R5 2.5 TDI - How to test sensors
MickB
France, Crolles
C?ID=437669
Hi there!
I'm stuck since months with power loss, resulting in error P0299 (boost pressure not reached).
After large research I found that the ECU's signal to the turbo's solenoid (variable geometry) is always between 40% and 60% (duty cycle).
I tried an ECU swap, the problem is the same, so my conclusion is that the ECU receive a wrong input signal from a sensor.
But I can't figure out the faulty sensor :-(
I've already checked:
- Boost pressure sensor (100% sure OK)
- Air flowmeter (100% sure OK)
- Throttle (90% sure OK, signal goes from 0% to 100%)
- Coolant sensor (90% sure OK, tested with external thermometer)
- Diesel temp (100% sure OK)
My current guess is the crankshaft sensor or the camshaft, but I don't know how I can check that…
Any idea?
Thanks!
MickB
France, Crolles
C?ID=437669
Of course!
Wednesday,14,July,2021,17:36:07:05101
VIN: WV2ZZZ7HZ5H097010   License Plate:
Mileage: 189740km-117898mi   Repair Order:
          57 6E 76 77 78 7D
VIN: WV2ZZZ7HZ5H097010   Mileage: 189740km-117898miles
   Part No SW: 070 906 016 BF    HW: 028 101 183 7
   Component: R5 2,5L EDC G000SG  7000
   Revision: 12345678    Serial number: VWZ7Z0E1788298
   Coding: 0001172
   Shop #: WSC 02756 785 00200
   VCID: 55F78BD0C91068738C5-513C
16683 - Boost Pressure Regulation
            P0299 - 000 - Control Range Not Reached - Intermittent
                    RPM: 2268 /min
                    Torque: 370.9 Nm
                    Speed: 101.0 km/h
                    Load: 63.5 %
                    Voltage: 14.21 V
                    Bin. Bits: 00101000
                    Absolute Pres.: 2284.8 mbar
                    Absolute Pres.: 1836.0 mbar
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 7H0-907-37x-ESP-A.lbl
   Part No: 7H0 907 379 M
   Component: ESP ALLRAD MK25     0203
   Coding: 0006687
   VCID: 3FDB49785B6C8223B69-5118
Address 08: Auto HVAC        Labels: Redir Fail!
   Part No: 7H5 907 040 B
   Component: CLIMAtronic T5    X 3717
   Coding: 0000040
   Shop #: WSC 61431 001 1048576
   VCID: 2A0D082CB0EE178BF17-5118
   Subsystem 1 - Part No: 7H7 907 049 A
   Component: Display_2_ClimaT5 X 0307
01186 - Rear Air Distribution Flap Motor (V136)
Address 09: Cent. Elect.        Labels:. 7H0-937-049.lbl
   Part No: 7H0 937 049 P
   Component: BORDNETZ SGVER 1.0  1901
   Coding: 0000102
   Shop #: WSC 00012 000 00000
01598 - Drive Battery Voltage
            002 - Lower Limit Exceeded
00991 - Interior Lights
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
   Part No: 1C0 909 605 F
   Component: 11 AIRBAG VW61 0R   0003
   Coding: 12593
   Shop #: WSC 02756
   VCID: 270BF118A6FC2AE3EE9-5118
   Part No: 1J0 907 487 A
   Component: Lenkradelektronik   0005
   Coding: 00119
   Shop #: WSC 02770
   VCID: 2F3B19388E0C72A3269-5160
Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
   Part No: 7H5 920 870 J
   Component: KOMBI+WEGFAHRSP VDO V03
   Coding: 05112
   Shop #: WSC 61427
   VCID: 382922647B42B51B773-5118
   WV2ZZZ7HZ5H097010     VWZ7Z0E1788298
01322 - Control Module for Multi-Function Unit (MFA) (J501)
Address 18: Aux. Heat        Labels: 7H0-819-008.clb
   Part No: 7H0 815 071 C
   Component: Standheizung        0207
   VCID: 2809F224AEE2259BE73-5118
00664 - Fuel gauge
   Part No: 6N0 909 901
   Coding: 00022
   Shop #: WSC 02756
   VCID: 70B9DA4453B22D5B7F3-5118
Address 22: AWD        Labels: 7H0-907-554.clb
   Part No: 7H0 907 554 A
   Component: HALDEX 4Motion      0105
   Coding: 0000001
   Shop #: WSC 02771 785 00200
   VCID: 2E05043C8C067BAB2DF-5118
Address 37: Navigation        Labels: 7L6-919-887-CD.lbl
   Part No: 7H0 919 887 D
   Component:      Navigation     0634
   Coding: 0000002
   Shop #: WSC 02770 785 00200
   VCID: 3D27337051609033A45-5118
Address 46: Central Conv.        Labels: 7H0-959-433.lbl
   Part No: 7H0 959 433 B
   Component: C   Komfortgerát     0004
   Coding: 00073
   Shop #: WSC 02756
   VCID: 323D104C9D3E5F4B497-4AE0
   Subsystem 1 - Part No: 7H1959801A
   Component: Tõrsteuer.FS KLO 0203
   Subsystem 2 - Part No: 7H1959802A
   Component: Tõrsteuer.BF KLO 0203
Address 56: Radio        Labels: 7L6-035-186-CD.lbl
   Part No: 7L6 035 186 A
   Component:        Radio        0634
   Coding: 0006405
   VCID: 313F1F409D38645330D-5118
Address 76: Park Assist        Labels: 7E0-919-283.lbl
   Part No: 7E0 919 283
   Component: Parkingsyst. T5 T5M 801
   Coding: 00127
   Shop #: WSC 02756
   VCID: 6C81CE347F9AC9BB43B-513C
Address 77: Telephone        Labels: None
   Part No: 7H0 035 729 F
   Component: CIB PAH  HW 203 SW  0309
   Coding: 0000364
   VCID: 2F3B19388B0C72A3269-5118
Address 7D: Aux. Heat        Labels: None
   Part No: 7H0 819 002 K
   Component: Luftstandheizung, D 0426
   Revision: 00052426    Serial number:        0097616
   VCID: 2E05043C8C067BAB2DF-4B1E
End----------(Elapsed Time: 05:02, VBatt start/end: 12.3V/12.3V)-----------
OK, you have a boost pressure regulation fault. Why do you think this would be caused by the crankshaft or camshaft sensors? I don't think that is at all likely.
Look at MVB 011. Field 2 is requested boost, field 3 is actual (measured) boost, and field 4 is is duty cycle for the control solenoid.
My guess is you either have a boost leak or a sticky turbo actuator.
MickB
France, Crolles
C?ID=437669
I'm 100% sure that turbo is ok and no leak in the pipes, because:
- Turbo is brand new
- All pipes are leak-checked (supercharging and vaccum)
- Last but not least: if I control the actuator's solenoid by myself (in place of the ECU), everything works like a charm, boost pressure rise quickly and reach the requested boost pressure
My last find is that the ECU never ask the solenoid to give 100% pressure from the turbo.
Example:
- Engine at 2200 rpm
- Throttle at 100%
- 5th gear
- Requested boost: 2200mbar
- Actual boost pressure: 1300mbar
- Solenoid duty cycle: 60%
So: why the ECU do not ask 100% to the solenoid?
I tried a ECU swap: same issue.
That's why I'm trying to find out why the ECU is making a wrong calculation.
My guess is a faulty sensor, sending a wrong value to the ECU, resulting in a low duty cycle.
- G70 (brand new)
- G62
- G83
- G81 (brand new)
- G31 (brand new)
I'm a bit lost with this issue and I've shown the T5 to two separate mechanic with no results…
MickB
France, Crolles
C?ID=437669
Hi,
Any idea on how I can check sensors?
Or an other lead to explore?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
As far as the sensors go, check them at the ECU itself by using the measuring values provided. With a cold engine, you should see them at ambient temp and pressure. Personally I do not see this as a sensor issue but more likely to be a leak either on the pressure or vacuum side. Quite common would be a faulty diverter or boost pressure control valve. That said, it is wise not to assume replacement parts are 100% OK - even when using original VAG parts! If you swapped some or all of these (sensors & turbo) with aftermarket or rebuild parts, those were my first things to triple check. Did you check all the points mentioned in our WIKI? Does the charge pressure system keep it's pressure when you manually apply it and check it with a pressure gauge (i.e. have you confirmed there are no leaks)?
I've updated our control module documentation, which means there is now documentation for your engine control module. In order to use it, please download the following update - it installs on top of your existing VCDS installation and includes quite a few new files.
MickB
France, Crolles
C?ID=437669
Hi Sebastian,
Cool! I'll give it a try soon.
Yes:
- Turbo is brand new + tested
- Charging hose/pipe: new seals + leak tested (keep pressure manually applied)
- Vaccum hose/pipe: leak tested
- Pressure sensor: tested (compare value in VCDS vs real value checked with a digital manometer)
- Valve: brand new + checked
For the temp sensor: I've checked them comparing VCDS value vs digital thermometer, all are good.
What let me say all the charging parts are ok: If I control the valve manually, by applying a 0-12V voltage on it, the charing pressure is good and everything works like a charm. As the valve is controlled by a simple PWM signal, you can replace the signal with an external power supply. Applying 6V mean a 50% PWM duty cycle, 12V mean a 100% PWM duty cycle.
As you can see in the file log behind, the duty cycle sent by the ECU is almost every time around 50%, even when there's a big difference between asked pressure and real pressure. So my guess is that the ECU is making a wrong calculation.
;RPM;P consigne;P réelle;Duty Cycle;;;;;;
TIME;;;;;TIME;;;;;TIME
STAMP; /min; mbar; mbar; %;STAMP;;;;;STAMP
0,02;798;1009,8;979,2;78,9;;;;;;
0,28;798;1009,8;979,2;78,9;;;;;;
0,54;798;1009,8;979,2;78,9;;;;;;
0,8;798;1009,8;979,2;78,9;;;;;;
1,06;798;1009,8;979,2;78,9;;;;;;
1,33;798;1009,8;979,2;78,9;;;;;;
1,6;798;1009,8;979,2;78,9;;;;;;
1,86;798;1009,8;979,2;78,9;;;;;;
2,14;798;1009,8;979,2;78,9;;;;;;
2,4;798;1009,8;979,2;78,9;;;;;;
2,67;798;1009,8;979,2;78,5;;;;;;
2,93;798;1009,8;979,2;78,9;;;;;;
3,2;840;1244,4;979,2;78,5;;;;;;
3,47;1134;1030,2;969;74,2;;;;;;
3,73;1113;1030,2;989,4;74,6;;;;;;
3,99;1071;1040,4;989,4;75;;;;;;
4,26;1071;1050,6;979,2;75;;;;;;
4,51;1050;1050,6;989,4;75,4;;;;;;
4,76;1050;1060,8;989,4;75,4;;;;;;
5,04;1008;1060,8;989,4;76,1;;;;;;
5,31;966;1040,4;989,4;76,5;;;;;;
5,57;945;1040,4;989,4;76,9;;;;;;
5,84;945;1060,8;989,4;76,9;;;;;;
6,1;945;1050,6;989,4;76,9;;;;;;
6,37;861;1009,8;989,4;77,7;;;;;;
6,64;756;1050,6;989,4;79,3;;;;;;
6,9;798;1050,6;989,4;78,9;;;;;;
7,15;861;1040,4;989,4;78,1;;;;;;
7,43;903;1020;989,4;77,3;;;;;;
7,7;882;1020;989,4;77,7;;;;;;
7,96;882;1020;989,4;77,7;;;;;;
8,23;861;1020;989,4;77,7;;;;;;
8,5;861;1020;989,4;78,1;;;;;;
8,76;840;1009,8;979,2;78,1;;;;;;
9,02;840;1009,8;979,2;78,1;;;;;;
9,29;840;1009,8;979,2;78,5;;;;;;
9,56;819;1009,8;979,2;78,5;;;;;;
9,82;819;1009,8;979,2;78,5;;;;;;
10,09;819;1009,8;979,2;78,5;;;;;;
10,34;819;1009,8;979,2;78,5;;;;;;
10,62;819;1009,8;979,2;78,5;;;;;;
10,89;819;1009,8;979,2;78,5;;;;;;
11,15;819;1009,8;979,2;78,5;;;;;;
11,42;819;1009,8;979,2;78,5;;;;;;
11,67;819;1009,8;979,2;78,5;;;;;;
11,95;819;1009,8;979,2;78,5;;;;;;
12,22;819;1009,8;979,2;78,5;;;;;;
12,48;819;1009,8;979,2;78,5;;;;;;
12,74;819;1009,8;979,2;78,5;;;;;;
13,01;819;1009,8;979,2;78,5;;;;;;
13,28;819;1009,8;979,2;78,5;;;;;;
13,54;819;1009,8;979,2;78,5;;;;;;
13,81;798;1009,8;979,2;78,9;;;;;;
14,07;798;1009,8;979,2;78,9;;;;;;
14,33;798;1009,8;979,2;78,9;;;;;;
14,6;798;1009,8;979,2;78,9;;;;;;
14,87;798;1009,8;979,2;78,9;;;;;;
15,13;798;1009,8;979,2;78,9;;;;;;
15,4;777;1009,8;979,2;78,9;;;;;;
15,67;798;1009,8;979,2;78,9;;;;;;
15,93;798;1009,8;979,2;78,9;;;;;;
16,2;798;1009,8;979,2;78,9;;;;;;
16,46;798;1009,8;979,2;78,9;;;;;;
16,72;798;1009,8;979,2;78,9;;;;;;
16,99;798;1009,8;979,2;78,9;;;;;;
17,26;798;1009,8;979,2;78,9;;;;;;
17,52;777;1009,8;979,2;79,3;;;;;;
17,78;777;1009,8;979,2;79,3;;;;;;
18,05;819;1009,8;979,2;78,5;;;;;;
18,31;819;1009,8;979,2;78,5;;;;;;
18,58;798;1009,8;979,2;78,9;;;;;;
18,84;798;1009,8;979,2;78,9;;;;;;
19,11;798;1009,8;979,2;78,9;;;;;;
19,37;798;1009,8;979,2;78,9;;;;;;
19,64;798;1009,8;979,2;78,9;;;;;;
19,91;798;1009,8;979,2;78,9;;;;;;
20,17;798;1009,8;979,2;78,9;;;;;;
20,44;798;1009,8;979,2;78,9;;;;;;
20,7;798;1009,8;979,2;78,9;;;;;;
20,97;798;1009,8;979,2;78,9;;;;;;
21,24;798;1009,8;979,2;78,9;;;;;;
21,5;798;1009,8;979,2;78,9;;;;;;
21,77;798;1009,8;979,2;78,9;;;;;;
22,03;798;1009,8;979,2;78,9;;;;;;
22,3;777;1009,8;979,2;78,9;;;;;;
22,56;777;1009,8;979,2;79,3;;;;;;
22,84;777;1020;979,2;78,9;;;;;;
23,1;798;1020;979,2;78,9;;;;;;
23,37;819;1020;979,2;78,5;;;;;;
23,63;819;1009,8;979,2;78,5;;;;;;
23,9;798;1009,8;979,2;78,9;;;;;;
24,17;798;1009,8;979,2;78,9;;;;;;
24,42;798;1009,8;979,2;78,9;;;;;;
24,69;798;1009,8;979,2;78,9;;;;;;
24,95;798;1009,8;979,2;78,9;;;;;;
25,22;798;1009,8;979,2;78,9;;;;;;
25,49;798;1009,8;979,2;78,9;;;;;;
25,76;798;1009,8;979,2;78,9;;;;;;
26,01;798;1009,8;979,2;78,9;;;;;;
26,28;756;1009,8;979,2;79,3;;;;;;
26,54;756;1020;969;79,3;;;;;;
26,81;798;1020;979,2;78,9;;;;;;
27,08;777;1020;979,2;78,9;;;;;;
27,34;735;1050,6;979,2;79,7;;;;;;
27,61;798;1040,4;979,2;78,9;;;;;;
27,87;882;1020;979,2;77,7;;;;;;
28,15;861;1020;989,4;77,7;;;;;;
28,4;861;1020;999,6;77,7;;;;;;
28,67;861;1020;999,6;78,1;;;;;;
28,94;861;1020;999,6;78,1;;;;;;
29,2;840;1020;989,4;78,1;;;;;;
29,47;819;1020;989,4;78,5;;;;;;
29,73;819;1020;989,4;78,5;;;;;;
30;819;1020;989,4;78,5;;;;;;
30,26;819;1020;989,4;78,5;;;;;;
30,53;840;1020;979,2;78,1;;;;;;
30,8;840;1020;979,2;78,1;;;;;;
31,06;840;1009,8;979,2;78,1;;;;;;
31,33;819;1009,8;979,2;78,5;;;;;;
31,59;819;1009,8;979,2;78,5;;;;;;
31,86;798;1009,8;979,2;78,9;;;;;;
32,13;756;1020;979,2;79,3;;;;;;
32,39;798;1244,4;979,2;78,9;;;;;;
32,65;1134;1101,6;969;74,2;;;;;;
32,92;1218;1336,2;989,4;75;;;;;;
33,19;1428;1458,6;999,6;67,5;;;;;;
33,45;1554;1336,2;1040,4;66,7;;;;;;
33,72;1323;1132,2;1091,4;71;;;;;;
33,99;1071;1162,8;1111,8;79,3;;;;;;
34,25;1071;1193,4;1101,6;77,3;;;;;;
34,52;1050;1183,2;1091,4;78,1;;;;;;
34,79;1050;1193,4;1091,4;79,3;;;;;;
35,05;1113;1050,6;1081,2;71;;;;;;
35,32;1071;1030,2;1060,8;72,2;;;;;;
35,58;1071;1020;1040,4;73,8;;;;;;
35,85;1092;1030,2;1030,2;75;;;;;;
36,11;1071;1050,6;1020;75;;;;;;
36,38;1050;1060,8;999,6;75,4;;;;;;
36,65;1155;1111,8;999,6;74,2;;;;;;
36,92;1260;1275;999,6;74,6;;;;;;
37,18;1365;1203,6;1009,8;74,6;;;;;;
37,44;1491;1162,8;1040,4;75;;;;;;
37,7;1575;1142,4;1060,8;71;;;;;;
37,98;1638;1122;1060,8;68,3;;;;;;
38,24;1701;1101,6;1060,8;67,1;;;;;;
38,51;1743;1091,4;1050,6;65,1;;;;;;
38,78;1764;1081,2;1050,6;65,1;;;;;;
39,03;1785;1081,2;1040,4;65,9;;;;;;
39,3;1785;1050,6;1030,2;62,3;;;;;;
39,57;1260;1030,2;999,6;73,4;;;;;;
39,84;882;1020;1020;79,3;;;;;;
40,1;861;1020;1020;79,3;;;;;;
40,37;819;1009,8;1020;79,7;;;;;;
40,63;1029;1040,4;999,6;79,3;;;;;;
40,9;1008;1173;1009,8;80,1;;;;;;
41,17;1029;1203,6;1009,8;75,4;;;;;;
41,43;1050;1193,4;1020;75,4;;;;;;
41,7;1113;1213,8;1030,2;74,6;;;;;;
41,96;1155;1224;1050,6;74,2;;;;;;
42,23;1197;1213,8;1060,8;73,4;;;;;;
42,49;1218;1213,8;1071;76,1;;;;;;
42,76;1260;1203,6;1081,2;76,1;;;;;;
43,02;1281;1173;1081,2;76,1;;;;;;
43,28;1323;1132,2;1081,2;74,2;;;;;;
43,56;1323;1122;1071;75;;;;;;
43,82;1365;1122;1071;74,6;;;;;;
44,08;1365;1122;1060,8;75;;;;;;
44,35;1365;1111,8;1060,8;74,6;;;;;;
44,62;1386;1060,8;1050,6;71;;;;;;
44,89;1323;1030,2;1050,6;70,6;;;;;;
45,15;1344;1030,2;1030,2;71;;;;;;
45,42;1281;1030,2;1020;72,2;;;;;;
45,68;1239;1020;1009,8;74,6;;;;;;
45,94;1176;1020;999,6;76,1;;;;;;
46,2;1113;1020;999,6;76,9;;;;;;
46,47;1029;1020;989,4;78,5;;;;;;
46,73;966;1009,8;989,4;76,5;;;;;;
47,01;903;1009,8;989,4;77,3;;;;;;
47,28;861;1009,8;989,4;78,1;;;;;;
47,54;819;1009,8;979,2;78,5;;;;;;
47,81;798;1009,8;979,2;78,9;;;;;;
48,08;777;1020;979,2;78,9;;;;;;
48,34;756;1050,6;979,2;79,3;;;;;;
48,6;756;1081,2;989,4;79,3;;;;;;
48,87;777;1101,6;989,4;79,3;;;;;;
49,13;756;1142,4;989,4;79,3;;;;;;
49,4;777;1162,8;999,6;79,3;;;;;;
49,67;840;1275;999,6;78,5;;;;;;
49,93;861;1305,6;999,6;78,1;;;;;;
50,2;882;1315,8;1009,8;77,7;;;;;;
50,46;945;1366,8;1020;76,9;;;;;;
50,73;987;1387,2;1030,2;76,1;;;;;;
51;1050;1417,8;1050,6;75,4;;;;;;
51,26;1092;1438,2;1060,8;74,6;;;;;;
51,52;1155;1387,2;1081,2;73,8;;;;;;
51,79;1176;1377;1091,4;73,4;;;;;;
52,06;1239;1346,4;1111,8;73;;;;;;
52,32;1281;1377;1132,2;73,4;;;;;;
52,58;1344;1356,6;1152,6;72,2;;;;;;
52,85;1386;1346,4;1162,8;70,2;;;;;;
53,12;1428;1346,4;1193,4;70,2;;;;;;
53,39;1470;1326;1203,6;69,4;;;;;;
53,65;1491;1315,8;1213,8;68,6;;;;;;
53,92;1512;1264,8;1224;67,5;;;;;;
54,18;1533;1193,4;1234,2;61,5;;;;;;
54,45;1554;1152,6;1203,6;61,5;;;;;;
54,71;1533;1101,6;1152,6;61,9;;;;;;
54,98;1533;1071;1111,8;62,3;;;;;;
55,24;1470;1040,4;1091,4;65,1;;;;;;
55,5;1470;1040,4;1060,8;67,1;;;;;;
55,78;1428;1040,4;1040,4;69;;;;;;
56,04;1365;1030,2;1030,2;69,8;;;;;;
56,3;1302;1030,2;1020;70,2;;;;;;
56,57;1260;1020;1009,8;72,2;;;;;;
56,83;1176;1020;999,6;74,6;;;;;;
57,1;1092;1020;999,6;74,6;;;;;;
57,36;1029;1020;989,4;75,8;;;;;;
57,63;966;1009,8;989,4;76,5;;;;;;
57,89;903;1009,8;989,4;77,3;;;;;;
58,16;861;1009,8;989,4;77,7;;;;;;
58,42;840;1009,8;979,2;78,1;;;;;;
58,69;798;1020;979,2;78,9;;;;;;
58,95;798;1020;979,2;78,9;;;;;;
59,22;777;1020;979,2;78,9;;;;;;
59,48;777;1050,6;989,4;79,3;;;;;;
59,75;777;1111,8;989,4;78,9;;;;;;
60,02;798;1152,6;989,4;78,9;;;;;;
60,28;798;1162,8;989,4;78,5;;;;;;
60,55;840;1162,8;999,6;78,1;;;;;;
60,82;882;1213,8;999,6;77,7;;;;;;
61,09;882;1213,8;1009,8;77,7;;;;;;
61,35;924;1193,4;1020;77,3;;;;;;
61,62;924;1183,2;1020;76,9;;;;;;
61,88;966;1142,4;1030,2;76,5;;;;;;
62,15;945;1162,8;1030,2;76,5;;;;;;
62,42;987;1173;1040,4;76,1;;;;;;
62,68;1008;1162,8;1040,4;76,1;;;;;;
62,95;1008;1173;1040,4;75,8;;;;;;
63,21;1029;1162,8;1040,4;75,4;;;;;;
63,48;1050;1152,6;1040,4;75,4;;;;;;
63,75;1071;1173;1040,4;75;;;;;;
64,01;1092;1152,6;1040,4;74,6;;;;;;
64,27;1134;1122;1040,4;74,2;;;;;;
64,54;1155;1111,8;1040,4;74,2;;;;;;
64,8;1176;1081,2;1040,4;73,4;;;;;;
65,06;1197;1081,2;1040,4;73,4;;;;;;
65,33;1197;1081,2;1030,2;73,4;;;;;;
65,59;1218;1081,2;1030,2;73;;;;;;
65,86;1218;1081,2;1030,2;73;;;;;;
66,13;1218;1081,2;1030,2;72,6;;;;;;
66,4;1218;1081,2;1030,2;72,6;;;;;;
66,66;1239;1091,4;1030,2;72,2;;;;;;
66,92;1260;1101,6;1030,2;72,2;;;;;;
67,19;1260;1101,6;1030,2;72,2;;;;;;
67,45;1260;1101,6;1030,2;72,2;;;;;;
67,72;1281;1101,6;1030,2;71,8;;;;;;
67,98;1281;1101,6;1030,2;71,4;;;;;;
68,25;1302;1101,6;1030,2;71,4;;;;;;
68,52;1281;1101,6;1030,2;71,4;;;;;;
68,78;1281;1101,6;1030,2;71,4;;;;;;
69,04;1302;1091,4;1030,2;71;;;;;;
69,31;1323;1091,4;1030,2;70,6;;;;;;
69,57;1323;1091,4;1030,2;70,6;;;;;;
69,85;1323;1091,4;1030,2;70,6;;;;;;
70,11;1344;1091,4;1030,2;70,2;;;;;;
70,37;1365;1091,4;1030,2;70,2;;;;;;
70,64;1323;1040,4;1030,2;71;;;;;;
70,91;1323;1030,2;1020;71,4;;;;;;
71,18;1323;1030,2;1009,8;71;;;;;;
71,44;1281;1020;1009,8;71,8;;;;;;
71,71;1239;1020;999,6;72,2;;;;;;
71,98;1197;1020;999,6;73;;;;;;
72,24;1155;1020;989,4;73,8;;;;;;
72,51;1113;1020;989,4;74,2;;;;;;
72,77;1134;1030,2;989,4;74,2;;;;;;
73,04;1134;1081,2;979,2;74,2;;;;;;
73,3;1113;1111,8;979,2;74,6;;;;;;
73,57;1134;1071;999,6;74,2;;;;;;
73,84;1176;1060,8;999,6;73,8;;;;;;
74,11;1176;1050,6;999,6;73,4;;;;;;
74,37;1155;1060,8;999,6;73,8;;;;;;
74,64;1176;1060,8;999,6;73,8;;;;;;
74,9;1218;1050,6;999,6;73;;;;;;
75,17;1197;1060,8;999,6;73,4;;;;;;
75,43;1239;1060,8;999,6;72,6;;;;;;
75,7;1239;1060,8;999,6;72,2;;;;;;
75,97;1281;1060,8;999,6;71,8;;;;;;
76,23;1281;1060,8;999,6;71,8;;;;;;
76,49;1302;1060,8;999,6;71;;;;;;
76,76;1302;1071;999,6;71,4;;;;;;
77,03;1344;1060,8;999,6;70,6;;;;;;
77,29;1365;1060,8;999,6;70,2;;;;;;
77,56;1365;1071;1009,8;70,2;;;;;;
77,82;1428;1091,4;1009,8;69;;;;;;
78,09;1449;1111,8;1009,8;75,8;;;;;;
78,36;1491;1111,8;1009,8;75;;;;;;
78,62;1512;1111,8;1009,8;74,2;;;;;;
78,89;1554;1111,8;1020;73,4;;;;;;
79,14;1575;1111,8;1030,2;72,2;;;;;;
79,42;1617;1101,6;1040,4;71;;;;;;
79,68;1638;1101,6;1040,4;70,2;;;;;;
79,95;1659;1081,2;1040,4;67,9;;;;;;
80,21;1428;1030,2;1020;68,6;;;;;;
80,47;945;1020;1020;78,5;;;;;;
80,74;903;1020;1020;79,3;;;;;;
81,01;903;1020;1030,2;78,5;;;;;;
81,27;987;1030,2;1020;78,5;;;;;;
81,55;1050;1030,2;1009,8;78,9;;;;;;
81,8;1071;1040,4;1009,8;79,7;;;;;;
82,07;1092;1040,4;1009,8;74,6;;;;;;
82,35;1092;1040,4;1009,8;75;;;;;;
82,6;1113;1040,4;1009,8;74,6;;;;;;
82,87;1134;1040,4;1009,8;74,2;;;;;;
83,13;1155;1040,4;1009,8;74,2;;;;;;
83,4;1155;1040,4;999,6;73,8;;;;;;
83,67;1134;1020;999,6;74,2;;;;;;
83,93;1155;1020;999,6;74,2;;;;;;
84,2;1155;1020;999,6;73,8;;;;;;
84,46;1092;1020;989,4;74,6;;;;;;
84,72;1113;1020;989,4;74,6;;;;;;
84,98;1092;1020;989,4;75;;;;;;
85,25;1071;1020;989,4;75;;;;;;
85,52;1008;1009,8;979,2;75,8;;;;;;
85,78;777;1009,8;989,4;78,9;;;;;;
86,05;819;1009,8;979,2;78,5;;;;;;
86,32;840;1009,8;979,2;78,5;;;;;;
86,58;819;1009,8;989,4;78,5;;;;;;
86,84;840;1009,8;989,4;78,5;;;;;;
87,12;903;1009,8;979,2;77,3;;;;;;
87,38;903;1009,8;979,2;77,3;;;;;;
87,65;903;1009,8;979,2;77,3;;;;;;
87,91;903;1009,8;979,2;77,3;;;;;;
88,18;966;1020;979,2;76,5;;;;;;
88,45;924;1020;979,2;76,9;;;;;;
88,71;987;1081,2;979,2;76,1;;;;;;
88,98;945;1152,6;979,2;76,5;;;;;;
89,24;987;1203,6;989,4;76,1;;;;;;
89,51;1050;1244,4;999,6;75,4;;;;;;
89,77;1092;1315,8;1020;74,6;;;;;;
90,04;1155;1315,8;1040,4;73,8;;;;;;
90,31;1218;1305,6;1060,8;74,6;;;;;;
90,56;1281;1295,4;1091,4;73,4;;;;;;
90,83;1344;1285,2;1122;72,2;;;;;;
91,1;1407;1336,2;1142,4;71,4;;;;;;
91,37;1449;1366,8;1142,4;69,8;;;;;;
91,63;1512;1468,8;1162,8;67,5;;;;;;
91,89;1575;1540,2;1193,4;64,3;;;;;;
92,16;1638;1530;1224;64,3;;;;;;
92,43;1722;1509,6;1254,6;63,1;;;;;;
92,7;1785;1489,2;1264,8;63,1;;;;;;
92,96;1827;1479;1264,8;63,1;;;;;;
93,23;1911;1346,4;1264,8;46,6;;;;;;
93,49;1932;1162,8;1244,4;47,7;;;;;;
93,76;1932;1071;1193,4;49,3;;;;;;
94,03;1869;1050,6;1142,4;46,9;;;;;;
94,29;1890;1050,6;1071;47,3;;;;;;
94,56;1827;1050,6;1040,4;50,9;;;;;;
94,82;1764;1040,4;1020;53,7;;;;;;
95,09;1680;1040,4;1009,8;56,4;;;;;;
95,36;1596;1040,4;999,6;60;;;;;;
95,62;1512;1030,2;999,6;63,9;;;;;;
95,89;1449;1030,2;999,6;67,9;;;;;;
96,15;1512;1122;999,6;76,5;;;;;;
96,41;1512;1132,2;1009,8;75;;;;;;
96,68;1491;1224;1050,6;72,2;;;;;;
96,95;1533;1407,6;1071;67,9;;;;;;
97,21;1596;1448,4;1101,6;66,3;;;;;;
97,48;1659;1540,2;1152,6;64,7;;;;;;
97,74;1743;1591,2;1203,6;62,7;;;;;;
98;1806;1591,2;1244,4;61,9;;;;;;
98,28;1890;1570,8;1264,8;60,8;;;;;;
98,54;1953;1560,6;1285,2;61,2;;;;;;
98,81;2037;1540,2;1305,6;60;;;;;;
99,07;2100;1530;1315,8;59,6;;;;;;
99,34;2184;1530;1326;59,6;;;;;;
99,61;2226;1530;1326;59,2;;;;;;
99,87;2289;1509,6;1336,2;58,4;;;;;;
100,13;2352;1366,8;1346,4;42,2;;;;;;
100,4;2163;1060,8;1264,8;32;;;;;;
100,66;1596;1040,4;1142,4;50,9;;;;;;
100,93;1029;1020;1101,6;71,4;;;;;;
101,2;1134;1142,4;1071;79,7;;;;;;
101,46;1386;1254,6;1060,8;73;;;;;;
101,73;1470;1754,4;1111,8;67,9;;;;;;
101,99;1470;1856,4;1183,2;66,3;;;;;;
102,26;1512;1887;1244,4;63,9;;;;;;
102,52;1533;1876,8;1295,4;62,7;;;;;;
102,79;1575;1876,8;1336,2;61,5;;;;;;
103,04;1617;1764,6;1366,8;59,6;;;;;;
103,32;1659;1652,4;1377;61,5;;;;;;
103,59;1680;1570,8;1356,6;63,1;;;;;;
103,85;1722;1540,2;1346,4;63,5;;;;;;
104,12;1743;1519,8;1326;62,3;;;;;;
104,39;1785;1519,8;1315,8;63,1;;;;;;
104,65;1785;1499,4;1305,6;63,1;;;;;;
104,92;1827;1499,4;1305,6;63,1;;;;;;
105,18;1827;1213,8;1295,4;48,1;;;;;;
105,45;1827;1132,2;1234,2;53,7;;;;;;
105,71;1827;1101,6;1183,2;54,1;;;;;;
105,98;1827;1081,2;1142,4;57,2;;;;;;
106,24;1806;1060,8;1111,8;59,2;;;;;;
106,51;1785;1040,4;1081,2;60;;;;;;
106,78;1764;1040,4;1060,8;60;;;;;;
107,03;1722;1040,4;1040,4;60;;;;;;
107,31;1701;1040,4;1020;58,8;;;;;;
107,57;1680;1040,4;1009,8;60,4;;;;;;
107,84;1659;1040,4;999,6;61,9;;;;;;
108,1;1617;1040,4;999,6;59,2;;;;;;
108,37;1596;1040,4;989,4;60,4;;;;;;
108,63;1575;1040,4;989,4;61,5;;;;;;
108,9;1554;1040,4;989,4;62,7;;;;;;
109,16;1533;1040,4;989,4;63,5;;;;;;
109,43;1491;1030,2;979,2;64,7;;;;;;
109,7;1470;1030,2;979,2;65,1;;;;;;
109,96;1449;1030,2;979,2;65,1;;;;;;
110,22;1407;1030,2;979,2;66,7;;;;;;
110,49;1386;1030,2;979,2;67,5;;;;;;
110,76;1365;1030,2;979,2;68,3;;;;;;
111,03;1344;1040,4;979,2;71;;;;;;
111,29;1323;1050,6;979,2;71;;;;;;
111,56;1323;1071;979,2;71;;;;;;
111,82;1302;1132,2;969;79,3;;;;;;
112,09;1302;1173;989,4;77,3;;;;;;
112,36;1323;1173;1020;74,6;;;;;;
112,62;1239;1132,2;1040,4;78,9;;;;;;
112,89;1281;1132,2;1040,4;78,1;;;;;;
113,15;1281;1132,2;1050,6;78,5;;;;;;
113,42;1281;1132,2;1050,6;78,1;;;;;;
113,68;1281;1132,2;1050,6;78,5;;;;;;
113,95;1281;1132,2;1060,8;78,5;;;;;;
114,21;1260;1132,2;1060,8;78,9;;;;;;
114,48;1260;1132,2;1060,8;78,9;;;;;;
114,73;1239;1132,2;1060,8;79,7;;;;;;
115,01;1260;1244,4;1060,8;75,4;;;;;;
115,28;1239;1662,6;1060,8;73;;;;;;
115,54;1239;1703,4;1101,6;73,8;;;;;;
115,81;1344;1836;1132,2;69,8;;;;;;
116,06;1260;1723,8;1173;69,8;;;;;;
116,33;1323;1795,2;1203,6;70,6;;;;;;
116,61;1323;1815,6;1234,2;68,6;;;;;;
116,87;1365;1846,2;1254,6;68,6;;;;;;
117,14;1386;1876,8;1285,2;67,5;;;;;;
117,4;1407;1897,2;1315,8;66,3;;;;;;
117,67;1428;1927,8;1346,4;64,3;;;;;;
117,93;1449;1948,2;1366,8;63,5;;;;;;
118,19;1470;1989;1387,2;62,7;;;;;;
118,46;1512;2019,6;1407,6;62,3;;;;;;
118,73;1533;2050,2;1438,2;61,5;;;;;;
118,99;1575;2060,4;1448,4;61,2;;;;;;
119,26;1596;2091;1458,6;60,4;;;;;;
119,53;1638;2111,4;1479;60;;;;;;
119,79;1680;2142;1509,6;59,2;;;;;;
120,06;1722;2162,4;1540,2;58,8;;;;;;
120,32;1743;2193;1570,8;58;;;;;;
120,59;1785;2203,2;1611,6;57,6;;;;;;
120,85;1827;2050,2;1642,2;49,7;;;;;;
121,12;1848;1662,6;1611,6;54,1;;;;;;
121,38;1848;1111,8;1448,4;32,7;;;;;;
121,65;1827;1071;1224;52,9;;;;;;
121,92;1785;1060,8;1142,4;56,8;;;;;;
122,18;1764;1060,8;1101,6;59,6;;;;;;
122,45;1743;1050,6;1081,2;61,5;;;;;;
122,72;1701;1050,6;1060,8;63,5;;;;;;
122,98;1659;1050,6;1040,4;65,1;;;;;;
123,24;1638;1071;1030,2;68,6;;;;;;
123,51;1617;1122;1030,2;70,2;;;;;;
123,78;1575;1152,6;1030,2;74,2;;;;;;
124,04;1554;1152,6;1020;74,6;;;;;;
124,31;1554;1122;1040,4;72,2;;;;;;
124,57;1533;1122;1060,8;71,4;;;;;;
124,84;1512;1101,6;1060,8;70,6;;;;;;
125,1;1470;1060,8;1060,8;69,4;;;;;;
125,37;1491;1060,8;1050,6;69,8;;;;;;
125,63;1428;1050,6;1040,4;71,8;;;;;;
125,89;1428;1040,4;1030,2;72,2;;;;;;
126,17;1428;1040,4;1030,2;72,6;;;;;;
126,43;1407;1030,2;1020;73,4;;;;;;
126,69;1407;1030,2;1009,8;73,8;;;;;;
126,96;1428;1030,2;1009,8;69,8;;;;;;
127,23;1386;1030,2;999,6;70,2;;;;;;
127,5;1386;1030,2;999,6;69,8;;;;;;
127,76;1386;1030,2;999,6;68,6;;;;;;
128,03;1407;1030,2;989,4;67,5;;;;;;
128,28;1365;1030,2;989,4;68,3;;;;;;
128,55;1365;1030,2;989,4;68,3;;;;;;
128,82;1344;1030,2;989,4;68,6;;;;;;
129,09;1344;1030,2;989,4;68,6;;;;;;
129,35;1344;1030,2;989,4;69;;;;;;
129,62;1323;1030,2;979,2;69,4;;;;;;
129,88;1323;1030,2;979,2;69,4;;;;;;
130,15;1302;1030,2;979,2;70,2;;;;;;
130,42;1281;1030,2;979,2;70,6;;;;;;
130,68;1281;1020;979,2;71;;;;;;
130,95;1239;1020;979,2;72,2;;;;;;
131,2;1218;1020;979,2;73;;;;;;
131,48;1197;1020;979,2;73,4;;;;;;
131,74;1155;1020;979,2;73,8;;;;;;
132,01;1134;1020;979,2;74,2;;;;;;
132,28;1113;1020;979,2;74,6;;;;;;
132,54;1092;1020;979,2;74,6;;;;;;
132,81;1050;1020;979,2;75,4;;;;;;
133,07;1092;1071;979,2;74,6;;;;;;
133,34;1071;1122;979,2;75,4;;;;;;
133,6;1092;1213,8;989,4;75;;;;;;
133,87;1092;1458,6;999,6;74,6;;;;;;
134,14;1113;1499,4;1020;74,2;;;;;;
134,4;1134;1530;1040,4;74,2;;;;;;
134,67;1155;1550,4;1060,8;73,8;;;;;;
134,93;1176;1591,2;1071;73,4;;;;;;
135,2;1197;1632;1091,4;73,4;;;;;;
135,46;1218;1672,8;1111,8;74,2;;;;;;
135,73;1239;1693,2;1122;72,2;;;;;;
135,99;1281;1693,2;1142,4;72,6;;;;;;
136,26;1302;1693,2;1162,8;71;;;;;;
136,53;1323;1581;1183,2;69,4;;;;;;
136,79;1344;1519,8;1203,6;68,6;;;;;;
137,06;1386;1387,2;1213,8;65,9;;;;;;
137,33;1386;1213,8;1224;67,9;;;;;;
137,59;1407;1193,4;1213,8;67,1;;;;;;
137,85;1407;1183,2;1193,4;67,9;;;;;;
138,12;1407;1183,2;1183,2;68,6;;;;;;
138,37;1407;1193,4;1183,2;69,8;;;;;;
138,65;1407;1254,6;1162,8;71,8;;;;;;
138,92;1407;1244,4;1142,4;72,2;;;;;;
139,17;1407;1183,2;1132,2;71;;;;;;
139,44;1407;1091,4;1122;66,7;;;;;;
139,71;1386;1060,8;1101,6;66,3;;;;;;
139,98;1365;1040,4;1081,2;67,5;;;;;;
140,24;1344;1030,2;1060,8;67,5;;;;;;
140,51;1323;1030,2;1040,4;68,3;;;;;;
140,78;1302;1030,2;1030,2;70,2;;;;;;
141,04;1260;1020;1020;71,8;;;;;;
141,3;1218;1020;1009,8;73,4;;;;;;
141,57;1176;1030,2;999,6;73,4;;;;;;
141,84;1113;1030,2;999,6;74,2;;;;;;
142,1;1134;1040,4;999,6;74,2;;;;;;
142,37;1113;1071;989,4;74,6;;;;;;
142,63;1092;1081,2;989,4;75;;;;;;
142,9;1092;1091,4;999,6;75;;;;;;
143,17;1113;1193,4;999,6;74,6;;;;;;
143,43;1071;1244,4;999,6;75;;;;;;
143,7;1092;1458,6;1020;74,6;;;;;;
143,96;1092;1479;1040,4;74,6;;;;;;
144,23;1113;1499,4;1060,8;74,2;;;;;;
144,49;1113;1499,4;1071;74,6;;;;;;
144,76;1155;1540,2;1081,2;73,8;;;;;;
145,03;1155;1560,6;1101,6;73,8;;;;;;
145,28;1176;1601,4;1111,8;73,4;;;;;;
145,55;1176;1591,2;1122;73,4;;;;;;
145,82;1197;1550,4;1132,2;69;;;;;;
146,09;1218;1519,8;1142,4;74,2;;;;;;
146,34;1239;1407,6;1152,6;68,3;;;;;;
146,6;1218;1234,2;1162,8;74,2;;;;;;
146,86;1239;1173;1162,8;73;;;;;;
147,13;1239;1162,8;1142,4;74,2;;;;;;
147,4;1239;1162,8;1142,4;74,6;;;;;;
147,66;1218;1162,8;1132,2;75,4;;;;;;
147,93;1218;1122;1122;71,8;;;;;;
148,2;1218;1101,6;1132,2;71;;;;;;
148,45;1218;1101,6;1111,8;72,6;;;;;;
148,73;1197;1081,2;1091,4;72,6;;;;;;
148,99;1176;1081,2;1081,2;74,2;;;;;;
149,26;1176;1132,2;1060,8;80,1;;;;;;
149,53;1176;1203,6;1050,6;77,3;;;;;;
149,79;1176;1203,6;1050,6;76,5;;;;;;
150,06;1155;1203,6;1081,2;76,9;;;;;;
150,32;1155;1193,4;1091,4;77,7;;;;;;
150,59;1155;1244,4;1091,4;76,9;;;;;;
150,85;1176;1315,8;1091,4;75,4;;;;;;
151,12;1155;1366,8;1122;76,1;;;;;;
151,39;1218;1499,4;1142,4;73,8;;;;;;
151,65;1239;1499,4;1162,8;73;;;;;;
151,92;1239;1683;1193,4;73,8;;;;;;
152,18;1281;1744,2;1203,6;71,8;;;;;;
152,45;1281;1754,4;1234,2;71,4;;;;;;
152,71;1323;1785;1254,6;69,8;;;;;;
152,97;1323;1795,2;1275;68,6;;;;;;
153,24;1344;1764,6;1305,6;65,5;;;;;;
153,51;1386;1693,2;1336,2;66,7;;;;;;
153,77;1407;1581;1356,6;65,1;;;;;;
154,04;1428;1244,4;1366,8;48,1;;;;;;
154,31;1428;1183,2;1315,8;59,6;;;;;;
154,57;1470;1183,2;1244,4;63,5;;;;;;
154,84;1470;1193,4;1193,4;67,1;;;;;;
155,1;1470;1264,8;1162,8;71;;;;;;
155,37;1470;1285,2;1152,6;70,6;;;;;;
155,63;1491;1285,2;1142,4;70,2;;;;;;
155,91;1470;1275;1132,2;70,6;;;;;;
156,16;1470;1275;1132,2;69,8;;;;;;
156,43;1449;1254,6;1122;70,2;;;;;;
156,7;1449;1203,6;1122;71,8;;;;;;
156,96;1449;1203,6;1122;73;;;;;;
157,23;1428;1203,6;1111,8;74,2;;;;;;
157,5;1407;1193,4;1101,6;75;;;;;;
157,76;1428;1193,4;1091,4;74,6;;;;;;
158,03;1428;1193,4;1091,4;75;;;;;;
158,29;1428;1162,8;1091,4;73;;;;;;
158,54;1428;1142,4;1081,2;73,8;;;;;;
158,82;1407;1132,2;1081,2;73,4;;;;;;
159,09;1407;1111,8;1081,2;72,6;;;;;;
159,36;1386;1081,2;1071;71,4;;;;;;
159,62;1386;1071;1071;71;;;;;;
159,89;1386;1050,6;1060,8;71,4;;;;;;
160,15;1344;1050,6;1050,6;72,2;;;;;;
160,42;1323;1040,4;1040,4;72,6;;;;;;
160,68;1323;1030,2;1030,2;71;;;;;;
160,95;1281;1030,2;1020;72,6;;;;;;
161,21;1281;1030,2;1009,8;73,4;;;;;;
161,48;1218;1020;1009,8;72,2;;;;;;
161,74;1176;1020;999,6;73,4;;;;;;
162,01;1134;1020;999,6;74,2;;;;;;
162,28;1176;1071;989,4;73,8;;;;;;
162,54;1134;1173;979,2;74,2;;;;;;
162,81;1071;1183,2;999,6;75;;;;;;
163,06;1071;1213,8;1009,8;75,4;;;;;;
163,33;1092;1315,8;1020;75;;;;;;
163,61;1071;1428;1040,4;75;;;;;;
163,87;1092;1438,2;1060,8;74,6;;;;;;
164,14;1092;1438,2;1071;74,6;;;;;;
164,4;1113;1448,4;1091,4;74,6;;;;;;
164,67;1113;1315,8;1101,6;74,6;;;;;;
164,94;1155;1468,8;1111,8;74,2;;;;;;
165,2;1197;1499,4;1122;74,6;;;;;;
165,46;1155;1479;1132,2;75,4;;;;;;
165,73;1197;1499,4;1142,4;74,6;;;;;;
166;1218;1499,4;1162,8;73,8;;;;;;
166,26;1239;1336,2;1173;65,1;;;;;;
166,53;1239;1244,4;1173;75;;;;;;
166,79;1239;1213,8;1173;74,6;;;;;;
167,04;1260;1193,4;1162,8;74,2;;;;;;
167,32;1260;1173;1152,6;73;;;;;;
167,59;1260;1142,4;1152,6;70,6;;;;;;
167,85;1239;1132,2;1142,4;71;;;;;;
168,12;1260;1101,6;1142,4;69;;;;;;
168,39;1239;1091,4;1132,2;69,8;;;;;;
168,65;1218;1081,2;1111,8;70,2;;;;;;
168,92;1218;1050,6;1091,4;69,4;;;;;;
169,18;1176;1020;1071;69,4;;;;;;
169,45;1197;1020;1050,6;70,6;;;;;;
169,71;1113;1020;1040,4;72,6;;;;;;
169,98;1092;1020;1030,2;73,8;;;;;;
170,25;1071;1020;1020;74,6;;;;;;
170,51;777;1009,8;1009,8;79,3;;;;;;
170,78;798;1009,8;1009,8;78,5;;;;;;
171,04;819;1009,8;999,6;78,5;;;;;;
171,31;840;1009,8;989,4;78,5;;;;;;
171,57;840;1009,8;989,4;78,5;;;;;;
171,84;819;1009,8;989,4;78,5;;;;;;
172,11;819;1009,8;989,4;78,5;;;;;;
172,37;819;1009,8;989,4;78,5;;;;;;
172,64;819;1009,8;989,4;78,5;;;;;;
172,9;819;1009,8;989,4;78,5;;;;;;
173,17;819;1020;989,4;78,5;;;;;;
173,43;819;1020;989,4;78,5;;;;;;
173,7;840;1009,8;989,4;78,1;;;;;;
173,96;840;1009,8;989,4;78,5;;;;;;
174,23;819;1009,8;989,4;78,5;;;;;;
174,49;819;1009,8;989,4;78,5;;;;;;
174,76;798;1009,8;989,4;78,9;;;;;;
175,02;777;1009,8;989,4;79,3;;;;;;
175,29;756;1020;989,4;79,3;;;;;;
175,56;735;1234,2;989,4;79,7;;;;;;
175,82;840;1295,4;989,4;78,5;;;;;;
176,09;1029;1203,6;999,6;75,8;;;;;;
176,35;966;1173;1009,8;76,5;;;;;;
176,62;945;1142,4;1030,2;76,5;;;;;;
176,88;966;1132,2;1040,4;76,5;;;;;;
177,15;966;1142,4;1050,6;76,5;;;;;;
177,42;987;1173;1060,8;76,5;;;;;;
177,68;987;1173;1060,8;76,1;;;;;;
177,95;1008;1234,2;1071;76,1;;;;;;
178,21;1092;1346,4;1081,2;74,6;;;;;;
178,48;1260;1509,6;1101,6;73,4;;;;;;
178,74;1470;1428;1142,4;66,7;;;;;;
179,01;1596;1356,6;1203,6;64,7;;;;;;
179,27;1722;1264,8;1254,6;57,2;;;;;;
179,54;1806;1224;1295,4;53,7;;;;;;
179,81;1932;1224;1315,8;48,9;;;;;;
180,07;1953;1213,8;1264,8;50,5;;;;;;
180,34;2058;1193,4;1224;50,9;;;;;;
180,6;1743;1040,4;1162,8;42,6;;;;;;
180,87;1197;1020;1111,8;63,5;;;;;;
181,14;903;1009,8;1081,2;70,2;;;;;;
181,4;1197;1081,2;1060,8;72,2;;;;;;
181,67;1134;1213,8;1071;77,3;;;;;;
181,93;1176;1305,6;1071;76,5;;;;;;
182,2;1239;1366,8;1091,4;74,6;;;;;;
182,46;1302;1397,4;1122;73;;;;;;
182,73;1386;1550,4;1152,6;69,4;;;;;;
182,99;1470;1540,2;1203,6;66,7;;;;;;
183,26;1512;1530;1254,6;66,3;;;;;;
183,52;1617;1509,6;1305,6;64,7;;;;;;
183,79;1680;1479;1326;64,7;;;;;;
184,06;1743;1509,6;1336,2;63,5;;;;;;
184,32;1806;1560,6;1336,2;61,2;;;;;;
184,59;1869;1560,6;1346,4;61,5;;;;;;
184,86;1953;1540,2;1366,8;58,4;;;;;;
185,11;2016;1366,8;1366,8;50,1;;;;;;
185,39;2058;1315,8;1336,2;52,1;;;;;;
185,65;2100;1315,8;1285,2;54,1;;;;;;
185,92;2142;1315,8;1254,6;55,6;;;;;;
186,17;2184;1305,6;1224;55,6;;;;;;
186,44;2205;1193,4;1203,6;50,9;;;;;;
186,71;1995;1050,6;1162,8;39,5;;;;;;
186,98;1512;1040,4;1111,8;54,1;;;;;;
187,24;924;1009,8;1091,4;71;;;;;;
187,51;945;1091,4;1071;78,9;;;;;;
187,78;1407;1132,2;1050,6;76,5;;;;;;
188,04;1281;1295,4;1071;73,8;;;;;;
188,3;1281;1591,2;1111,8;72,6;;;;;;
188,57;1323;1774,8;1142,4;71,4;;;;;;
188,84;1344;1795,2;1183,2;70,2;;;;;;
189,1;1365;1805,4;1224;69;;;;;;
189,37;1386;1754,4;1254,6;67,1;;;;;;
189,64;1428;1693,2;1295,4;65,5;;;;;;
189,9;1428;1611,6;1336,2;63,9;;;;;;
190,17;1470;1377;1356,6;62,7;;;;;;
190,43;1470;1244,4;1336,2;60,8;;;;;;
190,7;1470;1244,4;1285,2;62,7;;;;;;
190,96;1428;1203,6;1244,4;65,9;;;;;;
191,23;1470;1244,4;1213,8;71,4;;;;;;
191,49;1470;1285,2;1183,2;70,6;;;;;;
191,76;1491;1285,2;1173;70,6;;;;;;
192,02;1470;1234,2;1152,6;65,5;;;;;;
192,29;1491;1183,2;1142,4;68,3;;;;;;
192,56;1470;1152,6;1132,2;68,3;;;;;;
192,82;1470;1152,6;1111,8;69,8;;;;;;
193,08;1470;1152,6;1101,6;71,4;;;;;;
193,35;1470;1152,6;1091,4;71,8;;;;;;
193,61;1449;1152,6;1081,2;73,4;;;;;;
193,88;1449;1213,8;1071;74,2;;;;;;
194,15;1470;1346,4;1040,4;69,4;;;;;;
194,42;1470;1356,6;1081,2;69;;;;;;
194,68;1449;1244,4;1122;65,9;;;;;;
194,94;1449;1162,8;1162,8;67,9;;;;;;
195,21;1449;1142,4;1142,4;68,6;;;;;;
195,48;1428;1122;1132,2;69;;;;;;
195,74;1428;1111,8;1111,8;69,8;;;;;;
196,01;1407;1111,8;1091,4;71;;;;;;
196,27;1407;1122;1081,2;72,6;;;;;;
196,55;1407;1234,2;1071;75,4;;;;;;
196,8;1407;1417,8;1050,6;70,2;;;;;;
197,07;1407;1387,2;1101,6;69,4;;;;;;
197,34;1428;1377;1142,4;68,6;;;;;;
197,6;1428;1377;1173;69,4;;;;;;
197,86;1407;1213,8;1203,6;66,3;;;;;;
198,13;1428;1152,6;1213,8;65,1;;;;;;
198,4;1428;1152,6;1183,2;68,3;;;;;;
198,67;1428;1152,6;1152,6;70,2;;;;;;
198,93;1407;1162,8;1132,2;71,8;;;;;;
199,19;1407;1152,6;1111,8;73;;;;;;
199,46;1407;1173;1091,4;76,1;;;;;;
199,73;1407;1193,4;1081,2;75,4;;;;;;
199,99;1386;1193,4;1071;75,4;;;;;;
200,26;1323;1132,2;1091,4;74,2;;;;;;
200,53;1344;1122;1091,4;73,8;;;;;;
200,79;1323;1091,4;1091,4;69,8;;;;;;
201,06;1302;1030,2;1081,2;69,4;;;;;;
201,32;1302;1030,2;1060,8;70,6;;;;;;
201,59;1281;1040,4;1050,6;73,4;;;;;;
201,85;1281;1060,8;1040,4;75;;;;;;
202,12;1260;1091,4;1020;80,1;;;;;;
202,38;1260;1122;1020;80,5;;;;;;
202,65;1239;1173;1040,4;78,5;;;;;;
202,92;1239;1213,8;1060,8;75,8;;;;;;
203,18;1239;1509,6;1071;74,2;;;;;;
203,45;1260;1652,4;1101,6;73,4;;;;;;
203,71;1260;1662,6;1142,4;72,6;;;;;;
203,98;1281;1662,6;1173;71;;;;;;
204,24;1302;1683;1213,8;71;;;;;;
204,5;1323;1693,2;1244,4;70,2;;;;;;
204,78;1323;1693,2;1275;69;;;;;;
205,04;1344;1703,4;1305,6;67,5;;;;;;
205,31;1365;1713,6;1336,2;66,7;;;;;;
205,57;1407;1723,8;1377;66,3;;;;;;
205,84;1428;1723,8;1407,6;65,9;;;;;;
206,1;1470;1734;1428;65,1;;;;;;
206,37;1491;1734;1458,6;64,3;;;;;;
206,63;1512;1734;1479;63,5;;;;;;
206,89;1533;1713,6;1499,4;63,9;;;;;;
207,16;1575;1642,2;1509,6;63,9;;;;;;
207,42;1596;1642,2;1499,4;64,7;;;;;;
207,7;1596;1632;1499,4;64,3;;;;;;
207,96;1617;1652,4;1489,2;63,9;;;;;;
208,23;1659;1662,6;1458,6;62,3;;;;;;
208,49;1680;1621,8;1438,2;60;;;;;;
208,76;1680;1560,6;1417,8;63,9;;;;;;
209,03;1701;1581;1387,2;63,5;;;;;;
209,29;1701;1581;1366,8;63,1;;;;;;
209,56;1722;1693,2;1356,6;62,3;;;;;;
209,82;1764;1744,2;1346,4;61,2;;;;;;
210,09;1722;1744,2;1366,8;61,2;;;;;;
210,35;1764;1754,4;1387,2;60,8;;;;;;
210,62;1785;1785;1417,8;60;;;;;;
210,89;1806;1785;1428;59,6;;;;;;
211,15;1827;1774,8;1438,2;60;;;;;;
211,41;1869;1774,8;1438,2;59,6;;;;;;
211,67;1869;1764,6;1438,2;59,6;;;;;;
211,95;1911;1774,8;1438,2;59,2;;;;;;
212,21;1932;1774,8;1428;58,8;;;;;;
212,48;1953;1774,8;1428;59,2;;;;;;
212,74;1974;1774,8;1428;58,8;;;;;;
213,01;1995;1795,2;1438,2;58,4;;;;;;
213,28;2016;1795,2;1438,2;58,4;;;;;;
213,54;2037;1795,2;1448,4;58;;;;;;
213,81;2058;1785;1448,4;58;;;;;;
214,07;2058;1744,2;1448,4;58,4;;;;;;
214,34;2079;1744,2;1448,4;58,4;;;;;;
214,6;2100;1744,2;1458,6;58;;;;;;
214,87;2121;1734;1458,6;58;;;;;;
215,14;2163;1734;1458,6;57,6;;;;;;
215,4;2184;1683;1468,8;55,2;;;;;;
215,67;2184;1275;1438,2;40,6;;;;;;
215,93;2184;1203,6;1336,2;45,4;;;;;;
216,2;2184;1152,6;1244,4;48,5;;;;;;
216,46;2163;1132,2;1183,2;50,9;;;;;;
216,73;2142;1142,4;1152,6;54,4;;;;;;
216,99;2163;1407,6;1152,6;61,5;;;;;;
217,25;2184;1683;1122;58;;;;;;
217,52;2184;1744,2;1203,6;56,4;;;;;;
217,79;2184;1754,4;1295,4;56;;;;;;
218,06;2205;1754,4;1377;56,4;;;;;;
218,32;2226;1744,2;1438,2;56,4;;;;;;
218,59;2247;1734;1479;55,6;;;;;;
218,85;2289;1734;1499,4;56;;;;;;
219,12;2205;1142,4;1509,6;14,2;;;;;;
219,38;2163;1060,8;1315,8;22,9;;;;;;
219,65;1638;1040,4;1162,8;45;;;;;;
219,92;1113;1030,2;1101,6;68,3;;;;;;
220,18;1407;1091,4;1081,2;65,1;;;;;;
220,45;1449;1183,2;1101,6;71,8;;;;;;
220,71;1449;1264,8;1132,2;71;;;;;;
220,98;1428;1887;1162,8;67,9;;;;;;
221,24;1449;1938;1213,8;66,7;;;;;;
221,5;1449;1938;1254,6;65,9;;;;;;
221,77;1449;1938;1295,4;66,7;;;;;;
222,04;1449;1948,2;1326;64,7;;;;;;
222,31;1449;1958,4;1356,6;63,9;;;;;;
222,58;1449;1968,6;1377;64,7;;;;;;
222,83;1449;1938;1407,6;64,7;;;;;;
223,09;1470;1978,8;1407,6;63,9;;;;;;
223,36;1470;1968,6;1428;63,1;;;;;;
223,63;1470;1978,8;1438,2;63,5;;;;;;
223,9;1470;1978,8;1448,4;62,7;;;;;;
224,16;1491;1999,2;1448,4;62,3;;;;;;
224,43;1491;1989;1458,6;61,9;;;;;;
224,7;1491;1989;1458,6;63,1;;;;;;
224,97;1491;1999,2;1458,6;62,3;;;;;;
225,23;1491;2009,4;1458,6;63,1;;;;;;
225,5;1470;1989;1448,4;63,1;;;;;;
225,76;1512;2019,6;1448,4;63,1;;;;;;
226,03;1512;2019,6;1438,2;61,9;;;;;;
226,29;1512;2019,6;1438,2;62,7;;;;;;
226,56;1512;2029,8;1438,2;63,1;;;;;;
226,82;1512;2019,6;1428;61,5;;;;;;
227,09;1512;2019,6;1428;62,7;;;;;;
227,35;1512;2029,8;1417,8;63,9;;;;;;
227,62;1512;2019,6;1407,6;63,5;;;;;;
227,89;1512;2019,6;1397,4;63,9;;;;;;
228,15;1512;2019,6;1387,2;63,1;;;;;;
228,42;1512;2019,6;1387,2;63,1;;;;;;
228,68;1512;2019,6;1387,2;64,3;;;;;;
228,95;1512;2019,6;1387,2;63,9;;;;;;
229,21;1512;2019,6;1377;63,5;;;;;;
229,48;1512;2019,6;1377;64,3;;;;;;
229,74;1512;2019,6;1366,8;64,7;;;;;;
230,01;1512;2019,6;1366,8;64,3;;;;;;
230,28;1512;2019,6;1356,6;63,9;;;;;;
230,54;1512;2019,6;1356,6;64,3;;;;;;
230,81;1512;2019,6;1356,6;64,3;;;;;;
231,07;1491;1999,2;1356,6;64,7;;;;;;
231,34;1491;1030,2;1356,6;24,5;;;;;;
231,61;1071;1020;1254,6;52,1;;;;;;
231,87;819;1091,4;1162,8;80,5;;;;;;
232,14;1554;1254,6;1111,8;55,6;;;;;;
232,4;2226;1081,2;1122;48,1;;;;;;
232,67;2079;1264,8;1183,2;63,5;;;;;;
232,93;2142;1907,4;1162,8;58;;;;;;
233,2;2100;2040;1264,8;54,1;;;;;;
233,46;2121;2060,4;1397,4;52,1;;;;;;
233,73;2142;2060,4;1519,8;52,1;;;;;;
234;2163;2050,2;1601,4;52,5;;;;;;
234,26;2184;2050,2;1642,2;53,7;;;;;;
234,52;2205;2040;1652,4;53,7;;;;;;
234,79;2247;2029,8;1642,2;53,7;;;;;;
235,06;2268;1989;1621,8;53,3;;;;;;
235,33;2268;1917,6;1601,4;53,3;;;;;;
235,59;2310;1897,2;1570,8;54,8;;;;;;
235,85;2310;1856,4;1560,6;54,8;;;;;;
236,12;2331;1825,8;1550,4;55,2;;;;;;
236,39;2352;1795,2;1540,2;55,6;;;;;;
236,65;2352;1744,2;1540,2;55,6;;;;;;
236,91;2373;1744,2;1530;56;;;;;;
237,18;2373;1744,2;1519,8;56;;;;;;
237,45;2394;1744,2;1519,8;56;;;;;;
237,71;2394;1948,2;1519,8;53,7;;;;;;
237,98;2415;2009,4;1560,6;52,1;;;;;;
238,25;2436;2121,6;1611,6;50,9;;;;;;
238,51;2457;2121,6;1642,2;50,9;;;;;;
238,78;2499;2121,6;1652,4;50,9;;;;;;
239,04;2520;2111,4;1662,6;50,5;;;;;;
239,31;2541;2101,2;1662,6;50,5;;;;;;
239,57;2562;2070,6;1672,8;50,5;;;;;;
239,84;2583;2009,4;1672,8;51,3;;;;;;
240,1;2604;1999,2;1662,6;51,7;;;;;;
240,37;2625;1989;1662,6;51,3;;;;;;
240,64;2646;1907,4;1652,4;51,7;;;;;;
240,89;2667;1876,8;1642,2;51,7;;;;;;
241,17;2667;1703,4;1632;44,2;;;;;;
241,43;2667;1438,2;1570,8;31,6;;;;;;
241,7;2625;1122;1438,2;25,3;;;;;;
241,96;2625;1091,4;1244,4;43,8;;;;;;
242,23;2562;1081,2;1162,8;46,9;;;;;;
242,5;2562;1081,2;1111,8;47,3;;;;;;
242,76;2520;1081,2;1081,2;49,7;;;;;;
243,03;2478;1071;1060,8;51,7;;;;;;
243,29;2436;1071;1040,4;52,9;;;;;;
243,56;2415;1071;1030,2;54,1;;;;;;
243,82;2373;1071;1030,2;52,9;;;;;;
244,08;2331;1071;989,4;44,2;;;;;;
244,35;2268;1071;979,2;44,6;;;;;;
244,62;2226;1060,8;989,4;45;;;;;;
244,89;2184;1060,8;989,4;45,4;;;;;;
245,15;2142;1060,8;989,4;45,8;;;;;;
245,42;2100;1060,8;989,4;46,2;;;;;;
245,68;2037;1060,8;989,4;46,6;;;;;;
245,95;1995;1050,6;989,4;46,9;;;;;;
246,2;1932;1050,6;979,2;48,1;;;;;;
246,48;1869;1050,6;979,2;49,3;;;;;;
246,73;1806;1050,6;989,4;51,3;;;;;;
247;1743;1040,4;989,4;52,9;;;;;;
247,26;1701;1040,4;989,4;54,1;;;;;;
247,54;1659;1040,4;989,4;55,6;;;;;;
247,81;1638;1060,8;989,4;65,5;;;;;;
248,07;1596;1162,8;1009,8;73,8;;;;;;
248,34;1617;1489,2;1040,4;65,9;;;;;;
248,61;1596;1744,2;1091,4;64,7;;;;;;
248,87;1617;1805,4;1152,6;64,3;;;;;;
249,14;1617;1856,4;1213,8;63,5;;;;;;
249,39;1638;1927,8;1264,8;63,1;;;;;;
249,67;1659;1989;1315,8;60,8;;;;;;
249,92;1701;2040;1366,8;60;;;;;;
250,2;1743;2101,2;1428;57,6;;;;;;
250,47;1764;2142;1468,8;58;;;;;;
250,73;1806;2142;1509,6;56,8;;;;;;
250,99;1848;2142;1550,4;56,4;;;;;;
251,26;1890;2142;1591,2;55,6;;;;;;
251,52;1932;1958,4;1611,6;51,7;;;;;;
251,79;1953;1785;1601,4;56,4;;;;;;
252,06;1974;1509,6;1550,4;38,7;;;;;;
252,32;1995;1254,6;1448,4;40,6;;;;;;
252,58;1995;1203,6;1295,4;49,3;;;;;;
252,86;1995;1162,8;1203,6;51,7;;;;;;
253,12;1995;1152,6;1173;53,7;;;;;;
253,38;1995;1295,4;1142,4;63,9;;;;;;
253,65;1995;1621,8;1142,4;62,3;;;;;;
253,92;2016;1825,8;1173;58;;;;;;
254,18;2037;1948,2;1264,8;55,2;;;;;;
254,45;2058;1958,4;1366,8;54,4;;;;;;
254,72;2100;1948,2;1458,6;54,8;;;;;;
254,98;2142;1948,2;1519,8;54,8;;;;;;
255,24;2163;1938;1560,6;55,2;;;;;;
255,51;2184;1927,8;1581;54,8;;;;;;
255,78;2226;1917,6;1591,2;54,8;;;;;;
256,04;2247;1856,4;1591,2;54,4;;;;;;
256,31;2268;1713,6;1581;53,3;;;;;;
256,57;2289;1662,6;1530;54,1;;;;;;
256,84;2310;1468,8;1489,2;42,6;;;;;;
257,1;2310;1254,6;1417,8;41;;;;;;
257,36;2310;1183,2;1326;43,8;;;;;;
257,64;2289;1122;1244,4;45,8;;;;;;
257,9;2289;1111,8;1183,2;48,9;;;;;;
258,16;2268;1101,6;1152,6;50,5;;;;;;
258,43;2247;1091,4;1132,2;51,7;;;;;;
258,7;2184;1060,8;1101,6;49,3;;;;;;
258,96;2205;1060,8;1071;47,7;;;;;;
259,23;2142;1060,8;1050,6;48,1;;;;;;
259,49;2121;1060,8;1030,2;48,5;;;;;;
259,76;2079;1060,8;1020;48,5;;;;;;
260,03;2037;1050,6;979,2;51,7;;;;;;
260,29;1995;1050,6;979,2;52,1;;;;;;
260,56;1953;1050,6;989,4;47,7;;;;;;
260,82;1911;1050,6;989,4;48,1;;;;;;
261,09;1869;1050,6;989,4;49,3;;;;;;
261,35;1827;1050,6;989,4;50,5;;;;;;
261,62;1701;1040,4;989,4;53,7;;;;;;
261,89;1155;1020;1009,8;73,4;;;;;;
262,15;714;1020;1030,2;80,1;;;;;;
262,41;798;1009,8;1030,2;78,9;;;;;;
262,68;861;1009,8;1020;78,1;;;;;;
262,95;840;1009,8;1020;78,1;;;;;;
263,21;966;1009,8;1020;76,5;;;;;;
263,48;966;1009,8;1020;76,5;;;;;;
263,74;1029;1009,8;1020;75,8;;;;;;
264,01;1134;1020;1009,8;74,2;;;;;;
264,27;1260;1020;1009,8;72,2;;;;;;
264,54;1659;1040,4;999,6;63,5;;;;;;
264,8;1995;1050,6;999,6;57,6;;;;;;
265,07;1827;1060,8;1009,8;61,5;;;;;;
265,34;1848;1071;1020;59,2;;;;;;
265,6;1827;1081,2;1030,2;63,9;;;;;;
265,87;1785;1081,2;1030,2;64,7;;;;;;
266,14;1785;1101,6;1030,2;67,1;;;;;;
266,4;1743;1122;1040,4;67,9;;;;;;
266,67;1743;1132,2;1040,4;69,4;;;;;;
266,93;1743;1132,2;1040,4;69,8;;;;;;
267,2;1743;1203,6;1050,6;69,8;;;;;;
267,46;1743;1295,4;1060,8;66,7;;;;;;
267,73;1743;1407,6;1071;64,7;;;;;;
268;1764;1458,6;1122;63,5;;;;;;
268,26;1785;1479;1193,4;62,3;;;;;;
268,52;1827;1479;1234,2;63,1;;;;;;
268,79;1848;1468,8;1264,8;61,9;;;;;;
269,04;1890;1489,2;1285,2;62,3;;;;;;
269,31;1953;1560,6;1295,4;61,2;;;;;;
269,58;1995;1570,8;1326;60;;;;;;
269,85;2058;1570,8;1356,6;59,2;;;;;;
270,12;2142;1642,2;1397,4;58,8;;;;;;
270,38;2205;1621,8;1428;58,4;;;;;;
270,65;2268;1632;1468,8;57,6;;;;;;
270,92;2352;1642,2;1499,4;57,2;;;;;;
271,18;2457;1652,4;1530;56,4;;;;;;
271,45;2541;1683;1560,6;55,2;;;;;;
271,71;2625;1764,6;1662,6;54,1;;;;;;
271,98;2751;1856,4;1734;51,7;;;;;;
272,24;2835;1856,4;1815,6;48,5;;;;;;
272,51;2940;1764,6;1836;37,9;;;;;;
272,78;2919;1091,4;1703,4;5,1;;;;;;
273,04;2562;1081,2;1336,2;24,9;;;;;;
273,31;1932;1050,6;1173;42,2;;;;;;
273,57;1449;1081,2;1111,8;73,4;;;;;;
273,84;1701;1917,6;1101,6;62,3;;;;;;
274,1;1764;2182,8;1203,6;58,4;;;;;;
274,37;1764;2182,8;1315,8;56,8;;;;;;
274,64;1764;2193;1438,2;56;;;;;;
274,9;1785;2193;1550,4;55,2;;;;;;
275,17;1806;2213,4;1652,4;55,6;;;;;;
275,43;1848;2223,6;1723,8;56;;;;;;
275,7;1869;2244;1764,6;54,8;;;;;;
275,96;1911;2254,2;1805,4;56;;;;;;
276,23;1953;2274,6;1846,2;55,2;;;;;;
276,49;2016;2295;1897,2;54,8;;;;;;
276,76;2058;2295;1938;53,3;;;;;;
277,03;2100;2305,2;1978,8;54,1;;;;;;
277,29;2163;2305,2;1989;53,7;;;;;;
277,55;2226;2315,4;2009,4;52,9;;;;;;
277,82;2289;2315,4;2040;52,1;;;;;;
278,09;2352;2325,6;2060,4;52,1;;;;;;
278,35;2415;2325,6;2080,8;51,3;;;;;;
278,62;2478;2335,8;2091;50,5;;;;;;
278,89;2541;2335,8;2111,4;50,1;;;;;;
279,15;2604;2346;2131,8;49,7;;;;;;
279,42;2667;2346;2152,2;49,3;;;;;;
279,68;2709;2346;2172,6;48,9;;;;;;
279,95;2772;1948,2;2111,4;39,5;;;;;;
280,21;2688;1081,2;1764,6;8,7;;;;;;
280,48;2478;1081,2;1346,4;31,2;;;;;;
280,74;1890;1050,6;1183,2;49,7;;;;;;
281,01;1344;1030,2;1132,2;71,4;;;;;;
281,28;1911;1213,8;1101,6;54,4;;;;;;
281,54;1743;1581;1152,6;62,7;;;;;;
281,81;1743;2182,8;1254,6;58,4;;;;;;
282,08;1743;2182,8;1366,8;57,6;;;;;;
282,34;1743;2182,8;1489,2;56,8;;;;;;
282,61;1764;2193;1591,2;55,2;;;;;;
282,86;1764;2193;1703,4;55,6;;;;;;
283,12;1785;2203,2;1764,6;56,8;;;;;;
283,39;1785;2203,2;1785;56,4;;;;;;
283,66;1806;2213,4;1795,2;57,6;;;;;;
283,93;1827;2213,4;1815,6;56,4;;;;;;
284,19;1848;2223,6;1825,8;56,8;;;;;;
284,46;1869;2233,8;1846,2;56,8;;;;;;
284,72;1890;2244;1856,4;56,4;;;;;;
284,99;1911;2254,2;1866,6;56,4;;;;;;
285,26;1911;2254,2;1887;56;;;;;;
285,53;1932;2264,4;1897,2;56;;;;;;
285,79;1953;2274,6;1897,2;56;;;;;;
286,06;1974;2274,6;1907,4;55,2;;;;;;
286,32;1974;2284,8;1917,6;54,1;;;;;;
286,59;2016;2295;1927,8;55,2;;;;;;
286,85;2016;2295;1927,8;55,2;;;;;;
287,12;2037;2295;1917,6;54,8;;;;;;
287,38;2058;2295;1907,4;54,8;;;;;;
287,65;2079;2295;1917,6;54,4;;;;;;
287,92;2100;2305,2;1927,8;53,7;;;;;;
288,18;2121;2305,2;1948,2;53,7;;;;;;
288,45;2142;2305,2;1968,6;53,3;;;;;;
288,71;2163;2305,2;1989;53,3;;;;;;
288,98;2205;2305,2;1978,8;53,3;;;;;;
289,24;2226;2315,4;1948,2;53,3;;;;;;
289,5;2247;2203,2;1897,2;52,5;;;;;;
289,78;2247;2142;1836;52,9;;;;;;
290,04;2289;2142;1774,8;52,5;;;;;;
290,3;2289;2070,6;1744,2;52,9;;;;;;
290,57;2310;1968,6;1693,2;54,1;;;;;;
290,84;2331;1958,4;1662,6;54,1;;;;;;
291,11;2331;1958,4;1642,2;54,1;;;;;;
291,37;2352;1948,2;1632;54,1;;;;;;
291,64;2331;1938;1632;53,7;;;;;;
291,9;2373;1897,2;1621,8;54,1;;;;;;
292,17;2373;1876,8;1621,8;53,7;;;;;;
292,43;2394;1866,6;1621,8;54,4;;;;;;
292,7;2394;1846,2;1621,8;54,4;;;;;;
292,96;2394;1846,2;1621,8;54,4;;;;;;
293,23;2415;1825,8;1621,8;53,3;;;;;;
293,5;2415;1805,4;1621,8;55,2;;;;;;
293,76;2394;1244,4;1611,6;25,6;;;;;;
294,02;2394;1091,4;1417,8;37,5;;;;;;
294,29;2373;1071;1224;46,9;;;;;;
294,56;2373;1071;1152,6;50,9;;;;;;
294,82;2352;1071;1111,8;53,7;;;;;;
295,09;2331;1071;1091,4;55,2;;;;;;
295,36;2310;1071;1060,8;55,2;;;;;;
295,62;2289;1071;1050,6;55,6;;;;;;
295,88;2268;1071;1040,4;57,6;;;;;;
296,15;2247;1071;1040,4;52,9;;;;;;
296,42;2247;1071;1030,2;56;;;;;;
296,68;2226;1071;1030,2;56,4;;;;;;
296,94;2226;1081,2;1030,2;56;;;;;;
297,21;2205;1091,4;1030,2;55,6;;;;;;
297,48;2184;1091,4;1030,2;55,6;;;;;;
297,74;2184;1091,4;1040,4;55,6;;;;;;
298,01;2163;1091,4;1040,4;55,6;;;;;;
298,28;2163;1091,4;1040,4;55,6;;;;;;
298,54;2142;1091,4;1040,4;56;;;;;;
298,79;2142;1091,4;1040,4;56;;;;;;
299,07;2121;1091,4;1040,4;56;;;;;;
299,34;2100;1081,2;1050,6;56,4;;;;;;
299,59;2100;1081,2;1040,4;56,4;;;;;;
299,86;2079;1081,2;1040,4;56,8;;;;;;
300,13;2079;1081,2;1040,4;56,8;;;;;;
300,39;2058;1071;1040,4;57,2;;;;;;
300,67;2037;1060,8;1040,4;58;;;;;;
300,94;2058;1071;1040,4;57,2;;;;;;
301,19;2037;1091,4;1040,4;60,8;;;;;;
301,47;2016;1101,6;1040,4;61,2;;;;;;
301,73;1995;1111,8;1040,4;61,9;;;;;;
301,99;1995;1122;1050,6;62,3;;;;;;
302,26;1974;1122;1050,6;62,3;;;;;;
302,53;1974;1122;1050,6;63,1;;;;;;
302,79;1974;1122;1060,8;63,5;;;;;;
303,06;1953;1122;1060,8;63,9;;;;;;
303,32;1953;1142,4;1060,8;65,9;;;;;;
303,58;1953;1213,8;1060,8;67,9;;;;;;
303,85;1932;1264,8;1060,8;65,9;;;;;;
304,12;1932;1326;1091,4;63,9;;;;;;
304,39;1932;1326;1132,2;62,3;;;;;;
304,65;1932;1336,2;1193,4;62,7;;;;;;
304,92;1932;1499,4;1213,8;61,9;;;;;;
305,18;1911;1509,6;1244,4;59,6;;;;;;
305,45;1911;1499,4;1275;60,4;;;;;;
305,71;1911;1275;1305,6;49,7;;;;;;
305,98;1911;1162,8;1295,4;49,3;;;;;;
306,24;1911;1152,6;1254,6;52,5;;;;;;
306,51;1890;1152,6;1213,8;55,2;;;;;;
306,77;1869;1152,6;1183,2;58;;;;;;
307,04;1869;1519,8;1173;63,9;;;;;;
307,3;1890;2101,2;1152,6;60,8;;;;;;
307,56;1890;2244;1224;57,6;;;;;;
307,83;1890;2244;1305,6;56;;;;;;
308,1;1890;2244;1397,4;54,8;;;;;;
308,37;1911;2142;1479;51,3;;;;;;
308,63;1911;2091;1540,2;55,6;;;;;;
308,9;1932;2091;1560,6;55,6;;;;;;
309,17;1953;2274,6;1581;56;;;;;;
309,43;1974;2274,6;1621,8;55,6;;;;;;
309,69;1995;2284,8;1642,2;55,2;;;;;;
309,96;1995;2264,4;1652,4;52,5;;;;;;
310,23;2016;2029,8;1642,2;55,6;;;;;;
310,5;2016;1989;1591,2;55,2;;;;;;
310,76;2037;1866,6;1560,6;55,6;;;;;;
311,03;2037;1703,4;1519,8;57,2;;;;;;
311,29;2037;1672,8;1479;59,2;;;;;;
311,56;2037;1540,2;1458,6;50,5;;;;;;
311,82;2037;1356,6;1428;46,2;;;;;;
312,09;2037;1295,4;1366,8;51,3;;;;;;
312,35;2016;1203,6;1305,6;49,3;;;;;;
312,62;2016;1152,6;1264,8;47,7;;;;;;
312,89;2016;1142,4;1213,8;51,3;;;;;;
313,15;2016;1142,4;1173;53,3;;;;;;
313,42;1995;1183,2;1152,6;62,7;;;;;;
313,68;1974;1601,4;1162,8;63,5;;;;;;
313,95;1995;1948,2;1152,6;58;;;;;;
314,21;1995;2040;1254,6;56,8;;;;;;
314,48;1995;2080,8;1356,6;54,4;;;;;;
314,75;2016;2091;1468,8;52,9;;;;;;
315,01;2016;1713,6;1550,4;46,9;;;;;;
315,27;2016;1458,6;1509,6;48,1;;;;;;
315,54;2016;1417,8;1387,2;52,5;;;;;;
315,81;2016;1346,4;1336,2;53,7;;;;;;
316,07;1995;1234,2;1275;51,7;;;;;;
316,33;1995;1162,8;1234,2;50,1;;;;;;
316,61;1974;1132,2;1193,4;51,7;;;;;;
316,87;1974;1122;1152,6;53,3;;;;;;
317,14;1953;1111,8;1132,2;54,1;;;;;;
317,39;1953;1101,6;1111,8;55,2;;;;;;
317,67;1932;1091,4;1101,6;55,6;;;;;;
317,93;1911;1071;1091,4;56,4;;;;;;
318,19;1890;1060,8;1071;57,6;;;;;;
318,45;1890;1050,6;1060,8;58,8;;;;;;
318,72;1869;1050,6;1050,6;58,8;;;;;;
318,98;1848;1050,6;1040,4;59,2;;;;;;
319,25;1827;1050,6;1030,2;59,2;;;;;;
319,51;1806;1050,6;1020;60,4;;;;;;
319,78;1806;1040,4;1020;63,5;;;;;;
320,05;1785;1040,4;1020;63,1;;;;;;
320,32;1764;1050,6;1009,8;63,5;;;;;;
320,58;1743;1040,4;1009,8;63,9;;;;;;
320,85;1722;1040,4;1009,8;60;;;;;;
321,11;1701;1040,4;979,2;54,1;;;;;;
321,38;1680;1040,4;989,4;54,8;;;;;;
321,65;1659;1040,4;999,6;55,2;;;;;;
321,91;1638;1040,4;1009,8;56;;;;;;
322,18;1617;1040,4;1009,8;56,8;;;;;;
322,45;1596;1040,4;1009,8;57,6;;;;;;
322,71;1575;1040,4;1009,8;58,8;;;;;;
322,97;1554;1040,4;1009,8;59,6;;;;;;
323,23;1533;1040,4;1009,8;60,4;;;;;;
323,51;1512;1030,2;1009,8;61,5;;;;;;
323,77;1470;1030,2;1009,8;63,1;;;;;;
324,04;987;1009,8;1020;76,1;;;;;;
324,31;756;1009,8;1030,2;79,7;;;;;;
324,57;840;1009,8;1030,2;78,5;;;;;;
324,84;840;1009,8;1030,2;78,1;;;;;;
325,1;840;1009,8;1030,2;78,5;;;;;;
325,37;819;1009,8;1030,2;78,5;;;;;;
325,63;819;1009,8;1030,2;78,5;;;;;;
325,9;861;1009,8;1020;78,1;;;;;;
326,17;987;1009,8;1009,8;76,1;;;;;;
326,43;1071;1020;1009,8;75;;;;;;
326,69;1239;1020;999,6;72,2;;;;;;
326,96;1407;1030,2;999,6;67,5;;;;;;
327,23;1554;1040,4;989,4;60;;;;;;
327,49;1680;1040,4;989,4;54,8;;;;;;
327,76;1869;1050,6;1020;50,1;;;;;;
328,03;1974;1050,6;1040,4;47,3;;;;;;
328,29;1869;1050,6;1060,8;49,3;;;;;;
328,55;1743;1040,4;1060,8;52,9;;;;;;
328,82;1638;1040,4;1050,6;56;;;;;;
329,09;1554;1040,4;1040,4;59,6;;;;;;
329,35;1491;1030,2;1030,2;62,7;;;;;;
329,62;1428;1030,2;1030,2;65,1;;;;;;
329,88;1365;1030,2;1030,2;67,9;;;;;;
330,15;1302;1030,2;1030,2;70,2;;;;;;
330,42;1239;1020;1030,2;71,8;;;;;;
330,68;1176;1020;1030,2;73,4;;;;;;
330,95;1113;1020;1020;74,6;;;;;;
331,21;1050;1020;1009,8;75,4;;;;;;
331,48;987;1009,8;1009,8;76,1;;;;;;
331,74;924;1009,8;999,6;76,9;;;;;;
332,01;882;1009,8;999,6;77,7;;;;;;
332,28;840;1009,8;989,4;78,5;;;;;;
332,54;819;1009,8;989,4;78,5;;;;;;
332,81;819;1020;989,4;78,5;;;;;;
333,07;819;1020;989,4;78,5;;;;;;
333,34;819;1020;999,6;78,5;;;;;;
333,61;819;1020;999,6;78,5;;;;;;
333,87;840;1009,8;999,6;78,1;;;;;;
334,14;840;1009,8;999,6;78,1;;;;;;
334,4;819;1009,8;999,6;78,9;;;;;;
334,66;819;1009,8;989,4;78,5;;;;;;
334,93;819;1009,8;989,4;78,5;;;;;;
335,2;819;1009,8;989,4;78,5;;;;;;
335,45;819;1009,8;989,4;78,5;;;;;;
335,73;819;1009,8;989,4;78,5;;;;;;
335,99;819;1009,8;989,4;78,5;;;;;;
336,26;819;1009,8;989,4;78,5;;;;;;
336,53;798;1020;989,4;78,9;;;;;;
336,79;777;1060,8;989,4;79,3;;;;;;
337,05;798;1224;989,4;78,9;;;;;;
337,32;798;1275;999,6;78,9;;;;;;
337,58;840;1285,2;1009,8;78,5;;;;;;
337,86;861;1305,6;1009,8;78,1;;;;;;
338,12;903;1326;1030,2;77,3;;;;;;
338,39;945;1366,8;1040,4;76,9;;;;;;
338,65;987;1387,2;1060,8;76,1;;;;;;
338,91;1071;1428;1081,2;75,4;;;;;;
339,18;1113;1479;1101,6;74,6;;;;;;
339,45;1197;1591,2;1132,2;73,4;;;;;;
339,71;1260;1683;1162,8;73;;;;;;
339,98;1344;1795,2;1203,6;69,8;;;;;;
340,24;1428;1897,2;1264,8;66,3;;;;;;
340,51;1554;2019,6;1346,4;61,5;;;;;;
340,78;1701;2131,8;1458,6;59,2;;;;;;
341,04;1827;1948,2;1611,6;50,9;;;;;;
341,31;1974;1703,4;1734;36,3;;;;;;
341,57;2100;1611,6;1662,6;45,8;;;;;;
341,84;2226;1805,4;1530;56,4;;;;;;
342,11;2373;2152,2;1499,4;52,1;;;;;;
342,37;2520;2172,6;1570,8;48,9;;;;;;
342,64;2688;2172,6;1652,4;48,5;;;;;;
342,89;2856;2162,4;1713,6;46,9;;;;;;
343,16;3024;2142;1764,6;46,9;;;;;;
343,42;3108;1193,4;1785;4,7;;;;;;
343,7;3087;1101,6;1458,6;7,5;;;;;;
343,96;2541;1081,2;1203,6;33,5;;;;;;
344,23;1953;1050,6;1111,8;42,2;;;;;;
344,49;1407;1030,2;1081,2;60,8;;;;;;
344,76;1764;1071;1060,8;65,1;;;;;;
345,02;1932;1142,4;1060,8;63,1;;;;;;
345,29;1995;1397,4;1111,8;62,3;;;;;;
345,56;1995;1795,2;1183,2;58,4;;;;;;
345,82;2037;1887;1305,6;57,2;;;;;;
346,09;2100;2162,4;1428;53,3;;;;;;
346,35;2163;2295;1591,2;52,1;;;;;;
346,62;2247;2315,4;1774,8;48,9;;;;;;
346,88;2331;2315,4;1938;48,5;;;;;;
347,14;2415;2274,6;2009,4;48,1;;;;;;
347,42;2457;1417,8;1958,4;4,7;;;;;;
347,69;2415;1071;1519,8;7,9;;;;;;
347,95;1932;1050,6;1244,4;35,5;;;;;;
348,21;1722;1162,8;1142,4;71,8;;;;;;
348,48;1680;1774,8;1152,6;63,1;;;;;;
348,75;1701;2142;1213,8;61,2;;;;;;
349,01;1722;2152,2;1264,8;60;;;;;;
349,28;1743;2172,6;1315,8;59,2;;;;;;
349,54;1764;2193;1366,8;57,6;;;;;;
349,81;1806;2203,2;1428;57,2;;;;;;
350,07;1827;2213,4;1468,8;56,8;;;;;;
350,34;1869;2233,8;1519,8;55,6;;;;;;
350,61;1890;2244;1581;55,6;;;;;;
350,87;1932;2264,4;1621,8;55,6;;;;;;
351,14;1974;2274,6;1672,8;55,2;;;;;;
351,4;1995;2295;1754,4;52,9;;;;;;
351,67;2037;2295;1846,2;51,3;;;;;;
351,93;2079;2295;1938;49,7;;;;;;
352,2;2121;2305,2;1968,6;52,9;;;;;;
352,46;2184;2305,2;1948,2;53,7;;;;;;
352,73;2205;2305,2;1978,8;52,5;;;;;;
353;2247;2172,6;1989;50,5;;;;;;
353,26;2163;1060,8;1693,2;7,9;;;;;;
353,53;1743;1040,4;1336,2;38,7;;;;;;
353,79;1239;1020;1193,4;69,8;;;;;;
354,06;1491;1448,4;1142,4;71,4;;;;;;
354,32;1701;1693,2;1173;60,4;;;;;;
354,59;1722;2009,4;1285,2;60,8;;;;;;
354,85;1722;2131,8;1417,8;56,4;;;;;;
355,12;1743;2162,4;1560,6;55,2;;;;;;
355,39;1764;2111,4;1713,6;55,6;;;;;;
355,65;1785;1989;1795,2;58;;;;;;
355,92;1806;1968,6;1795,2;56,8;;;;;;
356,18;1806;1897,2;1774,8;57,6;;;;;;
356,45;1827;1866,6;1723,8;58,8;;;;;;
356,71;1848;1876,8;1683;58,8;;;;;;
356,98;1848;1866,6;1662,6;58;;;;;;
357,24;1869;1856,4;1642,2;58,8;;;;;;
357,51;1890;1876,8;1642,2;58,4;;;;;;
357,77;1911;1897,2;1642,2;58;;;;;;
358,04;1911;1927,8;1642,2;57,6;;;;;;
358,31;1932;1968,6;1652,4;56,8;;;;;;
358,57;1953;1978,8;1662,6;56,4;;;;;;
358,83;1974;2091;1672,8;55,6;;;;;;
359,1;1974;2111,4;1703,4;54,8;;;;;;
359,37;1995;2111,4;1723,8;54,4;;;;;;
359,64;2016;2101,2;1744,2;55,2;;;;;;
359,9;2037;1989;1744,2;54,8;;;;;;
360,17;2037;1774,8;1703,4;54,4;;;;;;
360,43;2037;1275;1642,2;23,7;;;;;;
360,7;2058;1060,8;1407,6;23,7;;;;;;
360,96;2058;1060,8;1203,6;45,8;;;;;;
361,23;2058;1060,8;1101,6;52,1;;;;;;
361,5;2037;1050,6;1071;54,4;;;;;;
361,76;2037;1050,6;1050,6;56;;;;;;
362,03;2037;1050,6;1040,4;56,8;;;;;;
362,29;2037;1050,6;1030,2;57,2;;;;;;
362,56;2016;1050,6;1030,2;57,6;;;;;;
362,82;2016;1050,6;1030,2;46,9;;;;;;
363,09;2016;1050,6;1030,2;46,9;;;;;;
363,35;2016;1050,6;1030,2;46,9;;;;;;
363,62;1995;1050,6;1020;46,9;;;;;;
363,89;1995;1050,6;1020;46,9;;;;;;
364,15;1995;1050,6;1009,8;47,3;;;;;;
364,42;1995;1050,6;999,6;47,3;;;;;;
364,68;1974;1050,6;999,6;47,3;;;;;;
364,94;1974;1050,6;989,4;47,3;;;;;;
365,21;1974;1050,6;989,4;47,7;;;;;;
365,48;1974;1050,6;989,4;47,7;;;;;;
365,74;1953;1050,6;989,4;47,7;;;;;;
366,01;1953;1050,6;989,4;47,7;;;;;;
366,27;1953;1050,6;989,4;47,7;;;;;;
366,54;1932;1050,6;979,2;48,1;;;;;;
366,8;1932;1050,6;979,2;48,1;;;;;;
367,07;1932;1050,6;979,2;48,1;;;;;;
367,34;1932;1050,6;979,2;48,1;;;;;;
367,61;1911;1050,6;979,2;48,5;;;;;;
367,87;1911;1050,6;979,2;48,5;;;;;;
368,12;1911;1050,6;979,2;48,5;;;;;;
368,39;1890;1050,6;979,2;48,9;;;;;;
368,67;1869;1050,6;979,2;49,3;;;;;;
368,93;1848;1050,6;989,4;50,1;;;;;;
369,19;1806;1050,6;989,4;50,9;;;;;;
369,46;1785;1040,4;989,4;51,7;;;;;;
369,73;1764;1040,4;989,4;52,1;;;;;;
369,99;1743;1040,4;989,4;52,9;;;;;;
370,26;1722;1040,4;989,4;53,7;;;;;;
370,52;1680;1040,4;989,4;54,4;;;;;;
370,79;1659;1040,4;989,4;55,2;;;;;;
371,06;1638;1040,4;989,4;56;;;;;;
371,33;1617;1040,4;989,4;56,8;;;;;;
371,59;1596;1040,4;989,4;57,6;;;;;;
371,86;1575;1040,4;999,6;58,8;;;;;;
372,11;1554;1040,4;999,6;60;;;;;;
372,37;1533;1030,2;999,6;61,2;;;;;;
372,65;1512;1030,2;999,6;61,9;;;;;;
372,92;1470;1030,2;999,6;63,1;;;;;;
373,18;1470;1030,2;999,6;63,9;;;;;;
373,45;1449;1030,2;999,6;64,3;;;;;;
373,71;1449;1030,2;1020;64,3;;;;;;
373,98;1449;1030,2;1009,8;65,1;;;;;;
374,24;1428;1030,2;1009,8;65,5;;;;;;
374,51;1428;1030,2;999,6;65,5;;;;;;
374,78;1428;1030,2;999,6;65,5;;;;;;
375,04;1428;1030,2;999,6;66,3;;;;;;
375,31;1428;1030,2;989,4;66,3;;;;;;
375,57;1407;1030,2;989,4;66,7;;;;;;
375,84;1407;1030,2;989,4;66,7;;;;;;
376,1;1407;1030,2;989,4;67,1;;;;;;
376,37;1386;1030,2;989,4;67,5;;;;;;
376,64;1386;1030,2;989,4;67,5;;;;;;
376,9;1386;1030,2;979,2;67,5;;;;;;
377,16;1386;1030,2;979,2;67,5;;;;;;
377,43;1386;1030,2;979,2;67,9;;;;;;
377,69;1386;1030,2;979,2;67,9;;;;;;
377,96;1386;1030,2;979,2;67,9;;;;;;
378,23;1386;1030,2;979,2;67,9;;;;;;
378,49;1386;1030,2;979,2;68,3;;;;;;
378,76;1365;1030,2;979,2;67,9;;;;;;
379,02;1365;1030,2;979,2;67,9;;;;;;
379,29;1386;1030,2;979,2;67,9;;;;;;
379,56;1386;1030,2;979,2;67,9;;;;;;
379,83;1386;1030,2;979,2;67,9;;;;;;
380,08;1386;1030,2;979,2;67,9;;;;;;
380,35;1386;1030,2;979,2;67,9;;;;;;
380,62;1386;1030,2;979,2;67,9;;;;;;
380,89;1386;1030,2;979,2;67,5;;;;;;
381,15;1386;1030,2;979,2;67,5;;;;;;
381,41;1386;1030,2;979,2;67,5;;;;;;
381,68;1386;1030,2;979,2;67,5;;;;;;
381,95;1407;1030,2;979,2;67,5;;;;;;
382,21;1407;1030,2;979,2;67,5;;;;;;
382,48;1407;1030,2;979,2;67,1;;;;;;
382,74;1407;1030,2;979,2;67,5;;;;;;
383,01;1407;1030,2;979,2;67,5;;;;;;
383,27;1407;1030,2;979,2;67,1;;;;;;
383,54;1407;1030,2;979,2;67,1;;;;;;
383,81;1407;1030,2;979,2;67,1;;;;;;
384,07;1407;1030,2;979,2;67,1;;;;;;
384,34;1407;1030,2;979,2;67,1;;;;;;
384,6;1407;1030,2;979,2;67,1;;;;;;
384,87;1407;1030,2;979,2;67,1;;;;;;
385,14;1407;1030,2;979,2;66,7;;;;;;
385,4;1407;1030,2;979,2;66,7;;;;;;
385,67;1407;1030,2;979,2;66,7;;;;;;
385,93;1407;1030,2;979,2;66,7;;;;;;
386,2;1407;1030,2;979,2;67,1;;;;;;
386,46;1386;1030,2;979,2;67,5;;;;;;
386,73;1365;1030,2;979,2;68,3;;;;;;
386,99;1344;1030,2;979,2;68,6;;;;;;
387,25;1323;1030,2;979,2;69,4;;;;;;
387,52;1302;1030,2;979,2;70,2;;;;;;
387,79;1008;1020;979,2;75,4;;;;;;
388,06;672;1060,8;979,2;74,2;;;;;;
388,33;840;1009,8;979,2;78,1;;;;;;
388,59;861;1009,8;989,4;78,1;;;;;;
388,85;840;1009,8;989,4;78,1;;;;;;
389,12;840;1009,8;999,6;78,1;;;;;;
389,38;1008;1009,8;999,6;76,1;;;;;;
389,65;1155;1020;999,6;74,2;;;;;;
389,92;1365;1030,2;999,6;69;;;;;;
390,18;1617;1040,4;979,2;57,2;;;;;;
390,45;1890;1050,6;979,2;49,7;;;;;;
390,71;1911;1050,6;1009,8;48,5;;;;;;
390,98;1890;1050,6;1030,2;48,9;;;;;;
391,24;1785;1040,4;1030,2;51,3;;;;;;
391,51;1701;1040,4;1030,2;53,7;;;;;;
391,76;1617;1040,4;1030,2;56,8;;;;;;
392,03;1491;1030,2;1020;62,3;;;;;;
392,29;1407;1030,2;1020;66,7;;;;;;
392,56;1344;1030,2;1020;68,6;;;;;;
392,83;1302;1030,2;1030,2;69,8;;;;;;
393,09;1281;1030,2;1030,2;70,6;;;;;;
393,36;1260;1020;1020;71;;;;;;
393,62;1260;1020;1009,8;71,8;;;;;;
393,89;1218;1020;1009,8;72,2;;;;;;
394,16;1197;1020;999,6;73;;;;;;
394,42;1197;1020;999,6;73,4;;;;;;
394,69;1155;1020;999,6;73,8;;;;;;
394,95;1155;1020;989,4;73,8;;;;;;
395,21;1134;1020;989,4;74,2;;;;;;
395,48;1134;1020;989,4;74,2;;;;;;
395,75;1113;1020;989,4;74,6;;;;;;
396,02;1092;1020;989,4;74,6;;;;;;
396,28;1092;1020;979,2;75;;;;;;
396,55;1071;1020;979,2;75;;;;;;
396,81;1050;1020;979,2;75,4;;;;;;
397,07;1029;1009,8;979,2;75,8;;;;;;
397,34;1008;1009,8;979,2;76,1;;;;;;
397,61;987;1030,2;979,2;76,1;;;;;;
397,87;1008;1060,8;979,2;75,8;;;;;;
398,14;966;1071;979,2;76,5;;;;;;
398,41;966;1071;989,4;76,5;;;;;;
398,67;966;1111,8;999,6;76,5;;;;;;
398,94;966;1111,8;999,6;76,5;;;;;;
399,21;966;1162,8;999,6;76,5;;;;;;
399,48;966;1213,8;1009,8;76,5;;;;;;
399,74;966;1377;1020;76,5;;;;;;
400;987;1387,2;1040,4;76,1;;;;;;
400,27;1008;1397,4;1050,6;76,1;;;;;;
400,54;1008;1407,6;1071;75,8;;;;;;
400,8;1029;1264,8;1081,2;75,8;;;;;;
401,07;1029;1244,4;1091,4;75,8;;;;;;
401,34;1029;1224;1091,4;75,8;;;;;;
401,59;1029;1224;1101,6;75,8;;;;;;
401,86;1008;1234,2;1101,6;75,8;;;;;;
402,12;1029;1285,2;1101,6;75,8;;;;;;
402,39;1008;1407,6;1101,6;75,8;;;;;;
402,66;1029;1407,6;1111,8;75,8;;;;;;
402,92;1029;1417,8;1122;75,4;;;;;;
403,19;1029;1417,8;1122;75,4;;;;;;
403,45;1050;1417,8;1132,2;75,4;;;;;;
403,72;1071;1438,2;1132,2;75;;;;;;
403,99;1092;1458,6;1142,4;75;;;;;;
404,26;1092;1479;1152,6;74,6;;;;;;
404,53;1134;1509,6;1152,6;74,2;;;;;;
404,79;1155;1560,6;1162,8;73,8;;;;;;
405,06;1176;1591,2;1173;73,4;;;;;;
405,32;1197;1642,2;1193,4;73,4;;;;;;
405,59;1239;1683;1203,6;73;;;;;;
405,86;1281;1734;1224;72,2;;;;;;
406,11;1323;1774,8;1244,4;70,6;;;;;;
406,37;1344;1815,6;1264,8;68,3;;;;;;
406,64;1407;1866,6;1305,6;67,5;;;;;;
406,92;1449;1938;1346,4;64,7;;;;;;
407,18;1491;1968,6;1397,4;61,9;;;;;;
407,45;1533;2029,8;1458,6;61,2;;;;;;
407,71;1575;2050,2;1530;60,4;;;;;;
407,98;1617;2080,8;1611,6;59,6;;;;;;
408,25;1659;2121,6;1683;58,8;;;;;;
408,51;1722;2162,4;1764,6;57,2;;;;;;
408,78;1764;2193;1825,8;57,2;;;;;;
409,04;1827;2213,4;1866,6;57,2;;;;;;
409,31;1848;2233,8;1897,2;56,8;;;;;;
409,57;1890;2233,8;1917,6;55,6;;;;;;
409,84;1932;2244;1927,8;56;;;;;;
410,11;1974;2244;1927,8;55,6;;;;;;
410,36;2016;2254,2;1927,8;54,8;;;;;;
410,64;2058;2254,2;1927,8;54,4;;;;;;
410,9;2079;2244;1917,6;54,4;;;;;;
411,17;2142;2244;1897,2;54,1;;;;;;
411,43;2163;2244;1876,8;53,7;;;;;;
411,7;2205;2244;1836;53,3;;;;;;
411,97;2247;2111,4;1805,4;50,1;;;;;;
412,23;2268;1948,2;1744,2;52,1;;;;;;
412,49;2289;1662,6;1662,6;48,9;;;;;;
412,76;2289;1244,4;1550,4;19,7;;;;;;
413,03;2205;1060,8;1356,6;22,9;;;;;;
413,29;1764;1050,6;1183,2;45,4;;;;;;
413,56;1512;1101,6;1111,8;75;;;;;;
413,82;1491;1846,2;1111,8;67,5;;;;;;
414,09;1470;1968,6;1162,8;67,5;;;;;;
414,35;1470;1968,6;1203,6;67,1;;;;;;
414,62;1470;1958,4;1234,2;65,1;;;;;;
414,88;1470;1958,4;1264,8;66,3;;;;;;
415,15;1470;1958,4;1285,2;66,3;;;;;;
415,42;1470;1968,6;1315,8;65,9;;;;;;
415,68;1470;1968,6;1326;65,5;;;;;;
415,95;1491;1968,6;1346,4;65,1;;;;;;
416,21;1470;1968,6;1366,8;65,1;;;;;;
416,48;1491;1978,8;1377;64,3;;;;;;
416,74;1491;1989;1387,2;64,3;;;;;;
417,01;1491;1989;1407,6;63,9;;;;;;
417,28;1491;1989;1417,8;61,9;;;;;;
417,54;1512;1999,2;1428;63,1;;;;;;
417,81;1533;2019,6;1438,2;63,9;;;;;;
418,07;1533;2019,6;1438,2;62,7;;;;;;
418,34;1533;2019,6;1448,4;63,1;;;;;;
418,61;1533;2029,8;1448,4;61,9;;;;;;
418,87;1554;2029,8;1458,6;61,5;;;;;;
419,13;1554;2029,8;1468,8;61,9;;;;;;
419,4;1554;2029,8;1468,8;61,2;;;;;;
419,67;1575;2050,2;1479;61,2;;;;;;
419,93;1575;2050,2;1479;61,2;;;;;;
420,2;1575;2060,4;1489,2;61,2;;;;;;
420,47;1596;2070,6;1489,2;61,2;;;;;;
420,73;1596;2070,6;1499,4;60,8;;;;;;
421;1617;2080,8;1499,4;61,2;;;;;;
421,26;1617;2080,8;1499,4;60;;;;;;
421,53;1617;2080,8;1509,6;59,2;;;;;;
421,79;1617;2091;1519,8;59,2;;;;;;
422,06;1638;2101,2;1519,8;59,2;;;;;;
422,32;1659;2111,4;1519,8;59,6;;;;;;
422,59;1659;2111,4;1519,8;60;;;;;;
422,86;1659;2111,4;1519,8;58,8;;;;;;
423,12;1680;2121,6;1530;59,6;;;;;;
423,38;1680;2131,8;1530;59,6;;;;;;
423,65;1680;2131,8;1540,2;59,2;;;;;;
423,92;1701;2152,2;1550,4;58,8;;;;;;
424,18;1722;2162,4;1560,6;58,8;;;;;;
424,45;1743;2162,4;1591,2;58,4;;;;;;
424,71;1743;2172,6;1611,6;58,4;;;;;;
424,98;1764;2193;1632;58;;;;;;
425,25;1785;2193;1652,4;58;;;;;;
425,51;1806;2203,2;1672,8;57,6;;;;;;
425,77;1806;2213,4;1683;57,6;;;;;;
426,04;1848;2223,6;1703,4;56,8;;;;;;
426,31;1848;2233,8;1723,8;56,4;;;;;;
426,57;1869;2244;1744,2;55,6;;;;;;
426,84;1911;2254,2;1774,8;56,4;;;;;;
427,11;1932;2264,4;1815,6;55,6;;;;;;
427,37;1953;2274,6;1856,4;54,8;;;;;;
427,64;1974;2284,8;1897,2;54,8;;;;;;
427,9;1974;1295,4;1887;4,7;;;;;;
428,17;1869;1050,6;1560,6;7,9;;;;;;
428,43;1533;1040,4;1275;45;;;;;;
428,69;1029;1020;1173;70,2;;;;;;
428,95;1575;1377;1132,2;58,8;;;;;;
429,22;1134;1020;1152,6;70,6;;;;;;
429,49;714;1244,4;1122;80,5;;;;;;
429,76;1806;1264,8;1091,4;68,3;;;;;;
430,02;1953;1060,8;1142,4;59,2;;;;;;
430,29;1911;1142,4;1203,6;59,6;;;;;;
430,56;1911;1805,4;1295,4;58,8;;;;;;
430,82;1932;2254,2;1468,8;56;;;;;;
431,09;1953;2264,4;1713,6;50,9;;;;;;
431,35;1974;2274,6;1989;47,3;;;;;;
431,62;1995;2284,8;2162,4;47,3;;;;;;
431,89;2016;2295;2193;51,7;;;;;;
432,15;2058;2295;2162,4;54,8;;;;;;
432,42;2079;2295;2111,4;54,4;;;;;;
432,68;2121;2305,2;2080,8;54,1;;;;;;
432,95;2142;2305,2;2060,4;54,1;;;;;;
433,21;2163;2305,2;2009,4;53,7;;;;;;
433,48;2184;2305,2;1968,6;53,3;;;;;;
433,74;2205;2305,2;1938;53,3;;;;;;
434,01;2226;2233,8;1907,4;48,5;;;;;;
434,28;2247;1897,2;1815,6;55,2;;;;;;
434,54;2247;1417,8;1693,2;29,2;;;;;;
434,81;2142;1060,8;1489,2;16,2;;;;;;
435,07;1911;1050,6;1234,2;44,2;;;;;;
435,34;1449;1030,2;1142,4;66,7;;;;;;
435,6;1092;1203,6;1122;78,1;;;;;;
435,87;1617;1642,2;1111,8;65,1;;;;;;
436,13;1638;2009,4;1213,8;63,1;;;;;;
436,4;1659;2111,4;1305,6;60,8;;;;;;
436,67;1659;2111,4;1407,6;58,4;;;;;;
436,93;1659;2121,6;1519,8;58;;;;;;
437,2;1659;2111,4;1611,6;58,4;;;;;;
437,46;1659;2121,6;1693,2;58;;;;;;
437,73;1680;2121,6;1764,6;57,6;;;;;;
437,99;1680;2131,8;1815,6;58,8;;;;;;
438,26;1701;2142;1856,4;58,8;;;;;;
438,53;1701;2142;1887;57,6;;;;;;
438,79;1701;2152,2;1917,6;57,6;;;;;;
439,06;1722;2162,4;1938;57,2;;;;;;
439,32;1722;2172,6;1948,2;58,4;;;;;;
439,59;1743;2182,8;1958,4;56,8;;;;;;
439,85;1764;2193;1968,6;58;;;;;;
440,12;1764;2193;1978,8;58;;;;;;
440,38;1785;2193;1989;58;;;;;;
440,65;1785;2203,2;1999,2;57,6;;;;;;
440,92;1806;2203,2;2009,4;57,2;;;;;;
441,18;1806;2213,4;2019,6;57,6;;;;;;
441,45;1827;2213,4;2019,6;57,2;;;;;;
441,72;1827;2223,6;2019,6;56;;;;;;
441,97;1848;2223,6;2029,8;57,2;;;;;;
442,25;1848;2233,8;1999,2;56,8;;;;;;
442,51;1869;2233,8;1968,6;56,8;;;;;;
442,77;1869;2233,8;1948,2;56,8;;;;;;
443,03;1890;2244;1938;56,8;;;;;;
443,31;1890;2244;1938;56,4;;;;;;
443,57;1890;2223,6;1938;54,1;;;;;;
443,84;1890;1499,4;1876,8;11;;;;;;
444,1;1848;1050,6;1550,4;13,8;;;;;;
444,37;1869;1050,6;1275;42,2;;;;;;
444,63;1848;1050,6;1142,4;54,8;;;;;;
444,9;1827;1050,6;1091,4;58,4;;;;;;
445,16;1827;1050,6;1071;60;;;;;;
445,43;1806;1050,6;1060,8;61,2;;;;;;
445,7;1785;1040,4;1050,6;61,9;;;;;;
445,95;1764;1040,4;1050,6;62,3;;;;;;
446,22;1764;1040,4;1050,6;52,5;;;;;;
446,49;1743;1040,4;1050,6;52,9;;;;;;
446,76;1722;1040,4;1040,4;53,3;;;;;;
447,03;1701;1040,4;1040,4;53,7;;;;;;
447,29;1680;1040,4;1040,4;54,4;;;;;;
447,56;1680;1040,4;1030,2;54,8;;;;;;
447,82;1659;1040,4;1030,2;55,2;;;;;;
448,09;1638;1040,4;1030,2;56;;;;;;
448,35;1617;1040,4;1020;56,4;;;;;;
448,62;1617;1040,4;1020;56,8;;;;;;
448,89;1596;1040,4;1020;57,6;;;;;;
449,15;1575;1040,4;1020;58,4;;;;;;
449,42;1554;1040,4;1009,8;59,2;;;;;;
449,68;1554;1040,4;1009,8;60;;;;;;
449,95;1533;1040,4;1009,8;60,8;;;;;;
450,21;1512;1040,4;1009,8;62,7;;;;;;
450,48;1512;1162,8;1020;74,2;;;;;;
450,74;1491;1295,4;1060,8;69,8;;;;;;
451,01;1491;1356,6;1101,6;68,3;;;;;;
451,27;1491;1397,4;1142,4;68,6;;;;;;
451,54;1491;1591,2;1183,2;67,1;;;;;;
451,81;1491;1927,8;1224;66,7;;;;;;
452,07;1470;1968,6;1264,8;65,9;;;;;;
452,34;1470;1968,6;1305,6;64,7;;;;;;
452,61;1470;1958,4;1346,4;65,1;;;;;;
452,87;1470;1958,4;1377;63,1;;;;;;
453,14;1470;1958,4;1407,6;63,1;;;;;;
453,4;1470;1958,4;1428;63,5;;;;;;
453,67;1491;1968,6;1458,6;62,7;;;;;;
453,93;1491;1968,6;1479;63,5;;;;;;
454,2;1491;1968,6;1489,2;62,3;;;;;;
454,46;1491;1662,6;1499,4;58,8;;;;;;
454,73;1449;1173;1479;29,6;;;;;;
454,99;1449;1030,2;1315,8;38,7;;;;;;
455,26;1449;1030,2;1162,8;53,3;;;;;;
455,52;1428;1030,2;1101,6;58;;;;;;
455,79;1428;1030,2;1081,2;60,4;;;;;;
456,06;1407;1030,2;1060,8;62,7;;;;;;
456,33;1407;1030,2;1040,4;64,3;;;;;;
456,59;1386;1030,2;1030,2;65,5;;;;;;
456,85;1302;1030,2;1020;70,2;;;;;;
457,11;819;1009,8;1020;78,1;;;;;;
457,37;777;1009,8;1009,8;79,3;;;;;;
457,64;840;1009,8;1009,8;78,1;;;;;;
457,92;1071;1020;1009,8;75;;;;;;
458,18;1806;1040,4;999,6;51,3;;;;;;
458,44;1701;1040,4;1040,4;53,7;;;;;;
458,71;1701;1040,4;1071;53,7;;;;;;
458,98;1680;1040,4;1081,2;54,8;;;;;;
459,24;1638;1040,4;1081,2;56;;;;;;
459,51;1596;1040,4;1071;57,2;;;;;;
459,78;1533;1040,4;1060,8;60;;;;;;
460,04;1344;1030,2;1050,6;68,6;;;;;;
460,31;1029;1020;1060,8;75,4;;;;;;
460,58;819;1009,8;1050,6;78,5;;;;;;
460,84;840;1009,8;1050,6;78,5;;;;;;
461,11;840;1009,8;1040,4;78,5;;;;;;
461,37;966;1009,8;1030,2;76,5;;;;;;
461,63;1092;1020;1020;75;;;;;;
461,9;1911;1081,2;979,2;66,7;;;;;;
462,17;1806;1162,8;1050,6;70,2;;;;;;
462,42;1806;1958,4;1060,8;62,3;;;;;;
462,7;1806;2203,2;1183,2;56,8;;;;;;
462,95;1827;2213,4;1356,6;54,4;;;;;;
463,21;1869;2233,8;1550,4;53,3;;;;;;
463,48;1932;2254,2;1805,4;48,5;;;;;;
463,74;1974;2070,6;2009,4;40,6;;;;;;
464,01;2037;1683;1938;15,8;;;;;;
464,27;2037;1111,8;1550,4;19,3;;;;;;
464,54;1869;1050,6;1285,2;30;;;;;;
464,81;1365;1030,2;1162,8;57,6;;;;;;
465,07;861;1009,8;1111,8;69,4;;;;;;
465,34;777;1009,8;1091,4;73,4;;;;;;
465,6;1260;1040,4;1060,8;73;;;;;;
465,87;1344;1030,2;1060,8;67,1;;;;;;
466,14;1302;1030,2;1060,8;68,3;;;;;;
466,4;1302;1030,2;1040,4;71;;;;;;
466,67;1281;1030,2;1040,4;71,4;;;;;;
466,93;1281;1030,2;1030,2;71,8;;;;;;
467,2;1281;1040,4;1020;72,2;;;;;;
467,46;1281;1081,2;1020;71,8;;;;;;
467,73;1281;1152,6;999,6;79,3;;;;;;
467,99;1281;1407,6;1030,2;73,4;;;;;;
468,26;1281;1723,8;1071;73;;;;;;
468,53;1281;1734;1122;73;;;;;;
468,79;1302;1744,2;1162,8;72,2;;;;;;
469,06;1302;1754,4;1203,6;71,8;;;;;;
469,33;1323;1764,6;1234,2;71;;;;;;
469,59;1323;1785;1264,8;70,6;;;;;;
469,85;1344;1795,2;1295,4;68,6;;;;;;
470,12;1365;1815,6;1336,2;68,3;;;;;;
470,39;1386;1846,2;1366,8;67,1;;;;;;
470,65;1407;1866,6;1407,6;66,3;;;;;;
470,92;1428;1887;1448,4;63,9;;;;;;
471,18;1449;1907,4;1489,2;62,7;;;;;;
471,45;1449;1938;1540,2;62,7;;;;;;
471,71;1491;1968,6;1601,4;61,9;;;;;;
471,98;1512;1989;1672,8;61,5;;;;;;
472,24;1533;2009,4;1734;60,8;;;;;;
472,5;1554;1907,4;1785;58;;;;;;
472,78;1596;1723,8;1774,8;46,2;;;;;;
473,04;1596;1326;1672,8;30,4;;;;;;
473,31;1617;1203,6;1407,6;46,6;;;;;;
473,57;1617;1173;1254,6;57,6;;;;;;
473,84;1617;1132,2;1183,2;58,4;;;;;;
474,1;1617;1122;1152,6;59,2;;;;;;
474,37;1617;1091,4;1132,2;58,8;;;;;;
474,63;1617;1071;1111,8;59,2;;;;;;
474,9;1617;1071;1091,4;60,8;;;;;;
475,17;1596;1060,8;1081,2;61,9;;;;;;
475,43;1617;1091,4;1071;63,9;;;;;;
475,7;1617;1091,4;1060,8;63,9;;;;;;
475,96;1617;1101,6;1060,8;65,1;;;;;;
476,23;1596;1091,4;1050,6;65,1;;;;;;
476,49;1596;1101,6;1050,6;64,7;;;;;;
476,76;1596;1142,4;1050,6;72,2;;;;;;
477,03;1617;1173;1050,6;72,2;;;;;;
477,29;1596;1173;1050,6;73;;;;;;
477,56;1617;1173;1060,8;71,8;;;;;;
477,82;1617;1173;1091,4;71;;;;;;
478,09;1617;1173;1111,8;69;;;;;;
478,35;1617;1173;1122;69;;;;;;
478,62;1617;1173;1132,2;69;;;;;;
478,88;1617;1173;1132,2;69;;;;;;
479,15;1617;1173;1132,2;69,4;;;;;;
479,42;1638;1173;1132,2;69;;;;;;
479,68;1638;1173;1132,2;69,4;;;;;;
479,95;1638;1173;1132,2;69,8;;;;;;
480,21;1638;1193,4;1132,2;70,6;;;;;;
480,48;1638;1234,2;1132,2;70,2;;;;;;
480,74;1659;1234,2;1132,2;69,8;;;;;;
481,01;1659;1244,4;1132,2;69,4;;;;;;
481,28;1659;1254,6;1142,4;69;;;;;;
481,55;1680;1275;1162,8;67,9;;;;;;
481,81;1659;1275;1173;67,9;;;;;;
482,08;1659;1264,8;1183,2;67,5;;;;;;
482,34;1701;1275;1193,4;67,9;;;;;;
482,61;1701;1254,6;1203,6;63,1;;;;;;
482,87;1701;1173;1203,6;62,7;;;;;;
483,13;1701;1173;1193,4;63,5;;;;;;
483,4;1701;1162,8;1173;64,7;;;;;;
483,67;1701;1173;1162,8;65,5;;;;;;
483,93;1722;1173;1142,4;67,1;;;;;;
484,2;1701;1162,8;1142,4;67,1;;;;;;
484,46;1701;1162,8;1132,2;67,1;;;;;;
484,73;1722;1162,8;1122;67,5;;;;;;
484,99;1722;1142,4;1122;65,9;;;;;;
485,26;1722;1111,8;1111,8;65,5;;;;;;
485,53;1701;1071;1101,6;64,7;;;;;;
485,79;1701;1060,8;1091,4;65,1;;;;;;
486,06;1701;1050,6;1081,2;65,9;;;;;;
486,32;1701;1040,4;1071;66,7;;;;;;
486,59;1680;1040,4;1060,8;57,6;;;;;;
486,85;1680;1040,4;1020;60;;;;;;
487,12;1659;1040,4;1040,4;59,2;;;;;;
487,39;1659;1040,4;1050,6;58,8;;;;;;
487,65;1638;1040,4;1060,8;56;;;;;;
487,92;1638;1040,4;1060,8;56,4;;;;;;
488,18;1617;1040,4;1050,6;56,4;;;;;;
488,45;1617;1040,4;1050,6;56,8;;;;;;
488,72;1596;1040,4;1040,4;57,6;;;;;;
488,98;1575;1040,4;1040,4;58;;;;;;
489,23;1575;1040,4;1030,2;58,4;;;;;;
489,5;1554;1040,4;1030,2;59,2;;;;;;
489,77;1554;1040,4;1030,2;59,6;;;;;;
490,05;1554;1040,4;1030,2;60;;;;;;
490,31;1533;1040,4;1030,2;60,4;;;;;;
490,57;1512;1030,2;1030,2;61,2;;;;;;
490,83;1512;1030,2;1020;61,9;;;;;;
491,11;1491;1030,2;1020;62,3;;;;;;
491,37;1491;1030,2;1020;62,7;;;;;;
491,64;1491;1030,2;1020;63,1;;;;;;
491,9;1470;1030,2;1020;63,9;;;;;;
492,17;1449;1030,2;1030,2;64,3;;;;;;
492,43;1428;1030,2;1020;65,1;;;;;;
492,7;1428;1030,2;1020;67,9;;;;;;
492,96;1407;1030,2;1009,8;69,8;;;;;;
493,23;1428;1040,4;1009,8;69,4;;;;;;
493,49;1407;1040,4;1009,8;69,8;;;;;;
493,76;1407;1040,4;999,6;69,8;;;;;;
494,03;1407;1040,4;999,6;69,8;;;;;;
494,3;1407;1040,4;999,6;69,8;;;;;;
494,56;1407;1040,4;999,6;70,2;;;;;;
494,82;1407;1040,4;999,6;70,2;;;;;;
495,09;1386;1040,4;999,6;70,2;;;;;;
495,35;1386;1040,4;999,6;70,2;;;;;;
495,62;1386;1030,2;999,6;69,8;;;;;;
495,89;1365;1030,2;999,6;70,6;;;;;;
496,15;1365;1030,2;999,6;70,6;;;;;;
496,42;1365;1030,2;999,6;70,6;;;;;;
496,68;1344;1030,2;989,4;70,2;;;;;;
496,95;1344;1030,2;989,4;70,2;;;;;;
497,21;1344;1030,2;989,4;71;;;;;;
497,48;1344;1040,4;989,4;71;;;;;;
497,74;1344;1050,6;989,4;71;;;;;;
498,01;1302;1040,4;989,4;71,4;;;;;;
498,28;1302;1040,4;989,4;71,4;;;;;;
498,54;1302;1040,4;999,6;71,4;;;;;;
498,8;1302;1040,4;999,6;71,4;;;;;;
499,06;1302;1040,4;999,6;71,8;;;;;;
499,34;1281;1040,4;999,6;71,8;;;;;;
499,6;1281;1030,2;999,6;71,8;;;;;;
499,87;1281;1030,2;999,6;72,2;;;;;;
500,14;1218;1020;999,6;72,6;;;;;;
500,4;1260;1020;999,6;71,4;;;;;;
500,67;1218;1020;999,6;72,6;;;;;;
500,92;1218;1020;989,4;73;;;;;;
501,2;1197;1020;989,4;73,4;;;;;;
501,46;1197;1020;989,4;73,4;;;;;;
501,73;1176;1020;989,4;73,4;;;;;;
501,99;1155;1020;989,4;73,8;;;;;;
502,26;1155;1020;989,4;74,2;;;;;;
502,53;1134;1020;989,4;74,2;;;;;;
502,79;1113;1020;979,2;74,6;;;;;;
503,06;1092;1020;979,2;75;;;;;;
503,32;1092;1020;979,2;75;;;;;;
503,59;1071;1020;979,2;75;;;;;;
503,86;1071;1020;979,2;75;;;;;;
504,12;1050;1020;979,2;75,4;;;;;;
504,39;1050;1020;979,2;75,4;;;;;;
504,65;1029;1030,2;979,2;75,8;;;;;;
504,92;1029;1050,6;969;75,8;;;;;;
505,18;1029;1050,6;989,4;75,8;;;;;;
505,45;987;1050,6;999,6;76,1;;;;;;
505,71;1008;1101,6;999,6;76,1;;;;;;
505,98;987;1162,8;999,6;76,1;;;;;;
506,25;1008;1193,4;999,6;76,1;;;;;;
506,51;1029;1213,8;1020;75,4;;;;;;
506,78;1008;1132,2;1030,2;75,8;;;;;;
507,04;1008;1009,8;1050,6;75,8;;;;;;
507,31;735;1009,8;1040,4;79,3;;;;;;
507,57;777;1009,8;1030,2;79,3;;;;;;
507,84;840;1060,8;1030,2;78,1;;;;;;
508,1;1512;1030,2;1009,8;68,6;;;;;;
508,37;1491;1050,6;1020;68,3;;;;;;
508,63;1470;1101,6;1020;67,5;;;;;;
508,9;1470;1183,2;1020;74,6;;;;;;
509,17;1512;1458,6;1071;68,6;;;;;;
509,43;1533;1683;1122;65,1;;;;;;
509,7;1575;1764,6;1224;61,2;;;;;;
509,96;1617;1764,6;1336,2;60,4;;;;;;
510,23;1680;1509,6;1448,4;46,6;;;;;;
510,49;1701;1275;1407,6;51,3;;;;;;
510,76;1764;1244,4;1336,2;53,3;;;;;;
511,01;1764;1193,4;1275;52,1;;;;;;
511,29;1764;1173;1224;54,4;;;;;;
511,56;1785;1162,8;1183,2;56,8;;;;;;
511,82;1806;1152,6;1152,6;57,6;;;;;;
512,09;1827;1142,4;1132,2;58;;;;;;
512,36;1827;1132,2;1111,8;58,8;;;;;;
512,62;1848;1122;1101,6;58,8;;;;;;
512,89;1848;1122;1091,4;58,8;;;;;;
513,15;1848;1111,8;1091,4;59,2;;;;;;
513,42;1848;1111,8;1081,2;60;;;;;;
513,68;1869;1111,8;1071;59,6;;;;;;
513,95;1869;1111,8;1071;60,4;;;;;;
514,21;1869;1111,8;1060,8;61,2;;;;;;
514,48;1848;1060,8;1060,8;59,6;;;;;;
514,74;1869;1050,6;1050,6;60,4;;;;;;
515,01;1848;1050,6;1040,4;58,8;;;;;;
515,28;1848;1050,6;1030,2;56,4;;;;;;
515,54;1827;1050,6;1020;57,2;;;;;;
515,81;1806;1050,6;1009,8;65,1;;;;;;
516,07;1806;1060,8;1009,8;65,1;;;;;;
516,34;1806;1071;1009,8;65,9;;;;;;
516,6;1785;1060,8;1009,8;61,5;;;;;;
516,87;1764;1060,8;1009,8;62,3;;;;;;
517,14;1764;1040,4;1009,8;63,1;;;;;;
517,4;1764;1040,4;1009,8;62,7;;;;;;
517,67;1743;1040,4;1009,8;63,1;;;;;;
517,93;1722;1040,4;1009,8;63,5;;;;;;
518,2;1722;1040,4;999,6;63,9;;;;;;
518,46;1701;1040,4;999,6;64,3;;;;;;
518,73;1680;1040,4;999,6;65,1;;;;;;
518,99;1680;1071;999,6;63,9;;;;;;
519,26;1680;1111,8;999,6;71,8;;;;;;
519,53;1659;1132,2;1009,8;74,2;;;;;;
519,79;1659;1203,6;1009,8;71;;;;;;
520,06;1722;1530;1030,2;64,3;;;;;;
520,32;1701;1581;1091,4;61,5;;;;;;
520,59;1743;1499,4;1183,2;58,8;;;;;;
520,86;1743;1224;1254,6;50,5;;;;;;
521,12;1764;1162,8;1264,8;54,4;;;;;;
521,38;1785;1162,8;1224;55,6;;;;;;
521,65;1785;1111,8;1183,2;54,8;;;;;;
521,92;1785;1101,6;1152,6;56;;;;;;
522,18;1806;1091,4;1132,2;57,6;;;;;;
522,45;1785;1081,2;1101,6;58,4;;;;;;
522,71;1785;1081,2;1091,4;60;;;;;;
522,97;1785;1081,2;1081,2;60,8;;;;;;
523,23;1785;1071;1071;59,6;;;;;;
523,49;1743;1040,4;1040,4;53,3;;;;;;
523,76;1281;1030,2;1040,4;67,5;;;;;;
524,02;840;1020;1050,6;75;;;;;;
524,29;945;1234,2;1040,4;80,5;;;;;;
524,56;1113;1030,2;1040,4;73,4;;;;;;
524,82;1113;1050,6;1050,6;73,4;;;;;;
525,09;1176;1091,4;1050,6;76,1;;;;;;
525,36;1155;1132,2;1060,8;73,8;;;;;;
525,62;1155;1173;1060,8;73,8;;;;;;
525,89;1176;1346,4;1060,8;73,8;;;;;;
526,15;1176;1397,4;1081,2;73,4;;;;;;
526,42;1176;1356,6;1111,8;73,4;;;;;;
526,68;1176;1193,4;1132,2;73,4;;;;;;
526,94;1197;1173;1142,4;73,4;;;;;;
527,21;1197;1173;1152,6;75;;;;;;
527,48;1197;1173;1152,6;75;;;;;;
527,74;1218;1203,6;1152,6;76,9;;;;;;
528,01;1218;1224;1162,8;75,8;;;;;;
528,27;1218;1224;1162,8;75,8;;;;;;
528,54;1239;1224;1173;75,8;;;;;;
528,81;1239;1213,8;1173;74,6;;;;;;
529,07;1239;1162,8;1173;71,8;;;;;;
529,34;1260;1152,6;1173;69,4;;;;;;
529,61;1239;1132,2;1173;69,4;;;;;;
529,87;1260;1132,2;1152,6;70,2;;;;;;
530,14;1260;1122;1142,4;70,6;;;;;;
530,4;1260;1081,2;1132,2;67,5;;;;;;
530,67;1260;1040,4;1111,8;66,7;;;;;;
530,93;1239;1040,4;1091,4;68,3;;;;;;
531,19;1239;1040,4;1071;69;;;;;;
531,46;1260;1040,4;1060,8;70,2;;;;;;
531,73;1260;1050,6;1050,6;72,6;;;;;;
531,99;1239;1060,8;1040,4;73,4;;;;;;
532,26;1239;1060,8;1030,2;74,2;;;;;;
532,52;1260;1060,8;1030,2;72,2;;;;;;
532,79;1260;1050,6;1040,4;72,2;;;;;;
533,06;1239;1040,4;1040,4;72,6;;;;;;
533,32;1239;1040,4;1040,4;72,6;;;;;;
533,59;1239;1020;1040,4;72,6;;;;;;
533,85;1218;1020;1030,2;72,2;;;;;;
534,12;903;1009,8;1020;76,5;;;;;;
534,38;861;1020;1020;78,1;;;;;;
534,65;840;1020;1009,8;78,1;;;;;;
534,92;840;1020;999,6;78,1;;;;;;
535,18;966;1009,8;999,6;76,5;;;;;;
535,45;1344;1030,2;989,4;69;;;;;;
535,71;1743;1040,4;969;53,3;;;;;;
535,98;1785;1040,4;989,4;51,7;;;;;;
536,24;1785;1040,4;1020;51,7;;;;;;
536,51;1764;1040,4;1030,2;52,5;;;;;;
536,77;1743;1040,4;1030,2;52,9;;;;;;
537,04;1722;1040,4;1030,2;53,3;;;;;;
537,3;1701;1040,4;1030,2;53,7;;;;;;
537,57;1680;1040,4;1020;54,8;;;;;;
537,84;1638;1040,4;1020;55,6;;;;;;
538,1;1596;1040,4;1009,8;57,2;;;;;;
538,37;1554;1040,4;1009,8;59,2;;;;;;
538,64;1512;1030,2;1009,8;61,5;;;;;;
538,9;1470;1030,2;1009,8;63,5;;;;;;
539,17;1449;1030,2;1009,8;64,7;;;;;;
539,43;1407;1030,2;1009,8;66,7;;;;;;
539,7;1386;1030,2;1020;67,9;;;;;;
539,97;1365;1030,2;1020;68,3;;;;;;
540,23;1323;1030,2;1009,8;69,4;;;;;;
540,49;1302;1030,2;1009,8;70,2;;;;;;
540,76;1281;1030,2;999,6;71,4;;;;;;
541,03;1239;1030,2;999,6;72,6;;;;;;
541,29;1218;1040,4;999,6;73;;;;;;
541,56;1197;1050,6;989,4;73;;;;;;
541,82;1197;1081,2;979,2;73,4;;;;;;
542,09;1176;1101,6;999,6;73,4;;;;;;
542,35;1176;1101,6;1009,8;73,8;;;;;;
542,62;1155;1101,6;1020;73,8;;;;;;
542,88;1155;1101,6;1020;73,8;;;;;;
543,15;1176;1101,6;1030,2;73,4;;;;;;
543,41;1155;1111,8;1030,2;74,2;;;;;;
543,68;1155;1111,8;1030,2;73,8;;;;;;
543,95;1155;1111,8;1030,2;73,8;;;;;;
544,21;1134;1111,8;1030,2;74,2;;;;;;
544,48;1134;1101,6;1030,2;74,2;;;;;;
544,75;1134;1111,8;1030,2;74,2;;;;;;
545,01;1155;1101,6;1030,2;74,2;;;;;;
545,28;1155;1111,8;1040,4;73,8;;;;;;
545,54;1155;1101,6;1040,4;73,8;;;;;;
545,81;1134;1111,8;1040,4;74,2;;;;;;
546,07;1155;1101,6;1040,4;73,8;;;;;;
546,34;1155;1111,8;1040,4;73,8;;;;;;
546,6;1176;1111,8;1040,4;73,8;;;;;;
546,87;1176;1122;1040,4;73,4;;;;;;
547,14;1197;1122;1040,4;79,3;;;;;;
547,4;1218;1122;1040,4;78,5;;;;;;
547,66;1218;1132,2;1050,6;78,5;;;;;;
547,93;1239;1142,4;1060,8;79,3;;;;;;
548,2;1260;1142,4;1060,8;78,5;;;;;;
548,46;1281;1142,4;1071;77,3;;;;;;
548,73;1323;1142,4;1081,2;76,5;;;;;;
549;1344;1142,4;1081,2;75,8;;;;;;
549,26;1365;1142,4;1091,4;75,4;;;;;;
549,53;1386;1132,2;1091,4;75;;;;;;
549,78;1407;1132,2;1091,4;74,6;;;;;;
550,05;1407;1132,2;1091,4;74,2;;;;;;
550,31;1428;1132,2;1091,4;73,4;;;;;;
550,59;1449;1132,2;1091,4;73,4;;;;;;
550,86;1470;1132,2;1091,4;72,6;;;;;;
551,12;1491;1132,2;1101,6;72,6;;;;;;
551,38;1491;1132,2;1101,6;71,8;;;;;;
551,65;1512;1132,2;1101,6;71,8;;;;;;
551,92;1533;1122;1101,6;70,6;;;;;;
552,18;1554;1122;1101,6;70,6;;;;;;
552,45;1575;1111,8;1101,6;69,4;;;;;;
552,71;1596;1081,2;1101,6;66,3;;;;;;
552,98;1617;1071;1101,6;65,9;;;;;;
553,24;1638;1060,8;1091,4;66,3;;;;;;
553,51;1659;1040,4;1081,2;66,3;;;;;;
553,77;1680;1040,4;1060,8;66,3;;;;;;
554,04;1680;1040,4;1050,6;65,5;;;;;;
554,3;1701;1040,4;1040,4;64,3;;;;;;
554,57;1722;1040,4;1030,2;63,5;;;;;;
554,84;1722;1040,4;1030,2;59,2;;;;;;
555,1;1743;1050,6;1020;63,9;;;;;;
555,37;1764;1050,6;1020;63,1;;;;;;
555,64;1785;1050,6;1020;62,7;;;;;;
555,9;1785;1050,6;1009,8;62,3;;;;;;
556,17;1806;1050,6;1009,8;61,9;;;;;;
556,43;1827;1050,6;1009,8;61,5;;;;;;
556,7;1848;1050,6;1009,8;61,5;;;;;;
556,96;1869;1050,6;1009,8;61,2;;;;;;
557,23;1890;1050,6;1009,8;60,8;;;;;;
557,49;1890;1050,6;1009,8;60,8;;;;;;
557,75;1911;1050,6;1009,8;60;;;;;;
558,03;1932;1050,6;1009,8;59,6;;;;;;
558,29;1932;1050,6;999,6;59,2;;;;;;
558,56;1953;1050,6;999,6;58,4;;;;;;
558,82;1974;1050,6;999,6;58;;;;;;
559,09;1974;1050,6;999,6;57,6;;;;;;
559,35;1995;1050,6;999,6;56,8;;;;;;
559,62;2016;1050,6;999,6;56,4;;;;;;
559,88;2037;1050,6;999,6;56;;;;;;
560,15;2037;1050,6;999,6;56;;;;;;
560,42;2058;1060,8;999,6;56,4;;;;;;
560,71;2058;1060,8;999,6;56,8;;;;;;
560,96;2079;1060,8;999,6;56,4;;;;;;
561,23;2100;1060,8;999,6;56;;;;;;
561,49;2121;1060,8;999,6;56;;;;;;
561,76;2142;1060,8;999,6;55,2;;;;;;
562,03;2142;1060,8;999,6;54,4;;;;;;
562,29;2163;1060,8;989,4;53,7;;;;;;
562,56;2184;1060,8;989,4;52,1;;;;;;
562,82;2184;1060,8;989,4;50,9;;;;;;
563,09;2205;1060,8;989,4;50,5;;;;;;
563,35;2226;1060,8;989,4;48,5;;;;;;
563,62;2226;1060,8;979,2;46,2;;;;;;
563,89;2226;1060,8;938,4;45;;;;;;
564,15;2247;1071;948,6;44,6;;;;;;
564,42;2247;1071;958,8;44,6;;;;;;
564,68;2247;1071;958,8;44,6;;;;;;
564,95;2247;1071;958,8;44,6;;;;;;
565,21;2247;1071;958,8;44,6;;;;;;
565,48;2268;1071;958,8;44,6;;;;;;
565,74;2247;1071;958,8;44,6;;;;;;
566,01;2268;1071;969;44,6;;;;;;
566,28;2268;1071;969;44,6;;;;;;
566,54;2268;1071;969;44,6;;;;;;
566,81;2268;1071;969;44,6;;;;;;
567,07;2289;1071;969;44,2;;;;;;
567,34;2289;1071;969;44,2;;;;;;
567,61;2289;1071;969;44,2;;;;;;
567,87;2289;1071;969;44,2;;;;;;
568,13;2310;1071;969;44,2;;;;;;
568,4;2310;1071;969;44,2;;;;;;
568,67;2310;1071;969;44,2;;;;;;
568,93;2310;1071;969;44,2;;;;;;
569,2;2310;1071;969;44,2;;;;;;
569,46;2331;1071;969;44,2;;;;;;
569,73;2331;1071;969;44,2;;;;;;
569,99;2331;1071;969;44,2;;;;;;
570,26;2331;1071;969;44,2;;;;;;
570,53;2331;1071;969;44,2;;;;;;
570,79;2331;1071;958,8;44,2;;;;;;
571,06;2352;1071;958,8;44,2;;;;;;
571,32;2352;1071;958,8;43,8;;;;;;
571,59;2352;1071;958,8;43,8;;;;;;
571,85;2373;1071;958,8;43,8;;;;;;
572,12;2373;1071;958,8;43,8;;;;;;
572,39;2373;1071;958,8;43,8;;;;;;
572,65;2394;1071;958,8;43,8;;;;;;
572,91;2394;1071;958,8;43,8;;;;;;
573,18;2394;1071;958,8;43,8;;;;;;
573,45;2394;1071;958,8;43,8;;;;;;
573,72;2415;1071;958,8;43,8;;;;;;
573,98;2415;1071;958,8;43,4;;;;;;
574,24;2415;1071;958,8;43,4;;;;;;
574,51;2436;1071;958,8;43,4;;;;;;
574,78;2436;1071;958,8;43,4;;;;;;
575,04;2436;1071;958,8;43,4;;;;;;
575,31;2436;1071;958,8;43,4;;;;;;
575,57;2457;1071;958,8;43,4;;;;;;
575,84;2457;1071;958,8;43,4;;;;;;
576,1;2457;1071;958,8;43,4;;;;;;
576,37;2457;1071;958,8;43,4;;;;;;
576,64;2457;1071;958,8;43,4;;;;;;
576,9;2478;1071;958,8;43,4;;;;;;
577,17;2478;1071;958,8;43;;;;;;
577,43;2478;1071;958,8;43;;;;;;
577,7;2478;1071;958,8;43;;;;;;
577,97;2478;1081,2;958,8;43;;;;;;
578,23;2499;1081,2;958,8;43;;;;;;
578,49;2478;1081,2;958,8;43;;;;;;
578,76;2478;1081,2;958,8;43;;;;;;
579,02;2499;1081,2;958,8;43;;;;;;
579,29;2499;1081,2;958,8;43;;;;;;
579,56;2499;1081,2;958,8;43;;;;;;
579,82;2499;1081,2;958,8;43;;;;;;
580,09;2499;1081,2;958,8;43;;;;;;
580,35;2499;1081,2;958,8;43;;;;;;
580,62;2499;1081,2;958,8;43;;;;;;
580,89;2499;1081,2;958,8;43;;;;;;
581,15;2520;1081,2;958,8;43;;;;;;
581,42;2520;1081,2;958,8;43;;;;;;
581,68;2520;1081,2;958,8;43;;;;;;
581,95;2520;1081,2;958,8;43;;;;;;
582,21;2520;1081,2;958,8;43;;;;;;
582,47;2520;1081,2;958,8;43;;;;;;
582,74;2478;1081,2;958,8;43;;;;;;
583;2478;1071;958,8;43;;;;;;
583,26;2457;1071;958,8;43,4;;;;;;
583,54;2436;1071;958,8;43,4;;;;;;
583,81;2415;1071;958,8;43,4;;;;;;
584,07;2352;1071;958,8;43,8;;;;;;
584,34;1764;1040,4;989,4;52,1;;;;;;
584,6;1197;1020;1009,8;72,2;;;;;;
584,87;672;1020;1030,2;80,1;;;;;;
585,14;819;1009,8;1020;78,9;;;;;;
585,4;882;1009,8;1020;77,7;;;;;;
585,67;1092;1020;1009,8;75;;;;;;
585,93;1365;1030,2;999,6;69;;;;;;
586,2;1680;1040,4;999,6;55,6;;;;;;
586,46;2058;1050,6;999,6;46,6;;;;;;
586,73;2016;1050,6;1009,8;46,9;;;;;;
586,99;1911;1050,6;1020;48,1;;;;;;
587,26;1869;1050,6;1020;49,7;;;;;;
587,53;1806;1040,4;1009,8;51,3;;;;;;
587,79;1764;1040,4;999,6;52,1;;;;;;
588,06;1722;1040,4;999,6;53,3;;;;;;
588,32;1680;1040,4;989,4;54,4;;;;;;
588,59;1659;1040,4;989,4;55,6;;;;;;
588,86;1596;1040,4;989,4;56,8;;;;;;
589,12;1554;1040,4;989,4;59,6;;;;;;
589,39;1533;1040,4;989,4;60,4;;;;;;
589,65;1512;1030,2;989,4;61,5;;;;;;
589,92;1491;1030,2;989,4;62,7;;;;;;
590,18;1491;1030,2;989,4;65,5;;;;;;
590,45;1470;1030,2;999,6;67,9;;;;;;
590,71;1470;1030,2;1009,8;68,3;;;;;;
590,98;1470;1050,6;1009,8;68,6;;;;;;
591,24;1470;1060,8;1009,8;68,3;;;;;;
591,51;1470;1030,2;1009,8;64,3;;;;;;
591,78;1449;1030,2;1009,8;64,7;;;;;;
592,04;1407;1030,2;999,6;66,3;;;;;;
592,31;1386;1030,2;999,6;67,5;;;;;;
592,57;1134;1020;999,6;73,4;;;;;;
592,84;672;1050,6;999,6;76,5;;;;;;
593,1;819;1020;989,4;78,9;;;;;;
593,37;840;1009,8;989,4;78,1;;;;;;
593,64;861;1009,8;999,6;78,1;;;;;;
593,9;1008;1009,8;999,6;75,8;;;;;;
594,17;1134;1020;999,6;74,2;;;;;;
594,43;1302;1030,2;999,6;70,6;;;;;;
594,7;1491;1030,2;999,6;63,5;;;;;;
594,96;1680;1040,4;979,2;54,8;;;;;;
595,23;1575;1040,4;1009,8;61,2;;;;;;
595,5;1533;1050,6;1030,2;67,5;;;;;;
595,76;1491;1111,8;1040,4;72,6;;;;;;
596,03;1512;1162,8;1071;73;;;;;;
596,29;1554;1315,8;1091,4;69;;;;;;
596,56;1596;1530;1091,4;65,5;;;;;;
596,82;1638;1570,8;1142,4;63,1;;;;;;
597,09;1701;1540,2;1193,4;62,3;;;;;;
597,35;1743;1530;1244,4;62,3;;;;;;
597,62;1806;1519,8;1295,4;62,7;;;;;;
597,88;1848;1519,8;1315,8;61,9;;;;;;
598,15;1911;1550,4;1315,8;61,5;;;;;;
598,42;1953;1683;1336,2;60;;;;;;
598,68;2037;1744,2;1366,8;58;;;;;;
598,95;2100;1754,4;1407,6;58;;;;;;
599,21;2184;1785;1458,6;56,4;;;;;;
599,48;2268;1754,4;1530;55,6;;;;;;
599,74;2352;1723,8;1560,6;54,4;;;;;;
600,01;2436;1703,4;1570,8;54,4;;;;;;
600,28;2520;1672,8;1560,6;54,1;;;;;;
600,54;2604;1621,8;1591,2;49,7;;;;;;
600,81;2688;1519,8;1581;40,6;;;;;;
601,07;2730;1244,4;1499,4;35,9;;;;;;
601,34;2646;1081,2;1295,4;27,2;;;;;;
601,61;2121;1060,8;1152,6;41,8;;;;;;
601,87;1722;1081,2;1101,6;65,5;;;;;;
602,13;1701;1397,4;1091,4;65,5;;;;;;
602,4;1701;2152,2;1152,6;61,5;;;;;;
602,67;1722;2162,4;1213,8;60;;;;;;
602,93;1743;2182,8;1264,8;59,6;;;;;;
603,2;1764;2193;1315,8;58,8;;;;;;
603,46;1785;2203,2;1366,8;57,6;;;;;;
603,73;1806;2213,4;1397,4;56,8;;;;;;
603,99;1848;2223,6;1428;57,2;;;;;;
604,26;1869;2233,8;1458,6;56,8;;;;;;
604,53;1890;2244;1468,8;56,8;;;;;;
604,79;1911;2244;1479;56,4;;;;;;
605,06;1932;2254,2;1479;56;;;;;;
605,32;1932;2264,4;1479;55,6;;;;;;
605,59;1953;2274,6;1489,2;55,6;;;;;;
605,86;1974;2274,6;1499,4;55,6;;;;;;
606,12;1995;2284,8;1509,6;54,8;;;;;;
606,38;2016;2295;1519,8;54,8;;;;;;
606,65;2037;2295;1540,2;54,4;;;;;;
606,92;2079;2295;1560,6;54,1;;;;;;
607,18;2100;2305,2;1591,2;53,7;;;;;;
607,45;2163;2305,2;1621,8;53,3;;;;;;
607,71;2184;2305,2;1652,4;52,5;;;;;;
607,98;2226;2315,4;1703,4;52,1;;;;;;
608,24;2268;2315,4;1764,6;50,5;;;;;;
608,51;2331;2315,4;1825,8;51,3;;;;;;
608,78;2373;2325,6;1866,6;51,3;;;;;;
609,04;2415;2233,8;1876,8;49,7;;;;;;
609,31;2436;2050,2;1815,6;48,5;;;;;;
609,57;2457;1917,6;1734;53,3;;;;;;
609,84;2478;1917,6;1672,8;53,3;;;;;;
610,11;2478;1917,6;1652,4;53,3;;;;;;
610,37;2499;1927,8;1642,2;53,3;;;;;;
610,62;2499;1948,2;1632;52,9;;;;;;
610,89;2520;2009,4;1632;51,7;;;;;;
611,17;2541;2009,4;1642,2;51,7;;;;;;
611,43;2562;2009,4;1642,2;51,7;;;;;;
611,7;2562;2009,4;1652,4;51,7;;;;;;
611,96;2583;2203,2;1652,4;50,1;;;;;;
612,23;2604;2223,6;1693,2;50,1;;;;;;
612,49;2625;2009,4;1723,8;46,9;;;;;;
612,76;2667;2346;1713,6;49,3;;;;;;
613,03;2709;2346;1856,4;46,9;;;;;;
613,3;2709;1611,6;1958,4;4,7;;;;;;
613,56;2604;1081,2;1570,8;8,7;;;;;;
613,82;2058;1060,8;1264,8;35,5;;;;;;
614,09;1743;2182,8;1173;62,3;;;;;;
614,36;1722;2172,6;1193,4;61,2;;;;;;
614,62;1722;2162,4;1234,2;61,5;;;;;;
614,89;1722;2162,4;1254,6;61,2;;;;;;
615,15;1701;2152,2;1275;61,5;;;;;;
615,42;1701;2152,2;1295,4;61,5;;;;;;
615,68;1680;2142;1305,6;61,5;;;;;;
615,95;1701;2142;1315,8;61,5;;;;;;
616,21;1680;2131,8;1315,8;61,5;;;;;;
616,48;1680;2131,8;1326;61,5;;;;;;
616,75;1680;2131,8;1326;61,9;;;;;;
617,01;1659;2121,6;1326;62,3;;;;;;
617,27;1659;2121,6;1336,2;62,3;;;;;;
617,53;1659;2111,4;1336,2;62,7;;;;;;
617,8;1659;2111,4;1336,2;62,3;;;;;;
618,07;1638;1825,8;1336,2;13;;;;;;
618,33;1428;1030,2;1264,8;51,3;;;;;;
618,59;987;1009,8;1173;69,8;;;;;;
618,86;1974;1315,8;1122;48,1;;;;;;
619,12;2289;1101,6;1142,4;55,2;;;;;;
619,39;2331;1550,4;1244,4;58,4;;;;;;
619,66;2289;2040;1315,8;52,5;;;;;;
619,92;2310;2040;1509,6;50,1;;;;;;
620,19;2331;1989;1693,2;51,7;;;;;;
620,46;2352;1978,8;1785;51,7;;;;;;
620,73;2352;1917,6;1805,4;53,3;;;;;;
620,99;2373;1907,4;1774,8;54,4;;;;;;
621,26;2373;1907,4;1723,8;54,4;;;;;;
621,52;2394;1897,2;1683;54,1;;;;;;
621,79;2415;1897,2;1652,4;54,1;;;;;;
622,05;2415;1958,4;1642,2;53,3;;;;;;
622,32;2436;1948,2;1642,2;53,3;;;;;;
622,59;2457;1948,2;1642,2;53,3;;;;;;
622,86;2457;1948,2;1642,2;53,3;;;;;;
623,12;2478;1948,2;1652,4;53,3;;;;;;
623,38;2478;1989;1652,4;52,5;;;;;;
623,65;2520;2233,8;1672,8;50,9;;;;;;
623,92;2457;1071;1713,6;4,7;;;;;;
624,18;2331;1071;1438,2;16,2;;;;;;
624,45;1764;1040,4;1224;43;;;;;;
624,71;1575;1917,6;1142,4;65,9;;;;;;
624,98;1575;2060,4;1173;64,3;;;;;;
625,24;1575;2040;1213,8;65,1;;;;;;
625,51;1554;2040;1244,4;64,7;;;;;;
625,77;1533;2029,8;1275;65,1;;;;;;
626,04;1533;2019,6;1295,4;64,3;;;;;;
626,31;1533;2019,6;1305,6;64,3;;;;;;
626,57;1512;2019,6;1315,8;65,1;;;;;;
626,84;1512;1999,2;1315,8;65,5;;;;;;
627,1;1512;1999,2;1315,8;65,5;;;;;;
627,37;1491;1978,8;1315,8;65,1;;;;;;
627,64;1491;1978,8;1315,8;65,9;;;;;;
627,89;1491;1968,6;1315,8;66,3;;;;;;
628,17;1470;1958,4;1305,6;66,3;;;;;;
628,43;1470;1958,4;1305,6;65,9;;;;;;
628,7;1449;1938;1305,6;67,1;;;;;;
628,96;1449;1938;1295,4;66,7;;;;;;
629,23;1449;1917,6;1295,4;67,5;;;;;;
629,48;1428;1917,6;1285,2;67,5;;;;;;
629,76;1428;1897,2;1285,2;68,3;;;;;;
630,03;1428;1887;1285,2;68,3;;;;;;
630,29;1407;1887;1285,2;68,3;;;;;;
630,55;1407;1876,8;1275;68,6;;;;;;
630,81;1407;1866,6;1275;69,4;;;;;;
631,08;1386;1866,6;1275;69,4;;;;;;
631,35;1386;1846,2;1264,8;69,4;;;;;;
631,62;1365;1836;1264,8;69,8;;;;;;
631,88;1365;1825,8;1264,8;69,8;;;;;;
632,15;1344;1815,6;1264,8;70,2;;;;;;
632,42;1197;1020;1234,2;59,6;;;;;;
632,68;861;1009,8;1162,8;70,6;;;;;;
632,95;945;1275;1111,8;80,5;;;;;;
633,21;2016;1132,2;1091,4;60,8;;;;;;
633,48;1890;1142,4;1173;59,6;;;;;;
633,75;1869;1428;1264,8;63,1;;;;;;
634,01;1869;2070,6;1377;56,8;;;;;;
634,28;1890;2244;1581;52,1;;;;;;
634,55;1932;2182,8;1805,4;45;;;;;;
634,81;1953;1744,2;1795,2;54,8;;;;;;
635,07;1953;1071;1550,4;19,3;;;;;;
635,34;3150;2131,8;1275;51,3;;;;;;
635,6;4116;1132,2;1346,4;34,7;;;;;;
635,87;4347;1081,2;1244,4;39,5;;;;;;
636,13;4305;1081,2;1173;32;;;;;;
636,4;3612;1101,6;1111,8;39,1;;;;;;
636,67;2982;1101,6;1071;43,4;;;;;;
636,93;2478;1081,2;1060,8;45;;;;;;
637,2;1995;1050,6;1060,8;46,9;;;;;;
637,46;1533;1040,4;1050,6;59,2;;;;;;
637,73;1554;1040,4;1040,4;59,2;;;;;;
637,99;1554;1040,4;1030,2;61,2;;;;;;
638,26;1512;1030,2;1030,2;61,9;;;;;;
638,53;1554;1081,2;1030,2;66,7;;;;;;
638,79;1512;1856,4;1040,4;67,5;;;;;;
639,06;1470;1958,4;1101,6;68,3;;;;;;
639,32;1512;1989;1142,4;65,5;;;;;;
639,59;1512;2009,4;1183,2;65,9;;;;;;
639,86;1533;2019,6;1234,2;65,5;;;;;;
640,12;1554;2029,8;1264,8;63,1;;;;;;
640,39;1596;2050,2;1315,8;62,7;;;;;;
640,65;1638;2080,8;1346,4;60,8;;;;;;
640,91;1659;2111,4;1407,6;60,8;;;;;;
641,18;1701;2142;1458,6;58,4;;;;;;
641,45;1743;2172,6;1519,8;58;;;;;;
641,71;1785;2193;1601,4;56,4;;;;;;
641,98;1827;2142;1672,8;49,7;;;;;;
642,25;1869;1815,6;1713,6;50,9;;;;;;
642,51;1890;1774,8;1662,6;57,2;;;;;;
642,78;1911;1795,2;1601,4;59,2;;;;;;
643,03;1932;1927,8;1560,6;57,6;;;;;;
643,3;1953;2080,8;1550,4;55,6;;;;;;
643,57;1974;2091;1570,8;54,8;;;;;;
643,84;2016;2111,4;1591,2;55,2;;;;;;
644,1;2058;2193;1611,6;54,8;;;;;;
644,37;2121;2274,6;1632;54,1;;;;;;
644,63;2163;2264,4;1683;52,5;;;;;;
644,9;2226;2203,2;1713,6;49,3;;;;;;
645,17;2268;1927,8;1703,4;54,4;;;;;;
645,43;2310;1764,6;1642,2;52,9;;;;;;
645,7;2331;1713,6;1591,2;53,7;;;;;;
645,96;2352;1611,6;1570,8;50,9;;;;;;
646,23;2352;1162,8;1530;22,9;;;;;;
646,49;2373;1101,6;1305,6;41,8;;;;;;
646,76;2352;1071;1203,6;48,5;;;;;;
647,02;2352;1071;1142,4;49,3;;;;;;
647,29;2331;1071;1101,6;50,5;;;;;;
647,56;2310;1071;1071;50,5;;;;;;
647,82;2310;1071;1050,6;50,1;;;;;;
648,09;2268;1071;1040,4;51,3;;;;;;
648,35;2268;1071;1030,2;49,3;;;;;;
648,62;2226;1060,8;979,2;45;;;;;;
648,89;2205;1060,8;989,4;45;;;;;;
649,15;2184;1060,8;989,4;45,4;;;;;;
649,42;2142;1060,8;989,4;45,4;;;;;;
649,68;2121;1060,8;989,4;48,5;;;;;;
649,95;2079;1060,8;989,4;50,5;;;;;;
650,21;2079;1060,8;999,6;52,1;;;;;;
650,48;2037;1050,6;1020;56,4;;;;;;
650,75;2058;1081,2;1020;57,2;;;;;;
651;2037;1111,8;1030,2;62,3;;;;;;
651,27;2016;1142,4;1040,4;63,9;;;;;;
651,54;2037;1183,2;1050,6;67,1;;;;;;
651,81;2058;1244,4;1060,8;65,9;;;;;;
652,07;2037;1244,4;1071;65,1;;;;;;
652,34;2058;1244,4;1122;62,7;;;;;;
652,6;2058;1234,2;1162,8;60,8;;;;;;
652,87;2079;1234,2;1173;60,4;;;;;;
653,14;2079;1224;1183,2;61,5;;;;;;
653,4;2100;1213,8;1183,2;58,4;;;;;;
653,67;2079;1132,2;1183,2;55,6;;;;;;
653,93;2100;1132,2;1162,8;56,8;;;;;;
654,2;2100;1122;1152,6;56,8;;;;;;
654,46;2100;1122;1142,4;57,6;;;;;;
654,73;2100;1122;1132,2;58;;;;;;
654,99;2100;1142,4;1122;60;;;;;;
655,26;2121;1356,6;1122;64,3;;;;;;
655,53;2121;1438,2;1111,8;61,2;;;;;;
655,79;2142;1438,2;1152,6;59,2;;;;;;
656,06;2142;1428;1244,4;60,8;;;;;;
656,31;2163;1315,8;1295,4;53,7;;;;;;
656,59;2184;1183,2;1305,6;39,5;;;;;;
656,85;2184;1101,6;1264,8;45,8;;;;;;
657,12;2184;1091,4;1213,8;49,3;;;;;;
657,39;2184;1081,2;1173;51,7;;;;;;
657,65;2163;1071;1132,2;54,4;;;;;;
657,92;2163;1071;1101,6;56;;;;;;
658,18;2163;1071;1081,2;57,2;;;;;;
658,45;2184;1091,4;1071;58,4;;;;;;
658,71;2163;1101,6;1071;58,4;;;;;;
658,98;2163;1101,6;1071;59,2;;;;;;
659,24;2163;1132,2;1071;60,8;;;;;;
659,51;2163;1142,4;1081,2;60;;;;;;
659,78;2163;1162,8;1081,2;61,5;;;;;;
660,04;2184;1173;1091,4;61,5;;;;;;
660,31;2163;1162,8;1101,6;61,5;;;;;;
660,57;2184;1173;1101,6;61,2;;;;;;
660,84;2184;1162,8;1111,8;61,2;;;;;;
661,1;2184;1122;1111,8;58,8;;;;;;
661,37;2184;1122;1111,8;59,6;;;;;;
661,63;2205;1111,8;1111,8;58,8;;;;;;
661,9;2205;1101,6;1111,8;58,4;;;;;;
662,16;2205;1091,4;1101,6;58,8;;;;;;
662,43;2184;1081,2;1101,6;58,8;;;;;;
662,7;2163;1071;1091,4;59,6;;;;;;
662,96;2163;1060,8;1081,2;60,4;;;;;;
663,23;2163;1060,8;1071;58,8;;;;;;
663,49;2142;1060,8;1050,6;59,6;;;;;;
663,76;2121;1060,8;1050,6;59,6;;;;;;
664,02;2121;1060,8;1040,4;60,4;;;;;;
664,29;2079;1060,8;1030,2;54,8;;;;;;
664,56;2058;1060,8;1030,2;54,8;;;;;;
664,82;2037;1050,6;1020;54,8;;;;;;
665,09;2037;1050,6;1020;55,2;;;;;;
665,36;2016;1050,6;1009,8;56,8;;;;;;
665,62;1974;1050,6;1009,8;57,2;;;;;;
665,89;1953;1050,6;1009,8;58;;;;;;
666,15;1953;1050,6;999,6;58,8;;;;;;
666,42;1932;1050,6;999,6;58,8;;;;;;
666,68;1911;1050,6;999,6;59,2;;;;;;
666,95;1911;1050,6;999,6;60,8;;;;;;
667,21;1890;1050,6;999,6;60,8;;;;;;
667,48;1869;1071;999,6;60;;;;;;
667,74;1848;1071;999,6;60,4;;;;;;
668,01;1827;1071;999,6;60,4;;;;;;
668,28;1848;1071;1009,8;60,4;;;;;;
668,55;1827;1071;1009,8;60,4;;;;;;
668,81;1827;1071;1009,8;60,4;;;;;;
669,07;1827;1071;1009,8;60,8;;;;;;
669,34;1827;1071;1009,8;60,8;;;;;;
669,6;1806;1071;1009,8;60,8;;;;;;
669,87;1827;1071;1009,8;60,8;;;;;;
670,13;1806;1071;1009,8;61,2;;;;;;
670,4;1827;1071;1009,8;60,8;;;;;;
670,67;1785;1071;1009,8;61,2;;;;;;
670,93;1764;1081,2;1009,8;61,5;;;;;;
671,19;1806;1081,2;1009,8;60,4;;;;;;
671,45;1827;1091,4;1009,8;59,6;;;;;;
671,73;1827;1081,2;1020;65,1;;;;;;
672;1827;1081,2;1020;64,7;;;;;;
672,25;1827;1091,4;1020;65,1;;;;;;
672,53;1827;1081,2;1030,2;65,1;;;;;;
672,78;1827;1081,2;1030,2;65,1;;;;;;
673,05;1827;1081,2;1030,2;65,5;;;;;;
673,31;1827;1071;1030,2;64,7;;;;;;
673,59;1827;1071;1030,2;65,5;;;;;;
673,85;1827;1071;1030,2;65,9;;;;;;
674,12;1848;1071;1030,2;65,9;;;;;;
674,38;1827;1071;1030,2;66,3;;;;;;
674,65;1827;1071;1030,2;66,3;;;;;;
674,92;1827;1071;1030,2;66,7;;;;;;
675,18;1848;1071;1030,2;60,4;;;;;;
675,45;1827;1071;1030,2;60,8;;;;;;
675,71;1827;1071;1030,2;60,4;;;;;;
675,98;1827;1081,2;1030,2;60;;;;;;
676,24;1848;1081,2;1030,2;60;;;;;;
676,51;1827;1132,2;1030,2;67,1;;;;;;
676,78;1869;1305,6;1030,2;67,5;;;;;;
677,04;1848;1295,4;1020;64,3;;;;;;
677,31;1869;1479;1091,4;62,7;;;;;;
677,57;1932;1754,4;1142,4;59,6;;;;;;
677,84;1932;1754,4;1244,4;58;;;;;;
678,09;1974;1754,4;1346,4;57,6;;;;;;
678,37;2016;1795,2;1417,8;57,6;;;;;;
678,64;2058;1795,2;1499,4;57,2;;;;;;
678,9;2100;1795,2;1550,4;56,8;;;;;;
679,17;2142;1754,4;1581;54,8;;;;;;
679,46;2184;1703,4;1591,2;53,7;;;;;;
679,71;2205;1703,4;1581;55,2;;;;;;
679,98;2247;1530;1560,6;43;;;;;;
680,25;2268;1479;1509,6;48,1;;;;;;
680,51;2289;1366,8;1448,4;42,6;;;;;;
680,78;2268;1132,2;1356,6;37,5;;;;;;
681,04;2289;1101,6;1254,6;45,4;;;;;;
681,31;2289;1101,6;1183,2;49,3;;;;;;
681,57;2289;1101,6;1142,4;51,7;;;;;;
681,84;2289;1193,4;1122;58,8;;;;;;
682,1;2289;1173;1132,2;54,1;;;;;;
682,37;2289;1111,8;1132,2;52,9;;;;;;
682,64;2289;1101,6;1122;53,7;;;;;;
682,9;2289;1101,6;1111,8;54,1;;;;;;
683,17;2289;1101,6;1101,6;54,8;;;;;;
683,43;2289;1213,8;1101,6;60;;;;;;
683,7;2289;1366,8;1122;62,7;;;;;;
683,96;2310;1662,6;1091,4;57,2;;;;;;
684,23;2373;1825,8;1224;54,1;;;;;;
684,5;2373;1836;1377;53,3;;;;;;
684,76;2415;1825,8;1519,8;53,3;;;;;;
685,03;2457;1866,6;1632;52,9;;;;;;
685,29;2499;1866,6;1703,4;51,3;;;;;;
685,56;2520;1825,8;1744,2;49,3;;;;;;
685,82;2562;1774,8;1713,6;49,3;;;;;;
686,09;2604;1591,2;1621,8;47,7;;;;;;
686,36;2604;1275;1519,8;33,5;;;;;;
686,62;2604;1091,4;1356,6;32;;;;;;
686,89;2331;1071;1183,2;37,5;;;;;;
687,15;1764;1040,4;1111,8;48,1;;;;;;
687,42;1512;1152,6;1081,2;75,8;;;;;;
687,68;1722;1356,6;1091,4;65,9;;;;;;
687,95;1722;1978,8;1173;61,9;;;;;;
688,21;1743;2172,6;1275;58,4;;;;;;
688,48;1764;2182,8;1377;57,2;;;;;;
688,75;1785;2193;1489,2;56;;;;;;
689,01;1806;2203,2;1601,4;55,6;;;;;;
689,28;1827;2213,4;1693,2;56;;;;;;
689,54;1869;2233,8;1754,4;55,6;;;;;;
689,8;1890;2193;1785;56;;;;;;
690,07;1911;2131,8;1785;55,2;;;;;;
690,34;1932;2091;1754,4;56;;;;;;
690,61;1953;2091;1713,6;55,6;;;;;;
690,87;1974;2101,2;1683;55,6;;;;;;
691,14;1995;2101,2;1662,6;55,2;;;;;;
691,4;2016;2101,2;1642,2;55,2;;;;;;
691,67;2037;2091;1621,8;54,8;;;;;;
691,93;2058;2040;1611,6;52,9;;;;;;
692,2;2079;1968,6;1591,2;55,2;;;;;;
692,45;2100;1968,6;1570,8;55,6;;;;;;
692,73;2121;1968,6;1570,8;55,6;;;;;;
692,98;2142;1989;1570,8;54,8;;;;;;
693,26;2100;1723,8;1570,8;42,2;;;;;;
693,53;2163;1683;1540,2;58;;;;;;
693,79;2142;1805,4;1519,8;53,7;;;;;;
694,06;2184;1805,4;1530;56;;;;;;
694,32;2184;1887;1530;55,6;;;;;;
694,59;2205;1887;1540,2;55,6;;;;;;
694,85;2226;1999,2;1550,4;54,1;;;;;;
695,12;2247;2050,2;1570,8;53,7;;;;;;
695,39;2247;2182,8;1591,2;52,9;;;;;;
695,65;2268;2254,2;1652,4;51,7;;;;;;
695,92;2310;2254,2;1703,4;51,7;;;;;;
696,18;2331;2254,2;1734;51,7;;;;;;
696,45;2352;2254,2;1764,6;51,7;;;;;;
696,71;2373;2223,6;1785;51,3;;;;;;
696,98;2394;2193;1785;48,5;;;;;;
697,24;2394;1989;1774,8;51,7;;;;;;
697,51;2436;1958,4;1703,4;53,3;;;;;;
697,78;2436;1856,4;1683;48,9;;;;;;
698,04;2394;1071;1611,6;5,9;;;;;;
698,31;2184;1060,8;1326;24,9;;;;;;
698,58;1638;1091,4;1173;71,8;;;;;;
698,84;1827;2080,8;1142,4;61,2;;;;;;
699,11;1827;2213,4;1203,6;60;;;;;;
699,37;1827;2213,4;1264,8;60;;;;;;
699,64;1827;2213,4;1326;58,4;;;;;;
699,9;1827;2223,6;1377;57,6;;;;;;
700,17;1848;2223,6;1428;56,8;;;;;;
700,43;1848;2223,6;1479;56;;;;;;
700,7;1848;2233,8;1519,8;56,8;;;;;;
700,96;1869;2233,8;1560,6;56,4;;;;;;
701,23;1869;2233,8;1611,6;56;;;;;;
701,5;1890;2233,8;1642,2;56;;;;;;
701,76;1911;2244;1683;56;;;;;;
702,02;1911;2254,2;1703,4;55,6;;;;;;
702,29;1911;2254,2;1744,2;55,2;;;;;;
702,55;1932;2244;1764,6;54,8;;;;;;
702,83;1953;2233,8;1774,8;56;;;;;;
703,08;1953;2223,6;1764,6;55,6;;;;;;
703,34;1974;2223,6;1754,4;55,6;;;;;;
703,62;1974;2203,2;1744,2;55,6;;;;;;
703,88;2016;2244;1723,8;55,2;;;;;;
704,15;2016;2274,6;1734;55,2;;;;;;
704,41;2037;2264,4;1754,4;54,4;;;;;;
704,68;2037;2254,2;1764,6;54,1;;;;;;
704,95;2058;2254,2;1774,8;54,4;;;;;;
705,21;2100;2264,4;1785;54,4;;;;;;
705,48;2100;2295;1815,6;53,3;;;;;;
705,74;2121;2305,2;1866,6;50,9;;;;;;
706,01;2142;2305,2;1907,4;53,7;;;;;;
706,28;2142;2305,2;1927,8;51,3;;;;;;
706,54;2163;2305,2;1968,6;52,5;;;;;;
706,8;2184;2305,2;1989;53,3;;;;;;
707,07;2205;2305,2;2019,6;52,9;;;;;;
707,34;2226;2315,4;2040;52,9;;;;;;
707,59;2247;2315,4;2070,6;52,5;;;;;;
707,86;2268;2315,4;2091;52,1;;;;;;
708,12;2310;2315,4;2101,2;52,1;;;;;;
708,4;2310;2315,4;2121,6;51,7;;;;;;
708,67;2352;2325,6;2131,8;52,1;;;;;;
708,93;2373;2325,6;2142;51,7;;;;;;
709,2;2394;2325,6;2142;51,7;;;;;;
709,46;2415;2325,6;2152,2;51,3;;;;;;
709,73;2436;2325,6;2152,2;51,3;;;;;;
709,99;2457;2325,6;2162,4;51,3;;;;;;
710,26;2478;2335,8;2172,6;50,9;;;;;;
710,52;2499;2335,8;2172,6;50,9;;;;;;
710,79;2520;2335,8;2172,6;50,5;;;;;;
711,06;2541;2335,8;2182,8;50,5;;;;;;
711,32;2562;2335,8;2193;50,1;;;;;;
711,59;2583;2335,8;2203,2;50,1;;;;;;
711,86;2604;2346;2213,4;50,1;;;;;;
712,12;2625;2346;2223,6;50,1;;;;;;
712,39;2646;2346;2223,6;49,7;;;;;;
712,64;2667;2346;2233,8;49,3;;;;;;
712,92;2688;2346;2233,8;49,7;;;;;;
713,18;2709;2346;2244;49,3;;;;;;
713,45;2730;2346;2254,2;49,3;;;;;;
713,71;2751;2356,2;2254,2;48,5;;;;;;
713,98;2772;2356,2;2264,4;48,9;;;;;;
714,24;2793;2356,2;2274,6;48,9;;;;;;
714,51;2814;2356,2;2274,6;48,5;;;;;;
714,78;2835;2356,2;2284,8;48,1;;;;;;
715,04;2856;2356,2;2284,8;48,5;;;;;;
715,31;2856;2366,4;2295;48,5;;;;;;
715,57;2877;2366,4;2295;48,5;;;;;;
715,84;2898;2366,4;2295;48,1;;;;;;
716,11;2919;2366,4;2305,2;48,1;;;;;;
716,37;2940;2366,4;2305,2;47,7;;;;;;
716,64;2961;2366,4;2315,4;48,1;;;;;;
716,9;2982;2366,4;2325,6;47,7;;;;;;
717,17;2982;2376,6;2325,6;47,7;;;;;;
717,43;3003;2376,6;2335,8;47,3;;;;;;
717,7;3024;2376,6;2335,8;47,3;;;;;;
717,96;3003;1734;2346;4,7;;;;;;
718,23;3003;1091,4;1795,2;9,9;;;;;;
718,49;3003;1091,4;1336,2;36,7;;;;;;
718,76;2961;1091,4;1152,6;52,1;;;;;;
719,03;2919;1091,4;1122;54,4;;;;;;
719,29;2877;1091,4;1111,8;54,8;;;;;;
719,56;2814;1091,4;1101,6;55,2;;;;;;
719,82;2751;1091,4;1101,6;55,2;;;;;;
720,09;2688;1081,2;1101,6;41,8;;;;;;
720,35;2625;1081,2;1101,6;42,2;;;;;;
720,62;2562;1081,2;1091,4;42,6;;;;;;
720,89;2499;1081,2;1081,2;43;;;;;;
721,15;2436;1071;1071;43,4;;;;;;
721,42;2373;1071;1050,6;43,8;;;;;;
721,68;2310;1071;1030,2;44,2;;;;;;
721,95;2226;1071;1020;44,6;;;;;;
722,21;1722;1040,4;1030,2;52,9;;;;;;
722,48;1197;1020;1040,4;71,8;;;;;;
722,74;1113;1020;1050,6;75;;;;;;
723,01;2016;1050,6;1030,2;47,3;;;;;;
723,28;2646;1081,2;1009,8;42,2;;;;;;
723,54;2646;1081,2;1050,6;42,2;;;;;;
723,81;2604;1081,2;1071;42,6;;;;;;
724,07;2583;1081,2;1071;42,6;;;;;;
724,34;2562;1081,2;1060,8;42,6;;;;;;
724,6;2562;1081,2;1040,4;42,6;;;;;;
724,87;2541;1081,2;1020;42,6;;;;;;
725,13;2520;1081,2;1009,8;43;;;;;;
725,4;2478;1071;1009,8;43;;;;;;
725,66;2436;1071;999,6;43,4;;;;;;
725,93;2394;1071;999,6;43,8;;;;;;
726,2;2352;1071;999,6;43,8;;;;;;
726,46;2289;1071;999,6;44,2;;;;;;
726,73;2247;1071;999,6;44,6;;;;;;
726,99;2226;1060,8;999,6;45;;;;;;
727,26;2184;1060,8;999,6;45;;;;;;
727,53;2163;1060,8;999,6;45,4;;;;;;
727,79;2142;1060,8;999,6;45,8;;;;;;
728,05;2142;1060,8;999,6;45,8;;;;;;
728,32;2121;1060,8;989,4;45,8;;;;;;
728,59;2121;1060,8;989,4;45,8;;;;;;
728,85;2100;1060,8;989,4;45,8;;;;;;
729,12;2100;1060,8;989,4;46,2;;;;;;
729,39;2100;1060,8;989,4;46,2;;;;;;
729,65;2100;1060,8;989,4;46,2;;;;;;
729,92;2079;1060,8;989,4;46,2;;;;;;
730,17;2079;1060,8;989,4;46,2;;;;;;
730,45;2079;1060,8;989,4;46,2;;;;;;
730,76;2079;1060,8;989,4;46,2;;;;;;
730,99;2079;1060,8;989,4;46,2;;;;;;
731,26;2079;1060,8;989,4;46,2;;;;;;
731,53;2079;1060,8;989,4;46,2;;;;;;
731,78;2079;1060,8;989,4;46,2;;;;;;
732,04;2079;1060,8;989,4;46,2;;;;;;
732,32;2079;1060,8;989,4;46,2;;;;;;
732,6;2079;1060,8;989,4;46,2;;;;;;
732,85;2079;1060,8;989,4;46,2;;;;;;
733,11;2079;1060,8;989,4;46,2;;;;;;
733,39;2079;1060,8;989,4;46,2;;;;;;
733,65;2079;1060,8;989,4;46,2;;;;;;
733,92;2079;1060,8;989,4;46,2;;;;;;
734,18;2079;1060,8;989,4;46,2;;;;;;
734,45;2079;1060,8;989,4;46,2;;;;;;
734,71;2079;1060,8;989,4;46,2;;;;;;
734,98;2079;1060,8;989,4;46,2;;;;;;
735,24;2058;1060,8;989,4;46,2;;;;;;
735,51;2079;1060,8;989,4;46,2;;;;;;
735,78;2058;1060,8;989,4;46,2;;;;;;
736,04;2079;1060,8;989,4;46,2;;;;;;
736,31;2058;1060,8;989,4;46,2;;;;;;
736,57;2058;1060,8;989,4;46,6;;;;;;
736,84;2058;1060,8;989,4;46,2;;;;;;
737,1;2058;1060,8;989,4;46,2;;;;;;
737,37;2058;1060,8;989,4;46,2;;;;;;
737,62;2058;1060,8;989,4;46,6;;;;;;
737,9;2037;1050,6;989,4;46,6;;;;;;
738,16;1995;1050,6;989,4;46,9;;;;;;
738,43;1512;1030,2;999,6;61,2;;;;;;
738,7;966;1009,8;1030,2;75,8;;;;;;
738,97;693;1050,6;1030,2;79,7;;;;;;
739,23;903;1009,8;1030,2;77,3;;;;;;
739,49;1302;1030,2;1020;70,6;;;;;;
739,76;1680;1040,4;1020;55,6;;;;;;
740,03;2079;1060,8;1040,4;46,6;;;;;;
740,29;2373;1071;1040,4;43,8;;;;;;
740,56;2247;1071;1060,8;44,6;;;;;;
740,82;2163;1060,8;1060,8;45,4;;;;;;
741,09;2079;1060,8;1050,6;46,2;;;;;;
741,35;1995;1050,6;1040,4;46,9;;;;;;
741,62;1890;1050,6;1030,2;48,5;;;;;;
741,88;1806;1050,6;1020;50,9;;;;;;
742,15;1701;1040,4;1020;54,1;;;;;;
742,42;1617;1040,4;1020;56,8;;;;;;
742,68;1533;1040,4;1020;60;;;;;;
742,95;1470;1030,2;1020;63,5;;;;;;
743,21;1428;1030,2;1020;65,9;;;;;;
743,48;1386;1030,2;1020;67,5;;;;;;
743,75;1365;1030,2;1030,2;67,9;;;;;;
744,01;1365;1030,2;1030,2;68,3;;;;;;
744,27;1365;1030,2;1020;69,8;;;;;;
744,53;1344;1030,2;1020;71;;;;;;
744,81;1344;1050,6;1020;70,6;;;;;;
745,07;1344;1081,2;1009,8;70,2;;;;;;
745,34;1365;1101,6;999,6;70,2;;;;;;
745,6;1365;1111,8;1009,8;77,3;;;;;;
745,87;1386;1162,8;1030,2;77,3;;;;;;
746,13;1386;1193,4;1050,6;75,4;;;;;;
746,39;1428;1397,4;1071;71,4;;;;;;
746,65;1428;1601,4;1101,6;68,3;;;;;;
746,93;1449;1642,2;1152,6;67,5;;;;;;
747,19;1491;1642,2;1213,8;64,7;;;;;;
747,46;1533;1642,2;1285,2;64,3;;;;;;
747,73;1554;1642,2;1336,2;63,9;;;;;;
747,99;1596;1642,2;1387,2;63,9;;;;;;
748,25;1638;1652,4;1428;63,1;;;;;;
748,53;1680;1642,2;1489,2;59,6;;;;;;
748,79;1743;1703,4;1479;61,5;;;;;;
749,06;1785;1764,6;1479;60,4;;;;;;
749,32;1827;1754,4;1499,4;60;;;;;;
749,59;1890;1744,2;1530;58,8;;;;;;
749,86;1953;1744,2;1550,4;59,2;;;;;;
750,12;1995;1713,6;1581;53,7;;;;;;
750,39;1974;1060,8;1499,4;17;;;;;;
750,65;1701;1040,4;1275;33,1;;;;;;
750,92;1176;1020;1173;61,2;;;;;;
751,18;1029;1285,2;1122;80,5;;;;;;
751,45;1323;1060,8;1111,8;67,1;;;;;;
751,71;1344;1111,8;1132,2;67,9;;;;;;
751,98;1386;1122;1162,8;65,1;;;;;;
752,25;1407;1152,6;1162,8;66,7;;;;;;
752,51;1407;1152,6;1162,8;67,5;;;;;;
752,77;1428;1152,6;1152,6;67,9;;;;;;
753,04;1428;1162,8;1142,4;68,6;;;;;;
753,31;1449;1162,8;1132,2;69,4;;;;;;
753,57;1449;1173;1132,2;69;;;;;;
753,84;1470;1173;1132,2;69,4;;;;;;
754,1;1470;1173;1132,2;69,4;;;;;;
754,37;1491;1173;1132,2;69;;;;;;
754,63;1491;1162,8;1132,2;68,3;;;;;;
754,9;1512;1132,2;1132,2;65,9;;;;;;
755,17;1512;1111,8;1122;65,9;;;;;;
755,43;1533;1111,8;1111,8;65,9;;;;;;
755,7;1533;1111,8;1111,8;66,3;;;;;;
755,96;1533;1111,8;1111,8;66,7;;;;;;
756,23;1554;1111,8;1101,6;66,3;;;;;;
756,5;1575;1111,8;1101,6;65,5;;;;;;
756,76;1575;1111,8;1101,6;65,5;;;;;;
757,02;1596;1111,8;1101,6;65,1;;;;;;
757,3;1596;1091,4;1101,6;63,9;;;;;;
757,56;1596;1081,2;1091,4;63,1;;;;;;
757,82;1596;1071;1091,4;63,5;;;;;;
758,09;1596;1060,8;1081,2;63,9;;;;;;
758,36;1617;1060,8;1071;64,3;;;;;;
758,62;1617;1050,6;1071;64,3;;;;;;
758,88;1638;1050,6;1050,6;64,7;;;;;;
759,15;1617;1040,4;1050,6;64,3;;;;;;
759,42;1638;1040,4;1040,4;63,1;;;;;;
759,68;1617;1040,4;1030,2;61,2;;;;;;
759,95;1617;1040,4;1030,2;58;;;;;;
760,21;1617;1040,4;999,6;56,4;;;;;;
760,48;1617;1040,4;999,6;56,8;;;;;;
760,75;1617;1040,4;1009,8;56,4;;;;;;
761,01;1617;1040,4;1020;56,8;;;;;;
761,28;1617;1040,4;1030,2;56,8;;;;;;
761,54;1617;1040,4;1030,2;56,8;;;;;;
761,81;1617;1040,4;1030,2;56,8;;;;;;
762,07;1596;1040,4;1030,2;56,8;;;;;;
762,34;1596;1040,4;1030,2;56,8;;;;;;
762,61;1596;1040,4;1030,2;56,8;;;;;;
762,86;1617;1040,4;1030,2;56,8;;;;;;
763,12;1617;1040,4;1030,2;56,8;;;;;;
763,39;1596;1040,4;1030,2;57,2;;;;;;
763,66;1596;1040,4;1030,2;57,2;;;;;;
763,93;1596;1040,4;1030,2;57,2;;;;;;
764,2;1596;1040,4;1030,2;57,2;;;;;;
764,46;1596;1040,4;1030,2;57,2;;;;;;
764,73;1596;1040,4;1030,2;57,2;;;;;;
764,99;1596;1040,4;1030,2;57,2;;;;;;
765,26;1596;1040,4;1030,2;57,2;;;;;;
765,53;1596;1040,4;1030,2;57,2;;;;;;
765,79;1596;1040,4;1030,2;57,2;;;;;;
766,06;1596;1040,4;1030,2;56,8;;;;;;
766,32;1617;1040,4;1020;56,8;;;;;;
766,59;1617;1040,4;1020;56,8;;;;;;
766,85;1617;1040,4;1020;56,8;;;;;;
767,12;1617;1040,4;1020;56,4;;;;;;
767,39;1617;1040,4;1020;56,8;;;;;;
767,65;1638;1040,4;1020;56;;;;;;
767,92;1617;1040,4;1020;56,4;;;;;;
768,18;1638;1040,4;1020;56;;;;;;
768,45;1638;1040,4;1020;56;;;;;;
768,71;1638;1040,4;1020;56;;;;;;
768,98;1638;1040,4;1020;56;;;;;;
769,24;1638;1040,4;1020;55,6;;;;;;
769,51;1659;1040,4;1020;55,6;;;;;;
769,78;1659;1040,4;1020;55,6;;;;;;
770,04;1659;1040,4;1020;55,6;;;;;;
770,31;1659;1040,4;1020;55,2;;;;;;
770,57;1680;1040,4;1020;54,8;;;;;;
770,83;1680;1040,4;1020;54,8;;;;;;
771,11;1680;1040,4;1020;54,8;;;;;;
771,37;1680;1040,4;1020;54,4;;;;;;
771,64;1701;1040,4;1020;54,1;;;;;;
771,9;1701;1040,4;1020;54,1;;;;;;
772,17;1701;1040,4;1020;54,1;;;;;;
772,43;1701;1040,4;1020;54,1;;;;;;
772,7;1701;1040,4;1009,8;54,1;;;;;;
772,96;1680;1040,4;1009,8;54,4;;;;;;
773,23;1680;1040,4;1009,8;54,8;;;;;;
773,49;1659;1040,4;1009,8;55,6;;;;;;
773,76;1638;1040,4;1009,8;56;;;;;;
774,02;1617;1040,4;1009,8;56,8;;;;;;
774,29;1596;1040,4;1009,8;57,6;;;;;;
774,56;1575;1040,4;1009,8;58,4;;;;;;
774,82;1554;1040,4;1009,8;59,6;;;;;;
775,09;1533;1040,4;1009,8;60,4;;;;;;
775,35;1512;1030,2;1009,8;61,2;;;;;;
775,62;1491;1030,2;1009,8;62,3;;;;;;
775,89;1491;1030,2;1009,8;62,7;;;;;;
776,15;1470;1030,2;1009,8;63,1;;;;;;
776,42;1470;1030,2;1020;63,1;;;;;;
776,68;1470;1030,2;1020;63,5;;;;;;
776,95;1491;1030,2;1020;63,1;;;;;;
777,21;1491;1030,2;1009,8;62,7;;;;;;
777,48;1491;1030,2;1009,8;62,7;;;;;;
777,74;1218;1020;999,6;72,2;;;;;;
778,01;735;1009,8;1009,8;79,7;;;;;;
778,28;798;1009,8;999,6;78,9;;;;;;
778,54;924;1009,8;999,6;77,3;;;;;;
778,8;1176;1020;999,6;73,8;;;;;;
779,07;1806;1040,4;999,6;52,9;;;;;;
779,34;2310;1071;999,6;43,8;;;;;;
779,6;2289;1071;1020;44,2;;;;;;
779,87;2310;1071;1020;44,2;;;;;;
780,14;2310;1071;1020;44,2;;;;;;
780,4;2331;1071;1020;44,2;;;;;;
780,66;2331;1071;999,6;44,2;;;;;;
780,93;2331;1071;989,4;44,2;;;;;;
781,2;2331;1071;989,4;44,2;;;;;;
781,46;2352;1071;979,2;43,8;;;;;;
781,73;2352;1071;979,2;43,8;;;;;;
782;2352;1071;979,2;43,8;;;;;;
782,26;2352;1071;969;43,8;;;;;;
782,53;2331;1071;969;44,2;;;;;;
782,79;2331;1071;969;44,2;;;;;;
783,06;2289;1071;979,2;44,2;;;;;;
783,32;2247;1071;979,2;44,6;;;;;;
783,59;2184;1060,8;979,2;45,4;;;;;;
783,86;2121;1060,8;979,2;45,8;;;;;;
784,12;2079;1060,8;979,2;46,2;;;;;;
784,39;2016;1050,6;979,2;46,6;;;;;;
784,65;1974;1050,6;979,2;47,3;;;;;;
784,92;1974;1050,6;979,2;47,3;;;;;;
785,18;1953;1050,6;979,2;47,7;;;;;;
785,45;1932;1050,6;979,2;48,5;;;;;;
785,71;1911;1050,6;979,2;48,5;;;;;;
785,98;1890;1050,6;979,2;48,9;;;;;;
786,24;1869;1050,6;979,2;49,3;;;;;;
786,51;1848;1050,6;979,2;49,7;;;;;;
786,78;1848;1050,6;979,2;50,1;;;;;;
787,04;1827;1050,6;979,2;50,5;;;;;;
787,3;1806;1040,4;979,2;51,3;;;;;;
787,57;1827;1050,6;979,2;50,9;;;;;;
787,84;1764;1040,4;989,4;52,1;;;;;;
788,1;1806;1050,6;989,4;50,9;;;;;;
788,37;1785;1040,4;979,2;52,1;;;;;;
788,63;1785;1040,4;989,4;52,1;;;;;;
788,9;1785;1040,4;989,4;52,1;;;;;;
789,16;1764;1040,4;989,4;52,5;;;;;;
789,43;1743;1040,4;989,4;52,9;;;;;;
789,7;1596;1040,4;989,4;56,4;;;;;;
789,96;1029;1020;1009,8;75,4;;;;;;
790,22;756;1040,4;1020;79,7;;;;;;
790,49;882;1009,8;1020;77,7;;;;;;
790,76;861;1009,8;1020;78,1;;;;;;
791,03;840;1009,8;1020;78,1;;;;;;
791,29;840;1009,8;1020;78,1;;;;;;
791,56;966;1009,8;1020;76,5;;;;;;
791,82;1134;1020;1020;74,2;;;;;;
792,09;1386;1030,2;1009,8;67,9;;;;;;
792,35;1659;1040,4;989,4;55,6;;;;;;
792,61;1911;1050,6;989,4;48,9;;;;;;
792,88;1764;1040,4;1030,2;52,5;;;;;;
793,15;1701;1040,4;1030,2;54,4;;;;;;
793,41;1596;1040,4;1030,2;56,8;;;;;;
793,68;1533;1040,4;1030,2;60,4;;;;;;
793,95;1407;1030,2;1030,2;65,5;;;;;;
794,21;1008;1020;1030,2;75,8;;;;;;
794,48;756;1020;1040,4;79,7;;;;;;
794,75;798;1020;1030,2;78,9;;;;;;
795,01;819;1020;1030,2;78,5;;;;;;
795,28;840;1020;1030,2;78,5;;;;;;
795,54;819;1020;1030,2;78,5;;;;;;
795,81;819;1020;1030,2;78,5;;;;;;
796,08;840;1020;1030,2;78,5;;;;;;
796,34;840;1020;1020;78,5;;;;;;
796,61;861;1009,8;1020;78,1;;;;;;
796,88;840;1009,8;1009,8;78,1;;;;;;
797,14;840;1009,8;1009,8;78,1;;;;;;
797,4;840;1009,8;999,6;78,1;;;;;;
797,66;819;1009,8;999,6;78,5;;;;;;
797,93;798;1009,8;999,6;78,9;;;;;;
798,23;798;1009,8;999,6;78,9;;;;;;
798,46;777;1009,8;999,6;79,3;;;;;;
798,73;777;1009,8;999,6;79,3;;;;;;
799,01;777;1009,8;999,6;78,9;;;;;;
799,26;798;1009,8;989,4;78,9;;;;;;
799,52;777;1009,8;999,6;78,9;;;;;;
799,79;777;1009,8;989,4;78,9;;;;;;
800,05;798;1009,8;989,4;78,9;;;;;;
800,32;798;1009,8;989,4;78,9;;;;;;
800,58;798;1009,8;989,4;78,9;;;;;;
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Please run 2 control module maps and attach them here. One with the engine cold and another with the engine warm and at idle speed.
The parts you replaced are original VAG or 3rd party sourced/made?
MickB
France, Crolles
C?ID=437669
Parts are both from VW and other reseller (but a serious one and only great manufacturer). But each time the swap between old and new part confirmed that that was not the faulty one.
Just to be sure, you want log from Engine > mesure blocs > group 2?
DGMotors
C?ID=57532
I'm 100% sure that turbo is ok and no leak in the pipes, because:
- Turbo is brand new
This is not a reason to say the turbo is any good! I seen countless faulty new turbos (withy the same fault you describe!)
My last find is that the ECU never ask the solenoid to give 100% pressure from the turbo.
Example:
- Engine at 2200 rpm
- Throttle at 100%
- 5th gear
- Requested boost: 2200mbar
- Actual boost pressure: 1300mbar
- Solenoid duty cycle: 60%
So: why the ECU do not ask 100% to the solenoid?
The reason is on a working vehicle the duty cycle should be around 20%-30% by this point so the ECU has already trimmed up 100%
Here a know working T5 boost build up:
    Engine Speed    Boost Pressure    Boost Pressure    Charge Pressure
TIME    (G28)    (specified)    (actual)    Control Duty Cycle
STAMP     /min     mbar     mbar     %
67        861    1071    1091.4    80.5
67.46    882        1050.6    1091.4    80.5
67.93    819        1050.6    1091.4    80.5
68.4    1008    1152.6    1081.2    80.5
68.87    1008    1162.8    1111.8    80.1
69.34    1092    1183.2    1132.2    79.7
69.81    1197    1193.4    1162.8    78.9
70.28    1218    1193.4    1203.6    78.5
70.75    1344    1234.2    1244.4    76.9
71.22    1449    1264.8    1305.6    71
71.7    1701    1448.4    1397.4    59.6
72.17    1785    1448.4    1601.4    46.6
72.64    2205    1774.8    1876.8    33.9
73.11    2394    1693.2    2264.4    5.5
73.58    2184    1785    1550.4    47.7
74.05    2268    1754.4    1611.6    44.6
74.51    2310    1703.4    1662.6    41.8
74.98    2373    1662.6    1693.2    39.5
75.46    2184    1734    1703.4    45
75.93    2121    1519.8    1672.8    34.3
76.4    1743    1275    1428    52.1
76.87    1659    1173    1285.2    58.4
DGMotors
C?ID=57532
What let me say all the charging parts are ok: If I control the valve manually, by applying a 0-12V voltage on it, the charing pressure is good and everything works like a charm. As the valve is controlled by a simple PWM signal, you can replace the signal with an external power supply. Applying 6V mean a 50% PWM duty cycle, 12V mean a 100% PWM duty cycle.
I think you find this test is incorrect.
The solenoid is open or shut - so applying enough voltage to operate give 100% duty cycle (so i would guess 6v operates it and this is not 50% it 100% duty cycle) where as be open 50% and shut 50% as per PWM turning the power on/off is 50% duty cycle but appears 6v on multimeter.
also have you checked for blocked exhaust, stuck EGR valve ETC
MickB
France, Crolles
C?ID=437669
Actually I tried 3 different turbos:
- the original one, which reveals it was ok after disassembly but I broke 3 screws while disassembling
- the second one, witch was workbench tested by the reseller but I had an oil leak issue due to bad installation
- the third one, also workbench tested (report was provided with the turbo)
All the tree turbos lead to the same issue. So 1 turbo HS is possible, but 3 I don’t think so.
I do not agree, in this case the PWM is the electronic way to modulate the input voltage. And I’m 100% positive that you can control the solenoid this way. I tested it while driving with complete monitoring (VCDS, oscilloscope, …) and I can precisely control the boost pressure this way.
I do.
EGR cleaned and tested both manually and with VCDS.
Exhaust: I drove with exhaust disconnected, and double-check that with a camera inside the pipe.
DGMotors
C?ID=57532
Please provide a log of groups 003 and 011 under driving full throttle in 2/3rd gear from 1000RPM to close to red line as you can get
Sebastian
Magdeburg, Germany
HN0-nnnnnn
As a baseline that looks OK. A next level would be logging the sensor data when it changes from cold to warm, to see if there are any jumps or irregularities in the values. Those irregularities can easily be spotted when loading the log into VCScope afterwards.
Similar to the sensor data above, you may want to load the log into VCScope afterwards, to check not just for proper max values but also for jumps/irregularities.
An unrelated topic, logging injector status codes (MVB 018+019) are always worth a look - especially when there are no fault codes stored. You may see a 064/128 in a log where it doesn't belong, which otherwise would be missed when looking at those values live while driving.
Zenerdiode
Newcastle, England
C?ID=24330
DGMotors Toby is correct. The solenoid is a binary device and is open or closed. Its rated voltage is 12VDC; that doesn’t mean to say a voltage of, say, 4VDC may be able to pick it. But the air vane certainly won’t hover half open if you apply half the coil’s rated voltage…
Also when the solenoid is open, it allows pressure to be applied to the end component; there is very little, if any, flow through it. That’s why modulating its duty cycle modulates the pressure applied to the component due to the elasticity of air.
MickB
France, Crolles
C?ID=437669
Done, 2 tries for each.
Wednesday,21,July,2021,18:25:30:05101-VCID:55F78BD0C91068738C5-513C,VCDS Version: Release 21.3.0 (x64),Data version: 20210226 DS325.0
070 906 016 BF,,R5 2.5L EDC G000SG  7000,
,Group A:,'003,,,,Group B:,'011,,,,Group C:, Not Running
,,RPM,Mass Air / Rev.,Mass Air / Rev.,Duty Cycle,,RPM,Absolute Pres.,Absolute Pres.,Duty Cycle,,,,,
,TIME,,,,,TIME,,,,,TIME,,,,
Marker,STAMP, /min, mg/str, mg/str, %,STAMP, /min, mbar, mbar, %,STAMP,,,,
2ng gear - 1st try
1,8.95,1197,360.0,360.0,43.4,8.69,1176,1142.4,1009.8,73.4,,,,,
,9.48,1281,820.0,460.0,95.5,9.22,1218,1275.0,1020.0,76.5,,,,,
,10.02,1365,865.0,500.0,95.5,9.75,1302,1795.2,1050.6,72.2,,,,,
,10.55,1512,930.0,535.0,95.5,10.28,1428,1958.4,1122.0,68.3,,,,,
,11.08,1680,980.0,595.0,95.5,10.81,1596,2101.2,1203.6,63.1,,,,,
,11.61,1848,980.0,640.0,95.5,11.34,1785,2203.2,1275.0,58.8,,,,,
,12.14,2079,980.0,685.0,95.5,11.87,1995,2284.8,1346.4,55.6,,,,,
,12.67,2310,980.0,740.0,95.5,12.40,2184,2305.2,1397.4,53.3,,,,,
,13.20,2562,980.0,810.0,95.5,12.93,2436,2325.6,1458.6,50.9,,,,,
,13.73,2877,980.0,940.0,95.5,13.46,2709,2346.0,1601.4,45.8,,,,,
,14.26,3213,980.0,985.0,95.5,13.99,3024,2376.6,1846.2,44.6,,,,,
,14.79,3549,980.0,1000.0,95.5,14.52,3360,2397.0,1978.8,45.4,,,,,
,15.32,3843,980.0,995.0,95.5,15.05,3675,2376.6,2060.4,46.2,,,,,
,15.85,4095,980.0,945.0,95.5,15.58,3969,2305.2,2070.6,46.6,,,,,
,16.38,4305,980.0,885.0,95.5,16.11,4221,2213.4,2019.6,45.8,,,,,
,16.91,4452,980.0,825.0,95.5,16.64,4389,1958.4,1938.0,45.8,,,,,
,17.44,4578,980.0,750.0,95.5,17.17,4536,1734.0,1815.6,41.4,,,,,
,17.97,4662,980.0,700.0,95.5,17.71,4620,1591.2,1642.2,43.0,,,,,
,18.50,4662,980.0,540.0,95.5,18.24,4641,1142.4,1560.6,20.1,,,,,
,19.03,4536,980.0,470.0,95.5,18.76,4620,1050.6,1193.4,39.1,,,,,
2nd gear - 1st try
3,41.84,1386,875.0,545.0,95.5,41.57,1344,1734.0,1173.0,70.2,,,,,
,42.37,1428,895.0,550.0,95.5,42.10,1407,1907.4,1224.0,68.6,,,,,
,42.90,1470,920.0,610.0,95.5,42.63,1470,1989.0,1275.0,65.1,,,,,
,43.43,1554,950.0,605.0,95.5,43.16,1512,2050.2,1315.8,63.5,,,,,
,43.96,1617,980.0,620.0,95.5,43.69,1596,2091.0,1356.6,61.2,,,,,
,44.49,1701,980.0,630.0,95.5,44.22,1659,2142.0,1377.0,60.8,,,,,
,45.02,1785,980.0,665.0,95.5,44.76,1743,2193.0,1387.2,58.4,,,,,
,45.55,1890,980.0,645.0,95.5,45.29,1827,2233.8,1397.4,57.2,,,,,
,46.08,1974,980.0,670.0,95.5,45.81,1932,2264.4,1397.4,56.4,,,,,
,46.61,2058,980.0,670.0,95.5,46.35,2016,2295.0,1407.6,54.8,,,,,
,47.14,2163,980.0,700.0,95.5,46.87,2100,2305.2,1428.0,54.1,,,,,
,47.67,2268,980.0,745.0,95.5,47.41,2205,2305.2,1479.0,52.9,,,,,
,48.20,2394,980.0,840.0,95.5,47.94,2331,2315.4,1560.6,51.3,,,,,
,48.73,2541,980.0,905.0,95.5,48.47,2457,2325.6,1693.2,46.2,,,,,
,49.26,2688,980.0,945.0,95.5,49.00,2604,2346.0,1815.6,46.2,,,,,
,49.79,2835,980.0,975.0,95.5,49.53,2772,2356.2,1887.0,47.7,,,,,
,50.32,2982,980.0,1015.0,95.5,50.06,2898,2366.4,1978.8,47.3,,,,,
,50.85,3129,980.0,1020.0,95.5,50.59,3045,2376.6,2050.2,47.3,,,,,
,51.38,3276,980.0,1045.0,95.5,51.12,3213,2386.8,2101.2,47.3,,,,,
,51.91,3423,980.0,1025.0,95.5,51.65,3360,2397.0,2152.2,46.6,,,,,
,52.44,3570,980.0,1045.0,95.5,52.18,3507,2407.2,2182.8,46.9,,,,,
,52.97,3696,980.0,1020.0,95.5,52.71,3633,2386.8,2193.0,46.6,,,,,
,53.51,3843,980.0,990.0,95.5,53.24,3759,2356.2,2182.8,46.9,,,,,
,54.04,3948,980.0,990.0,95.5,53.77,3885,2325.6,2162.4,46.9,,,,,
,54.57,4053,980.0,960.0,95.5,54.30,3990,2305.2,2142.0,46.9,,,,,
,55.10,4137,980.0,920.0,95.5,54.83,4095,2264.4,2111.4,46.2,,,,,
,55.63,4242,980.0,905.0,95.5,55.36,4200,2223.6,2070.6,46.9,,,,,
,56.16,4326,980.0,870.0,95.5,55.89,4284,2121.6,2019.6,45.4,,,,,
,56.69,4410,980.0,840.0,95.5,56.42,4368,1968.6,1968.6,46.6,,,,,
,57.22,4452,980.0,750.0,95.5,56.95,4431,1723.8,1887.0,37.9,,,,,
,57.75,4494,980.0,680.0,95.5,57.49,4473,1581.0,1672.8,40.6,,,,,
,58.28,4515,980.0,630.0,95.5,58.02,4494,1479.0,1540.2,45.8,,,,,
,58.81,4494,980.0,495.0,95.5,58.54,4515,1060.8,1428.0,5.9,,,,,
,59.34,4452,980.0,375.0,95.5,59.07,4473,1060.8,1101.6,37.5,,,,,
,59.87,4410,980.0,375.0,95.5,59.60,4431,1071.0,1009.8,44.6,,,,,
1st gear - 2nd try
5,138.90,1155,515.0,480.0,95.5,138.64,1092,1428.0,1040.4,75.0,,,,,
,139.43,1302,845.0,500.0,95.5,139.16,1239,1693.2,1081.2,74.2,,,,,
,139.96,1491,925.0,585.0,95.5,139.69,1407,1917.6,1152.6,68.6,,,,,
,140.49,1701,980.0,655.0,95.5,140.23,1596,2101.2,1254.6,61.9,,,,,
,141.02,1932,980.0,745.0,95.5,140.75,1827,2223.6,1387.2,57.2,,,,,
,141.55,2268,980.0,855.0,95.5,141.29,2100,2305.2,1550.4,52.9,,,,,
,142.08,2646,980.0,945.0,95.5,141.82,2436,2325.6,1723.8,47.3,,,,,
,142.61,2961,980.0,1040.0,95.5,142.35,2814,2356.2,1887.0,46.9,,,,,
,143.14,3360,980.0,1045.0,95.5,142.88,3171,2386.8,2029.8,46.9,,,,,
,143.67,3717,980.0,1030.0,95.5,143.41,3549,2407.2,2111.4,46.6,,,,,
,144.23,4032,980.0,975.0,95.5,143.94,3885,2325.6,2131.8,46.2,,,,,
,144.75,4284,980.0,905.0,95.5,144.48,4158,2233.8,2091.0,46.6,,,,,
,145.28,4473,980.0,820.0,95.5,145.01,4389,1927.8,1978.8,42.6,,,,,
,145.81,4599,980.0,735.0,95.5,145.54,4557,1693.2,1815.6,41.0,,,,,
,146.34,4662,980.0,660.0,95.5,146.08,4662,1550.4,1621.8,41.4,,,,,
2nd gear - 2nd try
7,154.83,1050,205.0,200.0,25.6,154.56,1092,1020.0,1009.8,74.6,,,,,
,155.35,1029,645.0,415.0,95.5,155.09,1113,1458.6,989.4,74.6,,,,,
,155.89,1050,650.0,420.0,95.5,155.62,1029,1417.8,1020.0,75.4,,,,,
,156.42,1050,665.0,430.0,95.5,156.15,1050,1428.0,1050.6,75.4,,,,,
,156.95,1071,680.0,450.0,95.5,156.68,1071,1438.2,1071.0,75.0,,,,,
,157.48,1092,700.0,450.0,95.5,157.21,1071,1448.4,1101.6,75.0,,,,,
,158.01,1113,705.0,460.0,95.5,157.74,1092,1468.8,1111.8,74.6,,,,,
,158.54,1134,725.0,470.0,95.5,158.27,1113,1489.2,1132.2,74.6,,,,,
,159.07,1155,740.0,480.0,95.5,158.80,1134,1519.8,1142.4,74.2,,,,,
,159.60,1176,755.0,480.0,95.5,159.33,1155,1550.4,1152.6,73.8,,,,,
,160.13,1197,790.0,485.0,95.5,159.86,1176,1581.0,1162.8,73.8,,,,,
,160.66,1218,805.0,470.0,95.5,160.39,1218,1652.4,1183.2,74.6,,,,,
,161.19,1239,815.0,505.0,95.5,160.92,1218,1693.2,1193.4,73.0,,,,,
,161.72,1281,835.0,520.0,95.5,161.46,1260,1723.8,1203.6,73.0,,,,,
,162.25,1302,845.0,495.0,95.5,161.99,1281,1754.4,1224.0,71.8,,,,,
,162.78,1344,855.0,510.0,95.5,162.52,1323,1815.6,1244.4,70.2,,,,,
,163.31,1365,880.0,545.0,95.5,163.05,1365,1856.4,1264.8,69.8,,,,,
,163.84,1407,900.0,580.0,95.5,163.58,1386,1907.4,1285.2,67.9,,,,,
,164.37,1449,915.0,615.0,95.5,164.11,1428,1958.4,1315.8,66.3,,,,,
,164.90,1512,935.0,625.0,95.5,164.64,1491,2019.6,1366.8,62.7,,,,,
,165.43,1575,965.0,630.0,95.5,165.17,1533,2060.4,1397.4,61.9,,,,,
,165.96,1638,980.0,645.0,95.5,165.70,1596,2101.2,1428.0,60.4,,,,,
,166.49,1701,980.0,685.0,95.5,166.23,1659,2142.0,1458.6,59.6,,,,,
,167.02,1764,980.0,695.0,95.5,166.76,1722,2182.8,1479.0,58.4,,,,,
,167.56,1848,980.0,730.0,95.5,167.29,1806,2223.6,1509.6,57.6,,,,,
,168.08,1911,980.0,695.0,95.5,167.82,1869,2244.0,1530.0,56.4,,,,,
,168.61,1995,980.0,675.0,95.5,168.35,1953,2274.6,1519.8,55.6,,,,,
,169.15,2079,980.0,710.0,95.5,168.88,2037,2295.0,1530.0,54.8,,,,,
,169.68,2142,980.0,745.0,95.5,169.41,2121,2305.2,1550.4,54.1,,,,,
,170.21,2247,980.0,785.0,95.5,169.94,2184,2305.2,1601.4,52.9,,,,,
,170.74,2331,980.0,840.0,95.5,170.47,2268,2315.4,1683.0,51.7,,,,,
,171.27,2436,980.0,910.0,95.5,171.00,2394,2325.6,1774.8,49.3,,,,,
,171.80,2541,980.0,950.0,95.5,171.53,2499,2335.8,1856.4,48.9,,,,,
,172.33,2667,980.0,990.0,95.5,172.06,2604,2346.0,1938.0,49.3,,,,,
,172.86,2793,980.0,1015.0,95.5,172.59,2730,2346.0,2019.6,48.9,,,,,
,173.39,2919,980.0,1020.0,95.5,173.12,2856,2356.2,2080.8,48.5,,,,,
,173.92,3045,980.0,1025.0,95.5,173.65,2982,2366.4,2121.6,47.7,,,,,
,174.45,3171,980.0,1040.0,95.5,174.19,3108,2376.6,2152.2,47.3,,,,,
,174.98,3276,980.0,1050.0,95.5,174.72,3234,2386.8,2193.0,46.9,,,,,
,175.51,3402,980.0,1040.0,95.5,175.25,3339,2397.0,2223.6,46.9,,,,,
,176.04,3528,980.0,1040.0,95.5,175.77,3465,2407.2,2233.8,46.9,,,,,
,176.57,3633,980.0,1015.0,95.5,176.31,3591,2397.0,2254.2,46.9,,,,,
,177.10,3759,980.0,1005.0,95.5,176.84,3696,2376.6,2244.0,46.9,,,,,
,177.63,3864,980.0,1005.0,95.5,177.37,3801,2346.0,2244.0,46.9,,,,,
,178.16,3948,980.0,975.0,95.5,177.90,3906,2325.6,2213.4,46.6,,,,,
,178.69,4032,980.0,965.0,95.5,178.43,3990,2295.0,2193.0,46.9,,,,,
,179.23,4116,980.0,945.0,95.5,178.96,4074,2264.4,2172.6,46.9,,,,,
,179.75,4179,980.0,920.0,95.5,179.49,4158,2244.0,2131.8,46.9,,,,,
,180.29,4263,980.0,890.0,95.5,180.02,4221,2203.2,2101.2,46.9,,,,,
,180.82,4326,980.0,865.0,95.5,180.55,4284,2121.6,2050.2,46.9,,,,,
,181.35,4368,980.0,850.0,95.5,181.08,4347,2009.4,1999.2,46.6,,,,,
,181.88,4410,980.0,820.0,95.5,181.61,4389,1927.8,1978.8,46.6,,,,,
,182.41,4431,980.0,765.0,95.5,182.14,4431,1754.4,1887.0,38.3,,,,,
,182.94,4473,980.0,705.0,95.5,182.67,4452,1693.2,1744.2,46.9,,,,,
,183.47,4473,980.0,660.0,95.5,183.20,4473,1591.2,1632.0,44.2,,,,,
MickB
France, Crolles
C?ID=437669
Maybe, maybe not… But one thing sure is that I was able to precisely control the boost pressure this way. (even if it's not conventional, I agree!)
For me the conclusion of this precise test is that the turbo is mechanically capable of giving a boost pressure as high as the ECU is asking.
Before that test I tried to control the turbo with a vacuum hand-pump, the result was the same.
With this result, I think that the turbo is ok, and also the boost pipes, the vacuum pipes, the vacuum pump, the boost solenoid, the exhaust.
Or I'm really missing something?!
