- Jul 9, 2021
- 34
- 15
- England, UK
- C?ID=337088
Hello, I've recently carried out a tailgate conversion on a 2021 T6.1 Transporter with a tailgate that has genuine VW LED bulbs.
The wiring has been paired up to the number plate lights wiring of the van, but the dash is bringing up a standard bulb warning error - although the number plate lights are powering up.
On older models when I've had a similar issue, I've gone into 09 Central Elec module and coding and turned off lamp diagnostics for the bulb. On the T6.1's there isn't coding information for this module, and Dana says to use the adpation function, and to post a Module Map of 09 to see which channels are used in the BCM.
I did wonder if changing the spec of the van from barn doors to tailgate in the module might help? As I believe that from the T6 onwards the tailgate bulbs are LED as standard.
Auto scan below, I'll post the module map seperate. Please can someone help! Thanks in advance.
Thursday,08,July,2021,12:23:55:53043
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
VIN: WV1ZZZ7HZMH061530 License Plate: TAILGATE CONV LIGHT FAULT
Mileage: 6015km-3737mi Repair Order:
Address 09: Cent. Elect. Labels: None
Control Module Part Number: 2Q0 937 090 C HW: 2Q0 937 090 C
Component and/or Version: BCM A0 Std+ H11 0943
Software Coding:
Work Shop Code: WSC 00000 000 00000
ASAM Dataset: EV_BCMA0 206001 (VN46)
ROD: EV_BCMA0_206.rod
VCID: 323CEF70C4A392AB497-8066
12298 - License Plate Light
B12CA 15 [009] - Open or Short to Plus
Reset counter: 189
Mileage: 6015 km
Date: 2021.07.08
Time: 12:13:20
Zusaetzliche Umgebungsdaten-Terminal 15 status: On
Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
Zusaetzliche Umgebungsdaten-Low beam: Not operated
Zusaetzliche Umgebungsdaten-OFF: Not operated
Zusaetzliche Umgebungsdaten-Outside temperature: -50.0 °C
Zusaetzliche Umgebungsdaten-Automatic high beam assist: operated
Zusaetzliche Umgebungsdaten-Position lamps: Not operated
Zusaetzliche Umgebungsdaten-Parking light left: Not operated
Zusaetzliche Umgebungsdaten-Parking light right: Not operated
Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
Zusaetzliche Umgebungsdaten-last wakeup: keine Stoerschutzursache
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
Zusaetzliche Umgebungsdaten-voltage measurement: 11.6 V
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 44 5F 75
VIN: WV1ZZZ7HZMH061530 Mileage: 6015km-3737miles
Address 01: Engine (J623-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 SA HW: 04L 907 445 M
Component: R4 2.0l TDI H01 9697
Revision: 23301001
Coding: 002540144364050900000000000000000000000000000000
Shop #: WSC 00012 790 00181
ASAM Dataset: EV_ECM20TDI03004L906056SA 004004
ROD: EV_ECM20TDI03004L906056QF_004.rod
VCID: 7EA40B40407B86CBFDF-802A
Readiness: N/A
Part No SW: 0BT 300 046 R HW: 0GC 927 711 H
Component: GSG DQ500 H06 3101
Revision: 00H06V11
ROD: EV_TCMDQ500021_VN46.rod
VCID: 45D6A4AC652D1513FC5-8010
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 7LA 614 517 B HW: 7LA 614 517
Component: ESC_high H01 0800
Serial number: 08503549201213
Coding: 30552452484DEE860C5924A712667726392724B8
ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 003012
ROD: EV_Brake1ESP90iBOSCHVN46X_003.rod
VCID: 3E24CB4000FB46CBBDF-806A
Address 08: Auto HVAC (J301) Labels:* None
Part No SW: 7LA 907 426 F HW: 7LA 907 426 F
Component: AC Manuell H01 0602
Coding: A03110000810030001000800504001050000000000000000800000000000
ASAM Dataset: EV_AirCondiBHTCVN54XT6PA 001002
ROD: EV_AirCondiBHTCVN54XT6PA.rod
VCID: 46D4A3A0582B1E0BF5F-8012
Rear A/C control head:
Part No SW: 2Q0 937 090 C HW: 2Q0 937 090 C
Component: BCM A0 Std+ H11 0943
Serial number: 00102034900056
Subsystem 1 - Part No SW: 5Q0 955 559 C HW: 5Q0 955 559 C Labels: 5Q0-955-547.CLB
Component: RLS 054 0206
Serial number: S6Y20M12D07H09M44S38
Coding: 0018EE
Driver door control module:
Subsystem 2 - Part No SW: 7L1 959 405 B HW: 7L1 959 163 B
Component: FHSG_DRV 001 0002
Serial number: 00000000000046121650
Coding: 1F000F
Front passenger door control module:
Subsystem 3 - Part No SW: 7L1 959 406 B HW: 7L1 959 164 B
Component: FHSG_PSG 001 0002
Serial number: 00000000000046150817
Coding: 050007
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY203150VE3
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000033886005
Reset counter: 189
Mileage: 6015 km
Date: 2021.07.08
Time: 12:13:20
Part No SW: 5QA 919 294 J HW: 5QA 919 294
Component: PDC 8 Kanal H08 0073
Serial number: 000150058320342
Coding: 8451051811
ASAM Dataset: EV_EPHVA18AU3700000 009053
ROD: EV_EPHVA18AU3700000.rod
VCID: 53F28AF49B79BBA3621-8006
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 3200670201FF8748949C815580508700000000000000000004
Shop #: WSC 00012 790 00022
ASAM Dataset: EV_ACCMRRCONTIVW376 003016
ROD: EV_ACCMRRCONTIVW376_003_VN54.rod
VCID: 43D2BAB46B192B23D21-8016
Part No SW: 2Q0 959 655 AD HW: 2Q0 959 655 AD
Component: VW22Airbag 016 0506
Revision: --------
Coding: 8800C00000000000800000CF008C40000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 7F5AF64447718FC3F69-802A
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI3
Part No SW: 7LA 920 941 A HW: 7LA 920 941 A
Component: KOMBI 202 8400
Coding: 27A412082480260001882A011401000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009071
ROD: EV_DashBoardVDDMQBAB_VW27.rod
Part No SW: 3Q0 907 530 AG HW: 3Q0 907 530 C
Component: GW MQB High 521 5423
Serial number: 12122010801113
Coding: 030100044F05730001100058100F00010001070000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 74B029687E37DC9B9BB-8020
Generator:
Component: 5-00-11-00-04
Subsystem 2 - Part No SW: 3G0 959 442 N HW: 3G0 959 442 N
Component: E221__MFL-PR6 H07 0110
Serial number: PR6-0440066340200347
Coding: 2C0D00
Subsystem 3 - Part No SW: 7E0 915 181 N HW: 7E0 915 181 N
Component: J367-BDMConti H03 1052
Serial number: 77343301002012180076
Address 44: Steering Assist (J500) Labels:| 2N0-909-143.clb
Part No SW: 7LA 909 144 F HW: 7LA 909 144 D
Component: EPS_MQB_ZFLS 751 7150
Coding: 0106
ASAM Dataset: EV_SteerAssisMNB 002012
ROD: EV_SteerAssisMNB.rod
Part No SW: 3CN 035 869 A HW: 3CN 035 869 A
Component: MU-E-D-ER 720 0890
Serial number: 15122000021493
Coding: 066401003C00000041110101008000001F0000C60000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001044
ROD: EV_MUEnt4CGen2LGE_VW27.rod
VCID: 44D0B9A86E172C1BEBB-8010
Address 75: Telematics (J949) Labels:* None
Part No SW: 5WA 035 282 HW: 5WA 035 282
Component: OCUGen3Low H14 0092
Serial number: 0000000011NVUQ0
Coding: 06462000196818208005460160000607
ASAM Dataset: EV_OCUGen3Low 002036
ROD: EV_OCUGen3Low_AU27.rod
VCID: 015E70BC3185F93380D-8054
End----(Elapsed Time: 01:20, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
Software Coding:
Reset counter: 189
Mileage: 6015 km
Date: 2021.07.08
Time: 12:13:20
Software Coding:
Reset counter: 189
Mileage: 6015 km
Date: 2021.07.08
Time: 12:13:20
Software Coding:
Reset counter: 189
Mileage: 6015 km
Date: 2021.07.08
Time: 12:13:20
