Just another A6 3.0T O2 sensor thread (graphs and videos!!)
pouliotk2441
Massachusetts, USA
C?ID=292557
Hey guys,
Coming from the 2j/standalone platform so please have some patience lol... I'm trying to help my father out with his '12 A6, 3.0T. Its got downpipes, an upper pulley and a stage 2 GIAC tune. It began with slow response O2 sensor codes and cat efficiency codes. All O2's were changed, but found a few injectors were leaking so they were all replaced along with coil packs... He's been trying to get an inspection sticker but still hasn't been able to due to the same codes. About a week ago he informed me he had the Ross-Tech cable so I've been trying to research and figure it out for him... I did add the straight catted spacers that just set the O2 slow response codes off for both sides immediately. So I pulled them and put the O2's back in as normal. It passed all the Basic Settings that were related to O2 sensors and catalytic converters. So I did a little more digging and selected these parameters to graph based on another post I saw. Can anyone tell me what the hell is going on lol. There's a few videos attached.. if I need to log anything, please let me know. Since its tuned, Im trying to figure out if I should continue messing with oxygen sensor spacers and/or he needs new cats before having him spend who knows how much on new ones.. Mass is pretty strict with readiness monitors so I do not believe they can just be shut off (like with APR tunes).
Red:B1 S1
Green: B1 S2
Yellow: B2 S1
Blue: B2 S2
Trowbridge, UK
As always we're going to need to see a full unedited VCDS Auto-Scan...
pouliotk2441
Massachusetts, USA
C?ID=292557
Tuesday,20,July,2021,12:18:09:54131
VCDS Version: 21.3.0.0 (x64)
VIN: WAUBGAFC4CN018467   License Plate:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 36 3B 42 44 46 52 53 55
          56 5F 62 6C 72 8F 90
VIN: WAUBGAFC4CN018467   Mileage: 156906km-97496miles
Address 01: Engine (J623-CGXB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 907 551 A    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0010
   Revision: --H07---
   Coding: 0A2A0032052600060000
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM30TFS0214G0907551A 003008
   ROD: EV_ECM30TFS0214G0907551A_003.rod
   VCID: 275C73515E3E67B3A2-8072
13273 - Catalyst System; Bank 2
          P0430 00 [101] - Efficiency Below Threshold
                    Mileage: 156906 km
                    Date: 2021.07.19
                    Time: 20:49:01
                    Engine RPM: 1487.00 /min
                    Normed load value: 46.3 %
                    Vehicle speed: 50 km/h
                    Coolant temperature: 93 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 13.913 V
                    Engine speed: actual: 1472 /min
                    MAF_ENVD: 348.61176 mg/stroke
                    Coolant temperature (unfiltered): 93.75 °C
                    Engine: operating status: PL
                    TEMP_CAT_ENVD[2]: 765.000000 °C
                    Vehicle speed: actual: 50 km/h
Readiness: 1010 0101
   Part No SW: 4G0 927 158 P    HW: 0BK 927 156 R
   Component: 0BK 30TFSIUSA H08 1006
   Revision: --H08---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002018
   VCID: 3B74BF21B2B6D353D6-806E
   Part No SW: 4G0 907 379 F    HW: 4G0 907 379 F
   Component: ESP PREMIUM   H09 0250
   Coding: 44A70F0122E5F0805B00
   ASAM Dataset: EV_ESPPremiAU57X 004017
   VCID: 3466941D9FE81C2B17-8060
   Part No SW: 4H0 907 064 BC    HW: 4H0 907 064 BC
   Component: BCM2 2.0      H31 0330
   Coding: 09883006000000000000
   VCID: 6BD44F618A5683D306-803E
   Component: J764 ELV MLB  H39 0046
   Serial number: 2311000119826012
00183 - Interior Access/Start Authorization Antenna 1 (R138)
                    Fault Status: 00101100
                    Reset counter: 108
                    Mileage: 156714 km
                    Date: 2021.07.16
                    Time: 13:00:48
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 N    HW: 4G0 820 043 N
   Component: KLIMA 2 ZONEN H10 0056
   Serial number: 24061100040273
   Coding: 6601201808
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_AirCondiBasisUDS 002033
   ROD: EV_AirCondiBasisUDS_002.rod
   VCID: 2A5A8A654D2C5ADBBD-807E
0247 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Fault Frequency: 17
                    Reset counter: 120
                    Mileage: 156886 km
                    Date: 2021.07.19
                    Time: 16:48:58
                    Outside temperature: 25.5 °C
                    Engine RPM: 702 /min
                    Vehicle speed: 0.00 km/h
   Part No SW: 4H0 907 063 BG    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0100
   Revision: 11012002    Serial number: 00000001110359
   Coding: 06002091063C9FE08100088380003908CF9CD208A2090121000004402000
   VCID: 6ED24675B94476FB21-803A
   Component: WWS57X 110522  H35 0051
   Serial number:         110527045847
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 11525990
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 D    HW: 4G0 941 531 D
   Component: E1 - LDS  H07 0044
   Serial number: 16 06 2011  00000730
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H02 0002
   Serial number: 42080DA5000000000001
02258 - Door Opener Transmitter
                    Reset counter: 62
                    Mileage: 156569 km
                    Date: 2021.07.13
                    Time: 16:03:00
Address 0E: Media Player 1 (R41)       Labels: Redir Fail!
   Part No SW: 8X0 035 110 B    HW: 8X0 035 110
   Component: CDC-MP3-Pana  H41 0480
   Revision: 00000007
   VCID: 2C568C7D4FD844EB4F-8078
   Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0043
   Revision: 11001001    Serial number: 55901117300705
   Coding: 280105
   Shop #: WSC 22705 444 103343
   ASAM Dataset: EV_EPHVA18AU57X0000 002005
   ROD: EV_EPHVA18AU57X0000_002_AU57.rod
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H31 0032
   Revision: --------    Serial number: 003D800183PI
   Coding: 303234373131303030314A55304C34473053
   VCID: 336497019AE61B130E-8066
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H11 0027
   Serial number: 6940000Y1100004XHX0D
   Serial number: 3575HRB405V0JR9K8HRR
   Serial number: 3585HRB40550INGS2PM9
   Serial number: 3515JRB405B0HM7E18UI
   Serial number: 3525JRB404P0JE3GD086
   Serial number: 3554VRB405F0JNPM50QF
   Serial number: 3564VRB405T0JNPMLOFG
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20110620000943
   Coding: 000014
   VCID: 306E980D63F0200B73-8064
   Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
   Component: E221 - MFL  H07 0009
   Part No SW: 4G8 920 982     HW: 4G8 920 982
   Component: TBenUsa       H71 0375
   Revision: 26181114    Serial number: 658270611593008
   Coding: 0BE609040B01D705020000
   ASAM Dataset: EV_RBD4K 004040
   ROD: EV_RBD4K_AU57.rod
   VCID: 71E85D09A07A69033C-8024
1048580 - Button for Trip Odometer Reset
          B11FE 13 [009] - Open Circuit
                    Reset counter: 62
                    Mileage: 156569 km
                    Date: 2021.07.13
                    Time: 16:03:53
   Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0213
   Revision: --------    Serial number: 00000000180054
   Coding: 00C1033000
   ROD: EV_GatewUDS_AU57.rod
   VCID: 326A920565FC121B05-8066
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650742175
12290 - Quiescent Current
          U1406 00 [008] - Too High
                    Reset counter: 103
                    Mileage: 156603 km
                    Date: 2021.07.13
                    Time: 21:14:01
                    Voltage terminal 30: 12.2 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 28 °C
                    System status: LIN_active
                    IN ESP_standstill flag: no standstill detected
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
   Component: MEM-FS        H03 0153
   Revision: AA000000    Serial number: 00000006205832
   Coding: 0058130000002001000001010101102030303232203232
   VCID: 77FC6311C61E3733F2-8022
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0004
   Revision: --------    Serial number: EJ1BPA42016S6+0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 2D5081797CC24DE358-8078
   Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
   Component: TSG FA        H05 0212
   Coding: 011F17204E00628002000002
   VCID: 428AC2C5DD5CA29B95-8016
   Component: RCEPS         H33 0010
   Revision: 00001000    Serial number: 0031090329
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0152002984
   Coding: 0106023A00FA440480B00800020500000000000000000000000000000000
   Component: GTO BF  H01 0070
   Serial number: 00000000000000037723
   Subsystem 2 - Part No SW: 7P5 959 591     HW: 4H0 959 591
   Component: J245 PS40.033  H07 0006
   Serial number:     WOO1238910+
   Coding: 001F00
                    Reset counter: 62
                    Mileage: 156569 km
                    Date: 2021.07.13
                    Time: 16:03:57
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 63
                    Mileage: 156580 km
                    Date: 2021.07.13
                    Time: 16:25:21
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 63
                    Mileage: 156580 km
                    Date: 2021.07.13
                    Time: 16:25:53
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   VCID: 4188CDC9D85AB9838C-8014
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000091141
   ROD: EV_ParkiBrake_VW51.rod
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Component: ....LWR12.... H02 0013
   Serial number: 110627-0004-121
   Coding: 1221A6101002A400
   ROD: EV_HeadlRegulBasic_AU21.rod
   VCID: 2C568C7D47D844EB4F-8078
   Part No SW: 4G0 035 082 B    HW: 4G0 035 082
   Component: Radio U SIRIU H51 0076
   Revision: AB001007    Serial number: 156FR0B7517020
   Coding: 020007020100000001
   VCID: 1F4C6BB10E6EAF73DA-804A
   Part No SW: 4G0 035 746 A    HW: 4G0 035 746
   Component: H-BNT-NA      H48 0380
   Revision: --------    Serial number: 031FZ0B7508738
   Coding: 050200000003E0EF45128B2E00000003100001000000000000
   VCID: 254079592C3275A390-8070
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDB1300Z4GT
   Subsystem 3 - Part No SW: 4G1 919 610 A    HW: 4G1 919 610 A
   Component: E380 BDT C7  H08 0203
   Serial number: 90349KFM000CJ
   Component: CD-Database  3371
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010F17204000628002000002
   VCID: 4486C4DDC748ACABA7-8010
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H04---    Serial number: 525 PA8J19G1BM
   Coding: 1080004
   VCID: 26427E5591347EBB99-8072
   Component: TSG HR        H04 0212
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Coding: 00060000031F030000030801424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 6FEC5B71B64E7FF32A-803A
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 70EE580DAB70600B33-8024
End-------------------------(Elapsed Time: 05:19)--------------------------
pouliotk2441
Massachusetts, USA
C?ID=292557
I’m not sure if that’s what you were looking for. I did clear the codes last night and only drove it a few miles so I’ll do it again after some driving and the light comes on. I just looked again and now the efficiency code is gone, but I have a P013A pending
