Seriously Jacked Up 2012 Jetta SE
bcliles91
Kenbridge, VA, USA
C?ID=446230
Hello all, I would like to thank you in advance for any help you may provide. I picked up a seriously cheap 2012 Jetta SE for about $1,200... I was stoked b/c it is a manual, thought it would be relatively simple and would make an excellent beater car but then I found out exactly how complex VW’s really are… I really can’t even get it inspected in Virginia yet. Hell fire, I thought this would be better than an Audi, BMW, or Mercedes Benz… But I am learning really quickly...
The key broke in half and was stuck inside of the ignition. Had to go to stealership to get that redone. $1,000k later and it cranks. Window regulator and switch got put in. I've done the oil change, air filter, plugs, and some new ignition coils. But throwing parts at it isn't doing the job. I recently acquired VCDS and I can tell it’s a very capable diagnostic program.
Anyway, is this car a flood car? There are SOO many screwed-up modules on a 2012 it’s asinine. I will post up the auto scan and let y’all take a look. If you know how to fix any of the above please let me know.
On the plus side, the radio works and the stick shift is fun. I was really impressed on the back roads in this car. Handles excellently!
Major concerns:
1.) Airbag light r/t passenger seat occupancy. I purchased the under-seat occupancy control module and installed it.
2.) No A/C but worked on the way home with the car??
3.) Check Engine light and the engine is LOUD and whiney.
4.) Tire Pressure light/TPMS (can it be disabled?)
bcliles91
Kenbridge, VA, USA
C?ID=446230
Monday,05,July,2021,23:04:04:48195
VCDS Version: 21.3.0.0  HEX-V2 CB: 0.4543.4
VIN: 3VWBP7AJ0CM317246   License Plate:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 03 08 09 15 17 19 25 56
VIN: 3VWBP7AJ0CM317246   Mileage: 290020km-180210miles
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 CH    HW: 07K 907 309 B
   Component: 2,5l R5/4V      G01 1155
   Revision: T4H04---    Serial number:
   Coding: 0000071
   Shop #: WSC 00066 000 00000
   VCID: 76B5EFBFF4CCF98BA5F-8022
000112 - Sensor for Ambient Air Temperature (G17)
               P0070 - 000 - Malfunction
                    Mileage: 290023 km
                    Date: 2015.11.26
                    Time: 10:56:19
                    Temperature: 29.0°C
                    Temperature: 27.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 12.192 V
000113 - Sensor for Ambient Air Temperature (G17)
               P0071 - 000 - Implausible Signal
                    Mileage: 290023 km
                    Date: 2015.11.26
                    Time: 10:56:19
                    Temperature: 29.0°C
                    Temperature: 27.0°C
                    Voltage: 12.192 V
Readiness: 1110 1101
   Revision: 00H31001
   Coding: B14B440C492308018D0D22E8921F1061A70000
   VCID: 7BA3FE8BC3EEA4E3DA1-802E
                    Reset counter: 126
                    Mileage: 290023 km
                    Date: 2015.11.26
                    Time: 10:57:43
                    Count: 2
                    Count: 28672
                    Count: 16390
                    Count: 43520
                    Count: 512
                    Count: 1278
00667 - Ambient Temperature Signal
                    Fault Status: 01101000
                    Reset counter: 126
                    Mileage: 290023 km
                    Date: 2015.11.26
                    Time: 10:57:43
                    Count: 2
                    Count: 28672
                    Count: 8259
                    Count: 43520
                    Count: 512
                    Count: 1278
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 AP    HW: 5C0 820 047 AP
   Component: J301  Klimaanlage   0203
   Revision: 2001010S    Serial number: 00000000512593
   VCID: 6E85C7DF8C9CC14B6DF-803A
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 126
                    Mileage: 290023 km
                    Date: 2015.11.26
                    Time: 10:57:42
   Part No SW: 5C0 937 086 E    HW: 5C0 937 086 A
   Component: BCM25 JLB M3  H67 0251
   Revision: B0067001    Serial number: 04351204110116
   Coding: 7B994B1808AB0B0000302000240884D400C2502E60000000300000000000
   Shop #: WSC 12345 123 61029
   VCID: 2E0507DF401C814B2DF-807A
   Subsystem 1 - Part No SW: 6R0 959 801 DF    HW: 6R0 959 801 DF
Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  022 1467
   Serial number: 14202743181205073201
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels:
6R0-959-802.CLB
   Component: J387__TSG_BT  002 3464
   Coding: 820000
   Subsystem 3 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3464
   Coding: 800000
   Subsystem 4 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3464
   Coding: 800000
03591 - Control Circuit for Horn
                    Reset counter: 126
                    Mileage: 290023 km
                    Date: 2015.11.26
                    Time: 10:57:46
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   013 0807
   Serial number: 003GTM012L6E
   Coding: 00003936
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 343115B7AEB0AB9B5BB-8060
   Serial number: 6940000Y200001YC2R02
   Coding: 303037
   Serial number: 3572MSME4166255EZZZ-
   Serial number: 3582MSME3C2E635FZZZB
   Serial number: 3516KSME77534211ZZZJ
   Serial number: 3526KSME07642811ZZZJ
   Serial number: 3556LSME596C3E0FZZZF
   Serial number: 3566LSME254A1C12ZZZW
9446128 - Control Module for Seat Occupant Detection
          B1022 F0 [137] - No Basic Setting
                    Reset counter: 126
                    Mileage: 290023 km
                    Date: 2021.07.05
                    Time: 10:57:46
9445973 - Seat occupied recognition control module
          B1022 55 [137] - Not configured
                    Reset counter: 126
                    Mileage: 290023 km
                    Date: 2021.07.05
                    Time: 10:57:46
   Part No SW: 5C6 920 951 B    HW: 5C6 920 951 B
   Component: KOMBI         H04 0604
   Coding: 270201
   Shop #: WSC 00066 000 00122
   VCID: 2A0D0BCF7C74ED6BF17-807E
9453330 - Outside temperature sensor
          B103F 1B [009] - Resistance Too High
                    Reset counter: 126
                    Mileage: 290023 km
                    Date: 2021.07.05
                    Time: 10:57:43
   Part No SW: 6N0 909 901     HW: 5C0 937 086 A
   Component: GW-K-CAN TP20 H67 0251
   Revision: B0067001
   Coding: 102200
   VCID: 70B9D9A79AA8D7BB7F3-8024
   Component: IMMO          H04 0604
   VCID: 6A8DCBCFBCF42D6B317-803E
   Part No SW: 1K0 035 164 D    HW: 1K0 035 164 D
   Component: LOW NAR       H02 0004
   Revision: -----03S    Serial number: VWZ4Z6L3178642
   Coding: 05000400010006
   VCID: 2313E6EB1BDE3C23B21-8076
                    Reset counter: 126
                    Mileage: 290023 km
                    Date: 2015.11.26
                    Time: 10:57:45
                    Reset counter: 126
                    Mileage: 290023 km
                    Date: 2015.11.26
                    Time: 10:57:45
End----------(Elapsed Time: 00:55, VBatt start/end: 12.1V/12.1V)-----------
Hi and welcome.
Lots of things are upset over the OAT sensor. Do you have a wiring diagram?
None of the faults in that scan are indicative of a check-engine light. But I just noticed that the scan is a couple of weeks old.
Suggestion: Scan it again. Then clear all fault codes, take it for a quick trip around the block, and scan it again to see what faults comes back.
bcliles91
Kenbridge, VA, USA
C?ID=446230
I ran a scan today and unfortunately it has all of the same problems appear. I uploaded this b/c I had it handy in my gmail. This car is more difficult than a scan and clear. I forgot to mention my buddy put a new ambient air temp sensor in so it must be the wiring? and I sure don’t have a diagram…
Trowbridge, UK
The idea of doing a scan and clear is to get rid of historical fault codes, so only the 'real' ones are left to make fault finding easier.
See how in Uwe's post (and here) wiring diagram is a different color, that's because it's a link to where you can download all the official documents about your car as PDF files for a 24 hour fee of $35 (IIRC).
bcliles91
Kenbridge, VA, USA
C?ID=446230
Thursday,22,July,2021,20:48:55:48195
VIN: 3VWBP7AJ0CM317246   License Plate: 07222021
Mileage: 290040km-180222mi   Repair Order:
VIN: 3VWBP7AJ0CM317246   Mileage: 290040km-180222miles
   Coding: 0000071
               P0070 - 000 - Malfunction - MIL ON
                    Fault Status: 11100000
                    Mileage: 290023 km
                    Date: 2015.11.26
                    Time: 10:56:19
                    Temperature: 29.0°C
                    Temperature: 27.0°C
                    Voltage: 12.192 V
                    Mileage: 290023 km
                    Date: 2015.11.26
                    Time: 10:56:19
                    Temperature: 29.0°C
                    Temperature: 27.0°C
                    Voltage: 12.192 V
000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
               P0016 - 000 - Incorrect Correlation - MIL ON
                    Mileage: 290023 km
                    Date: 2015.12.05
                    Time: 08:49:24
                    RPM: 744 /min
                    Load: 24.3 %
                    Speed: 7.0 km/h
                    Temperature: 36.0°C
                    Temperature: 30.0°C
                    Voltage: 13.589 V
Readiness: 1010 1100
   Revision: 00H31001
                    Reset counter: 126
                    Mileage: 290023 km
                    Date: 2015.11.26
                    Time: 10:57:43
                    Count: 2
                    Count: 28672
                    Count: 8259
                    Count: 43520
                    Count: 512
                    Count: 1278
                    Reset counter: 126
                    Mileage: 290023 km
                    Date: 2015.11.26
                    Time: 10:57:43
                    Count: 2
                    Count: 28672
                    Count: 16390
                    Count: 43520
                    Count: 512
                    Count: 1278
                    Reset counter: 126
                    Mileage: 290023 km
                    Date: 2015.11.26
                    Time: 10:57:42
   Subsystem 1 - Part No SW: 6R0 959 801 DF    HW: 6R0 959 801 DF  Labels: 6R0-959-801.CLB
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Coding: 820000
   Coding: 800000
   Coding: 800000
                    Reset counter: 126
                    Mileage: 290023 km
                    Date: 2015.11.26
                    Time: 10:57:46
   Coding: 00003936
   Coding: 303037
                    Reset counter: 126
                    Mileage: 290023 km
                    Date: 2021.07.05
                    Time: 10:57:46
9445972 - Seat occupied recognition control module
          B1022 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 129
                    Mileage: 290044 km
                    Date: 2021.07.20
                    Time: 07:38:58
          B1022 55 [008] - Not configured
                    Reset counter: 169
                    Mileage: 290023 km
                    Date: 2021.07.05
                    Time: 10:57:46
   Coding: 270201
                    Reset counter: 126
                    Mileage: 290023 km
                    Date: 2021.07.05
                    Time: 10:57:43
   Revision: B0067001
   Coding: 102200
                    Reset counter: 126
                    Mileage: 290023 km
                    Date: 2015.11.26
                    Time: 10:57:45
                    Reset counter: 126
                    Mileage: 290023 km
                    Date: 2015.11.26
                    Time: 10:57:45
