MIB2STD in MK6 - mute/volume while parking
swenak
Czech Republic
C?ID=236893
Hi,
I have retrofitted MIB2STD in VW Golf MK6 (including 5F support gateway). Only proglem is, that cant code (adapt) mute/volume while parking. I set adaptation it in 5F-Information Electr., in 10-Park/Steer Assist too, but nothing changed, radio dont change volume/dont mute while parking. Is that possible?
Thanks.
CineXMike
C?ID=222249
Hi,
Yes this is possible.
I have a Golf MK6 with MIB2 aswell.
Here have an autoscan:
Wednesday,25,November,2020,10:49:18:10011
VCDS Version: 20.4.2.0 (x64)
VIN: WVWZZZ1KZBW183224   License Plate: SJ170T
Mileage: 71870km-44657mi   Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 25 42 44 46 4C 4F 52 5F A5
VIN: WVWZZZ1KZBW183224   Mileage: 71870km-44657miles
15-Airbags -- Status: Cannot be reached 1100
4C-Tire Pressure II -- Status: Cannot be reached 1100
Address 01: Engine (J623-CBZA)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 AK    HW: 03F 906 070 B
   Component: SIMOS10.12H03 9673
   Revision: --H03---    Serial number: 00000000000000
   Coding: 002500D6232400080000
   ASAM Dataset: EV_ECM12TFS02103F906070AK 004008
   ROD: EV_ECM12TFS02103F906070AA_004_VW32.rod
   VCID: 6BFB2E2082A2EBDED6-803E
6051 - No Communications with Airbag Control Module
          U0151 00 [039] - -
                    Mileage: 71874 km
                    Date: 2020.11.25
                    Time: 19:41:34
                    Engine speed: 849.00 /min
                    Normed load value: 13.3 %
                    Coolant temperature: 41 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 14.015 V
                    Time since engine start: 27.5 s
                    Engine torque: 29.28125 Nm
                    Accelerator pedal travel-Accelerator position: 0.00 %
                    Ignition angle of current cylinder: actual value-Ignition angle: actual: -0.750 °
Readiness: 0110 0101
   Part No SW: 0AM 300 050 L    HW: 0AM 927 769 D
   Component: GSG DSG AG7     403 9033
   Revision: 00040034    Serial number: CU501011205939
   Shop #: WSC 00191 264 15243
   VCID: 3245F344AD087A16D5-8066
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: 0000000000000000000000000000000000000000
   VCID: 7EDD1774E9D06E7661-802A
                    Reset counter: 214
                    Date: 2020.11.25
                    Time: 19:41:49
                    Count: 3
                    Count: 20992
                    Count: 195
                    Count: 50688
                    Fault Status: 01100101
                    Reset counter: 214
                    Mileage: 71874 km
                    Date: 2020.11.25
                    Time: 19:41:48
                    Count: 3
                    Count: 2
                    Count: 25088
                    Count: 212
                    Count: 50944
                    Reset counter: 214
                    Mileage: 71874 km
                    Date: 2020.11.25
                    Time: 19:41:48
                    Count: 3
                    Count: 2
                    Count: 25088
                    Count: 279
                    Count: 50944
                    Reset counter: 214
                    Mileage: 71874 km
                    Date: 2020.11.25
                    Time: 19:41:48
                    Count: 3
                    Count: 2
                    Count: 25088
                    Count: 295
                    Count: 50944
                    Reset counter: 214
                    Mileage: 71874 km
                    Date: 2020.11.25
                    Time: 19:41:48
                    Count: 3
                    Count: 2
                    Count: 25088
                    Count: 270
                    Count: 50944
00150 - Plausibility Brake Booster System
                    Reset counter: 214
                    Mileage: 71874 km
                    Date: 2020.11.25
                    Time: 19:41:48
                    Count: 3
                    Count: 2
                    Count: 25088
                    Count: 398
                    Count: 51200
                    Count: 256
   Part No SW: 5ND 907 044 E    HW: 5ND 907 044 E
   Component: Climatronic   H03 0404
   Revision: 00001K02
   Coding: 0000000000
   VCID: 44A9A59CCFBCC4A677-8010
9496597 - Sunlight Photo Sensor
          B10E8 15 [009] - Open or Short to Plus
                    Reset counter: 214
                    Mileage: 71874 km
                    Date: 2020.11.25
                    Time: 19:41:57
9496613 - Sunlight Photo Sensor
                    Reset counter: 214
                    Mileage: 71874 km
                    Date: 2020.11.25
                    Time: 19:41:57
13636352 - Control module not coded
          U1013 00 [009] - -
                    Reset counter: 214
                    Mileage: 71874 km
                    Date: 2020.11.25
                    Time: 19:41:57
13701600 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 214
                    Mileage: 71874 km
                    Date: 2020.11.25
                    Time: 19:41:57
   Part No SW: 1K0 937 086 J    HW: 1K0 937 086 J
   Component: BCM PQ35  M+  103 0615
   Revision: 00103 AD
   Coding: 40180A38CC33F390600C0089740081EC47710088736D8D60648060200040
   VCID: 3753C250866A9F3EE2-8062
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 04121  26  0512
   Coding: 009F95
   Component: RLS 161210 05  54  0403
   Coding: 0730AD
                    Reset counter: 214
                    Mileage: 71874 km
                    Date: 2020.11.25
                    Time: 19:42:16
                    Voltage: 14.00 V
                        Term 50 Off
03395 - Control Module for High Beam Assistant
                    Reset counter: 214
                    Mileage: 71874 km
                    Date: 2020.11.25
                    Time: 19:42:16
                    Voltage: 14.00 V
                        Term 50 Off
Address 10: Park/Steer Assist (J791)       Labels:. 1T0-919-475.clb
   Part No SW: 1T0 919 475 P    HW: 3T0 919 475 C
   Component: PARKHILFE PLA H08 0116
   Revision: --------    Serial number: 13991032216273
   Coding: 10810A
   VCID: 48B1B1ACFB94E0C69B-801C
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 214
                    Mileage: 71874 km
                    Date: 2020.11.25
                    Time: 19:42:23
                    Temperature: 16.0°C
Address 13: Auto Dist. Reg
Address 15: Airbags
   Part No SW: 5K0 953 507 AJ    HW: 5K0 953 549 B
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number: WHRPIƒhtHHHfg
   Coding: 189A100002
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 78D1016CC3F450462B-802C
   Component: E221__MFL-TK6  H07 0022
   Serial number: 50000000000000803283
   Coding: E30000
267264 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 214
                    Mileage: 71874 km
                    Date: 2020.11.25
                    Time: 19:42:41
   Part No SW: 5K7 920 882 C    HW: 5K7 920 882 C
   Component: KOMBI         H02 1104
   Coding: 111D020000
   Shop #: WSC 00040 040 00011
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
   VCID: 3753C2508E6A9F3EE2-8062
12669184 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 214
                    Mileage: 71874 km
                    Date: 2020.11.25
                    Time: 19:41:22
   Part No SW: 7N0 907 530 AS    HW: 7N0 907 530 AN
   Component: J533  Gateway X56 1653
   Revision:   X56       Serial number: 240812F2001807
   Coding: 350002
   Shop #: WSC 26072 001 104857
   VCID: 01276C88982E118E1C-8054
                    Reset counter: 214
                    Mileage: 71874 km
                    Date: 2020.11.25
                    Time: 19:42:50
03109 - Tire Pressure Monitoring Control Module 2 (J793)
                    Reset counter: 214
                    Mileage: 71874 km
                    Date: 2020.11.25
                    Time: 19:42:54
02001 - Data-Bus Automatic Distance Regulation
                    Reset counter: 214
                    Mileage: 71874 km
                    Date: 2020.11.25
                    Time: 19:42:50
   Component: IMMO          H02 1104
   VCID: 6AF52B248D58F2D6AD-803E
   Part No SW: 5K0 959 701 C    HW: 5K0 959 701 C
   Component: Tuer-SG         009 2119
   Coding: 0012342
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 251    3501
   Revision: 00H20000
   VCID: 3957C468707E894E14-806C
02797 - Control Module for Directional Stabilization Assistance (J759)
                    Reset counter: 214
                    Mileage: 71874 km
                    Date: 2020.11.25
                    Time: 19:43:07
                    Voltage: 14.13 V
                        DU
                    Temperature: 22.0°C
                    RPM: 752 /min
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         X56 1653
   Coding: 00000000
   VCID: 6FC33A30BEBA17FEFA-803A
   Part No SW: 5K0 959 702 E    HW: 5K0 959 702 E
   Component: Tuer-SG         009 2151
   Coding: 0012598
   VCID: 354FC8585C666D2EF0-8060
   Part No SW: 5C0 035 680 E    HW: 5C0 035 680 E
   Component: MU-S-ND-ER    H31 0368
   Serial number: VWZAZ2S5402550
   Coding: 02731001AA0000001111120100880A001F0100C4002001000F
   Shop #: WSC 35110 790 50316
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 236B06002AF2E39E2E-8076
   Subsystem 1 - Part No SW: 5NA 919 866 AR    HW: -----------
   Component: ECE AS 20/21  --- 1430
          B201A 00 [009] - -
                    Reset counter: 214
                    Mileage: 71874 km
                    Date: 2020.11.25
                    Time: 19:43:28
                    Voltage terminal 30: 13.6 V
                    Status_Software_Version_Management-module_name:
          U1101 00 [009] - Active
                    Reset counter: 214
                    Mileage: 71874 km
                    Date: 2020.11.25
                    Time: 19:43:28
                    Voltage terminal 30: 13.5 V
1564 - Microphone 1
          B129B 13 [009] - Open Circuit
                    Reset counter: 214
                    Mileage: 71874 km
                    Date: 2020.11.25
                    Time: 19:43:28
                    Voltage terminal 30: 13.4 V
7201 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 214
                    Mileage: 71874 km
                    Date: 2020.11.25
                    Time: 19:43:30
                    BAP-BAP_Function_ID: 02
0011 - Digital Radio Antenna
          B1103 13 [009] - Open Circuit
                    Reset counter: 214
                    Mileage: 71874 km
                    Date: 2020.11.25
                    Time: 19:43:28
                    Status of digital radio antenna 1-Antenna current: 0 mA
                    Status of digital radio antenna 1-Connection between radio and antenna amplifier: Open circuit
                    Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Not available
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 0.000000
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 0.000000
Address A5: Frt Sens. Drv. Assist
End-------------------------(Elapsed Time: 01:54)--------------------------
If needed i can provide an adaptation map later today.
dieseltje
The Netherlands
C?ID=148044
If you have VCP you can upload dataset into de DM with speach enhancement. With that option you can adjust it. Have done it also with my DM.
kamold
Australia
C?ID=241363
Check your adaptation channels for PDC Audio lowering. Should be activated, and messagebus set to terminal 15.
Spacewalker
Poland
C?ID=159607
I think this is only work if you use 1K8 PDC
swenak
Czech Republic
C?ID=236893
Dont have VCP, only VCDS and ODIS.
This I have, but same.
Hi,
I mean, that adaptation is need, because conding is simple.
Maybe problem is, that now I have PDC disabled, because I have now only 10 sensors installed (2 rear are in plan) and with activa PDC ot not work? But front/rear sensors work correctly.
