Mk6 golf, Code new ABS Without Old Coding (MK60EC1)
shams
Auckland, NZ
C?ID=380692
Hi guys.
First time posting a hard job ;)
I have a car that had its abs ripped out.
Supposedly from vw they say the original unit was ABS PUMP 1K0614517BK BEF from the vin number in his system. We fitted a pump with the last three letters off, 1K0614517BK is the same though.
Below is the scan data, was hoping someone could help with new coding values
shams
Auckland, NZ
C?ID=380692
Whoops -
VIN: WVWZZZ1KZAM612083   License Plate:
Chassis Type: 1K-VW36 (1K0)
VIN: WVWZZZ1KZAM612083   Mileage: 110530km-68680miles
Address 01: Engine (CAX)       Labels: 03C-906-016-CAX.clb
   Part No SW: 03C 997 016     HW: 03C 906 016
   Component: MED17.5.5           7589
   Revision: LCH02---    Serial number:
   Coding: 0000077
   Shop #: WSC 62320 981 65327
   VCID: 6695B45894640E7B15F-8032
13 Faults Found:
               P0300 - 000 -  - Intermittent
                    Mileage: 90771 km
                    Date: 2014.06.16
                    Time: 21:20:19
                    RPM: 661 /min
                    Load: 18.0 %
                    Temperature: 87.0°C
                    Temperature: 25.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.843 V
000772 - Cylinder 4
               P0304 - 000 - Misfire Detected - Intermittent - MIL ON
                    Fault Status: 10100000
                    Mileage: 93365 km
                    Date: 2014.08.28
                    Time: 04:46:30
                    RPM: 3162 /min
                    Load: 100.0 %
                    Speed: 36.0 km/h
                    Temperature: 88.0°C
                    Temperature: 36.0°C
                    Voltage: 13.716 V
000113 - Sensor for Ambient Air Temperature (G17)
               P0071 - 000 - Implausible Signal - Intermittent
                    Mileage: 96477 km
                    Date: 2014.11.27
                    Time: 03:36:34
                    RPM: 770 /min
                    Load: 21.2 %
                    Speed: 8.0 km/h
                    Temperature: 74.0°C
                    Temperature: 31.0°C
                    Voltage: 13.716 V
004874 - Cylinder Disabling
               P130A - 000 -  - Intermittent
                    Fault Frequency: 14
                    Mileage: 110199 km
                    Date: 2015.10.21
                    Time: 00:00:44
                    RPM: 3292 /min
                    Load: 100.0 %
                    Speed: 40.0 km/h
                    Temperature: 88.0°C
                    Temperature: 28.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.843 V
001089 - EVAP Emission Control Sys
               P0441 - 000 - Incorrect Flow - Intermittent
                    Mileage: 109521 km
                    Date: 2015.10.14
                    Time: 19:04:25
                    RPM: 695 /min
                    Load: 23.1 %
                    Temperature: 90.0°C
                    Temperature: 34.0°C
                    Voltage: 13.843 V
000771 - Cylinder 3
               P0303 - 000 - Misfire Detected - Intermittent
                    Mileage: 110200 km
                    Date: 2015.10.21
                    Time: 00:01:47
                    RPM: 2177 /min
                    Load: 82.7 %
                    Speed: 26.0 km/h
                    Temperature: 88.0°C
                    Temperature: 29.0°C
                    Voltage: 13.970 V
001674 - ECM Power Relay Load Circuit
               P068A - 000 - Opens Too Early - Intermittent
                    Temperature: 32.0°C
                    Temperature: 26.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
001378 - System Voltage
               P0562 - 000 - Too Low - Intermittent
                    Mileage: 110462 km
                    Date: 2015.11.29
                    Time: 10:49:32
                    Temperature: 9.0°C
                    Temperature: 14.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 8.382 V
006418 - Pressure Sensor for Brake Boost (G294)
               P1912 - 000 - Short to Plus
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 20.0°C
                    Temperature: 23.0°C
                    Voltage: 12.319 V
049441 - No Communication with ABS Brake Control Module
               U0121 - 000 -  - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 20.0°C
                    Temperature: 23.0°C
                    Voltage: 12.319 V
005161 - Circuit for Brake Vacuum Pump
               P1429 - 000 - Open Circuit
                    Mileage: 110462 km
                    Date: 2015.11.26
                    Time: 00:00:31
                    RPM: 352 /min
                    Load: 51.4 %
                    Temperature: 20.0°C
                    Temperature: 24.0°C
                    Voltage: 10.414 V
001152 - Coolant Fan Control Circuit 1
               P0480 - 000 - Electrical Malfunction - Intermittent
                    Fault Frequency: 12
                    Temperature: 18.0°C
                    Temperature: 21.0°C
                    Voltage: 0.000 V
053285 - Please Check Fault Codes in Control Module for HVAC (J301)
               U1025 - 000 -  - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 18.0°C
                    Temperature: 21.0°C
                    Voltage: 13.589 V
   Part No SW: 0AM 300 048 L    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 2669
   Revision: 00043014    Serial number: CU501309225868
   Shop #: WSC 60242 000 1048576
   VCID: 392F2F24B55A518388D-806C
   Part No SW: 1K0 907 379 AP    HW: 1K0 907 379 AP
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
Coding: 000000000000000000000000000000000000
   Shop #: WSC 00078 210 01865
   VCID: 005982C09A00C04B8F3-8054
                    Reset counter: 150
                    Mileage: 110535 km
                    Date: 2015.12.04
                    Time: 00:19:51
                    Count: 16391
                    Count: 12800
                    Count: 195
                    Count: 49152
                    Count: 1024
01486 - System Function Test Activated
                    Reset counter: 150
                    Mileage: 110535 km
                    Date: 2015.12.04
                    Time: 00:19:51
                    Count: 16391
                    Count: 12800
                    Count: 320
                    Count: 49152
                    Count: 1024
                    Fault Status: 01100101
                    Reset counter: 150
                    Mileage: 110535 km
                    Date: 2015.12.04
                    Time: 00:19:51
                    Count: 16391
                    Count: 12800
                    Count: 279
                    Count: 49152
                    Count: 1024
                    Reset counter: 150
                    Mileage: 110535 km
                    Date: 2015.12.04
                    Time: 00:19:51
                    Count: 16391
                    Count: 12800
                    Count: 295
                    Count: 49152
                    Count: 1024
                    Reset counter: 150
                    Mileage: 110535 km
                    Date: 2015.12.04
                    Time: 00:19:51
                    Count: 16391
                    Count: 12800
                    Count: 270
                    Count: 49152
                    Count: 1024
00150 - Plausibility Brake Booster System
                    Reset counter: 150
                    Mileage: 110535 km
                    Date: 2015.12.04
                    Time: 00:19:52
                    Count: 16391
                    Count: 12800
                    Count: 398
                    Count: 49152
                    Count: 1024
   Part No SW: 3C8 907 336 H    HW: 3C8 907 336 H
   Component: Climatic      H13 0203
   Revision: 00006001
   Coding: 0000000000
   Shop #: WSC 00066 000 00148
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 323D180864ACA2DB497-8066
Address 09: Cent. Elect.
   Part No SW: 5K0 959 655 A    HW: 5K0 959 655 A
   Component: AirbagVW10G   033 0604
   Serial number: 003C3D07D0MU
   Coding: 00003236
   Shop #: WSC 00066 000 00000
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 38292A2082D0488B773-806C
   Subsystem 1 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 12660048ZZZZZZZZZZZZ
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 70673349ZZZZZZZZZZZZ
   Serial number: 5D74171DZZZZZZZZZZZZ
   Serial number: 5808151DZZZZZZZZZZZZ
   Part No SW: 1K0 953 549 CP    HW: 1K0 953 549 CP
   Component: J0527           053 0111
   Coding: 0001004
   VCID: 025D88C8980CD25B997-8056
   Part No SW: 5K0 920 860 F    HW: 5K0 920 860 F
   Component: KOMBI         H08 0020
   Revision: V0008011    Serial number:
   Coding: 570B00
   ASAM Dataset: EV_KombiUDSMM9RM10 A04010
ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
   VCID: 2F3B117C779E8F33269-807A
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H07 0081
   Revision:   H07 01    Serial number: 140709F1000014
   Coding: ED807F06000202002003
                    Reset counter: 150
                    Mileage: 110535 km
                    Date: 2015.12.04
                    Time: 00:19:52
   Component: IMMO          H08 0020
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01010
   Part No SW: 1K0 959 701 AE    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1520
   Revision: 71009005    Serial number: 00000520998812
   Coding: 0004790
   VCID: 71BFD704ADAAD9C370D-8024
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 69     2901
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 2F3B117C7B1E8F33269-807A
                    Fault Status: 11100101
                    Mileage: 110535 km
                    Date: 2015.12.04
                    Time: 00:19:49
                    Battery Volts: 13.8 V
                        DU
                    Temperature: 32.0°C
                    Count: 3
                    Steering Angle: 0.00°
                        SteerAng n.Init
Address 46: Central Conv.
   Part No SW: 1K0 959 702 AE    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1526
   Revision: 71009005    Serial number: 00000884998728
   Coding: 0005046
   VCID: 72BDD808A8ACE2DB897-8026
Address 56: Radio
   Part No SW: 1K0 959 703 AG    HW: 1K0 959 795 R
   Component: J388   TUER-SG HL   1401
   Revision: 11006001    Serial number: 00000004200073
   Coding: 0000144
   VCID: 75B7E314D9C2F5E3AC5-8020
   Part No SW: 1K0 959 704 AG    HW: 1K0 959 794 R
   Component: J389   TUER-SG HR   1401
   Revision: 11006001    Serial number: 00000004203697
   Coding: 0000144
   VCID: 76B5E418C4C4FEFBA5F-8022
End----------(Elapsed Time: 01:08, VBatt start/end: 13.8V/13.9V)-----------
I had to dig deep on this one but I'm reasonably confident the factory condition 03-ABS coding was:
133B400D112300FCC80B02EC881C00803100
The replacement steps on this page apply:
Feedback would be highly appreciated.
PR-Codes:
Vehicle Identification No. WVWZZZ1KZAM612083
Model golf estate
GOLF
Date of production 07.09.2009
Year 2010
Sales type AJ52G5
Engine Code CAXA
Transmission Code LWZ
G1C 7-speed automatic transmission
L0R Right-hand drive
B29 Type approval country Japan
0YG Weight range 7 installation control only, no requirement forecast
1N3 Speed-related variable steering assist (Servotronic)
2UA Standard design
1AS Electronic stability control (ESC)
1ZP Disc brakes in front (Geomet D)
1KE Disc brakes in rear
7L3 Without start-stop system without regenerative braking
UG1 Hill start assist
7K0 Without tyre pressure monitor
shams
Auckland, NZ
C?ID=380692
Hey Dana
Thank you so much. The code was accepted. Still won't go through to last step on process though. I think there is a wiring issue as this car has had the abs unit including wiring ripped out and someone else has redone the wiring. The code b+ short to ground is still showing and system shows code 4 .
shams
Auckland, NZ
C?ID=380692
Date: 2047.15.31
Time: 31:63:63
Temperature: 20.0°C
Temperature: 23.0°C
Voltage: 12.319 V
Thanks for the update. The current condition Auto-Scan would help but it looks like this car uses a G608 sensor (rather than component G294) located in the brake booster and wired to the ABS module. PL24 shows that based on VIN as part number 1K0 998 213 and it has 3 wires per ABS diagram #33 on page 4.
If you haven't done so already I would confirm this car has that sensor and the wires are properly connected to the ABS module.
shams
Auckland, NZ
C?ID=380692
Hi Dana
Thanks a lot for your time.
I had to look up pl24 (partslink24.com) right.
Do I need a subscription to use it ?
The issue is the job came to me with the wiring done. Even the abs was selected ,this was recommended from a vw dealer.
ABS PUMP 1K0614517BK BEF when he run the vin number in his system.
The pump used was the same but without BEF at the end (which I thought was not part of the number). Anyone know what that is for ?
When I questioned about wiring or possibility of loose wiring, he said the wires were matched by color coding on them and soldered.
Yes, PartsLink24 is a subscription based service but your money may be better spent with a subscription to the RoW market erWin VW website to obtain the repair information such as wiring diagrams and component location information. All of those websites are linked from this page:
In the meanwhile a temp link to the PL24 screen shot related to the G608 sensor may be helpful:
I would firstly make sure that sensor is present and connected. Providing it is, the wiring diagram should add clarity to the wire colors and terminals at each end to make sure everything is connected correctly.
Next, the 1K0 907 379 AP 03-ABS module appears to be correct based on VIN. The part number of the loaded pump and module is 1K0 614 517 BK and the BEF at the end just indicates "filled and vented" (i.e assembled and pre-filled) so I wouldn't worry about the lack of that suffix. It was likely printed on the receipt for billing reasons but may not appear on the labels on the part itself.
shams
Auckland, NZ
C?ID=380692
Thanks again Dana
Ok i looked a the brake booster and cant find a sensor there (item 10 in the diagram). Booster number is 1K2614105AR.
Below is the updated scan (i see the short is not showing any more). I had retried the ending steps from the last abs calibration but the lights still remain. (traction control and abs).
I then tried steering recalibration for code 01486, but im not sure im engaging the system correctly.
I understand i need to hold the brake pedal down hard and wait till lights change. initially i couldnt get any change, now i see the abs light is solid and then starts flashing once held down. I have driven about 8 circles at 20kph (Steady) and the flashing light goes to solid (abs) like it was before starting.
So im stumped at the next step now.
Friday,23,July,2021,21:15:22:15412
VIN: WVWZZZ1KZAM612083   Mileage: 110560km-68698miles
   Coding: 0000077
Readiness: 0110 0001
   Revision: 00H45001
   Coding: 133B400D112300FCC80B02EC881C00803100
01487 - System Function Test
                    Reset counter: 193
                    Mileage: 110566 km
                    Date: 2015.12.14
                    Time: 22:33:55
                    Count: 16384
                    Count: 12
                    Count: 12800
                    Count: 321
                    Count: 48640
                    Count: 835
                    Reset counter: 153
                    Mileage: 110566 km
                    Date: 2015.12.14
                    Time: 22:23:07
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 320
                    Count: 49408
                    Count: 60
   Revision: 00006001
   Coding: 0000000000
   Part No SW: 5K0 937 084 A    HW: 5K0 937 084 A
   Component: BCM PQ35 B    008 0019
   Revision: BG008001
   Coding: 40180E3A982D02C0440000800000002003000088525D8960648000000000
   VCID: 303912006A2090CB3F3-8064
   Component: Wischer 20080  21  0501
   Coding: 009795
01501 - Bulb for Blinkers; Rear Left (M6)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 153
                    Mileage: 110555 km
                    Date: 2015.12.08
                    Time: 18:50:21
                    Voltage: 13.65 V
   Coding: 00003236
   Coding: 0001004
   Coding: 570B00
                    Reset counter: 153
                    Mileage: 110555 km
                    Date: 2015.12.08
                    Time: 18:00:58
   Coding: 0004790
   Revision: 00H17000
   Coding: 0005046
00097 - Front Passengers Central Locking (Safe) Motor (V162)
                    Fault Status: 01101100
                    Fault Frequency: 43
                    Reset counter: 153
                    Mileage: 110555 km
                    Date: 2015.12.08
                    Time: 18:01:30
                    Fault Frequency: 14
                    Reset counter: 193
                    Mileage: 110555 km
                    Date: 2015.12.08
                    Time: 18:01:31
Address 56: Radio
   Coding: 0000144
   Coding: 0000144
End----------(Elapsed Time: 01:11, VBatt start/end: 13.6V/13.8V)-----------
That scan looks a lot better! It might not feel like it, with the lights beeping/flashing at you, however you made progress.
Moving forward, the System Function Test gives you roughly 50 seconds to complete successfully and if too much time passes you get 01486 -and- 01487. The later simply means it was initiated but failed or timed out. When that happens I think it is easiest to shut the engine off, wait 5 seconds, start the car back up and start over with brake pedal pressing step from the beginning. When it works as expected the test only takes 10 - 20 seconds from start to finish on this Golf 6 based model.
The most common issue when that test will not complete is caused by communicating with the 03-ABS module during the procedure. Make sure you were using the steps here:
shams
Auckland, NZ
C?ID=380692
Hi Dana
Well I spent hours redoing the tests and starting from the beginning. Trying my older scanner and finally it threw 4 errors for speed sensor and one for yaw sensor. I then went back to the shop and jacked up the car. The right front abs sensor is connected to the rear left and vice versa. Hence it would never complete the final step :) I assume this the problem and will try fix the wiring. Any chance you would have access to a wiring diagram for that plug to abs ? Thanks
shams
Auckland, NZ
C?ID=380692
Ok sorted, the two twisted pairs look very similiar in colour so it was an easy mistake i guess. Swapped them over and voila the ABS is all coded.
Thanks a Lot Dana for helping.
If anyone digs up this old thread.... i used this diagram from the forums as well which worked for this vin.
