Tiguan RNS315 Help after car Battery died.
krtbyl
Hillsboro, MO, USA
C?ID=261463
I am trying to resolve an issue with a backup camera on my 2013 VW Tiguan 2.0T TSI SEL. The car had a dying battery after sitting for about a month and it wouldnt start. Lights flashed and it acted hit and miss with trying to start it using the Push to start... I knew better than to try to Jump start the car as these newer cars have pretty touchy electrical systems.. I charged the battery up and then started the car. Once running I found my car with the dreaded Dead Head unit.. no power. VCDS showed
01304 - Radio
After validating power and all fuses were still good, I tested this with the Radio from my Jetta and found the Radio was DOA as the Jetta Radio powered right up. Fast forward I bought a used Radio from a 2013 Beetle.. still a RNS315 and installed it.. Everything comes back up and works properly except for the Backup camera. it tells Camera is not responding and now it shows a warning sign on the lower bar and looks like it is trying to start Parking sensor which my car does not have..
I check the VCDS and cleared all codes and now everything is fine til I put car in reverse and then the backup camera throws this code.
Address 6c: Back-up Cam. Labels:5N0-907-441.clb
Part No SW: 5N0-907-441-A HW: 5N0907441A
Component: J772__Rearview 0030
Revision: 00H11000 Serial Number: 525PA8-J255288
Coding: 0110010
Shop #: WSC 01324 011 00200
VCID: 2D1D9AB7F7682EBF02D432-8078
02283 - Video Connection to Output [End Unit]
Fault Status: 00101011
Reset Counter: 81
Mileage: 166177 km
Date: 2038.14.10
Time: 06:01:36
: Term 15 On
: Reverse ON
Count: 4
I did noticed from a previous scan when the radio was dead that the Backup camera was fine but the VCID had changed.
Here is the previous scan..
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 5N0 907 441 A HW: 5N0 907 441 A
Revision: 00H11000 Serial number: 525PA8-J255288
Coding: 0110010
VCID: AD125F0E34D317E3D8-80F8
Same Coding in it, but I am thinking i need to make a change something somewhere to tell the radio that it has a different Backup camera system in it now than previously or could it be that the Camera module got smoked as well. It is still responding to the Scan from VCDS so not sure that is the case. Just looking for some better direction instead of throwing parts at it.. Also note Backup lights and rear wiper work just fine on the car as well as everything else Just getting backup camera issues. Any help or advice would be greatly appreciated.
Moving to Car Repair Support.
Please post a complete Auto-Scan for better context.
krtbyl
Hillsboro, MO, USA
C?ID=261463
Here is a complete Scan prior to replacing the radio after the Battery failure and then i will incluse a Scan in the next post after the radio was replaced
Wednesday,14,July,2021,21:49:13:49833
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4543.4
VIN: WVGBV7AX2DW525316   License Plate:
Chassis Type: AX-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 25 2B 2E 36 37 42 44 46 4C
          4F 52 53 55 56 62 69 6C 72
VIN: WVGBV7AX2DW525316   Mileage: 166160km-103247miles
37-Navigation -- Status: Cannot be reached 1100
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 997 027 R    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2 06 0401
   Revision: P3H07---    Serial number:
   Coding: 0423010A190F0160
   Shop #: WSC 39776 001 1048576
   VCID: C4C41AAA8759F6AB27-8090
   Part No SW: 09G 927 750 NK    HW: 09G 927 750 NK
   Component: AQ 250 6F           2253
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 875ECDA6F6EF1DB302-80D2
   Part No SW: 5N0 614 109 AR    HW: 5N0 614 109 AR
   Component: J104   C6 450M VD28 0006
   Revision: --H07---    Serial number: 00000005989661
   Coding: 0005161
   VCID: FBB6A156BA27495316-80AE
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 085 0902
   Revision: 00085000    Serial number: 0180895323
   Coding: 030C0C
   VCID: B4244A6A1FF9462B97-80E0
   Part No SW: 3AA 907 044 AN    HW: 3AA 907 044 AN
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 0010001002
   VCID: FCB4A24A77294E6B1F-80A8
   Part No SW: 5K0 937 086 N    HW: 5K0 937 086 N
   Component: BCM PQ35 M    021 0068
   Revision: BJ021001
   Coding: 6F180A1B88232EC4008800C134000D444855AE06576D8DF0E4840000A040
   VCID: BFCE15462EBF95737A-80EA
   Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 07071  013 0204
   Serial number: N1955119   °204!
   Coding: 009795
   Component: RLS 100712 05  54  0403
   Coding: 02304D
   Part No SW: 5N0 959 655 S    HW: 5N0 959 655 S
   Component: J234__2VB VW10 HI   2118
   Revision: 24017000    Serial number: 003L6PDDY5MD
   Coding: 0022082
   VCID: CDD23F8E541337E3F8-8098
   Subsystem 1 - Part No: 5N0 959 339 B
   Subsystem 2 - Serial number: 00000000008R06
   Subsystem 3 - Serial number: 0014.05.120000300000630001ÿ†63
   Subsystem 4 - Serial number: 630001ÿ†6332MTS634311772 ÿ†63
   Subsystem 5 - Serial number: 11772 ÿ†6342MTS641570891 ÿ†63
   Subsystem 6 - Serial number: 70891 ÿ†6351HTS6PFIPABKJ ÿ†63
   Subsystem 7 - Serial number: PABKJ ÿ†6361HTS6B1OPABKR ÿ†63
   Subsystem 8 - Serial number: PABKR ÿ†63727TS62FHI1BKJ ÿ†63
   Subsystem 9 - Serial number: I1BKJ ÿ†63827TS6UMF47BKR ÿ
   Subsystem 10 - Serial number: 47BKR ÿ
   Part No SW: 5K0 953 501 BL    HW: 5K0 953 569 L
   Revision: FF010041    Serial number: 20120709300286
   Coding: 110A140000
   VCID: F5A2B76E54031F2360-80A0
   Component: E221__MFL-TAS  H31 0033
   Coding: 820000
   Part No SW: 5N0 920 973 B    HW: 5N0 920 973 B
   Component: KOMBI         H05 0705
   Coding: 211F01
   VCID: B32649761AF741138E-80E6
   Part No SW: 7N0 907 530 T    HW: 7N0 907 530 K
   Component: J533  Gateway H40 1632
   Revision:   H40       Serial number: 070712F6000233
   Coding: 356002
   VCID: C1CA13BE584BE3830C-8094
                    Mileage: 166161 km
                    Date: 2015.12.05
                    Time: 09:05:60
01304 - Radio
                    Mileage: 166161 km
                    Date: 2015.12.05
                    Time: 09:05:60
   Part No SW: 0AY 907 554 E    HW: 0AY 907 554 E
   Component: Haldex 4Motion      0043
   Coding: 0000005
   Component: IMMO          H05 0705
   Coding: 000007
   VCID: EA9894120DBDC0DBFD-80BE
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 12000161251001
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: AF2E4506F6DF65F3EA-80FA
          U1400 00 [008] - -
          [Under voltage (temporary)]
                    Reset counter: 73
                    Mileage: 165999 km
                    Date: 2021.06.30
                    Time: 06:29:46
                    ELV State: 0A
                    Information Clamps: 00 00
                    CoCo State: 30 01
                    WFS State: 00 1A
                    Vehicle speed: 0.00 km/h
                    Voltage: 46
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662989334
   Coding: 020100
   VCID: AA185412C53D00DB3D-80FE
                    Reset counter: 72
01304 - Radio
                    Reset counter: 32
00464 - Control Module with Display for Radio and Navigation (J503)
                    Reset counter: 32
   Part No SW: 561 959 760 A    HW: 561 959 760 A
   Component: MEM-FS        H04 0181
   Revision: AA000000    Serial number: 00000027499024
   Coding: 00581B0000000000000001010101202020202121202020
   VCID: A10AB33EB80BC3836C-80F4
                    Reset counter: 73
                    Mileage: 165999 km
                    Date: 2015.11.21
                    Time: 00:00:30
                    Reset counter: 73
                    Mileage: 166045 km
                    Date: 2015.11.21
                    Time: 10:07:28
Address 37: Navigation
   Part No SW: 5N0 959 701 G    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0503
   Revision: 12110009    Serial number: 0005306656
   Coding: 0015BE
   VCID: B93A7B5E389BBB4344-80EC
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  008 1504
   Serial number: 00000007013525
   Coding: 000490
   Part No SW: 5N1 909 144 N    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.286 1101
   Revision: 1AH03837    Serial number: 00121860275301
   Coding: 0000258
   VCID: BD326F4EE4B3876368-80E8
   Part No SW: 7N0 907 532     HW: 7N0 907 530 K
   Component: EZE_2         H40 1632
   Coding: 050B0500
   VCID: EFAE85063E5F25F3AA-80BA
   Component: J245EE20SKB13  H03 0220
   Component: J394EE20SKB13  H03 0220
   Part No SW: 5N0 959 702 G    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0503
   Revision: 14110009    Serial number: 0005312067
   Coding: 0015BE
   VCID: BA3864523D9DB05B4D-80EE
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  008 1504
   Serial number: 00000007012192
   Coding: 000490
   Revision:   H19       Serial number: 00000000333466
   Coding: 0026156
   VCID: B6207062C185543BA9-80E2
   Component: AFS-ECU       H04 0111
   Coding: 041A00010B000400
   VCID: B73E7D660E8FAD33B2-80E2
   Subsystem 1 - Part No: 4H0 941 329   Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 4H0 941 329   Labels: 3D0-941-329.CLB
Address 56: Radio
   Revision: 3A001001    Serial number: 00008030191262
   Coding: 420D000100000000
   VCID: B02C467AE3E17A0BF3-80E4
   Coding: 0110010
                    Reset counter: 72
                    Mileage: 165999 km
                    Date: 2015.11.21
                    Time: 06:29:48
                        Reverse OFF
                    Count: 3
End----------(Elapsed Time: 01:50, VBatt start/end: 12.2V/12.2V)-----------
krtbyl
Hillsboro, MO, USA
C?ID=261463
Here is the complete Scan once the Radio was replaced
#hndoc:?docid=00006E82&xt=hnh:F52BAF0B3A422BA96559AA19B5DCE18C91175E52D0BF3F141FC9FEF628610175
VCDS Mobile 0.4544.0.4
VCDS Mobile: 0.4544
Data Version: 30000060
05-Acc/Start Auth. -- Status: OK 16000
08-Auto HVAC -- Status: OK 16000
09-Cent. Elect. -- Status: OK 16000
16-Steering wheel -- Status: OK 16000
17-Instruments -- Status: OK 16000
25-Immobilizer -- Status: OK 16000
2B-Steer. Col. Lock -- Status: OK 16000
36-Seat Mem. Drvr -- Status: OK 16000
42-Door Elect, Driver -- Status: OK 16000
46-Central Conv. -- Status: OK 16000
52-Door Elect, Pass. -- Status: OK 16000
62-Door, Rear Left -- Status: OK 16000
69-Trailer -- Status: OK 16000
72-Door, Rear Right -- Status: OK 16000
Address 01: Engine    Labels: 06J-906-026-CCT.clb
    Part No SW: 06J 997 027 R    HW: 06J907309A
    Revision: P3H07---    Serial Number:
    VCID: 44CBDF1344E2CFF7FDBA2F-8011
No fault codes found.
    Part No SW: 09G 927 750 NK    HW: 09G927750NK
    Revision: 00H97000    Serial Number:
    Coding: 0000840
    VCID: 8751881FB554A4EF585810-80D2
    Part No SW: 5N0 614 109 AR    HW: 5N0614109AR
    Component: J104  C6 450M VD29  0006
    Revision: --H07---    Serial Number: 00000005989661
    Coding: 0005161
    VCID: 7BB964EF799C700FCCC08C-802E
Address 05: Acc/Start Auth.  (J518)    Labels: 5K0-959-434.clb
    Revision: 00085000
    Coding: 030C0C
    ROD: N/A
    VCID: 342B8FD31442E7774D1AFF-8061
    No ASAM data for: "EV_KESSYPQ35G"
Address 08: Auto HVAC  (J255)    Labels: 5K0-907-044.clb
    Revision: 00001K02
    Coding: 0010001002
    ROD: N/A
    VCID: 7CBB67F37C92EF37C5CA97-8029
    No ASAM data for: "EV_Climatronic"
Address 09: Cent. Elect.  (J519)    Labels: 1K0-937-08x-09.clb
    Revision: BJ021001
    VCID: 3FC1D0FF2D042C2FA06878-806A
    Subsystem 1 -     Part No SW: 5N1-955-119    Labels: 1Kx-955-119.clb
    Component: Wischer 07071013 0204
    Coding: 009795
    Subsystem 2 -     Part No SW: 1K0-955-559-AH    Labels: 1K0-955-559-AG.clb
    Component: RLS 100712 0554  0403
    Coding: 02304D
    Part No SW: 5N0 959 655 S    HW: 5N0959339B
    Revision: 24017000    Serial Number: 003L6PDDY5MD
    Coding: 0022082
    VCID: 4DDDFA3797A80EBF221492-8018
    Subsystem 1 -     Part No SW: 5N0-959-339-B
    Serial Number: 00000000008R06
    Subsystem 2 -     Serial Number: 6332MTS634311772
    Subsystem 3 -     Serial Number: 6342MTS641570891
    Subsystem 4 -     Serial Number: 6351HTS6PFIPABKJ
    Subsystem 5 -     Serial Number: 6361HTS6B1OPABKR
    Subsystem 6 -     Serial Number: 63727TS62FHI1BKJ
Address 16: Steering wheel  (J527)    Labels: 5K-16.lbl
    Revision: FF010041
    Coding: 110A140000
    ROD: N/A
    VCID: 75AD72D75FB8BE7FBA84CA-8020
    No ASAM data for: "EV_VW360SteerWheelUDS"
Address 17: Instruments  (J285)    Labels: 5K0-920-xxx-17.clb
    Coding: 211F01
    ROD: N/A
    VCID: 33298CCF114CE04F5410F4-8066
    No ASAM data for: "EV_Kombi_UDS_VDD_RM09"
Address 19: CAN Gateway  (J533)    Labels: 7N0-907-530-V2.clb
    Revision:  H40
    Coding: 356002
    VCID: 41C5D6075BF05ADFD69C0E-8014
    Part No SW: 0AY 907 554 E    HW: 0AY907554E
    Coding: 0000005
Address 25: Immobilizer  (J334)    Labels: 5K0-920-xxx-25.clb
    Coding: 000007
    ROD: N/A
    VCID: EA97D1AB8606E187A736D1-80BF
    No ASAM data for: "EV_Immo_UDS_VDD_RM09"
Address 2B: Steer. Col. Lock  (J764)    Labels: 5K0-905-861.clb
    Revision: 00000000
    ROD: N/A
    VCID: 2F2180BFFD64C4AF30C8C8-807A
    No ASAM data for: "EV_ELVMarquMPVW36X"
Address 2E: Media Player 3  (J650)    Labels: 5N0-035-342.lbl
    Revision: A1001003
    Coding: 020100
    VCID: 2A1791ABC686B987E7B611-807F
    Revision: AA000000
    VCID: 21057687BBB07ADFB65CAE-8074
Address 37: Navigation  (J794)    Labels: 1K0-035-27x-37.clb
    Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
    Component: RNS315-NAR    H53 0319
    Coding: 00090001010002000000100A
    Shop #: WSC 01383 790 50316
    ROD: N/A
    VCID: 250D6297AF988EFFCA645A-8070
    No ASAM data for: "EV_RNS315NARV2UDS"
Address 42: Door Elect, Driver  (J386)    Labels: 3C0-959-70X-GEN4.clb
    Revision: 12110009
    Coding: 0015BE
    ROD: N/A
    VCID: 3935BEE733201A1F9E2CB6-806C
    No ASAM data for: "EV_TSGFPQ35BRFVW46X"
    Part No SW: 5N1 909 144 N    HW: 5N1909148G
    Revision: 1AH03837    Serial Number: 00121860275301
    Coding: 0000258
    VCID: 3D3DAAF72708BE3FB27462-8068
Address 46: Failed to respond
Address 4F: Centr. Electr. II  (J520)    Labels: 1K0-907-532.clb
    Revision:  H40
    Coding: 050B0500
    VCID: EFA1C0BFBDE41CAFF04888-80BA
    Subsystem 1 -     Part No SW: 8R0-959-591-A
    Component: J245EE20SKB13H03 0220
    Subsystem 2 -     Part No SW: 8R0-959-591-A
    Component: J394EE20SKB13H03 0220
Address 52: Door Elect, Pass.  (J387)    Labels: 3C0-959-70X-GEN4.clb
    Revision: 14110009
    Coding: 0015BE
    ROD: N/A
    VCID: 3A37A1EB36261107975641-806F
    No ASAM data for: "EV_TSGBPQ35BRFVW46X"
    Part No SW: 3AA 907 801 H    HW: 3AA907801H
    Revision:  H19      Serial Number: 00000000333466
    Coding: 0026156
    VCID: 362FB5DB023E6D67730E95-8063
Address 55: Xenon Range  (J745)    Labels: 5M0-907-357-V3.clb
    Revision: --------
    ROD: N/A
    VCID: 3731B8DF05340C6F6838A0-8062
    No ASAM data for: "EV_HeadlRegulVWAFSPt"
Address 69: Trailer  (J345)    Labels: 1K0-907-383-V2.clb
    Revision: 3A001001
    VCID: 302383C3E05AC35729F2D3-8065
    Part No SW: 5N0 907 441 A    HW: 5N0907441A
    Coding: 0110010
End--(Elapsed Time: 02:53, VBatt start/end: 12.5/12.5 Vign: 12.5)-
It does not look like your RNS has RVC enabled in Coding. See Byte 3. I suggest using VCDS for this rather than VCDS-Mobile.
krtbyl
Hillsboro, MO, USA
C?ID=261463
Ok so I went in to the Long coding Helper on byte 3 of the Navigation unit and clicked the enabled Rear view Camera and updated the Long code. Now I am getting and error Control Module Incorrectly Coded. I went through all the models and compared them to what they were before and they all seem to match. That was the first time I have done any kind of Coding with the VCDS and it is Extremely Slick.. I have attached what the latest Auto Scan from the Car now.. I still see in the lower right hand corner what looks like is Park assist which my Tiguan never had.
Wednesday,21,July,2021,21:39:24:49833
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4544.4
VIN: WVGBV7AX2DW525316   License Plate: RC9
Mileage: 166510km-103464mi   Repair Order:
VIN: WVGBV7AX2DW525316   Mileage: 166510km-103464miles
   VCID: 44C49AAA075976ABA7-8010
   Coding: 0000840
   VCID: 075E4DA676EF9DB382-8052
   Component: J104   C6 450M VD2E 0006
   Coding: 0005161
   VCID: 7BB621563A27C95396-802E
   Coding: 030C0C
   VCID: 3424CA6A9FF9C62B17-8060
   Revision: 00001K02
   Coding: 0010001002
   VCID: 7CB4224AF729CE6B9F-8028
   Revision: BJ021001
   VCID: 3FCE9546AEBF1573FA-806A
   Coding: 009795
   Coding: 02304D
   Coding: 0022082
   VCID: 4DD2BF8ED413B7E378-8018
   Coding: 110A140000
   VCID: 75A2376ED4039F23E0-8020
   Coding: 820000
   Coding: 211F01
   VCID: 3326C9769AF7C1130E-8066
   Coding: 356002
   VCID: 41CA93BED84B63838C-8014
   Coding: 0000005
   Coding: 000007
   VCID: 6A9814128DBD40DB7D-803E
   VCID: 2F2EC50676DFE5F36A-807A
   Coding: 020100
   VCID: 2A18D412453D80DBBD-807E
   VCID: 210A333E380B4383EC-8074
   Serial number: VWZAZ2M4251703
   Coding: 00090041010002000000100A
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 2502272E2423AFA390-8070
   Component: NAR_V3_(0037)  0037
1048646 - Rear View Camera
          B1102 31 [009] - No Signal
                    Reset counter: 46
                    Mileage: 166514 km
                    Date: 2021.07.21
                    Time: 09:15:03
          B11CF 53 [009] - Deactivated
                    Reset counter: 46
                    Mileage: 166514 km
                    Date: 2021.07.21
                    Time: 09:14:41
1048641 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [ECU wrong coded]
                    Reset counter: 46
                    Mileage: 166514 km
                    Date: 2021.07.21
                    Time: 09:14:42
                    Correction for sound system: OK
                    Traffic sign display: OK
                    CD-Changer: OK
                    Status of antenna 2 for radio: OK
                    Digital radio (DAB): OK
                    Antenna diagnostic: OK
                    Telephone baseplate diagnostic: OK
                    Speaker status: OK
                    Rearview camera: Malfunction
                    Telephone Transceiver: OK
   Coding: 0015BE
   VCID: 393AFB5EB89B3B43C4-806C
   Slave Driver:
   Coding: 000490
   Coding: 0000258
   VCID: 3D32EF4E64B30763E8-8068
   Coding: 050B0500
   VCID: 6FAE0506BE5FA5F32A-803A
   Coding: 0015BE
   VCID: 3A38E452BD9D305BCD-806E
   Slave Passenger:
   Coding: 000490
   Coding: 0026156
   VCID: 3620F0624185D43B29-8062
   VCID: 373EFD668E8F2D3332-8062
   VCID: 302CC67A63E1FA0B73-8064
   Coding: 0110010
   VCID: 2D12DF0EB4D397E358-8078
                    Reset counter: 46
                    Mileage: 166514 km
                    Date: 2015.12.12
                    Time: 09:15:03
                        Reverse ON
                    Count: 4
End----------(Elapsed Time: 01:38, VBatt start/end: 12.6V/12.5V)-----------
Where are you seeing that?
I think the "Incorrectly Coded" fault is more likely due to the fact that you're configured for a Fender Sound System, and I see no sound system / amplifier in this vehicle. You might try setting that to Sound System not Installed in Byte 1.
krtbyl
Hillsboro, MO, USA
C?ID=261463
Uwe Thank you so much for the help and direction on this. I will give that a try and see what happens!
krtbyl
Hillsboro, MO, USA
C?ID=261463
Uwe I am seeing the what Looks like Park assist at the lower right hand corner of the stereo when the car is put in reverse. I will try to capture that with a picture and attach it. I am out of town for the weekend so I will try to get it back on here by Monday, maybe sooner.. Sorry I missed the question the first time I read that.
