The fault I want to diagnose and repair relates to the air suspension. A light comes on on the dash, warning me there is an issue with the system. The thing is, the air suspension seems to be working just fine, it rises up and down with no problem, even with this fault light coming on. And the fault seems to happen when I go over a bump. I can drive 40 miles on a smooth road and no fault light comes on, then I hit a pothole and the light comes on.
According to repeated VAG-COM tests, the issue is the Left Front Body Acceleration Sensor (G341). Each time the warning light comes on I use VagCOm to run a test then I reset the DTC codes. Next time I check the fault it's the same thing begin reported - Left Front Body Acceleration Sensor (G341)
How/where do I run a test on the Left Front Body Acceleration Sensor (G341)? I can see within the Level COntrol system there are tests I can run, but they are for things like the height of each corner, the pressure valves etc, but I see nothing for Left Front Body Acceleration Sensor (G341).
Also, would you suggest just buying a new Left Front Body Acceleration Sensor (G341) and swapping it out? According to Erwin it looks like a fairly easy swap, remove the front wheel liner then easy access to the sensor.
Here's a test I ran earlier this week showing the fault:
Monday,12,July,2021,16:11:18:61536
VCDS Version: 21.3.0.0 (x64)
VIN: WAUZZZ4L5CD008563
Mileage: 197430km-122677mi Repair Order: LEVEL FAULT
Chassis Type: 4L-AU56 (4F0)
Scan: 01 02 03 05 08 09 15 16 17 18 19 34 3D 42 46 4F 52 55 56 5F
62 69 6C 6D 6F 72 76
VIN: WAUZZZ4L5CD008563 Mileage: 197430km-122677miles
3D-Special Function -- Status: OK 0000
Address 01: Engine (J623-CRCA) Labels:. 059-907-401-V2.clb
Part No SW: 4L2 910 401 B HW: 4L0 907 401 C
Component: 3.0TDI EDC17 H37 0001
Revision: 53H37--- Serial number:
Coding: 2A2A4012A52701020000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0114L2910401B 001001
ROD: EV_ECM30TDI0114L1910401H.rod
VCID: 234460242A259893FE-8076
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 AL HW: 0C8 927 750 AL
Component: AL1000 AISIN 001 1977
Coding: 001578
Shop #: WSC 41538 001 1048576
ASAM Dataset: EV_TCMAL991031 001001
ROD: EV_TCMAL991031_001_AU56.rod
VCID: 76E26970C9375D3BE9-8022
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 2200673
Shop #: WSC 12345 123 12345
VCID: 3466937857CB0F2B17-8060
Part No SW: 4F0 910 852 B HW: 4F0 905 852 F
Component: FBSAUDIC6 ELV H05 0130
Revision: 00H05000 Serial number: 10603401872089
Coding: 0000211
Shop #: WSC 51245 002 1048576
VCID: 25407E3CEC1166A390-8070
Subsystem 1 - Part No: 4F0 910 132 E
Component: FBSAUDIC6 EZS H03 0020
Component: FBSAUDIC6 IDG H01 0054
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AH
Component: KLIMA 4 ZONEN H15 0070
Revision: 00---026 Serial number: 00000030204553
Coding: 01009416
VCID: 25407E3C2C1166A390-8070
Fault Status: 00101110
Fault Frequency: 15
Reset counter: 61
Mileage: 196958 km
Date: 2021.06.30
Time: 13:01:02
Temperature: 26.0°C
Part No SW: 4F0 910 279 AH HW: 4F0 907 279 D
Component: ILM Fahrer H31 0400
Coding: 0033121
VCID: 6FEC5C147E6D6CF32A-803A
Subsystem 1 - Part No: 4L2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H13 0110
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 D HW: 4L0 959 655 C
Component: 71 AIRBAG AUDI8RH43 0230
Revision: 04H43000 Serial number: 00399D085YHC
Coding: 0014129
VCID: 2E528110B9E725FB61-807A
Subsystem 1 - Serial number: 6332QSME5B4F4D50W
Subsystem 2 - Serial number: 6342QSME645C3854N
Subsystem 3 - Serial number: 6352QSME3A5A2D7E+
Subsystem 4 - Serial number: 6362QSME3C5A0A7C.
Subsystem 5 - Serial number: 63734SME4F5A456CJ
Subsystem 6 - Serial number: 63834SME5C4F00487
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H07000 Serial number: 90026111600276
Coding: 0102142
VCID: 285E77089B037BCBAB-807C
Component: E0221 H03 0030
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 984 P HW: 4L0 920 984 P
Component: KOMBIINSTR. H22 0410
Revision: 00000000 Serial number: JX802V18C
Coding: 3356630400012600010404
VCID: 408ECFA8D373A38B83-8014
Address 18: Aux. Heat Labels: 4L0-910-105.lbl
Part No SW: 4L0 910 105 HW: 4L0 815 071 G
Component: Heizgeraet H09 0140
Revision: 0000000C Serial number: 00000009021078
Coding: 0000101
VCID: 60CE2F28B3B3C38BA3-8034
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 P HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0047
Revision: LB200032 Serial number: 3200L11719029C
Coding: 00CF07
VCID: 3C76BB58BF9BC76BDF-8068
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 00000000002790984579
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Serial number: 11216000003021200181
Address 34: Level Control Labels: 4L0-910-553.lbl
Part No SW: 4L0 910 553 H HW: 4L0 907 553 E
Component: LUFTFDR.-CDC H04 7870
Revision: --H04001 Serial number: 15.1528-0150.2
Coding: 0015520
VCID: 2F6C9C14BEED2CF36A-807A
00139 - Left Front Body Acceleration Sensor (G341)
Fault Frequency: 19
Reset counter: 61
Mileage: 196961 km
Date: 2021.07.02
Time: 11:57:06
Error Code: 194
01577 - Turn-Off due to Over-Temp
Fault Status: 00100001
Reset counter: 61
Mileage: 196962 km
Date: 2021.07.02
Time: 11:57:19
Error Code: 68
Address 3D: Special Function Labels: 8K0-907-440.clb
Part No SW: 8K0 907 440 HW: 8K0 907 440
Component: STS H04 0040
Revision: S0H04000 Serial number: 00000000045860
Coding: 01010101000000000000000202
VCID: 6BD448044A7590D306-803E
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000011339294
Coding: 011F06205061440004
VCID: 489ED788FB439BCB4B-801C
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 H HW: 4L0 907 289 H
Component: Komfortgeraet H10 0110
Revision: 0110 --- Serial number: 01549431100000
Coding: 4071675
VCID: 3560AE7C5CB1162320-8060
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Component: IRUE No Answer
Reset counter: 21
Mileage: 119751 km
Date: 2017.11.20
Time: 16:02:12
01134 - Alarm Horn (H12)
Fault Status: 01101000
Fault Frequency: 135
Reset counter: 77
Mileage: 119751 km
Date: 2017.11.20
Time: 16:16:46
Reset counter: 77
Mileage: 119751 km
Date: 2017.11.20
Time: 16:16:46
Part No SW: 4F0 910 280 HW: 4F0 907 280 E
Component: ILM Beifahrer H14 0100
Revision: Serial number: 00000000236929
Coding: 0011101
VCID: 5EB211D089C7F57B91-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000011505224
Coding: 011F06205C61440004
VCID: 479CD4B4F65D94B342-8012
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H02 0010
Coding: 0000008
VCID: 3F8CCC546E8DDC73FA-806A
Part No SW: 4G0 035 056 J HW: 4G0 035 056
Component: Radio U STD H52 0133
Revision: AB001007 Serial number: 051H00B7529478
Coding: 010003020100000000
VCID: 285E77085B037BCBAB-807C
Part No SW: 4L2 035 670 N HW: 4L2 035 670
Component: H-BNT-EU H42 1036
Revision: -------- Serial number: 075GU0B7501506
Coding: 180101060004D3EF01000355EF632003040000000100000000
Shop #: WSC 00481 210 83561
VCID: 3560AE7C9CB1162320-8060
Subsystem 1 - Part No: 8R0 060 884 HF
Component: EUR 2020/2021 3101
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Serial number: A130GZ0BS000801
Subsystem 3 - Part No SW: 4L0 919 614 B HW: 4L0 919 614 B
Component: E0380 Bedient H01 0060
Serial number: 00000001889204
Subsystem 4 - Part No: 8R0 060 961 B
Component: CD-Database 3371
01043 - Control Module; Incorrect Software Version
Reset counter: 21
Mileage: 197369 km
Date: 2021.07.12
Time: 13:01:05
Bin. Bits: 00000000 00000000
Bin. Bits: 00000000 00000010
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000011592807
Coding: 010E06204061230004
VCID: 4682D9B0F1578DBBB9-8012
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H09 0100
Revision: 2A001001 Serial number: 00000159164934
Coding: 0100000000000000
VCID: 31689A6C68D93A037C-8064
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H05--- Serial number: 525PA8-J18437V
Coding: 1020201
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Component: ValeoHeckdeckel H56 0500
Revision: --H56001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CD64B184F7B97EB0F-8038
Subsystem 3 - Serial number: RD08.08.11--H56001001B0057ÿ
Subsystem 4 - Serial number: 1B0057ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H07 0080
Revision: AAH07080 Serial number: 118331833-----
Coding: 0003587
VCID: 2642793091176DBB99-8072
Component: J_245_EE16_SKB10H11 0220
Subsystem 2 - Part No: 4L0 910 591 A
Component: J_394_EE16_SKB10H11 0220
Subsystem 3 - Part No: 4L0 910 591 A
Component: J_392_EE16_SKB10H11 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000011593325
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4L0 910 283 E HW: 4L0 919 283 E
Component: Parkhilfe 8-Kan H03 0100
Revision: 00H03000 Serial number: 37331120707657
Coding: 0231046
VCID: 2C568B188FFB57EB4F-8078
End-------------------------(Elapsed Time: 03:41)--------------------------
