A6 Allroad C5 Stuck in ECON mode
Neilthebath
C?ID=112649
Hi any help please,
Air conditioning wont come on, cant get it to come off ECON mode, carried out scan as you can see 00819 High Pressure Sensor (G65) Open or Short To Plus, checked plug 12volts present, did an output test condenser fan didn't run, checked operation by putting a 12volt supply to fan ran with no issue. Obviously i don't know if the sensor is faulty or not, i did disconnect the plug and did a rescan but it would not clear the DTC i don't know if that's because its out of the circuit. My thoughts are why didn't the output test not run the fan is there a relay ? where is, it checked the fuses in the usual place i.e. A post drivers side all ok, refrigerant gas level checked and fine
Hopefully someone may have experienced a similar problem
VCDS Version: 21.3.0.0 (x64)
VIN: WAUZZZ4B22N029256   License Plate: OU51WNN
Mileage: 144258   Repair Order:
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
          75 76 77
Address 01: Engine        Labels: 059-907-401-AKE.clb
   Part No: 4Z7 907 401 B
   Component:  2.5l/4VTEDC G000SG D06
   Coding: 01015
   Shop #: WSC 02325
   VCID: 3C734C052CF09A6BDF-4AE6
   Subsystem 1 - Part No: 00015059
   Component: 130 106EC150_1.R75438658187
   WAUZZZ4B22N029256     AUZ7Z0A1904587
Readiness: N/A
Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
   Part No: 4Z7 907 389
   Component: ABS/ESP allrad      D57
   Coding: 06355
   Shop #: WSC 02325
   VCID: 091DE5D133A27FC394-5102
Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
   Part No: 4B0 820 043 AC
   Component: A6-Klimavollautomat 0104
   Coding: 00004
   Shop #: WSC 02325
   VCID: 5BB1EF99C9BEBD53F6-2566
            30-00 - Open or Short to Plus
Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
   Part No: 4Z7 959 655 D
   Component: Airbag 8.4E         3000
   Coding: 0001106
   Shop #: WSC 02325 785 00200
   VCID: 50AB08B5C0780E0B13-5120
Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
   Part No: 4B0 920 981 J
   Component: KOMBI+WEGFAHRS. VDO D07
   Coding: 04460
   Shop #: WSC 00001
   VCID: 2D557141E78A03E358-5120
Address 34: Level Control        Labels: 4Z7-907-553.lbl
   Part No: 4Z7 907 553 E
   Component:  - 2C1A1          D040
   Coding: 25500
   Shop #: WSC 00001
   VCID: 479923E96536C9B342-5102
Address 35: Centr. Locks        Labels:. 4B0-962-258.clb
   Part No: 4B0 962 258 K
   Component: Zentralverrieg.,DWA D35
   Coding: 06863
   Shop #: WSC 02325
   VCID: 316D6D31FBB267037C-4ECA
Address 45: Inter. Monitor        Labels: 4B0-951-173.lbl
   Part No: 4B0 951 173
   Component: Innenraumueberw.    D03
   Coding: 00002
   Shop #: WSC 02325
   VCID: 60CBD875E0D89E8BA3-4B00
Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D06
   Coding: 00030
   Shop #: WSC 02325
   VCID: 0403F4E5148022ABE7-4B4A
Address 56: Radio        Labels: None
   Part No: 4B0 K35 195 H
   Component: symphony II NP2    0005
   Coding: 00001
   Shop #: WSC 02325
   VCID: 408B38F54018FE8B83-4E78
End-------------------------(Elapsed Time: 05:39)--------------------------
If you had power on terminal 3 and ground on terminal 1 replacing the G65 sensor might be a lot easier than checking the signal wire to the 08-Auto HVAC controller. However, if you replace the sensor make sure they sell you the correct part number because there were several sensor types for vehicles from this time frame.
In regards to the Output test function, did you try that in both Address 01 and 08? I don't know if that is a supported function on this car but it can't hurt to try in both controllers.
Neilthebath
C?ID=112649
Hi Dana
Thanks for your reply yes i was thinking about replacing sensor. No i didnt try both addresses i will give that a go.
Regards Neil.
Neilthebath
C?ID=112649
Update, replaced G65 sensor rescanned fault will not clear ?
Did they sell you part number 3R0 959 126?
If not, let us know which part number was removed and which was installed.
If so, it might be time to jump into a wiring diagram so the signal wire from it to the 08-Auto HVAC controller (including any connector points in-between) can be checked.
Neilthebath
C?ID=112649
Hi
The part number I was sold is 4H0 959 126B
The part removed was 8Z0 959 126
Regards.
OK. I'm not so sure that's correct based on the Supersession path:
8Z0 959 126
8E0 959 126
8E0 959 126 B
8E0 959 126 C
3R0 959 126
That's probably why PartsLink24 only showed the newest 8E and 3R part numbers based on VIN.
I'm not very confident that 4H0 959 126 B (which is a newer sensor that communicates via LIN) is correct for this car.
Neilthebath
C?ID=112649
I’m only going on what they say ,
I’m more inclined to think it’s an electrical problem as I can’t even clear the fault with the sensor disconnect and plug disconnected in engine bay.
Maybe HVAC control???
