Ambient Lighting- Door Closed 2019 Audi S3
ChrisdraggerS3
Jamaica
C?ID=426264
Good Day everyone,
How do I use VCDS to turn on Ambient Light for door when it is closed. IT works fine when door is open. However I am unable to turn it on nor am I able to adjust it or the lights in the door handles. They are always on . The MMI feature is only able to adjust the footwell lights and the cupholder lights (front). The dealer is tryinf=g to convince me that thhis is normal operation. I am not convinced. I have seen on other forums where they say this is a factory fault.
Help!
AUTOSCAN below:
Sunday,18,July,2021,19:15:36:29807
VIN: WAUZZZ8V1K1005252   License Plate:
Mileage: 21590km-13415mi   Repair Order:
Chassis Type: 8V-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 15 17 19 20 22 29 2B 39 42 44 47 4B 52
          5F 6C A9 BB BC D6 D7
VIN: WAUZZZ8V1K1005252   Mileage: 21590km-13415miles
Address 01: Engine (J623-DJHB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 J    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 0A251012240600083004
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208V0906259J 001005
   ROD: EV_ECM20TFS0208V0906259J.rod
   VCID: 47CB50BD5F2AB2C30E9-8012
   Part No SW: 0GC 300 012 M    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2302
   Revision: 00H06V08
   ROD: EV_TCMDQ381061_VW37.rod
   VCID: 2D070215DD967893145-8078
   No subsystems:
   Part No SW: 8V0 614 517 D    HW: 8V0 614 517 C
   Component: ESC           H25 0640
   Revision: 00000000    Serial number: 61938000000365
   Coding: 319C938D54990BAE8B930B694093698CC92AD0D1D0029637004150348208420000000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037008
   ROD: EV_Brake1UDSContiMK100IPB_037_AU37.rod
   VCID: 3A2D39491CD8DF2B817-806E
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0481662163
   Coding: 030C0C1720
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43D344AD6B129EE3D21-8016
   Part No SW: 8V0 820 043 AE    HW: 8V0 820 043 AE
   Component: AC Automat    H03 0150
   Revision: 20003000    Serial number: 00000000024950
   Coding: 03100014110000010000000000001500
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008025
   VCID: 75B7EA7575467053AC5-8020
   Humidity sensor: exterior:
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: 3B80504900PAG0MUFU03
   Part No SW: 5Q0 937 084 DC    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H38 0273
   Serial number: 00001824503875
   ROD: EV_BCMBOSCH_019.rod
   VCID: 7CA1FF51566C211BD3B-8028
   Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS371 180713  043 0585
   Serial number:         180803074855
   Coding: 0A47F7
   Serial number: 21581066X81A955547A0
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 08 05 2018  20000580
   Serial number: 000000000ZY181970VMU
   Serial number: 00000000000045095739
   Sunroof control module:
   Subsystem 6 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H04 0005
   Serial number: 0000FST0024VU4Z00000
   Coding: 901E00
   Steering Column Switch:
   Subsystem 7 - Part No SW: 82A 953 521 CF    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000030061820240385
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 214
                    Mileage: 21565 km
                    Date: 2021.07.16
                    Time: 15:55:46
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418018204
   Coding: 0470151011
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 4CC16F91464C519B23B-8018
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    006 0339
   Serial number: 003VWR4HS57P
   Coding: 98CCC000000000005C54000000C8000000C5
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   VCID: 094F968509BE04B3D8D-805C
   Subsystem 1 - Part No SW: -----------    HW: 480 002 908 18
   Serial number: 35700000000DE61C213O
   Subsystem 2 - Part No SW: -----------    HW: 480 002 908 18
   Serial number: 35800000000D0ACC313R
   Subsystem 3 - Part No SW: -----------    HW: 480 402 308 18
   Component: SideSensor_Dr  004 6149
   Serial number: 35100011E2B7DB9443BE
   Subsystem 4 - Part No SW: -----------    HW: 480 402 308 18
   Component: SideSensor_Pr  004 6149
   Serial number: 3520001302B78F62C15/
   Subsystem 5 - Part No SW: -----------    HW: 480 402 106 18
   Serial number: 3550002C325325A5218U
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 790 B    HW: 8V0 920 790 B
   Component: FBenRDW       H19 0108
   Coding: 248D18522B8008080501FE001000001000000000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_DashBoardFPKAU37X 001032
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 3B233C4D13E2E6239A1-806E
16776994 - Databus
          [TSG_FT_02 communication error can_error_timeout]
                    Reset counter: 3
                    Mileage: 21573 km
                    Date: 2021.07.17
                    Time: 18:25:40
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5344
   Serial number: 31081810520902
   Coding: 0101000830085A005B00822A3C0B00000001010000000000000000000000
   ROD: EV_GatewNF_AU37.rod
   VCID: 3D2732550DF6E813A45-8068
   Generator:
   Component: 1-01-13-01-04
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0004
   Serial number: 20180815214804 22612
Address 20: High Beam Assist. (J844)       Labels:* None
   Part No SW: 81A 857 511 A    HW: 81A 857 511 A
   Component: FLA           H10 0003
   Revision: AA001001
   Coding: 0404010700000000000001
   ASAM Dataset: EV_HighBeamAssisAU33X 001017
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   VCID: 2615FD39F8604BCBD5F-8072
   Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7762
   Serial number: HA1-00023.05.18
   Coding: 0001
   VCID: 4DC76295BD565893345-8018
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
   Component: LCM_MQB       H07 0022
   VCID: 42DD41A9740897EBD97-8016
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H07 0021
   Serial number: 18000285193006
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 313F1E65C1AE1C7330D-8064
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YE007RH227129
   Coding: 005F1A205001000000001002
   Shop #: WSC 99999 999 83333
   VCID: 44D147B16E1C99DBEBB-8010
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 81160000
   ROD: EV_SteerAssisMQB_015.rod
24320 - Steering
          C10AC 07 [009] - Mechanical Failure
          [Belastungszähler hat 99% überschritten Belastungszähler hat 100% erreicht]
                    Reset counter: 206
                    Mileage: 21458 km
                    Date: 2021.07.13
                    Time: 11:51:08
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 13.50 V
                    Temperature: 59.0 °C
                    KFC: 5F
                    KFA: 00 00
                    Freeze frame conditions: 5F
                    uioUdNotFilt_xdu16: 13.77 V
                    uAdSensI_SwitchedKl30_xdu16: 13.73 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
   Part No SW: 81A 035 466 B    HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0440
   Revision: 00000001    Serial number: AUZ8ZAJ5F01V7B2
   Coding: 0173030000AAAA2AAA0000010000
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C9Gen2ALPI.rod
   VCID: 2411E7318E5CB9DBCBB-8070
   Component: FCM MQB Low   002 0342
   Serial number: 19081810802795
   Coding: 000000050900143200102B00020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002004
   ROD: EV_MultiModulContiVW48X_002_VW41.rod
   VCID: 35372A7535C630536C5-8060
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YE007RGN14715
   Coding: 005F12205C01000000001002
   Part No SW: 8V1 035 040 C    HW: 8V1 035 040 C
   Component: MU-P-N-RW     055 1326
   Serial number: A700H0JS001883
   Coding: 017351030000000011220002001A00002F0027E6017001005E
   VCID: 2E050519D090038B2DF-807A
   Subsystem 1 - Part No SW: V03 959 802 DG    HW: -----------
   Component: ROW 2018/2019  --- 0071
   Multimedia System 1:
   Component: DU High  H49 0014
   Serial number: AUZ8Z9J1Y0DCUW
   Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL115061800050052
   Compact disc data bank:
   Component: Gracenote2  --- 4013
   Coding: 0273010102002001400040
   VCID: 392F264519DED43388D-806C
   Part No SW: 8V0 907 159 A    HW: 4H0 907 159 A
   Serial number: 180628201048
   VCID: 3E25355900F0F30BBDF-806A
   Part No SW: 8W1 959 395 D    HW: 8W1 959 395 D
   Component: TSG HFS003 0187
   Serial number: YE007RGV30064
   Coding: 000C12204001000000001002
   ROD: EV_DCU2RearDriveMAXHCONT_VW41.rod
   Component: TSG HBFS003 0187
   Serial number: YE007RGV3006E
   ROD: EV_DCU2RearPasseMAXHKLO_VW37.rod
   VCID: 176BC0FD4F0AE2435E9-8042
End----------(Elapsed Time: 01:35, VBatt start/end: 12.3V/12.3V)-----------
@ChrisdraggerS3: Hi - I'm trying to understand your question and I'm not succeeding, so I need your help (please)
I assume by "Ambient light", you mean the lamp in overhead fitting (between the left/right reading lamps) that the WD calls W1 - Front interior light.
You say "IT works fine when door is open. However I am unable to turn it on" - but of course you can do this (independent of the door status) via the overhead switch located near the lamp.
So, what extra control function are you seeking exactly?
PS:I don't have access to the WD for your particular vehicle - but for Audi 8V series diagram in my possession, the wiring arrangement for W1 appears to be very rudimentary.
ChrisdraggerS3
Jamaica
C?ID=426264
Hi
I am talking about the LED strip that is located just at the top of the Bang n Olufsen speaker.
I am not able to independently turn it on when I go into the MMI>MENU>car>Vehicle settings>Background lighting>Door brightness .
The LED strip only activates when I open the door.
This is not normal operation. This LED strip should be able to activate along with footwell lights and cup holder lights once the headlights are on.
let me know if I have clarified and you are able to help
thanks
@ChrisdraggerS3: Arrhhh......... yes, now I understand, thank you for clarifying.
I think you mean these (pic from a RoW A3 8v):
If these are the correct lights, then they are directly wired to the respective door modules - they are not part of the BCM.
I'm more than happy to be advised otherwise by more knowledgeable forum colleagues - but AFAIK, the behavior of these lights cannot be modified - alas
ChrisdraggerS3
Jamaica
C?ID=426264
Thanks for your input! I await further confirmation that it is hardwired to the door.
zabster
West Yorkshire, UK
C?ID=421594
I agree with DV52. Yes B&O Speaker Light is directly wired into door module.
8V has individual pins for Ambient Light, Door Handle Light, Warning/Entry Light and B&O Speaker Light in door module. Each can be activated through Long Coding for individual door module with VCDS.
Ambient in Door would power on with door open, or at night with Light Sensor. During night if MMI menu is activated, light can be powered Off.
Module 09 allows for Ambient and Door Handle to be combined or work separate. If separate Door Handle, it stays on as if it is on Terminal 30, On at Key Unlock, On all the time with car on and powers off when car is Locked.
No control of Warning/Entry Light.
I don't remember seeing anything in 09 for B&O and there is definitely no light channel for them.
If you want MMI control you can consider wiring it to ambient pin but I am not sure if Wattage requirements would be same, but B&O Speaker Light certainly can't be requiring more than Ambient lights.
zabster
West Yorkshire, UK
C?ID=421594
Hi
thanks
Hi
I have had a quick look on audi-sport posts about B&O Speaker Light and there are some people who have complained of similar issue to Audi and not getting much help. If you have MMI menu active and have Door option then normal behaviour should be as you expect, to be On with door Open and On during night with headlight etc and dimming control via MMI Background Lighting.
You mention of Door Handle Light as well and I have given my experience of its standalone behaviour above.
Through module 09 You can try and make Door Handle to work with Ambient.. The option is in Adaptation in Ambient Light adaptation group and see how that works out. There are some Ambient adaptation in 09 that I can't make sense of but you can explore each one separately to see what happens.
Like I said above, 4 separate pins in door module for different lights so maybe it is wired to wrong pin. Your B&O seems to be behaving like Warning/Entry Light. You might have to rewire it to ambient pin.
ChrisdraggerS3
Jamaica
C?ID=426264
Thanks, finally someone is seeing my point and problem..
If only now I could get the wiring diagram to do further checks..as for the door I am worndering what on earth that could be wired to as it is just always on…and no way to turn it off..night or day..door opened..door closed..the light is handle is just always on with no possibility of turning it off or adjustment
please help me
zabster
West Yorkshire, UK
C?ID=421594
please help me
The above diagram has all door lights connections. Note B&O is on 20pin connector and others are on 32pin connector.
The behaviour of door handle as you describe is exactly what I found it out to be as well and as there is no other adaptation for it I would say that is how it is meant to behave if it on pin 3. But if you access through module 09 adaptation, there are few adaptations starting with words Ambient Lights, and one of those is Door Handle Light with Ambient Light. Active that, even if you don't have ambient lights. That will give you MMI control on it and also it won't stay On all the time.
For your B&O If it is on pin3 of 20pin connector and it behaves as you say have described then you can try pin8 of 32pin connector or even pin3, double up door handle. However, I am not considering wattage requirements here But from experience Door Handle pin3 supplies very low power but pin8 is high power, sorry no numbers. Also from experience, the door modules are very well built that if you put too much load on any of those pins in 32pin connector, that specific pin will trip/powerOff and behave normal once the excess load is removed without need to remove error via vagcom.
Goodluck.
zabster
West Yorkshire, UK
C?ID=421594
hmm......... very much a cobbled-together and greatly simplified WD of J386 - hope I've gotten all the lights on the door panel
Just wanted to add this regarding B&O light
It is not directly wired to 20pin connector on door module but through a small 4pin or 2pin connector on the way. But you should be able to track it anyway with the wire color coding.
zabster
West Yorkshire, UK
C?ID=421594
Goodluck.
I must declare my experience is only with my own car but I did spend a lot of time investigating how different pins behaved because I had purchased this cheap kit off AliExpress and it required some modifications before the door module was happy with them.
@zabster : thanks for adding the clarification - the problem when creating simplified WD is the decision as to what to include and what to leave-out!!:thumbs:
zabster
West Yorkshire, UK
C?ID=421594
I am actually impressed with your simplified diagram. Can't believe you went through the effort of creating a simplified version. I took ages understanding the diagrams first time I looked at them.
I wanted to clarify because I don't have the fancy B&O lights. I only have 32pin connector to disconnect when I remove door panel and I can't picture how it would be when you have B&O wired to another connector. Do you remove both 32pin and 20pin or you disconnect the connector in the way for 20pin connector.
ChrisdraggerS3
Jamaica
C?ID=426264
SO Audi HQ has responded. They state that my vehicle was designed to operate without the BO lights on while driving with lights on. Only with door control unit SW larger than 300, this function has been integrated and my car has Software 0187 in the door units. I don't know what this means but can it still be resolved or I have to live with it in its current state.
zabster
West Yorkshire, UK
C?ID=421594
Hi
Sorry I don't understand what that is supposed to mean but maybe someone else can understand this response.
You have the information above to inspect behind door panel and try rewire to a different supply pin and see what happens.
Regards
@zabster: If I can take a stab at interpreting what Audi-HQ told @ChrisdraggerS3 - I think he/she is saying that the supply voltage @ pin T20c /3 on my wiring diagram is not T58 with the SW version for his J386 module.
But yes your suggestion should work - so OP can simply turn-on the low-beam/Parking Lights and using a multi-meter check which pins in the WD have +12V. With these pins identified - then turn-off the low-beam lights and those pins which no longer have +12V are T58 pins (i.e. pins that are +12V when the low-beam (and Parking Lights) are switched-on)
ChrisdraggerS3
Jamaica
C?ID=426264
i am male:). Audi HQ is saying that there is no problem. The car was intended to operate with the B&O lights off.
zabster
West Yorkshire, UK
C?ID=421594
I'm impressed.. 👏👏👏
