENG117676-Vehicle menu operation-menu_display_Start_Stop_reasons,not activated ,256
IDE04300-ENG117680-Vehicle menu operation-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,256
IDE04300-ENG117677-Vehicle menu operation-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,256
IDE04300-ENG117678-Vehicle menu operation-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,256
IDE04300-ENG117679-Vehicle menu operation-menu_display_Start_Stop_reasons_standstill,not activated ,256
IDE04300-ENG122315-Vehicle menu operation-menu_display_trailer_assistant,not activated ,256
IDE04300-ENG122319-Vehicle menu operation-menu_display_trailer_assistant_after_disclaimer,not activated ,256
IDE04300-ENG122316-Vehicle menu operation-menu_display_trailer_assistant_clamp_15_off,not activated ,256
IDE04300-ENG122317-Vehicle menu operation-menu_display_trailer_assistant_over_threshold_high,not activated ,256
IDE04300-ENG122318-Vehicle menu operation-menu_display_trailer_assistant_standstill,not activated ,256
IDE04300-ENG122320-Vehicle menu operation-menu_display_TV_tuner,not activated ,256
IDE04300-ENG122324-Vehicle menu operation-menu_display_TV_tuner_after_disclaimer,not activated ,256
IDE04300-ENG122321-Vehicle menu operation-menu_display_TV_tuner_clamp_15_off,not activated ,256
IDE04300-ENG122322-Vehicle menu operation-menu_display_TV_tuner_over_threshold_high,not activated ,256
IDE04300-ENG122323-Vehicle menu operation-menu_display_TV_tuner_standstill,not activated ,256
IDE04300-ENG117611-Vehicle menu operation-menu_display_ugdo,not activated ,256
IDE04300-ENG117615-Vehicle menu operation-menu_display_ugdo_after_disclaimer,not activated ,256
IDE04300-ENG117612-Vehicle menu operation-menu_display_ugdo_clamp_15_off,not activated ,256
IDE04300-ENG117613-Vehicle menu operation-menu_display_ugdo_over_threshold_high,not activated ,256
IDE04300-ENG117614-Vehicle menu operation-menu_display_ugdo_standstill,not activated ,256
IDE04300-ENG122291-Vehicle menu operation-menu_display_user_eco_rating,not activated ,256
IDE04300-ENG122295-Vehicle menu operation-menu_display_user_eco_rating_after_disclaimer,not activated ,256
IDE04300-ENG122292-Vehicle menu operation-menu_display_user_eco_rating_clamp_15_off,not activated ,256
IDE04300-ENG122293-Vehicle menu operation-menu_display_user_eco_rating_over_threshold_high,not activated ,256
IDE04300-ENG122294-Vehicle menu operation-menu_display_user_eco_rating_standstill,not activated ,256
IDE04300-ENG117581-Vehicle menu operation-menu_display_vin,activated ,256
IDE04300-ENG117585-Vehicle menu operation-menu_display_vin_after_disclaimer,not activated ,256
IDE04300-ENG117582-Vehicle menu operation-menu_display_vin_clamp_15_off,not activated ,256
IDE04300-ENG117583-Vehicle menu operation-menu_display_vin_over_threshold_high,activated ,256
IDE04300-ENG117584-Vehicle menu operation-menu_display_vin_standstill,not activated ,256
IDE04300-ENG117661-Vehicle menu operation-menu_display_weariness_recognition,activated ,256
IDE04300-ENG117665-Vehicle menu operation-menu_display_weariness_recognition_after_disclaimer,not activated ,256
IDE04300-ENG117662-Vehicle menu operation-menu_display_weariness_recognition_clamp_15_off,not activated ,256
IDE04300-ENG117663-Vehicle menu operation-menu_display_weariness_recognition_over_threshold_high,activated ,256
IDE04300-ENG117664-Vehicle menu operation-menu_display_weariness_recognition_standstill,not activated ,256
IDE04300-ENG117521-Vehicle menu operation-menu_display_windows,not activated ,256
IDE04300-ENG117525-Vehicle menu operation-menu_display_windows_after_disclaimer,not activated ,256
IDE04300-ENG117522-Vehicle menu operation-menu_display_windows_clamp_15_off,not activated ,256
IDE04300-ENG117523-Vehicle menu operation-menu_display_windows_over_threshold_high,not activated ,256
IDE04300-ENG117524-Vehicle menu operation-menu_display_windows_standstill,not activated ,256
IDE04300-ENG117546-Vehicle menu operation-menu_display_wiper,activated ,256
IDE04300-ENG117550-Vehicle menu operation-menu_display_wiper_after_disclaimer,not activated ,256
IDE04300-ENG117547-Vehicle menu operation-menu_display_wiper_clamp_15_off,not activated ,256
IDE04300-ENG117548-Vehicle menu operation-menu_display_wiper_over_threshold_high,activated ,256
IDE04300-ENG117549-Vehicle menu operation-menu_display_wiper_standstill,not activated ,256
IDE04300-ENG248733-Vehicle menu operation-menu_EngineFunctions,not activated ,256
IDE04300-ENG248734-Vehicle menu operation-menu_EngineFunctions_after_disclaimer,not activated ,256
IDE04300-ENG248735-Vehicle menu operation-menu_EngineFunctions_clamp_15_off,not activated ,256
IDE04300-ENG248736-Vehicle menu operation-menu_EngineFunctions_over_threshold_high,not activated ,256
IDE04300-ENG248737-Vehicle menu operation-menu_EngineFunctions_stillstand,not activated ,256
IDE04300-ENG252067-Vehicle menu operation-menu_exterior_illumination_2,not activated ,256
IDE04300-ENG252055-Vehicle menu operation-menu_exterior_illumination_2_after_disclaimer,not activated ,256
IDE04300-ENG252059-Vehicle menu operation-menu_exterior_illumination_2_clamp_15_off,not activated ,256
IDE04300-ENG252069-Vehicle menu operation-menu_exterior_illumination_2_over_threshold_high,not activated ,256
IDE04300-ENG252082-Vehicle menu operation-menu_exterior_illumination_2_stillstand,not activated ,256
IDE04300-ENG152515-Vehicle menu operation-menu_fas_profile,activated ,256
IDE04300-ENG152519-Vehicle menu operation-menu_fas_profile_after_disclaimer,not activated ,256
IDE04300-ENG152516-Vehicle menu operation-menu_fas_profile_clamp_15_off,not activated ,256
IDE04300-ENG152517-Vehicle menu operation-menu_fas_profile_over_threshold_high,activated ,256
IDE04300-ENG248738-Vehicle menu operation-menu_fas_profile_stillstand,not activated ,256
IDE04300-ENG185798-Vehicle menu operation-menu_fod,not activated ,256
IDE04300-ENG185799-Vehicle menu operation-menu_fod_after_disclaimer,not activated ,256
IDE04300-ENG185800-Vehicle menu operation-menu_fod_clamp_15_off,not activated ,256
IDE04300-ENG185801-Vehicle menu operation-menu_fod_over_threshold_high,not activated ,256
IDE04300-ENG185802-Vehicle menu operation-menu_fod_stillstand,not activated ,256
IDE04300-ENG248739-Vehicle menu operation-menu_IAA_PSO,activated ,256
IDE04300-ENG248740-Vehicle menu operation-menu_IAA_PSO_after_disclaimer,not activated ,256
IDE04300-ENG248741-Vehicle menu operation-menu_IAA_PSO_clamp_15_off,activated ,256
IDE04300-ENG248742-Vehicle menu operation-menu_IAA_PSO_over_threshold_high,activated ,256
IDE04300-ENG248743-Vehicle menu operation-menu_IAA_PSO_stillstand,not activated ,256
IDE04300-ENG248744-Vehicle menu operation-menu_ITM,not activated ,256
IDE04300-ENG248745-Vehicle menu operation-menu_ITM_after_disclaimer,not activated ,256
IDE04300-ENG248746-Vehicle menu operation-menu_ITM_clamp_15_off,not activated ,256
IDE04300-ENG248747-Vehicle menu operation-menu_ITM_over_threshold_high,not activated ,256
IDE04300-ENG248748-Vehicle menu operation-menu_ITM_stillstand,not activated ,256
IDE04300-ENG249916-Vehicle menu operation-menu_lift,not activated ,256
IDE04300-ENG249917-Vehicle menu operation-menu_lift_after_disclaimer,not activated ,256
IDE04300-ENG249918-Vehicle menu operation-menu_lift_clamp_15_off,not activated ,256
IDE04300-ENG249919-Vehicle menu operation-menu_lift_over_threshold_high,not activated ,256
IDE04300-ENG249920-Vehicle menu operation-menu_lift_stillstand,not activated ,256
IDE04300-ENG281916-Vehicle menu operation-menu_LLCC,not activated ,256
IDE04300-ENG281940-Vehicle menu operation-menu_LLCC_after_disclaimer,not activated ,256
IDE04300-ENG282002-Vehicle menu operation-menu_LLCC_clamp_15_off,not activated ,256
IDE04300-ENG281920-Vehicle menu operation-menu_LLCC_over_threshold_high,not activated ,256
IDE04300-ENG281919-Vehicle menu operation-menu_LLCC_standstill,not activated ,256
IDE04300-ENG184478-Vehicle menu operation-menu_mascot,not activated ,256
IDE04300-ENG184479-Vehicle menu operation-menu_mascot_after_disclaimer,not activated ,256
IDE04300-ENG184480-Vehicle menu operation-menu_mascot_clamp_15_off,not activated ,256
IDE04300-ENG184481-Vehicle menu operation-menu_mascot_over_threshold_high,not activated ,256
IDE04300-ENG184482-Vehicle menu operation-menu_mascot_stillstand,not activated ,256
IDE04300-ENG152562-Vehicle menu operation-menu_mobile_device_key_profile,not activated ,256
IDE04300-ENG152563-Vehicle menu operation-menu_mobile_device_key_profile_after_disclaimer,not activated ,256
IDE04300-ENG152564-Vehicle menu operation-menu_mobile_device_key_profile_clamp_15_off,not activated ,256
IDE04300-ENG152565-Vehicle menu operation-menu_mobile_device_key_profile_over_threshold_high,not activated ,256
IDE04300-ENG152566-Vehicle menu operation-menu_mobile_device_key_profile_stillstand,not activated ,256
IDE04300-ENG248749-Vehicle menu operation-menu_PaCo,not activated ,256
IDE04300-ENG248750-Vehicle menu operation-menu_PaCo_after_disclaimer,not activated ,256
IDE04300-ENG248751-Vehicle menu operation-menu_PaCo_clamp_15_off,not activated ,256
IDE04300-ENG248752-Vehicle menu operation-menu_PaCo_over_threshold_high,not activated ,256
IDE04300-ENG248753-Vehicle menu operation-menu_PaCo_stillstand,not activated ,256
IDE04300-ENG142092-Vehicle menu operation-menu_soundcontrol,not activated ,256
IDE04300-ENG248754-Vehicle menu operation-menu_SoundControl_2,not activated ,256
IDE04300-ENG248755-Vehicle menu operation-menu_SoundControl_2_after_disclaimer,not activated ,256
IDE04300-ENG248756-Vehicle menu operation-menu_SoundControl_2_clamp_15_off,not activated ,256
IDE04300-ENG248757-Vehicle menu operation-menu_SoundControl_2_over_threshold_high,not activated ,256
IDE04300-ENG248758-Vehicle menu operation-menu_SoundControl_2_stillstand,not activated ,256
IDE04300-ENG142096-Vehicle menu operation-menu_soundcontrol_after_disclaimer,not activated ,256
IDE04300-ENG142093-Vehicle menu operation-menu_soundcontrol_clamp_15_off,not activated ,256
IDE04300-ENG142094-Vehicle menu operation-menu_soundcontrol_over_threshold_high,not activated ,256
IDE04300-ENG142095-Vehicle menu operation-menu_soundcontrol_standstill,not activated ,256
IDE04300-ENG152505-Vehicle menu operation-menu_statistic,not activated ,256
IDE04300-ENG152509-Vehicle menu operation-menu_statistic_after_disclaimer,not activated ,256
IDE04300-ENG152506-Vehicle menu operation-menu_statistic_clamp_15_off,not activated ,256
IDE04300-ENG152507-Vehicle menu operation-menu_statistic_over_threshold_high,not activated ,256
IDE04300-ENG248759-Vehicle menu operation-menu_statistic_stillstand,not activated ,256
IDE04300-ENG152510-Vehicle menu operation-menu_sunroof,not activated ,256
IDE04300-ENG152514-Vehicle menu operation-menu_sunroof_after_disclaimer,not activated ,256
IDE04300-ENG152511-Vehicle menu operation-menu_sunroof_clamp_15_off,not activated ,256
IDE04300-ENG152512-Vehicle menu operation-menu_sunroof_over_threshold_high,not activated ,256
IDE04300-ENG248760-Vehicle menu operation-menu_sunroof_stillstand,not activated ,256
IDE04300-ENG185803-Vehicle menu operation-menu_vas,not activated ,256
IDE04300-ENG185804-Vehicle menu operation-menu_vas_after_disclaimer,not activated ,256
IDE04300-ENG185805-Vehicle menu operation-menu_vas_clamp_15_off,not activated ,256
IDE04300-ENG185806-Vehicle menu operation-menu_vas_over_threshold_high,not activated ,256
IDE04300-ENG185807-Vehicle menu operation-menu_vas_stillstand,not activated ,256
IDE04300-ENG152500-Vehicle menu operation-menu_wireless_charging,not activated ,256
IDE04300-ENG152504-Vehicle menu operation-menu_wireless_charging_after_disclaimer,not activated ,256
IDE04300-ENG152501-Vehicle menu operation-menu_wireless_charging_clamp_15_off,not activated ,256
IDE04300-ENG152502-Vehicle menu operation-menu_wireless_charging_over_threshold_high,not activated ,256
IDE04300-ENG152503-Vehicle menu operation-menu_wireless_charging_standstill,not activated ,256
IDE04307-ENG117700-Vehicle function list BAP-ACC_0x05,not activated ,256
IDE04307-ENG117701-Vehicle function list BAP-ACC_0x05_msg_bus,not activated ,256
IDE04307-ENG117702-Vehicle function list BAP-air_suspension_0x06,not activated ,256
IDE04307-ENG117703-Vehicle function list BAP-air_suspension_0x06_msg_bus,not activated ,256
IDE04307-ENG117764-Vehicle function list BAP-Amplifier_0x2D,not activated ,256
IDE04307-ENG117765-Vehicle function list BAP-Amplifier_0x2D_msg_bus,not activated ,256
IDE04307-ENG122334-Vehicle function list BAP-Angle_Of_Slope_0x24,not activated ,256
IDE04307-ENG122335-Vehicle function list BAP-Angle_Of_Slope_0x24_msg_bus,not activated ,256
IDE04307-ENG117696-Vehicle function list BAP-auxilary_heating_0x03,not activated ,256
IDE04307-ENG117697-Vehicle function list BAP-auxilary_heating_0x03_msg_bus,not activated ,256
IDE04307-ENG117744-Vehicle function list BAP-AWV_0x1B,not activated ,256
IDE04307-ENG117745-Vehicle function list BAP-AWV_0x1B_msg_bus,not activated ,256
IDE04307-ENG122336-Vehicle function list BAP-Battery_Management_0x25,not activated ,256
IDE04307-ENG122337-Vehicle function list BAP-Battery_Management_0x25_msg_bus,not activated ,256
IDE04307-ENG117758-Vehicle function list BAP-BCmE_0x23,not activated ,256
IDE04307-ENG117759-Vehicle function list BAP-BCmE_0x23_msg_bus,not activated ,256
IDE04307-ENG117760-Vehicle function list BAP-Brake_0x26,not activated ,256
IDE04307-ENG117761-Vehicle function list BAP-Brake_0x26_msg_bus,not activated ,256
IDE04307-ENG248526-Vehicle function list BAP-Car2X_0x61,not activated ,256
IDE04307-ENG248527-Vehicle function list BAP-Car2X_0x61_msg_bus,not activated ,256
IDE04307-ENG117717-Vehicle function list BAP-central_locking_0x0D,activated ,256
IDE04307-ENG117716-Vehicle function list BAP-central_locking_0x0D_msg_bus,Terminal 15 ,256
IDE04307-ENG117736-Vehicle function list BAP-charisma_0x17,activated ,256
IDE04307-ENG117737-Vehicle function list BAP-charisma_0x17_msg_bus,Terminal 15 ,256
IDE04307-ENG282048-Vehicle function list BAP-ChassisControl_0x57,not activated ,256
IDE04307-ENG282008-Vehicle function list BAP-ChassisControl_0x57_msg_bus,not activated ,256
IDE04307-ENG117734-Vehicle function list BAP-clima_slave_2_0x16,not activated ,256
IDE04307-ENG117735-Vehicle function list BAP-clima_slave_2_0x16_msg_bus,not activated ,256
IDE04307-ENG248490-Vehicle function list BAP-climate_master_0x42,activated ,256
IDE04307-ENG248630-Vehicle function list BAP-climate_master_0x42_msg_bus,CAB_10 ,256
IDE04307-ENG117692-Vehicle function list BAP-climatic_master_0x01,activated ,256
IDE04307-ENG117693-Vehicle function list BAP-climatic_master_0x01_msg_bus,CAB_10 ,256
IDE04307-ENG117694-Vehicle function list BAP-climatic_slave_0x02,activated ,256
IDE04307-ENG117695-Vehicle function list BAP-climatic_slave_0x02_msg_bus,CAB_10 ,256
IDE04307-ENG117724-Vehicle function list BAP-clock_0x11,activated ,256
IDE04307-ENG117725-Vehicle function list BAP-clock_0x11_msg_bus,Infotainment data bus ,256
IDE04307-ENG117732-Vehicle function list BAP-compass_0x15,not activated ,256
IDE04307-ENG117733-Vehicle function list BAP-compass_0x15_msg_bus,not activated ,256
IDE04307-ENG142158-Vehicle function list BAP-connection_manager_0x47,not activated ,256
IDE04307-ENG142159-Vehicle function list BAP-connection_manager_0x47_msg_bus,not activated ,256
IDE04307-ENG152529-Vehicle function list BAP-daf_profile_0x51,not activated ,256
IDE04307-ENG152530-Vehicle function list BAP-daf_profile_0x51_msg_bus,not activated ,256
IDE04307-ENG137043-Vehicle function list BAP-display_configuration_0x45,activated ,256
IDE04307-ENG137044-Vehicle function list BAP-display_configuration_0x45_msg_bus,Terminal 15 ,256
IDE04307-ENG117722-Vehicle function list BAP-driver_seat_0x10,activated ,256
IDE04307-ENG117723-Vehicle function list BAP-driver_seat_0x10_msg_bus,CAB_4 ,256
IDE04307-ENG125039-Vehicle function list BAP-Ecall_0x33,not activated ,256
IDE04307-ENG125828-Vehicle function list BAP-eCall_0x33_msg_bus,not activated ,256
IDE04307-ENG127500-Vehicle function list BAP-efficiency_assis_msg_bus_0x3C,Terminal 15 ,256
IDE04307-ENG127499-Vehicle function list BAP-efficiency_assist_0x3C,activated ,256
IDE04307-ENG248657-Vehicle function list BAP-EngineFunctions_0x5D,not activated ,256
IDE04307-ENG248658-Vehicle function list BAP-EngineFunctions_0x5D_msg_bus,not activated ,256
IDE04307-ENG125829-Vehicle function list BAP-ENI_0x37,not activated ,256
IDE04307-ENG125830-Vehicle function list BAP-ENI_0x37_msg_bus,not activated ,256
IDE04307-ENG264168-Vehicle function list BAP-ENI2_0x58,not activated ,256
IDE04307-ENG264169-Vehicle function list BAP-ENI2_0x58_msg_bus,not activated ,256
IDE04307-ENG264170-Vehicle function list BAP-ENI3_0x6E,not activated ,256
IDE04307-ENG264171-Vehicle function list BAP-ENI3_0x6E_msg_bus,not activated ,256
IDE04307-ENG264172-Vehicle function list BAP-ENI4_0x6F,not activated ,256
IDE04307-ENG264173-Vehicle function list BAP-ENI4_0x6F_msg_bus,not activated ,256
IDE04307-ENG117708-Vehicle function list BAP-exterieur_light_0x09,activated ,256
IDE04307-ENG117709-Vehicle function list BAP-exterieur_light_0x09_msg_bus,Terminal 15 ,256
IDE04307-ENG252073-Vehicle function list BAP-exterieur_light_2_0x6B,not activated ,256
IDE04307-ENG252076-Vehicle function list BAP-exterieur_light_2_0x6B_msg_bus,not activated ,256
IDE04307-ENG142168-Vehicle function list BAP-fas_profile_0x4D,activated ,256
IDE04307-ENG142169-Vehicle function list BAP-fas_profile_0x4D_msg_bus,Terminal 15 ,256
IDE04307-ENG142154-Vehicle function list BAP-front_traffic_assist_0x41,not activated ,256
IDE04307-ENG142155-Vehicle function list BAP-front_traffic_assist_0x41_msg_bus,not activated ,256
IDE04307-ENG117698-Vehicle function list BAP-headup_displ_0x04,not activated ,256
IDE04307-ENG117699-Vehicle function list BAP-headup_displ_0x04_msg_bus,not activated ,256
IDE04307-ENG117746-Vehicle function list BAP-Hybrid_0x1D,not activated ,256
IDE04307-ENG117747-Vehicle function list BAP-Hybrid_0x1D_msg_bus,not activated ,256
IDE04307-ENG248711-Vehicle function list BAP-IAA_PSO_0x52,activated ,256
IDE04307-ENG248712-Vehicle function list BAP-IAA_PSO_0x52_msg_bus,Infotainment data bus ,256
IDE04307-ENG152535-Vehicle function list BAP-infotainmentsettings_profile_0x50,not activated ,256
IDE04307-ENG152536-Vehicle function list BAP-infotainmentsettings_profile_0x50_msg_bus,not activated ,256
IDE04307-ENG117706-Vehicle function list BAP-interieur_light_0x08,activated ,256
IDE04307-ENG117707-Vehicle function list BAP-interieur_light_0x08_msg_bus,Terminal 15 ,256
IDE04307-ENG252052-Vehicle function list BAP-interieur_light_2_0x6A,not activated ,256
IDE04307-ENG252047-Vehicle function list BAP-interieur_light_2_0x6A_msg_bus,not activated ,256
IDE04307-ENG248719-Vehicle function list BAP-ITM_0x65,not activated ,256
IDE04307-ENG248720-Vehicle function list BAP-ITM_0x65_msg_bus,not activated ,256
IDE04307-ENG117740-Vehicle function list BAP-LDW_HCA_0x19,activated ,256
IDE04307-ENG117741-Vehicle function list BAP-LDW_HCA_0x19_msg_bus,Terminal 15 ,256
IDE04307-ENG249902-Vehicle function list BAP-lift_0x64,not activated ,256
IDE04307-ENG249903-Vehicle function list BAP-lift_0x64_msg_bus,not activated ,256
IDE04307-ENG281905-Vehicle function list BAP-LLCC_0x78,not activated ,256
IDE04307-ENG281994-Vehicle function list BAP-LLCC_0x78_msg_bus,not activated ,256
IDE04307-ENG248726-Vehicle function list BAP-Mascot_0x53,not activated ,256
IDE04307-ENG248727-Vehicle function list BAP-Mascot_0x53_msg_bus,not activated ,256
IDE04307-ENG117720-Vehicle function list BAP-MFA_0x0F,activated ,256
IDE04307-ENG117721-Vehicle function list BAP-MFA_0x0F_msg_bus,Terminal 15 ,256
IDE04307-ENG117767-Vehicle function list BAP-MFL_Jocker_0x34,activated ,256
IDE04307-ENG117766-Vehicle function list BAP-MFL_Jocker_msg_bus_0x34,Infotainment data bus ,256
IDE04307-ENG117719-Vehicle function list BAP-mirror_0x0E,not activated ,256
IDE04307-ENG117718-Vehicle function list BAP-mirror_0x0E_msg_bus,not activated ,256
IDE04307-ENG117738-Vehicle function list BAP-Night_Vision_0x18,not activated ,256
IDE04307-ENG117739-Vehicle function list BAP-Night_Vision_0x18_msg_bus,not activated ,256
IDE04307-ENG248788-Vehicle function list BAP-PaCo_0x55,not activated ,256
IDE04307-ENG248789-Vehicle function list BAP-PaCo_0x55_msg_bus,not activated ,256
IDE04307-ENG117710-Vehicle function list BAP-parking_assist_0x0A,activated ,256
IDE04307-ENG117711-Vehicle function list BAP-parking_assist_0x0A_msg_bus,Terminal 15 ,256
IDE04307-ENG117752-Vehicle function list BAP-Passenger_Seat_0x20,not activated ,256
IDE04307-ENG117753-Vehicle function list BAP-Passenger_Seat_0x20_msg_bus,not activated ,256
IDE04307-ENG125831-Vehicle function list BAP-Pedestrian_Assist_0x3A,not activated ,256
IDE04307-ENG125832-Vehicle function list BAP-Pedestrian_Assist_msg_bus_0x3A,not activated ,256
IDE04307-ENG122333-Vehicle function list BAP-Range_Data_0x39,not activated ,256
IDE04307-ENG125827-Vehicle function list BAP-Range_Data_msg_bus_0x39,not activated ,256
IDE04307-ENG122327-Vehicle function list BAP-RearSeatEntertainment_0x2E,not activated ,256
IDE04307-ENG122328-Vehicle function list BAP-RearSeatEntertainment_0x2E_msg_bus,not activated ,256
IDE04307-ENG248801-Vehicle function list BAP-remote_services_0x4E,not activated ,256
IDE04307-ENG248802-Vehicle function list BAP-remote_services_0x4E_msg_bus,not activated ,256
IDE04307-ENG117750-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F,activated ,256
IDE04307-ENG117751-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Terminal 15 ,256
IDE04307-ENG125833-Vehicle function list BAP-Seat_Pneumatic_0x3B,not activated ,256
IDE04307-ENG125834-Vehicle function list BAP-Seat_Pneumatic_msg_bus_0x3B,not activated ,256
IDE04307-ENG139200-Vehicle function list BAP-Seatmemory_codriver_rear_0x3F,not activated ,256
IDE04307-ENG139201-Vehicle function list BAP-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,256
IDE04307-ENG139198-Vehicle function list BAP-Seatmemory_driver_rear_0x3E,not activated ,256
IDE04307-ENG139199-Vehicle function list BAP-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,256
IDE04307-ENG117726-Vehicle function list BAP-service_interval_display_0x12,activated ,256
IDE04307-ENG117727-Vehicle function list BAP-service_interval_display_0x12_msg_bus,Terminal 15 ,256
IDE04307-ENG117748-Vehicle function list BAP-SideView_0x1E,not activated ,256
IDE04307-ENG117749-Vehicle function list BAP-SideView_0x1E_msg_bus,not activated ,256
IDE04307-ENG139202-Vehicle function list BAP-Soundcontrol_0x44,not activated ,256
IDE04307-ENG139203-Vehicle function list BAP-Soundcontrol_0x44_msg_bus,not activated ,256
IDE04307-ENG248819-Vehicle function list BAP-SoundControl2_0x66,not activated ,256
IDE04307-ENG248820-Vehicle function list BAP-SoundControl2_0x66_msg_bus,not activated ,256
IDE04307-ENG122329-Vehicle function list BAP-Special_Functions_0x35,not activated ,256
IDE04307-ENG122330-Vehicle function list BAP-Special_Functions_msg_bus_0x35,not activated ,256
IDE04307-ENG127678-Vehicle function list BAP-spoiler_0x40,not activated ,256
IDE04307-ENG127679-Vehicle function list BAP-spoiler_0x40_msg_bus,not activated ,256
IDE04307-ENG117762-Vehicle function list BAP-Start_Stop_reasons_0x27,not activated ,256
IDE04307-ENG117763-Vehicle function list BAP-Start_Stop_reasons_0x27_msg_bus,not activated ,256
IDE04307-ENG142162-Vehicle function list BAP-statistic_0x4A,not activated ,256
IDE04307-ENG142163-Vehicle function list BAP-statistic_0x4A_msg_bus,not activated ,256
IDE04307-ENG142164-Vehicle function list BAP-sunroof_front_0x4B,not activated ,256
IDE04307-ENG142165-Vehicle function list BAP-sunroof_front_0x4B_msg_bus,not activated ,256
IDE04307-ENG142166-Vehicle function list BAP-sunroof_rear_0x4C,not activated ,256
IDE04307-ENG142167-Vehicle function list BAP-sunroof_rear_0x4C_msg_bus,not activated ,256
IDE04307-ENG117742-Vehicle function list BAP-SWA_0x1A,not activated ,256
IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus,not activated ,256
IDE04307-ENG117704-Vehicle function list BAP-tire_pressure_system_0x07,activated ,256
IDE04307-ENG117705-Vehicle function list BAP-tire_pressure_system_0x07_msg_bus,Terminal 15 ,256
IDE04307-ENG117754-Vehicle function list BAP-traffic_sign_recognition_0x21,activated ,256
IDE04307-ENG117755-Vehicle function list BAP-traffic_sign_recognition_0x21_msg_bus,Terminal 15 ,256
IDE04307-ENG122331-Vehicle function list BAP-Trailer_Assistant_0x36,not activated ,256
IDE04307-ENG122332-Vehicle function list BAP-Trailer_Assistant_msg_bus_0x36,not activated ,256
IDE04307-ENG260744-Vehicle function list BAP-Trained_Park_Assist_0x5F,not activated ,256
IDE04307-ENG258630-Vehicle function list BAP-Trained_Park_Assist_0x5F_msg_bus,not activated ,256
IDE04307-ENG122325-Vehicle function list BAP-TV_tuner_0x2C,not activated ,256
IDE04307-ENG122326-Vehicle function list BAP-TV_tuner_0x2C_msg_bus,not activated ,256
IDE04307-ENG117730-Vehicle function list BAP-UGDO_0x14,not activated ,256
IDE04307-ENG117731-Vehicle function list BAP-UGDO_0x14_msg_bus,not activated ,256
IDE04307-ENG117728-Vehicle function list BAP-unit_master_0x13,activated ,256
IDE04307-ENG117729-Vehicle function list BAP-unit_master_0x13_msg_bus,Terminal 15 ,256
IDE04307-ENG185817-Vehicle function list BAP-vas_0x54,not activated ,256
IDE04307-ENG185818-Vehicle function list BAP-vas_0x54_msg_bus,not activated ,256
IDE04307-ENG117712-Vehicle function list BAP-VPS_0x0B,activated ,256
IDE04307-ENG117713-Vehicle function list BAP-VPS_0x0B_msg_bus,Terminal 15 ,256
IDE04307-ENG117756-Vehicle function list BAP-weariness_rcognition_0x22,activated ,256
IDE04307-ENG117757-Vehicle function list BAP-weariness_rcognition_0x22_msg_bus,Terminal 15 ,256
IDE04307-ENG117714-Vehicle function list BAP-wiper_comfort_0x0C,activated ,256
IDE04307-ENG117715-Vehicle function list BAP-wiper_comfort_0x0C_msg_bus,Terminal 15 ,256
IDE04307-ENG142160-Vehicle function list BAP-wireless_charging_0x48,not activated ,256
IDE04307-ENG142161-Vehicle function list BAP-wireless_charging_0x48_msg_bus,not activated ,256
IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code,2 ,2
IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code,2 ,2
IDE04521-Sporadic ring break detection,none ,1
IDE04522-Awakening ability on optical databus,OFF ,1
IDE06698-MAS00839-Audio management input gain-TV Tuner,-128 dB,34
IDE06698-MAS00846-Audio management input gain-Satellite radio,-128 dB,34
IDE06698-MAS01984-Audio management input gain-Radio (FM),-128 dB,34
IDE06698-MAS01985-Audio management input gain-Radio (AM),-128 dB,34
IDE06698-MAS01986-Audio management input gain-Digital radio (DAB),-128 dB,34
IDE06698-ENG125854-Audio management input gain-Exbox_DMB,-128 dB,34
IDE06698-ENG117430-Audio management input gain-HFP,-128 dB,34
IDE06698-ENG125846-Audio management input gain-Media_Airplay,-128 dB,34
IDE06698-ENG125837-Audio management input gain-Media_AUX_Adapter,-128 dB,34
IDE06698-ENG125836-Audio management input gain-Media_AUXIN,-128 dB,34
IDE06698-ENG125843-Audio management input gain-Media_Bluray,-128 dB,34
IDE06698-ENG125841-Audio management input gain-Media_BTDevice,-128 dB,34
IDE06698-ENG125838-Audio management input gain-Media_CDA,-128 dB,34
IDE06698-ENG125848-Audio management input gain-Media_Cloud,-128 dB,34
IDE06698-ENG125839-Audio management input gain-Media_DVD,-128 dB,34
IDE06698-ENG125844-Audio management input gain-Media_HDMI,-128 dB,34
IDE06698-ENG125840-Audio management input gain-Media_MFP,-128 dB,34
IDE06698-ENG125847-Audio management input gain-Media_UPNP,-128 dB,34
IDE06698-ENG125855-Audio management input gain-Mirrorlink,-128 dB,34
IDE06698-ENG125859-Audio management input gain-Phone_Ringer_MFP,-128 dB,34
IDE06698-ENG125860-Audio management input gain-Phone_Ringer_OB,-128 dB,34
IDE06698-ENG125858-Audio management input gain-Phone_Voice,-128 dB,34
IDE06698-ENG125842-Audio management input gain-TA_Tuner_FM,-128 dB,34
IDE06698-ENG125850-Audio management input gain-Tone_Beep,-128 dB,34
IDE06698-ENG125853-Audio management input gain-Tone_Messaging,-128 dB,34
IDE06698-ENG125852-Audio management input gain-Tone_Touchscreen,-128 dB,34
IDE06698-ENG125851-Audio management input gain-Tone_Warning,-128 dB,34
IDE06698-ENG251556-Audio management input gain-touch_screen_player,-128 dB,34
IDE06698-ENG125856-Audio management input gain-TTS_Nav,-128 dB,34
IDE06698-ENG125857-Audio management input gain-TTS_SDS,-128 dB,34
IDE06698-ENG125845-Audio management input gain-Tuner_Online,-128 dB,34
IDE06698-ENG125849-Audio management input gain-Tuner_Personal,-128 dB,34
IDE06698-ENG125835-Audio management input gain-Tuner_TI,-128 dB,34
IDE06698-ENG125861-Audio management input gain-TV_AV_IN,-128 dB,34
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,not activated ,2
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,not activated ,2
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,not activated ,2
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,not activated ,2
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,not activated ,2
IDE08814-MAS14301-Navigation receiver GNSS configuration-external GPS receiver via bus,not activated ,2
IDE08814-MAS15014-Navigation receiver GNSS configuration-Beidou,not activated ,2
IDE08814-MAS18801-Navigation receiver GNSS configuration-external GPS receiver 2 via bus,not activated ,2
IDE08814-MAS18802-Navigation receiver GNSS configuration-Gnss update rate,0 ,2
IDE08814-ENG259336-Navigation receiver GNSS configuration-GNSS_over_ethernet,not activated ,2
IDE10082-MAS09814-Telephone functions configuration-Call Center Function,OFF ,1
IDE10082-MAS13846-Telephone functions configuration-Internet access via WiFi,available. ,1
IDE10082-ENG278502-Telephone functions configuration-Icon_for_data_connection,Hide ,1
IDE10494-ENG128241-Active noise reduction: configuration-ANC_EOL_level,3 ,31
IDE10494-ENG128062-Active noise reduction: configuration-mask_level_result_FL_FL_1,NO_Mask ,31
IDE10494-ENG128064-Active noise reduction: configuration-mask_level_result_FL_FL_2,NO_Mask ,31
IDE10494-ENG128066-Active noise reduction: configuration-mask_level_result_FL_FL_3,NO_Mask ,31
IDE10494-ENG128068-Active noise reduction: configuration-mask_level_result_FL_FR_1,NO_Mask ,31
IDE10494-ENG128070-Active noise reduction: configuration-mask_level_result_FL_FR_2,NO_Mask ,31
IDE10494-ENG128072-Active noise reduction: configuration-mask_level_result_FL_FR_3,NO_Mask ,31
IDE10494-ENG128086-Active noise reduction: configuration-mask_level_result_FL_Mic5_1,NO_Mask ,31
IDE10494-ENG128088-Active noise reduction: configuration-mask_level_result_FL_Mic5_2,NO_Mask ,31
IDE10494-ENG128090-Active noise reduction: configuration-mask_level_result_FL_Mic5_3,NO_Mask ,31
IDE10494-ENG128092-Active noise reduction: configuration-mask_level_result_FL_Mic6_1,NO_Mask ,31
IDE10494-ENG128094-Active noise reduction: configuration-mask_level_result_FL_Mic6_2,NO_Mask ,31
IDE10494-ENG128096-Active noise reduction: configuration-mask_level_result_FL_Mic6_3,NO_Mask ,31
IDE10494-ENG128074-Active noise reduction: configuration-mask_level_result_FL_RL_1,NO_Mask ,31
IDE10494-ENG128076-Active noise reduction: configuration-mask_level_result_FL_RL_2,NO_Mask ,31
IDE10494-ENG128078-Active noise reduction: configuration-mask_level_result_FL_RL_3,NO_Mask ,31
IDE10494-ENG128080-Active noise reduction: configuration-mask_level_result_FL_RR_1,NO_Mask ,31
IDE10494-ENG128082-Active noise reduction: configuration-mask_level_result_FL_RR_2,NO_Mask ,31
IDE10494-ENG128084-Active noise reduction: configuration-mask_level_result_FL_RR_3,NO_Mask ,31
IDE10494-ENG128098-Active noise reduction: configuration-mask_level_result_FR_FL_1,NO_Mask ,31
IDE10494-ENG128100-Active noise reduction: configuration-mask_level_result_FR_FL_2,NO_Mask ,31
IDE10494-ENG128102-Active noise reduction: configuration-mask_level_result_FR_FL_3,NO_Mask ,31
IDE10494-ENG128104-Active noise reduction: configuration-mask_level_result_FR_FR_1,NO_Mask ,31
IDE10494-ENG128106-Active noise reduction: configuration-mask_level_result_FR_FR_2,NO_Mask ,31
IDE10494-ENG128108-Active noise reduction: configuration-mask_level_result_FR_FR_3,NO_Mask ,31
IDE10494-ENG128122-Active noise reduction: configuration-mask_level_result_FR_Mic5_1,NO_Mask ,31
IDE10494-ENG128124-Active noise reduction: configuration-mask_level_result_FR_Mic5_2,NO_Mask ,31
IDE10494-ENG128126-Active noise reduction: configuration-mask_level_result_FR_Mic5_3,NO_Mask ,31
IDE10494-ENG128128-Active noise reduction: configuration-mask_level_result_FR_Mic6_1,NO_Mask ,31
IDE10494-ENG128130-Active noise reduction: configuration-mask_level_result_FR_Mic6_2,NO_Mask ,31
IDE10494-ENG128132-Active noise reduction: configuration-mask_level_result_FR_Mic6_3,NO_Mask ,31
IDE10494-ENG128110-Active noise reduction: configuration-mask_level_result_FR_RL_1,NO_Mask ,31
IDE10494-ENG128112-Active noise reduction: configuration-mask_level_result_FR_RL_2,NO_Mask ,31
IDE10494-ENG128114-Active noise reduction: configuration-mask_level_result_FR_RL_3,NO_Mask ,31
IDE10494-ENG128116-Active noise reduction: configuration-mask_level_result_FR_RR_1,NO_Mask ,31
IDE10494-ENG128118-Active noise reduction: configuration-mask_level_result_FR_RR_2,NO_Mask ,31
IDE10494-ENG128120-Active noise reduction: configuration-mask_level_result_FR_RR_3,NO_Mask ,31
IDE10494-ENG128134-Active noise reduction: configuration-mask_level_result_RL_FL_1,NO_Mask ,31
IDE10494-ENG128136-Active noise reduction: configuration-mask_level_result_RL_FL_2,NO_Mask ,31
IDE10494-ENG128138-Active noise reduction: configuration-mask_level_result_RL_FL_3,NO_Mask ,31
IDE10494-ENG128140-Active noise reduction: configuration-mask_level_result_RL_FR_1,NO_Mask ,31
IDE10494-ENG128142-Active noise reduction: configuration-mask_level_result_RL_FR_2,NO_Mask ,31
IDE10494-ENG128144-Active noise reduction: configuration-mask_level_result_RL_FR_3,NO_Mask ,31
IDE10494-ENG128158-Active noise reduction: configuration-mask_level_result_RL_Mic5_1,NO_Mask ,31
IDE10494-ENG128160-Active noise reduction: configuration-mask_level_result_RL_Mic5_2,NO_Mask ,31
IDE10494-ENG128162-Active noise reduction: configuration-mask_level_result_RL_Mic5_3,NO_Mask ,31
IDE10494-ENG128164-Active noise reduction: configuration-mask_level_result_RL_Mic6_1,NO_Mask ,31
IDE10494-ENG128166-Active noise reduction: configuration-mask_level_result_RL_Mic6_2,NO_Mask ,31
IDE10494-ENG128168-Active noise reduction: configuration-mask_level_result_RL_Mic6_3,NO_Mask ,31
IDE10494-ENG128146-Active noise reduction: configuration-mask_level_result_RL_RL_1,NO_Mask ,31
IDE10494-ENG128148-Active noise reduction: configuration-mask_level_result_RL_RL_2,NO_Mask ,31
IDE10494-ENG128150-Active noise reduction: configuration-mask_level_result_RL_RL_3,NO_Mask ,31
IDE10494-ENG128152-Active noise reduction: configuration-mask_level_result_RL_RR_1,NO_Mask ,31
IDE10494-ENG128154-Active noise reduction: configuration-mask_level_result_RL_RR_2,NO_Mask ,31
IDE10494-ENG128156-Active noise reduction: configuration-mask_level_result_RL_RR_3,NO_Mask ,31
IDE10494-ENG128170-Active noise reduction: configuration-mask_level_result_RR_FL_1,NO_Mask ,31
IDE10494-ENG128172-Active noise reduction: configuration-mask_level_result_RR_FL_2,NO_Mask ,31
IDE10494-ENG128174-Active noise reduction: configuration-mask_level_result_RR_FL_3,NO_Mask ,31
IDE10494-ENG128176-Active noise reduction: configuration-mask_level_result_RR_FR_1,NO_Mask ,31
IDE10494-ENG128178-Active noise reduction: configuration-mask_level_result_RR_FR_2,NO_Mask ,31
IDE10494-ENG128180-Active noise reduction: configuration-mask_level_result_RR_FR_3,NO_Mask ,31
IDE10494-ENG128194-Active noise reduction: configuration-mask_level_result_RR_Mic5_1,NO_Mask ,31
IDE10494-ENG128196-Active noise reduction: configuration-mask_level_result_RR_Mic5_2,NO_Mask ,31
IDE10494-ENG128198-Active noise reduction: configuration-mask_level_result_RR_Mic5_3,NO_Mask ,31
IDE10494-ENG128200-Active noise reduction: configuration-mask_level_result_RR_Mic6_1,NO_Mask ,31
IDE10494-ENG128202-Active noise reduction: configuration-mask_level_result_RR_Mic6_2,NO_Mask ,31
IDE10494-ENG128204-Active noise reduction: configuration-mask_level_result_RR_Mic6_3,NO_Mask ,31
IDE10494-ENG128182-Active noise reduction: configuration-mask_level_result_RR_RL_1,NO_Mask ,31
IDE10494-ENG128184-Active noise reduction: configuration-mask_level_result_RR_RL_2,NO_Mask ,31
IDE10494-ENG128186-Active noise reduction: configuration-mask_level_result_RR_RL_3,NO_Mask ,31
IDE10494-ENG128188-Active noise reduction: configuration-mask_level_result_RR_RR_1,NO_Mask ,31
IDE10494-ENG128190-Active noise reduction: configuration-mask_level_result_RR_RR_2,NO_Mask ,31
IDE10494-ENG128192-Active noise reduction: configuration-mask_level_result_RR_RR_3,NO_Mask ,31
IDE10494-ENG128206-Active noise reduction: configuration-mask_level_result_Subw_FL_1,NO_Mask ,31
IDE10494-ENG128208-Active noise reduction: configuration-mask_level_result_Subw_FL_2,NO_Mask ,31
IDE10494-ENG128210-Active noise reduction: configuration-mask_level_result_Subw_FL_3,NO_Mask ,31
IDE10494-ENG128212-Active noise reduction: configuration-mask_level_result_Subw_FR_1,NO_Mask ,31
IDE10494-ENG128214-Active noise reduction: configuration-mask_level_result_Subw_FR_2,NO_Mask ,31
IDE10494-ENG128216-Active noise reduction: configuration-mask_level_result_Subw_FR_3,NO_Mask ,31
IDE10494-ENG128230-Active noise reduction: configuration-mask_level_result_Subw_Mic5_1,NO_Mask ,31
IDE10494-ENG128232-Active noise reduction: configuration-mask_level_result_Subw_Mic5_2,NO_Mask ,31
IDE10494-ENG128234-Active noise reduction: configuration-mask_level_result_Subw_Mic5_3,NO_Mask ,31
IDE10494-ENG128236-Active noise reduction: configuration-mask_level_result_Subw_Mic6_1,NO_Mask ,31
IDE10494-ENG128238-Active noise reduction: configuration-mask_level_result_Subw_Mic6_2,NO_Mask ,31
IDE10494-ENG128240-Active noise reduction: configuration-mask_level_result_Subw_Mic6_3,NO_Mask ,31
IDE10494-ENG128218-Active noise reduction: configuration-mask_level_result_Subw_RL_1,NO_Mask ,31
IDE10494-ENG128220-Active noise reduction: configuration-mask_level_result_Subw_RL_2,NO_Mask ,31
IDE10494-ENG128222-Active noise reduction: configuration-mask_level_result_Subw_RL_3,NO_Mask ,31
IDE10494-ENG128224-Active noise reduction: configuration-mask_level_result_Subw_RR_1,NO_Mask ,31
IDE10494-ENG128226-Active noise reduction: configuration-mask_level_result_Subw_RR_2,NO_Mask ,31
IDE10494-ENG128228-Active noise reduction: configuration-mask_level_result_Subw_RR_3,NO_Mask ,31
IDE10494-ENG128061-Active noise reduction: configuration-mask_phase_result_FL_FL_1,NO_Mask ,31
IDE10494-ENG128063-Active noise reduction: configuration-mask_phase_result_FL_FL_2,NO_Mask ,31
IDE10494-ENG128065-Active noise reduction: configuration-mask_phase_result_FL_FL_3,NO_Mask ,31
IDE10494-ENG128067-Active noise reduction: configuration-mask_phase_result_FL_FR_1,NO_Mask ,31
IDE10494-ENG128069-Active noise reduction: configuration-mask_phase_result_FL_FR_2,NO_Mask ,31
IDE10494-ENG128071-Active noise reduction: configuration-mask_phase_result_FL_FR_3,NO_Mask ,31
IDE10494-ENG128085-Active noise reduction: configuration-mask_phase_result_FL_Mic5_1,NO_Mask ,31
IDE10494-ENG128087-Active noise reduction: configuration-mask_phase_result_FL_Mic5_2,NO_Mask ,31
IDE10494-ENG128089-Active noise reduction: configuration-mask_phase_result_FL_Mic5_3,NO_Mask ,31
IDE10494-ENG128091-Active noise reduction: configuration-mask_phase_result_FL_Mic6_1,NO_Mask ,31
IDE10494-ENG128093-Active noise reduction: configuration-mask_phase_result_FL_Mic6_2,NO_Mask ,31
IDE10494-ENG128095-Active noise reduction: configuration-mask_phase_result_FL_Mic6_3,NO_Mask ,31
IDE10494-ENG128073-Active noise reduction: configuration-mask_phase_result_FL_RL_1,NO_Mask ,31
IDE10494-ENG128075-Active noise reduction: configuration-mask_phase_result_FL_RL_2,NO_Mask ,31
IDE10494-ENG128077-Active noise reduction: configuration-mask_phase_result_FL_RL_3,NO_Mask ,31
IDE10494-ENG128079-Active noise reduction: configuration-mask_phase_result_FL_RR_1,NO_Mask ,31
IDE10494-ENG128081-Active noise reduction: configuration-mask_phase_result_FL_RR_2,NO_Mask ,31
IDE10494-ENG128083-Active noise reduction: configuration-mask_phase_result_FL_RR_3,NO_Mask ,31
IDE10494-ENG128097-Active noise reduction: configuration-mask_phase_result_FR_FL_1,NO_Mask ,31
IDE10494-ENG128099-Active noise reduction: configuration-mask_phase_result_FR_FL_2,NO_Mask ,31
IDE10494-ENG128101-Active noise reduction: configuration-mask_phase_result_FR_FL_3,NO_Mask ,31
IDE10494-ENG128103-Active noise reduction: configuration-mask_phase_result_FR_FR_1,NO_Mask ,31
IDE10494-ENG128105-Active noise reduction: configuration-mask_phase_result_FR_FR_2,NO_Mask ,31
IDE10494-ENG128107-Active noise reduction: configuration-mask_phase_result_FR_FR_3,NO_Mask ,31
IDE10494-ENG128121-Active noise reduction: configuration-mask_phase_result_FR_Mic5_1,NO_Mask ,31
IDE10494-ENG128123-Active noise reduction: configuration-mask_phase_result_FR_Mic5_2,NO_Mask ,31
IDE10494-ENG128125-Active noise reduction: configuration-mask_phase_result_FR_Mic5_3,NO_Mask ,31
IDE10494-ENG128127-Active noise reduction: configuration-mask_phase_result_FR_Mic6_1,NO_Mask ,31
IDE10494-ENG128129-Active noise reduction: configuration-mask_phase_result_FR_Mic6_2,NO_Mask ,31
IDE10494-ENG128131-Active noise reduction: configuration-mask_phase_result_FR_Mic6_3,NO_Mask ,31
IDE10494-ENG128109-Active noise reduction: configuration-mask_phase_result_FR_RL_1,NO_Mask ,31
IDE10494-ENG128111-Active noise reduction: configuration-mask_phase_result_FR_RL_2,NO_Mask ,31
IDE10494-ENG128113-Active noise reduction: configuration-mask_phase_result_FR_RL_3,NO_Mask ,31
IDE10494-ENG128115-Active noise reduction: configuration-mask_phase_result_FR_RR_1,NO_Mask ,31
IDE10494-ENG128117-Active noise reduction: configuration-mask_phase_result_FR_RR_2,NO_Mask ,31
IDE10494-ENG128119-Active noise reduction: configuration-mask_phase_result_FR_RR_3,NO_Mask ,31
IDE10494-ENG128133-Active noise reduction: configuration-mask_phase_result_RL_FL_1,NO_Mask ,31
IDE10494-ENG128135-Active noise reduction: configuration-mask_phase_result_RL_FL_2,NO_Mask ,31
IDE10494-ENG128137-Active noise reduction: configuration-mask_phase_result_RL_FL_3,NO_Mask ,31
IDE10494-ENG128139-Active noise reduction: configuration-mask_phase_result_RL_FR_1,NO_Mask ,31
IDE10494-ENG128141-Active noise reduction: configuration-mask_phase_result_RL_FR_2,NO_Mask ,31
IDE10494-ENG128143-Active noise reduction: configuration-mask_phase_result_RL_FR_3,NO_Mask ,31
IDE10494-ENG128157-Active noise reduction: configuration-mask_phase_result_RL_Mic5_1,NO_Mask ,31
IDE10494-ENG128159-Active noise reduction: configuration-mask_phase_result_RL_Mic5_2,NO_Mask ,31
IDE10494-ENG128161-Active noise reduction: configuration-mask_phase_result_RL_Mic5_3,NO_Mask ,31
IDE10494-ENG128163-Active noise reduction: configuration-mask_phase_result_RL_Mic6_1,NO_Mask ,31
IDE10494-ENG128165-Active noise reduction: configuration-mask_phase_result_RL_Mic6_2,NO_Mask ,31
IDE10494-ENG128167-Active noise reduction: configuration-mask_phase_result_RL_Mic6_3,NO_Mask ,31
IDE10494-ENG128145-Active noise reduction: configuration-mask_phase_result_RL_RL_1,NO_Mask ,31
IDE10494-ENG128147-Active noise reduction: configuration-mask_phase_result_RL_RL_2,NO_Mask ,31
IDE10494-ENG128149-Active noise reduction: configuration-mask_phase_result_RL_RL_3,NO_Mask ,31
IDE10494-ENG128151-Active noise reduction: configuration-mask_phase_result_RL_RR_1,NO_Mask ,31
IDE10494-ENG128153-Active noise reduction: configuration-mask_phase_result_RL_RR_2,NO_Mask ,31
IDE10494-ENG128155-Active noise reduction: configuration-mask_phase_result_RL_RR_3,NO_Mask ,31
IDE10494-ENG128169-Active noise reduction: configuration-mask_phase_result_RR_FL_1,NO_Mask ,31
IDE10494-ENG128171-Active noise reduction: configuration-mask_phase_result_RR_FL_2,NO_Mask ,31
IDE10494-ENG128173-Active noise reduction: configuration-mask_phase_result_RR_FL_3,NO_Mask ,31
IDE10494-ENG128175-Active noise reduction: configuration-mask_phase_result_RR_FR_1,NO_Mask ,31
IDE10494-ENG128177-Active noise reduction: configuration-mask_phase_result_RR_FR_2,NO_Mask ,31
IDE10494-ENG128179-Active noise reduction: configuration-mask_phase_result_RR_FR_3,NO_Mask ,31
IDE10494-ENG128193-Active noise reduction: configuration-mask_phase_result_RR_Mic5_1,NO_Mask ,31
IDE10494-ENG128195-Active noise reduction: configuration-mask_phase_result_RR_Mic5_2,NO_Mask ,31
IDE10494-ENG128197-Active noise reduction: configuration-mask_phase_result_RR_Mic5_3,NO_Mask ,31
IDE10494-ENG128199-Active noise reduction: configuration-mask_phase_result_RR_Mic6_1,NO_Mask ,31
IDE10494-ENG128201-Active noise reduction: configuration-mask_phase_result_RR_Mic6_2,NO_Mask ,31
IDE10494-ENG128203-Active noise reduction: configuration-mask_phase_result_RR_Mic6_3,NO_Mask ,31
IDE10494-ENG128181-Active noise reduction: configuration-mask_phase_result_RR_RL_1,NO_Mask ,31
IDE10494-ENG128183-Active noise reduction: configuration-mask_phase_result_RR_RL_2,NO_Mask ,31
IDE10494-ENG128185-Active noise reduction: configuration-mask_phase_result_RR_RL_3,NO_Mask ,31
IDE10494-ENG128187-Active noise reduction: configuration-mask_phase_result_RR_RR_1,NO_Mask ,31
IDE10494-ENG128189-Active noise reduction: configuration-mask_phase_result_RR_RR_2,NO_Mask ,31
IDE10494-ENG128191-Active noise reduction: configuration-mask_phase_result_RR_RR_3,NO_Mask ,31
IDE10494-ENG128205-Active noise reduction: configuration-mask_phase_result_Subw_FL_1,NO_Mask ,31
IDE10494-ENG128207-Active noise reduction: configuration-mask_phase_result_Subw_FL_2,NO_Mask ,31
IDE10494-ENG128209-Active noise reduction: configuration-mask_phase_result_Subw_FL_3,NO_Mask ,31
IDE10494-ENG128211-Active noise reduction: configuration-mask_phase_result_Subw_FR_1,NO_Mask ,31
IDE10494-ENG128213-Active noise reduction: configuration-mask_phase_result_Subw_FR_2,NO_Mask ,31
IDE10494-ENG128215-Active noise reduction: configuration-mask_phase_result_Subw_FR_3,NO_Mask ,31
IDE10494-ENG128229-Active noise reduction: configuration-mask_phase_result_Subw_Mic5_1,NO_Mask ,31
IDE10494-ENG128231-Active noise reduction: configuration-mask_phase_result_Subw_Mic5_2,NO_Mask ,31
IDE10494-ENG128233-Active noise reduction: configuration-mask_phase_result_Subw_Mic5_3,NO_Mask ,31
IDE10494-ENG128235-Active noise reduction: configuration-mask_phase_result_Subw_Mic6_1,NO_Mask ,31
IDE10494-ENG128237-Active noise reduction: configuration-mask_phase_result_Subw_Mic6_2,NO_Mask ,31
IDE10494-ENG128239-Active noise reduction: configuration-mask_phase_result_Subw_Mic6_3,NO_Mask ,31
IDE10494-ENG128217-Active noise reduction: configuration-mask_phase_result_Subw_RL_1,NO_Mask ,31
IDE10494-ENG128219-Active noise reduction: configuration-mask_phase_result_Subw_RL_2,NO_Mask ,31
IDE10494-ENG128221-Active noise reduction: configuration-mask_phase_result_Subw_RL_3,NO_Mask ,31
IDE10494-ENG128223-Active noise reduction: configuration-mask_phase_result_Subw_RR_1,NO_Mask ,31
IDE10494-ENG128225-Active noise reduction: configuration-mask_phase_result_Subw_RR_2,NO_Mask ,31
IDE10494-ENG128227-Active noise reduction: configuration-mask_phase_result_Subw_RR_3,NO_Mask ,31
IDE11104-MAS18803-FM tuner: mono/stereo setting-lower HF stereo threshold in dBµV,34 ,3
IDE11104-MAS18804-FM tuner: mono/stereo setting-Maximum NF stereo channel separation in dB,50 ,3
IDE11104-MAS18805-FM tuner: mono/stereo setting-lower HF stereo threshold in seconds,15.00 s,3
IDE11105-Brand-specific display of connect application, ,64
IDE11122-Country identification: country of sale HMI,TR ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,23
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked ,23
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,non_blocked ,23
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,23
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,23
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked ,23
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,non_blocked ,23
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,non_blocked ,23
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked ,23
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,blocked ,23
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,blocked ,23
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked ,23
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,23
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked ,23
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked ,23
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,non_blocked ,23
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked ,23
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,23
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,non_blocked ,23
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked ,23
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,non_blocked ,23
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,23
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked ,23
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,non_blocked ,23
IDE11502-ENG248673-Locked menu contents-FB_HELP_0,non_blocked ,23
IDE11502-ENG248674-Locked menu contents-FB_HELP_1,non_blocked ,23
IDE11502-ENG248675-Locked menu contents-FB_HELP_2,non_blocked ,23
IDE11502-ENG248676-Locked menu contents-FB_HELP_3,non_blocked ,23
IDE11502-ENG248677-Locked menu contents-FB_HELP_4,non_blocked ,23
IDE11502-ENG248678-Locked menu contents-FB_HELP_5,non_blocked ,23
IDE11502-ENG248679-Locked menu contents-FB_HELP_6,non_blocked ,23
IDE11502-ENG248680-Locked menu contents-FB_HELP_7,non_blocked ,23
IDE11502-ENG248681-Locked menu contents-FB_HELP_8,non_blocked ,23
IDE11502-ENG248682-Locked menu contents-FB_HELP_9,non_blocked ,23
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,blocked ,23
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,23
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,23
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,23
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,23
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,23
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked ,23
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,23
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked ,23
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked ,23
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked ,23
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,non_blocked ,23
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked ,23
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,non_blocked ,23
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked ,23
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked ,23
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked ,23
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,23
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked ,23
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,23
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked ,23
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,non_blocked ,23
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,23
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,23
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,23
IDE11502-ENG127626-Locked menu contents-FB_MISC_1,non_blocked ,23
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,23
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,23
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,23
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,23
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked ,23
IDE11502-ENG127640-Locked menu contents-FB_MISC_15,non_blocked ,23
IDE11502-ENG127641-Locked menu contents-FB_MISC_16,non_blocked ,23
IDE11502-ENG127642-Locked menu contents-FB_MISC_17,non_blocked ,23
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked ,23
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked ,23
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,blocked ,23
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,23
IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked ,23
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,23
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,blocked ,23
IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked ,23
IDE11502-ENG127650-Locked menu contents-FB_MISC_25,non_blocked ,23
IDE11502-ENG127651-Locked menu contents-FB_MISC_26,blocked ,23
IDE11502-ENG127652-Locked menu contents-FB_MISC_27,non_blocked ,23
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,blocked ,23
IDE11502-ENG127654-Locked menu contents-FB_MISC_29,non_blocked ,23
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,blocked ,23
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,blocked ,23
IDE11502-ENG127656-Locked menu contents-FB_MISC_31,non_blocked ,23
IDE11502-ENG127657-Locked menu contents-FB_MISC_32,non_blocked ,23
IDE11502-ENG127658-Locked menu contents-FB_MISC_33,non_blocked ,23
IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked ,23
IDE11502-ENG127660-Locked menu contents-FB_MISC_35,non_blocked ,23
IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked ,23
IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked ,23
IDE11502-ENG127663-Locked menu contents-FB_MISC_38,non_blocked ,23
IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked ,23
IDE11502-ENG127629-Locked menu contents-FB_MISC_4,non_blocked ,23
IDE11502-ENG127665-Locked menu contents-FB_MISC_40,non_blocked ,23
IDE11502-ENG127666-Locked menu contents-FB_MISC_41,non_blocked ,23
IDE11502-ENG127667-Locked menu contents-FB_MISC_42,non_blocked ,23
IDE11502-ENG127668-Locked menu contents-FB_MISC_43,non_blocked ,23
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked ,23
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,23
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,23
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,23
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,23
IDE11502-ENG127631-Locked menu contents-FB_MISC_6,non_blocked ,23
IDE11502-ENG127632-Locked menu contents-FB_MISC_7,non_blocked ,23
IDE11502-ENG127633-Locked menu contents-FB_MISC_8,non_blocked ,23
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked ,23
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,23
IDE11502-ENG127562-Locked menu contents-FB_NAV_1,non_blocked ,23
IDE11502-ENG127571-Locked menu contents-FB_NAV_10,non_blocked ,23
IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked ,23
IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked ,23
IDE11502-ENG127574-Locked menu contents-FB_NAV_13,non_blocked ,23
IDE11502-ENG127575-Locked menu contents-FB_NAV_14,non_blocked ,23
IDE11502-ENG127576-Locked menu contents-FB_NAV_15,non_blocked ,23
IDE11502-ENG127577-Locked menu contents-FB_NAV_16,non_blocked ,23
IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked ,23
IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked ,23
IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked ,23
IDE11502-ENG127563-Locked menu contents-FB_NAV_2,non_blocked ,23
IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked ,23
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,23
IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked ,23
IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked ,23
IDE11502-ENG127585-Locked menu contents-FB_NAV_24,non_blocked ,23
IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked ,23
IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked ,23
IDE11502-ENG127588-Locked menu contents-FB_NAV_27,non_blocked ,23
IDE11502-ENG127589-Locked menu contents-FB_NAV_28,non_blocked ,23
IDE11502-ENG127590-Locked menu contents-FB_NAV_29,non_blocked ,23
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,23
IDE11502-ENG127591-Locked menu contents-FB_NAV_30,non_blocked ,23
IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked ,23
IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked ,23
IDE11502-ENG127594-Locked menu contents-FB_NAV_33,non_blocked ,23
IDE11502-ENG127595-Locked menu contents-FB_NAV_34,non_blocked ,23
IDE11502-ENG127596-Locked menu contents-FB_NAV_35,non_blocked ,23
IDE11502-ENG127597-Locked menu contents-FB_NAV_36,non_blocked ,23
IDE11502-ENG127598-Locked menu contents-FB_NAV_37,non_blocked ,23
IDE11502-ENG127599-Locked menu contents-FB_NAV_38,non_blocked ,23
IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked ,23
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,23
IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked ,23
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,23
IDE11502-ENG127568-Locked menu contents-FB_NAV_7,non_blocked ,23
IDE11502-ENG127569-Locked menu contents-FB_NAV_8,non_blocked ,23
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,23
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,23
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,non_blocked ,23
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,non_blocked ,23
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked ,23
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,non_blocked ,23
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked ,23
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,non_blocked ,23
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,non_blocked ,23
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,non_blocked ,23
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked ,23
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked ,23
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,23
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,23
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,23
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,non_blocked ,23
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,non_blocked ,23
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked ,23
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked ,23
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked ,23
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked ,23
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,non_blocked ,23
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,non_blocked ,23
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked ,23
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,non_blocked ,23
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,non_blocked ,23
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,23
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,23
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,23
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked ,23
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,23
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked ,23
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked ,23
IDE11638-Bluetooth Audio Codec,FF ,1
IDE12364-ENG122340-Head-Up-Display: configuration-crossroad_detail_map_compression_mode,RLE ,3
IDE12364-ENG122344-Head-Up-Display: configuration-crossroad_detail_map_resolution,0 ,3
IDE12364-ENG127006-Head-Up-Display: configuration-crossroad_detail_map_transmission_mode,OFF ,3
IDE14012-MAS18497-Ethernet: configuration-Ethernet activation: branch 1,slave ,2
IDE14012-MAS18498-Ethernet: configuration-Ethernet activation: branch 2,Deactivated ,2
IDE14012-MAS18499-Ethernet: configuration-Ethernet activation: branch 3,Deactivated ,2
IDE14012-MAS18500-Ethernet: configuration-Ethernet activation: branch 4,Deactivated ,2
IDE14729-ENG258620-Automotive audio bus (A2B): function configuration-ANC_microphone_FL_bus_number,0 ,22
IDE14729-ENG260754-Automotive audio bus (A2B): function configuration-ANC_microphone_FL_channel_uplink_high,0 ,22
IDE14729-ENG258987-Automotive audio bus (A2B): function configuration-ANC_microphone_FL_channel_uplink_low,0 ,22
IDE14729-ENG259482-Automotive audio bus (A2B): function configuration-ANC_microphone_FL_downlink_availability,OFF ,22
IDE14729-ENG260069-Automotive audio bus (A2B): function configuration-ANC_microphone_FL_uplink_availability,OFF ,22
IDE14729-ENG259265-Automotive audio bus (A2B): function configuration-ANC_microphone_FR_bus_number,0 ,22
IDE14729-ENG260504-Automotive audio bus (A2B): function configuration-ANC_microphone_FR_channel_uplink_high,0 ,22
IDE14729-ENG260890-Automotive audio bus (A2B): function configuration-ANC_microphone_FR_channel_uplink_low,0 ,22
IDE14729-ENG258681-Automotive audio bus (A2B): function configuration-ANC_microphone_FR_downlink_availability,OFF ,22
IDE14729-ENG258531-Automotive audio bus (A2B): function configuration-ANC_microphone_FR_uplink_availability,OFF ,22
IDE14729-ENG259867-Automotive audio bus (A2B): function configuration-ANC_microphone_RL_bus_number,0 ,22
IDE14729-ENG259148-Automotive audio bus (A2B): function configuration-ANC_microphone_RL_channel_uplink_high,0 ,22
IDE14729-ENG258419-Automotive audio bus (A2B): function configuration-ANC_microphone_RL_channel_uplink_low,0 ,22
IDE14729-ENG259263-Automotive audio bus (A2B): function configuration-ANC_microphone_RL_downlink_availability,OFF ,22
IDE14729-ENG260988-Automotive audio bus (A2B): function configuration-ANC_microphone_RL_uplink_availability,OFF ,22
IDE14729-ENG259725-Automotive audio bus (A2B): function configuration-ANC_microphone_RR_bus_number,0 ,22
IDE14729-ENG260426-Automotive audio bus (A2B): function configuration-ANC_microphone_RR_channel_uplink_high,0 ,22
IDE14729-ENG260243-Automotive audio bus (A2B): function configuration-ANC_microphone_RR_channel_uplink_low,0 ,22
IDE14729-ENG260582-Automotive audio bus (A2B): function configuration-ANC_microphone_RR_downlink_availability,OFF ,22
IDE14729-ENG260045-Automotive audio bus (A2B): function configuration-ANC_microphone_RR_uplink_availability,OFF ,22
IDE14729-ENG258744-Automotive audio bus (A2B): function configuration-Booster_bus_number,1 ,22
IDE14729-ENG261041-Automotive audio bus (A2B): function configuration-Booster_channel_uplink_high,14 ,22
IDE14729-ENG259938-Automotive audio bus (A2B): function configuration-Booster_channel_uplink_low,6 ,22
IDE14729-ENG258241-Automotive audio bus (A2B): function configuration-Booster_downlink_availability,OFF ,22
IDE14729-ENG260543-Automotive audio bus (A2B): function configuration-Booster_uplink_availability,OFF ,22
IDE14729-ENG258951-Automotive audio bus (A2B): function configuration-Con_Box_bus_number,1 ,22
IDE14729-ENG261246-Automotive audio bus (A2B): function configuration-Con_Box_channel_uplink_high,5 ,22
IDE14729-ENG259052-Automotive audio bus (A2B): function configuration-Con_Box_channel_uplink_low,0 ,22
IDE14729-ENG260513-Automotive audio bus (A2B): function configuration-Con_Box_downlink_availability,On ,22
IDE14729-ENG260873-Automotive audio bus (A2B): function configuration-Con_Box_uplink_availability,On ,22
IDE14729-ENG281991-Automotive audio bus (A2B): function configuration-OCU4_bus_number,0 ,22
IDE14729-ENG282001-Automotive audio bus (A2B): function configuration-OCU4_channel_uplink_high,0 ,22
IDE14729-ENG281909-Automotive audio bus (A2B): function configuration-OCU4_channel_uplink_low,0 ,22
IDE14729-ENG282039-Automotive audio bus (A2B): function configuration-OCU4_downlink_availability,OFF ,22
IDE14729-ENG281931-Automotive audio bus (A2B): function configuration-OCU4_uplink_availability,OFF ,22
IDE14729-ENG260986-Automotive audio bus (A2B): function configuration-PASD_bus_number,0 ,22
IDE14729-ENG258579-Automotive audio bus (A2B): function configuration-PASD_channel_uplink_high,0 ,22
IDE14729-ENG261104-Automotive audio bus (A2B): function configuration-PASD_channel_uplink_low,0 ,22
IDE14729-ENG259739-Automotive audio bus (A2B): function configuration-PASD_downlink_availability,OFF ,22
IDE14729-ENG261262-Automotive audio bus (A2B): function configuration-PASD_uplink_availability,OFF ,22
IDE14730-ENG258862-Automotive audio bus (A2B): diagnostic configuration bus 1-discovery_type,optimized ,10
IDE14730-ENG185820-Automotive audio bus (A2B): diagnostic configuration bus 1-Master,activated ,10
IDE14730-ENG261149-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _1,Emergency call module and communication unit ,10
IDE14730-ENG260380-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _2,Deactivated ,10
IDE14730-ENG260854-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _3,Deactivated ,10
IDE14730-ENG259870-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _4,Deactivated ,10
IDE14730-ENG260765-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _5,Deactivated ,10
IDE14730-ENG258502-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _6,Deactivated ,10
IDE14730-ENG261272-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _7,Deactivated ,10
IDE14730-ENG261221-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _8,Deactivated ,10
IDE14730-ENG259340-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _9,Deactivated ,10
IDE15222-ENG259093-Configuration of DK1 components-capacitive_volume_knob,not activated ,3
IDE15222-ENG260047-Configuration of DK1 components-display_audio_feedback,Display_speaker ,3
IDE15222-ENG260185-Configuration of DK1 components-shutter_foil,not activated ,3
IDE15335-ENG253480-Vehicle name information electronics-default_value_prefix_MMI_name,Audi_MMI_ ,42
IDE15335-ENG253482-Vehicle name information electronics-Postfix_2.4_GHz_SSID, ,42
IDE15335-ENG253481-Vehicle name information electronics-Postfix_5_GHz_SSID,_5GHz ,42
IDE15361-ENG259850-WLAN settings-2.4_GHz_max_channel_bandwidth,20_MHz ,7
IDE15361-ENG260321-WLAN settings-2.4_GHz_visibility,activated ,7
IDE15361-ENG258978-WLAN settings-5_GHz_max_channel_bandwidth,80_MHz ,7
IDE15361-ENG258896-WLAN settings-5_ghz_visibility,activated ,7
IDE15361-ENG248412-WLAN settings-5_ghz_wlan,On ,7
IDE15361-ENG248626-WLAN settings-channel_number_for_2_4GHz,6 ,7
IDE15361-ENG248627-WLAN settings-channel_number_for_5GHz,0 ,7
IDE15361-ENG253479-WLAN settings-DHCP_lease_time,72 H,7
IDE15361-ENG261211-WLAN settings-internet_over_WLAN_default_setting,activated ,7
IDE15361-ENG260341-WLAN settings-location_of_BT_WLAN_chip,active ,7
IDE15361-ENG259649-WLAN settings-WLAN_password_sync,Synchronized ,7
IDE15362-ENG253478-Smartphone configuration-Apple_car_play_wireless,On ,3
IDE15362-ENG185765-Smartphone configuration-Baidu_Car_Life_ios_Wireless,OFF ,3
IDE15362-ENG185766-Smartphone configuration-Baidu_Car_Life_Wireless,OFF ,3
IDE15362-ENG253483-Smartphone configuration-Google_android_auto_wireless,On ,3
IDE15387-ENG259927-Settings for navigation with e-vehicles-Built_In_Booster,0 kW,10
IDE15387-ENG259118-Settings for navigation with e-vehicles-Charging_Time_Factor,0 ,10
IDE15387-ENG258929-Settings for navigation with e-vehicles-Charging_Time_Offset,0 min,10
IDE15387-ENG259085-Settings for navigation with e-vehicles-Max_Battery_Ampere,0 A,10
IDE15387-ENG259058-Settings for navigation with e-vehicles-Max_Battery_Voltage,0 V,10
IDE15387-ENG261213-Settings for navigation with e-vehicles-Range_Assurance_Level_1_NumChargers,0 ,10
IDE15387-ENG259231-Settings for navigation with e-vehicles-Range_Assurance_Level_1_SOC,0 %,10
IDE15387-ENG258257-Settings for navigation with e-vehicles-Range_Assurance_Level_2_NumChargers,0 ,10
IDE15387-ENG259808-Settings for navigation with e-vehicles-Range_Assurance_Level_2_SOC,0 %,10
IDE15947-Back end configuration,1 ,1
ENG117918-ENG117811-Audio_Management_Audio_Delay_Lines-Amplifier_Delay_On_Off,On ,12
ENG117918-ENG117813-Audio_Management_Audio_Delay_Lines-Amplifier_Delay_Time,0 ms,12
ENG117918-ENG126188-Audio_Management_Audio_Delay_Lines-Headphone_Delay_On_Off,OFF ,12
ENG117918-ENG126189-Audio_Management_Audio_Delay_Lines-Headphone_Delay_Time,0 ms,12
ENG117918-ENG126190-Audio_Management_Audio_Delay_Lines-Headphone_wireless_Delay_On_Off,OFF ,12
ENG117918-ENG126191-Audio_Management_Audio_Delay_Lines-Headphone_wireless_Delay_Time,0 ms,12
ENG117918-ENG117810-Audio_Management_Audio_Delay_Lines-Main_Unit_Delay_On_Off,On ,12
ENG117918-ENG117812-Audio_Management_Audio_Delay_Lines-Main_Unit_Delay_Time,0 ms,12
ENG264032-ENG264184-Automotive_audio_bus_configuration_EMC_bus-Master_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264185-Automotive_audio_bus_configuration_EMC_bus-Master_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264186-Automotive_audio_bus_configuration_EMC_bus-Master_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264187-Automotive_audio_bus_configuration_EMC_bus-Master_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264188-Automotive_audio_bus_configuration_EMC_bus-Master_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264208-Automotive_audio_bus_configuration_EMC_bus-Slave_1_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264209-Automotive_audio_bus_configuration_EMC_bus-Slave_1_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264210-Automotive_audio_bus_configuration_EMC_bus-Slave_1_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264211-Automotive_audio_bus_configuration_EMC_bus-Slave_1_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264212-Automotive_audio_bus_configuration_EMC_bus-Slave_1_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264213-Automotive_audio_bus_configuration_EMC_bus-Slave_1_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264214-Automotive_audio_bus_configuration_EMC_bus-Slave_1_TXBCTL_TXBOVREN,Disable ,29
ENG264032-ENG264215-Automotive_audio_bus_configuration_EMC_bus-Slave_2_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264216-Automotive_audio_bus_configuration_EMC_bus-Slave_2_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264217-Automotive_audio_bus_configuration_EMC_bus-Slave_2_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264218-Automotive_audio_bus_configuration_EMC_bus-Slave_2_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264219-Automotive_audio_bus_configuration_EMC_bus-Slave_2_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264220-Automotive_audio_bus_configuration_EMC_bus-Slave_2_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264221-Automotive_audio_bus_configuration_EMC_bus-Slave_2_TXBCTL_TXBOVREN,Disable ,29
ENG264032-ENG264222-Automotive_audio_bus_configuration_EMC_bus-Slave_3_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264223-Automotive_audio_bus_configuration_EMC_bus-Slave_3_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264224-Automotive_audio_bus_configuration_EMC_bus-Slave_3_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264225-Automotive_audio_bus_configuration_EMC_bus-Slave_3_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264226-Automotive_audio_bus_configuration_EMC_bus-Slave_3_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264227-Automotive_audio_bus_configuration_EMC_bus-Slave_3_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264228-Automotive_audio_bus_configuration_EMC_bus-Slave_3_TXBCTL_TXBOVREN,Disable ,29
ENG264032-ENG264229-Automotive_audio_bus_configuration_EMC_bus-Slave_4_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264230-Automotive_audio_bus_configuration_EMC_bus-Slave_4_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264231-Automotive_audio_bus_configuration_EMC_bus-Slave_4_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264232-Automotive_audio_bus_configuration_EMC_bus-Slave_4_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264233-Automotive_audio_bus_configuration_EMC_bus-Slave_4_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264234-Automotive_audio_bus_configuration_EMC_bus-Slave_4_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264235-Automotive_audio_bus_configuration_EMC_bus-Slave_4_TXBCTL_TXBOVREN,Disable ,29
ENG264032-ENG264236-Automotive_audio_bus_configuration_EMC_bus-Slave_5_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264237-Automotive_audio_bus_configuration_EMC_bus-Slave_5_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264238-Automotive_audio_bus_configuration_EMC_bus-Slave_5_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264239-Automotive_audio_bus_configuration_EMC_bus-Slave_5_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264240-Automotive_audio_bus_configuration_EMC_bus-Slave_5_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264241-Automotive_audio_bus_configuration_EMC_bus-Slave_5_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264242-Automotive_audio_bus_configuration_EMC_bus-Slave_5_TXBCTL_TXBOVREN,Disable ,29
ENG264032-ENG264243-Automotive_audio_bus_configuration_EMC_bus-Slave_6_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264244-Automotive_audio_bus_configuration_EMC_bus-Slave_6_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264245-Automotive_audio_bus_configuration_EMC_bus-Slave_6_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264246-Automotive_audio_bus_configuration_EMC_bus-Slave_6_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264247-Automotive_audio_bus_configuration_EMC_bus-Slave_6_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264248-Automotive_audio_bus_configuration_EMC_bus-Slave_6_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264249-Automotive_audio_bus_configuration_EMC_bus-Slave_6_TXBCTL_TXBOVREN,Disable ,29
ENG264032-ENG264250-Automotive_audio_bus_configuration_EMC_bus-Slave_7_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264251-Automotive_audio_bus_configuration_EMC_bus-Slave_7_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264252-Automotive_audio_bus_configuration_EMC_bus-Slave_7_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264253-Automotive_audio_bus_configuration_EMC_bus-Slave_7_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264254-Automotive_audio_bus_configuration_EMC_bus-Slave_7_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264255-Automotive_audio_bus_configuration_EMC_bus-Slave_7_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264256-Automotive_audio_bus_configuration_EMC_bus-Slave_7_TXBCTL_TXBOVREN,Disable ,29
ENG264032-ENG264257-Automotive_audio_bus_configuration_EMC_bus-Slave_8_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264258-Automotive_audio_bus_configuration_EMC_bus-Slave_8_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264259-Automotive_audio_bus_configuration_EMC_bus-Slave_8_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264260-Automotive_audio_bus_configuration_EMC_bus-Slave_8_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264261-Automotive_audio_bus_configuration_EMC_bus-Slave_8_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264262-Automotive_audio_bus_configuration_EMC_bus-Slave_8_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264263-Automotive_audio_bus_configuration_EMC_bus-Slave_8_TXBCTL_TXBOVREN,Disable ,29
ENG264032-ENG264264-Automotive_audio_bus_configuration_EMC_bus-Slave_9_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264265-Automotive_audio_bus_configuration_EMC_bus-Slave_9_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264266-Automotive_audio_bus_configuration_EMC_bus-Slave_9_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264267-Automotive_audio_bus_configuration_EMC_bus-Slave_9_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264268-Automotive_audio_bus_configuration_EMC_bus-Slave_9_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264269-Automotive_audio_bus_configuration_EMC_bus-Slave_9_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264270-Automotive_audio_bus_configuration_EMC_bus-Slave_9_TXBCTL_TXBOVREN,Disable ,29
ENG277053-ENG273739-battery_charging_curve-Charging_power_01,0 ,30
ENG277053-ENG273716-battery_charging_curve-Charging_power_02,0 ,30
ENG277053-ENG273749-battery_charging_curve-Charging_power_03,0 ,30
ENG277053-ENG273698-battery_charging_curve-Charging_power_04,0 ,30
ENG277053-ENG273834-battery_charging_curve-Charging_power_05,0 ,30
ENG277053-ENG273839-battery_charging_curve-Charging_power_06,0 ,30
ENG277053-ENG273868-battery_charging_curve-Charging_power_07,0 ,30
ENG277053-ENG273719-battery_charging_curve-Charging_power_08,0 ,30
ENG277053-ENG273828-battery_charging_curve-Charging_power_09,0 ,30
ENG277053-ENG273624-battery_charging_curve-Charging_power_10,0 ,30
ENG277053-ENG273852-battery_charging_curve-Soc_01,0 ,30
ENG277053-ENG273701-battery_charging_curve-Soc_02,0 ,30
ENG277053-ENG273861-battery_charging_curve-Soc_03,0 ,30
ENG277053-ENG273825-battery_charging_curve-Soc_04,0 ,30
ENG277053-ENG273654-battery_charging_curve-Soc_05,0 ,30
ENG277053-ENG273816-battery_charging_curve-Soc_06,0 ,30
ENG277053-ENG273836-battery_charging_curve-Soc_07,0 ,30
ENG277053-ENG273870-battery_charging_curve-Soc_08,0 ,30
ENG277053-ENG273677-battery_charging_curve-Soc_09,0 ,30
ENG277053-ENG273801-battery_charging_curve-Soc_10,0 ,30
ENG248422-ENG248496-calendar_reminder-acoustic_reminder,OFF ,1
ENG248422-ENG248696-calendar_reminder-haptic_reminder,OFF ,1
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,No ,8
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,MOST ,8
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,OFF ,8
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,0 ,8
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,LVDS_map_FPK ,8
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon,MOST ,8
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,RLE ,8
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,0 ,8
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,LVDS_map_FPK ,8
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,OFF ,8
ENG152376-ENG101574-Dimming_ambient_illumination_for_volume_control-X1,0 ,6
ENG152376-ENG99557-Dimming_ambient_illumination_for_volume_control-X2,100 ,6
ENG152376-ENG102140-Dimming_ambient_illumination_for_volume_control-X3,50 ,6
ENG152376-ENG99777-Dimming_ambient_illumination_for_volume_control-Y1,50 %,6
ENG152376-ENG100480-Dimming_ambient_illumination_for_volume_control-Y2,0 %,6
ENG152376-ENG100773-Dimming_ambient_illumination_for_volume_control-Y3,100 %,6
ENG152377-ENG101574-Dimming_illumination_for_display_unit_1_for_multimedia_system-X1,0 ,18
ENG152377-ENG99557-Dimming_illumination_for_display_unit_1_for_multimedia_system-X2,100 ,18
ENG152377-ENG102140-Dimming_illumination_for_display_unit_1_for_multimedia_system-X3,253 ,18
ENG152377-ENG102936-Dimming_illumination_for_display_unit_1_for_multimedia_system-X4,2 ,18
ENG152377-ENG103548-Dimming_illumination_for_display_unit_1_for_multimedia_system-X5,28 ,18
ENG152377-ENG113992-Dimming_illumination_for_display_unit_1_for_multimedia_system-X6,255 ,18
ENG152377-ENG99777-Dimming_illumination_for_display_unit_1_for_multimedia_system-Y1,774.0 %,18
ENG152377-ENG100480-Dimming_illumination_for_display_unit_1_for_multimedia_system-Y2,3865.3 %,18
ENG152377-ENG100773-Dimming_illumination_for_display_unit_1_for_multimedia_system-Y3,6502.1 %,18
ENG152377-ENG100631-Dimming_illumination_for_display_unit_1_for_multimedia_system-Y4,103.6 %,18
ENG152377-ENG102174-Dimming_illumination_for_display_unit_1_for_multimedia_system-Y5,1996.7 %,18
ENG152377-ENG113993-Dimming_illumination_for_display_unit_1_for_multimedia_system-Y6,6553.5 %,18
ENG152378-ENG101574-Dimming_illumination_for_display_unit_2_for_multimedia_system-X1,0 ,18
ENG152378-ENG99557-Dimming_illumination_for_display_unit_2_for_multimedia_system-X2,100 ,18
ENG152378-ENG102140-Dimming_illumination_for_display_unit_2_for_multimedia_system-X3,253 ,18
ENG152378-ENG102936-Dimming_illumination_for_display_unit_2_for_multimedia_system-X4,2 ,18
ENG152378-ENG103548-Dimming_illumination_for_display_unit_2_for_multimedia_system-X5,28 ,18
ENG152378-ENG113992-Dimming_illumination_for_display_unit_2_for_multimedia_system-X6,255 ,18
ENG152378-ENG99777-Dimming_illumination_for_display_unit_2_for_multimedia_system-Y1,774.0 %,18
ENG152378-ENG100480-Dimming_illumination_for_display_unit_2_for_multimedia_system-Y2,3865.3 %,18
ENG152378-ENG100773-Dimming_illumination_for_display_unit_2_for_multimedia_system-Y3,6502.1 %,18
ENG152378-ENG100631-Dimming_illumination_for_display_unit_2_for_multimedia_system-Y4,103.6 %,18
ENG152378-ENG102174-Dimming_illumination_for_display_unit_2_for_multimedia_system-Y5,1996.7 %,18
ENG152378-ENG113993-Dimming_illumination_for_display_unit_2_for_multimedia_system-Y6,6553.5 %,18
ENG122933-ENG248643-error_mask-dtc_dfcc_1,00 00 00 ,30
ENG122933-ENG248644-error_mask-dtc_dfcc_10,00 00 00 ,30
ENG122933-ENG248645-error_mask-dtc_dfcc_2,00 00 00 ,30
ENG122933-ENG248646-error_mask-dtc_dfcc_3,00 00 00 ,30
ENG122933-ENG248647-error_mask-dtc_dfcc_4,00 00 00 ,30
ENG122933-ENG248648-error_mask-dtc_dfcc_5,00 00 00 ,30
ENG122933-ENG248649-error_mask-dtc_dfcc_6,00 00 00 ,30
ENG122933-ENG248650-error_mask-dtc_dfcc_7,00 00 00 ,30
ENG122933-ENG248651-error_mask-dtc_dfcc_8,00 00 00 ,30
ENG122933-ENG248652-error_mask-dtc_dfcc_9,00 00 00 ,30
ENG248427-ENG248668-exit_screen_configuration-exit_screen,not activated ,2
ENG248427-ENG248669-exit_screen_configuration-exit_screen_length_of_time,0 ms,2
ENG262676-ENG262680-function_configuration_AED-debbug_trace_profile,0 ,18
ENG262676-ENG262691-function_configuration_AED-shutdown_timer,0 ,18
ENG262676-ENG262692-function_configuration_AED-suspend_2_RAM_timer,0 ,18
ENG262676-ENG262693-function_configuration_AED-temperature_profile,0 ,18
ENG248428-ENG248528-function_configuration_audio-channel_1_HT,installed ,10
ENG248428-ENG248530-function_configuration_audio-channel_1_TT,installed ,10
ENG248428-ENG248532-function_configuration_audio-channel_10_HT,not installed ,10
ENG248428-ENG248534-function_configuration_audio-channel_10_TT,not installed ,10
ENG248428-ENG248536-function_configuration_audio-channel_11_HT,not installed ,10
ENG248428-ENG248538-function_configuration_audio-channel_11_TT,not installed ,10
ENG248428-ENG248540-function_configuration_audio-channel_12_HT,not installed ,10
ENG248428-ENG248542-function_configuration_audio-channel_12_TT,not installed ,10
ENG248428-ENG248544-function_configuration_audio-channel_13_HT,not installed ,10
ENG248428-ENG248546-function_configuration_audio-channel_13_TT,not installed ,10
ENG248428-ENG248548-function_configuration_audio-channel_14_HT,not installed ,10
ENG248428-ENG248550-function_configuration_audio-channel_14_TT,not installed ,10
ENG248428-ENG248552-function_configuration_audio-channel_15_HT,not installed ,10
ENG248428-ENG248554-function_configuration_audio-channel_15_TT,not installed ,10
ENG248428-ENG248556-function_configuration_audio-channel_16_HT,not installed ,10
ENG248428-ENG248558-function_configuration_audio-channel_16_TT,not installed ,10
ENG248428-ENG248560-function_configuration_audio-channel_17_HT,not installed ,10
ENG248428-ENG248562-function_configuration_audio-channel_17_TT,not installed ,10
ENG248428-ENG248564-function_configuration_audio-channel_18_HT,not installed ,10
ENG248428-ENG248566-function_configuration_audio-channel_18_TT,not installed ,10
ENG248428-ENG248568-function_configuration_audio-channel_19_HT,not installed ,10
ENG248428-ENG248571-function_configuration_audio-channel_19TT,not installed ,10
ENG248428-ENG248572-function_configuration_audio-channel_2_HT,installed ,10
ENG248428-ENG248574-function_configuration_audio-channel_2_TT,installed ,10
ENG248428-ENG248576-function_configuration_audio-channel_20_HT,not installed ,10
ENG248428-ENG248578-function_configuration_audio-channel_20_TT,not installed ,10
ENG248428-ENG248580-function_configuration_audio-channel_21_HT,not installed ,10
ENG248428-ENG248582-function_configuration_audio-channel_21_TT,not installed ,10
ENG248428-ENG248584-function_configuration_audio-channel_22_HT,not installed ,10
ENG248428-ENG248586-function_configuration_audio-channel_22_TT,not installed ,10
ENG248428-ENG248588-function_configuration_audio-channel_23_HT,not installed ,10
ENG248428-ENG248590-function_configuration_audio-channel_23_TT,not installed ,10
ENG248428-ENG248592-function_configuration_audio-channel_24_HT,not installed ,10
ENG248428-ENG248594-function_configuration_audio-channel_24_TT,not installed ,10
ENG248428-ENG248596-function_configuration_audio-channel_25_HT,not installed ,10
ENG248428-ENG248597-function_configuration_audio-channel_25_TT,not installed ,10
ENG248428-ENG248598-function_configuration_audio-channel_3_HT,installed ,10
ENG248428-ENG248600-function_configuration_audio-channel_3_TT,installed ,10
ENG248428-ENG248602-function_configuration_audio-channel_4_HT,installed ,10
ENG248428-ENG248604-function_configuration_audio-channel_4_TT,installed ,10
ENG248428-ENG248606-function_configuration_audio-channel_5_HT,not installed ,10
ENG248428-ENG248608-function_configuration_audio-channel_5_TT,installed ,10
ENG248428-ENG248610-function_configuration_audio-channel_6_HT,not installed ,10
ENG248428-ENG248612-function_configuration_audio-channel_6_TT,installed ,10
ENG248428-ENG248614-function_configuration_audio-channel_7_HT,not installed ,10
ENG248428-ENG248616-function_configuration_audio-channel_7_TT,not installed ,10
ENG248428-ENG248618-function_configuration_audio-channel_8_HT,not installed ,10
ENG248428-ENG248620-function_configuration_audio-channel_8_TT,not installed ,10
ENG248428-ENG248622-function_configuration_audio-channel_9_HT,not installed ,10
ENG248428-ENG248624-function_configuration_audio-channel_9_TT,not installed ,10
ENG248428-ENG248653-function_configuration_audio-Early_engine_sound,OFF ,10
ENG248428-ENG248491-function_configuration_audio-microphone_1,not installed ,10
ENG248428-ENG248492-function_configuration_audio-microphone_2,not installed ,10
ENG248428-ENG248763-function_configuration_audio-microphone_3,not installed ,10
ENG248428-ENG248764-function_configuration_audio-microphone_4,not installed ,10
ENG248428-ENG252056-function_configuration_audio-microphones_ANC,not installed ,10
ENG248428-ENG248818-function_configuration_audio-Signal_flow_topology,00 ,10
ENG248428-ENG248483-function_configuration_audio-Sound_system,internal ,10
ENG248428-ENG248830-function_configuration_audio-welcome_sound,OFF ,10
ENG248429-ENG248511-function_configuration_car-bap_online_functions,On ,2
ENG248429-ENG248512-function_configuration_car-bap_sds_sd,OFF ,2
ENG248429-ENG142151-function_configuration_car-conditioning_variant,0 ,2
ENG248429-ENG248635-function_configuration_car-dashboard_connection,BAP ,2
ENG248430-ENG248504-function_configuration_connectivity-app_connect_over_wifi,Yes ,6
ENG248430-ENG248506-function_configuration_connectivity-apple_car_play,On ,6
ENG248430-ENG152525-function_configuration_connectivity-Baidu_Car_Life,OFF ,6
ENG248430-ENG152559-function_configuration_connectivity-Baidu_Car_Life_ios,OFF ,6
ENG248430-ENG248518-function_configuration_connectivity-Bluetooth_Audio,available. ,6
ENG248430-ENG248519-function_configuration_connectivity-Bluetooth_Availability,available_with_low_energy ,6
ENG248430-ENG248520-function_configuration_connectivity-Bluetooth_Headphones,Not available ,6
ENG248430-ENG248521-function_configuration_connectivity-Bluetooth_Multimedia_Functionality,available. ,6
ENG248430-ENG248522-function_configuration_connectivity-Bluetooth_Phone,available. ,6
ENG248430-ENG183597-function_configuration_connectivity-Bluetooth_visibility,On ,6
ENG248430-ENG248525-function_configuration_connectivity-calendar_via_ctn,OFF ,6
ENG248430-ENG248672-function_configuration_connectivity-external_wlan_antenna,none ,6
ENG248430-ENG248693-function_configuration_connectivity-google_android_auto,On ,6
ENG248430-ENG248761-function_configuration_connectivity-messaging_pagewise_scrolling,installed ,6
ENG248430-ENG248762-function_configuration_connectivity-messaging_via_map,installed ,6
ENG248430-ENG138662-function_configuration_connectivity-Mirror_link,On ,6
ENG248430-ENG248766-function_configuration_connectivity-mirror_link_country_code,EU ,6
ENG248430-ENG142150-function_configuration_connectivity-MirrorLink_RGB_Preference,RGB565 ,6
ENG248430-ENG127495-function_configuration_connectivity-online_media,OFF ,6
ENG248430-ENG101416-function_configuration_connectivity-Reserved_1,OFF ,6
ENG248430-ENG99458-function_configuration_connectivity-Reserved_2,not installed ,6
ENG248430-ENG248826-function_configuration_connectivity-viwi_access_mode,no_restriction ,6
ENG248430-ENG248827-function_configuration_connectivity-viwi_function,not installed ,6
ENG248430-ENG252048-function_configuration_connectivity-welink,OFF ,6
ENG248430-ENG248831-function_configuration_connectivity-wifi_client_mode_2_GHz,OFF ,6
ENG248430-ENG248832-function_configuration_connectivity-wifi_client_mode_5GHz,On ,6
ENG248430-ENG248833-function_configuration_connectivity-WIFI_Hotspot_2_4GHz,On ,6
ENG248430-ENG248834-function_configuration_connectivity-WIFI_Hotspot_5GHz,On ,6
ENG248430-ENG248835-function_configuration_connectivity-wlan_aps_to_ccu_routing,On ,6
ENG248430-ENG248836-function_configuration_connectivity-wlan_module,activated ,6
ENG248430-ENG248837-function_configuration_connectivity-wlan_tethering_connection_check_via_disgnosis,OFF ,6
ENG253093-ENG152554-function_configuration_connectivity_extended-Phone_HMI_Privacy,0 ,5
ENG253093-ENG152555-function_configuration_connectivity_extended-Privacy_WithPINRequest,0 ,5
ENG253093-ENG152556-function_configuration_connectivity_extended-scon_telephony,OFF ,5
ENG248431-ENG248699-function_configuration_hmi-helpcontext_0,OFF ,5
ENG248431-ENG248700-function_configuration_hmi-helpcontext_1,OFF ,5
ENG248431-ENG248701-function_configuration_hmi-helpcontext_2,OFF ,5
ENG248431-ENG248702-function_configuration_hmi-helpcontext_3,OFF ,5
ENG248431-ENG248703-function_configuration_hmi-helpcontext_4,OFF ,5
ENG248431-ENG248704-function_configuration_hmi-helpcontext_5,OFF ,5
ENG248431-ENG248705-function_configuration_hmi-helpcontext_6,OFF ,5
ENG248431-ENG248706-function_configuration_hmi-helpcontext_7,OFF ,5
ENG248431-ENG248707-function_configuration_hmi-helpcontext_8,OFF ,5
ENG248431-ENG248708-function_configuration_hmi-helpcontext_9,OFF ,5
ENG248431-ENG248709-function_configuration_hmi-hmi_initial_disclaimer,OFF ,5
ENG248431-ENG248710-function_configuration_hmi-hmi_legal_disclaimer,OFF ,5
ENG248431-ENG248725-function_configuration_hmi-log_book,not_displayed ,5
ENG248431-ENG167525-function_configuration_hmi-Popup_if_GPS_services_in_use,OFF ,5
ENG248431-ENG248811-function_configuration_hmi-screenings,0 ,5
ENG248431-ENG248479-function_configuration_hmi-Skinning,0 ,5
ENG248431-ENG248821-function_configuration_hmi-speller,OFF ,5
ENG248432-ENG248505-function_configuration_media-app_start_automatically_on_customer_device,On ,3
ENG248432-ENG248481-function_configuration_media-aux_in,OFF ,3
ENG248432-ENG248671-function_configuration_media-external_cd_drive,OFF ,3
ENG248432-ENG249899-function_configuration_media-external_tv_tuner,OFF ,3
ENG248432-ENG117850-function_configuration_media-gracenote_local_coverarts,On ,3
ENG248432-ENG117851-function_configuration_media-gracenote_local_other,On ,3
ENG248432-ENG117848-function_configuration_media-gracenote_online_coverarts,OFF ,3
ENG248432-ENG117849-function_configuration_media-gracenote_online_other,OFF ,3
ENG248432-ENG248713-function_configuration_media-Import_Media_Data,not activated ,3
ENG248432-ENG248769-function_configuration_media-online_media_services,OFF ,3
ENG248432-ENG248770-function_configuration_media-online_tv,OFF ,3
ENG248432-ENG248794-function_configuration_media-picture_viewer,OFF ,3
ENG248432-ENG248804-function_configuration_media-Ripping_Media_Data,not activated ,3
ENG248432-ENG248482-function_configuration_media-USB,usb_ipod ,3
ENG248433-ENG117847-function_configuration_navigation-advanced_range_display,OFF ,4
ENG248433-ENG173863-function_configuration_navigation-Country_Navigation,NEAST ,4
ENG248433-ENG248692-function_configuration_navigation-gnns_antenna_Availability,not activated ,4
ENG248433-ENG127492-function_configuration_navigation-LGI,OFF ,4
ENG248433-ENG142152-function_configuration_navigation-Map_Style,0 ,4
ENG248433-ENG273674-function_configuration_navigation-max_AC_Charging_Power,0 kW,4
ENG248433-ENG248488-function_configuration_navigation-Navigation_system,activated ,4
ENG248433-ENG103811-function_configuration_navigation-PSD,activated ,4
ENG248433-ENG126994-function_configuration_navigation-TPEG_availability,OFF ,4
ENG248433-ENG248824-function_configuration_navigation-ttraffic_information,OFF ,4
ENG248433-ENG248828-function_configuration_navigation-vza,activated ,4
ENG248433-ENG127494-function_configuration_navigation-VZO,OFF ,4
ENG253085-ENG258874-function_configuration_online-hmi_sdk,OFF ,1
ENG253085-ENG138663-function_configuration_online-Smartphone_interface_for_rhmi,activated ,1
ENG248434-ENG142146-function_configuration_phone-allow_message_editing,On ,3
ENG248434-ENG281930-function_configuration_phone-BTLE_Messaging_support,OFF ,3
ENG248434-ENG125043-function_configuration_phone-Dtmf_without_active_call,On ,3
ENG248434-ENG142145-function_configuration_phone-esim_data_only_sms_support,OFF ,3
ENG248434-ENG248694-function_configuration_phone-GSM_Antenna_3,Deactivated ,3
ENG248434-ENG248695-function_configuration_phone-GSM_Antenna_4,Deactivated ,3
ENG248434-ENG248715-function_configuration_phone-interlink_box_antenna,not installed ,3
ENG248434-ENG248716-function_configuration_phone-interlink_box_nfc,not installed ,3
ENG248434-ENG248717-function_configuration_phone-interlink_box_pwm,not installed ,3
ENG248434-ENG248718-function_configuration_phone-interlink_box_wireless_charging,installed ,3
ENG248434-ENG130246-function_configuration_phone-LTE_modul,activated ,3
ENG248434-ENG142142-function_configuration_phone-map_email_support,On ,3
ENG248434-ENG142143-function_configuration_phone-map_instant_messaging_support,OFF ,3
ENG248434-ENG142141-function_configuration_phone-map_sms_support,On ,3
ENG248434-ENG248792-function_configuration_phone-phone_nad,not installed ,3
ENG248434-ENG125044-function_configuration_phone-Support_for_response_and_hold,OFF ,3
ENG248434-ENG125042-function_configuration_phone-Support_of_threeway_calling,On ,3
ENG248434-ENG130247-function_configuration_phone-Support_second_phone,two ,3
ENG248434-ENG248825-function_configuration_phone-user_menu_three_way_calling,not installed ,3
ENG248436-ENG248497-function_configuration_radio-AF,persistent ,8
ENG248436-ENG248498-function_configuration_radio-af_hmi_switch_default_value,On ,8
ENG248436-ENG248500-function_configuration_radio-AM_disable,Deactivated ,8
ENG248436-ENG248501-function_configuration_radio-am_fm_dab_antenna,not activated ,8
ENG248436-ENG248502-function_configuration_radio-am_hd_hmi_switch_default_value,not activated ,8
ENG248436-ENG248508-function_configuration_radio-band_settings_am_tuner,EU_RdW ,8
ENG248436-ENG248509-function_configuration_radio-band_settings_dab_tuner_band_1,OFF ,8
ENG248436-ENG248510-function_configuration_radio-band_settings_fm_tuner,EU_RdW ,8
ENG248436-ENG248633-function_configuration_radio-DAB_Alarm_Announcement,not activated ,8
ENG248436-ENG248634-function_configuration_radio-dab_mode_antenna_mode_1,not activated ,8
ENG248436-ENG248641-function_configuration_radio-drm_plus_fm,Deactivated ,8
ENG248436-ENG248642-function_configuration_radio-drm30_mf,Deactivated ,8
ENG248436-ENG248683-function_configuration_radio-FM_Antenna,available. ,8
ENG248436-ENG248684-function_configuration_radio-fm_hd_hmi_switch_default_value,not activated ,8
ENG248436-ENG248685-function_configuration_radio-FM_PTY31_Alarm,OFF ,8
ENG248436-ENG248686-function_configuration_radio-fm_radio_profiles,not_valid ,8
ENG248436-ENG248697-function_configuration_radio-HD_FM_Antenna_Mode,AM_FM_ANT ,8
ENG248436-ENG152533-function_configuration_radio-Hybrid_Radio_additional_online_data,Deactivated ,8
ENG248436-ENG152534-function_configuration_radio-Hybrid_Radio_Range_Extender,Deactivated ,8
ENG248436-ENG248767-function_configuration_radio-multiple_entry_switch,OFF ,8
ENG248436-ENG152553-function_configuration_radio-online_radio,Deactivated ,8
ENG248436-ENG248793-function_configuration_radio-PI_ignore,OFF ,8
ENG248436-ENG286264-function_configuration_radio-PTy switch default value,OFF ,8
ENG248436-ENG286265-function_configuration_radio-PTy_switch_visibility,OFF ,8
ENG248436-ENG248797-function_configuration_radio-Radio_Text_Plus,activated ,8
ENG248436-ENG248798-function_configuration_radio-rds_hmi_switch_default_value,On ,8
ENG248436-ENG248799-function_configuration_radio-rds_hmi_switch_visibility,OFF ,8
ENG248436-ENG248812-function_configuration_radio-SDARS_band_activation,Deactivated ,8
ENG248436-ENG249938-function_configuration_radio-SDARS_type,SAT_only ,8
ENG248436-ENG126993-function_configuration_radio-Station_Logo_DB_Mode,0 ,8
ENG248438-ENG248523-function_configuration_sound-brand_sound,Default ,1
ENG248438-ENG248765-function_configuration_sound-Microphone_for_vehicle_noise_cancelation,not activated ,1
ENG248438-ENG248803-function_configuration_sound-retractable_tweeters,not activated ,1
ENG248438-ENG142149-function_configuration_sound-vehicle_leaving_sound,not activated ,1
ENG248438-ENG142147-function_configuration_sound-vehicle_readiness_sound,activated ,1
ENG248439-ENG248632-function_configuration_speech-country_language_change,NEAST ,2
ENG248439-ENG138660-function_configuration_speech-SDS_Region_Flag,REGION_ROW_NEAREAST ,2
ENG244879-ENG137647-function_configuration_sw_update-UOTA,OFF ,1
ENG244879-ENG167532-function_configuration_sw_update-UOTA_2,On ,1
ENG244879-ENG249952-function_configuration_sw_update-UOTA_onboard_tester,Not available ,1
ENG248440-function_configuration_swap_fod,swap_not_active_fod_slave_active ,1
ENG248441-ENG248640-function_configuration_unit-Display_Turn_Out_Speed,normal ,1
ENG248441-ENG167523-function_configuration_unit-Pilot_Parking,Deactivated ,1
ENG248441-ENG249931-function_configuration_unit-reset_type_hardware_reset,Full_System ,1
ENG248441-ENG126143-function_configuration_unit-RVC_video_input,FBAS ,1
ENG248441-ENG248813-function_configuration_unit-second_display_via_lvds_connection,not connected ,1
ENG248441-ENG248822-function_configuration_unit-Suspend_to_RAM,activated ,1
ENG248441-ENG248829-function_configuration_unit-web_app_plattform_side_loading,Deactivated ,1
ENG248442-geocoordinate_create,create ,1
ENG248443-geocoordinate_show,Show ,1
ENG277065-ENG273775-navigation_settings_e_vehicles_extended-base_load,0 W,15
ENG277065-ENG273758-navigation_settings_e_vehicles_extended-Charging_station_preference,0 min,15
ENG277065-ENG106054-navigation_settings_e_vehicles_extended-Efficiency,0 %,15
ENG277065-ENG273815-navigation_settings_e_vehicles_extended-first_arrival_soc_factor,0 %,15
ENG277065-ENG273776-navigation_settings_e_vehicles_extended-max_arrival_soc,0 %,15
ENG277065-ENG273653-navigation_settings_e_vehicles_extended-max_target_soc,0 %,15
ENG277065-ENG273844-navigation_settings_e_vehicles_extended-min_arrival_soc,0 %,15
ENG277065-ENG273690-navigation_settings_e_vehicles_extended-multistop_routing,OFF ,15
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,activated ,5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,activated ,5
ENG248467-number_to_name_matching_algorithm,compare_last_digits ,1
ENG262674-region_coding_truffles,EU ,1
ENG167432-MAS19716-RSE_function_configuration-Services,Tracking Data group selected ,10
ENG167432-MAS19722-RSE_function_configuration-Data collector,activated ,10
ENG167432-MAS19797-RSE_function_configuration-Basic setting not recognized Guest: services,Settings from the previous drive cycle are adopted ,10
ENG167432-MAS19798-RSE_function_configuration-Basic setting not recognized Guest: campaigns with interest weighting,Settings from the previous drive cycle are adopted ,10
ENG167432-MAS19799-RSE_function_configuration-Basic setting not recognized Guest: campaigns with consent,Settings from the previous drive cycle are adopted ,10
ENG167432-MAS19887-RSE_function_configuration-Display info window for current privacy settings,Display ,10
ENG167432-MAS19892-RSE_function_configuration-Display selection for recurring dialog display,Display ,10
ENG167432-MAS19893-RSE_function_configuration-Selection for recurring dialog display availability,for personalized users ,10
ENG167432-ENG167528-RSE_function_configuration-RSE_navigation_coding,not activated ,10
ENG167432-ENG138661-RSE_function_configuration-RSE_software_component,not activated ,10
ENG248469-same_ssid_for_2_4_and_5_ghz,No ,1
ENG248470-sortorder,sortorder_1 ,1
ENG253041-ENG260670-speechinput_properties_for_activation-use_microphone_1_for_speech_input,Yes ,1
ENG253041-ENG260799-speechinput_properties_for_activation-use_microphone_2_for_speech_input,Yes ,1
ENG253041-ENG261039-speechinput_properties_for_activation-use_microphone_3_for_speech_input,No ,1
ENG253041-ENG259276-speechinput_properties_for_activation-use_microphone_4_for_speech_input,No ,1
ENG253041-ENG260534-speechinput_properties_for_activation-Voice_barge_in,On ,1
ENG253041-ENG258983-speechinput_properties_for_activation-Wake_up_phrase,On ,1
ENG253124-ENG261068-subsystem_identifier_version_implementation-abt_1,slave_component_lists ,2
ENG253124-ENG259782-subsystem_identifier_version_implementation-abt_2,slave_component_lists ,2
ENG253124-ENG253445-subsystem_identifier_version_implementation-actuator,slave_component_lists ,2
ENG253124-ENG260508-subsystem_identifier_version_implementation-display_1,individual_identifier_for_each_slave ,2
ENG253124-ENG260946-subsystem_identifier_version_implementation-display_2,slave_component_lists ,2
ENG253124-ENG260037-subsystem_identifier_version_implementation-display_3,slave_component_lists ,2
ENG253124-ENG286255-subsystem_identifier_version_implementation-display_4,slave_component_lists ,2
ENG253124-ENG258562-subsystem_identifier_version_implementation-display_5,individual_identifier_for_each_slave ,2
ENG253124-ENG99668-subsystem_identifier_version_implementation-Reserved_3,slave_component_lists ,2
ENG253124-ENG154261-subsystem_identifier_version_implementation-Reserved_4,slave_component_lists ,2
ENG253124-ENG154330-subsystem_identifier_version_implementation-Reserved_5,slave_component_lists ,2
ENG253124-ENG154188-subsystem_identifier_version_implementation-Reserved_6,slave_component_lists ,2
ENG253124-ENG154256-subsystem_identifier_version_implementation-Reserved_7,slave_component_lists ,2
ENG253124-ENG154341-subsystem_identifier_version_implementation-Reserved_8,slave_component_lists ,2
ENG253124-ENG154185-subsystem_identifier_version_implementation-Reserved_9,slave_component_lists ,2
ENG253124-ENG259851-subsystem_identifier_version_implementation-volume_controler_mmi,individual_identifier_for_each_slave ,2
Elapsed Time: 00:56
adpmap-65-4M0-907-273-B_WAUZZZF29MN105510-20210719-1939.CSV
;SW:4M0-907-273-B   HW:4M0-907-273-B ---  Tire Pressure
;Component:RDKHUFAU736   H06 0010, Coding:
;EV_RDKHUFAU736,002007,EV_RDKHUFAU736_AU58.rod
;Monday,19,July,2021,19:39:27:35862
;VCDS Version: Release 21.3.0  Data version: 20210318 DS325.0
;VCID: 2F3078EC67E58D13269-807A
IDE00820-ENG136322-Activating and deactivating all development messages-Internal_fault_number,0 ,3
IDE00820-ENG110578-Activating and deactivating all development messages-S_100,not activated ,3
IDE00820-ENG110579-Activating and deactivating all development messages-S_101,not activated ,3
IDE00820-ENG110580-Activating and deactivating all development messages-S_102,not activated ,3
IDE00820-ENG136320-Activating and deactivating all development messages-S_103-S_104,not activated ,3
IDE00820-ENG136321-Activating and deactivating all development messages-S_105-S_112,not activated ,3
IDE00820-ENG99057-Activating and deactivating all development messages-XCP,not activated ,3
IDE03513-IDE03525-Write sensor identification number-Sensor identification number (sensor ID),575837454 ,5
IDE03513-IDE06104-Write sensor identification number-Wheel position,4 ,5
Elapsed Time: 00:03
adpmap-6C-4M0-980-556-A_WAUZZZF29MN105510-20210719-1939.CSV
;SW:4M0-980-556-A   HW:4M0-980-556-A ---  Back-up Cam.
;Component:RVC Compact   H18 0250, Coding:0285010102002001C20040
;EV_CamSysRVRVCPANAMLBEv,005010,EV_CamSysRVRVCPANAMLBEv_005_VW53.rod
;Monday,19,July,2021,19:39:35:35862
;VCID: 3338749C8BCDA9F3421-8066
IDE02709-Actuator: PWM signal,100 %,1
IDE03531-Wheel/tire description,1950 mm,2
MAS02209-Image contrast,50 %,1
MAS02851-Brightness,50 %,1
ENG119212-camera_off,35.00 km/h,2
ENG119211-camera_on,30.00 km/h,2
ENG119200-color,50 %,1
ENG119218-debounce_time_for_reverse_gear,0 ms,2
ENG119215-display_position,0 px,1
ENG119216-engine_restart_timer,0 ms,2
ENG119209-Frequency_Swinging_Logo,100 Hz,2
ENG119221-FSG_control_state,On ,1
ENG119220-ENG119101-grafic_element_setting-setting_1_color_value,FF FF ,128
ENG119220-ENG119099-grafic_element_setting-setting_1_HMI_mode,FF ,128
ENG119220-ENG119100-grafic_element_setting-setting_1_pallet_ID,255 ,128
ENG119220-ENG119128-grafic_element_setting-setting_10_color_value,FF FF ,128
ENG119220-ENG119126-grafic_element_setting-setting_10_HMI_mode,FF ,128
ENG119220-ENG119127-grafic_element_setting-setting_10_pallet_ID,255 ,128
ENG119220-ENG119131-grafic_element_setting-setting_11_color_value,FF FF ,128
ENG119220-ENG119129-grafic_element_setting-setting_11_HMI_mode,FF ,128
ENG119220-ENG119130-grafic_element_setting-setting_11_pallet_ID,255 ,128
ENG119220-ENG119134-grafic_element_setting-setting_12_color_value,FF FF ,128
ENG119220-ENG119132-grafic_element_setting-setting_12_HMI_mode,FF ,128
ENG119220-ENG119133-grafic_element_setting-setting_12_pallet_ID,255 ,128
ENG119220-ENG119137-grafic_element_setting-setting_13_color_value,FF FF ,128
ENG119220-ENG119135-grafic_element_setting-setting_13_HMI_mode,FF ,128
ENG119220-ENG119136-grafic_element_setting-setting_13_pallet_ID,255 ,128
ENG119220-ENG119140-grafic_element_setting-setting_14_color_value,FF FF ,128
ENG119220-ENG119138-grafic_element_setting-setting_14_HMI_mode,FF ,128
ENG119220-ENG119139-grafic_element_setting-setting_14_pallet_ID,255 ,128
ENG119220-ENG119143-grafic_element_setting-setting_15_color_value,FF FF ,128
ENG119220-ENG119141-grafic_element_setting-setting_15_HMI_mode,FF ,128
ENG119220-ENG119142-grafic_element_setting-setting_15_pallet_ID,255 ,128
ENG119220-ENG119146-grafic_element_setting-setting_16_color_value,FF FF ,128
ENG119220-ENG119144-grafic_element_setting-setting_16_HMI_mode,FF ,128
ENG119220-ENG119145-grafic_element_setting-setting_16_pallet_ID,255 ,128
ENG119220-ENG119149-grafic_element_setting-setting_17_color_value,FF FF ,128
ENG119220-ENG119147-grafic_element_setting-setting_17_HMI_mode,FF ,128
ENG119220-ENG119148-grafic_element_setting-setting_17_pallet_ID,255 ,128
ENG119220-ENG119152-grafic_element_setting-setting_18_color_value,FF FF ,128
ENG119220-ENG119150-grafic_element_setting-setting_18_HMI_mode,FF ,128
ENG119220-ENG119151-grafic_element_setting-setting_18_pallet_ID,255 ,128
ENG119220-ENG119155-grafic_element_setting-setting_19_color_value,FF FF ,128
ENG119220-ENG119153-grafic_element_setting-setting_19_HMI_mode,FF ,128
ENG119220-ENG119154-grafic_element_setting-setting_19_pallet_ID,255 ,128
ENG119220-ENG119104-grafic_element_setting-setting_2_color_value,FF FF ,128
ENG119220-ENG119102-grafic_element_setting-setting_2_HMI_mode,FF ,128
ENG119220-ENG119103-grafic_element_setting-setting_2_pallet_ID,255 ,128
ENG119220-ENG119158-grafic_element_setting-setting_20_color_value,FF FF ,128
ENG119220-ENG119156-grafic_element_setting-setting_20_HMI_mode,FF ,128
ENG119220-ENG119157-grafic_element_setting-setting_20_pallet_ID,255 ,128
ENG119220-ENG119161-grafic_element_setting-setting_21_color_value,FF FF ,128
ENG119220-ENG119159-grafic_element_setting-setting_21_HMI_mode,FF ,128
ENG119220-ENG119160-grafic_element_setting-setting_21_pallet_ID,255 ,128
ENG119220-ENG119164-grafic_element_setting-setting_22_color_value,FF FF ,128
ENG119220-ENG119162-grafic_element_setting-setting_22_HMI_mode,FF ,128
ENG119220-ENG119163-grafic_element_setting-setting_22_pallet_ID,255 ,128
ENG119220-ENG119167-grafic_element_setting-setting_23_color_value,FF FF ,128
ENG119220-ENG119165-grafic_element_setting-setting_23_HMI_mode,FF ,128
ENG119220-ENG119166-grafic_element_setting-setting_23_pallet_ID,255 ,128
ENG119220-ENG119170-grafic_element_setting-setting_24_color_value,FF FF ,128
ENG119220-ENG119168-grafic_element_setting-setting_24_HMI_mode,FF ,128
ENG119220-ENG119169-grafic_element_setting-setting_24_pallet_ID,255 ,128
ENG119220-ENG119173-grafic_element_setting-setting_25_color_value,FF FF ,128
ENG119220-ENG119171-grafic_element_setting-setting_25_HMI_mode,FF ,128
ENG119220-ENG119172-grafic_element_setting-setting_25_pallet_ID,255 ,128
ENG119220-ENG119176-grafic_element_setting-setting_26_color_value,FF FF ,128
ENG119220-ENG119174-grafic_element_setting-setting_26_HMI_mode,FF ,128
ENG119220-ENG119175-grafic_element_setting-setting_26_pallet_ID,255 ,128
ENG119220-ENG119179-grafic_element_setting-setting_27_color_value,FF FF ,128
ENG119220-ENG119177-grafic_element_setting-setting_27_HMI_mode,FF ,128
ENG119220-ENG119178-grafic_element_setting-setting_27_pallet_ID,255 ,128
ENG119220-ENG119182-grafic_element_setting-setting_28_color_value,FF FF ,128
ENG119220-ENG119180-grafic_element_setting-setting_28_HMI_mode,FF ,128
ENG119220-ENG119181-grafic_element_setting-setting_28_pallet_ID,255 ,128
ENG119220-ENG119185-grafic_element_setting-setting_29_color_value,FF FF ,128
ENG119220-ENG119183-grafic_element_setting-setting_29_HMI_mode,FF ,128
ENG119220-ENG119184-grafic_element_setting-setting_29_pallet_ID,255 ,128
ENG119220-ENG119107-grafic_element_setting-setting_3_color_value,FF FF ,128
ENG119220-ENG119105-grafic_element_setting-setting_3_HMI_mode,FF ,128
ENG119220-ENG119106-grafic_element_setting-setting_3_pallet_ID,255 ,128
ENG119220-ENG119188-grafic_element_setting-setting_30_color_value,FF FF ,128
ENG119220-ENG119186-grafic_element_setting-setting_30_HMI_mode,FF ,128
ENG119220-ENG119187-grafic_element_setting-setting_30_pallet_ID,255 ,128
ENG119220-ENG119191-grafic_element_setting-setting_31_color_value,FF FF ,128
ENG119220-ENG119189-grafic_element_setting-setting_31_HMI_mode,FF ,128
ENG119220-ENG119190-grafic_element_setting-setting_31_pallet_ID,255 ,128
ENG119220-ENG119194-grafic_element_setting-setting_32_color_value,FF FF ,128
ENG119220-ENG119192-grafic_element_setting-setting_32_HMI_mode,FF ,128
ENG119220-ENG119193-grafic_element_setting-setting_32_pallet_ID,255 ,128
ENG119220-ENG119110-grafic_element_setting-setting_4_color_value,FF FF ,128
ENG119220-ENG119108-grafic_element_setting-setting_4_HMI_mode,FF ,128
ENG119220-ENG119109-grafic_element_setting-setting_4_pallet_ID,255 ,128
ENG119220-ENG119113-grafic_element_setting-setting_5_color_value,FF FF ,128
ENG119220-ENG119111-grafic_element_setting-setting_5_HMI_mode,FF ,128
ENG119220-ENG119112-grafic_element_setting-setting_5_pallet_ID,255 ,128
ENG119220-ENG119116-grafic_element_setting-setting_6_color_value,FF FF ,128
ENG119220-ENG119114-grafic_element_setting-setting_6_HMI_mode,FF ,128
ENG119220-ENG119115-grafic_element_setting-setting_6_pallet_ID,255 ,128
ENG119220-ENG119119-grafic_element_setting-setting_7_color_value,FF FF ,128
ENG119220-ENG119117-grafic_element_setting-setting_7_HMI_mode,FF ,128
ENG119220-ENG119118-grafic_element_setting-setting_7_pallet_ID,255 ,128
ENG119220-ENG119122-grafic_element_setting-setting_8_color_value,FF FF ,128
ENG119220-ENG119120-grafic_element_setting-setting_8_HMI_mode,FF ,128
ENG119220-ENG119121-grafic_element_setting-setting_8_pallet_ID,255 ,128
ENG119220-ENG119125-grafic_element_setting-setting_9_color_value,FF FF ,128
ENG119220-ENG119123-grafic_element_setting-setting_9_HMI_mode,FF ,128
ENG119220-ENG119124-grafic_element_setting-setting_9_pallet_ID,255 ,128
ENG119201-image_delay_timer,0.0 s,1
ENG119219-Minimal_time_to_stay_in_bus_sleep_before_ECU_off,20000 ms,2
ENG119214-rv_dark_off,10.00 km/h,2
ENG119213-rv_dark_on,15.00 km/h,2
ENG119203-RV_Last_Mode,90° parking spot ,1
ENG102898-RV_Start_Mode,90° parking spot ,1
ENG119205-Time_to_open_Swinging_Logo,750 ms,2
Elapsed Time: 00:06
adpmap-6D-8W5-959-107-D_WAUZZZF29MN105510-20210719-1939.CSV
;SW:8W5-959-107-D   HW:8W5-959-107 ---  Trunk Elect.
;Component:HDSG-Modul    H13 0171, Coding:1130
;EV_DeckLidCONTIAU736,001017,EV_DeckLidCONTIAU736_VW27.rod
;Monday,19,July,2021,19:39:45:35862
;VCID: 47C0304CEF5535530E9-8012
IDE00001-IDE03415-Production mode-Tone sensor,not active ,3
IDE00001-IDE10408-Production mode-Opening height in production mode,not active ,3
IDE00001-MAS10733-Production mode-Activation due to excessive pressure on rear lid,not active ,3
IDE00001-MAS10734-Production mode-Activation of rear lid with reduced speed,not active ,3
IDE00001-MAS10735-Production mode-Calibration,not active ,3
IDE00001-MAS10736-Production mode-Checking the rear lid button,not active ,3
IDE00001-MAS10738-Production mode-Opening and closing rear lid,not active ,3
IDE02158-Program opening stop,1212 ,2
IDE03435-Detection area upper,100 ,2
IDE03776-Offset for maximum programmable opening stop,40 ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,0 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,4 min,2
IDE09510-IDE02111-Tailgate reverse path-Reverse path when opening,0 ,4
IDE09510-IDE02113-Tailgate reverse path-Reverse path when closing,90 ,4
IDE09511-Minimum opening height of tailgate,400 ,2
IDE09512-Deactivation of tailgate,active ,1
IDE09514-MAS01871-Deactivation of tailgate while in trailer operation-Rear lid lock button in luggage compartment,active ,2
IDE09514-MAS06265-Deactivation of tailgate while in trailer operation-Release button in rear lid handle,active ,2
IDE09514-MAS09010-Deactivation of tailgate while in trailer operation-Sensor for rear lid opening,active ,2
IDE09514-MAS09042-Deactivation of tailgate while in trailer operation-Using button to close lock. mechanism in tailgate handle,active ,2
IDE09514-MAS09043-Deactivation of tailgate while in trailer operation-Remote ctrl: opening with button for tailgate unlock. mechan.,not active ,2
IDE09514-MAS09044-Deactivation of tailgate while in trailer operation-Remote ctrl: closing with button for tailgate unlock. mechan.,not active ,2
IDE09514-MAS09045-Deactivation of tailgate while in trailer operation-Using sensor to open tailgate,not active ,2
IDE09514-MAS09046-Deactivation of tailgate while in trailer operation-Using sensor to close tailgate,not active ,2
IDE09514-MAS09063-Deactivation of tailgate while in trailer operation-Opening with button for remote unlocking of tailgate,not active ,2
IDE09514-MAS09064-Deactivation of tailgate while in trailer operation-Closing with remote unl.button of tailgate when using a trailer,not active ,2
IDE09514-MAS11625-Deactivation of tailgate while in trailer operation-Button for opening rear lid in luggage compartment,active ,2
IDE09514-MAS13754-Deactivation of tailgate while in trailer operation-Opening with button 2 for remote unlocking of rear lid,not active ,2
IDE09514-MAS13755-Deactivation of tailgate while in trailer operation-Closing with remote unlock.butt.2 of rear lid when using trail.,not active ,2
IDE09520-Offset for opening height after basic setting,0 ,2
IDE10408-Opening height in production mode,60 %,2
IDE10695-Dectivation of the luggage compartment cover,not active ,1
IDE10703-Luggage compartment cover: tolerance of the block counter,0 ,2
IDE10704-Luggage compartment cover: maximum no. of block drives,0 ,2
IDE10705-Luggage compartment cover: number bloom drives,0 ,2
IDE10706-MAS01875-Luggage compartment cover: reverse path after obstacle recogn.-Open,0 ,4
IDE10706-MAS01876-Luggage compartment cover: reverse path after obstacle recogn.-Close,0 ,4
IDE10707-IDE03434-Luggage compartment cover: detection area-Detection area lower,0 ,4
IDE10707-IDE03435-Luggage compartment cover: detection area-Detection area upper,0 ,4
IDE10708-Luggage compartment cover: adjust. track tolerance,0 ,2
IDE10709-Luggage compartment cover: excess limitation in exclusion area,not active ,1
ENG131232-MAS01911-Ausstattungen aktivieren-Tone sensor,not active ,2
ENG131232-MAS01947-Ausstattungen aktivieren-Clamping strip 1,not active ,2
ENG131232-MAS01948-Ausstattungen aktivieren-Clamping strip 2,not active ,2
ENG131232-MAS01949-Ausstattungen aktivieren-Clamping strip 3,not active ,2
ENG131232-MAS01950-Ausstattungen aktivieren-Clamping strip 4,not active ,2
ENG131232-MAS04266-Ausstattungen aktivieren-Temperature sensor 1,active ,2
ENG131232-MAS04267-Ausstattungen aktivieren-Temperature sensor 2,active ,2
ENG131232-MAS08212-Ausstattungen aktivieren-Motor 2,not active ,2
ENG131232-MAS09001-Ausstattungen aktivieren-Closing Assist Motor,active ,2
ENG131232-MAS11624-Ausstattungen aktivieren-Motor 2: sensor system,not active ,2
Elapsed Time: 00:06
adpmap-75-4K2-035-282-A_WAUZZZF29MN105510-20210719-1939.CSV
;SW:4K2-035-282-A   HW:4K2-035-282-B ---  Telematics
;Component:CB_H_RdW      041 0236, Coding:0100E008C04000F6E0
;EV_ConBoxHighAU49X,001004,EV_ConBoxHighAU49X.rod
;Monday,19,July,2021,19:39:56:35862
;VCID: 261E9DC8481FCC5BD5F-8072
IDE00001-MAS00951-Production mode-Bluetooth,not active ,3
IDE00001-MAS03782-Production mode-WLAN,not active ,3
IDE00001-MAS17528-Production mode-Mobile communications network: configuration,not active ,3
IDE00761-MAS19772-Run-on time-Online data connection,240 H,6
IDE00761-MAS19773-Run-on time-SMS availability,384 H,6
IDE00761-MAS19774-Run-on time-Home network search,30 min,6
IDE00761-MAS19776-Run-on time-Ping frequency of data connection to back end,7 min,6
IDE00768-Country identification: country of sale,TR ,2
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active ,1
IDE00820-MAS03504-Activating and deactivating all development messages-XCP,not active ,1
IDE04550-Bluetooth: Sniff mode,On ,1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 min,2
IDE10082-MAS17529-Telephone functions configuration-Support for second telephone,On ,1
IDE10082-MAS17530-Telephone functions configuration-Support parallel phone calls,On ,1
IDE10082-MAS17531-Telephone functions configuration-Support for call holding function,OFF ,1
IDE11638-Bluetooth Audio Codec,00 ,1
IDE13338-Basic functions connect,activated ,1
IDE14089-Bluetooth Low Energy,On ,1
IDE14093-MAS13846-Emergency call module and communication unit: configuration-Internet access via WiFi,Not available ,2
IDE14093-MAS17936-Emergency call module and communication unit: configuration-WLAN 5GHz,On ,2
IDE14093-MAS17940-Emergency call module and communication unit: configuration-MAP SMS,On ,2
IDE14093-MAS17941-Emergency call module and communication unit: configuration-MAP e-mail,On ,2
IDE14093-MAS17942-Emergency call module and communication unit: configuration-MAP Instant Messaging,On ,2
IDE14093-MAS17943-Emergency call module and communication unit: configuration-Sms via SIM,OFF ,2
IDE14093-MAS17944-Emergency call module and communication unit: configuration-Sms via eSIM,OFF ,2
IDE14093-MAS17945-Emergency call module and communication unit: configuration-Bluetooth headset telephone,OFF ,2
IDE14093-MAS20485-Emergency call module and communication unit: configuration-WLAN Client Mode 2.4 GHz,OFF ,2
IDE14093-MAS20486-Emergency call module and communication unit: configuration-WLAN Client Mode 5 Ghz,OFF ,2
IDE14093-MAS20487-Emergency call module and communication unit: configuration-WiFi hotspot 2.4 Ghz,On ,2
IDE14093-MAS20488-Emergency call module and communication unit: configuration-WiFi Hotspot 5 Ghz,On ,2
IDE14159-MAS17894-Emergency call module and communication unit: basic functions-Language transfer via LTE (VoLTE),On ,1
IDE14159-MAS17895-Emergency call module and communication unit: basic functions-Satellite navigation (GPS),On ,1
IDE14159-MAS17896-Emergency call module and communication unit: basic functions-Satellite navigation (Galileo),On ,1
IDE14159-MAS17897-Emergency call module and communication unit: basic functions-Satellite navigation (Glonass),On ,1
IDE14159-MAS17898-Emergency call module and communication unit: basic functions-Satellite navigation (Beidou),On ,1
IDE15335-MAS20504-Vehicle name information electronics-Prefix,Audi_MMI_ ,42
IDE15335-MAS20505-Vehicle name information electronics-Postfix 2.4 GHz, ,42
IDE15335-MAS20506-Vehicle name information electronics-Postfix 5 GHz,_5GHz ,42
IDE15361-MAS13846-WLAN settings-Internet access via WiFi,activated ,4
IDE15361-MAS20496-WLAN settings-Channel number for 2.4 GHz WLAN,6 ,4
IDE15361-MAS20497-WLAN settings-Channel number for 5 GHz WLAN,0 ,4
IDE15361-MAS20498-WLAN settings-Password synchronization,Synchronized ,4
IDE15361-MAS20499-WLAN settings-2.4 GHz band visibility,visible ,4
IDE15361-MAS20500-WLAN settings-5 GHz band visibility,visible ,4
IDE15361-MAS20501-WLAN settings-2.4 GHz band bandwidth,Channel width 20 MHz ,4
IDE15361-MAS20502-WLAN settings-5 GHz band bandwidth,Channel width 40 MHz ,4
IDE15361-MAS20507-WLAN settings-IP configuration validity period (DHCP),72 H,4
IDE15362-MAS20508-Smartphone configuration-Apple CarPlay Wireless,On ,1
IDE15362-MAS20509-Smartphone configuration-Google Android Auto Wireless,OFF ,1
IDE15362-MAS20510-Smartphone configuration-Baidu CarLife Wireless (Android),OFF ,1
IDE15362-MAS20511-Smartphone configuration-Baidu CarLife Wireless (iOS),OFF ,1
MAS00951-Bluetooth,On ,1
MAS03782-WLAN,On ,1
Elapsed Time: 00:07
adpmap-80-4K0-915-101_WAUZZZF29MN105510-20210719-1940.CSV
;SW:4K0-915-101   HW:4K0-915-101 ---  Batt. reg. aux. accum.
;Component:MQ-BMS        H20 0127, Coding:
;EV_BMS12VLiIonSDIAU49X,001001,EV_BMS12VLiIonSDIAU49X.rod
;Monday,19,July,2021,19:40:06:35862
;VCID: 6092CBD06ABB626BEF3-8034
Elapsed Time: 00:00
adpmap-81-4K1-713-041-M_WAUZZZF29MN105510-20210719-1940.CSV
;SW:4K1-713-041-M   HW:4K1-713-041-H ---  Gear Shift
;Component:GSM-LL H15 0056, Coding:
;EV_GSMKAMAU581,001005,EV_GSMKAMAU581.rod
;Monday,19,July,2021,19:40:10:35862
;VCID: 2D0C62E46DE9FF03145-8078
ENG185705-Illumination_Parameter_String,00 00 00 01 00 01 32 01 5E 5F 02 9E 7D 02 9E 7D 02 9E 00 01 07 0A 01 07 64 15 BC C8 42 B1 FD 80 00 FD 80 00 00 00 AB 0A 00 AB 64 0B 12 C8 21 A8 FD 40 74 FD 40 74 02 F8 02 D5 03 31 02 FD 03 20 03 0E 01 9A 00 2A 00 00 00 00 ,74
Elapsed Time: 00:00
adpmap-A5-4K4-907-107-G_WAUZZZF29MN105510-20210719-1940.CSV
;SW:4K4-907-107-G   HW:4K4-907-107 ---  Frt Sens. Drv. Assist
;Component:zFAS Var A    H08 0366, Coding:0401820000000000000006000040042C18995200000000800000000000000000001900000000000000000000000000000000000000000000000080000000000000007818008000900000000000000000008040000080
;EV_ZFASAU516,003008,EV_ZFASAU516_003.rod
;Monday,19,July,2021,19:40:15:35862
;VCID: 3236719874D7A0FB497-8066
IDE00001-MAS14900-Production mode-Block laser beam,not active ,3
IDE00001-MAS15334-Production mode-Prevention of automatic parking,not active ,3
IDE00001-MAS15687-Production mode-Coding in two steps,not active ,3
IDE00001-MAS15689-Production mode-Deactivate crossing assistant,not active ,3
IDE00001-MAS15690-Production mode-Front camera: deactivate safety mechanisms,not active ,3
IDE00001-MAS16302-Production mode-Peripheral camera system: block partial function,not active ,3
IDE07596-Personalization of lane dept. warning Cl. 15 on,Last setting ,1
IDE13325-Emergency assistant: status after switching on terminal 15,As prior to switching off terminal 15 (personalized) ,1
IDE13367-MAS16343-Automatic headlamp calibration: settings-Image quality threshold value,0 %,7
IDE13367-MAS16344-Automatic headlamp calibration: settings-Time limit total duration,0 ms,7
IDE13367-MAS16345-Automatic headlamp calibration: settings-Time-limit for image processing,0 ms,7
IDE13367-MAS16346-Automatic headlamp calibration: settings-Time-limit for headlamp positioning,0 ms,7
IDE13369-MAS16358-Automatic headlamp calibration: correction angle-Right headlamp: horizontal,-1.00 °,4
IDE13369-MAS16359-Automatic headlamp calibration: correction angle-Right headlamp: vertical,-1.00 °,4
IDE13369-MAS16360-Automatic headlamp calibration: correction angle-Left headlamp: horizontal,-1.00 °,4
IDE13369-MAS16361-Automatic headlamp calibration: correction angle-Left headlamp: vertical,-1.00 °,4
IDE13370-MAS16358-Auto. headlamp calibration: correction of standard deviations-Right headlamp: horizontal,-0.50 ,4
IDE13370-MAS16359-Auto. headlamp calibration: correction of standard deviations-Right headlamp: vertical,-0.50 ,4
IDE13370-MAS16360-Auto. headlamp calibration: correction of standard deviations-Left headlamp: horizontal,-0.50 ,4
IDE13370-MAS16361-Auto. headlamp calibration: correction of standard deviations-Left headlamp: vertical,-0.50 ,4
IDE13583-Lane departure warning: intensity of the steering wheel vibration,Medium ,1
ENG153826-Emergency_assist_activation_override,EA_activation_over_menu ,1
Elapsed Time: 00:47
adpmap-AC-80A-907-355-G_WAUZZZF29MN105510-20210719-1941.CSV
;SW:80A-907-355-G   HW:80A-907-355-D ---  Reductant Control
;Component:SCR-Stg-G4H08 0005, Coding:
;EV_RDCMHelbaAU426,003011,EV_RDCMHelbaAU426_003.rod
;Monday,19,July,2021,19:41:05:35862
IDE00820-ENG114699-Activating and deactivating all development messages-Intern_fault_number,00 00 ,3
IDE00820-ENG136274-Activating and deactivating all development messages-Send_msg_sg_01,not activated ,3
IDE00820-ENG121182-Activating and deactivating all development messages-Send_msg_sg_03_10,not activated ,3
IDE02332-Deactivate production mode,Deactivating ,3
Elapsed Time: 00:01
adpmap-BB-4M1-959-795-J_WAUZZZF29MN105510-20210719-1941.CSV
;SW:4M1-959-795-J   HW:4M1-959-795-D ---  Door Rear Drv
;Component:TSG HFS005 0430, Coding:000DC90000000200A008B000
;EV_DCU2RearDriveMAXHKLO,001018,EV_DCU2RearDriveMAXHKLO_VW53.rod
;Monday,19,July,2021,19:41:11:35862
;VCID: 48C23370E24B3A2B073-801C
IDE09067-Side window shade: service mode,Deactivating ,1
Elapsed Time: 00:02
adpmap-BC-4M1-959-795-J_WAUZZZF29MN105510-20210719-1941.CSV
;SW:4M1-959-795-J   HW:4M1-959-795-D ---  Door Rear Pass
;Component:TSG HBFS005 0430, Coding:000DC90000000200A008B000
;EV_DCU2RearPasseMAXHKLO,001018,EV_DCU2RearPasseMAXHKLO_VW38.rod
;Monday,19,July,2021,19:41:17:35862
Elapsed Time: 00:01
adpmap-CA-4K0-907-594-AC_WAUZZZF29MN105510-20210719-1941.CSV
;SW:4K0-907-594-AC   HW:4K0-907-594 ---  Sunroof
;Component:SAD_STG_1     006 0002, Coding:468040058101
;EV_SunRoofCONTIAU736,009011,EV_SunRoofCONTIAU736_009_AU58.rod
;Monday,19,July,2021,19:41:22:35862
;VCID: 75BC8A84C539F7C3AC5-8020
IDE02104-IDE03633-Temperature dependent activation-Close sunroof,not active ,1
IDE02104-MAS09030-Temperature dependent activation-Open sun roof,active ,1
IDE02104-MAS09031-Temperature dependent activation-Open roof blind,not active ,1
IDE02104-MAS09032-Temperature dependent activation-Close roof blind,not active ,1
IDE09435-IDE03633-Speed dependent activation-Close sunroof,not active ,2
IDE09435-MAS09030-Speed dependent activation-Open sun roof,not active ,2
IDE09435-MAS09031-Speed dependent activation-Open roof blind,not active ,2
IDE09435-MAS09032-Speed dependent activation-Close roof blind,not active ,2
IDE09435-MAS16806-Speed dependent activation-Reduce sunroof tilt,not active ,2
IDE09439-MAS08884-Logic switch-over: controls-Sunroof button,not active ,1
IDE09439-MAS08932-Logic switch-over: controls-Sunroof shade button,not active ,1
IDE09439-MAS08992-Logic switch-over: controls-Button for sliding roof,not active ,1
IDE09439-MAS10443-Logic switch-over: controls-Button for sunroof/tilt roof: rear,not active ,1
IDE09439-MAS10444-Logic switch-over: controls-Sunroof shade button: rear,not active ,1
IDE09451-MAS08936-Travel path-Tilted position: max. opening width,not active ,1
IDE09451-MAS08937-Travel path-Sliding position: intermed. pos.,not active ,1
IDE09451-MAS08991-Travel path-Sliding position: reduc. opening width,not active ,1
IDE09451-MAS10725-Travel path-Sunroof shade: interm. position open,not active ,1
IDE09451-MAS10726-Travel path-Sunroof shade: interm. position close,not active ,1
IDE12616-IDE09434-Power sunroof control module - convenience function-Target position for comfort opening,Slid.position ,2
IDE12616-MAS06696-Power sunroof control module - convenience function-Comfort opening sunroof,active ,2
IDE12616-MAS13329-Power sunroof control module - convenience function-Comfort opening of roof shade,active ,2
IDE12616-MAS13330-Power sunroof control module - convenience function-Comfort closing of roof shade,active ,2
IDE12616-MAS14142-Power sunroof control module - convenience function-Private sphere mode,not active ,2
IDE12616-MAS16807-Power sunroof control module - convenience function-Comfort closing sunroof,active ,2
ENG146366-Applikationmode deactivate,Deactivating ,1
Elapsed Time: 00:02
adpmap-D6-4K0-941-572-DC_WAUZZZF29MN105510-20210719-1941.CSV
;SW:4K0-941-572-DC   HW:4K0-941-572-D ---  Light Ctrl Left 2
;Component:LMS_MLBevo    H06 0032, Coding:
;EV_LMSLeftHELLAAU58X,001013,EV_LMSLeftHELLAAU58X.rod
;Monday,19,July,2021,19:41:28:35862
;VCID: 72B6B198B457E0FB897-8026
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not activated ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not activated ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not activated ,1
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not activated ,1
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not activated ,1
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not activated ,1
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not activated ,1
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not activated ,1
IDE01550-Service position,not active ,1
IDE09392-Light distribution,not active ,1
IDE13847-Parking light for signature lights,not active ,1
IDE14258-Headlamp light classes,00 00 00 00 ,4
IDE14259-Headlamp Reset light class,Reset ,1
MAS06010-Ambient light,not active ,1
ENG168388-ENG168424-Activation of Write Service for Brightness Classes-Brightness_class_ch1_1,3 ,7
ENG168388-ENG168425-Activation of Write Service for Brightness Classes-Brightness_class_ch1_2,3 ,7
ENG168388-ENG168426-Activation of Write Service for Brightness Classes-Brightness_class_ch1_3,3 ,7
ENG168388-ENG168427-Activation of Write Service for Brightness Classes-Brightness_class_ch2_1,1 ,7
ENG168388-ENG168428-Activation of Write Service for Brightness Classes-Brightness_class_ch2_2,3 ,7
ENG168388-ENG168429-Activation of Write Service for Brightness Classes-Brightness_class_ch2_3,3 ,7
ENG168388-ENG168430-Activation of Write Service for Brightness Classes-Brightness_class_ch3_1,3 ,7
ENG168388-ENG168431-Activation of Write Service for Brightness Classes-Brightness_class_ch3_2,3 ,7
ENG168388-ENG168432-Activation of Write Service for Brightness Classes-Brightness_class_ch3_3,3 ,7
ENG168388-ENG168433-Activation of Write Service for Brightness Classes-Brightness_class_ch4_1,2 ,7
ENG168388-ENG168434-Activation of Write Service for Brightness Classes-Brightness_class_ch4_2,3 ,7
ENG168388-ENG168435-Activation of Write Service for Brightness Classes-Brightness_class_ch4_3,3 ,7
ENG168388-ENG168436-Activation of Write Service for Brightness Classes-Brightness_class_ch5_1,3 ,7
ENG168388-ENG168437-Activation of Write Service for Brightness Classes-Brightness_class_ch5_2,3 ,7
ENG168388-ENG168438-Activation of Write Service for Brightness Classes-Brightness_class_ch5_3,3 ,7
ENG168388-ENG168439-Activation of Write Service for Brightness Classes-Brightness_class_ch6_1,3 ,7
ENG168388-ENG168440-Activation of Write Service for Brightness Classes-Brightness_class_ch6_2,3 ,7
ENG168388-ENG168441-Activation of Write Service for Brightness Classes-Brightness_class_ch6_3,3 ,7
ENG168388-ENG168442-Activation of Write Service for Brightness Classes-Brightness_class_ch7_1,3 ,7
ENG168388-ENG168443-Activation of Write Service for Brightness Classes-Brightness_class_ch7_2,3 ,7
ENG168388-ENG168444-Activation of Write Service for Brightness Classes-Brightness_class_ch7_3,3 ,7
ENG168388-ENG168445-Activation of Write Service for Brightness Classes-Brightness_class_ch8_1,3 ,7
ENG168388-ENG168446-Activation of Write Service for Brightness Classes-Brightness_class_ch8_2,3 ,7
ENG168388-ENG168447-Activation of Write Service for Brightness Classes-Brightness_class_ch8_3,3 ,7
ENG168388-ENG168448-Activation of Write Service for Brightness Classes-Brightness_class_slave_1,3 ,7
ENG168388-ENG168449-Activation of Write Service for Brightness Classes-Brightness_class_slave_2,3 ,7
ENG168389-ENG168451-Activation of Write Service for headlamp data-Headlamp_construction_release,1 ,32
ENG168389-ENG168452-Activation of Write Service for headlamp data-Headlamp_manufacturer,HELLA        ,32
ENG168389-ENG168453-Activation of Write Service for headlamp data-Headlamp_part_number,01337701    ,32
ENG168389-ENG168454-Activation of Write Service for headlamp data-Headlamp_production_day,9 d,32
ENG168389-ENG168455-Activation of Write Service for headlamp data-Headlamp_production_hours,10 H,32
ENG168389-ENG168456-Activation of Write Service for headlamp data-Headlamp_production_minutes,52 min,32
ENG168389-ENG168457-Activation of Write Service for headlamp data-Headlamp_production_month,6 Months,32
ENG168389-ENG168458-Activation of Write Service for headlamp data-Headlamp_production_seconds,28 s,32
ENG168389-ENG168459-Activation of Write Service for headlamp data-Headlamp_production_year,2021 yr,32
ENG168389-ENG168460-Activation of Write Service for headlamp data-Headlamp_serial_number,1 ,32
ENG168390-ENG168462-Activation of Write Service for LED calibration values-LED_calibration_value_LMM1_LED1,100 %,108
ENG168390-ENG168463-Activation of Write Service for LED calibration values-LED_calibration_value_LMM1_LED10,100 %,108
ENG168390-ENG168464-Activation of Write Service for LED calibration values-LED_calibration_value_LMM1_LED11,100 %,108
ENG168390-ENG168465-Activation of Write Service for LED calibration values-LED_calibration_value_LMM1_LED12,100 %,108
ENG168390-ENG168466-Activation of Write Service for LED calibration values-LED_calibration_value_LMM1_LED2,100 %,108
ENG168390-ENG168467-Activation of Write Service for LED calibration values-LED_calibration_value_LMM1_LED3,100 %,108
ENG168390-ENG168468-Activation of Write Service for LED calibration values-LED_calibration_value_LMM1_LED4,100 %,108
ENG168390-ENG168469-Activation of Write Service for LED calibration values-LED_calibration_value_LMM1_LED5,100 %,108
ENG168390-ENG168470-Activation of Write Service for LED calibration values-LED_calibration_value_LMM1_LED6,100 %,108
ENG168390-ENG168471-Activation of Write Service for LED calibration values-LED_calibration_value_LMM1_LED7,100 %,108
ENG168390-ENG168472-Activation of Write Service for LED calibration values-LED_calibration_value_LMM1_LED8,100 %,108
ENG168390-ENG168473-Activation of Write Service for LED calibration values-LED_calibration_value_LMM1_LED9,100 %,108
ENG168390-ENG168474-Activation of Write Service for LED calibration values-LED_calibration_value_LMM10_LED1,37 %,108
ENG168390-ENG168475-Activation of Write Service for LED calibration values-LED_calibration_value_LMM10_LED10,37 %,108
ENG168390-ENG168476-Activation of Write Service for LED calibration values-LED_calibration_value_LMM10_LED11,37 %,108
ENG168390-ENG168477-Activation of Write Service for LED calibration values-LED_calibration_value_LMM10_LED12,37 %,108
ENG168390-ENG168478-Activation of Write Service for LED calibration values-LED_calibration_value_LMM10_LED2,37 %,108
ENG168390-ENG168479-Activation of Write Service for LED calibration values-LED_calibration_value_LMM10_LED3,37 %,108
ENG168390-ENG168480-Activation of Write Service for LED calibration values-LED_calibration_value_LMM10_LED4,37 %,108
ENG168390-ENG168481-Activation of Write Service for LED calibration values-LED_calibration_value_LMM10_LED5,37 %,108
ENG168390-ENG168482-Activation of Write Service for LED calibration values-LED_calibration_value_LMM10_LED6,37 %,108
ENG168390-ENG168483-Activation of Write Service for LED calibration values-LED_calibration_value_LMM10_LED7,37 %,108
ENG168390-ENG168484-Activation of Write Service for LED calibration values-LED_calibration_value_LMM10_LED8,37 %,108
ENG168390-ENG168485-Activation of Write Service for LED calibration values-LED_calibration_value_LMM10_LED9,37 %,108
ENG168390-ENG168486-Activation of Write Service for LED calibration values-LED_calibration_value_LMM11_LED1,37 %,108
ENG168390-ENG168487-Activation of Write Service for LED calibration values-LED_calibration_value_LMM11_LED10,37 %,108
ENG168390-ENG168488-Activation of Write Service for LED calibration values-LED_calibration_value_LMM11_LED11,37 %,108
ENG168390-ENG168489-Activation of Write Service for LED calibration values-LED_calibration_value_LMM11_LED12,37 %,108
ENG168390-ENG168490-Activation of Write Service for LED calibration values-LED_calibration_value_LMM11_LED2,37 %,108
ENG168390-ENG168491-Activation of Write Service for LED calibration values-LED_calibration_value_LMM11_LED3,37 %,108
ENG168390-ENG168492-Activation of Write Service for LED calibration values-LED_calibration_value_LMM11_LED4,37 %,108
ENG168390-ENG168493-Activation of Write Service for LED calibration values-LED_calibration_value_LMM11_LED5,37 %,108
ENG168390-ENG168494-Activation of Write Service for LED calibration values-LED_calibration_value_LMM11_LED6,37 %,108
ENG168390-ENG168495-Activation of Write Service for LED calibration values-LED_calibration_value_LMM11_LED7,37 %,108
ENG168390-ENG168496-Activation of Write Service for LED calibration values-LED_calibration_value_LMM11_LED8,37 %,108
ENG168390-ENG168497-Activation of Write Service for LED calibration values-LED_calibration_value_LMM11_LED9,37 %,108
ENG168390-ENG168498-Activation of Write Service for LED calibration values-LED_calibration_value_LMM12_LED1,37 %,108
ENG168390-ENG168499-Activation of Write Service for LED calibration values-LED_calibration_value_LMM12_LED10,37 %,108
ENG168390-ENG168500-Activation of Write Service for LED calibration values-LED_calibration_value_LMM12_LED11,37 %,108
ENG168390-ENG168501-Activation of Write Service for LED calibration values-LED_calibration_value_LMM12_LED12,37 %,108
ENG168390-ENG168502-Activation of Write Service for LED calibration values-LED_calibration_value_LMM12_LED2,37 %,108
ENG168390-ENG168503-Activation of Write Service for LED calibration values-LED_calibration_value_LMM12_LED3,37 %,108
ENG168390-ENG168504-Activation of Write Service for LED calibration values-LED_calibration_value_LMM12_LED4,37 %,108
ENG168390-ENG168505-Activation of Write Service for LED calibration values-LED_calibration_value_LMM12_LED5,37 %,108
ENG168390-ENG168506-Activation of Write Service for LED calibration values-LED_calibration_value_LMM12_LED6,37 %,108
ENG168390-ENG168507-Activation of Write Service for LED calibration values-LED_calibration_value_LMM12_LED7,37 %,108
ENG168390-ENG168508-Activation of Write Service for LED calibration values-LED_calibration_value_LMM12_LED8,37 %,108
ENG168390-ENG168509-Activation of Write Service for LED calibration values-LED_calibration_value_LMM12_LED9,37 %,108
ENG168390-ENG168510-Activation of Write Service for LED calibration values-LED_calibration_value_LMM2_LED1,100 %,108
ENG168390-ENG168511-Activation of Write Service for LED calibration values-LED_calibration_value_LMM2_LED10,100 %,108
ENG168390-ENG168512-Activation of Write Service for LED calibration values-LED_calibration_value_LMM2_LED11,100 %,108
ENG168390-ENG168513-Activation of Write Service for LED calibration values-LED_calibration_value_LMM2_LED12,100 %,108
ENG168390-ENG168514-Activation of Write Service for LED calibration values-LED_calibration_value_LMM2_LED2,100 %,108
ENG168390-ENG168515-Activation of Write Service for LED calibration values-LED_calibration_value_LMM2_LED3,100 %,108
ENG168390-ENG168516-Activation of Write Service for LED calibration values-LED_calibration_value_LMM2_LED4,100 %,108
ENG168390-ENG168517-Activation of Write Service for LED calibration values-LED_calibration_value_LMM2_LED5,100 %,108
ENG168390-ENG168518-Activation of Write Service for LED calibration values-LED_calibration_value_LMM2_LED6,100 %,108
ENG168390-ENG168519-Activation of Write Service for LED calibration values-LED_calibration_value_LMM2_LED7,100 %,108
ENG168390-ENG168520-Activation of Write Service for LED calibration values-LED_calibration_value_LMM2_LED8,100 %,108
ENG168390-ENG168521-Activation of Write Service for LED calibration values-LED_calibration_value_LMM2_LED9,100 %,108
ENG168390-ENG168522-Activation of Write Service for LED calibration values-LED_calibration_value_LMM3_LED1,100 %,108
ENG168390-ENG168523-Activation of Write Service for LED calibration values-LED_calibration_value_LMM3_LED10,100 %,108
ENG168390-ENG168524-Activation of Write Service for LED calibration values-LED_calibration_value_LMM3_LED11,100 %,108
ENG168390-ENG168525-Activation of Write Service for LED calibration values-LED_calibration_value_LMM3_LED12,100 %,108
ENG168390-ENG168526-Activation of Write Service for LED calibration values-LED_calibration_value_LMM3_LED2,100 %,108
ENG168390-ENG168527-Activation of Write Service for LED calibration values-LED_calibration_value_LMM3_LED3,100 %,108
ENG168390-ENG168528-Activation of Write Service for LED calibration values-LED_calibration_value_LMM3_LED4,100 %,108
ENG168390-ENG168529-Activation of Write Service for LED calibration values-LED_calibration_value_LMM3_LED5,100 %,108
ENG168390-ENG168530-Activation of Write Service for LED calibration values-LED_calibration_value_LMM3_LED6,100 %,108
ENG168390-ENG168531-Activation of Write Service for LED calibration values-LED_calibration_value_LMM3_LED7,100 %,108
ENG168390-ENG168532-Activation of Write Service for LED calibration values-LED_calibration_value_LMM3_LED8,100 %,108
ENG168390-ENG168533-Activation of Write Service for LED calibration values-LED_calibration_value_LMM3_LED9,100 %,108
ENG168390-ENG168534-Activation of Write Service for LED calibration values-LED_calibration_value_LMM4_LED1,100 %,108
ENG168390-ENG168535-Activation of Write Service for LED calibration values-LED_calibration_value_LMM4_LED10,100 %,108
ENG168390-ENG168536-Activation of Write Service for LED calibration values-LED_calibration_value_LMM4_LED11,100 %,108
ENG168390-ENG168537-Activation of Write Service for LED calibration values-LED_calibration_value_LMM4_LED12,100 %,108
ENG168390-ENG168538-Activation of Write Service for LED calibration values-LED_calibration_value_LMM4_LED2,100 %,108
ENG168390-ENG168539-Activation of Write Service for LED calibration values-LED_calibration_value_LMM4_LED3,100 %,108
ENG168390-ENG168540-Activation of Write Service for LED calibration values-LED_calibration_value_LMM4_LED4,100 %,108
ENG168390-ENG168541-Activation of Write Service for LED calibration values-LED_calibration_value_LMM4_LED5,100 %,108
ENG168390-ENG168542-Activation of Write Service for LED calibration values-LED_calibration_value_LMM4_LED6,100 %,108
ENG168390-ENG168543-Activation of Write Service for LED calibration values-LED_calibration_value_LMM4_LED7,100 %,108
ENG168390-ENG168544-Activation of Write Service for LED calibration values-LED_calibration_value_LMM4_LED8,100 %,108
ENG168390-ENG168545-Activation of Write Service for LED calibration values-LED_calibration_value_LMM4_LED9,100 %,108
ENG168390-ENG168546-Activation of Write Service for LED calibration values-LED_calibration_value_LMM5_LED1,100 %,108
ENG168390-ENG168547-Activation of Write Service for LED calibration values-LED_calibration_value_LMM5_LED10,100 %,108
ENG168390-ENG168548-Activation of Write Service for LED calibration values-LED_calibration_value_LMM5_LED11,100 %,108
ENG168390-ENG168549-Activation of Write Service for LED calibration values-LED_calibration_value_LMM5_LED12,100 %,108
ENG168390-ENG168550-Activation of Write Service for LED calibration values-LED_calibration_value_LMM5_LED2,100 %,108
ENG168390-ENG168551-Activation of Write Service for LED calibration values-LED_calibration_value_LMM5_LED3,100 %,108
ENG168390-ENG168552-Activation of Write Service for LED calibration values-LED_calibration_value_LMM5_LED4,100 %,108
ENG168390-ENG168553-Activation of Write Service for LED calibration values-LED_calibration_value_LMM5_LED5,100 %,108
ENG168390-ENG168554-Activation of Write Service for LED calibration values-LED_calibration_value_LMM5_LED6,100 %,108
ENG168390-ENG168555-Activation of Write Service for LED calibration values-LED_calibration_value_LMM5_LED7,100 %,108
ENG168390-ENG168556-Activation of Write Service for LED calibration values-LED_calibration_value_LMM5_LED8,100 %,108
ENG168390-ENG168557-Activation of Write Service for LED calibration values-LED_calibration_value_LMM5_LED9,100 %,108
ENG168390-ENG168558-Activation of Write Service for LED calibration values-LED_calibration_value_LMM6_LED1,100 %,108
ENG168390-ENG168559-Activation of Write Service for LED calibration values-LED_calibration_value_LMM6_LED10,100 %,108
ENG168390-ENG168560-Activation of Write Service for LED calibration values-LED_calibration_value_LMM6_LED11,100 %,108
ENG168390-ENG168561-Activation of Write Service for LED calibration values-LED_calibration_value_LMM6_LED12,100 %,108
ENG168390-ENG168562-Activation of Write Service for LED calibration values-LED_calibration_value_LMM6_LED2,100 %,108
ENG168390-ENG168563-Activation of Write Service for LED calibration values-LED_calibration_value_LMM6_LED3,100 %,108
ENG168390-ENG168564-Activation of Write Service for LED calibration values-LED_calibration_value_LMM6_LED4,100 %,108
ENG168390-ENG168565-Activation of Write Service for LED calibration values-LED_calibration_value_LMM6_LED5,100 %,108
ENG168390-ENG168566-Activation of Write Service for LED calibration values-LED_calibration_value_LMM6_LED6,100 %,108
ENG168390-ENG168567-Activation of Write Service for LED calibration values-LED_calibration_value_LMM6_LED7,100 %,108
ENG168390-ENG168568-Activation of Write Service for LED calibration values-LED_calibration_value_LMM6_LED8,100 %,108
ENG168390-ENG168569-Activation of Write Service for LED calibration values-LED_calibration_value_LMM6_LED9,100 %,108
ENG168390-ENG168570-Activation of Write Service for LED calibration values-LED_calibration_value_LMM7_LED1,100 %,108
ENG168390-ENG168571-Activation of Write Service for LED calibration values-LED_calibration_value_LMM7_LED10,100 %,108
ENG168390-ENG168572-Activation of Write Service for LED calibration values-LED_calibration_value_LMM7_LED11,100 %,108
ENG168390-ENG168573-Activation of Write Service for LED calibration values-LED_calibration_value_LMM7_LED12,100 %,108
ENG168390-ENG168574-Activation of Write Service for LED calibration values-LED_calibration_value_LMM7_LED2,100 %,108
ENG168390-ENG168575-Activation of Write Service for LED calibration values-LED_calibration_value_LMM7_LED3,100 %,108
ENG168390-ENG168576-Activation of Write Service for LED calibration values-LED_calibration_value_LMM7_LED4,100 %,108
ENG168390-ENG168577-Activation of Write Service for LED calibration values-LED_calibration_value_LMM7_LED5,100 %,108
ENG168390-ENG168578-Activation of Write Service for LED calibration values-LED_calibration_value_LMM7_LED6,100 %,108
ENG168390-ENG168579-Activation of Write Service for LED calibration values-LED_calibration_value_LMM7_LED7,100 %,108
ENG168390-ENG168580-Activation of Write Service for LED calibration values-LED_calibration_value_LMM7_LED8,100 %,108
ENG168390-ENG168581-Activation of Write Service for LED calibration values-LED_calibration_value_LMM7_LED9,100 %,108
ENG168390-ENG168582-Activation of Write Service for LED calibration values-LED_calibration_value_LMM8_LED1,100 %,108
ENG168390-ENG168583-Activation of Write Service for LED calibration values-LED_calibration_value_LMM8_LED10,100 %,108
ENG168390-ENG168584-Activation of Write Service for LED calibration values-LED_calibration_value_LMM8_LED11,100 %,108
ENG168390-ENG168585-Activation of Write Service for LED calibration values-LED_calibration_value_LMM8_LED12,100 %,108
ENG168390-ENG168586-Activation of Write Service for LED calibration values-LED_calibration_value_LMM8_LED2,100 %,108
ENG168390-ENG168587-Activation of Write Service for LED calibration values-LED_calibration_value_LMM8_LED3,100 %,108
ENG168390-ENG168588-Activation of Write Service for LED calibration values-LED_calibration_value_LMM8_LED4,100 %,108
ENG168390-ENG168589-Activation of Write Service for LED calibration values-LED_calibration_value_LMM8_LED5,100 %,108
ENG168390-ENG168590-Activation of Write Service for LED calibration values-LED_calibration_value_LMM8_LED6,100 %,108
ENG168390-ENG168591-Activation of Write Service for LED calibration values-LED_calibration_value_LMM8_LED7,100 %,108
ENG168390-ENG168592-Activation of Write Service for LED calibration values-LED_calibration_value_LMM8_LED8,100 %,108
ENG168390-ENG168593-Activation of Write Service for LED calibration values-LED_calibration_value_LMM8_LED9,100 %,108
ENG168390-ENG168594-Activation of Write Service for LED calibration values-LED_calibration_value_LMM9_LED1,37 %,108
ENG168390-ENG168595-Activation of Write Service for LED calibration values-LED_calibration_value_LMM9_LED10,37 %,108
ENG168390-ENG168596-Activation of Write Service for LED calibration values-LED_calibration_value_LMM9_LED11,37 %,108
ENG168390-ENG168597-Activation of Write Service for LED calibration values-LED_calibration_value_LMM9_LED12,37 %,108
ENG168390-ENG168598-Activation of Write Service for LED calibration values-LED_calibration_value_LMM9_LED2,37 %,108
ENG168390-ENG168599-Activation of Write Service for LED calibration values-LED_calibration_value_LMM9_LED3,37 %,108
ENG168390-ENG168600-Activation of Write Service for LED calibration values-LED_calibration_value_LMM9_LED4,37 %,108
ENG168390-ENG168601-Activation of Write Service for LED calibration values-LED_calibration_value_LMM9_LED5,37 %,108
ENG168390-ENG168602-Activation of Write Service for LED calibration values-LED_calibration_value_LMM9_LED6,37 %,108
ENG168390-ENG168603-Activation of Write Service for LED calibration values-LED_calibration_value_LMM9_LED7,37 %,108
ENG168390-ENG168604-Activation of Write Service for LED calibration values-LED_calibration_value_LMM9_LED8,37 %,108
ENG168390-ENG168605-Activation of Write Service for LED calibration values-LED_calibration_value_LMM9_LED9,37 %,108
ENG168403-Reset_of_laser_error_counter,Reset ,1
Elapsed Time: 00:07
adpmap-D7-4K0-941-572-DC_WAUZZZF29MN105510-20210719-1941.CSV
;SW:4K0-941-572-DC   HW:4K0-941-572-D ---  Light Ctrl Right 2
;EV_LMSRightHELLAAU58X,001013,EV_LMSRightHELLAAU58X.rod
;Monday,19,July,2021,19:41:39:35862
ENG168388-ENG168430-Activation of Write Service for Brightness Classes-Brightness_class_ch3_1,1 ,7
ENG168388-ENG168433-Activation of Write Service for Brightness Classes-Brightness_class_ch4_1,3 ,7
ENG168389-ENG168453-Activation of Write Service for headlamp data-Headlamp_part_number,01337702    ,32
ENG168389-ENG168456-Activation of Write Service for headlamp data-Headlamp_production_minutes,23 min,32
ENG168389-ENG168458-Activation of Write Service for headlamp data-Headlamp_production_seconds,32 s,32
Elapsed Time: 00:07
adpmap-DE-4K0-035-502-B_WAUZZZF29MN105510-20210719-1941.CSV
;SW:4K0-035-502-B   HW:4K0-035-502-B ---  Charger 1 for mobile dev
;Component:WLC Front     H14 0061, Coding:400000
;EV_Charg1MobilDevicAU651,004001,EV_Charg1MobilDevicAU651.rod
;Monday,19,July,2021,19:41:50:35862
;VCID: 20128BD02A3B226BAF3-8074
Elapsed Time: 00:01
