Code for Paddle Shifters AND Heated Steering Wheel?
SComp
Oakland, CA, USA
C?ID=391668
Hi, I’m trying to replace my 2011 Q7 heated wheel with a heated wheel with Paddle shifters from a 2010 A6, but can only find instructions for turning on one or the other. Does anyone know how to turn on both at once?
Thanks!
Hi and welcome.
Please post a complete Auto-Scan so people can see how the vehicle is equipped and configured.
SComp
Oakland, CA, USA
C?ID=391668
Thursday,15,July,2021,16:42:05:52289
VIN: WA1VMBFE9BD007527   License Plate:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3C 42 46 47 4C 4F 52 55
          56 5F 62 69 6C 6D 6F 72 76
VIN: WA1VMBFE9BD007527   Mileage: 126680km-78715miles
Address 01: Engine (J623-CATA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4L2 910 401     HW: 4L0 907 401 D
   Component: 3.0TDI FSA    H18 0009
   Revision: 54H18---    Serial number:
   Coding: 2A2A4012253600050000
   Shop #: WSC 04265 003 1048576
   ASAM Dataset: EV_ECM30TDI0114L2910401 002008
   ROD: EV_ECM30TDI0114L2910401_002.rod
   VCID: 619FA26BD1C56E13E0D-8034
5453 - Starter Relay
          P3088 00 [096] - Electrical Malfunction
5456 - Starter Will Not Turn
          P3054 00 [096] - Jammed or Electrical Malfunction
4814 - System Voltage
          P0562 00 [096] - Too Low
38161 - Reductant Metering Module
          P20FE 00 [096] - Malfunction
4629 - ECM Power Relay Load Circuit
          P068A 00 [032] - Opens Too Early
   Part No SW: 0C8 927 750 S    HW: 0C8 927 750 S
   Component: AL1000 AISIN  001 3408
   Coding: 001378
   ROD: EV_TCMAL991031_002.rod
   VCID: 3C21331F16E763FB93B-8068
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Revision: 00H02001
   Coding: 0099473
   Shop #: WSC 31414 790 00001
   VCID: 34311B3F3237ABBB5BB-8060
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 F
   Component: FBSAUDIC6 ELV   H05 0130
   Revision: 00H05000    Serial number: 10603401753278
   Coding: 0000135
   VCID: 2517F67B89EDC233DC5-8070
   Subsystem 1 - Part No: 4F0 910 132 L
   Component: FBSAUDIC6 EZS   H03 0020
   Component: FBSAUDIC6 KSG   H03 0020
   Component: FBSAUDIC6 IDG   H01 0053
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AF
   Component: KLIMA 4 ZONEN H13 0060
   Revision: 00---022    Serial number: 00000000264943
   Coding: 0004A036
   VCID: 2517F67B85EDC233DC5-8070
   Subsystem 1 - Part No SW: 8K0 959 772 D    HW: 8K0 959 772
   Component: SLR-B8  H05 0006
   Serial number:           1002258531
   Coding: 070000
   Subsystem 2 - Part No SW: 8K0 959 772 D    HW: 8K0 959 772
   Serial number:           1002258842
   Coding: 070000
   Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
   Component: ILM Fahrer      H29 0390
   Coding: 0139123
   VCID: 6E85C9571C9BC16B6DF-803A
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H17 0100
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 72 AIRBAG AUDI8RH43 0230
   Revision: 07H43000    Serial number: 0038QD09NRJ%
   Coding: 0014130
   VCID: 2B030043EF09F4430A1-807E
   Subsystem 1 - Part No: 4L0 910 339 A
   Component: BF-Gewichtsens. H03 0030
   Subsystem 2 - Serial number: 6332QSME76023C70C
   Subsystem 3 - Serial number: 6342QSME10030854/
   Subsystem 4 - Serial number: 6352QSME4F7D0038R
   Subsystem 5 - Serial number: 6362QSME74020758B
   Subsystem 6 - Serial number: 63734SME137A261C0
   Subsystem 7 - Serial number: 63834SME44782424.
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 C
   Component: J0527               0530
   Revision: 00H06000    Serial number: 90025110210323
   Coding: 0012242
   VCID: 270BFC73F3E1D023EE9-8072
   Component: E0221           H02 0100
Address 17: Instruments (J285)       Labels:. 4L0-920-xxx-17.clb
   Part No SW: 4L0 920 984 A    HW: 4L0 920 984 A
   Component: KOMBIINSTR.   H10 0209
   Revision: 00000000    Serial number: FLR03LR1C
   Coding: 8BD664040900CF05020201
   VCID: 313F122BC1259E9330D-8064
   Part No SW: 4F0 907 468 Q    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0047
   Revision: MB300033    Serial number: 3300M10C300079
   Coding: 00C303
   VCID: 3D273E1B0D7D6AF3A45-8068
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790371445
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AB
   Revision: 00---010    Serial number: 00000030180144
   Coding: 0000006
   VCID: 6889BF4F3E7F1F5B273-803C
00003 - Control Module
                    Fault Status: 00100011
                    Fault Frequency: 23
                    Mileage: 119459 km
                    Date: 2020.09.06
                    Time: 13:39:56
                    Fault Status: 00101101
                    Reset counter: 57
                    Mileage: 121278 km
                    Date: 2020.11.01
                    Time: 16:16:49
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0064
   Revision: AA000000    Serial number: 00001002264361
   Coding: 00581B00000011110000
   VCID: 323D1D27C423A58B497-8066
   Part No SW: 4L0 910 566 C    HW: 4L0 907 566 B
   Revision: 00H01000    Serial number: 6PZ 009 014-10
   Coding: 0010001
   VCID: 2E050957DC1B816B2DF-807A
   Subsystem 3 - Serial number: 5F09.01.1100H010003C910382ÿ
   Subsystem 4 - Serial number: 910382ÿ
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0361
   Revision:             Serial number: 0008000176049
   Coding: 011F57205E40440004
   VCID: 48C95FCF52BF3F5B073-801C
   Part No SW: 4L0 910 289 H    HW: 4L0 907 289 H
   Component: Komfortgeraet   H10 0110
   Revision: 0110 ---    Serial number: 01421421540000
   Coding: 3569693
   VCID: 3537263B394DB2B36C5-8060
   Part No SW: 4L0 035 223 G    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H03 0040
   Revision: CH003000    Serial number: 00000000022201
   VCID: 2615F177F8EBC92BD5F-8072
                    Fault Frequency: 11
                    Reset counter: 86
                    Mileage: 121294 km
                    Date: 2020.11.01
                    Time: 16:50:29
                    Bin. Bits: 00000001
Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H03 0110
   Revision: 00000276    Serial number: 00002760049322
   Coding: 0758477
   VCID: 2313E86387D93C03B21-8076
   Part No SW: 4F0 910 280     HW: 4F0 907 280 D
   Component: ILM Beifahrer   H14 0100
   Revision:             Serial number: 00000000083253
   Coding: 0012001
   VCID: 5EE59997EC3B51EBDDF-800A
02752 - Glovebox Unlocking Motor (V327)
                    Fault Status: 00101010
                    Reset counter: 77
                    Mileage: 126076 km
                    Date: 2021.06.26
                    Time: 17:57:00
                    Voltage: 12.600 V
                    Temperature: 77.0°C
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0361
   Revision:             Serial number: 0008000187430
   VCID: 47CB5CF35FA130230E9-8012
   Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
   Coding: 0000031
                    Reset counter: 200
                    Mileage: 121278 km
                    Date: 2020.11.01
                    Time: 16:15:10
   Part No SW: 4G0 035 082     HW: 4G0 035 082
   Component: Radio U SIRIU H51 0052
   Revision: AB001007    Serial number: 471A$0B7553488
   Coding: 020007010000000000
   VCID: 5DE79E9BED3D4AF3C45-8008
   Part No SW: 4L0 035 664 B    HW: 4L0 035 664 A
   Component: H-BN-NA       H51 0116
   Revision: --------    Serial number: 489A80B7546669
   Coding: 010200060004E3EF51002305EF6300030000
   VCID: 2A0D0547ECF3ED4BF17-807E
   Subsystem 1 - Part No: 8R0 060 884 P
   Component: NAR 2010  0407
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0084
   Serial number: 9466L/0A0284247
   Subsystem 3 - Part No SW: 4L0 910 609     HW: 4L0 919 611 C
   Component: E0380 Bedient  H05 0060
   Serial number: 00000001767792
   Component: CD-Database  1886
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0361
   Revision:             Serial number: 0008000188956
   Coding: 010E57204040230004
   VCID: 46D551F758AB292BF5F-8012
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Revision: 2A001001    Serial number: 00000141703689
   Coding: 0200000000000000
   Revision: --H05---    Serial number: 525PA8-J0Z42E5
   Coding: 1021201
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Component: ValeoHeckdeckel H56 0500
   Revision: --H56001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C81C35F2A87337B43B-8038
   Subsystem 3 - Serial number: RD22.01.11--H56001001A0129ÿ
   Subsystem 4 - Serial number: 1A0129ÿ
   Component: ILM HINTEN 2    H07 0080
   Revision: AAH07080    Serial number: 111889314-----
   Coding: 0003595
   VCID: 2615F177F4EBC92BD5F-8072
   Component: J_245_EE16_SKB10H11 0220
   Component: J_394_EE16_SKB10H11 0220
   Component: J_392_EE16_SKB10H11 0220
   Component: TSG HR        H11 0361
   Revision:             Serial number: 0008000189142
02131 - Child Safety Lock Motor
                    Fault Status: 01101000
                    Reset counter: 188
                    Mileage: 120700 km
                    Date: 2020.09.10
                    Time: 12:20:28
   Part No SW: 4L0 910 283 C    HW: 4L0 919 283 C
   Component: Parkhilfe 8-Kan H03 0500
   Revision: 00H03000    Serial number: 37331101702079
   Coding: 0231266
   VCID: 2A0D0547E0F3ED4BF17-807E
End----------(Elapsed Time: 02:14, VBatt start/end: 12.0V/12.1V)-----------
Try changing the Steering Wheel Control Module's coding from 0012242 to 0012342
