- Jan 9, 2019
- 261
- 82
- Groningen, The Netherlands
- C?ID=148044
Last week I've retrofitted B7 ABS block and B7 Parking brake in my 2008 Passat B6 TDI.
I've managed to clear all errors but I'm not shure if coding is correct and some how my Auto-Hold function has gone. Also in my cluster, the menu for Auto-Hold is gone.
Befor the retrofit with de 3C0 ACC ABS Block and 3C8 Parking brake it all worked good.
In my rear brakes I have the B6 ABS sensors.
Setup up is
Motor type CBAA (2.0TDI CR)
DSG
ACC B7
Gateway/CCM B7
Here is my new log and old log-file
Setup up is
DSG
ACC B7
Gateway/CCM B7
Sunday,18,July,2021,20:05:30:51200
VCDS Version: 21.3.0.0
Dealer/Shop Name: Haarsma
VIN: WVWZZZ3CZ8E231165 License Plate: 3TGD35
Mileage: 423400km-263088mi Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 13 14 15 16 17 19 25 36 42 44 46 47 4F 52
53 5F 62 69 72 A5
VIN: WVWZZZ3CZ8E231165 Mileage: 423400km-263088miles
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 CN HW: 03L 907 309
Component: R4 2,0L EDC F001AG 6220
Revision: --H01--- Serial number: VWZCZ000000000
Coding: 0000078
Shop #: WSC 66565 257 00032
VCID: 73EFF525127D2813CE-8026
Part No SW: 02E 300 050 D HW: 02E 927 770 AL
Component: GSG DSG AG6 511 1464
Revision: 51112 Serial number: 00000902190468
VCID: 132F95A532BD88136E-8046
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AJ HW: 3AA 614 109 AJ
Component: J104 C2 450M VE5F 0023
Revision: --H07--- Serial number: 00000005577542
Coding: 0123059
VCID: 75EBCB3D1C093623E0-8020
Part No SW: 3AA 907 044 BT HW: 3AA 907 044 BT
Component: Climatronic H05 0505
Revision: 00001K02
Coding: 0614004802
VCID: 030FA5E58ADD1893DE-8056
13701424 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 95
Mileage: 423401 km
Date: 2021.07.18
Time: 19:57:00
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000008249495
Coding: F5888F3510041A1147000F000F00000080195D436400010C000000000000
VCID: 71E3FF2D68611A033C-8024
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 070308 003 0205
Coding: 00049077
Shop #: WSC 12345
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 150408 046 0204
Coding: 00995365
Shop #: WSC 12345
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 39391608303549
Coding: 0071157111
ASAM Dataset: EV_EPHVA18VW364GP00 001007
ROD: EV_EPHVA18VW364GP00_VW32.rod
VCID: 377701358E85843332-8062
13639168 - Databus
Reset counter: 95
Mileage: 423401 km
Date: 2021.07.18
Time: 19:56:59
Address 13: Auto Dist. Reg Labels: 3AA-907-567.clb
Part No SW: 3AA 907 567 A HW: 3AA 907 567
Component: AC201 RDW A 036 0170
Revision: 00036000 Serial number: 00000000507894
Coding: 0010000
Shop #: WSC 12345 123 54321
VCID: 387502094B9B8B4B3B-806C
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0071
Revision: 00000000 Serial number: 24011201770002
Coding: 030180
VCID: 2757D175562514B3A2-8072
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__005 VW10 HI 1815
Revision: 19013000 Serial number: 0039DP7DDMR3
Coding: 0012341
Shop #: WSC 05311 000 00000
VCID: 3B7F1D057AADA053D6-806E
Subsystem 1 - Serial number: 6333FTS679040708
Subsystem 2 - Serial number: 6343FTS643870708
Subsystem 3 - Serial number: 6353ETS6T8U1TVNP
Subsystem 4 - Serial number: 6363ETS6VSJ1TVNP
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AH HW: 3C0 953 549 AH
Component: J0527 0030
Revision: 00035000 Serial number: 3C0953507
Coding: 0201822
VCID: 72E1F0216D67211BC5-8026
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 00000131
Part No SW: 3C8 920 880 T HW: 3C8 920 880 T
Component: KOMBI H04 1008
Coding: 160D000000
ROD: EV_Kombi_UDS_VDD_RM09_005_VW32.rod
VCID: 3D7B131DACB9AE63E8-8068
Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
Component: J533 Gateway H56 1682
Revision: H56 Serial number: 110914F1002091
Coding: 462036
VCID: 7BFFDD05FA2D605396-802E
Part No SW: 3AA 959 433 F HW: 3AA 959 433 E
Component: IMMO 042 0429
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 43138 001 1048576
VCID: 3C7D1E197FA3A76BDF-8068
Component: ELV 027 0380
3C0905861G ELV 027 0380
Part No SW: 3C8 959 760 HW: 3C8 959 760
Component: J810 0801
Revision: 00002000 Serial number: 00000000000000
Coding: 0000001
Part No SW: 3C0 959 701 A HW: 3C0 959 793 A
Component: TUER-SG FT 002 0321
Revision: 12101005 Serial number: 0000886354
Coding: 0011F7
ROD: EV_DCU42BroseDriveSide.rod
VCID: 2649DC71592F0DBB99-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0307
Serial number: 00000000331050
Coding: 0000D0
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 M HW: 5N1 909 148 G
Component: J500__APA-BS KL.299 1002
Revision: 1AH03734 Serial number: 00112710386901
Coding: 0000258
Component: KSG PQ47 ELV 042 0714
Coding: 1891020051034E7F00021C1F7008CFCE707901
Component: LIN BACKUP HORN H08 9001
Component: Neigungssensor 004 0611
Address 47: Sound System (-----) Labels: 5K0-035-456.clb
Part No SW: 3AA 035 466 A HW: 3AA 035 466
Component: KonzernAmp12K 6910
Revision: -------- Serial number: AA1108A0000108
ASAM Dataset: EV_AudioVerst12KanalSTT1 001001
ROD: EV_AudioVerst12KanalSTT1_VW46.rod
VCID: 2E59245171DF45FB61-807A
Part No SW: 7N0 907 532 HW: 7N0 907 530 AN
Component: EZE_2 H56 1682
Coding: 00000009
VCID: 6FE7F955BE550CF32A-803A
Subsystem 1 - Part No SW: 3C8 919 204 A HW: 3C8 919 204 A
Component: Analoguhr 005 0004
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0533
Revision: 14110009 Serial number: 0006086936
Coding: 0011F6
VCID: 36690C31898F7D3B29-8062
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0307
Serial number: 00000000340928
Coding: 0000D0
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000002010222
Coding: 0022157
VCID: 36690C31418F7D3B29-8062
Part No SW: 5C0 035 680 G HW: 5C0 035 680 C
Component: MU-S-ND-ER H22 0478
Serial number: VWZAZ2R8029459
Coding: 02840201AA00000011111106018808001F0106D400200101CF
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 254BDB7D242906A390-8070
Subsystem 1 - Part No SW: 5NA 919 866 AR HW: -----------
Component: ECE AS 20/21 --- 1430
Part No SW: 1K0 907 383 D HW: 1K0 907 383 B
Component: Anhaenger H16 0070
Revision: 3A002001 Serial number: 00000110888610
Coding: 0100000200000000
Shop #: WSC 05314 000 00000
VCID: 2E59245179DF45FB61-807A
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H08 0272
Serial number: 12091712K11901
Coding: 0004060400000405002623458087840099000E000000
ROD: EV_MFKBoschMQBB_VW46.rod
VCID: 3C7D1E19B7A3A76BDF-8068
End-------------------------(Elapsed Time: 03:49)--------------------------
Monday,28,June,2021,18:45:05:51200
Mileage: 422660km-262628mi Repair Order:
53 5F 62 69 72 A5
VIN: WVWZZZ3CZ8E231165 Mileage: 422660km-262628miles
Coding: 0000078
Address 03: ABS Brakes Labels:. 3C0-614-109-C4.clb
Part No SW: 3C0 698 109 E HW: 3C0 614 109 AF
Component: J104 C4 440 V3 0017
Revision: --025--- Serial number: 00000104023403
Coding: 0024854
VCID: 2C5D2E598FC337EB4F-8078
Revision: 00001K02
Coding: 0614004802
U1111 00 [009] - -
Fault Frequency: 11
Reset counter: 74
Mileage: 422603 km
Date: 2021.06.26
Time: 19:28:49
Coding: 00049077
Shop #: WSC 12345
Coding: 00995365
Shop #: WSC 12345
Coding: 0071157111
13639168 - Databus
Reset counter: 71
Mileage: 422603 km
Date: 2021.06.26
Time: 19:28:48
Coding: 0010000
Coding: 030180
Coding: 0012341
Coding: 0201822
Coding: 00000131
Coding: 160D000000
Coding: 462036
Coding: 0000001
Coding: 0011F7
Slave Driver:
Coding: 0000D0
Coding: 0000258
Part No: 3AA 035 466 A
Component: KonzernAmp12K H02 6910
Coding: 00000009
Coding: 0011F6
Slave Passenger:
Coding: 0000D0
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
Component: J540 EPB3 VW-10498 0003
Revision: 008 Serial number: 00000000055708
Coding: 0000057
Shop #: WSC 12346 987 64321
VCID: 2855D2499B3B1BCBAB-807C
End-------------------------(Elapsed Time: 03:32)--------------------------
Wednesday,30,June,2021,19:51:24:51200
53 5F 62 69 72 A5
Coding: 0000078
Coding: 0024854
Revision: 00001K02
Coding: 0614004802
U1111 00 [009] - -
Fault Frequency: 13
Reset counter: 75
Mileage: 422603 km
Date: 2021.06.26
Time: 19:28:49
Coding: 00049077
Shop #: WSC 12345
Coding: 00995365
Shop #: WSC 12345
Coding: 0071157111
13639168 - Databus
Reset counter: 71
Mileage: 422603 km
Date: 2021.06.26
Time: 19:28:48
Coding: 0010000
Coding: 030180
Coding: 0012341
Coding: 0201822
Coding: 00000131
Coding: 160D000000
Coding: 462036
Coding: 0000001
Coding: 0011F7
Slave Driver:
Coding: 0000D0
Coding: 0000258
Coding: 00000009
Coding: 0011F6
Slave Passenger:
Coding: 0000D0
Coding: 0000057
End-------------------------(Elapsed Time: 03:28)--------------------------
