Is there a way to display only current scan results and not history + current scan results?
1975 Kombi
Acton, Ontario, Canada
C?ID=211204
I know I can clear all historic results and rescan but what if I don't want to erase the historic stuff but only view current scan results. Like maybe see results by date?
I'm not sure I understand what you're asking.
Zenerdiode
Newcastle, England
C?ID=24330
Not quite possible I’m afraid, but it’s down to the VAG module firmware - not VCDS. As a slight comprise, if a fault is tagged as Intermittent, it is actually clear at that time you scanned; but recorded as had happened sometime in the past.
If no ‘Intermittent’ tag, the fault is actually on or occurring at the time you scanned.
Some later modules will give a date & time of the first occurrence, and the number of times it had occurred [Fault Frequency]. You may keep your eye on that to see if it increments between your scans.
Not helping with vehicle diagnostics, but on the fault stack of some firmware I wrote for work, for intermittent faults I record time of first occurrence, last cleared and number of occurrences.
