Audi e-tron coolant
Lgeee
C?ID=443756
Hi everyone.
I’m in middle of rebuilding a crashed e-tron 55, stuck at the moment at coolant refill as need to perform a bleeding and it asks input something in circuit 1 and 2 but can’t figure out what.
Any advice would be appreciated.
v4J5TSj
Hi and welcome.
Please post an Auto-Scan for context, and explain exactly where you're being asked to "input something in circuit 1 and 2".
Lgeee
C?ID=443756
Monday,12,July,2021,21:12:58:11644
VIN: WAUZZZGE1KB009409   License Plate:
Mileage: 22895km-14226mi   Repair Order:
Chassis Type: GE-AU58 (4K1)
Scan: 01 03 06 09 13 15 16 17 19 2B 36 3C 42 44 46 47 51 52 5F 6D
          74 75 81 84 8C A5 BB BC C5 C6 CA CD CE CF D6 D7 DE 8104 8111 8112
VIN: WAUZZZGE1KB009409   Mileage: 22895km-14226miles
13-Auto Dist. Reg -- Status: Cannot be reached 0100
51-Electric Drive -- Status: Malfunction 0010
84-Night Vision -- Status: Malfunction 0010
C5-Therm. mgt. -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
CD-Laser Scanner -- Status: Malfunction 0010
CE-Drive Motor 2 -- Status: Malfunction 0010
CF-Lane Chge Asst 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
8104-DC/DC Converter HV -- Status: OK 0000
8111-Rearview Mirror R -- Status: OK 0000
8112-Rearview Mirror L -- Status: OK 0000
Address 01: Engine (J623-    )       Labels: None
   Part No SW: 4KE 907 558 E    HW: 4KE 907 558
   Component: I99 99.9l XXX H02 0001
   Coding: 2A0A0012006E040034280000000000000000000000000000
   ASAM Dataset: EV_VCU00XXX0204KE907558E 001001
   ROD: EV_VCU00XXX0204KE907558E.rod
   VCID: 4BC36E035347C7932A1-801E
   Parking lock:
   Subsystem 1 - Part No SW: 0MA 341 601 B    HW: 0MA 341 601 B
   Component: V682 ParkLock  H23 0611
   Serial number: 2018.11.30.000000142
22008 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [039] - -
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 14:15:47
                    Engine RPM: 16383.75 /min
                    Normed load value: 100.0 %
                    Coolant temperature: 215 °C
                    Intake air temperature: 215 °C
                    Ambient air pressure: 2550 mbar
                    Voltage terminal 30: 12.500 V
                    LF_MVB_PDU_INTC_DIAG_8: 49152
                    LF_MVB_PDU_INTC_DIAG_9: 2
                    LF_MVB_PDU_INTC_DIAG_10: 64512
                    LF_MVB_PDU_INTC_DIAG_11: 0
                    LF_MVB_PDU_INTC_DIAG_13: 12290
                    LF_MVB_BUS_INTC_DIAG: 12544
   Part No SW: 4KE 909 059 AC    HW: 4KE 909 059 G
   Component: ESC           H09 0078
   Revision: 00000000    Serial number: 60299000000156
   Coding: 008800BA3D940BA2935408711880D2E425BEA90000BCD0C910184B27A47D95
   Shop #: WSC 00551 210 00000
   ASAM Dataset: EV_BRSContiMKC1AU516 009376
   ROD: EV_BRSContiMKC1AU516_009.rod
   VCID: 0849910F02B1EC8BC73-805C
8311 - Implausible Data Received from Body Control Module (Central Electric)
          U0422 00 [047] - -
          [CCan_LWR_Hoehenwert_VL_invalid]
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 20:24:33
                    Unlearning counter according OBD-OBD unlearning counter: 255
                    History Data-History data 1: 00
                    History Data-History data 2: 00
                    History Data-History data 3: 00
                    History Data-History data 4: 00
                    History Data-History data 5: 00
                    History Data-History data 6: 00
                    History Data-History data 7: 00
                    History Data-History data 8: 00
                    History Data-History data 9: 00
                    History Data-History data 10: 00
                    History Data-History data 11: 00
                    History Data-History data 12: 00
                    History Data-History data 13: 00
                    History Data-History data 14: 00
                    History Data-History data 15: 00
                    History Data-History data 16: 00
                    History Data-History data 17: 00
                    History Data-History data 18: 00
                    History Data-History data 19: 00
                    History Data-History data 20: 00
                    History Data-History data 21: 00
                    History Data-History data 22: 00
                    History Data-History data 0: 00
8413 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [175] - -
          [CCan_ACC_07_timeout]
                    Fault Frequency: 8
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 14:15:47
8418 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [175] - -
          [CCan_ACC_10_timeout]
                    Fault Frequency: 8
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 14:15:47
8440 - Lane change assistant control module
          U1046 00 [175] - Implausible signal
          [CCan_RCTA_Status_failure]
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 14:15:48
   Part No SW: 4M6 959 760 B    HW: 4M6 959 760 B
   Component: MEM-BFS       009 0044
   Serial number: 00000363407487
   Coding: 0038B2400001BEA14843010101010000810000070700878700000000000000
   Shop #: WSC 00046 412 00046
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736_VW38.rod
   VCID: 3D2730DB1DF37923A45-8068
   Valve block 1 in front seat passenger side:
   Subsystem 1 - Part No SW: 4N0 907 182     HW: 4N0 907 182
   Component: N477 VB1 BFSv  H04 0011
   Serial number: SJ80010202194025824A
   Coding: BF2F00
   Valve block 2 in front seat passenger side:
   Subsystem 2 - Part No SW: 4N0 907 182 D    HW: 4N0 907 182 D
   Component: N478 VB2 BFSv  H04 0010
   Serial number: SJ800118021911470072
   Part No SW: 4N0 907 063 HG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0673
   Coding: 07000143C13900DD074257889FEF8C68131B33110C06009789010A00192316810A45090240102000000003030049181A08028000C4030000000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 015010
   ROD: EV_BCM1BOSCHAU651_015.rod
   VCID: 7AADFBC74C5D8E1BC17-802E
   Subsystem 1 - Part No SW: 4KR 955 119     HW: 4K2 955 119
   Component: J400FRWISCH  063 0840
   Serial number: 00000001809050401792
   Coding: 7DC727
   Serial number: 22651548X81A955555A0
   Coding: 02005E
   Subsystem 3 - Part No SW: 4K2 941 501 A    HW: 4K2 941 501 A
   Component: E1 - LTM  H09 0086
   Serial number: 14S22.01.1900690201
   Serial number: GX1CE112121823311098
   Coding: 210000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4K0 947 135 L    HW: 4K0 947 135 L
   Component: Dachmodul  H42 0413
   Serial number: C00219893
   Coding: 0D0104
   Subsystem 6 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0100
   Serial number: WA136427000063314838
   Coding: 0A0700
   Subsystem 7 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V512 LLR1SLvL  H01 0012
   Serial number: Q98AJ03894684
   Subsystem 8 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V514 LLR1SKvL  H01 0012
   Serial number: Q98AJ038A4674
   Subsystem 9 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V516 LLR1SLvR  H01 0012
   Serial number: Q98AJ038A4676
   Subsystem 10 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V518 LLR1SKvR  H01 0012
   Serial number: Q98AJ038A4672
   Front windshield washer pump:
   Subsystem 11 - Part No SW: 4N0 907 605 C    HW: 4N0 907 605 A
   Component: J1100/SWP  H21 0015
   Serial number: 00000000001906701150
   Coding: 020000
11 Faults Found:
66073 - Rain/Light Recognition Sensor
          B1366 04 [009] - Internal System Fault
                    Fault Frequency: 22
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:42
                    average_Voltage_terminals: 13.00 V
                    Outside air temperature sensor-Outside air temperature on CAN: 18.50 °C
                    interior_temperature: 23.00 °C
                    Vehicle speed: 0.00 km/h
66080 - Rain/Light Recognition Sensor
                    Fault Frequency: 22
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:42
66081 - Rain/Light Recognition Sensor
                    Fault Frequency: 22
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:42
66082 - Rain/Light Recognition Sensor
                    Fault Frequency: 22
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:42
66308 - Reading Lamp; Rear Left
          B14EE 01 [008] - Electrical Failure
                    Reset counter: 200
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:42
66309 - Reading Lamp; Rear Right
          B14EF 01 [008] - Electrical Failure
                    Reset counter: 200
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:42
262165 - Lamp 1 for Contour Lighting of Dashboard
          U117E 00 [009] - No Communications
          [Instrument panel contour illumination lamp 1: No communication]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 20:05:41
                    average_Voltage_terminals: 13.50 V
                    interior_temperature: 22.50 °C
                    System run time-Engine running time: 11 s
                    System run time-Terminal 15 on: 0 s
262167 - Lamp 2 for Contour Lighting of Dashboard
          U1180 00 [009] - No Communications
          [Instrument panel contour illumination lamp 2: No communication]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 20:05:41
                    System run time-Engine running time: 65535 s
262169 - Lamp 3 for Contour Lighting of Dashboard
          U1182 00 [009] - No Communications
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 20:05:41
262473 - Bulb 1 for Ambient Lighting of Dashboard
          U1358 00 [009] - No Communication
          [Ambient lighting I-panel: RGB slave 1: no signal/communication]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 20:05:41
                    average_Voltage_terminals: 13.40 V
262482 - Bulb 2 for Ambient Lighting of Dashboard
          U135A 00 [009] - No Communication
          [Ambient lighting I-panel: RGB slave 2: no signal/communication]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 20:05:41
Address 13: Auto Dist. Reg
   Part No SW: 4KE 959 655     HW: 4KE 959 655
   Component: AirbagVW32    H36 3122
   Serial number: 003XPM00DTTP
   Coding: AACCF0C0002000009A5400FFF89D41A800C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001034
   ROD: EV_AirbaVW31SMEAU65x.rod
   VCID: 0B43AE0313C78793EA1-805E
   Left seat belt tensioner:
   Serial number: 00AI2018323313700000
   Coding: 03F002
   Right seat belt tensioner:
   Serial number: 00AI2019061620600000
   Coding: 03F002
   Subsystem 3 - Part No SW: -----------    HW: 480 000 703 19
   Serial number: 357000000003EC448A3U
   Subsystem 4 - Part No SW: -----------    HW: 480 031 103 19
   Serial number: 351001C1CC0B6A003E9E
   Subsystem 5 - Part No SW: -----------    HW: 480 031 103 19
   Serial number: 352001C1C1726C207E45
   Subsystem 6 - Part No SW: -----------    HW: 480 022 901 19
   Component: FrontSensor_D  000 0149
   Serial number: 3550001B92AA5E2165FI
   Subsystem 7 - Part No SW: -----------    HW: 480 022 901 19
   Component: FrontSensor_P  000 0149
   Serial number: 3560001B92AA5E216515
   Crash sensor high-voltage system 1:
   Subsystem 8 - Part No SW: -----------    HW: 480 022 901 19
   Component: HVSensor_gSat  000 0149
   Serial number: 3510001C32F0DDC4828G
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 9 - Part No SW: -----------    HW: 480 022 901 19
   Component: SideSens_B_Pf  000 0149
   Serial number: 3550001C32F0DDC6B32K
12 Faults Found:
1070336 - Databus
          [NWD: 0x12E ACC_07 Timeout]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:39
1064192 - Databus
          [NWD: 0x2A9 ACC_15 Timeout]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:40
10058259 - Crash Sensor for Side Airbag in B-Pillar; Driver Side
          B197A 13 [137] - Open Circuit
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:40
9451027 - Crash sensor side airbag; passenger side
          B1036 13 [137] - Open Circuit
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:40
9437723 - Igniter for Passenger's Airbag
          B1002 1B [137] - Resistance Too High
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:39
9572123 - Ignitor for Passenger Airbag Release Valve
          B120F 1B [137] - Resistance Too High
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:39
9442075 - Driver's Belt Force Limiter Igniter
          B1013 1B [137] - Resistance Too High
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:39
9442331 - Passenger's Belt Force Limiter Igniter
          B1014 1B [137] - Resistance Too High
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:39
          B1006 1B [137] - Resistance Too High
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:39
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [137] - Resistance Too High
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:39
9445397 - Key switch for deactivation of passenger-side airbag
          B1020 15 [137] - Open or Short to Plus
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:40
9446677 - Redundant signal path for airbag shut-off; passenger side
          B1025 15 [137] - Open or Short to Plus
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:40
   Part No SW: 4N0 907 129 AJ    HW: 4N0 907 129 AJ
   ROD: EV_SMLSKLOAU736_AU58.rod
   VCID: 79AFE4CB495B8503C8D-802C
   Part No SW: 4KE 920 795 B    HW: 4KE 920 795
   Component: FHybRDWACC--- H13 0031
   Coding: A50400C87C88060001A6E170B284480008000100
   ROD: EV_DashBoardAU65X_001_AU58.rod
   VCID: 46D55F3748253AFBF5F-8012
16777046 - Charger for HV Battery
          U1139 00 [008] - No Communications
          [BAP_BatteryControl_0x25 communication error bap_error_timeout heartbeat]
                    Reset counter: 200
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 13:31:00
16777089 - Databus
          [ACC_12 communication error can_error_timeout]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:38
   Part No SW: 4K1 907 468 D    HW: 4K1 907 468 C
   Component: Gateway       H04 0322
   Serial number: 1DF06037867901
   Coding: 02030005000180C000810000005B01329C8A0047180000000900009F00000000
   ASAM Dataset: EV_Gatew31xAU65x 003170
   ROD: EV_Gatew31xAU65x_AU58.rod
   VCID: 36352FF738C5AA7B65F-8062
   Subsystem 1 - Part No SW: 4N0 951 523 G    HW: 4N0 951 523 G
   Component: E221__MFL  H06 0003
   Subsystem 2 - Part No SW: 4N0 915 181 D    HW: 4N0 915 181 D
   Serial number: 76749601001902150042
   Subsystem 3 - Part No SW: 4N0 419 508     HW: 4N0 419 508
   Component: J1158 KLR  H44 0030
   Serial number: 19011023606S00304401
131589 - Control Module for Brake Electronics
          U13BF 00 [009] - No Communication on 2nd Bus
          [Timeout_Node_0x05_DiagAdress_03_ESP]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 13:44:39
131671 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [009] - -
          [Timeout_Node_0x57_DiagAdress_13_ACC]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 13:44:39
8531970 - Quiescent Current
          U1406 00 [009] - Too High
          [Electric_current_Upper_Limit_Value_Exceeded]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 20:48:47
                    EM_vehicle_state: 00 00
                    Total static current-current total quiescent current: 240 mA
                    Total static current-Total time quiescent current exceeded: 1.0 H
8913155 - Development Code 4
          B2F04 00 [009] - -
          [RWB_TME_Init_Abwurf_Dauerinit]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 14:54:11
8913156 - Development Code 5
          B2F05 00 [009] - -
          [RWB_BCME_Init_Abwurf_Dauerinit]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 14:51:46
          U1101 00 [009] - Active
          [KS_Active_1]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 13:44:36
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 19000053499018
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW53.rod
   VCID: 343115FF2EB9B86B5BB-8060
   Serial number: 00000363407474
   Coding: 00389A400001BEA14803010101010000810000070700878700000000004000
   Valve block 1 in front seat driver side:
   Component: N475 VB1 FSv  H04 0011
   Serial number: SJ80010202194025824F
   Coding: BF2F00
   Valve block 2 in front seat driver side:
   Component: N476 VB2 FSv  H04 0010
   Serial number: SJ80011802191147006D
   Part No SW: 4KE 907 566     HW: 4N0 907 566 A
   Component: MRR_HR H12 0426
   Coding: 4FDC80
   ASAM Dataset: EV_RearRadarS1DelphAU651 001018
   ROD: EV_RearRadarS1DelphAU651.rod
   VCID: 0557983B35A3F1E3BC5-8050
1183757 - Databus
          [databus message missing - ESP_03]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:39
                    Control Module temperature: 65 °C
                    Voltage terminal 30: 13.00 V
                    Vehicle speed: Initial value
                    Terminal 15 status: On
                    Voltage terminal 15: Measuring value not available
1183758 - Databus
          [databus message missing - ESP_15]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:39
1183761 - Databus
          [databus message missing - ESP_21]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:39
1183763 - Databus
          [databus message missing - ESP_32]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:39
1183764 - Databus
          [databus message missing - ESP_33]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:39
   Part No SW: 4M0 959 793 M    HW: 4M0 959 793 J
   Component: TSG FS        007 0387
   Serial number: 0000365877454
   Coding: 001DDA0043010482A000B022
   ROD: EV_DCU2DriveSideMAXHCONT_VW38.rod
   VCID: 48C9510F42312C8B073-801C
   Part No SW: 4N0 909 144 E    HW: 4N0 909 144 A
   Component: EPS_MLBEVO2BS H21 0505
   Coding: B4000101010000
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 323D13E7D4ADB65B497-8066
7354133 - Internal Control Module Memory Check Sum Error
          B2000 49 [137] - Internal electronic failure
          [DB6D_MOSFET_ERROR]
                    Mileage: 22895 km
                    Date: 2021.03.13
                    Time: 12:39:37
                    FreezeFrame_mw_1306_GDU-Current_Sense_Ampl_1_2_Errors: 00
                    FreezeFrame_mw_1306_GDU-Current_Sense_Ampl_3_and_VRO_Errors: 00
                    FreezeFrame_mw_1306_GDU-Digital_Output_Pin_Errors: 00
                    FreezeFrame_mw_1306_GDU-Err_Msk_Low_Imp: 00 00
                    FreezeFrame_mw_1306_GDU-Error Path Info: 00
                    FreezeFrame_mw_1306_GDU-External_Errors: 00
                    FreezeFrame_mw_1306_GDU-GDU Pin Level: 00
                    FreezeFrame_mw_1306_GDU-GDU_Error_Overview: 02
                    FreezeFrame_mw_1306_GDU-GDU_Internal_Errors_1: 00
                    FreezeFrame_mw_1306_GDU-GDU_Internal_Errors_2: 00
                    FreezeFrame_mw_1306_GDU-GDU_Special_Event: 00
                    FreezeFrame_mw_1306_GDU-Low_side_1_Output_Stage_Temperature: 00
                    FreezeFrame_mw_1306_GDU-Min_Max_DCLink: 0.00 V
                    FreezeFrame_mw_1306_GDU-Operation_mode_overview: 20
                    FreezeFrame_mw_1306_GDU-Short_Circuit_Errors: 00
                    FreezeFrame_mw_1306_GDU-Shutdown_Errors: 00
                    FreezeFrame_mw_1306_GDU-SPI_Comm_and_Conf_Errors: 00
                    FreezeFrame_mw_1306_GDU-Voltage_DCLink_FF: 16.59 V
3149825 - Databus
          [COMI_TIMEOUT_ACC10]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 14:15:47
                    FreezeFrame_mw_120C_Timeout-Engine RPM: 0.00 /min
                    FreezeFrame_mw_120C_Timeout-System status: 0
                    FreezeFrame_mw_120C_Timeout-Terminal 30 power supply: 13.15 V
                    FreezeFrame_mw_120C_Timeout-Terminal 15 status measured: On
                    FreezeFrame_mw_120C_Timeout-Engine steering torque sensor: average value: 0.00 Nm
                    FreezeFrame_mw_120C_Timeout-Terminal 15 resulting: On
                    FreezeFrame_mw_120C_Timeout-Terminal 15 status signal: On
                    FreezeFrame_mw_120C_Timeout-Steering pinion angle: offset corrected: 1.23 °
                    FreezeFrame_mw_120C_Timeout-ARA_signal_red_cyclic: 00
                    FreezeFrame_mw_120C_Timeout-PLA_signal_red_cyclic: 00
                    FreezeFrame_mw_120C_Timeout-SCU state: System OK
                    FreezeFrame_mw_120C_Timeout-Steering_angle_sender_status: System OK
   Part No SW: 8W0 907 064 GH    HW: 8W0 907 064 DH
   Component: BCM2 MLBevo   025 0424
   Coding: 017500002FB100416301A0046C00888200004000804F06582F0400000504823F001F0100010F13
   ASAM Dataset: EV_BCM2HellaAU736 016016
   ROD: EV_BCM2HellaAU736_016.rod
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY190501LDT
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000046767165
   left tail lamp 1:
   Subsystem 3 - Part No SW: 4KE 945 423     HW: 4KE 945 423
   Component: T1 LH ECE HD  H10 0403
   Serial number: A1W700008JW
   Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 11583227
   left tail lamp 2:
   Subsystem 5 - Part No SW: 4KE 945 429     HW: 4KE 945 429
   Component: T2 LH ECE HD  H10 0403
   Serial number: A1WK00009AL
   Right rear tail lamp 1:
   Subsystem 6 - Part No SW: 4KE 945 424     HW: 4KE 945 424
   Component: T1 RH ECE HD  H10 0403
   Serial number: A1WD00009Y0
   Right rear tail lamp 2:
   Subsystem 7 - Part No SW: 4KE 945 430     HW: 4KE 945 430
   Component: T2 RH ECE HD  H10 0403
   Serial number: A1WL00009AL
   Part No SW: 4N0 035 223 C    HW: 4N0 035 223
   Component: MIB2_amp_P_D5 H01 0170
   Revision: 00000001    Serial number: AUZ8ZAJ7D00U2N7
   Coding: 0115160000AAAA2FAA0000010002
   ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001010
   ROD: EV_AMPMst16C1Gen2pALPI.rod
   VCID: 2411E5BF9E5928EBCBB-8070
   Part No SW: 0EF 907 080 G    HW: 0EF 907 080 C
   Component: CUFZD683Q0AD2 H03 0010
   Revision: --------    Serial number: -00112.12.18000
   Coding: 01000000000000000000
   Shop #: WSC 60885 003 1048576
   ASAM Dataset: EV_DMCMHITACAU516 003007
   ROD: EV_DMCM2HITACAU516_003.rod
   VCID: 3A2D3BC70CDD4E1B817-806E
13828096 - Component protection
          U1115 00 [047] - No basic setting for SHE key
          [CmpntPrtctn_SHEKeyNoCnfg]
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 14:15:47
   Part No SW: 4M0 959 792 M    HW: 4M0 959 792 J
   Component: TSG BFS       007 0387
   Serial number: 0000365939474
   Coding: 001DDA0043010482A000B020
   ROD: EV_DCU2PasseSideMAXHCONT_VW38.rod
   VCID: 47CB52334F2F23F30E9-8012
196722 - Turn Signal in Exterior Mirror
          B11FD 13 [009] - Open Circuit
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 20:27:33
   Part No SW: 4KE 035 063 A    HW: 4KE 035 063
   Component: MU-H-LND-EU   046 2538
   Coding: 0115760100000000C3111102C00802302F0001E6037008008E
   Subsystem 1 - Part No: V03 959 804 BH
   Component: MIB2P_EU_Q119  0360
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4KE 919 605     HW: 4KE 919 605
   Component: DU AU516 High  H41 0144
   Serial number: INX00109111800130296
   Compact disc data bank:
   Component: Gracenote2  1009
   Volume Control 1:
   Subsystem 4 - Part No SW: 4N1 919 616 A    HW: 4N1 919 616
   Component: LSR-D5/C8  H33 0108
   Serial number: 00004419000023491054
   Multimedia System 5:
   Subsystem 5 - Part No SW: 4KE 919 603     HW: 4KE 919 603
   Component: DU AU516 Bot  H41 0144
   Serial number: INX00103121800140777
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Component: MediaConnectH  014 0133
   Serial number: 051900085162001
7173 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:45
                    Voltage terminal 30: 13.1 V
                    BAP-BAP_Function_ID: 02
          B2000 87 [009] - Missing message
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:38
                    Software module: status-SW_Status_Consistency: 00 00 01
                    Software module: status-SW_Status_Device: Eggnog
   Part No SW: 8W8 959 107 D    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0170
   Revision: --------    Serial number: A2-C744-8781-0
   Coding: 3330
   VCID: 4ACD6B075C3DDE9B117-801E
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4KE 907 777 AD    HW: 4KE 907 777 A
   Component: Fahrwerk-SG   H52 2311
   Serial number: 2203190375
   Coding: 10D86083DA4010
   ASAM Dataset: EV_ChassContrContiAU651 003018
   ROD: EV_ChassContrContiAU651_003.rod
   VCID: 0E45A71760D5B2BB0DF-805A
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130515299
   Coding: 303030
   Part No SW: 4K1 035 282 D    HW: 4K1 035 282 B
   Component: ConBox        H09 0232
   Serial number: 005CCA11F120292
   Coding: 01C0E0FFC040800000
   ROD: EV_ConBoxAU651_002.rod
   VCID: 2809F18FE271CC8BE73-807C
   Part No SW: 4KR 713 041 A    HW: 4KR 713 041
   Component: GSM-LL H04 0036
   Serial number: 92145SCJ00064
   ASAM Dataset: EV_GSMKLOAU516 001008
   ROD: EV_GSMKLOAU516.rod
   VCID: 42DD4327640D06DBD97-8016
Address 84: Night Vision (J853)       Labels:* None
   Part No SW: 4KE 907 547 B    HW: 4M0 907 547
   Component: NV-ECU-Gen3   H13 0260
   Serial number: 648027100201849
   Coding: 100112
   ASAM Dataset: EV_NightVisioG3AUTOLAU516 001002
   ROD: EV_NightVisioG3AUTOLAU516.rod
12306 - Video Cable for Night Vision System
          B11E1 29 [009] - Signal Implausible
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 20:24:21
                    Image processor: error number-Image processor: error number 2: 00 00 00 00
                    Image processor: error number-Image processor: error number 1: 1B E0 10 00
                    Voltage terminal 15: 13.00 V
                    System status-System_State_Data: 00 03
                    Outside temperature: 18.00 °C
                    Control Module temperature-Temperature 1: 19.00 °C
                    Control Module temperature-Temperature 2: 20.00 °C
                    Control Module temperature-Temperature 3: 19.00 °C
                    Control Module temperature-Average of temperature: 19.00 °C
                    Camera for night-vision system: supply voltage: 0.00 V
                    Camera for night-vision system: temperature-Temperature in control module: -41.00 °C
                    Camera for night-vision system: temperature-Camera protection window temp: 215.00 °C
   Part No SW: 4KE 915 233 F    HW: 4KE 915 233 B
   Component: BMC_MLBCBEV   H15 0231
   ASAM Dataset: EV_BECM0842071 001004
   ROD: EV_BECM0842071_VW53.rod
   VCID: 41DF4C2B610B1DC3C0D-8014
   Battery interrupt switch:
   Subsystem 1 - Part No SW: 4KE 915 250 C    HW: 4KE 915 250 B
   Component: BJB_MLBBEV  H12 0369
   Cell module control module 1:
   Subsystem 2 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 2:
   Subsystem 3 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 3:
   Subsystem 4 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 4:
   Subsystem 5 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 5:
   Subsystem 6 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 6:
   Subsystem 7 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 7:
   Subsystem 8 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 8:
   Subsystem 9 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 9:
   Subsystem 10 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 10:
   Subsystem 11 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 11:
   Subsystem 12 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 12:
   Subsystem 13 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AC    HW: 4N0 907 107 H
   Component: zFAS Var C    H09 0291
   Coding: 04E1840000000000003FD60000F4440E5B9E5600000000000000000000969401009BA8000000000000000080000000000000000000000000000040000000000000007CD80000009000800080000000000080400000E0
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_001.rod
   VCID: 0059892F2A81D4CB8F3-8054
20 Faults Found:
2114714 - Databus
          [TIMEOUT_LRR1_WZO]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 20:05:29
                    Supply voltages-Supply voltage Terminal 30 - internal: 0.00 V
                    Supply voltages-Terminal 30: 12.30 V
                    Supply voltages-Terminal 30 local: 12.30 V
2114719 - Databus
          [TIMEOUT_TCI_PS]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 20:05:29
2114850 - Databus
          [TIMEOUT_ACC_17]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 20:05:29
                    Supply voltages-Terminal 30: 12.40 V
2114895 - Databus
          [TIMEOUT_LRR1_SensorHeader_H]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 20:05:29
2113695 - Databus
          [TIMEOUT_LRR1_SensorHeader]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 20:05:29
2114802 - Databus
          [TIMEOUT_LRR1_SensorHeader_02]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 20:05:40
                    Supply voltages-Terminal 30: 13.40 V
                    Supply voltages-Terminal 30 local: 13.40 V
2114011 - Databus
          [LH_EPS_02_EPS_Unterstuetzungsleistung]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:38
2114053 - Databus
          [RCTA_01_RCTA_Status]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:38
2114631 - Databus
          [SWA_01_SWA_rel_Fehler]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:38
2114638 - Databus
          [LS1_SensorHeader_LS1_Fehler]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:38
2113665 - Databus
          [TIMEOUT_ACC_06]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:38
                    Supply voltages-Terminal 30: 12.90 V
                    Supply voltages-Terminal 30 local: 12.90 V
2114915 - Databus
          [SWA_01_SWA_Status_02]
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:38
233472 - Parking Sensor(s); Front
          B10FC F0 [008] - Function Limitation due to External Factors
          [Geber für Einparkhilfe - Schmutz bzw. Eisbildung vorn]
                    Reset counter: 200
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 12:04:37
                    Outside temperature: 20.00 °C
233523 - Parking Sensor(s); Front
          [Geber für Einparkhilfe vorne - Funktionseinschränkung durch Umwelteinflüsse]
                    Reset counter: 200
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 20:07:36
233524 - Side Front Left Parking Aid Sensor
          B10F6 31 [009] - No Signal
                    Fault Frequency: 13
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:43
233545 - Front Right Center Parking Aid Sensor
          B10F9 31 [009] - No Signal
                    Fault Frequency: 13
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:43
65551 - Emergency Assistant
          C12D7 F0 [009] - Status Feedback for HMI Implausible
                    Fault Frequency: 16
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:40
                    Profile master status emergency assistance-Nominal status: On
                    Profile master status emergency assistance-Actual status:: Malfunction
65542 - Lane Change Assistant
          C12DC F0 [009] - Status Feedback for HMI Implausible
                    Fault Frequency: 13
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:44
                    Profile master status lane change assistance-Mode: Not available
                    Profile master status lane change assistance-Nominal status: On
                    Profile master status lane change assistance-Actual status:: Malfunction
65543 - Egress Warning
          C12DD F0 [009] - Status Feedback for HMI Implausible
                    Fault Frequency: 13
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:44
                    Profile master status exit warning-Mode: Not available
                    Profile master status exit warning-Nominal status: On
                    Profile master status exit warning-Actual status:: Malfunction
65544 - Night Vision Assist
          C12DE F0 [009] - Status Feedback for HMI Implausible
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 20:24:27
                    Profile master status night vision assistant-Nominal status: On
                    Profile master status night vision assistant-Actual status:: Malfunction
   Part No SW: 4M0 959 795 M    HW: 4M0 959 795 J
   Component: TSG HFS       006 0387
   Serial number: 0000367574803
   Coding: 000DD80000010482A000B020
   ROD: EV_DCU2RearDriveMAXHKLO_VW53.rod
   Component: TSG HBFS      006 0387
   Serial number: 0000367573034
   ROD: EV_DCU2RearPasseMAXHKLO_VW38.rod
Address C5: Therm. mgt. (J1024)       Labels:* None
   Part No SW: 4KE 965 429 C    HW: 4KE 965 429
   Component: TME-Max       H08 0312
   Serial number: 0023311
   Coding: 00
   ASAM Dataset: EV_ThermContrVISAU49X 002036
   ROD: EV_ThermContrVISAU49X_AU58.rod
   Subsystem 1 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G395 pT-Sens1  H11 0010
   Subsystem 2 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
   Serial number: -00101.0W.4A20370144
   A/C compressor sub:
   Subsystem 3 - Part No SW: 4G0 816 797 C    HW: 4G0 816 797 C
   Component: J842 EKK es33  H03 0015
   Serial number: 00000000019011401142
   A/C pressure/coolant temperature sensor 2:
   Subsystem 4 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G826 pT-Sens2  H11 0010
   Expansion valve 2 for refrigerant:
   Subsystem 5 - Part No SW: 4M0 816 682 E    HW: 4M0 816 682 E
   Component: N637 EV2_KaMi  H12 0102
   Serial number: 00000000000150654201
   Shut-off valve 2 for refrigerant:
   Subsystem 6 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N640 AV2_KaMi  H12 0102
   Serial number: 00000000000130635181
   Shut-off valve 3 for refrigerant:
   Subsystem 7 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N641 AV3_KaMi  H12 0102
   Serial number: 00000000000130635305
   Shut-off valve 4 for refrigerant:
   Subsystem 8 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N642 AV4_KaMi  H12 0102
   Serial number: 00000000000130635175
   Shut-off valve 5 for refrigerant:
   Subsystem 9 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N643 AV5_KaMi  H12 0102
   Serial number: 00000000000130635499
   Radiator shutter:
   Subsystem 10 - Part No SW: 95B 965 501 S    HW: 95B 965 501 S
   Component: V544KJS1  H12 0109
   Serial number: 20190125020103050111
   Coolant valve 1:
   Subsystem 11 - Part No SW: 4KE 963 375 K    HW: 4KE 963 375 K
   Component: N632 V1_KUEMI  010 0103
   Serial number: 00000000000000055224
   Coolant valve 2:
   Subsystem 12 - Part No SW: 4KE 963 375 J    HW: 4KE 963 375 J
   Component: N633 V2_KUEMI  010 0103
   Serial number: 00000000000000049065
   Coolant valve 3:
   Subsystem 13 - Part No SW: 4KE 963 375 H    HW: 4KE 963 375 H
   Component: N634 V3_KUEMI  010 0103
   Serial number: 00000000000000058883
   Coolant valve 4:
   Subsystem 14 - Part No SW: 4KE 963 375 N    HW: 4KE 963 375 N
   Component: N635 V4_KUEMI  010 0103
   Serial number: 00000000000000041816
7 Faults Found:
61027 - Implausible Data Received from Body Control Module (Central Electric)
          U0422 00 [047] - -
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 14:15:52
                    Expanded ambient data 1-Voltage terminal 30: 0.000 V
                    Expanded ambient data 1-Vehicle speed: 0 km/h
                    Expanded ambient data 1-System status: Control operation: ignition on
                    Expanded ambient data 1-Power quota setting by energy management: 1D
                    Expanded ambient data 1-Status of drive readiness hybrid: Engine start
                    Expanded ambient data 1-Ambient temperature: 21.00 °C
                    Expanded ambient data 1-current state of low temp.circ.: 00
                    Expanded ambient data 1-previous state low-temp.circ.: 00
                    Expanded ambient data 1-Operating time in the current state of the low temp.circ.: 00
                    Expanded ambient data 1-current state of high-temp.circ.: 00
                    Expanded ambient data 1-previous state of high-temp.circ.: 00
                    Expanded ambient data 1-Operating time in the current state of the high temp.circ.: 00
                    Expanded ambient data 1-current state of battery low temp.circ.: 02
                    Expanded ambient data 1-previous state of battery low temp.circ.: 02
                    Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: FF
                    Expanded ambient data 1-current state of battery cold circuit: 00
                    Expanded ambient data 1-previous state of battery cold circuit: 00
                    Expanded ambient data 1-Operating time in the current state of the cold circuit: FF
59316 - No Communication With Active Grille Air Shutter Module 2
          U0285 00 [047] - -
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 14:15:51
                    Expanded ambient data 1-previous state of battery low temp.circ.: 00
                    Radiator shutter 2: status referencing-Initialization: initialized
                    Radiator shutter 2: status referencing-blockage: not active
                    Radiator shutter 2: status referencing-Direction of rotation: clockwise
                    Radiator shutter 2: status referencing-excessive temperature: not active
                    Radiator shutter 2: status referencing-Temperature in control module: -50 °C
                    Radiator shutter 2: status referencing-Internal malfunction: not active
                    Radiator shutter 2: status referencing-Supply voltage: 0.00 V
                    Radiator shutter 2: status referencing-Free run: not active
                    Radiator shutter 2: status referencing-Adapting: completed successfully
                    Radiator shutter 2: status referencing-Position: 127 %
                    Radiator shutter 2: status referencing-operational: not active
                    Radiator shutter 2: status referencing-Response error: OK
                    Radiator shutter 2: status referencing-Torque: Measuring value not available
                    Radiator shutter 2: status referencing-Reference value: not OK
                    Radiator shutter 2: status referencing-Position_Textual: Malfunction
                    Activation of radiator shutter 2-Initialization: not active
                    Activation of radiator shutter 2-LIN node- address: 1
                    Activation of radiator shutter 2-Target value: 0 %
                    Activation of radiator shutter 2-Direction of rotation: clockwise
                    Activation of radiator shutter 2-Set reference level: not active
                    Activation of radiator shutter 2-Torque: low
                    Activation of radiator shutter 2-LIN_node_adress_Textual: numerical value: no text
                    Activation of radiator shutter 2-set_value_Textual: numerical value: no text
59317 - No Communication With Active Grille Air Shutter Module 2
          U0285 00 [047] - -
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 14:15:59
60019 - Basic Setting for Coolant Fill
          P1A81 00 [044] - Not Ended
                    Fault Frequency: 8
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 14:17:15
                    Expanded ambient data 1-current state of battery low temp.circ.: 00
                    Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 04
61135 - Databus
          U1123 00 [047] - Received Error Message
          [EECF Databus error value received]
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 14:15:52
61137 - Databus
          [EED1 Databus error value received]
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 14:15:52
61133 - Databus
          [EECD Databus error value received]
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 14:15:52
   Part No SW: 5QE 915 684 J    HW: 5QE 915 684 J
   Component: OBC KOSTAL    H24 0023
   Serial number: ---------------
   Coding: 7B588C6742080E010000
   ASAM Dataset: EV_OBC3Phase1KLOMLBev14B 002001
   ROD: EV_OBC2PhaseKLOMLBev14P.rod
   VCID: 56F58F7798858A7B85F-8002
   Flap 1 for charging socket:
   Flap 2 for charging socket:
   Subsystem 2 - Part No SW: 4KE 862 277 A    HW: 4KE 862 277 A
   Component: F497LKL2       004 0003
   Serial number: 20181209030206081111
1060352 - Charging Cover A; Locking Detection
          P31CF 00 [047] - Electrical Malfunction
          [Socket_A_Lock_2_Check_circuit_open]
                    Mileage: 22895 km
                    Date: 2021.07.12
                    Time: 17:17:53
3211292 - Unknown Error Code
          B192E 13 [047] - Open Circuit
          [search_LED_LKL1_disconnected]
                    Mileage: 22895 km
                    Date: 2021.07.12
                    Time: 17:17:57
   Component: SAD_STG_1     005 0002
   Coding: 728040051602
   ROD: EV_SunRoofCONTIAU736_009_AU58.rod
   VCID: 75B7E8FB6543E163AC5-8020
Address CD: Laser Scanner (J1122)       Labels: None
   Part No SW: 4K8 907 660 B    HW: 4N0 907 660
   Component: LASER_SCANNER H36 0202
   ASAM Dataset: EV_LaserScannAU651 013013
   ROD: EV_LaserScannAU651_013.rod
   VCID: 353728FB25C3A1636C5-8060
11546632 - Laser for Adaptive Cruise
          C12EB 92 [009] - Performance or incorrect operation
          [Loss_of_front_cover_fatal_error]
                    Mileage: 45719 km
                    Date: 2021.02.18
                    Time: 13:11:52
                    Control Module temperature-Host: external temperature: 29 °C
                    Control Module temperature-Zynq: internal temperature: 42 °C
                    Control Module temperature-Host: internal temperature: 29 °C
                    Control Module temperature-Zynq: external temperature: 27 °C
                    Voltage terminal 15: 14.678 V
Address CE: Drive Motor 2 (J944)       Labels: None
   Part No SW: 0EF 907 180 J    HW: 0EF 907 180 C
   Component: CUBZE683Q0AD2 H03 0010
   Revision: --------    Serial number: -00117.12.18000
   Shop #: WSC 62793 004 1048576
   ASAM Dataset: EV_DMCM2HITACAU516 003007
   VCID: 3E2537D710F5623BBDF-806A
                    Mileage: 22895 km
                    Date: 2021.07.11
                    Time: 14:15:47
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H12 0426
   Coding: 4FDC80
   ASAM Dataset: EV_RearRadarS2DelphAU651 001018
   ROD: EV_RearRadarS2DelphAU651.rod
1183757 - Databus
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:39
                    Control Module temperature: 64 °C
                    Voltage terminal 30: 13.10 V
1183758 - Databus
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:39
1183761 - Databus
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:39
1183763 - Databus
                    Reset counter: 160
                    Mileage: 22895 km
                    Date: 2021.07.10
                    Time: 19:58:39
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 4K0 941 591 BC    HW: 4K0 941 591 B
   Component: LMS_MLBevo    H11 0031
   ROD: EV_LMSLeftHELLAAU58X.rod
   VCID: 71BFDCEB112BCD4370D-8024
Address D7: Light Ctrl Right 2 (A27)       Labels: None
0520 - Internal Control Module Memory Check Sum Error
          B2000 4B [009] - Over temperature
          [ecu defect - 5 volt regulator error]
                    Mileage: 22895 km
                    Date: 2021.06.14
                    Time: 00:01:40
Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
   Part No SW: 4N0 035 502 A    HW: 4N0 035 502 A
   Component: WLC Front     H10 0057
   Coding: 400000
   VCID: 221DE3A7844D26DBB97-8076
Address 8104: DC/DC Converter HV (A19)       Labels: None
   Part No SW: 4KE 907 171 B    HW: 4KE 907 171 B
   Component: DCDC Wandler H10 0400
   ASAM Dataset: EV_DCDCHVTDKAU516 001004
   ROD: EV_DCDCHVTDKAU516.rod
   VCID: 3FDB4AD317FF6B33B69-806A
Address 8111: Rearview Mirror R (J1030)       Labels:* None
   Part No SW: 4KE 907 181 B    HW: 4KE 907 181 A
   Component: VAS H31 0027
   Coding: 01010B07
   ASAM Dataset: EV_RearVLeftFicosAU516 001003
   ROD: EV_RearVLeftFicosAU516.rod
   VCID: 40D9492F6A0114CBCF3-8014
Address 8112: Rearview Mirror L (J1031)       Labels:* None
   Part No SW: 4KE 907 182 B    HW: 4KE 907 182 B
   Component: VAS H32 0027
   Coding: 01010B07
   ASAM Dataset: EV_RearVRightFicosAU516 001003
End----------(Elapsed Time: 03:44, VBatt start/end: 13.1V/13.1V)-----------
Lgeee
C?ID=443756
in therm. mgt module, basic settings drop-down list says "filling coolant circuit" which I done then "stop routine coolant circuit charging/flushing" I done after filling the expansion tank, and now under "test-bleed cooling circuit" there is two windows saying circuit 1 and circuit 2 where 1 to 3 digit numbers need to be put in to perform the bleeding,
hope that makes sense
NEtech
Denmark
C?ID=56995
I guess OP means for [C5], later.. yes he does :) .
I have not tested an e-tron, but looking at the basic settings it looks very similar to the ID.3 and ID.4
That basic setting is not used, even you could think so.
Use "IDE10179-ENG114972 Fill refrigerant circuit - Routine Control Option"
But before you activate it, load measurement values, search for 1447 and choose/mark them, when all valves show 100%, start your Refrigerant filling machine program.
After filling machine program is done, press [Stop] for the basic setting.
Lgeee
C?ID=443756
The one you described is for ac refill, I’m wanting to refill coolant(antifreeze) system
This ???
60019 - Basic Setting for Coolant Fill P1A81 00 [044] - Not Ended Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 8 Mileage: 22895 km Date: 2021.07.11 Time: 14:17:15
