2016 Audi A8L swivelling factory towbar
ctjfb
C?ID=443559
I have retrofitted a factory swivelling towbar to my 2018 Audi A8L 3.0 TDI
I used the Kufatec wiring loom, and the factory towbar, controller & switch. I also upgraded the cooling fans from 400W to 600W.
One 'anomaly' was that the Kufatec loom designed for post-facelift A8 D4s actually uses a pre-facelift controller, however I had assurance from Kufatec that this would work seamlessly as it is logically the same as the later rev controllers and differs only in the physical connections ...
Once the fitting was complete, I took the car to my local Audi Main Dealer for coding ..
They had the car for 2 days, saying that they were having trouble coding it, and eventually returned it with most of the coding missing - the trailer module was recognised in the gateway but most if not all other modules were unchanged.
They said that as it was not supplied & fitted by an Audi dealer they were unable to resolve the issues, and they thought that maybe it was the revision of the Trailer Controller that was causing SVM to error. I was not convinced but there was little I could do.. They charged me £150 for trying though :-)
So - since I had a diagnostic tool ( that shall remain nameless) I set about trying to do the coding myself.
I eventually gave up in frrustration and purchased a new VCDS interface late last week - and here I am!!
I have worked through most of the modules, making coding changes as far as I could tell in an appropriate way - in all cases just changing the status of 'trailer installed' or similar where I found it ...
Everything seems now to work fine. My ACC and suspension coding config errors have disappeared, and the towbar itself works perfectly as does all of the trailer lighting.
What I would very much like is someone to take a quick look through the coding in the attached log and see if I have omitted anything, or make any errors. For example - I could not find any obvious setting to change in the ABS or Transmission modules, but maybe nothing should change?
Any help would be sincerely appreciated!
Chris
Monday,19,July,2021,14:11:53:52965
VIN: WAUZZZ4H3GN017905   License Plate: XX16 XXX
Mileage: 24592km-15280mi   Repair Order:
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 13 15 16 17 19 28 30 34 36 3B 3C 42 44
          46 47 52 53 55 56 5F 62 69 6C 6D 6F 72 81 85 88 89 8B 8E 8F
          90 AC
VIN: WAUZZZ4H3GN017905   Mileage: 24592km-15280miles
Address 01: Engine (J623-CTBD)       Labels:. 059-907-401-V2.clb
   Part No SW: 4H0 997 401 F    HW: 4G0 907 401 E
   Component: 3.0TDI EDC17  H14 0002
   Revision: 58H14---
   Coding: 0A2A4032057601030800
   Shop #: WSC 37842 003 104857
   ASAM Dataset: EV_ECM30TDI0114H0997401F 001002
   ROD: EV_ECM30TDI0114H0997401E.rod
   VCID: 303919E54AAFBDDB3F3-8064
   Part No SW: 4H1 927 158 CL    HW: 0BK 927 156 AD
   Component: 0BK 30TDIRdW  H19 1011
   Revision: --H19---
   VCID: 7CA1FDD5D66789BBD3B-8028
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 AA    HW: 4H0 907 379 AA
   Component: ESP PREMIUM   H10 0665
   Coding: 60E5EB8006A7D701E300
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremi 005024
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 71BFDCE18125F4D370D-8024
   Part No SW: 4H0 907 064 GB    HW: 4H0 907 064 GB
   Component: BCM2 2.0      H37 0572
   Coding: 05B76F4E000000000000
   VCID: 6FBBDA999791E223669-803A
   Serial number: 3216000007823001
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-BFS       H08 0156
   Revision: AA000000    Serial number: 00000186137625
   Coding: C038320085047201010001010101112131313333283333
   VCID: 353728F1B54D98F36C5-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 P    HW: 4H0 820 043 P
   Component: Klima 4 Zonen H20 0210
   Coding: 36610AB83C0000
   ASAM Dataset: EV_AirCondiFront 003001
   ROD: EV_AirCondiFront_002.rod
   VCID: 2D0700915D9DD033145-8078
   Part No SW: 4H0 907 063 EB    HW: 4H0 907 063 AB
   Component: BCM1 2.0      H20 0367
   Revision: 19020001    Serial number: 00001277737002
   Coding: 0105001440349FE2C9014084A0001800009DE30A2F08020180000894610017000040002D0B0000
   Shop #: WSC 12345 123 61029
   VCID: 6C81CD95A687193B43B-8038
   Subsystem 1 - Part No SW: 4H2 955 119 D    HW: 4H2 955 119 A
   Component: WWS641 150721  H38 0100
   Serial number:         150820102141
   Coding: 0045F7
   Serial number: 61397506
   Coding: 0200FF
   Subsystem 3 - Part No SW: 4H0 941 531 B    HW: 4H0 941 531 B
   Component: E1 - LDS  H07 0044
   Serial number: 01 02 2016  00001534
   Component: EVLS-SG  H08 0300
   Serial number: WA122916000019036698
   Coding: 020300
   Component: AQ_Hum_Sensor  H03 0005
   Serial number: F3C8C41800PAG0MUFU01
   Part No SW: 4H0 907 561 C    HW: 4H0 907 561
   Component: ACC3          H21 0055
   Coding: 7F04020201
   ASAM Dataset: EV_AdaptCruisContrAU64X 002026
   ROD: EV_AdaptCruisContrAU64X_002.rod
   VCID: 2B030E896389DE030A1-807E
12032 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] - -
          [FAULT_MAR_PRE_MISALIGNMENT]
                    Reset counter: 111
                    Mileage: 24592 km
                    Date: 2021.07.19
                    Time: 14:04:57
                    Control Module temperature: 47 ∞C
                    Voltage terminal 15: 12.464 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1008ME7.
   Coding: 30333045313430303037554A305234483053
   VCID: 3B233EC993E94E839A1-806E
   Serial number: 3575HRB404R3TMTM909I
   Serial number: 3585HRB404R3TMTM38FR
   Serial number: 3515JRB400U556JE90PG
   Serial number: 3525JRB400U556JE6HFL
   Serial number: 3554VRB400655AL4S175
   Serial number: 3564VRB400855AL45PEG
   Revision: --------    Serial number: 01335PBR002ML
   Coding: 0000FC
   VCID: 372B22F9AF416AE37E9-8062
   Subsystem 1 - Part No SW: 4H0 951 528 J    HW: 4H0 951 528 J
   Component: E221 - MFL  H09 0010
   Serial number: 07 01 2016  D0018235
   Part No SW: 4H0 920 950 T    HW: 4H0 920 950 T
   Component: TDieGBACC---- H53 0803
   Revision: 39081207    Serial number: 658120216592013
   Coding: 338608001F552600010000
   Shop #: WSC 39608 004 1048576
   ASAM Dataset: EV_RBD4K 004050
   ROD: EV_RBD4K_AU64.rod
   VCID: 392F24C199D57C9388D-806C
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 Q    HW: 4H0 919 204 Q
   Component: Analoguhr D4  H05 0225
   Serial number: 2160113000288
   Part No SW: 4H0 907 468 AG    HW: 4H0 907 468 AC
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000002154230
   Coding: C0CD077F08
   ASAM Dataset: EV_GatewPkoUDS 001028
   VCID: 76B5EFFDE84BD3EBA5F-8022
   Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
   Component: J367-BDM  H08 0181
   Serial number: 53042320271911506281
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
   Serial number: 16055001333021200410
Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
   Part No SW: 4H0 919 158 K    HW: 4H0 919 158 K
   Component: Klima Fond    H17 0200
   Coding: 2800000000
   ASAM Dataset: EV_AirCondiHeck 002001
   ROD: EV_AirCondiHeck.rod
   VCID: 382921C5A2DF659B773-806C
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000091048
   Coding: 01010101000000000001000202
   VCID: 6491A5B54E57517B0BB-8030
   Coding: 008003
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F3B1A995791A223269-807A
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000186153598
   Coding: C0383B0085057201010001010101112131313333203333
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637 K    HW: 4H0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA77033JJ9
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 372B22F9AFC16AE37E9-8062
   Part No SW: 4H0 907 566 F    HW: 4H0 907 566 F
   Component: SWA Master    H08 0040
   Serial number: 0390383458
   Coding: 040322
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 333316E9BBB986C3421-8066
   Subsystem 1 - Part No SW: 4H0 907 568 F    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0040
   Serial number: 0388937177
   Coding: 040322
   Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
   Component: TSG FA        H08 0280
   Revision: --------    Serial number: 0000187004270
   Coding: 011F1E015E0162C202083017
   VCID: 48C95105D2BF151B073-801C
   Component: RCevo         H54 0202
   Revision: 00000002    Serial number: 0000667254
   Coding: 101001010000
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A2D3BCD9CD3778B817-806E
   Revision: 00002001    Serial number: 0393049681
   Coding: 011B0E2280B9399FFB20C7842E0316470000000000000000000000000000
   Subsystem 1 - Part No: 4H0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4H4 959 591 A    HW: 4H4 959 591 A
   Component: J245  007C  H07 0005
   Serial number: 60460024044
   Coding: 020200
   Subsystem 4 - Part No SW: 4H0 907 133 A    HW: 4H0 907 133 A
   Component: J505-FSH  H06 0046
   Serial number: 00000000000000013256
   Subsystem 5 - Part No SW: 4H0 947 135 N    HW: 4H0 947 135 N
   Component: Dachelektroni  H13 0080
   Serial number: A2016000000000858643
   Coding: 070000
   Subsystem 6 - Part No SW: 4H4 959 591 A    HW: 4H4 959 591 A
   Component: J394  0014  H07 0005
   Serial number: 60540025386
   Coding: 020200
   Subsystem 7 - Part No SW: 4H4 959 591 A    HW: 4H4 959 591 A
   Component: J392  006A  H07 0005
   Serial number: 60460024047
   Coding: 020200
   Subsystem 8 - Part No SW: 4H4 959 591 A    HW: 4H4 959 591 A
   Component: J867  00E0  H07 0005
   Serial number: 60530024865
   Coding: 020200
   Subsystem 9 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93751804
   Revision: CJ007001    Serial number: 00000000187365
   Coding: 030000
   VCID: 1D67D0512DBD20B3845-8048
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H08 0280
   Revision: --------    Serial number: 0000185174782
   Coding: 011F1E015E0162C202083006
   VCID: 3C213DD5966749BB93B-8068
   Part No SW: 4H0 907 801 L    HW: 4H0 907 801 A
   Component: EPB-4         H05 0017
   Revision: --------    Serial number: 00000001749043
   ASAM Dataset: EV_ParkiBrake 001029
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 313F1CE141A5B4D330D-8064
   Coding: 02F6022022130200
   VCID: 343115F5BEB781FB5BB-8060
   Subsystem 1 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7570
   Coding: E00300
   Subsystem 2 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7570
   Coding: E00300
   Power module 1 for left matrix headlamp:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E00300
   Power module 1 for right matrix headlamp:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E00300
   Part No SW: 4G0 035 061 S    HW: 4G0 035 061
   Component: Radio U DAB   H60 0154
   Revision: AB001007    Serial number: 109B.0G2534829
   Coding: 010103010000000001
   VCID: 2D0700915D1DD033145-8078
   Part No SW: 4H0 035 654 B    HW: 4H0 035 670 T
   Component: H-BNT-EU      H49 1034
   Revision: --------    Serial number: 449B.0G7531325
   Coding: 02010100000BF9EF7DB0EB1E00000003080001000000000000
   VCID: 2517F8B105EDE873DC5-8070
   Subsystem 1 - Part No: 8R0 060 884 HQ
   Component: EUR 2021  3201
   Subsystem 2 - Part No SW: 4H0 919 604 H    HW: 4H0 919 604 H
   Component: DU8 D4 SV NB  H63 0060
   Serial number: AUZ8ZDFY900QU1V
   Subsystem 3 - Part No SW: 4H2 919 600 L    HW: 4H2 919 600
   Component: E380 BDT D4  H11 0110
   Serial number: 00000000211963
   Component: CD-Database  6890
                    Reset counter: 108
                    Mileage: 24328 km
                    Date: 2021.07.15
                    Time: 18:28:34
                    Text: DU902A,Front,M,0,0,6
00658 - Control Head
                    Fault Frequency: 19
                    Reset counter: 151
                    Mileage: 24328 km
                    Date: 2021.07.15
                    Time: 18:38:51
                    Voltage: 12.70 V
                    Fault Status: 01101100
                    Reset counter: 111
                    Mileage: 24592 km
                    Date: 2021.07.19
                    Time: 12:56:21
                    Voltage: 12.70 V
                    Bin. Bits:      001
                    Reset counter: 149
                    Mileage: 24424 km
                    Date: 2021.07.17
                    Time: 18:11:04
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000000 00000010
03623 - Invalid Security/Release Code
                    Reset counter: 108
                    Mileage: 24328 km
                    Date: 2021.07.15
                    Time: 18:28:33
                    Hex Value: 0x0004
                    Hex Value: 0x0009
                    Count: 7
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H08 0280
   Revision: --------    Serial number: 0000183856882
   Coding: 010F1E01400062C202083006
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 4H0 907 383 C    HW: 4H0 907 383 C
   Component: Anhaenger     H07 0100
   Revision: 5H001001    Serial number: 00000119580902
   Coding: 0104010000000000
   Shop #: WSC 02311 785 00200
   Part No SW: 4H0 907 428 E    HW: 7P6 907 441 G
   Component: TopView       H09 0361
   Revision: 11001001    Serial number: 82330JG0149203
   Coding: 020D000001000000010102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
   ROD: EV_CamerSysteTopViewAUDI_008_AU57.rod
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 AC    HW: 4H0 959 107 AC
   Component: HDSG-Modul    H12 0049
   Revision: 10012001    Serial number: 036602065
   Coding: 021004C021
   ASAM Dataset: EV_DeckLidContrUnit 001032
   ROD: EV_DeckLidContrUnit.rod
   VCID: 6FBBDA999711E223669-803A
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000202421
   Coding: 220000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 6393A6A94BD95643F21-8036
   Component: TSG HR        H08 0280
   Revision: --------    Serial number: 0000183848519
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H2 927 731 A    HW: 4H2 927 731 A
   Component: GSM-RL        H09 0083
   Revision: 0R0D5015    Serial number: SN160129  0034
   ROD: EV_GSM2x3Mono_AU64.rod
   VCID: 2C010D956687D93B03B-8078
   Component: DPC-SG        H27 0081
   Coding: EA160000
   ROD: EV_OnBoardCamerDPC.rod
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00025014122801
   Coding: 776FF2
   ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00025014122601
   Coding: 376FF2
   Part No SW: 4H0 907 541 C    HW: 4H0 907 541
   Coding: 7F04020201
   ASAM Dataset: EV_AdaptCruisContr2AU64X 002023
   ROD: EV_AdaptCruisContr2AU64X_002.rod
   VCID: 290FF4816975CC13F8D-807C
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0090
   Serial number: 005000621502167
   Coding: 02C23B041111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Component: RGS-VL        H14 0080
   Coding: 0066F609031F0376070308004240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   Component: RGS-VR        H15 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 323D13ED44A38FCB497-8066
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 160280209
   ROD: EV_RDCMA00100.rod
End----------(Elapsed Time: 03:20, VBatt start/end: 12.5V/12.4V)-----------
Address 13: DTCs cleared
MasterTommy
Amsterdam
C?ID=295586
Seems like you got it right! Any faults i see in your scan are not related to the towbar.
ctjfb
C?ID=443559
OK - thanks very much for looking at it :-)
So - Am I safe to assume therefore that there is no coding change required to the ABS & Steering Assist modules?
Again - thanks
Chris
PS> A quick reminder for anyone doing this retrofit .. Remember to change the fuses for the cooling fans (40A --> 60A) after fitting the uprated fans :-) - Oops!
Correct. I just looked into one of these earlier on a pre-facelift 4.2L TDI A8 and the list of modules he needed to tweak included:
* 19-CAN Gateway
* 01-Engine
* 09-Cent. Elect.
* 10-Park/Steer Assist
* 11-Engine
* 13-Auto Dist. Reg
* 34-Level Control
* 3C-Lane Change
* 6C-Back-up Cam.
* 6D-Trunk Elect.
* 69-Trailer
* 8B-Adaptive Cruise 2
Most 4G/4H models do NOT have all of those control modules but the facelift ones should not need any changes to 44.
I'll take a deeper look at your scan in the moring to make sure everything looks OK.
@ctjfb It looks like you have everything configured correctly. :thumbs:
On a side note. Although unlikely that you need them currently a few of the controllers that show Labels: None should be labeled after running this updater:
https://ross-tech.de/downloads/upd
If you want to fill in more of the missing gaps use the Install German label file tick box.
ctjfb
C?ID=443559
Many thanks for all your help!
Chris
