2015 Q3 swivelling towbar coding
JPE
Manchester, UK
C?ID=426958
Hi i have an Audi 2015 Q3 and have installed a used Swivelling Towbar and have connected the wiring from the back of car to the module. i have tried to program the car but have no lights at the tow bar, the parking sensors do not deactivate however the LED at the cable pull in the boot works and the light on the dash works to say it not engaged as expected.
Coding as below please can you help?.
Chassis Type: 8U-AU21 (8U0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 55 5F 62 69
6D 72
VIN: WAUZZZ8U9FR048624 Mileage: 78920km-49038miles
Engine -- Status: OK 0000
Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 22-AWD -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: Malfunction 0010 6D-Trunk Elect. -- Status: OK 0000
Address 01: Engine (J623-CUWA) Labels:. 04L-907-309-V1.clb Part No SW: 04L 906 016 BH HW: 04L 907 309 K
Component: R4 2.0l TDI H20 2916 Revision: 8AH20---
Coding: 02250012041701082000
Shop #: WSC 56526 001 1048576
ASAM Dataset: EV_ECM20TDI01104L906016BH 004003 ROD: EV_ECM20TDI01104L906016BE_004.rod
VCID: 70B9DBBF8A282E4B832-8024
No fault code found. Readiness: 0 0 0 0 0
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb Part No SW: 0BH 300 012 K HW: 0BH 927 711 C Component: DSG DQ500-7A H08 4704
Revision: 00H08V01 Coding: 0014
ASAM Dataset: EV_TCMDQ500021 001001 ROD: EV_TCMDQ500021_001_VW36.rod VCID: 2B030CD3638E0D93F60-807E
Address 03: ABS Brakes (J104) Labels: 5N0-614-109-V1.clb Part No SW: 5N0 614 109 CA HW: 5N0 614 109 CA Component: ESC-EBC460iV1 H08 0004
Serial number: A00TC39
Coding: 21F124A1C924C374207D840224C793C304345700508B4885 Shop #: WSC 00049 770 00151
ASAM Dataset: EV_Brake1ESCEPBTRW 003039 ROD: EV_Brake1ESCEPBTRW_003.rod
VCID: 6C81CFCFA600CAABBFA-8038
0799 - Databus
U1123 00 [008] - Received Error Message [MSG_LH3_LM_INVALID]
Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame:
Reset counter: 253
Mileage: 78842 km
Date: 2021.07.11
Time: 18:10:35
Additional_Codes: 00 00 00 09 CA 7F 40 08 0A
DTC: 00 03 1F
Additional2: 05 00 01 05 05 00 37 00 37 00
Address 08: Auto HVAC Labels: 8P0-820-043.lbl Part No SW: 8U0 820 043 G HW: 8U0 820 043 G
Component: E87 Klimavoll 0210
Revision: 00H05000 Serial number: 8U0820043G Shop #: WSC 00000 000 00000
VCID: 35372AABB94A4B63904-8060
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb Part No SW: 8X0 907 063 AK HW: 8X0 907 063 AB
Component: BCM PQ35 M 113 0827 Revision: AC113817
Coding: 0E000A2CA805F1C0201849C00184014C43F327AA206F812BE400878400C1 Shop #: WSC 44403 003 1048576
VCID: 05579A6BA52A1BE3404-8050
Subsystem 1 - Part No SW: 8U2 955 119 HW: 8U2 955 119 Labels: 1KX-955-119.CLB
Component: WWS316 150412 H37 0090
Serial number: 150422065443
Coding: 0047F7
Component: G397_RLFS H06 0002 Serial number: 23924130
Coding: 02006E
Subsystem 3 - Part No: 8X0 951 177 Component: DWA-Sensor H0 H01 0020
Subsystem 4 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501
Address 10: Park/Steer Assist (J446) Labels:| 8X0-919-475.clb Part No SW: 8X0 919 475 AE HW: 8X0 919 475
Component: PARKHILFE 4K H03 0080
Revision: 11001001 Serial number: 37031511200727
Coding: 090109
Shop #: WSC 00049 770 00116
ASAM Dataset: EV_EPHVA14AU21X0000 003007 ROD: EV_EPHVA14AU21X0000_003.rod
VCID: 094F965B89B27F8324C-805C
Address 15: Airbags (J234) Labels:| 8X0-959-655.clb Part No SW: 8U0 959 655 C HW: 8U0 959 655 C
Component: AirbagVW-AU10 H09 0900 Serial number: 003PAR0B80XV
Coding: 30523232333030303030554A305238553053 Shop #: WSC 00049 770 00116
ASAM Dataset: EV_AirbaAU10SMEAU316 001010 ROD: EV_AirbaAU10SMEAU316_001.rod
VCID: 47CB5063DF26C9F3F28-8012
Subsystem 1 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3496KSME704B7136ZZZZ
Subsystem 2 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3506KSME09727136ZZZN
Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3516KSME2F757136ZZZZ
Serial number: 3526KSME2D547136ZZZV
Subsystem 5 - Part No SW: 8U0 959 651 HW: 8U0 959 651
Serial number: 3555USME536A3335ZZZ/ No fault code found.
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb Part No SW: 8X0 953 521 B HW: 5K0 953 569 AE
Component: LENKS.MODUL 016 0162
Revision: FF010018 Serial number: 20150421201468 Coding: 1894004000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004 ROD: EV_SMLSNGVOLWS.rod
VCID: 3B233C9393EE9D13660-806E
Subsystem 1 - Part No SW: 8U0 951 528 H HW: 8U0 951 528 H
Component: E221 - MFL H08 0010 Serial number: 18 04 2015 B0056759
Address 17: Instruments (J285) Labels:| 8X0-920-xxx-17.clb-SRI1 Part No SW: 8U0 920 980 G HW: 8U0 920 980 G
Component: KOMBI_MEDIUM H04 0470 Serial number: 00000000000000
Coding: 42CF01
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399 ROD: EV_Kombi_UDS_VDD_AU10.rod
VCID: 40D94B7FFA08FECB332-8014
Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb Part No SW: 8U0 907 468 AQ HW: 8U0 907 468 G Component: GAT 4CAN 1L M H13 0090
Revision: 1P140041 Serial number: 4141P154250348 Coding: FBCF1A5A000108610353
Shop #: WSC 45175 002 1048576 VCID: 117FBE3BE1624743ECC-8044
Component: J367-BDM H07 0180 Serial number: 42120D20221491942945
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042 Serial number: 15123000120021200181
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb Part No SW: 0AY 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H52 7531 Serial number: HA1-00013.03.15 Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002015 ROD: EV_AllWheelContrHA1VW37X.rod
VCID: 52FD713724647C5B956-8006
16671 - Pump for Haldex Clutch
C1112 04 [008] - Internal System Fault
[Pump Motor - mechanisch defekt (mechanisch festgefahren)] Intermittent - Confirmed - Tested Since Memory Clear
Reset counter: 253
Mileage: 78637 km
Date: 2021.07.05
Time: 19:21:40
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb Part No SW: 8U0 920 980 G HW: 8U0 920 980 G
Component: IMMO H04 0470 Serial number:
Coding: 000002
ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113 ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb Part No SW: 8X0 959 793 H HW: 8X0 959 793 H
Component: TSG FA H11 0415 Revision: -------- Serial number: --------------
Coding: 011806205C01000000 Shop #: WSC 00049 770 00151
VCID: 52FD713724E47C5B956-8006
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb Part No: 5N0 909 144 R
Component: EPS_ZFLS Kl. 296 3501 Revision: 00H22000
Shop #: WSC 00049 770 00151 VCID: 40D94B7FF688FECB332-8014
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb Part No SW: 8X0 959 792 H HW: 8X0 959 792 H
Component: TSG BF H11 0415 Revision: -------- Serial number: --------------
Coding: 011806201E01000000 Shop #: WSC 00049 770 00193
VCID: 51FF7E3B21E20743ACC-8004
Address 55: Headlight Range (J745) Labels:| 5M0-907-357-V3.clb Part No SW: 5M0 907 357 G HW: 7P6 907 357 B
Component: AFS-ECU H01 0031 Revision: -------- Serial number: --------------
Coding: 08AE00102B200200 Shop #: WSC 51491 001 1048576
ASAM Dataset: EV_HeadlRegulLEDAFSPt 001001 ROD: EV_HeadlRegulLEDAFSPt.rod
VCID: 3829239FA2D8B60B8B2-806C
Subsystem 1 - Part No SW: 7PP 941 572 AA HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H08 0002 Coding: E02500
Subsystem 2 - Part No SW: 7PP 941 572 AA HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H08 0002 Coding: E02500
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo links H01 7050 Coding: E02500
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 7050 Coding: E02500
Address 5F: Information Electr. (J794) Labels: None Part No SW: 8U1 035 192 A HW: 8U1 035 192 A
Component: RMC Nav Plus H61 0139
Coding: 01010600024153470823020103010000000000
Shop #: WSC 00049 770 00116 VCID: 333314B3BB3E5553BE0-8066
Subsystem 1 - Part No: 8X0 919 884 J
Component: P32-50-15.03 0001
Subsystem 2 - Part No SW: 8U0 919 603 A HW: 8U0 919 603 A
Component: DUBasic AU316 H42 0018 Serial number: AUZ8ZDFM503H6J3
Fault Found:
00862 - Antenna for GPS Navigation (R50/R52) 011 - Open Circuit - Intermittent
Fault Status: 00101011
Reset counter: 250
Mileage: 78648 km
Date: 2021.07.05
Time: 20:59:33
Address 62: Door, Rear Left (J388) Labels:. 8X0-959-795.clb Part No SW: 8X0 959 795 C HW: 8X0 959 795 C
Component: TSG HL H08 0415 Revision: -------- Serial number: --------------
Coding: 010006200001000000
Shop #: WSC 00049 770 00151 VCID: 4FFB784337D611B3BA8-801A
Address 69: Trailer (J345) Labels:. 7N0-907-383.clb Part No SW: 7N0 907 383 HW: 7N0 907 383
Component: Anhaenger H09 0101
Revision: 3I001002 Serial number: 00000152266413 Coding: 0109080000000000
Shop #: WSC 05314 123 12345 VCID: 73B3D4B3FBBE15537E0-8026
Faults Found:
02588 - Swiveling Trailer Hitch
005 - No or Incorrect Basic Setting / Adaptation - Intermittent - MIL ON Freeze Frame:
Fault Status: 10100101
Reset counter: 253
Mileage: 78928 km
Date: 2021.07.13
Time: 17:44:35
011 - Open Circuit - Intermittent - MIL ON Freeze Frame:
Fault Status: 10101011
Reset counter: 253
Address 6D: Trunk Elect. (----) Labels:* Redir Fail! Part No SW: 8U0 959 107 HW: 8U0 959 107
Component: HDSG-Modul H01 0549
Revision: 15001001 Serial number: 111500227 Coding: 183307C002
ASAM Dataset: EV_HDSGAU316 001001 ROD: EV_HDSGAU316.rod
VCID: 7CA1FF8FD6605A2B2FA-8028
Address 72: Door, Rear Right (J389) Labels:. 8X0-959-795.clb Part No SW: 8X0 959 795 C HW: 8X0 959 795 C
Component: TSG HR H08 0415 Revision: -------- Serial number: --------------
End----(Elapsed Time: 01:31, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
