Towbar / Trailer activation (2020 T6.1)
C_V
England, UK
C?ID=337088
Hello, I've recently installed a tow bar to a T6.1 4 motion - we've installed a few of the same kits but this is the first on a 4 motion.
The kits we buy come with comprehensive coding instructions, they've always worked first time with no issues, but this one has left an error in the ABS module saying "0602 - Function Restriction due to Faults in Other Modules" - we didnt take a scan before carrying out the work unfortunately.
I've gone back to the steps and checked that each change is still saved in each module, all the ones we changed are. There is a step called "Trailer hitch control module -> installed" under Encoding 09 Cen Elec Module which we haven't found previously or on this one either - that was my first thought as a potential issue.
Just looking at the installed modules, There is a step in the instructions if applicable to change in 74 Chassis Control - we have 22 AWD, I wonder if there is a setting in there that isn't listed in our instructions.
There is also a telematics fault which can be seen in the auto scan below, we see this fault quite regularly but never actually found out what it means?
Could someone point me in the right direction to start looking please?
Thursday,08,July,2021,13:35:44:53043
VIN: WV1ZZZ7HZLH064128   License Plate: T6.1-TOWBAR-FIT-ABS-FAULT
Mileage: 6596km-4098mi   Repair Order:
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 22 44 5F 65 69 75
VIN: WV1ZZZ7HZLH064128   Mileage: 6596km-4098miles
Address 01: Engine (J623-CXHA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 RT    HW: 04L 907 445 M
   Component: R4 2.0l TDI   H01 9970
   Revision: 23301001
   Coding: 001940144326050900000000000000000000000000000000
   Shop #: WSC 00012 790 00028
   ASAM Dataset: EV_ECM20TDI03004L906056RT 005004
   ROD: EV_ECM20TDI03004L906056LE_005.rod
   VCID: 107845F86AEF80BB1F3-8044
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 7LB 614 517 A    HW: 7LB 614 517
   Component: ESC_base      H01 0700
   Serial number: 08501612200217
   Coding: 30554452484DEE890C5522A6126E7706392120B8
   ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 002010
   ROD: EV_Brake1ESP90iBOSCHVN46X_002.rod
   VCID: 3E24CB4000FB46CBBDF-806A
          U1113 00 [008] - -
          [Dst_EpsTorqReqRejected]
                    Mileage: 6596 km
                    Date: 2021.07.07
                    Time: 23:04:14
Address 08: Auto HVAC (J301)       Labels:* None
   Part No SW: 7LA 907 426 B    HW: 7LA 907 426 B
   Component: AC Manuell    H01 0502
   Coding: A03110000810000001000800504001050000000000000000800000000000
   ASAM Dataset: EV_AirCondiBHTCT6PA 001004
   ROD: EV_AirCondiBHTCT6PA.rod
   VCID: 42DCBFB07403222BD97-8016
   Rear A/C control head:
   Part No SW: 2Q5 937 090     HW: 2Q5 937 090
   Component: BCM T6PA Std+ H10 0935
   Serial number: 01102007001831
   ASAM Dataset: EV_BCMA0 205001
   ROD: EV_BCMA0_205.rod
   VCID: 74B029687E37DC9B9BB-8020
   Driver door control module:
   Subsystem 1 - Part No SW: 7L1 959 405     HW: 7L1 959 163
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000037427075
   Coding: 1F0008
   Front passenger door control module:
   Subsystem 2 - Part No SW: 7L1 959 406     HW: 7L1 959 164
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000037455978
   Coding: 050000
   Serial number: 000000000ZY2004027Z0
   Serial number: 00000000000032804676
   Part No SW: 5QA 919 283 E    HW: 5QA 919 283
   Component: PDC 4 Kanal   H08 0061
   Serial number: 000150059220074
   Coding: 0601050101
   ASAM Dataset: EV_EPHVA14AU3700000 009044
   ROD: EV_EPHVA14AU3700000_009_VW37.rod
   VCID: 4CC091884647E45B23B-8018
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Coding: 2A00600A41FF8748949C815500508700000000000000000004
   Shop #: WSC 00012 790 00171
   ROD: EV_ACCMRRCONTIVW376_003_VN54.rod
   VCID: 43D2BAB46B192B23D21-8016
   Part No SW: 2Q0 959 655 AD    HW: 2Q0 959 655 AD
   Component: VW22Airbag    015 0506
   Revision: --------
   Coding: 8800C00000000000400000CF008C40000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 7F5AF64447718FC3F69-802A
Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI3
   Part No SW: 7LA 920 941     HW: 7LA 920 941
   Component: KOMBI         205 6750
   Coding: 27A412802080260001886A050401000000600000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009069
   ROD: EV_DashBoardVDDMQBAB_VW27.rod
   VCID: 7DA60C4C4D7D9DD3E45-8028
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 08032010523052
   Coding: 030100044F05730000000008000F00010001070000000000000000000000
   ROD: EV_GatewNF_VW27.rod
   VCID: 70B825780A2FE0BB7F3-8024
   Generator:
   Component: 4-00-05-00-04
   Subsystem 2 - Part No SW: 3G0 959 442 E    HW: 3G0 959 442 E
   Component: E221__MFL-PR6  H06 0110
   Serial number: PR6-0440066071203970
   Coding: 281C00
   Subsystem 3 - Part No SW: 7E0 915 181 N    HW: 7E0 915 181 N
   Component: J367-BDMConti  H03 1052
   Serial number: 7734330100200302003C
   Part No SW: 0CQ 907 554 L    HW: 0CQ 525 130 C
   Component: Haldex4Motion H56 7822
   Serial number: HA1-00021.01.20
   Coding: 0001
   VCID: 4EC49B80B05BD64B4DF-801A
Address 44: Steering Assist (J500)       Labels:| 2N0-909-143.clb
   Part No SW: 7LA 909 144 F    HW: 7LA 909 144 D
   Component: EPS_MQB_ZFLS  751 7150
   Coding: 0106
   ASAM Dataset: EV_SteerAssisMNB 002012
   ROD: EV_SteerAssisMNB.rod
   VCID: 45D6A4AC652D1513FC5-8010
   Part No SW: 3G5 035 820     HW: 3G5 035 820
   Component: MU-O-ND-EU    H12 0156
   Serial number: VWZAZ2X0566248
   Coding: 64600008000020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001001
   ROD: EV_MUOIMQB_VN46.rod
   VCID: 619E503CD1C55933E0D-8034
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H61 8214
   Serial number: VWZ6ZJX1461945
   Subsystem 2 - Part No: V03 959 806 MG
   Component: EU 2019/04     1004
   Part No SW: 5Q0 907 273 D    HW: 5Q0 907 273
   Component: RDKBERU30     H05 0010
   Serial number: 40000000388455
   ROD: EV_RDKBERU30_VW41.rod
   VCID: 3634D36028CB8E8B65F-8062
   Part No SW: 5Q0 907 383 E    HW: 5Q0 907 383 B
   Component: ConWysTrailer H14 0137
   Serial number: 00000181563668
   Coding: 0100000200000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
   VCID: 392ED85C19D561F388D-806C
   Part No SW: 5WA 035 284     HW: 5WA 035 284
   Component: OCUGen3High   H20 0088
   Serial number: 0000000001VITD3
   Coding: 06462000196898009005460160000607
   ASAM Dataset: EV_OCUGen3High 002115
   ROD: EV_OCUGen3High_002_VN46.rod
   VCID: 03527AB42B99EB23921-8056
7170 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Multi Function Display (0x0F) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
                    Mileage: 6596 km
                    Date: 2021.07.07
                    Time: 23:04:18
                    Voltage terminal 30: 11.8 V
End----(Elapsed Time: 01:29, VBatt start/end: 11.6V/11.8V. VIgn 11.9V)-----
VWT6
Finland
C?ID=295527
@C_V: Hi.
hmm....... for your hex09 question - does your BCM have an adaptation channel similar to:
  • ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet (meaning=Networking - Trailer connection device)
If so, try setting the value to "installed"
VWT6
Finland
C?ID=295527
T6.1 has a similar one: "ENG122979-MAS01374-Networking-Trailer"
^^^^^^^^ and maybe hex03: IDE04774-Vehicle and trailer stabilization > activated
VWT6
Finland
C?ID=295527
Hmmm... no such thing in T6.1 hex03 adaptations... although I had catched the below in a T6.1 with OEM trailer electronics (factory installed).
336920 - Databus - U1122 00 [040] - Implausible Message - [Brake electronics - implausible message (ESP_v_signal)]
Jacek
Poland
C?ID=360566
Is that "[Dst_EpsTorqReqRejected]" not referring to the power steering, take a look at the coding or adaptation in hex44.
Jacek
Poland
C?ID=360566
Is that "[Dst_EpsTorqReqRejected]" not referring to the power steering, take a look at the coding or adaptation in 44.
"1 Fault Found:
U1113 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear"
C_V
England, UK
C?ID=337088
