Post XENON Retrofit Golf Sportsvan 2015
sergelhr
saint-prix, France
C?ID=68124
Hi all
Following a Xenon Retrofit onto my Sportsvan 2015 TDI 150HP and a death yellow trianglefor almost 2 days :banghead:,i was able finally to clear all faults.
Now i'm running into issue with BCM Module 09 configuration Adpmap , as for example in auto no DRLduring day light only during night xenon and DRL dimmed!
I'm looking for an adpmap for a ROW version with basic xenon ( no DLA).
headlight washer not working anymore ,output test 09 tested satis? messed up bcm parameter?
My current adpmap with not working Led DRL :>https://drive.google.com/file/d/1UnLkU19c2yFaFsAodDCn4b1AKP5wsl8E/view?usp=sharing
Xenon wiring manual:>https://drive.google.com/file/d/15nqQzXoOAyUq-mzOJFabISlnvsjmhiTC/view?usp=sharing
:thumbs:
Best Regards
Serge
Monday,12,July,2021,14:46:19:15214
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4543.4
Dealer/Shop Name: vag dream
VIN: WVWZZZAUZFW53XXXX   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 20 42 44 52 55 5F 65 69
VIN: WVWZZZAUZFW53XXXX   Mileage: 121179km-75297miles
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 AS    HW: 04L 907 309 A
   Component: R4 2,0L EDC   H22 8133
   Revision: 81H22---
   Coding: 01190012035405082000
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_ECM20TDI01104L906021AS 002009
   ROD: EV_ECM20TDI01104L906021AE.rod
   VCID: 76A0C73CC9FC533BE9-8022
   Part No SW: 5Q0 907 379 CK    HW: 5Q0 907 379 G
   Component: ESC           H31 0472
   Revision: 00000000    Serial number: 62484000001693
   Coding: 03FA62A124238975037C060441C529C0462491C0608294F3F46050084002
   Shop #: WSC 12069 995 00001
   VCID: 075EBAF8BE165AB382-8052
   Part No SW: 5G0 907 044 AF    HW: 5G0 907 044 AF
   Component: Climatronic   H03 0907
   Revision: 00001K08
   Coding: 08020104202100011005000000101000
   VCID: 6B96E64882BE9ED306-803E
   Air quality sensor:
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Revision: --------    Serial number: 86580607151478
   Coding: 00020A42C24122FB4BE44080B11C07081000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 0346AEE88A2E7693DE-8056
   Subsystem 1 - Part No SW: 517 955 119     HW: 517 955 119
   Component: WWS    140818  042 X596
   Serial number:         140825163616
   Component: RLHS  037 0059
   Serial number: S5Y14M09D13H01M00S51
   Coding: 00A8DD
   Serial number: 000000000ZY140090CHY
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000066016913
   Humidity sensor: interior:
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39331425406527
   Coding: 0071051101
   Shop #: WSC 06132 002 1048576
   VCID: 3D321810AC4AC063E8-8068
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Serial number: 05091403212281
   Coding: 00000900FE0339
   VCID: 383C09048368E54B3B-806C
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR08MJD6
   Coding: 98CCC000000000005C5400CF004800000065
   VCID: 7F4E2218E6C61273BA-802A
   Left seat belt tensioner:
   Serial number: 34185453B09091450635
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34185452B10091470083
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 608 14
   Serial number: 3576700000027C0D7E0/
   Subsystem 4 - Part No SW: -----------    HW: 480 002 608 14
   Serial number: 358670000009811D7E0$
   Subsystem 5 - Part No SW: -----------    HW: 480 400 109 14
   Serial number: 3516502BB175A8E1E34P
   Subsystem 6 - Part No SW: -----------    HW: 480 400 109 14
   Serial number: 35265029D17750B4001
   Subsystem 7 - Part No SW: -----------    HW: 480 400 409 14
   Serial number: 3556502A9175A8E1534H
   Part No SW: 5Q0 953 507 DB    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 10091404221954
   Coding: 0400
   VCID: 79BACC00F8E23C4384-802C
   Part No SW: 517 920 751     HW: 517 920 751
   Component: KOMBI         302 4270
   Coding: 07A502802E80000800886A041400000000000000
   VCID: 55E2A0B0343A3823C0-8000
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1188
   Revision: --------    Serial number: 0002427602
   Coding: 030100340B087300EF00025C080F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011016
   ROD: EV_GatewLear_011.rod
   VCID: 42C86BECD5B4BF9B95-8016
   Generator:
   Component: E221__MFL-DC1  H16 0038
   Serial number: 27140002258940094372
   Coding: 2CFFFF
   Serial number: 5359094403
Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
   Part No SW: 5G0 857 511 D    HW: 5G0 857 511
   Component: FLA           H04 0002
   Revision: AA001001
   Coding: 02018A64727264565625393E01
   Shop #: WSC 73430 031 00161
   ASAM Dataset: EV_HighBeamAssisAU37X 001009
   ROD: EV_HighBeamAssisAU37X.rod
   VCID: 2B162648423E5ED346-807E
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 27081401101110
   Coding: 003003208000048000001000
   VCID: 3E301F1CA14CDB7BF1-806A
   Serial number: 00000000000003739477
   Coding: 110000
   Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    202 2032
   Revision: 00000000    Serial number: 0000037028
   Coding: 01000010005000
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
   ROD: EV_SteerAssisVWBSMQBA_008.rod
   VCID: 3B361608B25ECE53D6-806E
   Serial number: 03091401101660
   Coding: 003001208E00048000801000
   VCID: 3FCE6218A646D273FA-806A
   Serial number: 00000000000003719374
   Coding: 090000
   Coding: 069A010003000200
   Shop #: WSC 00001 001 104857
   VCID: 40CC61E4DBB8AD8B83-8014
   Subsystem 1 - Part No SW: 3D0 941 329 D    HW: 3D0 941 329 D  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 D    HW: 3D0 941 329 D  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 5G0 035 846 A    HW: 5G0 035 846 A
   Component: MU-S-N-ER     041 0430
   Serial number: V1F00509140199
   Coding: 02730901FF00000011110001000800031F0100840100010045
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 271EDA785ED67AB3A2-8072
   Subsystem 1 - Part No SW: 5G0 919 605 D    HW: 5G0 919 605 D
   Component: ABT_Std_Nav  H60 0030
   Serial number: VWZ8Z9PS403JHK
   Subsystem 2 - Part No SW: 5G0 919 866 BD    HW: -----------
   Component:  ECE 2020/21  --- 0094
   Serial number: 30000000235075
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 34243D349F00012B17-8060
   Part No SW: 5Q0 907 383 J    HW: 5Q0 907 383 B
   Component: Anhaenger     H21 0204
   Revision: 8C001003    Serial number: 0410662842
   Coding: 0100000202000000
End----------(Elapsed Time: 01:38, VBatt start/end: 13.2V/13.3V)-----------
sergelhr
saint-prix, France
C?ID=68124
I'm progressing the main contributor was the following channel was set as lamp instead lights, U led full brigth but with xenon on as well! for DRL
(8)-Daytime running lights-Fahrlicht bei TagDaytime running lights
sergelhr
saint-prix, France
C?ID=68124
After changing BCM BYTE 2 from OA to OD FLA and HeadLight Washer back to life as before xenon retrofit the only issue remaining is daylight operation.
with 115833 set as Daytime running lamps , LEd DRL remains off
with 115833 set as Daytime running Lights , LED DRL on but with xenon all the time!!!!!
a suggestion?
Latest admap ->https://drive.google.com/file/d/1QIoBEMn6ARvobJh_KNQ3pBbIxMcLRC8Y/view?usp=sharing
Latest scan->https://drive.google.com/file/d/14NWLzM-uJWy_H5ssSRL5CDS1oBRCmabx/view?usp=sharing
IDE06864-ENG115833-Daytime running lamps-Fahrlicht bei Tag,Daytime running lamps ,4
IDE06864-ENG115832-Daytime running lamps-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,4
IDE06864-ENG116592-Daytime running lamps-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,4
IDE06864-ENG116594-Daytime running lamps-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,4
IDE06864-ENG122184-Daytime running lamps-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,4
IDE06864-ENG115734-Daytime running lamps-Tagfahrlicht nur in Schalterstellung AUTO,not active ,4
IDE06864-ENG116593-Daytime running lamps-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,4
IDE06864-ENG115733-Daytime running lamps-Tagfahrlichtkontrollleuchte,not active ,4
IDE06864-ENG116591-Daytime running lamps-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,4
sergelhr
saint-prix, France
C?ID=68124
alleluia
for ex VLB10 A2 was set to Daytime running lights after changing to Daytime running lamp and IDE06864-ENG115833-Daytime running lamps-Fahrlicht bei Tag,Daytime running lamps ,4 no more issue:eek:
