HI All , i now have a S7 2013 and all was fine until one day started it and had loads of differential /air suspension/parking brake errors/abs and more .
but I took the car out and then came home , tried to start the car again and no errors came up on the dash ???
so I cleared all the DTc with my older hex can VCDS .
the next day same thing ....i have seen this sort of thing before in as the battery fails , so went and got a new battery at great cost as the old one was the original and 7 years old although only done 42K miles.
I cleared all the DTC and thought that would be the end , but no same thing happened the next day .
it seems a lot of the errors are due to another sensor malfunction .
but I can't really see what is the real problem .my gut tells me it is a abs or the rear wheel speed sensor as this one reports an actual fail.
anybody able to decipher this report in more detail for me or do i need a HEX can 2 ??
here is the scan , i hope someone can give me a clue to take to my garage guys .
Sunday,18,July,2021,14:35:04:33020
VCDS Version: 21.3.0.0 (x64)
License Plate:
Mileage: 68262km-42416mi Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 28 30 34 36 3B 42 44 46
47 52 53 55 56 5F 62 6D 72 82 A9 BA
Mileage: 68262km-42416miles
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CEUC) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 906 014 HW: 4H0 906 014
Component: 4.0l V8TFSI / H62 0012
Revision: NCH62---
Coding: 1A2500326526010A0800
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM40TFS0114G0906014 001014
ROD: EV_ECM40TFS0114G0906014.rod
VCID: 5FC7888F46BD60739A-800A
U1113 00 [032] - -
Mileage: 68229 km
Date: 2021.07.18
Time: 13:32:31
Engine RPM: 1300.50 /min
Normed load value: 11.8 %
Coolant temperature: 27 °C
Intake air temperature: 30 °C
Voltage terminal 30: 11.237 V
AFS dm: 61.7 kg/h
Mean injection time: 1.562 ms
Engine operating condition: Idle
Brake actuated status-Bits 0-7: 26
Tumg: 30.0 °C
Psr w: 423.28 hPa
Engine torque: 94.7 Nm
U1113 00 [032] - -
Mileage: 68229 km
Date: 2021.07.18
Time: 13:32:31
AFS dm: 61.7 kg/h
Tumg: 30.0 °C
Psr w: 423.28 hPa
Readiness: 0010 0001
Part No SW: 4G9 927 156 B HW: 0B5 927 156 K
Component: 0B5 40TFSIRdW H02 0002
Revision: --H02---
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMDL501021 001015
ROD: EV_TCMDL501021.rod
VCID: 346D37239FBB932B17-8060
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 L HW: 4G0 907 379 L
Component: ESP PREMIUM H09 0450
Coding: 65B6DF03A66DFBC0DB00
ASAM Dataset: EV_ESPPremiAU57X 004039
VCID: 3A71191BBDDF655BCD-806E
0486 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 233
Mileage: 68229 km
Date: 2021.07.18
Time: 13:32:30
VzRef: 00
Bit Info 1: 00
Bit Info 2: 0F
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 02
F-Type: 08
Uz: 98
0732 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 233
Mileage: 68229 km
Date: 2021.07.18
Time: 13:32:31
VzRef: 00
Bit Info 1: 00
Bit Info 2: 4F
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 01
F-Type: 08
Uz: B3
0382 - Rear Right Wheel Speed Sensor
C101D 07 [008] - Mechanical Failure
Reset counter: 233
Mileage: 68229 km
Date: 2021.07.18
Time: 13:24:24
VzRef: 0D
Bit Info 1: 00
Bit Info 2: 02
Bit Info 3: 00
Bit Info 4: 1F
F-Path: 01
F-Type: E6
Uz: A3
Part No SW: 4H0 907 064 DN HW: 4H0 907 064 DN
Component: BCM2 2.0 H35 0510
Coding: 01BA3046000000000000
VCID: 78F5C313CB53B74BFB-802C
Serial number: 0213000342108014
Part No SW: 4G0 820 043 AM HW: 4G0 820 043 AM
Component: KLIMA 4 ZONEN H14 0093
Serial number: 07111300040504
Coding: 6823007831
ASAM Dataset: EV_AirCondiComfoUDS 004003
ROD: EV_AirCondiComfoUDS_004.rod
VCID: 6AD1E95B8DFF15DB7D-803E
Part No SW: 4H0 907 063 CF HW: 4H0 907 063 F
Component: BCM1 2.0 H12 0130
Revision: 20012002 Serial number: 00000001798134
Coding: 2600201040349FE0298100C380001D0CCF9DC30A27090201000008606100
VCID: 6ED9E54BB917F9FB21-803A
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 131007 H36 0080
Serial number: 131009132055
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 21924349
Coding: 02006E
Subsystem 3 - Part No SW: 4G0 941 531 AA HW: 4G0 941 531 AA
Component: E1 - LDS H07 0044
Serial number: 30 10 2013 00001573
Serial number: 499987D6000000000001
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0083
Revision: 11001001 Serial number: 61061331501931
Coding: 88C309
ASAM Dataset: EV_EPHVA18AU57X0000 004009
ROD: EV_EPHVA18AU57X0000_004.rod
VCID: 71E3FE37A029E6033C-8024
13637410 - Databus
Reset counter: 233
Mileage: 68229 km
Date: 2021.07.18
Time: 13:32:33
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00FFXL-
Coding: 3031453032314E303133554A305234473853
VCID: 36690D2B89C7813B29-8062
Serial number: 3575HRB400M50NTM99L4
Serial number: 3585HRB40552A84E38R.
Serial number: 3515JRB400O50PGEMH1R
Serial number: 3525JRB400850OV2LP1L
Serial number: 3554VRB400Q50OV2S1ME
Serial number: 3564VRB400S50OV2KA2+
1049352 - Databus
Reset counter: 233
Mileage: 68229 km
Date: 2021.07.18
Time: 13:32:32
1049605 - Databus
Reset counter: 233
Mileage: 68229 km
Date: 2021.07.18
Time: 13:33:00
Revision: -------- Serial number: 90372MJV00014
Coding: 000034
VCID: 3777002F86CD783332-8062
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Serial number: 17 07 2013 11298939
Fault Status: 00101101
Reset counter: 233
Mileage: 68229 km
Date: 2021.07.18
Time: 13:32:32
Part No SW: 4G8 920 985 E HW: 4G8 920 985 E
Component: TBenGb Nv H58 0621
Revision: 29460233 Serial number: 658041013596022
Coding: 33A701039B432600010300
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K_AU57.rod
VCID: 39730617B8D96E43C4-806C
Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
Component: J533--Gateway H13 0050
Revision: -------- Serial number: 00000001159462
Coding: 00ED074800
ASAM Dataset: EV_GatewPkoUDS 001019
VCID: 72E1F13BA52FDD1BC5-8026
Serial number: 5685551703
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 13090500000000000038
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 A HW: 4H0 907 163 A
Component: 4 Wheel Drive H16 0013
Serial number: 003010130001863
ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
VCID: 2757D06F5E6DE8B3A2-8072
0385 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 50
Mileage: 68229 km
Date: 2021.07.18
Time: 13:32:31
0377 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 50
Mileage: 68229 km
Date: 2021.07.18
Time: 13:32:31
Part No SW: 4G0 919 158 M HW: 4G0 919 158 M
Component: KLIMA FOND H08 0093
Serial number: 08111300040714
Coding: 22
ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 4H0 907 440 HW: 4H0 907 440
Component: STS H06 0030
Revision: S0H06000 Serial number: 00000000049809
Coding: 01010101000000000001000102
VCID: 64CD876367DB43AB47-8030
Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H18 0782
Coding: 008000
ASAM Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_VW51.rod
VCID: 2E59254B7197B9FB61-807A
0648 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
Reset counter: 233
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000079883278
Coding: 0078130000006001000001010101102030303232203232
VCID: 77F7C02FC64DB833F2-8022
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H03 0056
Revision: -------- Serial number: EJ1BPA7E00R7X$
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3777002F8ECD783332-8062
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011F56024E21620002080402
VCID: 479770EFF62D08B342-8012
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H39 0010
Revision: 00001000 Serial number: 0003010950
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 3261313B65AF9D1B05-8066
3164944 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 233
Mileage: 68229 km
Date: 2021.07.18
Time: 13:32:32
Write only channel
Revision: 00002001 Serial number: 0319752332
Coding: 013B0622A0B9B80083300A0400010D470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Subsystem 3 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H11 0029
Serial number: WA106977000005142187
Part No SW: 4G2 035 223 A HW: 4G2 035 223 A
Component: STD-G3C7-ANC H02 0740
Revision: CJ002400 Serial number: 00000000000111
Coding: 030000
VCID: 1D3BF28704313263C8-8048
Component: TSG BF H03 0507
VCID: 46897DEBF12711BBB9-8012
Part No SW: 4H0 907 801 G HW: 4H0 907 801 A
Component: EPB-4 H03 0014
Revision: -------- Serial number: 00000000873093
ROD: EV_ParkiBrake_VW51.rod
VCID: 2C5D2F43478BCBEB4F-8078
460288 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 233
Mileage: 68229 km
Date: 2021.07.18
Time: 13:32:30
Voltage terminal 30: 11.9 V
Internal Fault ID: 142
Function light in parking brake button: On
Red operating lamp: On
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
Internal Parking Brake state: static
Status ParkingBrake left: applied
Status ParkingBrake right: applied
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 131109-0004-000
Coding: 11236F101000A300
ROD: EV_HeadlRegulBasic_AU21.rod
VCID: 2D5B22477C91C2E358-8078
Part No SW: 4G0 035 061 S HW: 4G0 035 061
Component: Radio U DAB H60 0154
Revision: AB001007 Serial number: 109K 0DB005264
Coding: 010103010000000001
VCID: 2D5B22477491C2E358-8078
Part No SW: 4G0 035 670 Q HW: 4G0 035 670 J
Component: H-BNT-EU H53 1034
Revision: -------- Serial number: 190K%0D7560635
Coding: 0A0101040203F5ED45808B3E00000003000001000000000000
VCID: 31633E3768A9A6037C-8064
Subsystem 1 - Part No: 8R0 060 884 GS
Component: EUR 2020 3001
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDDD0031BFF
Subsystem 3 - Part No SW: 4G2 919 612 Q HW: 4G2 919 612 Q
Component: E380 BDT C7 H11 0204
Serial number: 90349MKB0001L
Component: CD-Database 5571
Component: TSG HL H03 0507
Coding: 010F14024021620002080002
VCID: 499376D7E039FEC354-801C
Part No SW: 4G8 959 107 Q HW: 4G8 959 107 F
Component: HDSG-Modul H13 0043
Revision: 11013001 Serial number: 296301368
Coding: 0A3305C002
ASAM Dataset: EV_HDSGAu573 001022
ROD: EV_HDSGAu571.rod
VCID: 438F64FFCA1524939E-8016
Component: TSG HR H03 0507
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 4G8 919 604 L HW: 4G8 919 604 L
Component: HeadUpDisplay 004 0201
Coding: A20000
ASAM Dataset: EV_HUDContiC7 001023
ROD: EV_HUDContiC7.rod
VCID: 3C7D1F03B7EB5B6BDF-8068
Part No SW: 4G0 907 159 B HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0010
Serial number: 131018202336
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 HW: 4H0 907 145
Component: AEM - LEAR H07 0006
Revision: 00001001 Serial number: 97809002752800
ASAM Dataset: EV_AEMLearAU64X 002014
ROD: EV_AEMLearAU64X.rod
VCID: 66C99D6B99E731BB59-8032
0554 - No Basic Setting
B2010 00 [009] - -
Reset counter: 192
Mileage: 68229 km
Date: 2021.07.17
Time: 16:53:06
1632 - invalid data record
B2005 00 [009] - -
Reset counter: 192
Mileage: 68229 km
Date: 2021.07.17
Time: 16:53:06
End-------------------------(Elapsed Time: 06:11)--------------------------
