Ran VCDS after not getting communication with it. Runs and will drive in 1st but no chimes and other things inside. Cluster isn't lit up. I change fuel filter turned it on had had multiple codes on the cluster. So, I disconnected the battery to reset the codes. After I reconnected I had no cluster and car went into safe mode. After the scan. These are the codes. Seems all bit 3 go to Powertrain Databus.
How bad am I going to get broke off for the fix?
Tuesday,13,July,2021,18:12:03:60496
VCDS Version: 21.3.0.0 (x64)
VIN: WVGCM77L34D058513 License Plate:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
Address 01: Engine Labels: 077-907-560-AXQ.lbl
Part No SW: 4D0 907 560 DA HW: 8E0 907 560
Component: 4.2L V8/5V G 0020
Coding: 0007875
Shop #: WSC 31414 000 00000
VCID: 68D4B062589F8BCB6B-5120
9 Faults Found:
18053 - Powertrain Data Bus
P1645 - 008 - Missing Message from AWD Controller
18045 - Powertrain Data Bus
P1637 - 008 - Missing Message from Electric Load Controller
18043 - Powertrain Data Bus
P1635 - 008 - Missing Message from A/C Controller
18057 - Powertrain Data Bus
P1649 - 008 - Missing Message from ABS Controller
18107 - Powertrain Data Bus
P1699 - 008 - Missing Message from Steering Wheel Electronics
18058 - Powertrain Data Bus
P1650 - 008 - Missing Message from Instrument Cluster - MIL ON
18034 - Powertrain Data Bus
P1626 - 008 - Missing Message from TCU - MIL ON
17699 - Coolant Temp Sensor at Radiator Outlet (G83)
P1291 - 002 - Signal too Large - Intermittent
16885 - Vehicle Speed Sensor
P0501 - 004 - Implausible Signal - Intermittent
Readiness: 0010 1101
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) X012
VCID: 67D6B35E558184B362-FFFE
No Faults Found
Address 46: Central Conv. Labels:
VCID: 55AA8996ACED0623C0-FFFE
End-------------------------(Elapsed Time: 10:02)--------------------------
Address 01: DTCs cleared.
